    4. Neuer Adapter für Roborock-Staubsauger
      hansano last edited by
      Bekomme seit ein paa Tage folgende Fehlermeldung:
      roborock.0
      2024-11-30 11:31:54.304	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
      roborock.0
      2024-11-30 11:12:54.298	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
      roborock.0
      2024-11-30 10:59:54.296	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
      roborock.0
      roborock.0
      Hat noch jemand das Problem und eventuell eine Lösung?
        docsnyder7 @hansano last edited by
        bei mir schauts seit dem Update auf js 7.0.3 so aus
        roborock.0
        	2024-11-30 13:45:33.234	error	Login returned empty userdata.
        roborock.0
        	2024-11-30 13:45:33.233	error	Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:85:20)
        roborock.0
        	2024-11-30 13:45:33.228	error	unhandled promise rejection: Login returned empty userdata.
        roborock.0
        	2024-11-30 13:45:33.228	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        roborock.0
        	2024-11-30 13:45:33.202	error	Error in getUserData: Login returned empty userdata.
        roborock.0
        	2024-11-30 13:45:32.838	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
        roborock.0
        	2024-11-30 13:45:32.814	info	starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.3
        userdaten stehen im Adapter und sind auch korrekt
        JackDaniel 1 Reply Last reply Reply Quote 0
          Tom_W @chuck2941 last edited by
          @chuck2941
          Hallo Chuck2941,
          das ist bei mir genau das selbe. Hast du schon rausgefunden was dagegen hilft?
            TimoWald @Tom_W last edited by TimoWald
            Hallo habe aktuell diese Fehlermeldung. Diese kommt aber nur wenn ich Kartenerstellung aktiviere.
            Was kann ich dagegen tun?
            2024-12-07 13:00:18.752 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:20.373 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:21.787 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:24.444 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:26.375 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:28.423 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:30.431 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:32.502 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:34.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:36.428 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:38.402 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:40.751 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:42.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:44.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:46.411 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:48.468 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:49.028 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 240048
            2024-12-07 13:00:50.514 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:50.963 - info: daswetter.0 (240048) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 7.0.3
            2024-12-07 13:00:51.008 - info: daswetter.0 (240048) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-12-07 13:00:51.522 - info: daswetter.0 (240048) cleaned everything up...
            2024-12-07 13:00:51.537 - info: host.iobroker instance system.adapter.daswetter.0 having pid 240048 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-12-07 13:00:52.441 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:54.501 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:56.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:00:58.377 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:00.558 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:02.519 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:04.407 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:04.646 - info: solax.0 (70086) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
            2024-12-07 13:01:06.664 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:08.438 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:10.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:12.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:14.367 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:16.430 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:18.613 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:20.397 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:22.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:24.477 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:26.365 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:28.442 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:30.598 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:32.440 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            2024-12-07 13:01:34.439 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
            • JackDaniel
              JackDaniel @docsnyder7 last edited by
              @docsnyder7 sagte in Neuer Adapter für Roborock-Staubsauger:
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              bei mir auch, somit ist der adapter im moment tot
              Ro75 1 Reply Last reply Reply Quote 0
              • Ro75
                Ro75 @JackDaniel last edited by
                @jackdaniel was passiert wenn du auf die vorherige 6.x Version vom js-controler gehst? Bei mir läuft der Adapter so wie er soll.
                Ro75
                • JackDaniel
                  JackDaniel last edited by JackDaniel
                  er lief ja schon unter 7.x ohne probleme, es sieht für mich so aus als ob roborock da etwas serverseitig geändert hat (bei der anmeldung)
                  • copystring
                    copystring last edited by
                    Mal die App auf dem Handy öffnen. Eventuell müssen neue AGB angenommen werden.
                    • JackDaniel
                      das war auch mein erster gedanke
                      hab mich sogar ab und wieder angemeldet, brachte aber auch nichts
                      • copystring
                        Manchmal wird man gebannt, wenn zu viele Anfragen verschickt werden. Mal den Router neu starten, sodass man eine neue IP bekommt. Dann sollte es laufen.
                        • JackDaniel
                          hmm ich hab aber eine statische ib...
                          • copystring
                            Okay. So eine Sperre geht soweit ich weiß maximal 24 Stunden aus meiner Erfahrung heraus. Vielleicht mal den Adapter für einen Tag abschalten.
                            Ansonsten kann ich leider nicht so viel tun. Ich kann mir gerne mal ein Debuglog angucken, aber ich hatte schon einige solche Fälle und bisher noch keine Lösung außer sich eine neue IP zu holen.
                            • JackDaniel
                              ok dann ist der adapter für mich leider geschichte 😞
                              neu ip gibt es nicht da statisch, und adapter ist schon seit sonntag deaktiviert (und beim start jetzt kam sofort der crash)
                              und das ich nun nach jahren mit der ip gepannt wurde, ist für mich nicht ganz nachvollziehbar, da ich ja an der nutzung nichts geändert habe
                              • copystring
                                Ach so. Okay. Könnte natürlich auch ein anderer Fehler sein. Magst du mir ein Debuglog schicken?
                                • JackDaniel
                                  kommt auch nicht wirklich viel, die aktuelle dev auf debug gestellt beim start
                                  roborock.0
                                  2024-12-11 13:17:21.875	error	Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
                                  roborock.0
                                  2024-12-11 13:17:21.680	error	Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
                                  roborock.0
                                  2024-12-11 13:17:21.659	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
                                  roborock.0
                                  2024-12-11 13:17:21.402	debug	initializeRoborockApi
                                  roborock.0
                                  2024-12-11 13:17:21.377	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                  roborock.0
                                  2024-12-11 13:17:21.367	info	starting. Version 0.6.17 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.5
                                  roborock.0
                                  2024-12-11 13:17:21.212	debug	Plugin sentry Initialize Plugin (enabled=true)
                                  roborock.0
                                  2024-12-11 13:17:21.190	debug	States connected to redis: 127.0.0.1:6379
                                  roborock.0
                                  2024-12-11 13:17:21.185	debug	States create User PubSub Client
                                  roborock.0
                                  2024-12-11 13:17:21.185	debug	States create System PubSub Client
                                  roborock.0
                                  2024-12-11 13:17:21.182	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                                  roborock.0
                                  2024-12-11 13:17:21.173	debug	Objects connected to redis: 127.0.0.1:6379
                                  roborock.0
                                  2024-12-11 13:17:21.171	debug	Objects client initialize lua scripts
                                  roborock.0
                                  2024-12-11 13:17:21.036	debug	Objects create User PubSub Client
                                  roborock.0
                                  2024-12-11 13:17:21.036	debug	Objects create System PubSub Client
                                  roborock.0
                                  2024-12-11 13:17:21.035	debug	Objects client ready ... initialize now
                                  roborock.0
                                  2024-12-11 13:17:21.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                                    TimoWald @TimoWald last edited by TimoWald
                                    @timowald Keiner eine Lösung für mich?
                                    IOB läuft auf Proxmox.
                                    • Ro75
                                      Ro75 @TimoWald last edited by
                                      @timowald Compact mode aktiv? Für die map wird doch ein Port benötigt.
                                      Ro75
                                      T mcm1957 2 Replies Last reply Reply Quote 0
                                      • copystring
                                        @JackDaniel ich gehe davon aus, dass du den Adapter auch schon mal komplett gelöscht und neu eingerichtet hast?
                                        • JackDaniel
                                          danke das war genau der richtige tip, adapter geht wieder als ob nie etwas gewesen wäre 🤷‍♂️
                                          • copystring
                                            Das Issue von dir auf GitHub kann das also geschlossen werden?
                                            916
                                            303848
