    4. [gelöst] Canvas - compiled against a different Node.js vers,
      Diamand2k22 @Thomas Braun last edited by
      oh man, was ist denn da schon wieder kaputt ? 😥
        Thomas Braun Most Active @Diamand2k22 last edited by Thomas Braun
        @diamand2k22
        Hau den Adapter mal komplett von der Kiste runter und dann wieder frisch drauf.
        Am besten mit --debug dann:
        iob add ecovacs-deebot --debug
          $ iobroker url mrbungle64/ioBroker.ecovacs-deebot --host pi4b --debug
          install mrbungle64/ioBroker.ecovacs-deebot
          NPM version: 10.9.0
          Installing mrbungle64/ioBroker.ecovacs-deebot... (System call)
          npm warn deprecated npmlog@5.0.1: This package is no longer supported.
          npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.npm warn deprecated gauge@3.0.2: This package is no longer supported.
          > canvas@2.10.2 install> node-pre-gyp install --fallback-to-build --update-binary
          node-pre-gyp info it worked if it ends with oknode-pre-gyp info using node-pre-gyp@1.0.11node-pre-gyp info using node@22.12.0 | linux | arm64
          (node:2806199) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.(Use `node --trace-deprecation ...` to show where the warning was created)node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz
          node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@22.12.0 (node-v127 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
          gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
          gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
          gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/canvas/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/22.12.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.12.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.12.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/canvas',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
          gyp info ok
          gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node COPY Release/canvas-postbuild.node CXX(target) Release/obj.target/canvas/src/backend/Backend.o
          In file included from ../src/backend/Backend.h:6, from ../src/backend/Backend.cc:1:../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, imp::Sig)’:../../nan/nan.h:2548:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2548 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2549 | name | ~~~~ 2550 | , getter_ | ~~~~~~~~~ 2551 | , setter_ | ~~~~~~~~~ 2552 | , obj | ~~~~~ 2553 | , settings | ~~~~~~~~~~ 2554 | , attribute | ~~~~~~~~~~~ 2555 | #if (NODE_MODULE_VERSION < NODE_16_0_MODULE_VERSION) | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 2556 | , signature | ~~~~~~~~~~~ 2557 | #endif | ~~~~~~ 2558 | ); | ~ In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-function.h:15, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8.h:33, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/node.h:73, from ../../nan/nan.h:62:/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute)’:../../nan/nan.h:2594:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2594 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2595 | name | ~~~~ 2596 | , getter_ | ~~~~~~~~~ 2597 | , setter_ | ~~~~~~~~~ 2598 | , obj | ~~~~~ 2599 | , settings | ~~~~~~~~~~ 2600 | , attribute | ~~~~~~~~~~~ 2601 | ); | ~ /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~
          make: *** [canvas.target.mk:159: Release/obj.target/canvas/src/backend/Backend.o] Fehler 1make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
          gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:216:23)gyp ERR! System Linux 6.1.21-v8+
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--update-binary" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v127"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v22.12.0gyp ERR! node-gyp -v v10.2.0gyp ERR! not ok
          node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (node:events:524:28)node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1101:16)node-pre-gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:304:5)
          node-pre-gyp ERR! node -v v22.12.0node-pre-gyp ERR! node-pre-gyp -v v1.0.11node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)
          removed 2 packages, and changed 3 packages in 48s
          316 packages are looking for funding run `npm fund` for details
          upload [5] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/admin.d.ts admin.d.ts video/mp2t
          upload [4] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/ecovacs-deebot.png ecovacs-deebot.png image/png
          upload [3] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/index_m.html index_m.html text/html
          upload [2] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/jsonConfig.json jsonConfig.json application/json
          upload [1] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/style.css style.css text/css
          upload [0] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/words.js words.js application/javascript
          Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.16-alpha.4"
          Update "system.adapter.ecovacs-deebot.0"
          Update "system.adapter.ecovacs-deebot.1"
          Process exited with code 0
          irgendwie findet er das Package nicht.
            @diamand2k22 sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
            Ja, das ist nicht schlimm, weil es dann aus den Quellen gebaut wird.
            Sieht dann so aus:
            echad@chet:/opt/iobroker $ iob add ecovacs-deebot --debug
            NPM version: 10.9.2
            Installing iobroker.ecovacs-deebot@1.4.15... (System call)
            npm warn deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
            npm warn deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
            npm warn deprecated @xmldom/xmldom@0.9.0-beta.11: this version has critical issues, please update to the latest version
            npm warn deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
            node-pre-gyp info using node@23.5.0 | linux | arm64
            (node:122704) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
            node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
            node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
            node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@23.5.0 (node-v131 ABI, glibc) (falling back to source compile with node-gyp)
            node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
            gyp info using node-gyp@11.0.0
            gyp info ok
            gyp info spawn args '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build/config.gypi',
            gyp info spawn args '/home/iobroker/.cache/node-gyp/23.5.0/include/node/common.gypi',
            gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.5.0',
            gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.5.0/<(target_arch)/node.lib',
            gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas',
            gyp info ok
            gyp info spawn make
            make: Entering directory '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build'
            In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-local-handle.h:13,
                             from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:12,
                             from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:24,
                             from /home/iobroker/.cache/node-gyp/23.5.0/include/node/node.h:73,
                             from ../../../../nan/nan.h:62,
            In member function ‘bool v8::api_internal::IndirectHandleBase::IsEmpty() const’,
                inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:450:20,
                inlined from ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:463:8,
                inlined from ‘void Nan::Persistent<T, M>::Reset(const v8::Local<S>&) [with S = v8::Object; T = v8::Object; M = v8::NonCopyablePersistentTraits<v8::Object>]’ at ../../../../nan/nan_persistent_12_inl.h:29:33,
                inlined from ‘void Nan::ObjectWrap::Wrap(v8::Local<v8::Object>)’ at ../../../../nan/nan_object_wrap.h:56:23,
                inlined from ‘static void Backend::init(const Nan::FunctionCallbackInfo<v8::Value>&)’ at ../src/backend/Backend.cc:23:16:
            /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:56:43: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
               56 |   V8_INLINE bool IsEmpty() const { return location_ == nullptr; }
            In member function ‘void v8::api_internal::IndirectHandleBase::Clear()’,
                inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:452:14,
            /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:59:38: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
               59 |   V8_INLINE void Clear() { location_ = nullptr; }
            In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-object.h:11,
                             from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:13:
            In member function ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’,
            /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:465:16: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
              465 |   this->slot() = New(isolate, *other);
              CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
              CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
              CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
              CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
              CXX(target) Release/obj.target/canvas/src/Backends.o
              CXX(target) Release/obj.target/canvas/src/Canvas.o
            In file included from ../../../../nan/nan_callbacks.h:123,
                             from ../../../../nan/nan.h:182,
                             from ../src/Canvas.h:5,
                             from ../src/Canvas.cc:3:
            ../../../../nan/nan_callbacks_12_inl.h: In instantiation of ‘v8::Local<v8::Object> Nan::FunctionCallbackInfo<T>::Holder() const [with T = v8::Value]’:
            ../src/Canvas.cc:649:63:   required from here
            ../../../../nan/nan_callbacks_12_inl.h:112:68: warning: ‘v8::Local<v8::Object> v8::FunctionCallbackInfo<F>::Holder() const [with T = v8::Value]’ is deprecated: V8 will stop providing access to hidden prototype (i.e. JSGlobalObject). Use This() instead. \nDO NOT try to workaround this by accessing JSGlobalObject via v8::Object::GetPrototype() - it'll be deprecated soon too. \nSee http://crbug.com/333672197.  [-Wdeprecated-declarations]
              112 |   inline v8::Local<v8::Object> Holder() const { return info_.Holder(); }
            In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-isolate.h:22,
                             from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-snapshot.h:9,
                             from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-context.h:15,
                             from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:26,
                             from ../../../../nan/nan.h:62:
            /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-function-callback.h:658:15: note: declared here
              658 | Local<Object> FunctionCallbackInfo<T>::Holder() const {
              @diamand2k22
              Bitte ein gescheites Terminal verwenden, dann ist der Output auch besser lesbar.
              Wie in meinem Beispiel.
                Diamand2k22 @Thomas Braun last edited by Diamand2k22
                diesen ganzen Errors beim build von canvas machen micht stutzig... ab Zeile 140....
                pi4b@pi4b:/opt/iobroker$ iob upgrade iobroker.ecovacs-deebot@1.4.15 --debug
                Would you like to downgrade ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15 now? [(y)es, (n)o]: y
                Update ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15
                NPM version: 10.9.0
                (node:2806815) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                gyp info ok
                gyp info ok
                gyp info spawn make
                 2549 |       name
                 2550 |     , getter_
                 2551 |     , setter_
                 2552 |     , obj
                 2553 |     , settings
                 2554 |     , attribute
                 2556 |     , signature
                 2557 | #endif
                 2558 |   );
                 2595 |       name
                 2596 |     , getter_
                 2597 |     , setter_
                 2598 |     , obj
                 2599 |     , settings
                 2600 |     , attribute
                 2601 |   );
                gyp ERR! not ok
                node-pre-gyp ERR! System Linux 6.1.21-v8+
                node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
                node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                added 2 packages, and changed 3 packages in 50s
                Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.15"
                  @diamand2k22
                  Du solltest doch den Adapter komplett runterhauen und frisch neuinstallieren.
                    @diamand2k22
                    Bullseye oder Bookworm?
                    Und verwende nodejs@20.
                      bookworm und nodejs@22
                      hab den Fehler mit dem canvas übrigens auch bei dem esphome Adapter...
                        @diamand2k22
                        Dann hast du aber mit Sicherheit einen Versuch unternommen, von einer Vorversion auf den 'Bookworm' zu springen.
                        Das geht aber regelmäßig in die Hose.
                        Installier das System komplett NEU.
                          Bookworm hab ich schon lange drauf und auch bis jetzt nie ein Problem gehabt.
                          auch canvas hat bis dato funktioniert.
                          erst seid dem letzten sudo apt update && full-upgrade hab ich dieses Problem
                          ich sehe du hast da schon node@23.5.0 am laufen 😬
                            Es ist aber trotzdem nicht richtig installiert. Da läuft mindestens noch der Bullseye-Kernel.
                            So komische Fehler zeigen sich immer erst nach einiger Zeit. Das System fängt an sich merkwürdig zu verhalten.
                            Ja, ist mein Bastelsystem. Das andere System läuft auf nodejs@20.
                            Bookworm-Kernel:
                            echad@chet:~ $ uname -a
                            Linux chet 6.6.62+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64 GNU/Linux
                              ja sieht bei mir so aus:
                              pi4b@pi4b:~$ uname -a
                              Linux pi4b 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU
                              schau mal hier:
                              https://github.com/Automattic/node-canvas/issues/2377
                              hong6316 created this issue in Automattic/node-canvas
                              closed npm intall not working on node v22 #2377
                                Thomas Braun Most Active @Thomas Braun last edited by
                                @thomas-braun sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
                                Ich zitiere mich selbst:
                                  6.1.21-v8+
                                  Ist wie gesagt der falsche Kernel.
                                    gibt es denn eine Möglichkeit, den Kernel zu tauschen ohne Neuinstallation? oder ist der Murks zu groß?
                                      @diamand2k22
                                      Mit viel Gebastel und ggfls. zweifelhaftem Ergebnis:
                                      Wer es entgegen aller Warnungen versuchen möchte:
                                      https://www.heise.de/hintergrund/Raspberry-Pi-OS-InPlace-Upgrade-von-Bullseye-auf-Bookworm-wagen-9999516.html
                                        ok...dann werd ich die Neu-Installation mal in Angriff nehmen demnächst... d.h. jetzt konkret der veraltete Kernel in Kombination mit nodjs@22 führt zu dem Problem?
                                          @diamand2k22
                                          Kann ich dir nicht sagen. Ich kann dir aber sagen, dass es auf meinem 'senkrechten' System auch mit nodejs@22 baut:
                                          echad@chet:/opt/iobroker $ nodejs -v
                                          v22.12.0
                                          NPM version: 10.9.0
                                          (node:129683) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          gyp info ok
                                          gyp http GET https://nodejs.org/download/release/v22.12.0/node-v22.12.0-headers.tar.gz
                                          gyp http 200 https://nodejs.org/download/release/v22.12.0/node-v22.12.0-headers.tar.gz
                                          gyp http GET https://nodejs.org/download/release/v22.12.0/SHASUMS256.txt
                                          gyp http 200 https://nodejs.org/download/release/v22.12.0/SHASUMS256.txt
                                          gyp info ok
                                          gyp info spawn make
                                          In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-local-handle.h:13,
                                                           from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-array-buffer.h:12,
                                                           from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8.h:24,
                                              inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:469:20,
                                              inlined from ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’ at /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:482:8,
                                          /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-handle-base.h:56:43: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                              inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:471:14,
                                          /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-handle-base.h:59:38: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                          In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-object.h:10,
                                                           from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-array-buffer.h:13:
                                          /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:484:16: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                            484 |   this->slot() = New(isolate, *other);
                                            CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                                            CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                                            CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                                          ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:
                                          ../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch]
                                           2494 |   switch (state->textAlignment) {
                                          ../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
                                            CXX(target) Release/obj.target/canvas/src/closure.o
                                            CXX(target) Release/obj.target/canvas/src/color.o
                                            CXX(target) Release/obj.target/canvas/src/Image.o
                                          ../src/Image.cc: In member function ‘cairo_status_t Image::loadSVGFromBuffer(uint8_t*, unsigned int)’:
                                          ../src/Image.cc:1196:29: warning: ‘void rsvg_handle_get_dimensions(RsvgHandle*, RsvgDimensionData*)’ is deprecated: Use 'rsvg_handle_get_intrinsic_size_in_pixels' instead [-Wdeprecated-declarations]
                                           1196 |   rsvg_handle_get_dimensions(_rsvg, dims);
                                          In file included from ../src/Image.h:28,
                                                           from ../src/Image.cc:3:
                                          /usr/include/librsvg-2.0/librsvg/rsvg.h:708:6: note: declared here
                                            708 | void rsvg_handle_get_dimensions (RsvgHandle *handle, RsvgDimensionData *dimension_data);
                                          ../src/Image.cc: In member function ‘cairo_status_t Image::renderSVGToSurface()’:
                                          ../src/Image.cc:1235:48: warning: ‘gboolean rsvg_handle_render_cairo(RsvgHandle*, cairo_t*)’ is deprecated: Use 'rsvg_handle_render_document' instead [-Wdeprecated-declarations]
                                           1235 |   gboolean render_ok = rsvg_handle_render_cairo(_rsvg, cr);
                                          In file included from /usr/include/librsvg-2.0/librsvg/rsvg.h:1452:
                                          /usr/include/librsvg-2.0/librsvg/rsvg-cairo.h:88:10: note: declared here
                                             88 | gboolean rsvg_handle_render_cairo (RsvgHandle *handle, cairo_t *cr);
                                            CXX(target) Release/obj.target/canvas/src/ImageData.o
                                            CXX(target) Release/obj.target/canvas/src/init.o
                                            CXX(target) Release/obj.target/canvas/src/register_font.o
                                            SOLINK_MODULE(target) Release/obj.target/canvas.node
                                            COPY Release/canvas.node
                                          make: Leaving directory '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build'
                                          gyp info ok
                                          node-pre-gyp info ok
                                          added 33 packages in 2m
                                          230 packages are looking for funding
                                          host.chet install adapter ecovacs-deebot
                                          host.chet object system.adapter.ecovacs-deebot created/updated
                                          host.chet create instance ecovacs-deebot
                                          host.chet object system.adapter.ecovacs-deebot.0.alive created
                                          host.chet object system.adapter.ecovacs-deebot.0.connected created
                                          host.chet object system.adapter.ecovacs-deebot.0.compactMode created
                                          host.chet object system.adapter.ecovacs-deebot.0.cpu created
                                          host.chet object system.adapter.ecovacs-deebot.0.cputime created
                                          host.chet object system.adapter.ecovacs-deebot.0.memHeapUsed created
                                          host.chet object system.adapter.ecovacs-deebot.0.memHeapTotal created
                                          host.chet object system.adapter.ecovacs-deebot.0.memRss created
                                          host.chet object system.adapter.ecovacs-deebot.0.uptime created
                                          host.chet object system.adapter.ecovacs-deebot.0.inputCount created
                                          host.chet object system.adapter.ecovacs-deebot.0.outputCount created
                                          host.chet object system.adapter.ecovacs-deebot.0.eventLoopLag created
                                          host.chet object system.adapter.ecovacs-deebot.0.sigKill created
                                          host.chet object system.adapter.ecovacs-deebot.0.logLevel created
                                          host.chet object ecovacs-deebot.0.info created
                                          host.chet object ecovacs-deebot.0.info.connection created
                                          host.chet object ecovacs-deebot.0 created
                                          host.chet Set default value of ecovacs-deebot.0.info.connection: false
                                          host.chet object system.adapter.ecovacs-deebot.0 created
                                          echad@chet:/opt/iobroker $ node -v
                                          v22.12.0
                                          echad@chet:/opt/iobroker $ cd /opt/iobroker/ && npm ls canvas
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├─┬ iobroker.echarts@1.9.5
                                          │ ├── canvas@2.11.2
                                          │ └─┬ jsdom@25.0.1
                                          │   └── canvas@2.11.2 deduped
                                          ├─┬ iobroker.ecovacs-deebot@1.4.15
                                          │ └─┬ ecovacs-deebot@0.9.6-beta.3
                                          │   └── canvas@2.10.2
                                          └─┬ iobroker.mihome-vacuum@4.2.0
                                            Diamand2k22 last edited by Diamand2k22
                                            @thomas-braun said in [gelöst] Canvas - compiled against a different Node.js vers,:
                                            wenn ich es manuell über die Konsole installiere, mit:
                                            npm install canvas@2.10.2
                                            dann gehts.
                                            pi4b@pi4b:/opt/iobroker$ npm ls canvas
                                            └─┬ iobroker.ecovacs-deebot@1.4.16-alpha.4 (git+ssh://git@github.com/mrbungle64/                            ioBroker.ecovacs-deebot.git#22db1e39d24c855f6ae4eb567e8e9cdaa4ac2524)
                                              ├── canvas@2.10.2
                                              └─┬ ecovacs-deebot@0.9.6-beta.7
                                                └── canvas@2.10.2 deduped
                                            12238
