    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id
      e-i-k-e @Thomas Braun last edited by e-i-k-e
      Ich habe leider auch das problem mit
      ls: cannot access '/dev/serial/by-ids': No such file or directory
      Ich ziehe gerade mit iobroker um und habe iob neu auf ubuntu 22.04 installiert und anschließend ein iob backup eingespielt.
      Ausgang von iob diag lautet:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
      Operating System: Ubuntu 24.04.1 LTS
                Kernel: Linux 6.8.0-50-generic
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: 4.2023.08-4
         Firmware Date: Thu 2024-02-15
          Firmware Age: 9month 3w 6d
      OS is similar to: debian
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       23:59:11 up 21 min,  1 user,  load average: 0.53, 0.40, 0.45
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Operating System is the current Ubuntu LTS release codenamed 'noble'!
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2024-12-11 23:59:11 CET
                 Universal time: Wed 2024-12-11 22:59:11 UTC
                       RTC time: Wed 2024-12-11 22:59:10
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi sudo users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             10G        3.0G        6.9G        5.3M        846M        7.5G
      Swap:             0B          0B          0B
      Total:           10G        3.0G        6.9G
      Active iob-Instances:   58
               9938 M total memory
               2820 M used memory
               2578 M active memory
                460 M inactive memory
               6572 M free memory
                 54 M buffer memory
                752 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 23:59:11 up 21 min,  1 user,  load average: 0.53, 0.40, 0.45
      Tasks: 179 total,   1 running, 178 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 20.5 us,  4.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   9938.9 total,   6572.1 free,   2820.9 used,    807.5 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7118.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      tmpfs          tmpfs     994M  1.1M  993M   1% /run
      efivarfs       efivarfs  256K   20K  232K   8% /sys/firmware/efi/efivars
      /dev/sda1      ext4       51G  6.8G   45G  14% /
      tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda16     ext4      881M  112M  708M  14% /boot
      /dev/sda15     vfat      105M  6.1M   99M   6% /boot/efi
      tmpfs          tmpfs     994M   12K  994M   1% /run/user/0
      [Wed Dec 11 23:38:08 2024] EXT4-fs (sda1): mounted filesystem 428c45af-c748-4f29-9fe5-d56aa4a3f75e ro with ordered data mode. Quota mode: none.
      [Wed Dec 11 23:38:09 2024] EXT4-fs (sda1): re-mounted 428c45af-c748-4f29-9fe5-d56aa4a3f75e r/w. Quota mode: none.
      [Wed Dec 11 23:38:11 2024] EXT4-fs (sda16): mounted filesystem a4ce610e-4a3c-4ed2-8852-b138eade5b0b r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET        SOURCE     FSTYPE OPTIONS
      /             /dev/sda1  ext4   rw,relatime,discard,errors=remount-ro,commit=30
      `-/boot       /dev/sda16 ext4   rw,relatime
        `-/boot/efi /dev/sda15 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      /var:
      687M    /var/
      344M    /var/cache
      314M    /var/cache/apt
      216M    /var/cache/apt/archives
      199M    /var/lib
      Archived and active journals take up 19.2M in the file system.
      /opt/iobroker/backups:
      27M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      213M    /opt/iobroker/iobroker-data/
      176M    /opt/iobroker/iobroker-data/files
      158M    /opt/iobroker/iobroker-data/files/admin.admin
      157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.1+dfsg-6ubuntu5 500
              500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      ioBroker-Rock       ioBroker-Rock (version: 7.0.6, hostname: ioBroker-Rock , alive, uptime: 1247)
      raspberrypi-display1 raspberrypi-display1 (version: 7.0.2, hostname: raspberrypi-display1, alive, uptime: 1231)
      raspberrypi-display2 raspberrypi-display2 (version: 7.0.2, hostname: raspberrypi-display2, alive, uptime: 1233)
      raspberrypi-display3 raspberrypi-display3 (version: 4.0.24, hostname: raspberrypi-display3, alive, uptime: 1237)
      raspberrypi-display4 raspberrypi-display4 (version: 5.0.19, hostname: raspberrypi-display4, alive, uptime: 1239)
      raspberrypi-display5 raspberrypi-display5 (version: 7.0.2, hostname: raspberrypi-display5, alive, uptime: 1239)
      raspberrypi-slave   raspberrypi-slave (version: 5.0.8, hostname: raspberrypi-slave, alive, uptime: 1235)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.4
      javascript:     8.8.3
      nodejs modules from github:     3
      +-- iobroker.energiefluss-erweitert@0.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#a898e0cd728900620b9bfea0f1710d8720ebf82f)
      | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.2                  : admin                 : ioBroker-Rock                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.admin.3                  : admin                 : ioBroker-Rock                            -  enabled, port: 8900, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : ioBroker-Rock                            -  enabled
      + system.adapter.alexa2.0                 : alexa2                : ioBroker-Rock                            -  enabled
        system.adapter.backitup.0               : backitup              : ioBroker-Rock                            - disabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker-Rock                            -  enabled
        system.adapter.daswetter.0              : daswetter             : ioBroker-Rock                            -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : ioBroker-Rock                            -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : ioBroker-Rock                            -  enabled
      + system.adapter.discovergy.0             : discovergy            : ioBroker-Rock                            -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker-Rock                            - disabled
        system.adapter.dwd.0                    : dwd                   : ioBroker-Rock                            -  enabled
      + system.adapter.echarts.0                : echarts               : ioBroker-Rock                            -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker-Rock                            -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker-Rock                            -  enabled
        system.adapter.flot.0                   : flot                  : ioBroker-Rock                            -  enabled
      + system.adapter.hass.0                   : hass                  : ioBroker-Rock                            -  enabled, port: 8123
      + system.adapter.heatingcontrol.1         : heatingcontrol        : ioBroker-Rock                            -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Rock                            -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
        system.adapter.hoover.0                 : hoover                : ioBroker-Rock                            - disabled
        system.adapter.ical.0                   : ical                  : ioBroker-Rock                            -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-Rock                            -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-Rock                            -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Rock                            -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Rock                            -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-Rock                            -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-Rock                            -  enabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker-Rock                            -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : ioBroker-Rock                            -  enabled
      + system.adapter.javascript.2             : javascript            : raspberrypi-display1                     -  enabled
      + system.adapter.javascript.3             : javascript            : raspberrypi-display4                     -  enabled
      + system.adapter.javascript.4             : javascript            : raspberrypi-display2                     -  enabled
      + system.adapter.javascript.5             : javascript            : raspberrypi-display5                     -  enabled
      + system.adapter.midea.0                  : midea                 : ioBroker-Rock                            -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
        system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
      + system.adapter.mihome.0                 : mihome                : ioBroker-Rock                            -  enabled, port: 9898, bind: 192.168.3.100
      + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker-Rock                            -  enabled
      + system.adapter.modbus.0                 : modbus                : ioBroker-Rock                            -  enabled
        system.adapter.mqtt-client.0            : mqtt-client           : ioBroker-Rock                            - disabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Rock                            -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.musiccast.0              : musiccast             : ioBroker-Rock                            -  enabled
      + system.adapter.nut.0                    : nut                   : ioBroker-Rock                            -  enabled
        system.adapter.openweathermap.0         : openweathermap        : ioBroker-Rock                            -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBroker-Rock                            -  enabled, port: 8006
      + system.adapter.rpi2.1                   : rpi2                  : raspberrypi-display1                     -  enabled
      + system.adapter.rpi2.2                   : rpi2                  : raspberrypi-display2                     -  enabled
      + system.adapter.rpi2.3                   : rpi2                  : raspberrypi-display3                     -  enabled
      + system.adapter.rpi2.4                   : rpi2                  : raspberrypi-display4                     -  enabled
      + system.adapter.rpi2.5                   : rpi2                  : raspberrypi-display5                     -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Rock                            -  enabled, port: 45000, bind: 192.168.3.100
      + system.adapter.scenes.0                 : scenes                : ioBroker-Rock                            -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker-Rock                            -  enabled, port: 1890, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : ioBroker-Rock                            -  enabled, port: 1899, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Rock                            -  enabled
        system.adapter.simple-api.0             : simple-api            : ioBroker-Rock                            - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker-Rock                            -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : ioBroker-Rock                            -  enabled
      + system.adapter.sonoff.0                 : sonoff                : ioBroker-Rock                            -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-Rock                            -  enabled
        system.adapter.sprinklecontrol.0        : sprinklecontrol       : ioBroker-Rock                            - disabled
      + system.adapter.statistics.0             : statistics            : ioBroker-Rock                            -  enabled
      + system.adapter.synology.0               : synology              : ioBroker-Rock                            -  enabled, port: 5001
      + system.adapter.telegram.0               : telegram              : ioBroker-Rock                            -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : ioBroker-Rock                            -  enabled
        system.adapter.unifi.0                  : unifi                 : ioBroker-Rock                            - disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker-Rock                            -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker-Rock                            -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-Rock                            -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker-Rock                            -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-Rock                            -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : ioBroker-Rock                            -  enabled
        system.adapter.vis-bars.0               : vis-bars              : ioBroker-Rock                            -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-Rock                            -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-Rock                            -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-Rock                            -  enabled
        system.adapter.vis-history.0            : vis-history           : ioBroker-Rock                            -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Rock                            -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-Rock                            -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Rock                            -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-Rock                            -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Rock                            -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-Rock                            -  enabled
        system.adapter.vis-material.0           : vis-material          : ioBroker-Rock                            -  enabled
        system.adapter.vis-metro.0              : vis-metro             : ioBroker-Rock                            -  enabled
        system.adapter.vis-players.0            : vis-players           : ioBroker-Rock                            -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-Rock                            -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-Rock                            -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Rock                            -  enabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker-Rock                            -  enabled
        system.adapter.vis.0                    : vis                   : ioBroker-Rock                            -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : ioBroker-Rock                            -  enabled
        system.adapter.web-speedy.0             : web-speedy            : ioBroker-Rock                            - disabled
      + system.adapter.web.0                    : web                   : ioBroker-Rock                            -  enabled, port: 8082, bind: 192.168.3.100 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : ioBroker-Rock                            -  enabled, port: 8083, bind: 192.168.3.100, run as: admin
      + system.adapter.wolf-smartset.0          : wolf-smartset         : ioBroker-Rock                            -  enabled
        system.adapter.worx.0                   : worx                  : ioBroker-Rock                            - disabled
      + system.adapter.yamaha.0                 : yamaha                : ioBroker-Rock                            -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : ioBroker-Rock                            -  enabled
        system.adapter.yr.0                     : yr                    : ioBroker-Rock                            -  enabled
      + system.adapter.zigbee.0                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.4.4    , installed 7.4.4
      Adapter    "alarm"        : 3.6.4    , installed 3.6.4
      Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daswetter"    : 3.2.1    , installed 3.2.1
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovergy"   : 0.5.13   , installed 0.5.13
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "energiefluss-erweitert": 0.6.0, installed 0.6.0
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hoover"       : 0.1.3    , installed 0.1.3
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "midea"        : 0.0.7    , installed 0.0.7
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
      Adapter    "modbus"       : 6.4.0    , installed 6.4.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
      Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "statistics"   : 3.1.0    , installed 3.1.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.1, installed 1.1.1
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-jaeger-design": 1.3.9, installed 1.3.9
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "vw-connect"   : 0.6.1    , installed 0.6.1
      Adapter    "web"          : 6.3.1    , installed 6.3.1
      Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
      Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
      Adapter    "worx"         : 3.1.1    , installed 3.1.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
      Objects and States
      Objects:        39194
      States:         36289
      Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu noble-backports InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.3.100:2010      0.0.0.0:*               LISTEN      1001       11540      1563/io.hm-rpc.2
      tcp        0      0 192.168.3.100:2001      0.0.0.0:*               LISTEN      1001       9811       1487/io.hm-rpc.0
      tcp        0      0 192.168.3.100:8701      0.0.0.0:*               LISTEN      1001       11703      1683/io.hm-rpc.1
      tcp        0      0 192.168.3.100:45000     0.0.0.0:*               LISTEN      1001       12502      1752/io.sainlogic.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          715        1/init
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8188       1273/io.sonoff.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       10687      1373/io.mqtt.0
      tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       11519      1548/io.shelly.1
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      991        6774       633/systemd-resolve
      tcp        0      0 192.168.3.100:8083      0.0.0.0:*               LISTEN      1001       13321      1917/io.web.1
      tcp        0      0 192.168.3.100:8082      0.0.0.0:*               LISTEN      1001       12687      1977/io.web.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      991        6772       633/systemd-resolve
      tcp6       0      0 :::8900                 :::*                    LISTEN      1001       8070       1089/io.admin.3
      tcp6       0      0 :::22                   :::*                    LISTEN      0          8316       1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          3605       1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8885       973/io.admin.2
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11624      1638/io.shelly.0
      udp        0      0 0.0.0.0:47970           0.0.0.0:*                           1001       11834      1812/io.milight-sma
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           991        6773       633/systemd-resolve
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           991        6771       633/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          716        1/init
      udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       10200      1868/io.musiccast.0
      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       11644      1653/io.mihome.0
      udp6       0      0 :::111                  :::*                                0          717        1/init
        port: 80
      2024-12-11 23:59:05.006  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:07.010  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:09.012  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:10.542  - info: influxdb.0 (1202) Store 272 buffered influxDB history points
      2024-12-11 23:59:11.015  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:13.018  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:15.019  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:17.022  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:19.024  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:21.027  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:23.030  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:25.031  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:27.034  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:29.036  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:31.039  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:33.041  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:35.044  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
      2024-12-11 23:59:37.046  - warn: smartmeter.0 (1333) No or too long answer from Serial D
      Copy text starting here:
      ```bash
                              v.2024-10-19
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs  and npm
      nodeJS installation is correct
      MEMORY:
      Mem:             10G        3.0G        6.6G        5.3M        1.1G        7.4G
      Swap:             0B          0B          0B
      Total:           10G        3.0G        6.6G
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.4.4
      Objects type: redis
      States  type: redis
      Objects:                39194
      States:                 36289
      Size of iob-Database:
      768K    /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
        Thomas Braun Most Active @e-i-k-e last edited by
        @e-i-k-e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
        Virtualization: kvm
        Der Stick muss an die VM durchgereicht werden.
        Setz den user in die Gruppe adm rein. Und warum nennt man den user überhaupt ``pi`? Ist doch nicht mal ein Raspberry...
        Und bring den Versions-Zoo bei den ganzen hosts auf den gleichen aktuellen Stand.
          @thomas-braun sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
          Virtualization: kvm
          Die sind über Proxmox durchgereicht, werden über lsusb in der VM auch angezeigt.
          Kann ich machen, der User pi ist historisch mitgewandert.
          Hat das mit der Gruppe adm, denn etwas mit meinem "ls: cannot access '/dev/serial/by-ids': No such file or directory" zutun? Oder wofür wird dies benötigt?
          Wird nach und nach, leider sind einige Distribution so alt, dass ein update nicht ohne weiteres mehr möglich ist.
            Dann haste da viel zu lange gepennt.
            Die Gruppe adm wird für administrative Dinge benötigt. Unter anderem um logfiles auch ohne root-Rechte lesen zu können.
            E 2 Replies Last reply Reply Quote 0
              Da muss ich dir recht geben 😉
                Ich komme aber trotzdem leider nicht weiter.
                pi@iobroker:~$ lsusb
                Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                Bus 002 Device 002: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                Bus 002 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                pi@iobroker:~$ sudo ls /dev/serial/by-id
                ls: cannot access '/dev/serial/by-id': No such file or directory
                  @e-i-k-e
                  Schau dir per
                  dmesg -wT
                  die Meldungen an, wenn der Stickk entfernt und nach einer Minute wieder eingesteckt wird.
                    @e-i-k-e
                    Schau dir per
                    dmesg -wT
                    [Thu Dec 12 21:05:18 2024] usb 2-1: USB disconnect, device number 5
                    [Thu Dec 12 21:05:18 2024] usb 2-2: USB disconnect, device number 4
                    [Thu Dec 12 21:05:18 2024] workqueue: hub_event hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
                    [Thu Dec 12 21:05:18 2024] usb 2-2: new full-speed USB device number 6 using xhci_hcd
                    [Thu Dec 12 21:05:18 2024] usb 2-2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                    [Thu Dec 12 21:05:18 2024] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                    [Thu Dec 12 21:05:18 2024] usb 2-2: Product: CP2102 USB to UART Bridge Controller
                    [Thu Dec 12 21:05:18 2024] usb 2-2: Manufacturer: Silicon Labs
                    [Thu Dec 12 21:05:18 2024] usb 2-2: SerialNumber: 0021
                    [Thu Dec 12 21:05:54 2024] usb 2-1: new high-speed USB device number 7 using xhci_hcd
                    [Thu Dec 12 21:05:54 2024] usb 2-1: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
                    [Thu Dec 12 21:05:54 2024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                    [Thu Dec 12 21:05:54 2024] usb 2-1: Product: XDS110 (03.00.00.25) Embed with CMSIS-DAP
                    [Thu Dec 12 21:05:54 2024] usb 2-1: Manufacturer: Texas Instruments
                    [Thu Dec 12 21:05:54 2024] usb 2-1: SerialNumber: L1100L7S
                    [Thu Dec 12 21:05:54 2024] hid-generic 0003:0451:BEF3.0003: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.25) Embed with CMSIS-DAP] on usb-0000:01:1b.0-1/input5
                    Ein USB-Device habe ich stecken lassen und eins habe ich getrennt und nach einer gewissen zeit, wieder verbunden.
                      Und haben die auch Bezeichnungen?
                        Beide entfern.
                        Erst "Silicon Labs CP210x UART Bridge", anschließend " Texas Instruments, Inc. CC1352R1 Launchpad".
                        [Thu Dec 12 21:13:04 2024] usb 2-2: USB disconnect, device number 6
                        [Thu Dec 12 21:13:10 2024] usb 2-1: USB disconnect, device number 7
                        Einen wieder Verbunden "Texas Instruments, Inc. CC1352R1 Launchpad".
                        [Thu Dec 12 21:14:40 2024] usb 2-1: new high-speed USB device number 8 using xhci_hcd
                        [Thu Dec 12 21:14:40 2024] usb 2-1: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
                        [Thu Dec 12 21:14:40 2024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        [Thu Dec 12 21:14:40 2024] usb 2-1: Product: XDS110 (03.00.00.25) Embed with CMSIS-DAP
                        [Thu Dec 12 21:14:40 2024] usb 2-1: Manufacturer: Texas Instruments
                        [Thu Dec 12 21:14:40 2024] usb 2-1: SerialNumber: L1100L7S
                        [Thu Dec 12 21:14:40 2024] hid-generic 0003:0451:BEF3.0004: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.25) Embed with CMSIS-DAP] on usb-0000:01:1b.0-1/input5
                          @e-i-k-e
                          Das ist nur der Debugger.
                          Keine Ahnung, warum das eigentliche Device nicht gesehen wird.
                          Verwendest du da einen USB-Hub oder sowas? Stick am Verlängerungskabel?
                            @e-i-k-e
                            Es ist ein kurzes USB-Verlängerungskabel dazwischen. Aber diese Konstellation hat an der vorherigen Hardware genauso funktioniert.
                            Warum erhalte ich keine Ausgabe durch ls /dev/serial/by-id
                            Sondern nur die Meldung "ls: cannot access '/dev/serial/by-id': No such file or directory" ?
                              Weil der Kernel/udev das Gerät nicht als serielles Gerät erkennt und deswegen auch die Links nicht angelegt werden.
                                Kann ich noch was machen oder prüfen?
                                Ich finde es ja sehr merkwürdig, dass es nicht funktioniert.
                                Ich habe eine neue VM mit einer anderen Version (22.04) von Ubuntu aufgesetzt.
                                Gleiches Problem.
                                root@iobroker:~# lsusb
                                Bus 002 Device 002: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                                root@iobroker:~# ls -l /dev/serial/by-id
                                root@iobroker:~
                                  @e-i-k-e
                                  Joh, du sollst auch partout nicht als root herumeiern.
                                    Ist klar. Ist auch nur eine neue Test-Umgebung.
                                      @e-i-k-e
                                      Egal. Macht man ganz grundsätzlich nicht.
                                        Okay.
                                        Was kann ich bei meinem Problem noch machen?
                                        Kann das an der neuen Hardware (HP T640) bzw. einer falschen Bios Einstellung liegen?
                                          Thomas Braun Most Active @e-i-k-e last edited by Thomas Braun
                                          @e-i-k-e
                                          Ich weiß, das nutzt dir nix, aber richtig schaut das Einstecken eines seriellen Devices so aus:
                                          [Thu Dec 12 22:57:10 2024] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
                                          [Thu Dec 12 22:57:10 2024] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                                          [Thu Dec 12 22:57:10 2024] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                          [Thu Dec 12 22:57:10 2024] usb 1-1.3: Product: slae.sh cc2652rb stick - slaesh's iot stuff
                                          [Thu Dec 12 22:57:10 2024] usb 1-1.3: Manufacturer: Silicon Labs
                                          [Thu Dec 12 22:57:10 2024] usb 1-1.3: SerialNumber: 00_12_4B_00_23_93_2C_A8
                                          [Thu Dec 12 22:57:10 2024] cp210x 1-1.3:1.0: cp210x converter detected
                                          [Thu Dec 12 22:57:10 2024] usb 1-1.3: cp210x converter now attached to ttyUSB0
                                          Dann gibt es auch die Geräte-Datei und den Link by-id dorthin:
                                          echad@chet:~ $ ls -la /dev/serial/by-id/
                                          total 0
                                          drwxr-xr-x 2 root root 60 Dec 12 22:57 .
                                          drwxr-xr-x 4 root root 80 Dec 12 22:57 ..
                                          lrwxrwxrwx 1 root root 13 Dec 12 22:57 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                                          echad@chet:~ $
                                            Ich habe gerade eine dritte VM aufgesetzt, diesmal mit Debian 12.
                                            pi@localhost:~$ sudo ls -l /dev/serial/by-id
                                            [sudo] password for pi:
                                            total 0
                                            lrwxrwxrwx 1 root root 13 Dec 12 22:55 usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100L7S-if00 -> ../../ttyACM0
                                            lrwxrwxrwx 1 root root 13 Dec 12 22:55 usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100L7S-if03 -> ../../ttyACM1
                                            Verstehe nicht, warum es jetzt klappt.
                                            14838
