    4. Update von nodejs auf 20.x schiefgegangen?
      legro @Thomas Braun last edited by legro
      Ich habe iobroker nodejs-update eingegeben, weil dies ja die Installation ebenfalls überprüft. Herausgekommen ist dies ..
      ioBroker nodejs fixer 2024-10-10
      Recommended nodejs-version is: 20.18.1
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs 	v20.18.1
      /usr/bin/node 		v20.18.1
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.29.4
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
      Nothing to do - Your installation is using the correct paths.
      Nothing to do - Your version is the recommended one.
      ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
      *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
       *** DO NOT use 'nodejs-update' as part of a regular update process! ***
      Ich dachte natürlich, hurra - es ist alles in Ordnung. Leider ist dem nicht so.
      iob diag liefert ..
      Copy text starting here:
      ```bash
      			v.2024-10-19
       Static hostname: raspiBullseye
             Icon name: computer
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		64 bit
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      Display-Server: 	false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	0
      Pending iob updates: 	1
      Nodejs-Installation:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.2G        3.3G        3.6G        1.1M        1.4G        4.9G
      Swap:           209M          0B        209M
      Total:          8.4G        3.3G        3.8G
      Active iob-Instances: 	32
      Upgrade policy: none
      ioBroker Core: 		js-controller 		7.0.3
      			admin 			7.1.5
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspiBullseye                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspiBullseye                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		20716
      States: 		17417
      Size of iob-Database:
      50M	/opt/iobroker/iobroker-data/objects.jsonl
      17M	/opt/iobroker/iobroker-data/states.jsonl
      Operating System is the current Debian stable version codenamed 'bookworm'!
      Die Langversion ist in Arbeit und poste ich gleich.
      haselchen Thomas Braun 3 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @legro last edited by
        @legro
        Ist kein Node 20 Fehler.
        Hat mit dem Adapter zu tun.
        Da steht zwar Node22 , aber in dem Issue wird Dein Fehler aus dem Log behandelt.
        https://github.com/MyHomeMyData/ioBroker.e3oncan/issues/65
        ioBroker-Bot created this issue in MyHomeMyData/ioBroker.e3oncan
        closed Compatibility check and testing for node.js 22 #65
          Thomas Braun Most Active @legro last edited by
          @legro sagte in Update von nodejs auf 20.x schiefgegangen?:
          iobroker nodejs-updatiob diag
          ist ja auch Quatsch...
          iob diag
          muss das heißen.
          Rasperry ggfls. mit der Testversion von hier anpacken:
          https://forum.iobroker.net/topic/59549/iob-diag-skript
          • haselchen
            @legro
            Das ist vermutlich die Lösung vom Entwickler
              Hier die Langversion ..
              ========== Start marking the full check here ===========
              bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Model		: Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               12:44:37 up 32 min,  3 users,  load average: 0.85, 1.08, 1.09
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Sat 2024-12-14 12:44:37 CET
                         Universal time: Sat 2024-12-14 11:44:37 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Mem:            8.2G        3.0G        3.9G        1.1M        1.4G        5.2G
              Swap:           209M          0B        209M
              Total:          8.4G        3.0G        4.1G
                       7812 M total memory
                       2886 M used memory
                       3054 M active memory
                        783 M inactive memory
                       3722 M free memory
                        155 M buffer memory
                       1186 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 12:44:38 up 32 min,  3 users,  load average: 0.86, 1.08, 1.09
              Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 57.1 us, 14.3 sy,  0.0 ni, 28.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   7812.3 total,   3722.4 free,   2886.9 used,   1341.8 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4925.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              /dev/root      ext4       29G   16G   12G  58% /
              devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     1.6G  932K  1.6G   1% /run
              /dev/mmcblk0p1 vfat      253M   33M  220M  13% /boot
              tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
              [Sat Dec 14 12:12:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:AC:B4:A2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=5ace6bce-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sat Dec 14 12:12:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sat Dec 14 12:12:26 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sat Dec 14 12:12:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
              /var:
              6.0G	/var/
              2.9G	/var/lib
              2.6G	/var/log
              2.5G	/var/log/journal/71ce3d9ea88f4118a23250ffbeda1105
              Journal file /var/log/journal/71ce3d9ea88f4118a23250ffbeda1105/system@000617b59b4419c3-7f20c1d2455234ec.journal~ is truncated, ignoring file.
              Archived and active journals take up 2.4G in the file system.
              /opt/iobroker/backups:
              805M	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.4G	/opt/iobroker/iobroker-data/
              1.1G	/opt/iobroker/iobroker-data/files
              617M	/opt/iobroker/iobroker-data/files/javascript.admin
              560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
              558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
              27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
              26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
              26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
              24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              tcp
              *** NodeJS-Installation ***
              /usr/bin/npm 		10.8.2
              /usr/bin/npx 		10.8.2
              nodejs:
                Version table:
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspiBullseye       raspiBullseye (version: 7.0.3, hostname: raspiBullseye , alive, uptime: 1907)
              Core adapters versions
              js-controller: 	7.0.3
              admin: 		7.1.5
              javascript: 	8.8.3
              nodejs modules from github: 	0
              Adapter State
              + system.adapter.backitup.0               : backitup              : raspiBullseye                            -  enabled
                system.adapter.birthdays.0              : birthdays             : raspiBullseye                            -  enabled
                system.adapter.bydhvs.0                 : bydhvs                : raspiBullseye                            - disabled
              + system.adapter.daikin.0                 : daikin                : raspiBullseye                            -  enabled
              + system.adapter.daikin.1                 : daikin                : raspiBullseye                            -  enabled
              + system.adapter.daikin.2                 : daikin                : raspiBullseye                            -  enabled
                system.adapter.daswetter.0              : daswetter             : raspiBullseye                            -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : raspiBullseye                            -  enabled
              + system.adapter.discovery.0              : discovery             : raspiBullseye                            -  enabled
                system.adapter.dwd.0                    : dwd                   : raspiBullseye                            -  enabled
                system.adapter.e3oncan.0                : e3oncan               : raspiBullseye                            -  enabled
              + system.adapter.echarts.0                : echarts               : raspiBullseye                            -  enabled
                system.adapter.feiertage.0              : feiertage             : raspiBullseye                            -  enabled
                system.adapter.flexcharts.0             : flexcharts            : raspiBullseye                            -  enabled
              + system.adapter.fronius.0                : fronius               : raspiBullseye                            -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspiBullseye                            -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspiBullseye                            -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : raspiBullseye                            -  enabled, port: 42010
              + system.adapter.hue.0                    : hue                   : raspiBullseye                            -  enabled, port: 80
                system.adapter.ical.0                   : ical                  : raspiBullseye                            -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspiBullseye                            -  enabled
                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspiBullseye                            -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : raspiBullseye                            -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspiBullseye                            -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspiBullseye                            -  enabled
              + system.adapter.influxdb.0               : influxdb              : raspiBullseye                            -  enabled, port: 8086
              + system.adapter.javascript.0             : javascript            : raspiBullseye                            -  enabled
                system.adapter.modbus.0                 : modbus                : raspiBullseye                            - disabled
                system.adapter.modbus.1                 : modbus                : raspiBullseye                            - disabled
                system.adapter.modbus.2                 : modbus                : raspiBullseye                            - disabled
              + system.adapter.netatmo.0                : netatmo               : raspiBullseye                            -  enabled
              + system.adapter.nuki-extended.0          : nuki-extended         : raspiBullseye                            -  enabled
              + system.adapter.pushover.0               : pushover              : raspiBullseye                            -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : raspiBullseye                            -  enabled
              + system.adapter.scenes.0                 : scenes                : raspiBullseye                            -  enabled
              + system.adapter.shelly.0                 : shelly                : raspiBullseye                            -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.simple-api.0             : simple-api            : raspiBullseye                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspiBullseye                            -  enabled
              + system.adapter.telegram.0               : telegram              : raspiBullseye                            -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : raspiBullseye                            -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspiBullseye                            -  enabled
              + system.adapter.tuya.0                   : tuya                  : raspiBullseye                            -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspiBullseye                            -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspiBullseye                            -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspiBullseye                            -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspiBullseye                            -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspiBullseye                            -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspiBullseye                            -  enabled
                system.adapter.vis-map.0                : vis-map               : raspiBullseye                            -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : raspiBullseye                            -  enabled
                system.adapter.vis-metro.0              : vis-metro             : raspiBullseye                            -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspiBullseye                            -  enabled
                system.adapter.vis.0                    : vis                   : raspiBullseye                            -  enabled
              + system.adapter.yahka.0                  : yahka                 : raspiBullseye                            -  enabled
              + system.adapter.zigbee.0                 : zigbee                : raspiBullseye                            -  enabled, port: tcp://192.168.4.92:6638
              + instance is alive
              ioBroker-Repositories
              │ (index) │ name          │ url                                                     │ auto upgrade │
              │ 0       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
              │ 1       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
              │ 2       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
              │ 3       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
              Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
              Adapter    "daikin"       : 1.4.2    , installed 1.4.2
              Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "e3oncan"      : 0.10.3   , installed 0.10.3
              Adapter    "echarts"      : 1.9.2    , installed 1.9.2
              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
              Adapter    "fronius"      : 2.1.1    , installed 1.1.3  [Updatable]
              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "hue"          : 3.13.1   , installed 3.13.1
              Adapter    "ical"         : 1.16.1   , installed 1.16.1
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.3    , installed 7.0.3
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
              Adapter    "scenes"       : 3.2.3    , installed 3.2.3
              Adapter    "shelly"       : 8.2.1    , installed 8.2.1
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects: 	20716
              States: 	17408
              Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
              Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://deb.debian.org/debian bookworm InRelease
              Hit:4 https://apt.grafana.com stable InRelease
              Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:6 https://repos.influxdata.com/debian stable InRelease
              Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:8 https://apt.pivccu.de/piVCCU stable InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12093      992/dnsmasq
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16689      1112/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1995       1112/iobroker.js-co
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15170      983/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:43165         0.0.0.0:*               LISTEN      1001       20190      2952/io.yahka.0
              tcp        0      0 192.168.4.72:42010      0.0.0.0:*               LISTEN      1001       18261      2425/io.hm-rpc.1
              tcp        0      0 192.168.4.72:42001      0.0.0.0:*               LISTEN      1001       18250      2374/io.hm-rpc.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      112        1910       908/mosquitto
              tcp6       0      0 :::34875                :::*                    LISTEN      1001       20836      2952/io.yahka.0
              tcp6       0      0 :::39359                :::*                    LISTEN      1001       20832      2952/io.yahka.0
              tcp6       0      0 :::51989                :::*                    LISTEN      1001       19629      2623/io.nuki-extend
              tcp6       0      0 :::3000                 :::*                    LISTEN      111        14038      1111/grafana
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20707      2824/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14210      1659/io.admin.0
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21974      3018/io.simple-api.
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        14000      895/influxd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          15172      983/sshd: /usr/sbin
              tcp6       0      0 :::42629                :::*                    LISTEN      1001       20834      2952/io.yahka.0
              tcp6       0      0 :::1883                 :::*                    LISTEN      112        1911       908/mosquitto
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20158      2816/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20159      2816/io.tuya.0
              udp        0      0 0.0.0.0:40945           0.0.0.0:*                           108        1726       372/avahi-daemon: r
              udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12092      992/dnsmasq
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12089      992/dnsmasq
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1815       764/dhclient
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1724       372/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21837      2715/io.shelly.0
              udp6       0      0 :::33846                :::*                                108        1727       372/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        1725       372/avahi-daemon: r
              2024-12-14 12:45:02.900  - error: host.raspiBullseye Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
              2024-12-14 12:45:02.900  - error: host.raspiBullseye Caught by controller[0]: }
              2024-12-14 12:45:02.900  - error: host.raspiBullseye Caught by controller[0]: Node.js v20.18.1
              2024-12-14 12:45:02.900  - error: host.raspiBullseye instance system.adapter.e3oncan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-12-14 12:45:02.900  - info: host.raspiBullseye Restart adapter system.adapter.e3oncan.0 because enabled
              2024-12-14 12:45:34.598  - info: host.raspiBullseye instance system.adapter.e3oncan.0 in version "0.10.3" started with pid 9589
              2024-12-14 12:45:36.280  - error: host.raspiBullseye Caught by controller[0]: node:internal/modules/cjs/loader:1586
              2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
              2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]:                  ^
              2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]: Error: Module did not self-register: '/opt/iobroker/node_modules/socketcan/build/Release/can.node'.
              2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]:     at Module._extensions..node (node:internal/modules/cjs/loader:1586:18)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/socketcan/dist/socketcan.js:51:26)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
              2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12) {
              2024-12-14 12:45:36.283  - error: host.raspiBullseye Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
              2024-12-14 12:45:36.283  - error: host.raspiBullseye Caught by controller[0]: }
              2024-12-14 12:45:36.283  - error: host.raspiBullseye Caught by controller[0]: Node.js v20.18.1
              2024-12-14 12:45:36.283  - error: host.raspiBullseye instance system.adapter.e3oncan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-12-14 12:45:36.283  - info: host.raspiBullseye Restart adapter system.adapter.e3oncan.0 because enabled
              iob diag has finished.
                Da sieht man mal wieder, warum es keine brillante Idee ist, Versionsangaben in den hostname zu integrieren.
                Oder in der Signatur. Sowas irritiert nur Helfer, wenn es nicht wenigstens dann auch aktuell gehalten wird...
                Der 'Bookworm' ist auch nicht richtig installiert bzw. upgegraded worden. Nicht umsonst wird in dem Fall 'Bullseye auf Raspberry' eine NEUinstallation vorgesehen.
                Um so schiefe Installationen werde ich mich nicht weiter kümmern.
                Installier es gescheit von Grund auf neu.
                  @thomas-braun sagte in Update von nodejs auf 20.x schiefgegangen?:
                  Da diskreditierst du allerdings deine eigenen Arbeiten.🙄 Ich habe die Aktualisierung auf Bookworm nach deinen Anleitungen sorgfältig/minutiös durchgeführt - was auch monatelang zu keinerlei Schwierigkeiten/Fehler führte.
                  Dennoch werde ich deinen Rat annehmen und mein System neu aufsetzen.
                    Homoran Global Moderator Administrators @legro last edited by
                    nur dass diese Anleitung nicht für bullseye -> bookworm gilt!
                      Dann hast du aber die Passage
                      Diesmal rät Raspberry OS allerdings noch dringender als sonst dazu, die Systeme nicht von einem zum anderen Release rüberzuheben, sondern eine komplette Neuinstallation zu machen:
                      Wichtig zu wissen: Früher empfahl man eine frische Installation, aber es war möglich, vom Vorgänger zu aktualisieren. Die jetzige Installation sollte aber auf jeden Fall neu sein.
                      Da die Änderungen an der zugrundeliegenden Architektur so signifikant sind, schlägt man dieses Mal keine Prozedur vor, um ein Bullseye-Image auf Bookworm zu aktualisieren; jeder Versuch, dies zu tun, wird mit ziemlicher Sicherheit mit einem nicht bootenden Desktop und Datenverlust enden.
                      Die einzige Möglichkeit, Bookworm zu bekommen, ist entweder eine SD-Karte mit dem Raspberry Pi Imager zu erstellen oder ein Bookworm-Image von hier herunterzuladen und mit dem Tool der Wahl zu flashen.
                      Gilt aber auch für ein System ohne Desktop, bei meinen Versuchen hab ich schwer mit dem Bootvorgang zu kämpfen, den aktuellen Kernel habe ich nicht vollständig gestartet bekommen.
                      geflissentlich ignoriert, wenn du dich an diese Anleitung gehalten haben willst:
                      https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                        .. geflissentlich ignoriert, wenn du ..
                        Ein Versuch war's wert! Schließlich bin ich bisher nie schlecht mit deinen Anleitungen gefahren. Außerdem hat doch tatsächlich das Ganze über viele, viele Monate anstandslos funktioniert.
                        Mein Fazit: Linux ist und bleibt für mich eine ewige Bastelstube. Man schimpft immer auf M$ Windows. Zurecht - nur kannte ich mich damit wenigstens in etwa so aus, wie du in Sachen Linux.😊
                        Aber alles Lamentieren hilft mir nichts. Ich werde also mein System völlig neu aufsetzen und nehme dazu auch gleich einen neuen Raspberry Pi 5.
                          Thomas Braun Most Active @legro last edited by Thomas Braun
                          Das ist eher das 'Problem' an der Stelle, nicht die vermeintliche 'Bastelbude'.
                          Das wird nämlich nur von Leuten so gesehen, die 'Ahnung von Windows' haben und ihr 'Wissen' von dort versuchen in die Linux-Welt zu retten. Das funktioniert nur nicht und ist nur hinderlich im Umgang mit einem komplett anders aufgebauten Betriebssystem.
                          Linux IST nicht wie Windows. Und will und soll es auch gar nicht sein. Einen Windows-Klon braucht die Welt nicht und deswegen tickt Linux ganz bewusst anders.
                          Wenn das so eine 'Bastelbude' wäre, dann würde nicht die überwiegende Zahl der Server und 'Supercomputer' auf Linux setzen.
                            Du trägst Eulen nach Athen.🙂 Aber Linux bräuchte endlich eine vernünftige Möglichkeit, das System auf eine neue Version anzuheben ohne gleich alles neu installieren - oder eben ein Profi in Sachen Linux sein - zu müssen.
                            Ich fürchte, dass dies auch Kostengründe haben dürfte.😉
                            Solche Diskussionen sind letztendlich müßig. Statt weiter zu lamentieren installiere ich halt zum x. Mal alles wieder neu.
                            haselchen Thomas Braun Homoran 5 Replies Last reply Reply Quote 0
                            • haselchen
                              haselchen Most Active @legro last edited by haselchen
                              @legro
                              OT on
                              Müßig ist das keinesfalls, denn auch Windows kannst Du nicht so einfach von einer Version zur Anderen bringen -> Thema Hardware Voraussetzungen.
                              Und bei Windows wird Dir bei ner Installation einfach was ins System geklatscht.
                              In Linux kannst Du das überwiegend selbst steuern.
                              OT off
                              Und wenn Du so oft neu installieren musst , dann ist da was mit der Lernkurve nicht richtig 😉
                                legro @haselchen last edited by
                                @haselchen sagte in Update von nodejs auf 20.x schiefgegangen?:
                                @legro
                                Und wenn Du so oft neu installieren musst, dann ist da was mit der Lernkurve nicht richtig 😉
                                Auf meine alten Tage: Nein, nein und nochmals nein.
                                Ich will in Sachen Linux kein Profi müssen sein. 😂
                                Mit überzeugten Linux-Anwendern über Windows zu diskutieren, ist müßig. Das Ganze ist eh bloß noch OT.
                                  Die gibt es natürlich grundsätzlich (es gibt allerdings kein 'Linux' in dem Sinne, nur hunderte von Distributionen, die alle auf dem Linux-Kernel aufsetzen).
                                  Sog. 'rolling release'-Distributionen gibt es, die installierst du einmal und dann rollst du regelmäßig mit dem Upstream mit und hast immer die aktuellsten Versionen. Hab ich zum Beispiel auf dem Laptop von dem ich gerade tippe laufen.
                                  Setzt aber voraus, dass man sich mit dem System beschäftigen will und z. B. release notes liest.
                                  Und auch bei 'point releases' (wie z. B. Debian) geht das grundsätzlich von einem Release zum nächsten (tw. mit ein paar Kniffen und Anpassungen). In deinem konkreten Fall von 'Raspberry 11 - Bullseye' auf 'Raspberry 12 - Bookworm' sind die Änderungen zwischen den Releases allerdings so groß, das es auf eine Neuinstallation herausläuft. Die Änderungen ergeben sich übrigens daraus, das man bei der Bastelbude 'Raspberry OS' zu der Erkenntnis gekommen ist, das die eigenen Basteleien am OS nicht mehr erforderlich sein sollten und man nun auf den Debian-Standard zurückgeht. Es wird also künftig bei Raspberry OS weniger gebastelt und ein Sprung von 'Bookworm' auf 'Trixie' im Sommer 2025 dürfte wieder per 'in-line'-Upgrade funktionieren.
                                    Beim Betrieb von Servern sind die Lizenzkosten der kleinste Faktor. Da stehen andere Aspekte mehr im Vordergrund.
                                    Und diese Anforderungen werden von der 'Bastelbude' Linux wohl überwiegend besser erfüllt als von anderen Systemen.
                                      Homoran Global Moderator Administrators @legro last edited by Homoran
                                      hat es!
                                      nur in diesem einen speziellen Fall von Raspberrypi OS bullseye auf Raspberry pi OS bookworm geht das sinnvollerweise nicht.
                                      Dazu wurde früher im Raspberry pi OS / Raspbian zu viele Dinge Raspi-spezifisch in deren Linux eingebaut.
                                      mit Bookworm nähert man sich jetzt deutlich mehr an Debian an.
                                      Musst du auch nicht. Bin ich auch nicht.
                                      Habe erst durch ioBroker meinen ersten Kontakt mit Linux gehabt.
                                      Und weil ich mich mit Linux nicht wirklich auskenne mache ich bei jedem Wechsel des major releases eine Neuinstallation, spiele das Backup zurück und fertig.
                                      Der Vorteil ist, dass aller Schrott runter ist, dass ich (bisher) parallel aufbauen kann.
                                      Wenn ich fertig bin wird der alte Server abgeklemmt, beim neuen die IP angepasst, dann sind nur wenige Minuten Totzeit.
                                      Bei Raspi3/4 hab ich sogar die Karte einfach umgesteckt.
                                      für den Pi5 hab ich noch kein Reservegerät
                                        @legro
                                        Du kannst auch versuchen mit dieser Anleitung auf ein stabiles Raspberry OS 12 - Bookworm zu kommen:
                                        https://www.heise.de/hintergrund/Raspberry-Pi-OS-InPlace-Upgrade-von-Bullseye-auf-Bookworm-wagen-9999516.html
                                        Ich würde das aber nicht als generellen Upgrade-Pfad für alle user empfehlen wollen.
                                        Es gibt also schon Wege, dein Raspberry OS 11 auf 12 zu hieven. Sie sind nur in diesem Fall für meinen Geschmack zu verschlungen und unsicher für selbst-erklärte Linux-Laien und 'Warum-ist-Linux-nicht-wie-xy'-Frager.
                                        Thomas Braun L 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @Thomas Braun last edited by
                                          Und um das zu einem Abschluss zu bringen:
                                          Eine dieser 'rolling release' Distributionen läuft auf einem meiner Test-Raspberries:
                                          *** BASE SYSTEM ***
                                           Static hostname: daleth
                                                 Icon name: computer
                                          Operating System: Arch Linux ARM
                                                    Kernel: Linux 6.12.4-1-rpi
                                              Architecture: arm64
                                          OS is similar to: arch
                                          Model           : Raspberry Pi 4 Model B Rev 1.1
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           15:33:25 up 1 day, 16:11,  2 users,  load average: 0.85, 0.25, 0.09
                                          CPU threads: 4
                                          Unknown release codenamed 'n/a'. Please check yourself if the Operating System is actively maintained.
                                            @legro
                                            Ich bin bereits dabei ein neues System aufzubauen. Allerdings ist das ganz schön viel Arbeit, wie man hier nachlesen kann.😉 Da mein System wieder läuft, kann ich das Ganze in aller Ruhe angehen.
                                            Mittlerweile konnte ich mit Unterstützung von @jrbwh das Problem lösen. Es lag an irgendwelchen Abhängigkeiten.
                                            851
