    4. [gelöst] Canvas - compiled against a different Node.js vers,
      Diamand2k22 @Thomas Braun last edited by
      Irgendwie werd ich aus diesem thread nicht schlau 😀
      Hab das gleiche Problem mit:
      Status Ecovacs Deebot:The module /opt/iobroker/node_modules/canvas/build/Release/canvas.node
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 108. This version of Node.js requires
      NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild or npm install).
      Mein ssh Ausgabe sagt:
      pi4b@pi4b:~$ cd /opt/iobroker
      pi4b@pi4b:/opt/iobroker$ npm ls canvas
      iobroker.inst@3.0.0 /opt/iobroker
      └─┬ iobroker.ecovacs-deebot@1.4.15
        └─┬ ecovacs-deebot@0.9.6-beta.3
          └── canvas@2.10.2
      Wie bekomm ich den Fehler weg?
      System ist uptodate.
        Thomas Braun Most Active @Diamand2k22 last edited by
        @diamand2k22
        canvas muss neu gegen NODE_MODULE_VERSION 115 gebaut werden. Sollte eigentlich automatisch passieren.
        Entweder iobroker.ecovacs-deebot nochmal frisch installieren oder canvas direkt im entsprechenden Verzeichnis nochmal bauen lassen.
          Hast du da auf die Schnelle einen Befehl bevor ich mir wieder meinen npm tree zerstrubbel?
            Thomas Braun Most Active @Diamand2k22 last edited by Thomas Braun
            @diamand2k22
            iob upgrade iobroker.ecovacs-deebot@1.4.15
            Edit: Kommando berichtigt.
              Ich habe statt install Upgrade gemacht
              pi4b@pi4b:~$ iob install iobroker.ecovacs-deebot@1.4.15
              adapter "ecovacs-deebot" already installed. Use "upgrade" to upgrade to a newer version.
              pi4b@pi4b:~$ iob upgrade iobroker.ecovacs-deebot@1.4.15
              Would you like to reinstall version 1.4.15 of ecovacs-deebot now? [(y)es, (n)o]: y
              Update ecovacs-deebot from @1.4.15 to @1.4.15
              Uninstall npm packet "iobroker.ecovacs-deebot" for a clean re-installation
              removed 45 packages in 22s
              319 packages are looking for funding
                run `npm fund` for details
              NPM version: 10.7.0
              Installing iobroker.ecovacs-deebot@1.4.15... (System call)
              added 45 packages in 3m
              321 packages are looking for funding
              upload [5] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/admin.d.ts admin.d.ts video/mp2t
              upload [4] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/ecovacs-deebot.png ecovacs-deebot.png image/png
              upload [3] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/index_m.html index_m.html text/html
              upload [2] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/jsonConfig.json jsonConfig.json application/json
              upload [1] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/style.css style.css text/css
              upload [0] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/words.js words.js application/javascript
              pi4b@pi4b:~$
                Thomas Braun Most Active last edited by
                @diamand2k22 sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
                Ja, Fehler von mir. Muss upgrade lauten.
                  Passt danke, ich habe in dem Zug den js-Controller auch gleich auf die v6.0.8 mit Iob upgrade self gebracht. Ist soweit alles durchgelaufen 👍🏻
                    Hallo Thomas,
                    ich hab hier wieder ein Problem mit dem canvas Paket.
                    Wie kann ich das direkt builden lassen?
                    aktuell:
                    └── (empty)
                      Am besten 'indirekt' durch Reinstallation des entsprechenden iobroker-Adapters.
                        hab ich schon probiert,
                        aber immer noch fehlendes canvas Paket
                        pi4b@pi4b:/opt/iobroker$ iob upgrade iobroker.ecovacs-deebot@1.4.15
                        removed 45 packages in 29s
                        316 packages are looking for funding
                        NPM version: 10.9.0
                        added 45 packages in 48s
                        Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.15"
                        └── (empty)
                          @diamand2k22
                          Läuft bei mir durch:
                          echad@chet:/opt/iobroker $ npm ls canvas
                          ├─┬ iobroker.echarts@1.9.5
                          │ ├── canvas@2.11.2
                          │ └─┬ jsdom@25.0.1
                          │   └── canvas@2.11.2 deduped
                          └─┬ iobroker.mihome-vacuum@4.2.0
                          echad@chet:/opt/iobroker $ iob add ecovacs-deebot
                          NPM version: 10.9.2
                          added 33 packages in 2m
                          230 packages are looking for funding
                          host.chet install adapter ecovacs-deebot
                          host.chet object system.adapter.ecovacs-deebot created/updated
                          host.chet create instance ecovacs-deebot
                          host.chet object system.adapter.ecovacs-deebot.0.alive created
                          host.chet object system.adapter.ecovacs-deebot.0.connected created
                          host.chet object system.adapter.ecovacs-deebot.0.compactMode created
                          host.chet object system.adapter.ecovacs-deebot.0.cpu created
                          host.chet object system.adapter.ecovacs-deebot.0.cputime created
                          host.chet object system.adapter.ecovacs-deebot.0.memHeapUsed created
                          host.chet object system.adapter.ecovacs-deebot.0.memHeapTotal created
                          host.chet object system.adapter.ecovacs-deebot.0.memRss created
                          host.chet object system.adapter.ecovacs-deebot.0.uptime created
                          host.chet object system.adapter.ecovacs-deebot.0.inputCount created
                          host.chet object system.adapter.ecovacs-deebot.0.outputCount created
                          host.chet object system.adapter.ecovacs-deebot.0.eventLoopLag created
                          host.chet object system.adapter.ecovacs-deebot.0.sigKill created
                          host.chet object system.adapter.ecovacs-deebot.0.logLevel created
                          host.chet object ecovacs-deebot.0.info created
                          host.chet object ecovacs-deebot.0.info.connection created
                          host.chet object ecovacs-deebot.0 created
                          host.chet Set default value of ecovacs-deebot.0.info.connection: false
                          host.chet object system.adapter.ecovacs-deebot.0 created
                          │ ├── canvas@2.11.2
                          │ └─┬ jsdom@25.0.1
                          ├─┬ iobroker.ecovacs-deebot@1.4.15
                          │ └─┬ ecovacs-deebot@0.9.6-beta.3
                          │   └── canvas@2.10.2
                            oh man, was ist denn da schon wieder kaputt ? 😥
                              @diamand2k22
                              Hau den Adapter mal komplett von der Kiste runter und dann wieder frisch drauf.
                              Am besten mit --debug dann:
                              iob add ecovacs-deebot --debug
                                $ iobroker url mrbungle64/ioBroker.ecovacs-deebot --host pi4b --debug
                                install mrbungle64/ioBroker.ecovacs-deebot
                                NPM version: 10.9.0
                                Installing mrbungle64/ioBroker.ecovacs-deebot... (System call)
                                npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                                npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.npm warn deprecated gauge@3.0.2: This package is no longer supported.
                                > canvas@2.10.2 install> node-pre-gyp install --fallback-to-build --update-binary
                                node-pre-gyp info it worked if it ends with oknode-pre-gyp info using node-pre-gyp@1.0.11node-pre-gyp info using node@22.12.0 | linux | arm64
                                (node:2806199) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.(Use `node --trace-deprecation ...` to show where the warning was created)node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz
                                node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@22.12.0 (node-v127 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
                                gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
                                gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                                gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/canvas/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/22.12.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.12.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.12.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/canvas',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
                                gyp info ok
                                gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node COPY Release/canvas-postbuild.node CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                                In file included from ../src/backend/Backend.h:6, from ../src/backend/Backend.cc:1:../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, imp::Sig)’:../../nan/nan.h:2548:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2548 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2549 | name | ~~~~ 2550 | , getter_ | ~~~~~~~~~ 2551 | , setter_ | ~~~~~~~~~ 2552 | , obj | ~~~~~ 2553 | , settings | ~~~~~~~~~~ 2554 | , attribute | ~~~~~~~~~~~ 2555 | #if (NODE_MODULE_VERSION < NODE_16_0_MODULE_VERSION) | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 2556 | , signature | ~~~~~~~~~~~ 2557 | #endif | ~~~~~~ 2558 | ); | ~ In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-function.h:15, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8.h:33, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/node.h:73, from ../../nan/nan.h:62:/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute)’:../../nan/nan.h:2594:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2594 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2595 | name | ~~~~ 2596 | , getter_ | ~~~~~~~~~ 2597 | , setter_ | ~~~~~~~~~ 2598 | , obj | ~~~~~ 2599 | , settings | ~~~~~~~~~~ 2600 | , attribute | ~~~~~~~~~~~ 2601 | ); | ~ /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~
                                make: *** [canvas.target.mk:159: Release/obj.target/canvas/src/backend/Backend.o] Fehler 1make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                                gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:216:23)gyp ERR! System Linux 6.1.21-v8+
                                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--update-binary" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v127"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v22.12.0gyp ERR! node-gyp -v v10.2.0gyp ERR! not ok
                                node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (node:events:524:28)node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1101:16)node-pre-gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:304:5)
                                node-pre-gyp ERR! node -v v22.12.0node-pre-gyp ERR! node-pre-gyp -v v1.0.11node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)
                                removed 2 packages, and changed 3 packages in 48s
                                316 packages are looking for funding run `npm fund` for details
                                Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.16-alpha.4"
                                Update "system.adapter.ecovacs-deebot.0"
                                Update "system.adapter.ecovacs-deebot.1"
                                Process exited with code 0
                                irgendwie findet er das Package nicht.
                                  Ja, das ist nicht schlimm, weil es dann aus den Quellen gebaut wird.
                                  Sieht dann so aus:
                                  echad@chet:/opt/iobroker $ iob add ecovacs-deebot --debug
                                  NPM version: 10.9.2
                                  npm warn deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
                                  npm warn deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
                                  npm warn deprecated @xmldom/xmldom@0.9.0-beta.11: this version has critical issues, please update to the latest version
                                  npm warn deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
                                  node-pre-gyp info using node@23.5.0 | linux | arm64
                                  (node:122704) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                  node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
                                  node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
                                  node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@23.5.0 (node-v131 ABI, glibc) (falling back to source compile with node-gyp)
                                  node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
                                  gyp info using node-gyp@11.0.0
                                  gyp info ok
                                  gyp info spawn args '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build/config.gypi',
                                  gyp info spawn args '/home/iobroker/.cache/node-gyp/23.5.0/include/node/common.gypi',
                                  gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.5.0',
                                  gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.5.0/<(target_arch)/node.lib',
                                  gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas',
                                  gyp info ok
                                  gyp info spawn make
                                  make: Entering directory '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build'
                                  In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-local-handle.h:13,
                                                   from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:12,
                                                   from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:24,
                                                   from /home/iobroker/.cache/node-gyp/23.5.0/include/node/node.h:73,
                                                   from ../../../../nan/nan.h:62,
                                  In member function ‘bool v8::api_internal::IndirectHandleBase::IsEmpty() const’,
                                      inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:450:20,
                                      inlined from ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:463:8,
                                      inlined from ‘void Nan::Persistent<T, M>::Reset(const v8::Local<S>&) [with S = v8::Object; T = v8::Object; M = v8::NonCopyablePersistentTraits<v8::Object>]’ at ../../../../nan/nan_persistent_12_inl.h:29:33,
                                      inlined from ‘void Nan::ObjectWrap::Wrap(v8::Local<v8::Object>)’ at ../../../../nan/nan_object_wrap.h:56:23,
                                      inlined from ‘static void Backend::init(const Nan::FunctionCallbackInfo<v8::Value>&)’ at ../src/backend/Backend.cc:23:16:
                                  /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:56:43: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                     56 |   V8_INLINE bool IsEmpty() const { return location_ == nullptr; }
                                  In member function ‘void v8::api_internal::IndirectHandleBase::Clear()’,
                                      inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:452:14,
                                  /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:59:38: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                     59 |   V8_INLINE void Clear() { location_ = nullptr; }
                                  In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-object.h:11,
                                                   from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:13:
                                  In member function ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’,
                                  /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:465:16: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                    465 |   this->slot() = New(isolate, *other);
                                    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                                    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                                    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                                    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                                    CXX(target) Release/obj.target/canvas/src/Backends.o
                                    CXX(target) Release/obj.target/canvas/src/Canvas.o
                                  In file included from ../../../../nan/nan_callbacks.h:123,
                                                   from ../../../../nan/nan.h:182,
                                                   from ../src/Canvas.h:5,
                                                   from ../src/Canvas.cc:3:
                                  ../../../../nan/nan_callbacks_12_inl.h: In instantiation of ‘v8::Local<v8::Object> Nan::FunctionCallbackInfo<T>::Holder() const [with T = v8::Value]’:
                                  ../src/Canvas.cc:649:63:   required from here
                                  ../../../../nan/nan_callbacks_12_inl.h:112:68: warning: ‘v8::Local<v8::Object> v8::FunctionCallbackInfo<F>::Holder() const [with T = v8::Value]’ is deprecated: V8 will stop providing access to hidden prototype (i.e. JSGlobalObject). Use This() instead. \nDO NOT try to workaround this by accessing JSGlobalObject via v8::Object::GetPrototype() - it'll be deprecated soon too. \nSee http://crbug.com/333672197.  [-Wdeprecated-declarations]
                                    112 |   inline v8::Local<v8::Object> Holder() const { return info_.Holder(); }
                                  In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-isolate.h:22,
                                                   from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-snapshot.h:9,
                                                   from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-context.h:15,
                                                   from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:26,
                                                   from ../../../../nan/nan.h:62:
                                  /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-function-callback.h:658:15: note: declared here
                                    658 | Local<Object> FunctionCallbackInfo<T>::Holder() const {
                                    @diamand2k22
                                    Bitte ein gescheites Terminal verwenden, dann ist der Output auch besser lesbar.
                                    Wie in meinem Beispiel.
                                      Diamand2k22 @Thomas Braun last edited by Diamand2k22
                                      diesen ganzen Errors beim build von canvas machen micht stutzig... ab Zeile 140....
                                      pi4b@pi4b:/opt/iobroker$ iob upgrade iobroker.ecovacs-deebot@1.4.15 --debug
                                      Would you like to downgrade ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15 now? [(y)es, (n)o]: y
                                      Update ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15
                                      NPM version: 10.9.0
                                      (node:2806815) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                      gyp info ok
                                      gyp info ok
                                      gyp info spawn make
                                       2549 |       name
                                       2550 |     , getter_
                                       2551 |     , setter_
                                       2552 |     , obj
                                       2553 |     , settings
                                       2554 |     , attribute
                                       2556 |     , signature
                                       2557 | #endif
                                       2558 |   );
                                       2595 |       name
                                       2596 |     , getter_
                                       2597 |     , setter_
                                       2598 |     , obj
                                       2599 |     , settings
                                       2600 |     , attribute
                                       2601 |   );
                                      gyp ERR! not ok
                                      node-pre-gyp ERR! System Linux 6.1.21-v8+
                                      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
                                      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                      added 2 packages, and changed 3 packages in 50s
                                        @diamand2k22
                                        Du solltest doch den Adapter komplett runterhauen und frisch neuinstallieren.
                                          @diamand2k22
                                          Bullseye oder Bookworm?
                                          Und verwende nodejs@20.
                                            bookworm und nodejs@22
                                            hab den Fehler mit dem canvas übrigens auch bei dem esphome Adapter...
                                            13012
