    4. Neuer Adapter für Roborock-Staubsauger
      breaksrmine @Jey Cee last edited by breaksrmine
      @jey-cee danke geht wieder !
        chuck2941 last edited by
        Hallo, jedesmal wenn der S8 in Aktion ist wird mir der Log mit Warnungen vollgeschrieben, weiß jemand was das ist?
        In den Objekten gibt es keine Einträge dazu.
        24-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapData" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.432 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.begin" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.433 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.end" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.duration" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.area" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.435 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.error" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.complete" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.start_type" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.437 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.clean_type" has no existing object, this might lead to an error in future versions
        2024-11-26 08:09:04.438 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.finish_reason" has no existing object, this might lead to an error in future versions
        T E 2 Replies Last reply Reply Quote 0
        • Matzebhv
          Matzebhv last edited by
          Moin,
          ich habe seit heute den S8 MaxV Ultra.
          Hier kann anscheinend die Karte nicht mehr gezogen werden, das Log läuft über mit:
          Failed to execute get_map_v1 on robot xxxxxxxxxxT0dDsc9ju (roborock.vacuum.a97): Error: Failed to convert JavaScript value `Undefined` into rust type `String` at /opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:647:29 at Array.forEach (<anonymous>) at MapCreator.canvasMap (/opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:624:30) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:84:46)
          Wird das bei dem Modell noch nicht unterstützt?
          Bei dem Vorgänger S6MaxV Ultra hatte ich das Problem nicht.
          Habe die Karte jetzt erstmal deaktiviert.
          Matze
            hansano last edited by
            Bekomme seit ein paa Tage folgende Fehlermeldung:
            roborock.0
            2024-11-30 11:31:54.304	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
            roborock.0
            2024-11-30 11:12:54.298	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
            roborock.0
            2024-11-30 10:59:54.296	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
            roborock.0
            roborock.0
            Hat noch jemand das Problem und eventuell eine Lösung?
              docsnyder7 @hansano last edited by
              bei mir schauts seit dem Update auf js 7.0.3 so aus
              roborock.0
              	2024-11-30 13:45:33.234	error	Login returned empty userdata.
              roborock.0
              	2024-11-30 13:45:33.233	error	Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:85:20)
              roborock.0
              	2024-11-30 13:45:33.228	error	unhandled promise rejection: Login returned empty userdata.
              roborock.0
              	2024-11-30 13:45:33.228	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              	2024-11-30 13:45:33.202	error	Error in getUserData: Login returned empty userdata.
              roborock.0
              	2024-11-30 13:45:32.838	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
              roborock.0
              	2024-11-30 13:45:32.814	info	starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.3
              userdaten stehen im Adapter und sind auch korrekt
              JackDaniel 1 Reply Last reply Reply Quote 0
                Tom_W @chuck2941 last edited by
                @chuck2941
                Hallo Chuck2941,
                das ist bei mir genau das selbe. Hast du schon rausgefunden was dagegen hilft?
                  TimoWald @Tom_W last edited by TimoWald
                  Hallo habe aktuell diese Fehlermeldung. Diese kommt aber nur wenn ich Kartenerstellung aktiviere.
                  Was kann ich dagegen tun?
                  2024-12-07 13:00:18.752 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:20.373 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:21.787 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:24.444 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:26.375 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:28.423 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:30.431 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:32.502 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:34.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:36.428 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:38.402 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:40.751 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:42.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:44.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:46.411 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:48.468 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:49.028 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 240048
                  2024-12-07 13:00:50.514 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:50.963 - info: daswetter.0 (240048) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 7.0.3
                  2024-12-07 13:00:51.008 - info: daswetter.0 (240048) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2024-12-07 13:00:51.522 - info: daswetter.0 (240048) cleaned everything up...
                  2024-12-07 13:00:51.537 - info: host.iobroker instance system.adapter.daswetter.0 having pid 240048 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-12-07 13:00:52.441 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:54.501 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:56.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:00:58.377 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:00.558 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:02.519 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:04.407 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:04.646 - info: solax.0 (70086) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                  2024-12-07 13:01:06.664 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:08.438 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:10.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:12.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:14.367 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:16.430 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:18.613 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:20.397 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:22.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:24.477 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:26.365 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:28.442 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:30.598 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:32.440 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  2024-12-07 13:01:34.439 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                  • JackDaniel
                    JackDaniel @docsnyder7 last edited by
                    @docsnyder7 sagte in Neuer Adapter für Roborock-Staubsauger:
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    bei mir auch, somit ist der adapter im moment tot
                    Ro75 1 Reply Last reply Reply Quote 0
                    • Ro75
                      Ro75 @JackDaniel last edited by
                      @jackdaniel was passiert wenn du auf die vorherige 6.x Version vom js-controler gehst? Bei mir läuft der Adapter so wie er soll.
                      Ro75
                      • JackDaniel
                        JackDaniel last edited by JackDaniel
                        er lief ja schon unter 7.x ohne probleme, es sieht für mich so aus als ob roborock da etwas serverseitig geändert hat (bei der anmeldung)
                        • copystring
                          copystring last edited by
                          Mal die App auf dem Handy öffnen. Eventuell müssen neue AGB angenommen werden.
                          • JackDaniel
                            das war auch mein erster gedanke
                            hab mich sogar ab und wieder angemeldet, brachte aber auch nichts
                            • copystring
                              Manchmal wird man gebannt, wenn zu viele Anfragen verschickt werden. Mal den Router neu starten, sodass man eine neue IP bekommt. Dann sollte es laufen.
                              • JackDaniel
                                hmm ich hab aber eine statische ib...
                                • copystring
                                  Okay. So eine Sperre geht soweit ich weiß maximal 24 Stunden aus meiner Erfahrung heraus. Vielleicht mal den Adapter für einen Tag abschalten.
                                  Ansonsten kann ich leider nicht so viel tun. Ich kann mir gerne mal ein Debuglog angucken, aber ich hatte schon einige solche Fälle und bisher noch keine Lösung außer sich eine neue IP zu holen.
                                  • JackDaniel
                                    ok dann ist der adapter für mich leider geschichte 😞
                                    neu ip gibt es nicht da statisch, und adapter ist schon seit sonntag deaktiviert (und beim start jetzt kam sofort der crash)
                                    und das ich nun nach jahren mit der ip gepannt wurde, ist für mich nicht ganz nachvollziehbar, da ich ja an der nutzung nichts geändert habe
                                    • copystring
                                      Ach so. Okay. Könnte natürlich auch ein anderer Fehler sein. Magst du mir ein Debuglog schicken?
                                      • JackDaniel
                                        kommt auch nicht wirklich viel, die aktuelle dev auf debug gestellt beim start
                                        roborock.0
                                        2024-12-11 13:17:21.875	error	Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
                                        roborock.0
                                        2024-12-11 13:17:21.680	error	Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
                                        roborock.0
                                        2024-12-11 13:17:21.659	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
                                        roborock.0
                                        2024-12-11 13:17:21.402	debug	initializeRoborockApi
                                        roborock.0
                                        2024-12-11 13:17:21.377	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                        roborock.0
                                        2024-12-11 13:17:21.367	info	starting. Version 0.6.17 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.5
                                        roborock.0
                                        2024-12-11 13:17:21.212	debug	Plugin sentry Initialize Plugin (enabled=true)
                                        roborock.0
                                        2024-12-11 13:17:21.190	debug	States connected to redis: 127.0.0.1:6379
                                        roborock.0
                                        2024-12-11 13:17:21.185	debug	States create User PubSub Client
                                        roborock.0
                                        2024-12-11 13:17:21.185	debug	States create System PubSub Client
                                        roborock.0
                                        2024-12-11 13:17:21.182	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                                        roborock.0
                                        2024-12-11 13:17:21.173	debug	Objects connected to redis: 127.0.0.1:6379
                                        roborock.0
                                        2024-12-11 13:17:21.171	debug	Objects client initialize lua scripts
                                        roborock.0
                                        2024-12-11 13:17:21.036	debug	Objects create User PubSub Client
                                        roborock.0
                                        2024-12-11 13:17:21.036	debug	Objects create System PubSub Client
                                        roborock.0
                                        2024-12-11 13:17:21.035	debug	Objects client ready ... initialize now
                                        roborock.0
                                        2024-12-11 13:17:21.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                                          TimoWald @TimoWald last edited by TimoWald
                                          @timowald Keiner eine Lösung für mich?
                                          IOB läuft auf Proxmox.
                                          • Ro75
                                            Ro75 @TimoWald last edited by
                                            @timowald Compact mode aktiv? Für die map wird doch ein Port benötigt.
                                            Ro75
                                            T mcm1957 2 Replies Last reply Reply Quote 0
                                            916
                                            303823
