    3. Off Topic
    4. Grafana
    5. Fehler bei Wiederherstellung von Grafana
      wibear @Thomas Braun last edited by
      @thomas-braun sagte in Fehler bei Wiederherstellung von Grafana:
      Ist das Verzeichnis leer, wenn die Freigabe nicht gerade gemountet ist?
      Das Verzeichnis ist nicht leer.
        raspi@raspi:~ $ mount | sort
        binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
        bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        /dev/sda1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
        /dev/sda2 on / type ext4 (rw,noatime)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        proc on /proc type proc (rw,relatime)
        pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
        ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4955)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=388192k,mode=755)
        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=388188k,nr_inodes=97047,mode=700,uid=1000,gid=1000)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        udev on /dev type devtmpfs (rw,nosuid,relatime,size=1672772k,nr_inodes=418193,mode=755)
          wibear @Thomas Braun last edited by wibear
          Da greift schon was auf den Mountpunkt /opt/iobroker/ zu.
            Thomas Braun Most Active @wibear last edited by
            @wibear sagte in Fehler bei Wiederherstellung von Grafana:
            Sollte es aber sein, wenn es als Einhängepunkt fungieren soll.
              Über welches Verzeichnis sprechen wir /opt/iobroker ?
              Was soll ich ändern?
                Wir sprechen vom Mountpunkt /opt/iobroker/backups. Hatte das oben falsch.
                  Dieses Verzeichnis ist ja leer. Was kann es noch sein?
                    @wibear
                    Was passiert denn, wenn du das Ding manuell mountest?
                      Bin mit Linux nicht so vertraut.
                      Wie mounte ich das bitte?
                        @wibear
                        Schauen, ob der Mountpunkt leer ist:
                        ls -l /opt/iobroker/backups
                        dann mounten:
                        sudo mount -t cifs -o username=iobrokerBackup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backups
                        Dein password muss noch gesetzt werden.
                        W 2 Replies Last reply Reply Quote 0
                          dann mounten:
                          Ich habe gemountet und danach wie empfohlen
                          sudo systemctl daemon-reload
                          ausgeführt.
                          raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackup,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backups
                          mount: (hint) your fstab has been modified, but systemd still uses
                                 the old version; use 'systemctl daemon-reload' to reload.
                          raspi@raspi:~ $ ^C
                          raspi@raspi:~ $ sudo systemctl daemon-reload
                          mount error(16): Device or resource busy
                          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                            wibear @wibear last edited by
                            @wibear
                            ich habe umount ausgeführt, danach wieder mount:
                            raspi@raspi:~ $ sudo umount /opt/iobroker/backups
                            raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackp,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobrker/backups
                            raspi@raspi:~ $
                            Es wurde ohne irgendeine Meldung ausgeführt.
                              Das war vor mount
                              raspi@raspi:~ $ ls -l /opt/iobroker/backups
                              total 0
                              und das ist nach mount:
                              raspi@raspi:~ $ ls -l /opt/iobroker/backups                                        total 73984
                              -rwxrwxrwx 1 iobroker iobroker     9507 Dec  1 02:41 grafana_2024_12_01-02_41_35_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker     9505 Dec  8 02:41 grafana_2024_12_08-02_41_41_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  1 02:30 homematic_2024_12_01-02_30_22_3.79.6_backupiobroker.tar.sbk
                              -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  8 02:30 homematic_2024_12_08-02_30_22_3.79.6_backupiobroker.tar.sbk
                              -rwxrwxrwx 1 iobroker iobroker      225 Dec 10 15:20 homematic_2024_12_10-15_20_10_3.79.6_backupiobroker.tar.sbk
                              -rwxrwxrwx 1 iobroker iobroker 28285363 Dec  1 02:41 influxDB_2024_12_01-02_40_29_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker 30373723 Dec  8 02:41 influxDB_2024_12_08-02_40_29_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker  2114413 Dec  1 02:40 iobroker_2024_12_01-02_40_20_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker  2132546 Dec  8 02:40 iobroker_2024_12_08-02_40_20_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker    31808 Dec  1 02:41 javascripts_2024_12_01-02_41_52_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker    32943 Dec  8 02:42 javascripts_2024_12_08-02_41_59_backupiobroker.tar.gz
                                @wibear
                                So soll das aussehen.
                                  Wie soll ich bitte weiter vorgehen?
                                  Oder kann ich es irgenwie manuell machen?
                                    mount/unmount funktioniert manuell.
                                    Warum geht das nicht über Backitup (error 16)?
                                    Wie kann man es über die Konsole einspielen?
                                    Kann ich den Fehler in einer Log suchen?
                                      Erscheint die Meldung denn immer noch?
                                      Du darfst nicht mit irgendwelchen Prozessen (z. B. deinem graphischen Dateimanager) auf den Mountpunkt zugreifen.
                                        Der Fehler ist immer noch da, auch wenn ich nur die Konsole benutze.
                                          Es gibt in der IOB Log diese Meldung:
                                          DATA: {"type":"nas / copy","fileName":"/opt/iobroker/backups/grafana_2024_12_08-02_41_41_backupiobroker.tar.gz","currentTheme":"none","currentProtocol":"http:","stopIOB":false}
                                          Ist stopIOB (false) OK?
                                            @wibear
                                            Das scheint sich singulär auf das Grafana-Backup zu beziehen.
                                            Kann ich aber nix zu sagen, verwende ich nicht.
                                            1974
