    4. Kann nichts mehr im Dateimanager löschen
      helfi9999 @sigi234 last edited by
      @sigi234 versuche mal diese Einstellung:
      und den Adapter ws
        sigi234 Forum Testing Most Active @helfi9999 last edited by
        @helfi9999
        Leider nein
        • DJMarc75
          DJMarc75 @sigi234 last edited by
          @sigi234 Der Einfachheit halber: Rechner mal neu gestartet ?
            sigi234 Forum Testing Most Active @DJMarc75 last edited by sigi234
            @djmarc75 sagte in Kann nichts mehr im Dateimanager löschen:
            Jupp,
            host.Medion
            2022-10-29 12:50:35.560	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:31.534	error	instance system.adapter.hs100.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:27.477	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:23.911	error	instance system.adapter.echarts.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:11.666	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:07.762	error	instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:03.318	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            backitup.0
            7816	2022-10-29 12:50:02.745	error	backitup.0 already running
            host.Medion
            2022-10-29 12:50:00.480	error	instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            info.0
            8316	2022-10-29 12:49:59.914	error	info.0 already running
            host.Medion
            2022-10-29 12:49:56.374	error	instance system.adapter.musiccast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            musiccast.0
            12480	2022-10-29 12:49:55.796	error	musiccast.0 already running
            host.Medion
            2022-10-29 12:49:48.187	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            web.0
            13500	2022-10-29 12:49:47.575	error	web.0 already running
            host.Medion
            2022-10-29 12:49:43.762	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            discovery.0
            9224	2022-10-29 12:49:43.203	error	discovery.0 already running
            host.Medion
            2022-10-29 12:49:42.536	error	instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            meross.0
            14272	2022-10-29 12:49:41.955	error	meross.0 already running
            host.Medion
            2022-10-29 12:49:41.416	error	instance system.adapter.p
            Diese Fehler kommen nach jedem Neustart, gehen aber nach 5 Minuten weg.
              Homoran Global Moderator Administrators @sigi234 last edited by
              @sigi234 sagte in Kann nichts mehr im Dateimanager löschen:
              da laufen die Prozesse noch. Da ist beim Neustart anscheinend nicht korrekt beendet worden.
              welche admin Version?
                sigi234 Forum Testing Most Active @Homoran last edited by
                @homoran sagte in Kann nichts mehr im Dateimanager löschen:
                6.2.23
                  @sigi234 hätte mich bei dir auch gewundert wenn das noch 6.2,22 gewesen wäre. War aber mein letzter Strohhalm.
                    Bernd1967 1 Reply Last reply Reply Quote 0
                    • Bernd1967
                      Bernd1967 @sigi234 last edited by
                      @sigi234
                      Ich weiß, ist schon lange her, aber konntest Du das Problem damals irgendwie lösen ?
                      Hab das Problem auchmit vis-2.
                        sigi234 Forum Testing Most Active @Bernd1967 last edited by
                        @bernd1967 sagte in Kann nichts mehr im Dateimanager löschen:
                        @sigi234
                        Selbe Fehlermeldungen?
                        • MartinP
                          MartinP @sigi234 last edited by
                          Selbes Betriebssystem wäre meine erste Frage gewesen....
                          iobroker unter Windows zu installieren, würde mir nicht einfallen 😉
                          • Bernd1967
                            Bernd1967 @MartinP last edited by
                            @martinp
                            Unter Windows läuft sonst alles super.
                            • MartinP
                              MartinP @Bernd1967 last edited by
                              @bernd1967 Naja, ich vermute schon dass nur ein verschwindend geringer Prozentsatz der iobroker Installationen unter Windows läuft...
                              Falls das ein Windows-Spezifisches Problem ist, ist die Wahrscheinlichkeit eben recht gering, dass jemand über die gleiche Sache gestolpert ist, und deshalb Hilfestellung leisten kann ...
                              Zur Meldung:
                              error Caught by controller[0]: ReplyError: Error ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest'
                              cache.manifest ist bei mir unter Linux auch kein Directory ...
                              • Gaspode
                                Gaspode last edited by
                                @Bernd1967
                                Welche ioBroker Version nutzt du denn? Welchen Controller? Wie hast du installiert?
                                Beschreibe mal bitte die Schritte, mit denen du das Problem reproduzieren kannst und poste ein Log mit den Fehler-Ausgaben.
                                Ein "Hab das gleiche Problem" auf einen über zwei Jahre alten Beitrag ohne weitere Infos ist ein wenig Info, zumal das Problem der scheinbar noch laufenden Prozesse nach Neustart inzwischen behoben wurde. Ob das zusammen hängt ist natürlich eine andere Frage.
                                Also: Bitte mehr Details, dann würde ich das auch testweise mal hier bei mir nachstellen.
                                • Bernd1967
                                  Bernd1967 @Gaspode last edited by Bernd1967
                                  @gaspode
                                  Hier hatte ich nur nachgefragt weil der Fehler bei bestimmten Punkten ähnlich ist.
                                  Hier hatte ich die Daten gepostet.
                                  vis
                                  897
