      ltreff last edited by ltreff
      @armilar Rule2 ist aus dem Skript:
      Rule2 on Button1#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,button2"} endon
      Tasten-Config im Skript:
      button1: {
      // DE: Mögliche Werte wenn Rule2 definiert: 'page', 'toggle', 'set' - Wenn nicht definiert --> mode: null
      // EN: Possible values if Rule2 defined: 'page', 'toggle', 'set' - If not defined --> mode: null
      mode: 'toggle',
      // DE: Zielpage - Verwendet wenn mode = page
      // EN: Target page - Used if mode = page
      page: null,
      // DE: Zielentity - Verwendet wenn mode = set oder toggle
      // EN: Target entity - Used if mode = set or toggle
      entity: AliasPath + 'Config.Screensaver.alternativeScreensaverLayout.SET',
      // DE: Zielwert - Verwendet wenn mode = set
      // EN: Target value - Used if mode = set
      setValue: true
      // DE: Konfiguration des rechten Schalters des NSPanels
      // EN: Configuration of the right switch of the NSPanel
      button2: {
          mode: 'toggle',
          page: null,
          entity: AliasPath + 'Config.Screensaver.ScreensaverAdvanced.SET',
          setValue: null
      /***** 1. Tasmota-Config *****/
      // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
      // EN: Adapt to the MQTT adapter instance directories
      const NSPanelReceiveTopic: string = 'mqtt.0.MyHome.NSPanel1.tele.RESULT';
      const NSPanelSendTopic: string = 'mqtt.0.MyHome.NSPanel1.cmnd.CustomSend';
      T Armilar 2 Replies Last reply Reply Quote 0
        TT-Tom @ltreff last edited by
        @ltreff
        Also doch die Rule2 falsch, die muss den selben Topic haben wie dein Tasmota Topic. Da fehlt dein Myhome.
        • Armilar
          Armilar Most Active Forum Testing @ltreff last edited by Armilar
          @ltreff
          Rule2 on Button1#state do Publish MyHome/%topic%/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish MyHome/%topic%/tele/RESULT {"CustomRecv":"event,button2"} endon
          Rule2 1
          L 1 Reply Last reply Reply Quote 2
            ltreff @Armilar last edited by
            @armilar Das klappt jetzt.
            Der Wechsel der Anzeige ist auch noch vom Wert 0_userdata.0.NSPanel.1.Config.Screensaver.timeoutScreensaver abhängig.
            Vielen Dank, ich beende dann diesen Topic.
              losossos @Kuckuckmann last edited by
              @kuckuckmann
              Mahlzeit, ist schon 'ne Weile her seit meinem letztem post.
              Ich habe eine Frage zur Aktualisierung bzw. Aktivierung des Screensavers;
              Wie gesagt, ich hab lange nichts mehr an den Panels "gemacht". Alles lief prima und das Motto ist ja beakanntlicher Weise "never touch a running...."
              Nun habe ich aber doch mal wieder etwas angepasst/hinzugefügt und dabei dann auch das Skript von v 4.3.1 auf aktuell hochgezogen. Soweit läuft alles. Allerdings ist es jetzt so, daß mein Wetterscreensaver (accuweather) nicht mehr (automatisch) aktiviert wird wenn ich zuvor ne popup-nachricht 0_userdata.0.NSPanel.2.ScreensaverInfo.popupNotifyHeading und 0_userdata.0.NSPanel.2.ScreensaverInfo.popupNotifyText ausgegeben habe. Zuvor war es so, daß nach einem timeout der Wetter screensaver automatisch wieder aktiviert wurde. Jetzt klappt das nur noch wenn ich das Display kurz "antatsche".
              (ich zeige in bestimmten Abständen diverse "news" über diese Infozeilen an)
              An welcher "Schraube müßte ich denn drehen" ums wieder so hinzubekommen wie's zuvor war?
                TT-Tom @losossos last edited by
                @losossos
                Ja da hat sich in der Zeit einiges geändert. Hier kannst du alles nachlesen.
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/Changelog
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/Release-Notes
                und hier die Lösung für dein Problem
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#popupnotify-im-screensaver
                  losossos @TT-Tom last edited by
                  @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                  Oh, ja da hat sich ne ganze Menge getan! Gute Arbeit 👍 😊
                  Supi, klar , hätt natürlich auch alles nachlesen können, aber so geht's natürlich viiiiiel schneller.
                  1000-Dank und schöne 🎅 🎄
                    Kerschte_de last edited by Kerschte_de
                    Guten Abend zusammen.
                    Mein Test-NSPanel hatte ich mit Eurer Unterstützung zum Funktionieren bekommen. Die Kommunikation zwischen Panel und ioB lief.
                    Inzwischen habe ich meine beiden ioB-Instanzen zu einer neuen und einzigen ioB-Instanz neu aufgesetzt (jetzt kein Raspi mehr, sondern in miniPC (Proxmox). Entsprechend habe ich versucht, auch das Panel umzuziehen. Geflasht und eingerichtet war es ja bereits, also habe ich lediglich auf NSPanel-Tasmota die neue IPv4 hinterlegt. Meinen extern geführten MQTT-Broker habe ich entsprechend der Empfehlung auf einen neuen Port umgestellt ... und ebenfalls im Tasmota des NSPanels aktualisiert.
                    Die Ojektzeile "mqtt.0.RagowSmartHome.NSPanel_85C180.cmnd.CustomSend" habe ich über einen MQTT-Explorer angelegt. Das hatte funktioniert. Jedoch fiel mir dabei auf, dass ich nicht aus der Konsole des NSPanels heraus einen Befehl übermitteln konnte.
                    Inzwischen kommuniziert die Wetter-App mit dem Screensaver auf dem NSP. Auch Seiten kann ich im TS-Script des ioB anlegen. TS-Script habe ich auf der neuesten Version. Leider werden aber keine darin verknüpften Werte übertragen. Ich habe alles probiert, was ich mir von Euch dazu anlesen konnte. Ich bekomme es jedoch nicht wieder hin.
                    Meine Vermutung ist, dass es irgendwie mit dem Abo auf die beiden mqtt-Datenpunkte nicht ganz klappt (CustomSend und stat.RESULT). Dazu kenne ich aber auch nicht die Funktionsweise des Panels, was worüber kommuniziert wird. Wie erwähnt, Wetter im Screensaver und eigene Seitenstrukturen gehen, aber keine Werte/Datenpunkte. Kann mich bitte jemand begleiten, den Fehler bei mir systematisch einzugrenzen?
                      TT-Tom @Kerschte_de last edited by TT-Tom
                      @kerschte_de
                      Setze das Script bitte in den Debug-Modus und starte es neu, dann poste das Log vom Start des Script bis zum erscheinen des Screensaver.
                      Debugmodus im Panel unter Einstellung -> Script -> Debug Modus(an/aus)
                      oder im Script unter
                      // DE: liefert bei true detailliertere Meldundgen im Log.
                      // EN: if true, provides more detailed messages in the log.
                      var Debug: boolean = true;
                        Kerschte_de @TT-Tom last edited by
                        @tt-tom
                        Hallo Tom. Vielen Dank, dass Du Dich der Sache so schnell annimmst. Ich bin gerade auch nochmal das Video von Matthias durchgegangen, ob ich irgendwas entdecke ... habe einige Datenpunkte auch nochmal exakt nach seinem Video angelegt und dann im Script hinterlegt. Leider weiter ohne Erfolg.
                        14.12.2024, 18:20:28.125	[info ]: javascript.0 (363) Compiling TypeScript source script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT
                        14.12.2024, 18:20:28.391	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: source code did not change, using cached compilation result...
                        14.12.2024, 18:20:28.456	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                        14.12.2024, 18:20:28.459	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: setObjects enabled - create Alias Channels possible
                        14.12.2024, 18:20:28.460	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: weather alias for accuweather.0. already exists
                        14.12.2024, 18:20:28.464	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Desired TFT Firmware: 53 / v4.4.0
                        14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Installed TFT Firmware: 53 / v4.4.0
                        14.12.2024, 18:20:28.720	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Debug mode activated
                        14.12.2024, 18:20:28.788	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Tasmota Buzzer disabled
                        14.12.2024, 18:20:28.800	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: NaN W
                        14.12.2024, 18:20:28.801	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                        14.12.2024, 18:20:28.809	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting tasmota firmware version
                        14.12.2024, 18:20:28.810	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting current berry driver version
                        14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                        14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online berry driver version
                        14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online TFT version
                        14.12.2024, 18:20:28.813	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online firmware version
                        14.12.2024, 18:20:28.828	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: import adbase as ad
                        from luibackend.config import LuiBackendConfig
                        from luibackend.controller import LuiController
                        from luibackend.mqtt import LuiMqttListener, LuiMqttSender
                        from luibackend.updater import Updater
                        import apis
                        import json
                        from typing import Literal
                        class NsPanelLovelaceUIManager(ad.ADBase):
                            def initialize(self):
                                self.adapi = self.get_ad_api()
                                self.adapi.log('Starting')
                                apis.ad_api = self.adapi
                                apis.ha_api   = self.get_plugin_api("HASS")
                                apis.mqtt_api = self.get_plugin_api("MQTT")
                                cfg = self._cfg = LuiBackendConfig(apis.ha_api, self.args["config"])
                                use_api = cfg.get("use_api") == True
                                topic_send = cfg.get("panelSendTopic")
                                topic_recv = cfg.get("panelRecvTopic")
                                api_panel_name = cfg.get("panelName")
                                api_device_id = cfg.get("panelDeviceId")
                                quiet = cfg.get("quiet")
                                mqttsender = self._mqttsender = LuiMqttSender(apis.ha_api, use_api, topic_send, api_panel_name, quiet)
                                self._controller = LuiController(cfg, mqttsender.send_mqtt_msg)
                                desired_tasmota_driver_version   = 8
                                desired_display_firmware_version = 53
                                version     = "v4.3.3"
                                model       = cfg.get("model")
                                if model == "us-l":
                                    desired_display_firmware_url = cfg._config.get("displayURL-US-L", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-{version}.tft")
                                elif model == "us-p":
                                    desired_display_firmware_url = cfg._config.get("displayURL-US-P", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-{version}.tft")
                                else:
                                    desired_display_firmware_url = cfg._config.get("displayURL-EU",   f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-{version}.tft")
                                desired_tasmota_driver_url       = cfg._config.get("berryURL",         "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be")
                                mode = cfg.get("updateMode")
                                updater = Updater(self.adapi.log, mqttsender, topic_send, mode, desired_display_firmware_version, model, desired_display_firmware_url, desired_tasmota_driver_version, desired_tasmota_driver_url)
                                # Request Tasmota Driver Version
                                updater.request_berry_driver_version()
                                LuiMqttListener(use_api, topic_recv, api_panel_name, api_device_id, self._controller, updater)
                                self.adapi.log(f'Started ({version})')
                            # helpers
                            def show_card(self, card_key: str) -> None:
                                """Used to show card on panel"""
                                msg = json.dumps({"CustomRecv":f"event,buttonPress2,navigate.{card_key},button"})
                                topic = self._cfg.get("panelRecvTopic")
                                self._mqttsender.send_mqtt_msg(msg, topic)
                            def navigate(self, direction: Literal['up', 'prev', 'next']) -> None:
                                """Used to navigate different directions on the panel"""
                                msg = json.dumps({"CustomRecv":f"event,buttonPress2,nav{direction.title()},button"})
                            @property
                            def current_card(self) -> str:
                                """Used to get the panel's current card"""
                                return self._controller.current_card.key
                        14.12.2024, 18:20:28.832	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99
                        # based on;
                        # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21
                        # based on;
                        # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
                        # Example Flash
                        # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft
                        # FlashNextion http://nspanel.pky.eu/lui.tft
                        class Nextion : Driver
                            static header = bytes('55BB')
                            static flash_block_size = 4096
                            var flash_mode
                            var flash_start_millis
                            var flash_size
                            var flash_written
                            var flash_buff
                            var flash_offset
                            var flash_proto_version
                            var flash_proto_baud
                            var awaiting_offset
                            var tcp
                            var ser
                            var last_per
                            var url
                            def split_55(b)
                              var ret = []
                              var s = size(b)
                              var i = s-2   # start from last-1
                              while i > 0
                                if b[i] == 0x55 && b[i+1] == 0xBB
                                  ret.push(b[i..s-1]) # push last msg to list
                                  b = b[(0..i-1)]   # write the rest back to b
                                end
                                i -= 1
                              end
                              ret.push(b)
                              return ret
                            end
                            def crc16(data, poly)
                              if !poly  poly = 0xA001 end
                              # CRC-16 MODBUS HASHING ALGORITHM
                              var crc = 0xFFFF
                              for i:0..size(data)-1
                                crc = crc ^ data[i]
                                for j:0..7
                                  if crc & 1
                                    crc = (crc >> 1) ^ poly
                                  else
                                    crc = crc >> 1
                                  end
                                end
                              end
                              return crc
                            end
                            # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
                            def encode(payload)
                              var b = bytes()
                              b += self.header
                              b.add(size(payload), 2)   # add size as 2 bytes, little endian
                              b += bytes().fromstring(payload)
                              var msg_crc = self.crc16(b)
                              b.add(msg_crc, 2)       # crc 2 bytes, little endian
                              return b
                            end
                            def encodenx(payload)
                                var b = bytes().fromstring(payload)
                                b += bytes('FFFFFF')
                                return b
                            end
                            def sendnx(payload)
                                import string
                                var payload_bin = self.encodenx(payload)
                                self.ser.write(payload_bin)
                                log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3)
                            end
                            def send(payload)
                                var payload_bin = self.encode(payload)
                                if self.flash_mode==1
                                    log("NXP: skipped command becuase still flashing", 3)
                                else
                                    log("NXP: payload sent = " + str(payload_bin), 3)
                                end
                            end
                            def write_to_nextion(b)
                                self.ser.write(b)
                            end
                            def screeninit()
                                log("NXP: Screen Initialized")
                                self.sendnx("recmod=1")
                            end
                            def write_block()
                                import string
                                log("FLH: Read block",3)
                                while size(self.flash_buff)<self.flash_block_size && self.tcp.connected()
                                    if self.tcp.available()>0
                                        self.flash_buff += self.tcp.readbytes(4096)
                                    else
                                        tasmota.delay(50)
                                        log("FLH: Wait for available...",3)
                                    end
                                end
                                log("FLH: Buff size "+str(size(self.flash_buff)),3)
                                var to_write
                                if size(self.flash_buff)>self.flash_block_size
                                    to_write = self.flash_buff[0..self.flash_block_size-1]
                                    self.flash_buff = self.flash_buff[self.flash_block_size..]
                                else
                                    self.flash_buff = bytes()
                                end
                                log("FLH: Writing "+str(size(to_write)),3)
                                var per = (self.flash_written*100)/self.flash_size
                                if (self.last_per!=per)
                                    self.last_per = per
                                    tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
                                end
                                if size(to_write)>0
                                    self.flash_written += size(to_write)
                                    self.ser.write(to_write)
                                end
                                log("FLH: Total "+str(self.flash_written),3)
                                if (self.flash_written==self.flash_size)
                                    log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000)
                                    self.flash_mode = 0
                                    self.ser.deinit()
                                    self.ser = serial(17, 16, 115200, serial.SERIAL_8N1)
                                end
                            end
                            def every_100ms()
                                import string
                                if self.ser.available() > 0
                                    var msg = self.ser.read()
                                    if size(msg) > 0
                                        log(string.format("NXP: Received Raw = %s",str(msg)), 3)
                                        if (self.flash_mode==1)
                                            var strv = msg[0..-4].asstring()
                                            if string.find(strv,"comok 2")>=0
                                                tasmota.delay(50)
                                                log("FLH: Send (High Speed) flash start")
                                                self.flash_start_millis = tasmota.millis()
                                                #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size))
                                                if self.flash_proto_version == 0
                                                    self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                                else
                                                    self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                                end
                                                if self.flash_proto_baud != 115200
                                                    tasmota.delay(50)
                                                    self.ser.deinit()
                                                    self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1)
                                                end
                                            elif size(msg)==1 && msg[0]==0x08
                                                log("FLH: Waiting offset...",3)
                                                self.awaiting_offset = 1
                                            elif size(msg)==4 && self.awaiting_offset==1
                                                self.awaiting_offset = 0
                                                self.flash_offset = msg.get(0,4)
                                                log("FLH: Flash offset marker "+str(self.flash_offset),3)
                                                if self.flash_offset != 0
                                                    self.open_url_at(self.url, self.flash_offset)
                                                    self.flash_written = self.flash_offset
                                                end
                                                self.write_block()
                                            elif size(msg)==1 && msg[0]==0x05
                                                self.write_block()
                                            else
                                                log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2)
                                            end
                                        else
                                            var msg_list = self.split_55(msg)
                                            for i:0..size(msg_list)-1
                                                msg = msg_list[i]
                                                if size(msg) > 0
                                                    if msg == bytes('000000FFFFFF88FFFFFF')
                                                        self.screeninit()
                                                    elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB
                                                        var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring())
                                                        tasmota.publish_result(jm, "RESULT")
                                                    elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer
                                                        tasmota.cmd("buzzer 1,1")
                                                    else
                                                        var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                                                    end
                                                end
                                            end
                                        end
                                    end
                                end
                            end
                            def begin_nextion_flash()
                                self.flash_written = 0
                                self.flash_offset = 0
                                self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN')
                                self.sendnx('recmod=0')
                                self.flash_mode = 1
                                self.sendnx("connect")
                            end
                            def open_url_at(url, pos)
                                self.url = url
                                import string
                                var host
                                var port
                                var s1 = string.split(url,7)[1]
                                var i = string.find(s1,":")
                                var sa
                                if i<0
                                    port = 80
                                    i = string.find(s1,"/")
                                    sa = string.split(s1,i)
                                    host = sa[0]
                                else
                                    host = sa[0]
                                    s1 = string.split(sa[1],1)[1]
                                    port = int(sa[0])
                                end
                                var get = sa[1]
                                log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get))
                                self.tcp = tcpclient()
                                self.tcp.connect(host,port)
                                log("FLH: Connected:"+str(self.tcp.connected()),3)
                                var get_req = "GET "+get+" HTTP/1.0\r\n"
                                get_req += string.format("Range: bytes=%d-\r\n", pos)
                                get_req += string.format("HOST: %s:%s\r\n\r\n",host,port)
                                self.tcp.write(get_req)
                                var a = self.tcp.available()
                                i = 1
                                while a==0 && i<5
                                  tasmota.delay(100*i)
                                  tasmota.yield()
                                  i += 1
                                  log("FLH: Retry "+str(i),3)
                                end
                                if a==0
                                    log("FLH: Nothing available to read!",3)
                                    return
                                end
                                var b = self.tcp.readbytes()
                                i = 0
                                var end_headers = false;
                                var headers
                                while i<size(b) && headers==nil
                                    if b[i..(i+3)]==bytes().fromstring("\r\n\r\n")
                                        headers = b[0..(i+3)].asstring()
                                        self.flash_buff = b[(i+4)..]
                                    else
                                        i += 1
                                    end
                                end
                                #print(headers)
                                # check http respose for code 200/206
                                if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0
                                    log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3)
                                else
                                    log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3)
                                    print(headers)
                                    return -1
                                end
                                # only set flash size if pos is zero
                                if pos == 0
                                    # check http respose for content-length
                                    var tag = "Content-Length: "
                                    i = string.find(headers,tag)
                                    if (i>0)
                                        var i2 = string.find(headers,"\r\n",i)
                                        var s = headers[i+size(tag)..i2-1]
                                        self.flash_size=int(s)
                                    end
                                    log("FLH: Flash file size: "+str(self.flash_size),3)
                                end
                            end
                            def flash_nextion(url)
                                self.flash_size = 0
                                var res = self.open_url_at(url, 0)
                                if res != -1
                                    self.begin_nextion_flash()
                                end
                            end
                            def init()
                                log("NXP: Initializing Driver")
                                self.flash_mode = 0
                                self.flash_proto_version = 1
                                self.flash_proto_baud = 921600
                            end
                        end
                        var nextion = Nextion()
                        tasmota.add_driver(nextion)
                        def get_current_version(cmd, idx, payload, payload_json)
                            import string
                            var version_of_this_script = 9
                            var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script)
                        end
                        tasmota.add_cmd('GetDriverVersion', get_current_version)
                        def update_berry_driver(cmd, idx, payload, payload_json)
                            def task()
                                import path
                                import string
                        		if string.find(payload, ".tapp") > 0
                        		    print("tapp in URL; will do .tapp update and migration if necessary")
                        			if path.exists("autoexec.be")
                        			    print("autoexec.be found; will check for migration")
                        				var autoexecfile = open('autoexec.be')
                        				var line = autoexecfile.readline()
                        				autoexecfile.close()
                        				if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0
                        			        print("found lovelace berry driver, going to delete autoexec.be and .bec")
                        					path.remove("autoexec.be")
                        					path.remove("autoexec.bec")
                        				end
                        			end
                        			var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp")
                                    if r < 0
                                        print("Update failed")
                                    else
                                        tasmota.cmd("Restart 1")
                                    end
                        		elif string.find(payload, ".be") > 0
                        		    print("be in URL; will do .be update")
                        			if path.exists("nsp-lovelace-driver.tapp")
                        			    print("Error: there is the tapp version of the berry driver installed; cannot do .be update.")
                        			else
                                        var cl = webclient()
                                        cl.begin(payload)
                                        var r = cl.GET()
                                        if r == 200
                                            print("Sucessfully downloaded nspanel-lovelace-ui berry driver")
                                        else
                                            print("Error while downloading nspanel-lovelace-ui berry driver")
                                        end
                                        r = cl.write_file("autoexec.be")
                                        if r < 0
                                            print("Error while writeing nspanel-lovelace-ui berry driver")
                                        else
                                            print("Sucessfully written nspanel-lovelace-ui berry driver")
                                        end
                        			end
                        		else
                        			print("invalid url filetype")
                        		end
                                    var r = string.find(payload, ".tapp")
                                    if r < 0
                                        print("URL doesn't contain .tapp skipping update")
                                    else
                                    end
                                else
                                    var r = string.find(payload, ".be")
                                    if r < 0
                                        print("URL doesn't contain .be skipping update")
                                    else
                                    end
                                end
                            end
                            tasmota.set_timer(0,task)
                            tasmota.resp_cmnd_done()
                        end
                        tasmota.add_cmd('UpdateDriverVersion', update_berry_driver)
                        def flash_nextion(cmd, idx, payload, payload_json)
                            def task()
                            nextion.flash_proto_version = 1
                            nextion.flash_proto_baud = 921600
                                nextion.flash_nextion(payload)
                            end
                        end
                        def flash_nextion_adv(cmd, idx, payload, payload_json)
                            def task()
                                if idx==0
                                elif idx==1
                                    nextion.flash_proto_version = 0
                                elif idx==2
                                    nextion.flash_proto_baud = 115200
                                elif idx==3
                                elif idx==4
                                    nextion.flash_proto_baud = 256000
                                elif idx==5
                                elif idx==6
                                    nextion.ser.deinit()
                                    nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1)
                                else
                                end
                            end
                        end
                        def send_cmd(cmd, idx, payload, payload_json)
                            nextion.sendnx(payload)
                        end
                        def send_cmd2(cmd, idx, payload, payload_json)
                            nextion.send(payload)
                        end
                        tasmota.add_cmd('Nextion', send_cmd)
                        tasmota.add_cmd('CustomSend', send_cmd2)
                        tasmota.add_cmd('FlashNextion', flash_nextion)
                        tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
                        14.12.2024, 18:20:28.835	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online display firmware version => 53
                        14.12.2024, 18:20:28.852	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"nlui_driver_version":"9"}
                        14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current tasmota firmware version => 14.3.0
                        14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online berry driver version => 9
                        14.12.2024, 18:20:28.882	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current berry driver version => 9
                        14.12.2024, 18:20:28.926	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: hidden Cards disabled
                        K T 4 Replies Last reply Reply Quote 0
                          Kerschte_de @Kerschte_de last edited by
                          @kerschte_de
                          14.12.2024, 18:20:29.007	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497","assets_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets","upload_url":"https://uploads.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets{?name,label}","html_url":"https://github.com/joBr99/nspanel-lovelace-ui/releases/tag/v4.4.0","id":149090497,"author":{"login":"joBr99","id":29555657,"node_id":"MDQ6VXNlcjI5NTU1NjU3","avatar_url":"https://avatars.githubusercontent.com/u/29555657?v=4","gravatar_id":"","url":"https://api.github.com/users/joBr99","html_url":"https://github.com/joBr99","followers_url":"https://api.github.com/users/joBr99/followers","following_url":"https://api.github.com/users/joBr99/following{/other_user}","gists_url":"https://api.github.com/users/joBr99/gists{/gist_id}","starred_url":"https://api.github.com/users/joBr99/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/joBr99/subscriptions","organizations_url":"https://api.github.com/users/joBr99/orgs","repos_url":"https://api.github.com/users/joBr99/repos","events_url":"https://api.github.com/users/joBr99/events{/privacy}","received_events_url":"https://api.github.com/users/joBr99/received_events","type":"User","user_view_type":"public","site_admin":false},"node_id":"RE_kwDOGo1zRM4I4vDB","tag_name":"v4.4.0","target_commitish":"main","name":"v4.4.0 - Update for HA 2024.04","draft":false,"prerelease":false,"created_at":"2024-03-30T11:18:31Z","published_at":"2024-03-30T12:26:37Z","assets":[],"tarball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/tarball/v4.4.0","zipball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/zipball/v4.4.0","body":"## Besides the Update of the App in HACS you need to do the following things:\r\n\r\n🔄 **Restart the AppDaemon Container**\r\n\r\n**Add the following workaround to your Home Assistant configuration.yaml**\r\n\r\nhttps://docs.nspanel.pky.eu/stable/prepare_ha/#workaround-for-homeassistant-202404\r\n\r\n🔄 **Restart Home Assistant**\r\n\r\n## New Features:\r\n\r\n- **Implemented changes to work with upcoming Homeassistant Version 2024.04 @joBr99**\r\n","mentions_count":1}
                          14.12.2024, 18:20:29.052	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online TFT firmware version => 4.4.0
                          14.12.2024, 18:20:29.083	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"url":"https://api.github.com/repos/arendst/Tasmota/releases/190153880","assets_url":"https://api.github.com/repos/arendst/Tasmota/releases/190153880/assets","upload_url":"https://uploads.github.com/repos/arendst/Tasmota/releases/190153880/assets{?name,label}","html_url":"https://github.com/arendst/Tasmota/releases/tag/v14.4.0","id":190153880,"author":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"node_id":"RE_kwDOBMkSUM4LVYSY","tag_name":"v14.4.0","target_commitish":"master","name":"Tasmota v14.4.0 Rudolph","draft":false,"prerelease":false,"created_at":"2024-12-11T09:17:21Z","published_at":"2024-12-11T09:35:47Z","assets":[{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594561","id":212594561,"node_id":"RA_kwDOBMkSUM4Mq--B","name":"map_all.zip","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/zip","state":"uploaded","size":50218975,"download_count":20,"created_at":"2024-12-11T09:35:49Z","updated_at":"2024-12-11T09:35:50Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/map_all.zip"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594403","id":212594403,"node_id":"RA_kwDOBMkSUM4Mq-7j","name":"tasmota-4M.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":739968,"download_count":41,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-4M.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594404","id":212594404,"node_id":"RA_kwDOBMkSUM4Mq-7k","name":"tasmota-4M.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":518013,"download_count":42,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-4M.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594417","id":212594417,"node_id":"RA_kwDOBMkSUM4Mq-7x","name":"tasmota-AD.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669280,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AD.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594409","id":212594409,"node_id":"RA_kwDOBMkSUM4Mq-7p","name":"tasmota-AD.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469581,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AD.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594407","id":212594407,"node_id":"RA_kwDOBMkSUM4Mq-7n","name":"tasmota-AF.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668704,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AF.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594405","id":212594405,"node_id":"RA_kwDOBMkSUM4Mq-7l","name":"tasmota-AF.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469296,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AF.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594412","id":212594412,"node_id":"RA_kwDOBMkSUM4Mq-7s","name":"tasmota-BG.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":674672,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BG.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594421","id":212594421,"node_id":"RA_kwDOBMkSUM4Mq-71","name":"tasmota-BG.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470721,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BG.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594406","id":212594406,"node_id":"RA_kwDOBMkSUM4Mq-7m","name":"tasmota-BR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669520,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594411","id":212594411,"node_id":"RA_kwDOBMkSUM4Mq-7r","name":"tasmota-BR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469616,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594410","id":212594410,"node_id":"RA_kwDOBMkSUM4Mq-7q","name":"tasmota-CN.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668096,"download_count":37,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CN.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594415","id":212594415,"node_id":"RA_kwDOBMkSUM4Mq-7v","name":"tasmota-CN.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469483,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CN.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594425","id":212594425,"node_id":"RA_kwDOBMkSUM4Mq-75","name":"tasmota-CZ.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669248,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CZ.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594414","id":212594414,"node_id":"RA_kwDOBMkSUM4Mq-7u","name":"tasmota-CZ.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469625,"download_count":35,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CZ.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594419","id":212594419,"node_id":"RA_kwDOBMkSUM4Mq-7z","name":"tasmota-DE.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668576,"download_count":84,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-DE.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594418","id":212594418,"node_id":"RA_kwDOBMkSUM4Mq-7y","name":"tasmota-DE.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469239,"download_count":66,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-DE.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594408","id":212594408,"node_id":"RA_kwDOBMkSUM4Mq-7o","name":"tasmota-display.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":626128,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-display.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594413","id":212594413,"node_id":"RA_kwDOBMkSUM4Mq-7t","name":"tasmota-display.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":430756,"download_count":40,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-display.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594427","id":212594427,"node_id":"RA_kwDOBMkSUM4Mq-77","name":"tasmota-ES.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669424,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ES.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594416","id":212594416,"node_id":"RA_kwDOBMkSUM4Mq-7w","name":"tasmota-ES.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469393,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ES.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594454","id":212594454,"node_id":"RA_kwDOBMkSUM4Mq-8W","name":"tasmota-FR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669648,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594422","id":212594422,"node_id":"RA_kwDOBMkSUM4Mq-72","name":"tasmota-FR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469519,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594436","id":212594436,"node_id":"RA_kwDOBMkSUM4Mq-8E","name":"tasmota-FY.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668944,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FY.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594434","id":212594434,"node_id":"RA_kwDOBMkSUM4Mq-8C","name":"tasmota-FY.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469568,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FY.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594420","id":212594420,"node_id":"RA_kwDOBMkSUM4Mq-70","name":"tasmota-GR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":672832,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-GR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594423","id":212594423,"node_id":"RA_kwDOBMkSUM4Mq-73","name":"tasmota-GR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470557,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-GR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594437","id":212594437,"node_id":"RA_kwDOBMkSUM4Mq-8F","name":"tasmota-HE.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":670192,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HE.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594431","id":212594431,"node_id":"RA_kwDOBMkSUM4Mq-7_","name":"tasmota-HE.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469550,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HE.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594438","id":212594438,"node_id":"RA_kwDOBMkSUM4Mq-8G","name":"tasmota-HU.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669552,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HU.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594426","id":212594426,"node_id":"RA_kwDOBMkSUM4Mq-76","name":"tasmota-HU.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469699,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HU.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594430","id":212594430,"node_id":"RA_kwDOBMkSUM4Mq-7-","name":"tasmota-ir.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":681296,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ir.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594443","id":212594443,"node_id":"RA_kwDOBMkSUM4Mq-8L","name":"tasmota-ir.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":458199,"download_count":40,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ir.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594428","id":212594428,"node_id":"RA_kwDOBMkSUM4Mq-78","name":"tasmota-IT.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669680,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-IT.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594432","id":212594432,"node_id":"RA_kwDOBMkSUM4Mq-8A","name":"tasmota-IT.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469256,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-IT.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594439","id":212594439,"node_id":"RA_kwDOBMkSUM4Mq-8H","name":"tasmota-knx.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":664736,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-knx.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594424","id":212594424,"node_id":"RA_kwDOBMkSUM4Mq-74","name":"tasmota-knx.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":462131,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-knx.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594442","id":212594442,"node_id":"RA_kwDOBMkSUM4Mq-8K","name":"tasmota-KO.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669168,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-KO.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594457","id":212594457,"node_id":"RA_kwDOBMkSUM4Mq-8Z","name":"tasmota-KO.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469713,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-KO.bin.gz"},
                            Kerschte_de @Kerschte_de last edited by
                            @kerschte_de
                            {"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594433","id":212594433,"node_id":"RA_kwDOBMkSUM4Mq-8B","name":"tasmota-lite.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":520208,"download_count":62,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-lite.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594444","id":212594444,"node_id":"RA_kwDOBMkSUM4Mq-8M","name":"tasmota-lite.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":364868,"download_count":59,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-lite.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594429","id":212594429,"node_id":"RA_kwDOBMkSUM4Mq-79","name":"tasmota-minimal.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":374432,"download_count":108,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-minimal.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594435","id":212594435,"node_id":"RA_kwDOBMkSUM4Mq-8D","name":"tasmota-minimal.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":264238,"download_count":113,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-minimal.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594456","id":212594456,"node_id":"RA_kwDOBMkSUM4Mq-8Y","name":"tasmota-NL.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669024,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-NL.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594441","id":212594441,"node_id":"RA_kwDOBMkSUM4Mq-8J","name":"tasmota-NL.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469232,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-NL.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594448","id":212594448,"node_id":"RA_kwDOBMkSUM4Mq-8Q","name":"tasmota-PL.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669680,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PL.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594440","id":212594440,"node_id":"RA_kwDOBMkSUM4Mq-8I","name":"tasmota-PL.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469819,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PL.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594445","id":212594445,"node_id":"RA_kwDOBMkSUM4Mq-8N","name":"tasmota-PT.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669744,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PT.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594463","id":212594463,"node_id":"RA_kwDOBMkSUM4Mq-8f","name":"tasmota-PT.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469557,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PT.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594447","id":212594447,"node_id":"RA_kwDOBMkSUM4Mq-8P","name":"tasmota-RO.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669024,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RO.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594458","id":212594458,"node_id":"RA_kwDOBMkSUM4Mq-8a","name":"tasmota-RO.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469329,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RO.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594449","id":212594449,"node_id":"RA_kwDOBMkSUM4Mq-8R","name":"tasmota-RU.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":673744,"download_count":35,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RU.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594462","id":212594462,"node_id":"RA_kwDOBMkSUM4Mq-8e","name":"tasmota-RU.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470822,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RU.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594469","id":212594469,"node_id":"RA_kwDOBMkSUM4Mq-8l","name":"tasmota-SE.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669104,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SE.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594451","id":212594451,"node_id":"RA_kwDOBMkSUM4Mq-8T","name":"tasmota-SE.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469458,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SE.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594455","id":212594455,"node_id":"RA_kwDOBMkSUM4Mq-8X","name":"tasmota-sensors.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":736896,"download_count":48,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-sensors.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594446","id":212594446,"node_id":"RA_kwDOBMkSUM4Mq-8O","name":"tasmota-sensors.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":510956,"download_count":53,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-sensors.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594472","id":212594472,"node_id":"RA_kwDOBMkSUM4Mq-8o","name":"tasmota-SK.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669328,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SK.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594467","id":212594467,"node_id":"RA_kwDOBMkSUM4Mq-8j","name":"tasmota-SK.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469668,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SK.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594452","id":212594452,"node_id":"RA_kwDOBMkSUM4Mq-8U","name":"tasmota-TR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669248,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594466","id":212594466,"node_id":"RA_kwDOBMkSUM4Mq-8i","name":"tasmota-TR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469588,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594453","id":212594453,"node_id":"RA_kwDOBMkSUM4Mq-8V","name":"tasmota-TW.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668704,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TW.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594450","id":212594450,"node_id":"RA_kwDOBMkSUM4Mq-8S","name":"tasmota-TW.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469967,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TW.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594461","id":212594461,"node_id":"RA_kwDOBMkSUM4Mq-8d","name":"tasmota-UK.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":673856,"download_count":38,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-UK.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594459","id":212594459,"node_id":"RA_kwDOBMkSUM4Mq-8b","name":"tasmota-UK.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470776,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-UK.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594474","id":212594474,"node_id":"RA_kwDOBMkSUM4Mq-8q","name":"tasmota-VN.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":670496,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-VN.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594464","id":212594464,"node_id":"RA_kwDOBMkSUM4Mq-8g","name":"tasmota-VN.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469736,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-VN.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594468","id":212594468,"node_id":"RA_kwDOBMkSUM4Mq-8k","name":"tasmota-zbbridge.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":765456,"download_count":37,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zbbridge.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594475","id":212594475,"node_id":"RA_kwDOBMkSUM4Mq-8r","name":"tasmota-zbbridge.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":527313,"download_count":40,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zbbridge.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594460","id":212594460,"node_id":"RA_kwDOBMkSUM4Mq-8c","name":"tasmota-zigbee.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":857760,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zigbee.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594465","id":212594465,"node_id":"RA_kwDOBMkSUM4Mq-8h","name":"tasmota-zigbee.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":590540,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zigbee.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594482","id":212594482,"node_id":"RA_kwDOBMkSUM4Mq-8y","name":"tasmota.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668064,"download_count":84,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594479","id":212594479,"node_id":"RA_kwDOBMkSUM4Mq-8v","name":"tasmota.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":468540,"download_count":83,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594473","id":212594473,"node_id":"RA_kwDOBMkSUM4Mq-8p","name":"tasmota32-AD.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":2066048,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota32-AD.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594471","id":212594471,"node_id":"RA_kwDOBMkSUM4Mq-8n","name":"tasmota32-AD.factory.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":2983552,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota32-AD.factory.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594478","id":212594478,"node_id":"RA_kwDOBMkSUM4Mq-8u","name":"tasmota32-AF.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":2065568,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota32-AF.bin"},
                              @kerschte_de
                              da ist was durcheinandergekommen, da ich die maximale Zeichenzahl übersteige. Ich versuche es nochmal ab Zeile 572
                              javascript.0	18:20:28.125	info	Compiling TypeScript source script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT
                              javascript.0	18:20:28.391	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: source code did not change, using cached compilation result...
                              javascript.0	18:20:28.456	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                              javascript.0	18:20:28.459	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: setObjects enabled - create Alias Channels possible
                              javascript.0	18:20:28.460	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: weather alias for accuweather.0. already exists
                              javascript.0	18:20:28.464	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              javascript.0	18:20:28.502	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Desired TFT Firmware: 53 / v4.4.0
                              javascript.0	18:20:28.502	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Installed TFT Firmware: 53 / v4.4.0
                              javascript.0	18:20:28.720	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Debug mode activated
                              javascript.0	18:20:28.788	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Tasmota Buzzer disabled
                              javascript.0	18:20:28.800	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: NaN W
                              javascript.0	18:20:28.801	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                              javascript.0	18:20:28.809	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting tasmota firmware version
                              javascript.0	18:20:28.810	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting current berry driver version
                              javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                              javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online berry driver version
                              javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online TFT version
                              javascript.0	18:20:28.813	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online firmware version
                              javascript.0	18:20:28.828	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: import adbase as ad from luibackend.config import LuiBackendConfig from luibackend.controller import LuiController from luibackend.mqtt import LuiMqttListener, LuiMqttSender from luibackend.updater import Updater import apis import json from typing import Literal class NsPanelLovelaceUIManager(ad.ADBase): def initialize(self): self.adapi = self.get_ad_api() self.adapi.log('Starting') apis.ad_api = self.adapi apis.ha_api = self.get_plugin_api("HASS") apis.mqtt_api = self.get_plugin_api("MQTT") cfg = self._cfg = LuiBackendConfig(apis.ha_api, self.args["config"]) use_api = cfg.get("use_api") == True topic_send = cfg.get("panelSendTopic") topic_recv = cfg.get("panelRecvTopic") api_panel_name = cfg.get("panelName") api_device_id = cfg.get("panelDeviceId") quiet = cfg.get("quiet") mqttsender = self._mqttsender = LuiMqttSender(apis.ha_api, use_api, topic_send, api_panel_name, quiet) self._controller = LuiController(cfg, mqttsender.send_mqtt_msg) desired_tasmota_driver_version = 8 desired_display_firmware_version = 53 version = "v4.3.3" model = cfg.get("model") if model == "us-l": desired_display_firmware_url = cfg._config.get("displayURL-US-L", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-{version}.tft") elif model == "us-p": desired_display_firmware_url = cfg._config.get("displayURL-US-P", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-{version}.tft") else: desired_display_firmware_url = cfg._config.get("displayURL-EU", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-{version}.tft") desired_tasmota_driver_url = cfg._config.get("berryURL", "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be") mode = cfg.get("updateMode") updater = Updater(self.adapi.log, mqttsender, topic_send, mode, desired_display_firmware_version, model, desired_display_firmware_url, desired_tasmota_driver_version, desired_tasmota_driver_url) # Request Tasmota Driver Version updater.request_berry_driver_version() LuiMqttListener(use_api, topic_recv, api_panel_name, api_device_id, self._controller, updater) self.adapi.log(f'Started ({version})') # # helpers # def show_card(self, card_key: str) -> None: """Used to show card on panel""" msg = json.dumps({"CustomRecv":f"event,buttonPress2,navigate.{card_key},button"}) topic = self._cfg.get("panelRecvTopic") self._mqttsender.send_mqtt_msg(msg, topic) def navigate(self, direction: Literal['up', 'prev', 'next']) -> None: """Used to navigate different directions on the panel""" msg = json.dumps({"CustomRecv":f"event,buttonPress2,nav{direction.title()},button"}) topic = self._cfg.get("panelRecvTopic") self._mqttsender.send_mqtt_msg(msg, topic) @property def current_card(self) -> str: """Used to get the panel's current card""" return self._controller.current_card.key
                              javascript.0	18:20:28.832	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99 # based on; # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21 # based on; # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger # Example Flash # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft # FlashNextion http://nspanel.pky.eu/lui.tft class Nextion : Driver static header = bytes('55BB') static flash_block_size = 4096 var flash_mode var flash_start_millis var flash_size var flash_written var flash_buff var flash_offset var flash_proto_version var flash_proto_baud var awaiting_offset var tcp var ser var last_per var url def split_55(b) var ret = [] var s = size(b) var i = s-2 # start from last-1 while i > 0 if b[i] == 0x55 && b[i+1] == 0xBB ret.push(b[i..s-1]) # push last msg to list b = b[(0..i-1)] # write the rest back to b end i -= 1 end ret.push(b) return ret end def crc16(data, poly) if !poly poly = 0xA001 end # CRC-16 MODBUS HASHING ALGORITHM var crc = 0xFFFF for i:0..size(data)-1 crc = crc ^ data[i] for j:0..7 if crc & 1 crc = (crc >> 1) ^ poly else crc = crc >> 1 end end end return crc end # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc] def encode(payload) var b = bytes() b += self.header b.add(size(payload), 2) # add size as 2 bytes, little endian b += bytes().fromstring(payload) var msg_crc = self.crc16(b) b.add(msg_crc, 2) # crc 2 bytes, little endian return b end def encodenx(payload) var b = bytes().fromstring(payload) b += bytes('FFFFFF') return b end def sendnx(payload) import string var payload_bin = self.encodenx(payload) self.ser.write(payload_bin) log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3) end def send(payload) var payload_bin = self.encode(payload) if self.flash_mode==1 log("NXP: skipped command becuase still flashing", 3) else self.ser.write(payload_bin) log("NXP: payload sent = " + str(payload_bin), 3) end end def write_to_nextion(b) self.ser.write(b) end def screeninit() log("NXP: Screen Initialized") self.sendnx("recmod=1") end def write_block() import string log("FLH: Read block",3) while size(self.flash_buff)<self.flash_block_size && self.tcp.connected() if self.tcp.available()>0 self.flash_buff += self.tcp.readbytes(4096) else tasmota.delay(50) log("FLH: Wait for available...",3) end end log("FLH: Buff size "+str(size(self.flash_buff)),3) var to_write if size(self.flash_buff)>self.flash_block_size to_write = self.flash_buff[0..self.flash_block_size-1] self.flash_buff = self.flash_buff[self.flash_block_size..] else to_write = self.flash_buff self.flash_buff = bytes() end log("FLH: Writing "+str(size(to_write)),3) var per = (self.flash_written*100)/self.flash_size if (self.last_per!=per) self.last_per = per tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT") end if size(to_write)>0 self.flash_written += size(to_write) self.ser.write(to_write) end log("FLH: Total "+str(self.flash_written),3) if (self.flash_written==self.flash_size) log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000) self.flash_mode = 0 self.ser.deinit() self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) end end def every_100ms() import string if self.ser.available() > 0 var msg = self.ser.read() if size(msg) > 0 log(string.format("NXP: Received Raw = %s",str(msg)), 3) if (self.flash_mode==1) var strv = msg[0..-4].asstring() if string.find(strv,"comok 2")>=0 tasmota.delay(50) log("FLH: Send (High Speed) flash start") self.flash_start_millis = tasmota.millis() #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size)) if self.flash_proto_version == 0 self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud)) else self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud)) end if self.flash_proto_baud != 115200 tasmota.delay(50) self.ser.deinit() self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1) end elif size(msg)==1 && msg[0]==0x08 log("FLH: Waiting offset...",3) self.awaiting_offset = 1 elif size(msg)==4 && self.awaiting_offset==1 self.awaiting_offset = 0 self.flash_offset = msg.get(0,4) log("FLH: Flash offset marker "+str(self.flash_offset),3) if self.flash_offset != 0 self.open_url_at(self.url, self.flash_offset) self.flash_written = self.flash_offset end self.write_block() elif size(msg)==1 && msg[0]==0x05 self.write_block() else log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2) end else var msg_list = self.split_55(msg) for i:0..size(msg_list)-1 msg = msg_list[i] if size(msg) > 0 if msg == bytes('000000FFFFFF88FFFFFF') self.screeninit() elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring()) tasmota.publish_result(jm, "RESULT") elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer tasmota.cmd("buzzer 1,1") else var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4])) tasmota.publish_result(jm, "RESULT") end end end end end end end def begin_nextion_flash() self.flash_written = 0 self.awaiting_offset = 0 self.flash_offset = 0 self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN') self.sendnx('recmod=0') self.sendnx('recmod=0') self.flash_mode = 1 self.sendnx("connect") end def open_url_at(url, pos) self.url = url import string var host var port var s1 = string.split(url,7)[1] var i = string.find(s1,":") var sa if i<0 port = 80 i = string.find(s1,"/") sa = string.split(s1,i) host = sa[0] else sa = string.split(s1,i) host = sa[0] s1 = string.split(sa[1],1)[1] i = string.find(s1,"/") sa = string.split(s1,i) port = int(sa[0]) end var get = sa[1] log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get)) self.tcp = tcpclient() self.tcp.connect(host,port) log("FLH: Connected:"+str(self.tcp.connected()),3) var get_req = "GET "+get+" HTTP/1.0\r\n" get_req += string.format("Range: bytes=%d-\r\n", pos) get_req += string.format("HOST: %s:%s\r\n\r\n",host,port) self.tcp.write(get_req) var a = self.tcp.available() i = 1 while a==0 && i<5 tasmota.delay(100*i) tasmota.yield() i += 1 log("FLH: Retry "+str(i),3) a = self.tcp.available() end if a==0 log("FLH: Nothing available to read!",3) return end var b = self.tcp.readbytes() i = 0 var end_headers = false; var headers while i<size(b) && headers==nil if b[i..(i+3)]==bytes().fromstring("\r\n\r\n") headers = b[0..(i+3)].asstring() self.flash_buff = b[(i+4)..] else i += 1 end end #print(headers) # check http respose for code 200/206 if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0 log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3) else log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3) print(headers) return -1 end # only set flash size if pos is zero if pos == 0 # check http respose for content-length var tag = "Content-Length: " i = string.find(headers,tag) if (i>0) var i2 = string.find(headers,"\r\n",i) var s = headers[i+size(tag)..i2-1] self.flash_size=int(s) end log("FLH: Flash file size: "+str(self.flash_size),3) end end def flash_nextion(url) self.flash_size = 0 var res = self.open_url_at(url, 0) if res != -1 self.begin_nextion_flash() end end def init() log("NXP: Initializing Driver") self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) self.flash_mode = 0 self.flash_proto_version = 1 self.flash_proto_baud = 921600 end end var nextion = Nextion() tasmota.add_driver(nextion) def get_current_version(cmd, idx, payload, payload_json) import string var version_of_this_script = 9 var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script) tasmota.publish_result(jm, "RESULT") end tasmota.add_cmd('GetDriverVersion', get_current_version) def update_berry_driver(cmd, idx, payload, payload_json) def task() import path import string if string.find(payload, ".tapp") > 0 print("tapp in URL; will do .tapp update and migration if necessary") if path.exists("autoexec.be") print("autoexec.be found; will check for migration") var autoexecfile = open('autoexec.be') var line = autoexecfile.readline() autoexecfile.close() if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0 print("found lovelace berry driver, going to delete autoexec.be and .bec") path.remove("autoexec.be") path.remove("autoexec.bec") end end var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp") if r < 0 print("Update failed") else tasmota.cmd("Restart 1") end elif string.find(payload, ".be") > 0 print("be in URL; will do .be update") if path.exists("nsp-lovelace-driver.tapp") print("Error: there is the tapp version of the berry driver installed; cannot do .be update.") else var cl = webclient() cl.begin(payload) var r = cl.GET() if r == 200 print("Sucessfully downloaded nspanel-lovelace-ui berry driver") else print("Error while downloading nspanel-lovelace-ui berry driver") end r = cl.write_file("autoexec.be") if r < 0 print("Error while writeing nspanel-lovelace-ui berry driver") else print("Sucessfully written nspanel-lovelace-ui berry driver") tasmota.cmd("Restart 1") end end else print("invalid url filetype") end if path.exists("nsp-lovelace-driver.tapp") var r = string.find(payload, ".tapp") if r < 0 print("URL doesn't contain .tapp skipping update") else end else var r = string.find(payload, ".be") if r < 0 print("URL doesn't contain .be skipping update") else end end end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end tasmota.add_cmd('UpdateDriverVersion', update_berry_driver) def flash_nextion(cmd, idx, payload, payload_json) def task() nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def flash_nextion_adv(cmd, idx, payload, payload_json) def task() if idx==0 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 elif idx==1 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 elif idx==2 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 115200 elif idx==3 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 elif idx==4 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 256000 elif idx==5 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 256000 elif idx==6 nextion.ser.deinit() nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1) nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 else nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 end nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def send_cmd(cmd, idx, payload, payload_json) nextion.sendnx(payload) tasmota.resp_cmnd_done() end def send_cmd2(cmd, idx, payload, payload_json) nextion.send(payload) tasmota.resp_cmnd_done() end tasmota.add_cmd('Nextion', send_cmd) tasmota.add_cmd('CustomSend', send_cmd2) tasmota.add_cmd('FlashNextion', flash_nextion) tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
                              javascript.0	18:20:28.835	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online display firmware version => 53
                              javascript.0	18:20:28.852	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"nlui_driver_version":"9"}
                              javascript.0	18:20:28.855	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current tasmota firmware version => 14.3.0
                              javascript.0	18:20:28.855	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online berry driver version => 9
                              javascript.0	18:20:28.882	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current berry driver version => 9
                              javascript.0	18:20:28.926	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: hidden Cards disabled
                              javascript.0	18:20:29.007	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497","assets_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets","upload_url":"https://uploads.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets{?name,label}","html_url":"https://github.com/joBr99/nspanel-lovelace-ui/releases/tag/v4.4.0","id":149090497,"author":{"login":"joBr99","id":29555657,"node_id":"MDQ6VXNlcjI5NTU1NjU3","avatar_url":"https://avatars.githubusercontent.com/u/29555657?v=4","gravatar_id":"","url":"https://api.github.com/users/joBr99","html_url":"https://github.com/joBr99","followers_url":"https://api.github.com/users/joBr99/followers","following_url":"https://api.github.com/users/joBr99/following{/other_user}","gists_url":"https://api.github.com/users/joBr99/gists{/gist_id}","starred_url":"https://api.github.com/users/joBr99/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/joBr99/subscriptions","organizations_url":"https://api.github.com/users/joBr99/orgs","repos_url":"https://api.github.com/users/joBr99/repos","events_url":"https://api.github.com/users/joBr99/events{/privacy}","received_events_url":"https://api.github.com/users/joBr99/received_events","type":"User","user_view_type":"public","site_admin":false},"node_id":"RE_kwDOGo1zRM4I4vDB","tag_name":"v4.4.0","target_commitish":"main","name":"v4.4.0 - Update for HA 2024.04","draft":false,"prerelease":false,"created_at":"2024-03-30T11:18:31Z","published_at":"2024-03-30T12:26:37Z","assets":[],"tarball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/tarball/v4.4.0","zipball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/zipball/v4.4.0","body":"## Besides the Update of the App in HACS you need to do the following things:\r\n\r\n🔄 **Restart the AppDaemon Container**\r\n\r\n**Add the following workaround to your Home Assistant configuration.yaml**\r\n\r\nhttps://docs.nspanel.pky.eu/stable/prepare_ha/#workaround-for-homeassistant-202404\r\n\r\n🔄 **Restart Home Assistant**\r\n\r\n## New Features:\r\n\r\n- **Implemented changes to work with upcoming Homeassistant Version 2024.04 @joBr99**\r\n","mentions_count":1}
                                TT-Tom @Kerschte_de last edited by
                                @kerschte_de
                                aus dem Script diese Zeilen zeigen und ein Screenshot vom MQTT baum des Panel
                                // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
                                // EN: Adapt to the MQTT adapter instance directories
                                const NSPanelReceiveTopic: string = 'mqtt.0.SmartHome.NSPanel_1.tele.RESULT';
                                const NSPanelSendTopic: string = 'mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend';
                                  @kerschte_de
                                  kannst zurück setzen
                                    Kerschte_de @TT-Tom last edited by
                                    @tt-tom
                                    ... ja, mache ich:
                                    /***** 1. Tasmota-Config *****/
                                        const NSPanelReceiveTopic: string = 'mqtt.0.RagowSmartHome.NSPanel_85C180.tele.RESULT';
                                        const NSPanelSendTopic: string = 'mqtt.0.RagowSmartHome.NSPanel_85C180.cmnd.CustomSend';
                                        // DE: nur ändern, falls der User im Tasmota vor dem Kompilieren umbenannt wurde (Standard Tasmota: admin)
                                        // EN: only change if the user was renamed in Tasmota before compiling (default Tasmota: admin)
                                        const tasmota_web_admin_user: string = 'admin';
                                        // DE: setzten, falls "Web Admin Password" in Tasmota vergeben
                                        // EN set if "Web Admin Password" is assigned in Tasmota
                                        const tasmota_web_admin_password: string = '';
                                        // DE: Setzen der bevorzugten Tasmota32-Version (für Updates)
                                        // EN: Set preferred Tasmota32 version (for updates)
                                        const tasmotaOtaVersion: string = 'tasmota32-DE.bin';
                                            // DE: Es können ebenfalls andere Versionen verwendet werden wie zum Beispiel:
                                            // EN: Other versions can also be used, such as:
                                            // 'tasmota32-nspanel.bin' or 'tasmota32.bin' or 'tasmota32-DE.bin' or etc.
                                      @kerschte_de
                                      der tele fehlt, der ist entscheidend
                                        @tt-tom ... oh, sorry.
                                          @kerschte_de
                                          okay hier stimmt alles, jetzt bitte die Config einer Seite wo keine Werte kommen und den passenden Objektbaum vom ioBroker
                                          K 2 Replies Last reply Reply Quote 0
                                            @tt-tom ja, gern.
                                            Die Hauptseite ("HOME") dient der Navigation auf Unterseiten. Aktuell habe ich nur noch die im Erdgeschoss aktiv. Dort sind testweise 2 Temperatur-Sensoren verlinkt ... es kommt jedoch nichts an Werten an. Die Seiten selbst funktionieren alle ... so auch wie der Screensaver und das komplette Service-Menu:
                                            //-- Anfang für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich ----------------
                                            //-- Start for your own pages -- some self-defined aliases required ----------------
                                                //-- https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
                                            //-- ##### ##### ##### KERSTEN #### ##### #####
                                            //Level 0
                                            let Navigation1: PageType =
                                                'type': 'cardGrid',
                                                'heading': 'HOME',
                                                'useColor': true,
                                                'items': [
                                                    /*PageItem*/{ navigate: true, id: 'SensorenEG', icon: 'home-floor-0',offColor: Menu, onColor: Menu, name: 'Sensoren EG'},
                                                    //*PageItem*/{ navigate: true, id: 'SensorenOG', icon: 'home-floor-1',offColor: Menu, onColor: Menu, name: 'Sensoren OG'},
                                                    //*PageItem*/{ navigate: true, id: 'SensorenKeller', icon: 'home-floor-negative-1',offColor: Menu, onColor: Menu, name: 'Sensoren Keller'},
                                                    /*PageItem*/{ navigate: true, id: 'NSPanel_Service', icon: 'hammer-screwdriver',offColor: Menu, onColor: Menu, name: 'ServiceMenu'},
                                                    //{ id: 'alias.0.NSPanel_1.TestFenster', offColor: MSRed, onColor: MSGreen, name: 'Büro Fenster'},
                                                    //{ id: 'alias.0.NSPanel_1.Luftreiniger', icon: 'power', offColor: MSRed, onColor: MSGreen},
                                                    //{ id: 'alias.0.NSPanel_1.TestBlind', icon: 'projector-screen', onColor: White, name: 'Beamer', secondRow: 'auch Text'},
                                                    //{ id: 'alias.0.NSPanel_1.Kippfenster', useValue: true }
                                                 //Level 1
                                                 let SensorenEG: PageType =
                                                     'type': 'cardGrid',
                                                     'heading': 'Zigbee-Geräte EG',
                                                     'useColor': true,
                                                     'subPage': true,
                                                     'parent': Navigation1,
                                                     'items': [
                                                         { id: 'alias.0.NSPanel.1.1_Haus.EG.TempWZ.ACTUAL', name: 'WZ Temp.°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 3, colorScale: {'val_min': 15, 'val_max': 35, 'val_best': 21} },
                                                         { id: 'alias.0.NSPanel.1.1_Haus.EG.TempWZ.SECOND', name: 'WZ Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                                                         { id: 'alias.0.NSPanel.1.1_Haus.EG.TempKueche.ACTUAL', name: 'Küche Temp.°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 3, colorScale: {'val_min': 15, 'val_max': 35, 'val_best': 21} },
                                                         { id: 'alias.0.NSPanel.1.1_Haus.EG.TempKueche.SECOND', name: 'Küche Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                                            //-- ENDE für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich -------------------------
                                            Hier noch die Einbindung der Seiten selbst:
                                             **                           Configuration                           **
                                            export const config: Config = {
                                                // Seiteneinteilung / Page division
                                                // Hauptseiten / Mainpages
                                                pages: [
                                                    Navigation1,
                                                    //NSPanel_Service, //Auto-Alias Service Page
                                                    //Unlock_Service            //Auto-Alias Service Page (Service Pages used with cardUnlock)
                                                // Unterseiten / Subpages
                                                subPages: [
                                                    SensorenEG, // --> KeT hinzugefügt
                                                    NSPanel_Service, //Auto-Alias Service Page --> KeT von der Hauptseite auf die Sub-Seite verschoben (über Auskommentierung)
                                                    NSPanel_Service_SubPage, //Auto-Alias Service Page (only used with cardUnlock)
                                                    NSPanel_Infos, //Auto-Alias Service Page
                                                    NSPanel_Wifi_Info_1, //Auto-Alias Service Page
                                                    NSPanel_Wifi_Info_2, //Auto-Alias Service Page
                                                    NSPanel_Sensoren, //Auto-Alias Service Page
                                                    NSPanel_Hardware, //Auto-Alias Service Page
                                                    NSPanel_IoBroker, //Auot-Alias Service Page
                                                    NSPanel_Einstellungen, //Auto-Alias Service Page
                                                    NSPanel_Screensaver, //Auto-Alias Service Page
                                                    NSPanel_ScreensaverDimmode, //Auto-Alias Service Page
                                                    NSPanel_ScreensaverBrightness, //Auto-Alias Service Page
                                                    NSPanel_ScreensaverLayout, //Auto-Alias Service Page
                                                    NSPanel_ScreensaverWeather, //Auto-Alias Service Page
                                                    NSPanel_ScreensaverDateformat, //Auto-Alias Service Page
                                                    NSPanel_ScreensaverIndicators, //Auto-Alias Service Page
                                                    NSPanel_Relays, //Auto-Alias Service Page
                                                    NSPanel_Script, //Auto-Alias Service Page
                                                    NSPanel_Firmware, //Auto-Alias Service Page
                                                    NSPanel_FirmwareTasmota, //Auto-Alias Service Page
                                                    NSPanel_FirmwareBerry, //Auto-Alias Service Page
                                                    NSPanel_FirmwareNextion, //Auto-Alias Service Page
                                            und hier der Sreenshot der beiden Temperatur-Sensoren:
                                            80.8k
                                            lovelace ui nspanel sonoff
                                            270
                                            7647
                                            6304227
