    4. Mal wieder BLE Probleme
      chris299 @Thomas Braun last edited by
      @thomas-braun unverändert (bzw. was meinst Du mit Kaltstart? der iobroker wurde ja gerade ganz neu gestartet):
      ble.0
      	2024-11-07 23:14:07.454	info	starting scanner process...
      ble.0
      	2024-11-07 23:14:07.403	info	monitoring all services
      ble.0
      	2024-11-07 23:14:07.402	info	enabled plugins: Xiaomi, BTHome, _default
      ble.0
      	2024-11-07 23:14:07.402	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
      ble.0
      	2024-11-07 23:14:07.343	info	starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.0, js-controller: 6.0.11
      ble.0
      	2024-11-07 23:14:07.244	debug	States connected to redis: 127.0.0.1:9000
      ble.0
      	2024-11-07 23:14:07.186	debug	States create User PubSub Client
      ble.0
      	2024-11-07 23:14:07.186	debug	States create System PubSub Client
      ble.0
      	2024-11-07 23:14:07.176	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      ble.0
      	2024-11-07 23:14:07.157	debug	Objects connected to redis: 127.0.0.1:9001
      ble.0
      	2024-11-07 23:14:07.155	debug	Objects client initialize lua scripts
      ble.0
      	2024-11-07 23:14:07.126	debug	Objects create User PubSub Client
      ble.0
      	2024-11-07 23:14:07.126	debug	Objects create System PubSub Client
      ble.0
      	2024-11-07 23:14:07.125	debug	Objects client ready ... initialize now
      ble.0
      	2024-11-07 23:14:07.107	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      ble.0
      	2024-11-07 23:13:55.924	info	terminating
      ble.0
      	2024-11-07 23:13:55.423	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      ble.0
      	2024-11-07 23:13:55.422	info	terminating
      ble.0
      	2024-11-07 23:13:55.419	info	Got terminate signal TERMINATE_YOURSELF
        Thomas Braun Most Active @chris299 last edited by
        @chris299
        Läuft doch.
          @thomas-braun naja, wie ich ich oben schon schrieb: der Adapter ist grün, es werden aber keine Daten gesammelt und der DriverState ist "unknown" 😞
            @chris299
            rfkill
            sagt?
              chris299 @Thomas Braun last edited by chris299
              ID TYPE      DEVICE      SOFT      HARD
               0 bluetooth hci0   entsperrt entsperrt
              die üblichen OS Tools scheinen alle einwandfrei zu arbeiten, d.h. Hardware und Treiber funktionieren prinzipiell. IMHO klemmt es irgendwo an der Schnittstelle zum Adapter, vermutlich induziert durch ein Update auf OS seite...
                chris299 @chris299 last edited by
                @Jey-Cee das war der Thread zu meinem BLE Problem wie besprochen. konntest Du nachsehen, ob der Adapter bei Dir noch geht?
                Am fraglichen Tag hab ich leider doch keine OS updates gemacht, wie ich vermutet hatte...
                Ich habe also keine Idee, warum der Adapter seit dem keinerlei Daten mehr empfängt obwohl er grün ist....
                  @chris299
                  Könnte das sein.
                  https://github.com/abandonware/noble/issues/341
                  abondonware noble scheint aber eh ein paar Issues zu haben. Baut mit nodejs@23 z. B. momentan nicht, mit nodejs<23 geht es.
                  woowu created this issue in abandonware/noble
                  open Not get "poweredOn" event in Ubuntu #341
                    @thomas-braun danke für die Recherche, ja, das klingt ganz danach....
                    anscheinend gibt es da auch einen fix: https://github.com/stoprocent/noble/issues/4 den aber wohl @AlCalzone in den BLE Adapter einbauen müsste, aber keine Zeit mehr für sowas hat, wenn ich das richtig verstanden habe. 😞
                    @apollon77 scheint das Thema aber auch zu kennen....
                    rgillan created this issue in stoprocent/noble
                    closed Missing poweredOn event (at least in Ubuntu 24.04) #4
                      @chris299
                      Deswegen gibt es dieses issue:
                      https://github.com/AlCalzone/ioBroker.ble/issues/870
                      Grothesk242 created this issue in AlCalzone/ioBroker.ble
                      closed Switch to @stoprocent/noble - abandonware fork does not build with nodejs23 #870
                      • I
                        iobrokerle last edited by iobrokerle
                        @Thomas-Braun
                        ich habe mein System von einem raspi (4er, 2GB) auf einen neuen (4er, 4GB) umgezogen. Iobroker frisch installiert und dann backitup.
                        Der BLE Adapter war von Anfang an grün. Tage später habe ich gemerkt, dass die timestamps gleich bleiben. Die gefundenen Sensoren wurde einfach nicht aktualisiert.
                        Das mir bekannte habe ich alles durch:
                        cd /opt/iobroker/node_modules/iobroker.ble $ npm install --omit=dev
                        sudo setcap cap_net_raw+eip $(eval readlink -f which node)
                        BLE deinstalliert, neu installiert, iob fix etc...
                        "Verbunden mit Gerät oder Dienst" wird jetzt nicht mehr grün
                        Nichts 😧
                        Jedoch unter "hcitool lescann" werden alle Geräte aufgelistet.
                        Wenn ich das Log nach dem Neustart anschaue, siehts komisch aus:
                        Nodejs-Installation:
                        /usr/bin/nodejs v20.18.1
                        /usr/bin/node v20.18.1
                        /usr/bin/npm 10.8.2
                        /usr/bin/npx 10.8.2
                        /usr/bin/corepack 0.29.4
                        Recommended versions are nodejs 20.18.1 and npm 10.8.2
                        nodeJS installation is correct
                        Was kann ich noch tun? Bin ratlos.
                          Thomas Braun Most Active @iobrokerle last edited by
                          @iobrokerle
                          Siehe Issue genau einen Eintrag über deinem.
                          • I
                            Danke für die Antwort zur späten Stunde.
                            Den link habe ich gesehen aber nicht verstanden 😖
                            Was muss ich da machen?
                              @iobrokerle sagte in Mal wieder BLE Probleme:
                              Abwarten bis jemand den Adapter anpackt und ein Update raus haut.
                              • I
                                iobrokerle @Thomas Braun last edited by
                                OK.
                                Das geht dann mehreren aktuell so?
                                Dachte, beim Umzug lief was falsch.
                                  Ja.
                                  4571
