    4. js-controller Lucy (Version 7.0) jetzt im Stable Repository
      Thomas Braun Most Active @JackDaniel last edited by
      @jackdaniel sagte in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
      node-gyp -v v7.1.2
      Sollte nach meinem dafürhalten ab deutlich höhere Version zeigen.
      echad@chet:/opt/iobroker/node_modules/.bin $ ./node-gyp -v
      v10.3.1
      Sicher das da alles auf Stand und ordentlich installiert ist? Schau per
      iob diag
      nach dem Gesamtkonstrukt.
      JackDaniel 1 Reply Last reply Reply Quote 0
      • JackDaniel
        JackDaniel @Thomas Braun last edited by
        @thomas-braun sehe da soweit kein problem
        Script v.2024-10-19
        *** BASE SYSTEM ***
         Static hostname: NUC
               Icon name: computer-desktop
                 Chassis: desktop 🖥️
                  Kernel: Linux 6.1.0-28-amd64
            Architecture: x86-64
         Hardware Vendor: Intel Corporation
          Hardware Model: NUC7i3DNB
        Firmware Version: DNKBLi30.86A.0066.2019.0710.1146
        OS is similar to:
        model name      : Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:33:07 up 24 min,  2 users,  load average: 1.23, 1.06, 0.85
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2024-12-08 18:33:07 CET
                   Universal time: Sun 2024-12-08 17:33:07 UTC
                         RTC time: Sun 2024-12-08 17:33:07
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        jackdaniel
        HOME=/home/jackdaniel
        GROUPS=jackdaniel root adm cdrom floppy sudo audio dip video plugdev netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth redis
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:             33G        6.4G         25G        1.2M        2.5G         27G
        Swap:           1.0G          0B        1.0G
        Total:           34G        6.4G         26G
        Active iob-Instances:   55
                31985 M total memory
                 6097 M used memory
                  604 M active memory
                 6969 M inactive memory
                23972 M free memory
                  155 M buffer memory
                 2191 M swap cache
                  975 M total swap
                    0 M used swap
                  975 M free swap
        top - 18:33:08 up 24 min,  2 users,  load average: 1.23, 1.06, 0.85
        Tasks: 198 total,   2 running, 196 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  31985.7 total,  23971.0 free,   6098.9 used,   2347.2 buff/cache
        MiB Swap:    976.0 total,    976.0 free,      0.0 used.  25886.8 avail Mem
        *** FAILED SERVICES ***
          UNIT            LOAD   ACTIVE SUB    DESCRIPTION
        * nfs-DM900.mount loaded failed failed /nfs/DM900
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs   16G     0   16G   0% /dev
        tmpfs          tmpfs     3.2G  952K  3.2G   1% /run
        /dev/sda2      ext4      456G   90G  343G  21% /
        tmpfs          tmpfs      16G  4.0K   16G   1% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
        tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1000
        [Sun Dec  8 18:08:18 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Dec  8 18:08:19 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET      SOURCE    FSTYPE OPTIONS
        /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
        `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        /var:
        64G     /var/
        62G     /var/lib
        60G     /var/lib/influxdb/engine/data/517ed77552af6c06/autogen
        Archived and active journals take up 1.6G in the file system.
        /opt/iobroker/backups:
        2.8G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        738M    /opt/iobroker/iobroker-data/files
        246M    /opt/iobroker/iobroker-data/backup-objects
        165M    /opt/iobroker/iobroker-data/files/vis-2
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        89M     /opt/iobroker/iobroker-data/states.jsonl
        45M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
        /dev/serial/by-id/usb-0658_0200-if00
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A908OSEN-if00-port0
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        Hosts:
        NUC                 NUC (version: 7.0.5, hostname: NUC           , alive, uptime: 1471)
        Core adapters versions
        js-controller:  7.0.5
        admin:          7.4.3
        javascript:     8.8.3
        nodejs modules from github:     4
        +-- iobroker.mystrom@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.mystrom.git#5c82d5d501ae7f423ca7332e3ac42c6b194e9a58)
        +-- iobroker.roborock@0.6.17 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#7b75cd86f365853945f275ef76f313a7ec43be7b)
        +-- iobroker.unifi@0.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.unifi.git#da2846e82409f74edb5eb28c891dd68a719ff994)
        `-- stream-rtsp@0.1.1 (git+ssh://git@github.com/vladmandic/stream-rtsp.git#f7d6e15bc3b4cd43b11f06b02bd4a9a0014c27c7)
        Adapter State
        + system.adapter.admin.0                  : admin                 : NUC                                      -  enabled, port: 8089, bind: 0.0.0.0, run as: jackdaniel
          system.adapter.alarm.0                  : alarm                 : NUC                                      - disabled
          system.adapter.alias-manager.0          : alias-manager         : NUC                                      - disabled
        + system.adapter.backitup.0               : backitup              : NUC                                      -  enabled
        + system.adapter.ble.0                    : ble                   : NUC                                      -  enabled
          system.adapter.bosch-ebike.0            : bosch-ebike           : NUC                                      - disabled
        + system.adapter.bring.0                  : bring                 : NUC                                      -  enabled
        + system.adapter.chromecast.0             : chromecast            : NUC                                      -  enabled
        + system.adapter.cloud.0                  : cloud                 : NUC                                      -  enabled
          system.adapter.device-watcher.0         : device-watcher        : NUC                                      - disabled
          system.adapter.devices.0                : devices               : NUC                                      - disabled
        + system.adapter.discovery.0              : discovery             : NUC                                      -  enabled
        + system.adapter.echarts.0                : echarts               : NUC                                      -  enabled
        + system.adapter.enocean.0                : enocean               : NUC                                      -  enabled
        + system.adapter.envertech-pv.0           : envertech-pv          : NUC                                      -  enabled
        + system.adapter.eventlist.0              : eventlist             : NUC                                      -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : NUC                                      -  enabled
          system.adapter.ham.0                    : ham                   : NUC                                      - disabled
        + system.adapter.harmony.0                : harmony               : NUC                                      -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : NUC                                      -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : NUC                                      -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : NUC                                      - disabled, port: 0
          system.adapter.hmip.0                   : hmip                  : NUC                                      - disabled
        + system.adapter.homekit-controller.0     : homekit-controller    : NUC                                      -  enabled
        + system.adapter.hue-extended.0           : hue-extended          : NUC                                      -  enabled
        + system.adapter.hue.0                    : hue                   : NUC                                      -  enabled, port: 443
          system.adapter.icons-icons8.0           : icons-icons8          : NUC                                      - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUC                                      - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUC                                      - disabled
        + system.adapter.influxdb.0               : influxdb              : NUC                                      -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : NUC                                      -  enabled
        + system.adapter.javascript.0             : javascript            : NUC                                      -  enabled
        + system.adapter.lg-thinq.0               : lg-thinq              : NUC                                      -  enabled
          system.adapter.meteoalarm.0             : meteoalarm            : NUC                                      -  enabled
        + system.adapter.mihome-cloud.0           : mihome-cloud          : NUC                                      -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : NUC                                      -  enabled, port: 1883, bind: 192.168.1.72
        + system.adapter.mystrom.0                : mystrom               : NUC                                      -  enabled
        + system.adapter.mytime.0                 : mytime                : NUC                                      -  enabled
        + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : NUC                                      -  enabled, port: 16021
        + system.adapter.netatmo.0                : netatmo               : NUC                                      -  enabled
        + system.adapter.notification-manager.0   : notification-manager  : NUC                                      -  enabled
        + system.adapter.notificationforandroidtv.0: notificationforandroidtv: NUC                                      -  enabled
        + system.adapter.nuki.0                   : nuki                  : NUC                                      -  enabled
        + system.adapter.nuki.1                   : nuki                  : NUC                                      -  enabled
          system.adapter.openweathermap.0         : openweathermap        : NUC                                      -  enabled
          system.adapter.pushover.0               : pushover              : NUC                                      - disabled
          system.adapter.radar2.0                 : radar2                : NUC                                      - disabled
          system.adapter.roborock.0               : roborock              : NUC                                      - disabled
        + system.adapter.sayit.0                  : sayit                 : NUC                                      -  enabled
        + system.adapter.sayit.1                  : sayit                 : NUC                                      -  enabled
        + system.adapter.sayit.2                  : sayit                 : NUC                                      -  enabled
          system.adapter.sayit.3                  : sayit                 : NUC                                      - disabled
        + system.adapter.sayit.4                  : sayit                 : NUC                                      -  enabled
        + system.adapter.shelly.0                 : shelly                : NUC                                      -  enabled, port: 1882, bind: 192.168.1.72
        + system.adapter.shelly.1                 : shelly                : NUC                                      -  enabled, port: 1882, bind: 192.168.1.72
        + system.adapter.simple-api.0             : simple-api            : NUC                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: jackdaniel
        + system.adapter.socketio.0               : socketio              : NUC                                      -  enabled, port: 8480, bind: 0.0.0.0, run as: admin
        + system.adapter.sony-bravia.0            : sony-bravia           : NUC                                      -  enabled
        + system.adapter.sony-bravia.1            : sony-bravia           : NUC                                      -  enabled
          system.adapter.sourceanalytix.0         : sourceanalytix        : NUC                                      - disabled
        + system.adapter.telegram.0               : telegram              : NUC                                      -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : NUC                                      -  enabled
        + system.adapter.unifi-protect.0          : unifi-protect         : NUC                                      -  enabled
        + system.adapter.unifi.0                  : unifi                 : NUC                                      -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : NUC                                      -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : NUC                                      -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: NUC                                      -  enabled
          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: NUC                                      -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: NUC                                      -  enabled
          system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: NUC
                  -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : NUC                                      -  enabled
          system.adapter.vis-bars.0               : vis-bars              : NUC                                      - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUC                                      - disabled
          system.adapter.vis-history.0            : vis-history           : NUC                                      - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUC                                      - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : NUC                                      - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : NUC                                      -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUC                                      - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : NUC                                      - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : NUC                                      - disabled
          system.adapter.vis-map.0                : vis-map               : NUC                                      - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : NUC                                      - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : NUC                                      - disabled
          system.adapter.vis-metro.0              : vis-metro             : NUC                                      - disabled
          system.adapter.vis-players.0            : vis-players           : NUC                                      - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : NUC                                      - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUC                                      - disabled
          system.adapter.vis.0                    : vis                   : NUC                                      -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : NUC                                      -  enabled
        + system.adapter.web.0                    : web                   : NUC                                      -  enabled, port: 8082, bind: 192.168.1.72, run as: admin
        + system.adapter.windows-control.0        : windows-control       : NUC                                      -  enabled
          system.adapter.withings.0               : withings              : NUC                                      - disabled
        + system.adapter.ws.0                     : ws                    : NUC                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : NUC                                      -  enabled, port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
        + system.adapter.zwave2.0                 : zwave2                : NUC                                      -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Active repo(s): Beta (latest)
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: Beta (latest)
        Adapter    "admin"        : 7.4.4    , installed 7.4.3  [Updatable]
        Adapter    "alarm"        : 3.6.4    , installed 3.6.4
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "ble"          : 0.14.0   , installed 0.14.0
        Adapter    "bosch-ebike"  : 0.1.9    , installed 0.1.9
        Adapter    "bring"        : 1.9.0    , installed 1.9.0
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "enocean"      : 0.9.3    , installed 0.9.3
        Adapter    "envertech-pv" : 1.4.0    , installed 1.4.0
        Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "harmony"      : 1.5.0    , installed 1.5.0
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hmip"         : 1.25.0   , installed 1.25.0
        Adapter    "homekit-controller": 0.5.11, installed 0.5.11
        Adapter    "hue"          : 3.13.1   , installed 3.13.1
        Adapter    "iot"          : 3.4.4    , installed 3.4.3  [Updatable]
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.5    , installed 7.0.5
        Adapter    "lg-thinq"     : 1.0.6    , installed 1.0.6
        Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
        Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "mystrom"      : 0.1.0    , installed 0.1.0
        Adapter    "mytime"       : 1.2.2    , installed 1.2.2
        Adapter    "nanoleaf-lightpanels": 1.5.0, installed 1.5.0
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "notification-manager": 1.3.0, installed 1.3.0
        Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "radar2"       : 2.2.0    , installed 2.2.0
        Adapter    "roborock"     : 0.6.17   , installed 0.6.17
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "unifi-protect": 1.0.1    , installed 1.0.1
        Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
        Adapter    "vis-2-widgets-gauges": 1.1.1, installed 1.1.1
        Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
        Adapter    "vis-2-widgets-jaeger-design": 1.3.9, installed 1.3.9
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "vis-2-widgets-weather-and-heating": 0.8.0, installed 0.8.0
        Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
        Adapter    "vw-connect"   : 0.6.1    , installed 0.6.1
        Adapter    "web"          : 6.3.1    , installed 6.3.1
        Adapter    "windows-control": 0.1.5  , installed 0.1.5
        Adapter    "withings"     : 0.0.15   , installed 0.0.15
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
        Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
        Objects and States
        Objects:        29407
        States:         39647
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://downloads.plex.tv/repo/deb public InRelease
        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:7 https://repo.homebridge.io stable InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:36397         0.0.0.0:*               LISTEN      997        25850      937/Plex Plug-in [c
        tcp        0      0 192.168.1.72:9093       0.0.0.0:*               LISTEN      1001       23533      1334/io.nuki.1
        tcp        0      0 192.168.1.72:9092       0.0.0.0:*               LISTEN      1001       28954      1664/io.nuki.0
        tcp        0      0 0.0.0.0:47619           0.0.0.0:*               LISTEN      0          22035      579/rpc.mountd
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        22881      575/redis-server 12
        tcp        0      0 127.0.0.1:6380          0.0.0.0:*               LISTEN      110        24122      576/redis-server 12
        tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          22206      -
        tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      111        24182      707/mariadbd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22249      615/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14992      1/init
        tcp        0      0 0.0.0.0:33231           0.0.0.0:*               LISTEN      0          22047      579/rpc.mountd
        tcp        0      0 127.0.0.1:41831         0.0.0.0:*               LISTEN      997        24304      784/Plex Plug-in [c
        tcp        0      0 192.168.1.72:8082       0.0.0.0:*               LISTEN      1001       30797      1915/io.web.0
        tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      997        24188      588/Plex Media Serv
        tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      997        24322      900/Plex Tuner Serv
        tcp        0      0 0.0.0.0:39683           0.0.0.0:*               LISTEN      0          22059      579/rpc.mountd
        tcp        0      0 0.0.0.0:40335           0.0.0.0:*               LISTEN      0          22224      -
        tcp        0      0 192.168.1.72:2010       0.0.0.0:*               LISTEN      1001       27222      1630/io.hm-rpc.0
        tcp        0      0 192.168.1.72:1883       0.0.0.0:*               LISTEN      1001       28800      1559/io.mqtt.0
        tcp        0      0 192.168.1.72:1882       0.0.0.0:*               LISTEN      1001       28673      1437/io.shelly.1
        tcp        0      0 0.0.0.0:37581           0.0.0.0:*               LISTEN      107        19675      580/rpc.statd
        tcp6       0      0 :::44743                :::*                    LISTEN      107        19681      580/rpc.statd
        tcp6       0      0 :::8581                 :::*                    LISTEN      112        24339      844/hb-service
        tcp6       0      0 :::8480                 :::*                    LISTEN      1001       28545      2016/io.socketio.0
        tcp6       0      0 :::32400                :::*                    LISTEN      997        24186      588/Plex Media Serv
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       23400      1247/io.harmony.0
        tcp6       0      0 :::2049                 :::*                    LISTEN      0          22218      -
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       30009      1896/io.fullybrowse
        tcp6       0      0 :::51998                :::*                    LISTEN      112        24373      953/homebridge
        tcp6       0      0 :::3306                 :::*                    LISTEN      111        24183      707/mariadbd
        tcp6       0      0 :::36035                :::*                    LISTEN      0          22671      579/rpc.mountd
        tcp6       0      0 ::1:6380                :::*                    LISTEN      110        24123      576/redis-server 12
        tcp6       0      0 ::1:6379                :::*                    LISTEN      110        22882      575/redis-server 12
        tcp6       0      0 :::53                   :::*                    LISTEN      0          22986      582/AdGuardHome
        tcp6       0      0 :::22                   :::*                    LISTEN      0          22260      615/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          14994      1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      0          22332      582/AdGuardHome
        tcp6       0      0 :::56467                :::*                    LISTEN      0          22041      579/rpc.mountd
        tcp6       0      0 :::40239                :::*                    LISTEN      0          22227      -
        tcp6       0      0 :::8089                 :::*                    LISTEN      1001       25332      1034/io.admin.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       31821      2145/io.ws.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      998        25736      596/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       28645      2071/io.simple-api.
        tcp6       0      0 :::37237                :::*                    LISTEN      0          22053      579/rpc.mountd
        udp        0      0 0.0.0.0:32410           0.0.0.0:*                           997        25195      588/Plex Media Serv
        udp        0      0 0.0.0.0:32412           0.0.0.0:*                           997        25196      588/Plex Media Serv
        udp        0      0 0.0.0.0:32413           0.0.0.0:*                           997        25269      588/Plex Media Serv
        udp        0      0 0.0.0.0:32414           0.0.0.0:*                           997        25194      588/Plex Media Serv
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          22235      534/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14993      1/init
        udp        0      0 127.0.0.1:756           0.0.0.0:*                           0          19667      580/rpc.statd
        udp        0      0 127.0.0.1:50950         0.0.0.0:*                           997        25270      588/Plex Media Serv
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       31927      2195/io.nanoleaf-li
        udp        0      0 0.0.0.0:1901            0.0.0.0:*                           997        25274      588/Plex Media Serv
        udp        0      0 0.0.0.0:51324           0.0.0.0:*                           107        19672      580/rpc.statd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       28532      2000/io.homekit-con
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       27721      1392/io.chromecast.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        24374      953/homebridge
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        24336      844/hb-service
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       26152      1363/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       27255      1649/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       27256      1649/io.tuya.0
        udp        0      0 0.0.0.0:40226           0.0.0.0:*                           0          22032      579/rpc.mountd
        udp        0      0 127.0.0.1:40549         0.0.0.0:*                           997        25272      588/Plex Media Serv
        udp        0      0 192.168.1.72:57542      0.0.0.0:*                           997        25273      588/Plex Media Serv
        udp        0      0 0.0.0.0:57650           0.0.0.0:*                           0          22223      -
        udp        0      0 0.0.0.0:58477           0.0.0.0:*                           0          22044      579/rpc.mountd
        udp        0      0 192.168.1.72:42660      0.0.0.0:*                           997        25271      588/Plex Media Serv
        udp        0      0 0.0.0.0:42878           0.0.0.0:*                           0          22056      579/rpc.mountd
        udp        0      0 192.168.1.72:43811      0.0.0.0:*                           997        25275      588/Plex Media Serv
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       26075      1247/io.harmony.0
        udp6       0      0 :::53                   :::*                                0          22985      582/AdGuardHome
        udp6       0      0 :::111                  :::*                                0          14995      1/init
        udp6       0      0 :::38160                :::*                                0          22050      579/rpc.mountd
        udp6       0      0 :::56090                :::*                                107        19678      580/rpc.statd
        udp6       0      0 :::42571                :::*                                0          22062      579/rpc.mountd
        udp6       0      0 :::59844                :::*                                0          22038      579/rpc.mountd
        udp6       0      0 :::44507                :::*                                0          22225      -
        2024-12-08 18:32:56.397  - debug: envertech-pv.0 (1137) initStateobject (ST-BD69538AB5FC4A86B419C0C7162F571E.GW-94000936.CVT-20139780.SNID)
        2024-12-08 18:32:56.397  - debug: envertech-pv.0 (1137) initobject [ST-BD69538AB5FC4A86B419C0C7162F571E.GW-94000936.CVT-20139780.SNID]
        2024-12-08 18:32:56.402  - debug: envertech-pv.0 (1137) updateInfoConnected triggered
        2024-12-08 18:32:56.402  - debug: envertech-pv.0 (1137) info.connection set to true
        2024-12-08 18:33:05.585  - debug: nanoleaf-lightpanels.0 (2195) Polling timer started with 10000 ms
        2024-12-08 18:33:05.586  - debug: nanoleaf-lightpanels.0 (2195) Updating changed states...
        2024-12-08 18:33:15.597  - debug: nanoleaf-lightpanels.0 (2195) Polling timer started with 10000 ms
        2024-12-08 18:33:15.598  - debug: nanoleaf-lightpanels.0 (2195) Updating changed states...
        2024-12-08 18:33:25.605  - debug: nanoleaf-lightpanels.0 (2195) Polling timer started with 10000 ms
        2024-12-08 18:33:25.605  - debug: nanoleaf-lightpanels.0 (2195) Updating changed states...
        2024-12-08 18:33:32.150  - info: notification-manager.0 (1154) Send notification "admin.adapterUpdates" to "telegram.0"
        2024-12-08 18:33:32.154  - info: telegram.0 (1112) New notification received from system.adapter.notification-manager.0
        2024-12-08 18:33:32.436  - info: notification-manager.0 (1154) Instance telegram.0 successfully handled the notification for "admin.adapterUpdates"
        2024-12-08 18:33:33.035  - info: chromecast.0 (1392) Wohnzimmer - not enabled
        2024-12-08 18:33:33.049  - info: chromecast.0 (1392) Soundbar_Wohnzimmer - not enabled
        2024-12-08 18:33:33.204  - info: chromecast.0 (1392) Wohnzimmer - not enabled
        2024-12-08 18:33:33.232  - info: chromecast.0 (1392) Wohnzimmer - not enabled
        2024-12-08 18:33:33.367  - info: chromecast.0 (1392) Soundbar_Wohnzimmer - not enabled
        2024-12-08 18:33:33.376  - info: chromecast.0 (1392) Soundbar_Wohnzimmer - not enabled
        2024-12-08 18:33:35.611  - debug: nanoleaf-lightpanels.0 (2195) Polling timer started with 10000 ms
        2024-12-08 18:33:35.611  - debug: nanoleaf-lightpanels.0 (2195) Updating changed states...
        • BananaJoe
          BananaJoe Most Active last edited by
          Ich habe heute auch 7.0.5 installiert ... das hatte auch geklappt ... aber es wird mir jetzt wieder angeboten, Installation klappt aber nicht:
          2024-12-08 19:59:59.166  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
          2024-12-08 19:59:59.169  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:60082
          2024-12-08 20:00:01.224  - error: host.iobroker [CONTROLLER_AUTO_UPGRADE] Could not install js-controller@7.0.5
          2024-12-08 20:00:01.775  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Final information delivered
          2024-12-08 20:00:01.790  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
          Auf gefallen war mir das war andere Adapter sich auch nicht Upgraden lassen. Das geht zwar, danach ist es aber wieder die alte Version (z.B. Admin auf 7.4.4, nach Upgrade ist es immer noch 7.4.3)
          Feuersturm 1 Reply Last reply Reply Quote 1
          • Feuersturm
            Feuersturm @BananaJoe last edited by
            @bananajoe Ich hab gerade das gleiche Problem, siehe https://forum.iobroker.net/topic/77294/js-controller-lucy-version-7-0-jetzt-im-beta-repository/115
            Hab es im Beta Thread vom js-controller gepostet, da dies hier der stable Thread ist.
            • BananaJoe
              BananaJoe Most Active @Feuersturm last edited by
              @feuersturm ah, verdammt, danke, ich wechsle rüber
              • Dr. Bakterius
                Dr. Bakterius Most Active last edited by Dr. Bakterius
                Ich stehe auf dem Schlauch. Was will mir die '1' hier sagen?
                Edit: hat sich erledigt. Ich hätte nur früher drauf klicken müssen. 🙄
                  Thomas Braun Most Active @Dr. Bakterius last edited by
                  @dr-bakterius sagte in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
                  Klick mich!
                    drapo last edited by
                    Habe gerade gesehen, dass ich den js-controller updaten kann. Ich wollte diesen von 7.0.3 auf die 7.0.6 updaten. Wenn ich das im Admin unter dem Reiter Hosts machen möchte kommt dann gleich diese Meldung
                    Was kann ich dagegen tun?
                    Siggi0904 Meister Mopper 2 Replies Last reply Reply Quote 0
                    • Siggi0904
                      Siggi0904 @drapo last edited by
                      @drapo machs mal über die Console. Das ist besser.
                      https://forum.iobroker.net/topic/78324/js-controller-lucy-version-7-0-jetzt-im-stable-repository
                      • Meister Mopper
                        Meister Mopper @drapo last edited by
                        @drapo
                        Diese Meldung erhalte ich auch. Einfach abwarten, das Update läuft trotzdem durch.
                        Später einen Browserrefresh und alles ist gut.
                          drapo @Meister Mopper last edited by
                          @meister-mopper war leider bei mir nicht so. Ich hab das ganze auch im Docker Container am Laufen vielleicht liegt es daran. Ich habs nun über die Console installiert und funktioniert nun. Danke für Eure Antworten...
                          • mcm1957
                            mcm1957 @drapo last edited by mcm1957
                            @drapo
                            ev https://github.com/ioBroker/ioBroker.js-controller/issues/2988
                            Weiters:
                            https://github.com/ioBroker/ioBroker.js-controller/issues/2964 (gefixed)
                            Zitat:
                            Ja das ist klar du kannst erst ab 7.0.5 wieder mit Docker ein UI Upgrade machen
                            FlySmack created this issue in ioBroker/ioBroker.js-controller
                            closed [bug]: Docker js-contoller update from 7.0.2 to 7.0.x fails - SyntaxError: JSON Parse error: Unrecognized token '<' #2988
                            schnitzel14 created this issue in ioBroker/ioBroker.js-controller
                            closed [bug]: Docker UI Upgrade 7.0.2 -> 7.0.3 fails #2964
                              pingo last edited by pingo
                              Normalerweise klappt es super, wenn ich den Update Kreiselpfeil anklicke. Diesmal leider nicht. Leider bin ich in der Materie nicht so tief drin, dass ich die Fehlermeldung verstehe bzw. weiß, was ich nun tun sollte.
                              Der Container läuft einem Synology Server. Dort habe ich vorher das fällige Update erfolgreich gemacht.
                                Thomas Braun Most Active @pingo last edited by
                                @pingo
                                Mach es 'zu Fuß'.
                                Zum einen kommen da andere/bessere Meldungen und zum anderen bekommst du etwas Handwerkszeug an die Hand.
                                Ro75 P 2 Replies Last reply Reply Quote 1
                                  Homoran Global Moderator Administrators @pingo last edited by
                                  @pingo passt das?
                                  https://forum.iobroker.net/post/1232189
                                  • Ro75
                                    Ro75 @Thomas Braun last edited by
                                    @thomas-braun also die Meldung bekomme ich bei jedem Update. Allerdings ist am Ende immer alles OK und das Update vollzogen.
                                    Ro75.
                                      Thomas Braun Most Active @Ro75 last edited by
                                      @ro75
                                      Dann muss es an der GUI liegen (natürlich, woran auch sonst...), im Terminal sehe ich diese Meldungen nämlich nie.
                                        pingo @Thomas Braun last edited by
                                        @thomas-braun ich hatte das früher schon mal über die Konsole gemacht. Diesmal passt das nicht, was ich mir notiert hatte:
                                        admin@Diskstation920:~$ sudo su -
                                        Password:
                                        root@Diskstation920:~# docker exec -it buanet-iobroker1  /bin/bash
                                        root@buanet-iobroker1:/opt/iobroker# maintenance upgrade -y
                                        WARNING! This script should be executed as user iobroker! Please switch user and try again.
                                        Hast Du vielleicht einen Tipp, wie ich das Update als user iobroker ausführe?
                                          @pingo
                                          Von Containern hab ich keine Ahnung.
                                          P mcm1957 2 Replies Last reply Reply Quote 0
                                            ok. Ich habs stattdessen mal im Container Terminal versucht:
                                            das sieht gut aus, bis am Ende dann andauernd diese Fehlermeldung kommt:
                                            TCP 192.168.178.178:9999 Error: connect EHOSTUNREACH 192.168.178.178:9999
                                                at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1611:16) {
                                              errno: -113,
                                              code: 'EHOSTUNREACH',
                                              syscall: 'connect',
                                              address: '192.168.178.178',
                                              port: 9999
                                            81.1k
                                            backup dynamic notifications js-controller lucy stable test
                                            35
                                            116
                                            23166
