    4. Zigbee Netzwerk kaputt
      AXMLM @haselchen last edited by
      @haselchen said in Zigbee Netzwerk kaputt:
      @axmlm
      Bitte die Langfassung
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: smarthome
             Icon name: computer-desktop
               Chassis: desktop 🖥️
      Operating System: Ubuntu 24.04.1 LTS
                Kernel: Linux 6.8.0-51-generic
          Architecture: x86-64
       Hardware Vendor: Dell Inc.
        Hardware Model: Wyse 5070 Thin Client
      Firmware Version: 1.7.1
         Firmware Date: Thu 2020-07-30
          Firmware Age: 4y 4month 2w 5d
      OS is similar to: debian
      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:47:07 up 1 day, 25 min,  1 user,  load average: 0.63, 0.65, 0.43
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Ubuntu LTS release codenamed 'noble'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2024-12-17 19:47:07 CET
                 Universal time: Tue 2024-12-17 18:47:07 UTC
                       RTC time: Tue 2024-12-17 18:47:07
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      alexander
      HOME=/home/alexander
      GROUPS=alexander adm cdrom sudo dip plugdev lxd iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.1G        2.3G        4.4G        1.8M        1.7G        5.9G
      Swap:           4.3G          0B        4.3G
      Total:           12G        2.3G        8.7G
      Active iob-Instances:   22
               7763 M total memory
               2177 M used memory
               1900 M active memory
               1264 M inactive memory
               4234 M free memory
                210 M buffer memory
               1431 M swap cache
               4095 M total swap
                  0 M used swap
               4095 M free swap
      top - 19:47:08 up 1 day, 25 min,  1 user,  load average: 0.66, 0.66, 0.44
      Tasks: 167 total,   1 running, 166 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  4.3 us,  4.3 sy,  0.0 ni, 91.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7763.2 total,   4234.0 free,   2177.8 used,   1642.2 buff/cache
      MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   5585.4 avail Mem
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                        Type      Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs     777M  1.5M  775M   1% /run
      efivarfs                          efivarfs  384K  113K  267K  30% /sys/firmware/efi/efivars
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4       28G   13G   14G  48% /
      tmpfs                             tmpfs     3.8G     0  3.8G   0% /dev/shm
      tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4      2.0G  183M  1.7G  11% /boot
      /dev/sda1                         vfat      1.1G  6.2M  1.1G   1% /boot/efi
      tmpfs                             tmpfs     777M   12K  777M   1% /run/user/1000
      [Mon Dec 16 19:21:40 2024] EXT4-fs (dm-0): mounted filesystem 3106498e-accb-47ea-b9cb-5d9e2516d4d0 ro with ordered data mode. Quota mode: none.
      [Mon Dec 16 19:21:41 2024] EXT4-fs (dm-0): re-mounted 3106498e-accb-47ea-b9cb-5d9e2516d4d0 r/w. Quota mode: none.
      [Mon Dec 16 19:21:42 2024] EXT4-fs (sda2): mounted filesystem 4e830c7b-098b-40e5-be1f-581404f1580b r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET        SOURCE                            FSTYPE OPTIONS
      /             /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
      `-/boot       /dev/sda2                         ext4   rw,relatime
        `-/boot/efi /dev/sda1                         vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      /var:
      615M    /var/
      271M    /var/cache
      241M    /var/cache/apt
      226M    /var/lib
      176M    /var/lib/apt/lists
      Archived and active journals take up 103.3M in the file system.
      /opt/iobroker/backups:
      459M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_845efcbea045ed1186c8cc8f0a86e0b4-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.1+dfsg-6ubuntu5 500
              500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      smarthome           smarthome (version: 7.0.3, hostname: smarthome     , alive, uptime: 87923)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : smarthome                                -  enabled
      + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
      + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
      + system.adapter.discovery.0              : discovery             : smarthome                                -  enabled
      + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
      + system.adapter.history.0                : history               : smarthome                                -  enabled
        system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : smarthome                                -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : smarthome                                -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : smarthome                                -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : smarthome                                -  enabled
        system.adapter.iot.0                    : iot                   : smarthome                                - disabled
      + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
      + system.adapter.meross.0                 : meross                : smarthome                                -  enabled
      + system.adapter.modbus.0                 : modbus                : smarthome                                -  enabled
      + system.adapter.modbus.1                 : modbus                : smarthome                                -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : smarthome                                -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.reolink.0                : reolink               : smarthome                                - disabled
      + system.adapter.scenes.0                 : scenes                : smarthome                                -  enabled
      + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : smarthome                                - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.0                 : sonoff                : smarthome                                - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.stiebel-isg.0            : stiebel-isg           : smarthome                                -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
      + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : smarthome                                -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : smarthome                                -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : smarthome                                -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: smarthome                                -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: smarthome                                -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : smarthome                                -  enabled
        system.adapter.vis-bars.0               : vis-bars              : smarthome                                -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : smarthome                                -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : smarthome                                -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : smarthome                                -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : smarthome                                -  enabled
        system.adapter.vis-history.0            : vis-history           : smarthome                                -  enabled
        system.adapter.vis-homekittiles.0       : vis-homekittiles      : smarthome                                -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smarthome                                -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : smarthome                                -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : smarthome                                -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : smarthome                                -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : smarthome                                -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
        system.adapter.vis-weather.0            : vis-weather           : smarthome                                -  enabled
        system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : smarthome                                - disabled
      + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee.0                 : zigbee                : smarthome                                - disabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: minor
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.3    , installed 7.0.3
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "reolink"      : 1.1.2    , installed 1.1.2
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "stiebel-isg"  : 1.7.7    , installed 1.7.7
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-homekittiles": 0.3.1 , installed 0.3.1
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        6958
      States:         3849
      Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
      Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu noble-updates InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu noble-backports InRelease
      Reading package lists...
      Pending Updates: 2
      *** Listening Ports ***
      sudo: netstat: command not found
      2024-12-17 19:43:07.123  - info: modbus.1 (28637) Disconnected from slave 192.168.178.121
      2024-12-17 19:44:07.126  - info: modbus.1 (28637) Connected to slave 192.168.178.121
      2024-12-17 19:44:12.130  - warn: modbus.1 (28637) Error: undefined
      2024-12-17 19:44:12.131  - error: modbus.1 (28637) Request timed out.
      2024-12-17 19:44:12.131  - error: modbus.1 (28637) Client in error state.
      2024-12-17 19:44:12.133  - warn: modbus.1 (28637) [DevID_1] Poll error count: 7 code: {"err":"timeout","timeout":5000}
      2024-12-17 19:44:13.132  - info: modbus.1 (28637) Disconnected from slave 192.168.178.121
      2024-12-17 19:45:13.137  - info: modbus.1 (28637) Connected to slave 192.168.178.121
      2024-12-17 19:45:18.140  - warn: modbus.1 (28637) Error: undefined
      2024-12-17 19:45:18.141  - error: modbus.1 (28637) Request timed out.
      2024-12-17 19:45:18.141  - error: modbus.1 (28637) Client in error state.
      2024-12-17 19:45:18.142  - warn: modbus.1 (28637) [DevID_1] Poll error count: 8 code: {"err":"timeout","timeout":5000}
      2024-12-17 19:45:19.142  - info: modbus.1 (28637) Disconnected from slave 192.168.178.121
      2024-12-17 19:46:19.145  - info: modbus.1 (28637) Connected to slave 192.168.178.121
      2024-12-17 19:46:24.147  - warn: modbus.1 (28637) Error: undefined
      2024-12-17 19:46:24.148  - error: modbus.1 (28637) Request timed out.
      2024-12-17 19:46:24.148  - error: modbus.1 (28637) Client in error state.
      2024-12-17 19:46:24.148  - warn: modbus.1 (28637) [DevID_1] Poll error count: 9 code: {"err":"timeout","timeout":5000}
      2024-12-17 19:46:25.148  - info: modbus.1 (28637) Disconnected from slave 192.168.178.121
      2024-12-17 19:47:25.152  - info: modbus.1 (28637) Connected to slave 192.168.178.121
      2024-12-17 19:47:30.155  - warn: modbus.1 (28637) Error: undefined
      2024-12-17 19:47:30.156  - error: modbus.1 (28637) Request timed out.
      2024-12-17 19:47:30.156  - error: modbus.1 (28637) Client in error state.
      2024-12-17 19:47:30.157  - warn: modbus.1 (28637) [DevID_1] Poll error count: 10 code: {"err":"timeout","timeout":5000}
      2024-12-17 19:47:31.157  - info: modbus.1 (28637) Disconnected from slave 192.168.178.121
      iob diag has finished.
      Press any key for a summary
        @axmlm
        Also das Update macht man normalerweise mit dem GW Multitool
        https://zig-star.com/radio-docs/zigstar-multi-tool/ick
        wollte den Stick am Min PC lassen. Komme nicht gut dran aktuell, da der zugestellt ist mit Sachen aus anderem Kellerzimmer.
          AXMLM @Rushmed last edited by
          @rushmed said in Zigbee Netzwerk kaputt:
          @axmlm Steckt der Zigbee Stick direkt am PC und sind sonst noch aktive USB Geräte an der Kiste?
          https://forum.iobroker.net/topic/77409/gel%C3%B6st-zigbee-blackout
          Ich hatte kürzlich ein ähnliches Problem und konnte ein "schlechtes" USB Kabel zum Stick als Ursache identifizieren.
          Meine Probleme begannen als ich nen MiniPC neben meinen Raspi gebaut habe, Zigbee Totalausfall kam dann als ich dem PC noch ne USB HDD verpasst habe.
          ist direkt am PC
            AXMLM last edited by AXMLM
            im PC ist eine kleine M.2 Festplatte, falls es eine Rolle spielen sollte
            Edit: nur die und keine andere
              Interessant ist dass der Bewegungsmelder geht und das Manchmal (sehr oft) das Kellerlicht geschaltet wird, selten nicht. Manchmal geht er nicht mehr aus.
              • haselchen
                haselchen Most Active @AXMLM last edited by
                @axmlm
                Du hast anscheinend ein Netzwerkproblem?!
                Und dann gib im Adapter die by-id ein anstatt dev/tty…..
                A 2 Replies Last reply Reply Quote 1
                  @haselchen
                  der rechner ist per LAN verbunden, also Kabel, du meinst aber bestimmt Zigbee Netzwerk, oder
                  Wo muss ich by-id eingeben?
                  • haselchen
                    @axmlm
                    Überprüf mal ob er ne Netzwerkverbindung hat ( auch im Router nachschauen)
                    Die by-id steht in deiner Iob Diag Langfassung . Die trägst du im Zigbee Adapter ein
                      meinst Du hier?
                      • haselchen
                        @axmlm
                        Genau da
                          @axmlm
                          also ich bin die ganze zeit auf dem Rechner drauf. Über SSH und IOBroker. Aber ich denke du meinst was anderes. Was muss den Online sein? der Stick?
                          • haselchen
                            @axmlm
                            Lies doch bitte was ich schreibe.
                            Die dev/serial/by-id…. die steht in deiner Iob Langfassung.
                            Die kopierst du da raus und trägst sie in den Zigbee Adapter ein anstatt dev/tty….
                            Und dann gibst erstmal Feedback ob der Adapter grün wird
                              @haselchen
                              für mich musst du sehr langsam schreiben, habs nicht so mit skripten, bin aus Maschinenecke.
                              Aber super, dass du mir hilfst,
                              Also ich kopiere die Zeile 156 aus der Langfassung der Diagnosedatei und füge sie in den Adapter ein in die COM-Anschluss Name
                                Habe ich jetzt gemacht. DEr Adapter ist grün, auch mit dev/tty war er grün
                                • haselchen
                                  Und im Log nichts auffälliges?
                                  Poste mal bitte den Adapter Start
                                    Homoran Global Moderator Administrators @AXMLM last edited by
                                    @axmlm sagte in Zigbee Netzwerk kaputt:
                                    nur jetzt wird er auch nach einem Neustart wieder grün, wenn der USB-Port neu zugeordnet wird.
                                      PID
                                      Zeit
                                      debug
                                      Nachricht
                                      modbus.1
                                      33781	2024-12-17 20:15:18.660	info	Disconnected from slave 192.168.178.121
                                      modbus.1
                                      33781	2024-12-17 20:15:17.660	warn	[DevID_1] Poll error count: 11 code: {"err":"timeout","timeout":5000}
                                      modbus.1
                                      33781	2024-12-17 20:15:17.659	error	Client in error state.
                                      modbus.1
                                      33781	2024-12-17 20:15:17.659	error	Request timed out.
                                      modbus.1
                                      33781	2024-12-17 20:15:17.658	warn	Error: undefined
                                      modbus.1
                                      33781	2024-12-17 20:15:12.654	info	Connected to slave 192.168.178.121
                                      zigbee.0
                                      33888	2024-12-17 20:14:34.830	warn	DeviceAvailability:Failed to ping 0x54ef441000ccfabb lumi.plug.aeu001
                                      zigbee.0
                                      33888	2024-12-17 20:14:33.796	warn	DeviceConfigure: 0x54ef441000ccfabb lumi.plug.aeu001 Failed to configure. When device works is all fine when not wake up the device and check again
                                      zigbee.0
                                      33888	2024-12-17 20:14:28.685	warn	DeviceAvailability:Failed to ping 0xe0798dfffeb1cbf1 01MINIZB
                                      zigbee.0
                                      33888	2024-12-17 20:14:19.379	warn	DeviceAvailability:Failed to ping 0xe0798dfffeb4e99c 01MINIZB
                                      zigbee.0
                                      33888	2024-12-17 20:14:18.935	warn	DeviceAvailability:Failed to ping 0x54ef441000c8ebd1 lumi.plug.aeu001
                                      zigbee.0
                                      33888	2024-12-17 20:14:18.577	info	-> Configuring 0x54ef441000ccfabb lumi.plug.aeu001
                                      zigbee.0
                                      33888	2024-12-17 20:14:18.574	warn	DeviceConfigure: 0xcc86ecfffec3c90e TS0044 Failed to configure. When device works is all fine when not wake up the
                                      • haselchen
                                        @axmlm
                                        Try and Error.
                                        Lösch mal ein Device und lerne es neu an.
                                        Im besten Fall erkennt der Adapter/Stick das Gerät wieder.
                                          @haselchen
                                          Meine Barrikaden aus Holz haben wohl wirklich das Signal gestört. Oh je. Das Netzwerk scheint sich aufzubauen. WTF. Bin vorhin dahinter geklettert und habe den Rechner jetzt vor dem Berg aus Rauspund gestellt.
                                            DEr Adapter hat noch nicht alles gefunden , und der Schalter, den ich vorhin gelöscht habe zum Test, pairt sich nicht mehr, obwohl er vor seiner Nase sizt.
                                            1622
