    4. Test Adapter rpi2 2.x
      Tobias78 last edited by Tobias78
      Kurze Frage:
      Ich bekomme beim Start der aktuellen Version die Fehlermeldung ins log:
      rpi2 has an invalid jsonConfig:
      [{"instancePath":"/items/_monitoring/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["accordion","alive","autocomplete","autocompleteSendTo","certificate","certificates","checkLicense","checkbox","chips","color","coordinates","cron","custom","datePicker","deviceManager","divider","file","fileSelector","func","header","icon","image","imageSendTo","instance","interface","ip","jsonEditor","language","number","objectId","panel","password","pattern","port","qrCode","room","select","selectSendTo","sendTo","setState","slider","state","staticImage","staticLink","staticText","table","text","textSendTo","timePicker","user","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      Editiere ich die Datei mit
      sudo nano /opt/iobroker/iobroker-data/files/rpi2.admin/jsonConfig.json
      Steht dort:
      "i18n": true,
          "type": "table",
          "items": {
              "_monitoring": {
                  "type": "tabs",
                  "label": "Monitoring",
                  "items": {
                      "_explanation": {
                          "type": "staticText",
                          "text": "MonitoringExplanation",
                          "newLine
      ": true
      Richtig müsste in Zeile 5 statt:
      "type": "tabs",
      also
      "type": "table",
      sein, oder?
      Damit kommt die Fehlermeldung nicht und der Adapter funktioniert. Falls das richtig ist, könnte / müsste dies im Quellcode angepasst werden.
      Der Fehler tritt auch bei einer "frischen" Installation des Adapters auf.
      • Moppedman
        Moppedman @Garfonso last edited by Moppedman
        @garfonso
        Ich stoppe den io-Broker ja über ssh mit "iob stop". Daher kann ich dir nicht sagen in welchem Zustand die States dann stehen. Der io-Broker läuft dann ja nicht mehr.
        Habe aber festgestellt das beim Anhalten der Instanz des rpi2 Adapters die Relais das gleiche Verhalten zeigen und abfallen.
        Ich gehe davon aus, das beim ordnungsgemäßem Runterfahren des io-Brokers eine Routine aufgerufen wird die alle konfigurierten Ausgänge auf "0" bzw. keinen Strom / Spannung schaltet. Denn alle geschalteten Relais fallen beim alten Adapter ab und die Kontroll-LED auf meiner Relaisplatine erlischt.
        Habe mal das Verhalten getestet und in nachfolgende Tabelle eingetragen. Die States habe ich nach den Stoppen des rpi2 Adapters in den Objekten nachgeschaut und dann eingetragen. Man sieht das beim alten Adapter unabhängig vom Startwert "0" oder "1" beim Setzen auf FALSE das Relais anzieht. Beim neuen Adapter ist das Anziehen des Relais abhängig von Startwert. Bei "0" und FALSE ist das Relais AN. Bei "1" und FALSE ist das Relais aus.
        Garfonso S 2 Replies Last reply Reply Quote 0
        • Garfonso
          Garfonso Developer last edited by
          @smallfeuer said in Test Adapter rpi2 2.x:
          hoffe sie kommen nach dem nächsten Update nicht zurück.
          Öhm... das hoffe ich auch.
          Ich sehe da nichts, was dein Problem beheben würde. kopfkratz
          @tobias78 said in Test Adapter rpi2 2.x:
          Kurze Frage:
          Steht dort:
          "i18n": true,
              "type": "table",
              "items": {
                  "_monitoring": {
                      "type": "tabs",
                      "items": {
                          "_explanation": {
                              "newLine
          ": true
          "type": "tabs",
          also
          "type": "table",
          sein, oder?
          Danke für die Analyse. Aber welche Version des Adapters?
          Wenn ich es richtig sehe, müsste dort seit 2.2.1 panel statt tabs stehen, was tatsächlich falsch war. table ergibt wenig Sinn. Funktioniert damit noch die Configurationsseite?
          • Garfonso
            Garfonso Developer @Moppedman last edited by
            @moppedman said in Test Adapter rpi2 2.x:
            Dann stoppe doch mal nur den Adapter?
            Wobei ich nicht glaube, dass die States irgendwas mit dem Verhalten zu tun haben, wenn du den ganzen ioBroker stoppst...
            Und ja, das kann sein, dass das Verhalten anders ist, weil die GPIOs anders angesprochen werden.
            Interessant, dass du das erwartest. Ist das Konsensmeinung?
            Ich würde zugegebenermaßen eher erwarten, dass nichts mehr passiert, wenn ich den ioBroker beende.
            Das heißt, beim alten Adapter war "Startwert 1" fehlerhaft und hat einfach gar keinen Unterschied gemacht? Oder siehst du irgendeinen anderen Unterschied, den du nicht in der Tabelle hast?
            Und zur Spalte "gpioinfo" wäre noch interessant, was die sagt, wenn der Adapter beendet wurde. 🙂
            Moppedman 1 Reply Last reply Reply Quote 0
              Smallfeuer @Moppedman last edited by
              @moppedman
              Hast du dabei mal die Datenpunkte getrakt, beim Start des Adapter?
              Ich hatte den Wechsel auch nur in der Datenbank gesehen, bzw. am Torantrieb gemerkt, dem reicht ja ein kurzer Impuls zum Öffnen.
              Das Endergebnis war bei mir ebenfalls korrekt auf die Voreinstellung, nur halt Signalflattern zwischendrin.
              Vielleicht war es aber nur ein BUG bei meiner 1. Installation. Wie gesagt, jetzt läuft es 😉 wie immer.
              • Moppedman
                Hi @garfonso ,
                Wie geschrieben ist das Verhalten beim stoppen der Instanz identisch wie beim stoppen des ioBroker über SSH. Die Tabelle gilt also für beides.
                Ob meine Meinung Konsens der Community ist muss die Gruppe entscheiden und nicht ich.
                Meine Überlegung kommen aus einem reinen Sicherheitsaspekt. Wenn du an einer Industrieanlage einen NOT-AUS drückst muss alles Spannungsfrei geschaltet werden und es dürfen keine gefahrbringenden Bewegungen mehr eingeleitet werden. Ich habe mein Programm und auch die Verkabelung zu den Ventilen entsprechend aufgebaut. Das die Ausgänge auch beim Anhalten der Instanz weggeschaltet werden ist daher -sicherheitstechnisch- für mich logisch.
                Für mich sieht es so aus, dass der Startwert bzw. Anfangswert in den beiden Adapterversion völlig unterschiedlich interpretiert wird.
                • Im "alten" Adapter gibt der Startwert 1/0 an ob der Ausgang beim Starten des Adapters gesetzt werden soll oder nicht. Das Verhalten im Programm beim Setzen des States auf FALSE / TRUE ist davon völlig unabhängig aber immer gleich
                • Im "neuen" Adapter gibt der Anfangswert 1/0 an ob ich in einem Programm mit FALSE oder TRUE auf einen Ausgang Spannung gebe oder nicht, d.h. das Verhalten wird invertiert.
                Würdest du dem Zustimmen ?
                • Garfonso
                  Eben... daher macht der Adapter nichts, wenn er ausgeschaltet wird. Woher soll der wissen, bei welchem Spannungszustand sich was bewegt oder nicht?
                  Ich kann halt weder im aktuellen noch im alten Adaptercode sehen, dass da beim Beenden noch etwas in die GPIOs geschrieben wird. Das wäre ja notwendig, um die beim Beenden alle GPIOs auf 0 zu stellen. Und dann ist die Frage, ob das sicher für alle GPIOs ausgeführt wird, wenn z.B. der ioBroker oder Adapter abstürzen sollte... Insofern ist es, aus softwaretechnologischer Sicht, sicherer, beim Beenden nicht noch die States zu schreiben.
                  Das scheint so zu stimmen. Ich habe das Setting wohl völlig missinterpretiert. Wird angepasst.
                  L Moppedman S 3 Replies Last reply Reply Quote 0
                    Laser @Garfonso last edited by Laser
                    @garfonso Mir wäre es am Liebsten, wenn nach dem Adapter Neustart die Ausgänge nicht gesetzt sind. Nach einem Stromausfall z.B. ist kein Ausgang gesetzt. Wenn ich etwas vom Ausgang will, muß ich Ihn neu beschreiben.
                    • Moppedman
                      Moppedman @Laser last edited by
                      @laser Dazu habe ich ja mit @garfonso geschrieben. Er hat zuletzt ja gesagt das anpassen zu wollen. Wenn er das eingebaut hat, kannst du das Startverhalten über die Adaptereinstellung einstellen wie du willst.
                      • Moppedman
                        @garfonso Erst man vielen Dank das du das Startverhalten anpassen willst. Wenn du das fertig hast teste ich das gerne für dich. Einfach nur melden
                        Hinsichtlich des Freischalten verstehe ich jetzt, das weder im alten noch im neunen Adapter die Ausgänge zurückgeschaltet werden.
                        Kann es sein das im Betriebssystem für die GPIOs dieses Verhalten hinterlegt ist. Wenn ich das richtig gelesen habe wurden die GPIO von der Pi Foundation völlig neu aufgesetzt.
                        Garfonso 2 Replies Last reply Reply Quote 0
                          searcher57 @Garfonso last edited by
                          @garfonso
                          was ist denn jetzt los? Auf einmal funktioniert der Gaszähler nicht mehr.
                          Deinen Hinweis habe ich durchgeführt.
                           sudo apt install libgpiod-dev
                          Paketlisten werden gelesen… Fertig
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          libgpiod-dev ist schon die neueste Version (1.6.3-1+b3).
                          Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                            linux-headers-6.6.47+rpt-common-rpi linux-kbuild-6.6.47+rpt
                          Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Trotzdem kommen folgende Fehlermeldungen auf meinem Raspi 5:
                          v7.1.5
                          13
                          Log-Größe: 135.0 KB
                          Zeit
                          rpi2.0
                          	2024-12-22 13:58:12.326	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
                          rpi2.0
                          	2024-12-22 13:58:12.326	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
                          rpi2.0
                          	2024-12-22 13:58:12.325	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
                          rpi2.0
                          	2024-12-22 13:58:12.090	info	starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
                          Hast Du vielleicht eine Erklärung? Bis gestern hat alles funktioniert, wie es soll.
                            Thomas Braun Most Active @searcher57 last edited by
                            @searcher57
                            sudo apt update
                            apt policy libgpiod*
                            sagt? Und hast du den Adapter reinstalliert?
                            Mal in
                            raspi-config
                            nach gpio geschaut?
                              @thomas-braun said in Test Adapter rpi2 2.x:
                              raspi-config
                              So ich habe in der config I8 Remote GPIO Enable/disable remote access to GPIO pins aktiviert. Oder ist das falsch?
                              @searcher57
                              sudo apt update
                              Mal in
                              raspi-config
                              nach gpio geschaut?
                              Also ich habe GPIO aktiviert, oder war das falsch?
                              Hier die Ausgabe:
                              sudo apt update
                              OK:1 http://deb.debian.org/debian bookworm InRelease
                              OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
                              Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [55,4 kB]
                              OK:4 http://archive.raspberrypi.com/debian bookworm InRelease
                              OK:5 https://repos.influxdata.com/debian stable InRelease
                              OK:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                              OK:7 https://repo.mosquitto.org/debian bookworm InRelease
                              Es wurden 55,4 kB in 1 s geholt (85,0 kB/s).
                              Alle Pakete sind aktuell.
                              libgpiod-dev:
                                Installiert:           1.6.3-1+b3
                                Installationskandidat: 1.6.3-1+b3
                                Versionstabelle:
                               *** 1.6.3-1+b3 500
                                      100 /var/lib/dpkg/status
                              libgpiod-doc:
                                Installiert:           (keine)
                                Versionstabelle:
                                   1.6.3-1 500
                                      500 http://deb.debian.org/debian bookworm/main armhf Packages
                              libgpiod2:
                                Versionstabelle:
                               *** 1.6.3-1+b3 500
                                @searcher57 sagte in Test Adapter rpi2 2.x:
                                Nein, das passt.
                                  searcher57 @Thomas Braun last edited by
                                  Nein, das passt.
                                  Bis jetzt kein Erfolg. In der Config habe ich vorher nie etwas eingestellt.
                                    @searcher57
                                    Und was verrät
                                    cd /opt/iobroker/ && npm ls opengpio
                                    Adapter nochmal drüber installiert?
                                      @searcher57
                                      Und was verrät
                                      pi@Raspi58GB:~ $ cd /opt/iobroker/ && npm ls opengpio
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      └─┬ iobroker.rpi2@2.2.2
                                        └── opengpio@1.0.17
                                      pi@Raspi58GB:/opt/iobroker $
                                      Adapter gerade neu installiert, ohne Erfolg!
                                      S Homoran 2 Replies Last reply Reply Quote 0
                                        searcher57 @searcher57 last edited by
                                        @searcher57 said in Test Adapter rpi2 2.x:
                                        @searcher57
                                        Und was verrät
                                          └── opengpio@1.0.17
                                        Hier nochmal das Protokoll:
                                        pi2.0
                                        	2024-12-22 16:20:54.990	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
                                        rpi2.0
                                        	2024-12-22 16:20:54.990	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
                                        rpi2.0
                                        	2024-12-22 16:20:54.989	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
                                        rpi2.0
                                        	2024-12-22 16:20:54.675	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
                                        rpi2.0
                                        	2024-12-22 16:20:50.340	info	terminating
                                        rpi2.0
                                        	2024-12-22 16:20:49.841	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        rpi2.0
                                        	2024-12-22 16:20:49.840	info	terminating
                                        rpi2.0
                                        	2024-12-22 16:20:49.839	info	Got terminate signal TERMINATE_YOURSELF
                                        rpi2.0
                                        	2024-12-22 16:19:27.683	info	GPIO ports are not configured
                                        rpi2.0
                                        	2024-12-22 16:19:26.628	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
                                        rpi2.0
                                        	2024-12-22 16:16:33.859	info	terminating
                                        rpi2.0
                                        	2024-12-22 16:16:33.359	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        rpi2.0
                                        	2024-12-22 16:16:33.359	info	terminating
                                        rpi2.0
                                        	2024-12-22 16:16:33.358	info	Got terminate signal TERMINATE_YOURSELF
                                        rpi2.0
                                        	2024-12-22 16:05:28.448	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
                                        rpi2.0
                                        	2024-12-22 16:05:28.448	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
                                          Homoran Global Moderator Administrators @searcher57 last edited by
                                          bist du sicher?
                                          nicht nur die Instanz neu erstellt?
                                            searcher57 @Homoran last edited by
                                            @homoran said in Test Adapter rpi2 2.x:
                                            bist du sicher?
                                            Ja, bin mir sicher. Den Adapter gelöscht und über beta neu installiert und konfiguriert.
                                            519
                                            145918
