    3. Off Topic
    4. Proxmox
    5. gelöst: Host: Probleme mit unzureichendem Speicherplatz ...
      Thomas Braun Most Active @kiste01 last edited by
      @kiste01
      In der Langfassung könnte man die jetzige Zuteilung sehen...
        kiste01 @Thomas Braun last edited by
        @thomas-braun mach ich sofort
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-26-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
        OS is similar to:
        model name      : QEMU Virtual CPU version 2.5+
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:02:14 up 31 days,  4:02,  3 users,  load average: 0.51, 0.37, 0.66
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                       Local time: Thu 2024-12-19 18:02:14 CET
                   Universal time: Thu 2024-12-19 17:02:14 UTC
                         RTC time: Thu 2024-12-19 17:02:14
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi cdrom floppy sudo audio dip video plugdev users netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev redis
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:             16G        4.2G        9.6G        598K        3.4G         12G
        Swap:           1.0G          0B        1.0G
        Total:           17G        4.2G         10G
        Active iob-Instances:   53
                15992 M total memory
                 3997 M used memory
                 1244 M active memory
                 5015 M inactive memory
                 9121 M free memory
                  224 M buffer memory
                 2979 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        top - 18:02:14 up 31 days,  4:02,  3 users,  load average: 0.51, 0.37, 0.66
        Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15992.7 total,   9121.4 free,   3997.0 used,   3204.4 buff/cache
        MiB Swap:    975.0 total,    975.0 free,      0.0 used.  11995.7 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  7.8G     0  7.8G   0% /dev
        tmpfs          tmpfs     1.6G  580K  1.6G   1% /run
        /dev/sda1      ext4       15G   14G  518M  97% /
        tmpfs          tmpfs     7.9G  4.0K  7.9G   1% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
        [Mon Nov 18 14:00:00 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Nov 18 14:00:00 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        2.0G    /var/
        1.5G    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18
        1.5G    /var/log
        353M    /var/cache
        Archived and active journals take up 31.2M in the file system.
        /opt/iobroker/backups:
        1.5M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.9G    /opt/iobroker/iobroker-data/
        1.6G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        78M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        29M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-SHA_CUL868-if00
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        tcp
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Hosts:
        iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 1295)
        Core adapters versions
        js-controller:  7.0.3
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     6
        +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#2e63ad165a0c0147f01955b024a2ca002299ad65)
        +-- iobroker.fronius-solarweb@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e)
        +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059)
        +-- iobroker.scheppach-roboticmower@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.scheppach-roboticmower.git#b7a5aa58bca3c366b03249e8488ae6d7c4342ffd)
        +-- iobroker.shelly@8.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.shelly.git#1a3ed2bb255be15db71595e10040f2527210f635)
        +-- iobroker.solaredge-modbus@0.0.25 (git+ssh://git@github.com/joergspoerl/ioBroker.solaredge-modbus.git#a17300b3182465292a476c4e0fbaa96c9706e14d)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.airconwithme.0           : airconwithme          : iobroker                                 - disabled, compact disabled
          system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled, compact disabled
        + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled, compact disabled
        + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled, compact disabled
          system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 - disabled, compact disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled, compact disabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
        + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled, compact disabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled, compact disabled
        + system.adapter.deyeidc.1                : deyeidc               : iobroker                                 -  enabled, compact disabled, port: 8899
        + system.adapter.discovery.0              : discovery             : iobroker                                 - disabled, compact disabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 - disabled, compact disabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled, compact disabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
          system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 - disabled, compact disabled
          system.adapter.evcc.0                   : evcc                  : iobroker                                 - disabled, compact disabled, port: 7070
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled, compact disabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled, compact disabled
          system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled, compact disabled
        + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled, compact disabled
        + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
        + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled, compact disabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
          system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled, compact disabled
          system.adapter.iwg-vpn.0                : iwg-vpn               : iobroker                                 - disabled, compact disabled
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, compact disabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
        + system.adapter.kisshome-research.0      : kisshome-research     : iobroker                                 -  enabled, compact disabled
        + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled, compact disabled
        + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled, compact disabled
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, compact disabled, port: 54321
          system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
        + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled, compact disabled
          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1886, bind: 0.0.0.0
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled, compact disabled
        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled, compact disabled
          system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, compact disabled, port: 80, 7575, 8000, 8080, 8081, 8899
        + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled, compact disabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
        + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled, compact disabled
        + system.adapter.scheduler.0              : scheduler             : iobroker                                 -  enabled, compact disabled
          system.adapter.scheppach-roboticmower.0 : scheppach-roboticmower: iobroker                                 - disabled, compact disabled
          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled, compact disabled
          system.adapter.schoolfree.1             : schoolfree            : iobroker                                 -  enabled, compact disabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1886, bind: 0.0.0.0
          system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled, compact disabled
          system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 - disabled, compact disabled
        + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled, compact disabled
          system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.solaredge-modbus.0       : solaredge-modbus      : iobroker                                 - disabled, compact disabled, port: 502
          system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled, compact disabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1887, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled, compact disabled
          system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled, compact disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
          system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled, compact disabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled, compact disabled
          system.adapter.text2command.0           : text2command          : iobroker                                 - disabled, compact disabled
        + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled, compact disabled
          system.adapter.tibberlink.1             : tibberlink            : iobroker                                 - disabled, compact disabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled, compact disabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, compact disabled, port: 80, bind: 0.0.0.0, run as: admin
        + system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 -  enabled, compact disabled
          system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled, compact disabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: tcp://192.168.178.188:6638
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name                   │ url                                                     │ auto upgrade │
        │ 0       │ 'Beta (latest)'        │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
        │ 1       │ 'Stable (default)'     │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
        │ 2       │ 'default.ursprünglich' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 3       │ 'latest.ursprünglich'  │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Active repo(s): Stable (default)
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "airconwithme" : 0.0.4    , installed 0.0.4
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "evcc"         : 0.1.1    , installed 0.1.1
        Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
        Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "go-e"         : 1.0.41   , installed 1.0.41
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
        Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.3    , installed 7.0.3
        Adapter    "kisshome-research": 1.2.5, installed 1.2.5
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
        Adapter    "reolink"      : 1.1.2    , installed 1.1.2
        Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
        Adapter    "schoolfree"   : 1.1.6    , installed 1.1.6
        Adapter    "shelly"       : 8.2.1    , installed 8.4.0
        Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
        Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "telegram-menu": 2.1.3    , installed 2.1.3
        Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tibberlink"   : 3.5.4    , installed 3.5.4
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "vis-2"        : 2.9.64   , installed 2.10.8
        Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.3.5
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "welcome"      : 1.0.2    , installed 1.0.2
        Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        72662
        States:         56413
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       78415875   993130/io.shelly.1
        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       78412777   993137/io.sonoff.0
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       78409630   992629/iobroker.js-
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12100      1/systemd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14041      543/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      104        14030      510/redis-server 12
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       78411365   992647/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       78418952   994076/io.web.0
        tcp6       0      0 ::1:6379                :::*                    LISTEN      104        14031      510/redis-server 12
        tcp6       0      0 :::111                  :::*                    LISTEN      0          13700      1/systemd
        tcp6       0      0 :::80                   :::*                    LISTEN      1001       78418079   994136/io.welcome.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14043      543/sshd: /usr/sbin
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       78414190   993266/io.mihome-va
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       78415877   993119/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       78415922   993179/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       78415923   993179/io.tuya.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13966      475/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          417        1/systemd
        udp6       0      0 :::111                  :::*                                0          12101      1/systemd
        2024-12-19 17:55:12.403  - info: modbus.2 (993030) Disconnected from slave 192.168.178.44
        2024-12-19 17:56:12.405  - info: modbus.2 (993030) Connected to slave 192.168.178.44
        2024-12-19 17:58:42.539  - info: mercedesme.0 (993438) Lost WebSocket connection. Reconnect WebSocket
        2024-12-19 18:00:00.008  - info: go-e.0 (999210) Scheduled restart.
        2024-12-19 18:00:00.011  - info: go-e.0 (999210) terminating
        2024-12-19 18:00:00.011  - info: go-e.0 (999210) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2024-12-19 18:00:00.511  - info: go-e.0 (999210) terminating
        2024-12-19 18:00:00.653  - info: host.iobroker instance system.adapter.go-e.0 scheduled normal terminated and will be restarted on schedule.
        2024-12-19 18:00:00.653  - info: host.iobroker Restart adapter system.adapter.go-e.0 because enabled
        2024-12-19 18:00:02.192  - info: host.iobroker instance system.adapter.go-e.0 in version "1.0.41" started with pid 1005844
        2024-12-19 18:00:05.093  - warn: trashschedule.0 (994008) no events matches type "Wertstofftonne / gelber Sack" with match "Abfuhrtermin Wertstofftonne / gelber Sack (GELB)"
        2024-12-19 18:00:05.333  - info: go-e.0 (1005844) starting. Version 1.0.41 in /opt/iobroker/node_modules/iobroker.go-e, node: v20.18.1, js-controller: 7.0.3
        2024-12-19 18:00:05.384  - info: go-e.0 (1005844) Adapter is staring in Version setByGitHubActions
        2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Server: 192.168.178.171
        2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Intervall: 60
        2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Calculation Method: iob
        2024-12-19 18:00:05.386  - info: go-e.0 (1005844) Set value V2 false of id fup
        2024-12-19 18:00:32.017  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 1006159
        2024-12-19 18:00:34.745  - info: dwd.0 (1006159) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
        2024-12-19 18:00:35.183  - info: dwd.0 (1006159) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
        2024-12-19 18:00:35.184  - info: dwd.0 (1006159) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
        2024-12-19 18:00:35.194  - info: dwd.0 (1006159) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
        2024-12-19 18:00:35.195  - info: dwd.0 (1006159) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
        2024-12-19 18:00:35.206  - info: dwd.0 (1006159) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-12-19 18:00:35.721  - info: host.iobroker instance system.adapter.dwd.0 having pid 1006159 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        iob diag has finished.
          reutli @kiste01 last edited by
          @kiste01 sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
          Wo kann ich ansetzen?
          z.B. mal die Proxmox Instanz aufmachen und schauen, was da so geht:
            Homoran Global Moderator Administrators @kiste01 last edited by
            voll!
              @kiste01
              Ja, sda1 ist (fast) voll.
              Entweder machst du im ioBroker Platz oder du musst im Host-System der VM mehr Platz einräumen.
                Ok. Es ist noch nicht so lange her, da hatte ich das System extra neu aufgesetzt und dachte alle Stellschrauben deutlich erhöht zu haben.
                Ist das der Punkt in proxmox?
                Thomas Braun R 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @kiste01 last edited by Thomas Braun
                  Dann solltest du mal hinterfragen, was denn da so heftig viel Platz einnimmt.
                  Kann man u. a. per
                  sudo ncdu /
                  machen.
                    @kiste01
                    und nach der Analyse, was Dir die Platte "zumüllt":
                    Hardware → Hard Disk → Disk Aktion → Resize
                      Du meinst so was in etwa?
                      pi@iobroker:~$ du -h -a /var/log | sort -hr | head -n 20
                      du: cannot read directory '/var/log/private': Permission denied
                      du: cannot read directory '/var/log/redis': Permission denied
                      1.5G    /var/log
                      121M    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001.journal
                      101M    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000014765-00061ed627ea6251.journal
                      99M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000032250b-000620918fa918f7.journal
                      98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000002604b4-00062032f7da632c.journal
                      98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000001fec6d-00062032e20da8b0.journal
                      98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000019d425-00062032cb9cb472.journal
                      98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000013bbe0-00062032b71061c0.journal
                      98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000000da39a-00062032a26fbce3.journal
                      98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000078b53-000620328e069c1e.journal
                      97M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000002c1d00-000620330e737063.journal
                      93M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000003c2af7-000622e1a3054ded.journal
                      75M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000041d75d-000625466f7bd335.journal
                      65M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@000622cbcddff43a-72f9757d9babbe30.journal~
                      17M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000000938-0006196a726470ea.journal
                      14M     /var/log/installer/cdebconf/templates.dat
                      Dann könnte ich in dem Ordner /var/log/journal/ einiges löschen
                        NICHT einfach stumpf irgendwas löschen!
                        Und du solltest das per
                        ncdu machen, da siehst du eher die dicken Brummer. Dein journal ist nämlich nicht ungewöhnlich groß.
                          ah. Habs gefunden. Musste ich installieren.
                          --- /home/pi ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                            135.9 MiB [#############################################################] /.npm
                             62.9 MiB [############################                                 ] /.cache
                             12.0 KiB [                                                             ]  .bash_history
                             12.0 KiB [                                                             ] /.iobroker
                              8.0 KiB [                                                             ] /.config
                              4.0 KiB [                                                             ]  .bashrc
                              4.0 KiB [                                                             ]  .profile
                              4.0 KiB [                                                             ]  .bash_logout
                              4.0 KiB [                                                             ]  .rediscli_history
                              4.0 KiB [                                                             ]  .npmrc
                              0.0   B [                                                             ]  .sudo_as_admin_successful
                           /home/pi/.npm/_cacache/content-v2 -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                            126.9 MiB [#############################################################] /sha512
                          Davon hab ich überhaupt keine Ahnung, was ich da machen könnte. Da bin ich ehrlich
                            kiste01 @kiste01 last edited by
                            falsche Ebene
                                4.6 GiB [#############################################################] /opt
                            .   3.9 GiB [####################################################         ] /usr
                                2.5 GiB [#################################                            ] /home
                            .   2.0 GiB [##########################                                   ] /var
                              328.3 MiB [####                                                         ] /boot
                            .   4.1 MiB [                                                             ] /etc
                            . 556.0 KiB [                                                             ] /run
                            . 172.0 KiB [                                                             ] /tmp
                            !  16.0 KiB [                                                             ] /lost+found
                                8.0 KiB [                                                             ] /media
                                4.0 KiB [                                                             ] /dev
                            e   4.0 KiB [                                                             ] /srv
                            !   4.0 KiB [                                                             ] /root
                            e   4.0 KiB [                                                             ] /mnt
                            .   0.0   B [                                                             ] /proc
                            .   0.0   B [                                                             ] /sys
                            @   0.0   B [                                                             ]  initrd.img.old
                            @   0.0   B [                                                             ]  vmlinuz.old
                            @   0.0   B [                                                             ]  vmlinuz
                            @   0.0   B [                                                             ]  lib64
                            @   0.0   B [                                                             ]  sbin
                            @   0.0   B [                                                             ]  lib
                            @   0.0   B [                                                             ]  bin
                             2.7 GiB [#############################################################] /node_modules
                                1.8 GiB [########################################                     ] /iobroker-data
                              @reutli
                              Muss ich nach dem risize noch was machen? Neustart VM und Proxmox hab ich gemacht. Es werden jetzt 36G angezeigt, aber es bleibt bei den ursprünglichen15G
                              pi@iobroker:~$ df -h
                              Filesystem      Size  Used Avail Use% Mounted on
                              udev            7.8G     0  7.8G   0% /dev
                              tmpfs           1.6G  576K  1.6G   1% /run
                              /dev/sda1        15G   14G  482M  97% /
                              R Thomas Braun 2 Replies Last reply Reply Quote 0
                                @kiste01
                                Keine Ahnung bei mir war nach dem risize immer alles in Butter.
                                Wahrscheinlich musst Du die vorhandene root Partition mit 'gparted' oder anderem Tool vergrößern?
                                Da müssen aber Linux Spezis wie @Thomas-Braun ran...
                                  Ja, der 'von außen' nun zur Verfügung gestellte zusätzliche Platz muss jetzt auch 'im Inneren der VM' zugeteilt werden.
                                  Bei nativen Systemen starte ich dazu extern GParted oder sonst ein Live-Linux und vergrößere die Partition dann darüber. Bei VMs hab ich aber keine Aktien.
                                    @thomas-braun sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
                                    läuft genauso.
                                    gparted live Image in der PVE Zur Verfügung stellen.
                                    Diese dann als boot festlegen und proxmox neu starten
                                    Partition snpassen
                                    Boot zurückstellen
                                    Neustart
                                    fertig
                                      reutli last edited by Homoran
                                      @homoran sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
                                      läuft genauso.
                                      Hier (https://pve.proxmox.com/wiki/Resize_disks) auch genau beschrieben und zu gparted gibt es auch genug im Netz
                                        kiste01 @reutli last edited by
                                        @reutli
                                        Ich hab die größe der Partition vergrößert.
                                        Falls jemand ein step-by-step Anleitung braucht: https://youtu.be/-BjkHOxUqYc?si=911Sz85lnDcGq943
                                        Ich musste die UID (ca. bei 13:00) nicht umstellen
                                        R Meister Mopper 2 Replies Last reply Reply Quote 1
                                          reutli @kiste01 last edited by reutli
                                          @kiste01
                                          Sehr gut. Dann stell' bitte den thread auf gelöst (Titel editieren und "gelöst" hinzufügen).
                                          • Meister Mopper
                                            Meister Mopper @kiste01 last edited by
                                            @kiste01 sagte in gelöst: Host: Probleme mit unzureichendem Speicherplatz ...:
                                            @reutli
                                            Das ist keine gute Anleitung! Als root mit sudo arbeiten und eine VM in der Proxmox GUI mit stop beenden ist ein NOGO.
                                            Zudem ist das Ändern der UUID nicht erforderlich.
                                            Also für Lesende: Bitte nicht SO machen!
                                            81.1k
                                            2159
