    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id
      e-i-k-e @Thomas Braun last edited by
      Ich komme aber trotzdem leider nicht weiter.
      pi@iobroker:~$ lsusb
      Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
      Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 002 Device 002: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
      Bus 002 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
      Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      pi@iobroker:~$ sudo ls /dev/serial/by-id
      ls: cannot access '/dev/serial/by-id': No such file or directory
        Thomas Braun Most Active @e-i-k-e last edited by
        @e-i-k-e
        Schau dir per
        dmesg -wT
        die Meldungen an, wenn der Stickk entfernt und nach einer Minute wieder eingesteckt wird.
          e-i-k-e @Thomas Braun last edited by e-i-k-e
          @thomas-braun sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
          @e-i-k-e
          Schau dir per
          dmesg -wT
          [Thu Dec 12 21:05:18 2024] usb 2-1: USB disconnect, device number 5
          [Thu Dec 12 21:05:18 2024] usb 2-2: USB disconnect, device number 4
          [Thu Dec 12 21:05:18 2024] workqueue: hub_event hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
          [Thu Dec 12 21:05:18 2024] usb 2-2: new full-speed USB device number 6 using xhci_hcd
          [Thu Dec 12 21:05:18 2024] usb 2-2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
          [Thu Dec 12 21:05:18 2024] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [Thu Dec 12 21:05:18 2024] usb 2-2: Product: CP2102 USB to UART Bridge Controller
          [Thu Dec 12 21:05:18 2024] usb 2-2: Manufacturer: Silicon Labs
          [Thu Dec 12 21:05:18 2024] usb 2-2: SerialNumber: 0021
          [Thu Dec 12 21:05:54 2024] usb 2-1: new high-speed USB device number 7 using xhci_hcd
          [Thu Dec 12 21:05:54 2024] usb 2-1: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
          [Thu Dec 12 21:05:54 2024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [Thu Dec 12 21:05:54 2024] usb 2-1: Product: XDS110 (03.00.00.25) Embed with CMSIS-DAP
          [Thu Dec 12 21:05:54 2024] usb 2-1: Manufacturer: Texas Instruments
          [Thu Dec 12 21:05:54 2024] usb 2-1: SerialNumber: L1100L7S
          [Thu Dec 12 21:05:54 2024] hid-generic 0003:0451:BEF3.0003: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.25) Embed with CMSIS-DAP] on usb-0000:01:1b.0-1/input5
          Ein USB-Device habe ich stecken lassen und eins habe ich getrennt und nach einer gewissen zeit, wieder verbunden.
            @e-i-k-e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
            Und haben die auch Bezeichnungen?
              Beide entfern.
              Erst "Silicon Labs CP210x UART Bridge", anschließend " Texas Instruments, Inc. CC1352R1 Launchpad".
              [Thu Dec 12 21:13:04 2024] usb 2-2: USB disconnect, device number 6
              [Thu Dec 12 21:13:10 2024] usb 2-1: USB disconnect, device number 7
              Einen wieder Verbunden "Texas Instruments, Inc. CC1352R1 Launchpad".
              [Thu Dec 12 21:14:40 2024] usb 2-1: new high-speed USB device number 8 using xhci_hcd
              [Thu Dec 12 21:14:40 2024] usb 2-1: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
              [Thu Dec 12 21:14:40 2024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [Thu Dec 12 21:14:40 2024] usb 2-1: Product: XDS110 (03.00.00.25) Embed with CMSIS-DAP
              [Thu Dec 12 21:14:40 2024] usb 2-1: Manufacturer: Texas Instruments
              [Thu Dec 12 21:14:40 2024] usb 2-1: SerialNumber: L1100L7S
              [Thu Dec 12 21:14:40 2024] hid-generic 0003:0451:BEF3.0004: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.25) Embed with CMSIS-DAP] on usb-0000:01:1b.0-1/input5
                @e-i-k-e
                Das ist nur der Debugger.
                Keine Ahnung, warum das eigentliche Device nicht gesehen wird.
                Verwendest du da einen USB-Hub oder sowas? Stick am Verlängerungskabel?
                  @e-i-k-e
                  Es ist ein kurzes USB-Verlängerungskabel dazwischen. Aber diese Konstellation hat an der vorherigen Hardware genauso funktioniert.
                  Warum erhalte ich keine Ausgabe durch ls /dev/serial/by-id
                  Sondern nur die Meldung "ls: cannot access '/dev/serial/by-id': No such file or directory" ?
                    Weil der Kernel/udev das Gerät nicht als serielles Gerät erkennt und deswegen auch die Links nicht angelegt werden.
                      Kann ich noch was machen oder prüfen?
                      Ich finde es ja sehr merkwürdig, dass es nicht funktioniert.
                      Ich habe eine neue VM mit einer anderen Version (22.04) von Ubuntu aufgesetzt.
                      Gleiches Problem.
                      root@iobroker:~# lsusb
                      Bus 002 Device 002: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                      root@iobroker:~# ls -l /dev/serial/by-id
                      root@iobroker:~
                        @e-i-k-e
                        Joh, du sollst auch partout nicht als root herumeiern.
                          Ist klar. Ist auch nur eine neue Test-Umgebung.
                            @e-i-k-e
                            Egal. Macht man ganz grundsätzlich nicht.
                              Okay.
                              Was kann ich bei meinem Problem noch machen?
                              Kann das an der neuen Hardware (HP T640) bzw. einer falschen Bios Einstellung liegen?
                                Thomas Braun Most Active @e-i-k-e last edited by Thomas Braun
                                @e-i-k-e
                                Ich weiß, das nutzt dir nix, aber richtig schaut das Einstecken eines seriellen Devices so aus:
                                [Thu Dec 12 22:57:10 2024] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
                                [Thu Dec 12 22:57:10 2024] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                                [Thu Dec 12 22:57:10 2024] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                [Thu Dec 12 22:57:10 2024] usb 1-1.3: Product: slae.sh cc2652rb stick - slaesh's iot stuff
                                [Thu Dec 12 22:57:10 2024] usb 1-1.3: Manufacturer: Silicon Labs
                                [Thu Dec 12 22:57:10 2024] usb 1-1.3: SerialNumber: 00_12_4B_00_23_93_2C_A8
                                [Thu Dec 12 22:57:10 2024] cp210x 1-1.3:1.0: cp210x converter detected
                                [Thu Dec 12 22:57:10 2024] usb 1-1.3: cp210x converter now attached to ttyUSB0
                                Dann gibt es auch die Geräte-Datei und den Link by-id dorthin:
                                echad@chet:~ $ ls -la /dev/serial/by-id/
                                total 0
                                drwxr-xr-x 2 root root 60 Dec 12 22:57 .
                                drwxr-xr-x 4 root root 80 Dec 12 22:57 ..
                                lrwxrwxrwx 1 root root 13 Dec 12 22:57 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                                echad@chet:~ $
                                  Ich habe gerade eine dritte VM aufgesetzt, diesmal mit Debian 12.
                                  pi@localhost:~$ sudo ls -l /dev/serial/by-id
                                  [sudo] password for pi:
                                  total 0
                                  lrwxrwxrwx 1 root root 13 Dec 12 22:55 usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100L7S-if00 -> ../../ttyACM0
                                  lrwxrwxrwx 1 root root 13 Dec 12 22:55 usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100L7S-if03 -> ../../ttyACM1
                                  Verstehe nicht, warum es jetzt klappt.
                                    Weil es Debian ist... 😉
                                    E 1 Reply Last reply Reply Quote 3
                                      😉 bedeutet, dass Debian „besser“ für diesen Anwendungsfall wäre?
                                        @e-i-k-e
                                        Ist es ohnehin... Ubuntu ist ja nur der zweite Aufguss.
                                        14836
