    4. [gelöst] Canvas - compiled against a different Node.js vers,
      Diamand2k22 @Thomas Braun last edited by
      Passt danke, ich habe in dem Zug den js-Controller auch gleich auf die v6.0.8 mit Iob upgrade self gebracht. Ist soweit alles durchgelaufen 👍🏻
        Diamand2k22 last edited by
        Hallo Thomas,
        ich hab hier wieder ein Problem mit dem canvas Paket.
        Wie kann ich das direkt builden lassen?
        aktuell:
        pi4b@pi4b:/opt/iobroker$ npm ls canvas
        iobroker.inst@3.0.0 /opt/iobroker
        └── (empty)
          Thomas Braun Most Active @Diamand2k22 last edited by
          @diamand2k22 sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
          Am besten 'indirekt' durch Reinstallation des entsprechenden iobroker-Adapters.
            hab ich schon probiert,
            aber immer noch fehlendes canvas Paket
            pi4b@pi4b:/opt/iobroker$ iob upgrade iobroker.ecovacs-deebot@1.4.15
            Would you like to reinstall version 1.4.15 of ecovacs-deebot now? [(y)es, (n)o]: y
            Update ecovacs-deebot from @1.4.15 to @1.4.15
            Uninstall npm packet "iobroker.ecovacs-deebot" for a clean re-installation
            removed 45 packages in 29s
            316 packages are looking for funding
              run `npm fund` for details
            NPM version: 10.9.0
            Installing iobroker.ecovacs-deebot@1.4.15... (System call)
            added 45 packages in 48s
            Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.15"
            upload [5] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/admin.d.ts admin.d.ts video/mp2t
            upload [4] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/ecovacs-deebot.png ecovacs-deebot.png image/png
            upload [3] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/index_m.html index_m.html text/html
            upload [2] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/jsonConfig.json jsonConfig.json application/json
            upload [1] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/style.css style.css text/css
            upload [0] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/words.js words.js application/javascript
            └── (empty)
              Thomas Braun Most Active @Diamand2k22 last edited by Thomas Braun
              @diamand2k22
              Läuft bei mir durch:
              echad@chet:/opt/iobroker $ npm ls canvas
              ├─┬ iobroker.echarts@1.9.5
              │ ├── canvas@2.11.2
              │ └─┬ jsdom@25.0.1
              │   └── canvas@2.11.2 deduped
              └─┬ iobroker.mihome-vacuum@4.2.0
              echad@chet:/opt/iobroker $ iob add ecovacs-deebot
              NPM version: 10.9.2
              added 33 packages in 2m
              230 packages are looking for funding
              host.chet install adapter ecovacs-deebot
              host.chet object system.adapter.ecovacs-deebot created/updated
              host.chet create instance ecovacs-deebot
              host.chet object system.adapter.ecovacs-deebot.0.alive created
              host.chet object system.adapter.ecovacs-deebot.0.connected created
              host.chet object system.adapter.ecovacs-deebot.0.compactMode created
              host.chet object system.adapter.ecovacs-deebot.0.cpu created
              host.chet object system.adapter.ecovacs-deebot.0.cputime created
              host.chet object system.adapter.ecovacs-deebot.0.memHeapUsed created
              host.chet object system.adapter.ecovacs-deebot.0.memHeapTotal created
              host.chet object system.adapter.ecovacs-deebot.0.memRss created
              host.chet object system.adapter.ecovacs-deebot.0.uptime created
              host.chet object system.adapter.ecovacs-deebot.0.inputCount created
              host.chet object system.adapter.ecovacs-deebot.0.outputCount created
              host.chet object system.adapter.ecovacs-deebot.0.eventLoopLag created
              host.chet object system.adapter.ecovacs-deebot.0.sigKill created
              host.chet object system.adapter.ecovacs-deebot.0.logLevel created
              host.chet object ecovacs-deebot.0.info created
              host.chet object ecovacs-deebot.0.info.connection created
              host.chet object ecovacs-deebot.0 created
              host.chet Set default value of ecovacs-deebot.0.info.connection: false
              host.chet object system.adapter.ecovacs-deebot.0 created
              │ ├── canvas@2.11.2
              │ └─┬ jsdom@25.0.1
              ├─┬ iobroker.ecovacs-deebot@1.4.15
              │ └─┬ ecovacs-deebot@0.9.6-beta.3
              │   └── canvas@2.10.2
                oh man, was ist denn da schon wieder kaputt ? 😥
                  @diamand2k22
                  Hau den Adapter mal komplett von der Kiste runter und dann wieder frisch drauf.
                  Am besten mit --debug dann:
                  iob add ecovacs-deebot --debug
                    $ iobroker url mrbungle64/ioBroker.ecovacs-deebot --host pi4b --debug
                    install mrbungle64/ioBroker.ecovacs-deebot
                    NPM version: 10.9.0
                    Installing mrbungle64/ioBroker.ecovacs-deebot... (System call)
                    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.npm warn deprecated gauge@3.0.2: This package is no longer supported.
                    > canvas@2.10.2 install> node-pre-gyp install --fallback-to-build --update-binary
                    node-pre-gyp info it worked if it ends with oknode-pre-gyp info using node-pre-gyp@1.0.11node-pre-gyp info using node@22.12.0 | linux | arm64
                    (node:2806199) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.(Use `node --trace-deprecation ...` to show where the warning was created)node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz
                    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@22.12.0 (node-v127 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
                    gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
                    gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                    gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/canvas/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/22.12.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.12.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.12.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/canvas',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
                    gyp info ok
                    gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node COPY Release/canvas-postbuild.node CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                    In file included from ../src/backend/Backend.h:6, from ../src/backend/Backend.cc:1:../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, imp::Sig)’:../../nan/nan.h:2548:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2548 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2549 | name | ~~~~ 2550 | , getter_ | ~~~~~~~~~ 2551 | , setter_ | ~~~~~~~~~ 2552 | , obj | ~~~~~ 2553 | , settings | ~~~~~~~~~~ 2554 | , attribute | ~~~~~~~~~~~ 2555 | #if (NODE_MODULE_VERSION < NODE_16_0_MODULE_VERSION) | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 2556 | , signature | ~~~~~~~~~~~ 2557 | #endif | ~~~~~~ 2558 | ); | ~ In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-function.h:15, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8.h:33, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/node.h:73, from ../../nan/nan.h:62:/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute)’:../../nan/nan.h:2594:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2594 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2595 | name | ~~~~ 2596 | , getter_ | ~~~~~~~~~ 2597 | , setter_ | ~~~~~~~~~ 2598 | , obj | ~~~~~ 2599 | , settings | ~~~~~~~~~~ 2600 | , attribute | ~~~~~~~~~~~ 2601 | ); | ~ /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~
                    make: *** [canvas.target.mk:159: Release/obj.target/canvas/src/backend/Backend.o] Fehler 1make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:216:23)gyp ERR! System Linux 6.1.21-v8+
                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--update-binary" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v127"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v22.12.0gyp ERR! node-gyp -v v10.2.0gyp ERR! not ok
                    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (node:events:524:28)node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1101:16)node-pre-gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:304:5)
                    node-pre-gyp ERR! node -v v22.12.0node-pre-gyp ERR! node-pre-gyp -v v1.0.11node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)
                    removed 2 packages, and changed 3 packages in 48s
                    316 packages are looking for funding run `npm fund` for details
                    Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.16-alpha.4"
                    Update "system.adapter.ecovacs-deebot.0"
                    Update "system.adapter.ecovacs-deebot.1"
                    Process exited with code 0
                    irgendwie findet er das Package nicht.
                      Ja, das ist nicht schlimm, weil es dann aus den Quellen gebaut wird.
                      Sieht dann so aus:
                      echad@chet:/opt/iobroker $ iob add ecovacs-deebot --debug
                      NPM version: 10.9.2
                      npm warn deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
                      npm warn deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
                      npm warn deprecated @xmldom/xmldom@0.9.0-beta.11: this version has critical issues, please update to the latest version
                      npm warn deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
                      node-pre-gyp info using node@23.5.0 | linux | arm64
                      (node:122704) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                      node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
                      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
                      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@23.5.0 (node-v131 ABI, glibc) (falling back to source compile with node-gyp)
                      node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
                      gyp info using node-gyp@11.0.0
                      gyp info ok
                      gyp info spawn args '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build/config.gypi',
                      gyp info spawn args '/home/iobroker/.cache/node-gyp/23.5.0/include/node/common.gypi',
                      gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.5.0',
                      gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.5.0/<(target_arch)/node.lib',
                      gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas',
                      gyp info ok
                      gyp info spawn make
                      make: Entering directory '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build'
                      In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-local-handle.h:13,
                                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:12,
                                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:24,
                                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/node.h:73,
                                       from ../../../../nan/nan.h:62,
                      In member function ‘bool v8::api_internal::IndirectHandleBase::IsEmpty() const’,
                          inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:450:20,
                          inlined from ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:463:8,
                          inlined from ‘void Nan::Persistent<T, M>::Reset(const v8::Local<S>&) [with S = v8::Object; T = v8::Object; M = v8::NonCopyablePersistentTraits<v8::Object>]’ at ../../../../nan/nan_persistent_12_inl.h:29:33,
                          inlined from ‘void Nan::ObjectWrap::Wrap(v8::Local<v8::Object>)’ at ../../../../nan/nan_object_wrap.h:56:23,
                          inlined from ‘static void Backend::init(const Nan::FunctionCallbackInfo<v8::Value>&)’ at ../src/backend/Backend.cc:23:16:
                      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:56:43: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                         56 |   V8_INLINE bool IsEmpty() const { return location_ == nullptr; }
                      In member function ‘void v8::api_internal::IndirectHandleBase::Clear()’,
                          inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:452:14,
                      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:59:38: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                         59 |   V8_INLINE void Clear() { location_ = nullptr; }
                      In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-object.h:11,
                                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:13:
                      In member function ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’,
                      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:465:16: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                        465 |   this->slot() = New(isolate, *other);
                        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                        CXX(target) Release/obj.target/canvas/src/Backends.o
                        CXX(target) Release/obj.target/canvas/src/Canvas.o
                      In file included from ../../../../nan/nan_callbacks.h:123,
                                       from ../../../../nan/nan.h:182,
                                       from ../src/Canvas.h:5,
                                       from ../src/Canvas.cc:3:
                      ../../../../nan/nan_callbacks_12_inl.h: In instantiation of ‘v8::Local<v8::Object> Nan::FunctionCallbackInfo<T>::Holder() const [with T = v8::Value]’:
                      ../src/Canvas.cc:649:63:   required from here
                      ../../../../nan/nan_callbacks_12_inl.h:112:68: warning: ‘v8::Local<v8::Object> v8::FunctionCallbackInfo<F>::Holder() const [with T = v8::Value]’ is deprecated: V8 will stop providing access to hidden prototype (i.e. JSGlobalObject). Use This() instead. \nDO NOT try to workaround this by accessing JSGlobalObject via v8::Object::GetPrototype() - it'll be deprecated soon too. \nSee http://crbug.com/333672197.  [-Wdeprecated-declarations]
                        112 |   inline v8::Local<v8::Object> Holder() const { return info_.Holder(); }
                      In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-isolate.h:22,
                                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-snapshot.h:9,
                                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-context.h:15,
                                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:26,
                                       from ../../../../nan/nan.h:62:
                      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-function-callback.h:658:15: note: declared here
                        658 | Local<Object> FunctionCallbackInfo<T>::Holder() const {
                        @diamand2k22
                        Bitte ein gescheites Terminal verwenden, dann ist der Output auch besser lesbar.
                        Wie in meinem Beispiel.
                          Diamand2k22 @Thomas Braun last edited by Diamand2k22
                          diesen ganzen Errors beim build von canvas machen micht stutzig... ab Zeile 140....
                          pi4b@pi4b:/opt/iobroker$ iob upgrade iobroker.ecovacs-deebot@1.4.15 --debug
                          Would you like to downgrade ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15 now? [(y)es, (n)o]: y
                          Update ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15
                          NPM version: 10.9.0
                          (node:2806815) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                          gyp info ok
                          gyp info ok
                          gyp info spawn make
                           2549 |       name
                           2550 |     , getter_
                           2551 |     , setter_
                           2552 |     , obj
                           2553 |     , settings
                           2554 |     , attribute
                           2556 |     , signature
                           2557 | #endif
                           2558 |   );
                           2595 |       name
                           2596 |     , getter_
                           2597 |     , setter_
                           2598 |     , obj
                           2599 |     , settings
                           2600 |     , attribute
                           2601 |   );
                          gyp ERR! not ok
                          node-pre-gyp ERR! System Linux 6.1.21-v8+
                          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
                          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                          added 2 packages, and changed 3 packages in 50s
                            @diamand2k22
                            Du solltest doch den Adapter komplett runterhauen und frisch neuinstallieren.
                              @diamand2k22
                              Bullseye oder Bookworm?
                              Und verwende nodejs@20.
                                bookworm und nodejs@22
                                hab den Fehler mit dem canvas übrigens auch bei dem esphome Adapter...
                                  @diamand2k22
                                  Dann hast du aber mit Sicherheit einen Versuch unternommen, von einer Vorversion auf den 'Bookworm' zu springen.
                                  Das geht aber regelmäßig in die Hose.
                                  Installier das System komplett NEU.
                                    Bookworm hab ich schon lange drauf und auch bis jetzt nie ein Problem gehabt.
                                    auch canvas hat bis dato funktioniert.
                                    erst seid dem letzten sudo apt update && full-upgrade hab ich dieses Problem
                                    ich sehe du hast da schon node@23.5.0 am laufen 😬
                                      Es ist aber trotzdem nicht richtig installiert. Da läuft mindestens noch der Bullseye-Kernel.
                                      So komische Fehler zeigen sich immer erst nach einiger Zeit. Das System fängt an sich merkwürdig zu verhalten.
                                      Ja, ist mein Bastelsystem. Das andere System läuft auf nodejs@20.
                                      Bookworm-Kernel:
                                      echad@chet:~ $ uname -a
                                      Linux chet 6.6.62+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64 GNU/Linux
                                        ja sieht bei mir so aus:
                                        pi4b@pi4b:~$ uname -a
                                        Linux pi4b 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU
                                        schau mal hier:
                                        https://github.com/Automattic/node-canvas/issues/2377
                                        hong6316 created this issue in Automattic/node-canvas
                                        closed npm intall not working on node v22 #2377
                                          Thomas Braun Most Active @Thomas Braun last edited by
                                          @thomas-braun sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
                                          Ich zitiere mich selbst:
                                            6.1.21-v8+
                                            Ist wie gesagt der falsche Kernel.
                                            12242
