    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. [Nut Adapter] Adapterkonfiguration
    • N
      norbert999 @norbert999 last edited by
      @norbert999 Sorry, habs jetzt geschafft!
      2024-12-27 12:31:14.849 - info: host.raspi5 "system.adapter.nut.0" enabled
      2024-12-27 12:31:15.339 - info: host.raspi5 instance system.adapter.nut.0 in version "1.6.0" started with pid 6418
      2024-12-27 12:31:15.854 - debug: nut.0 (6418) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-12-27 12:31:15.869 - debug: nut.0 (6418) Objects client ready ... initialize now
      2024-12-27 12:31:15.870 - debug: nut.0 (6418) Objects create System PubSub Client
      2024-12-27 12:31:15.871 - debug: nut.0 (6418) Objects create User PubSub Client
      2024-12-27 12:31:15.890 - debug: nut.0 (6418) Objects client initialize lua scripts
      2024-12-27 12:31:15.893 - debug: nut.0 (6418) Objects connected to redis: 127.0.0.1:9001
      2024-12-27 12:31:15.906 - debug: nut.0 (6418) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-12-27 12:31:15.912 - debug: nut.0 (6418) States create System PubSub Client
      2024-12-27 12:31:15.913 - debug: nut.0 (6418) States create User PubSub Client
      2024-12-27 12:31:15.964 - debug: nut.0 (6418) States connected to redis: 127.0.0.1:9000
      2024-12-27 12:31:15.980 - debug: nut.0 (6418) Plugin sentry Do not initialize Plugin (enabled=false)
      2024-12-27 12:31:16.070 - info: nut.0 (6418) starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.nut, node: v20.18.1, js-controller: 7.0.6
      2024-12-27 12:31:16.078 - debug: nut.0 (6418) Create Channel status
      2024-12-27 12:31:16.090 - debug: nut.0 (6418) connected set to false
      2024-12-27 12:31:16.132 - debug: nut.0 (6418) Create State status.online
      2024-12-27 12:31:16.140 - debug: nut.0 (6418) Set State status.online = false
      2024-12-27 12:31:16.143 - debug: nut.0 (6418) Create State status.onbattery
      2024-12-27 12:31:16.144 - debug: nut.0 (6418) Set State status.onbattery = false
      2024-12-27 12:31:16.146 - debug: nut.0 (6418) Create State status.lowbattery
      2024-12-27 12:31:16.147 - debug: nut.0 (6418) Set State status.lowbattery = false
      2024-12-27 12:31:16.149 - debug: nut.0 (6418) Create State status.highbattery
      2024-12-27 12:31:16.150 - debug: nut.0 (6418) Set State status.highbattery = false
      2024-12-27 12:31:16.152 - debug: nut.0 (6418) Create State status.replacebattery
      2024-12-27 12:31:16.152 - debug: nut.0 (6418) Set State status.replacebattery = false
      2024-12-27 12:31:16.157 - debug: nut.0 (6418) Create State status.charging
      2024-12-27 12:31:16.158 - debug: nut.0 (6418) Set State status.charging = false
      2024-12-27 12:31:16.160 - debug: nut.0 (6418) Create State status.discharging
      2024-12-27 12:31:16.161 - debug: nut.0 (6418) Set State status.discharging = false
      2024-12-27 12:31:16.163 - debug: nut.0 (6418) Create State status.bypass
      2024-12-27 12:31:16.164 - debug: nut.0 (6418) Set State status.bypass = false
      2024-12-27 12:31:16.166 - debug: nut.0 (6418) Create State status.calibration
      2024-12-27 12:31:16.167 - debug: nut.0 (6418) Set State status.calibration = false
      2024-12-27 12:31:16.168 - debug: nut.0 (6418) Create State status.offline
      2024-12-27 12:31:16.169 - debug: nut.0 (6418) Set State status.offline = false
      2024-12-27 12:31:16.171 - debug: nut.0 (6418) Create State status.overload
      2024-12-27 12:31:16.172 - debug: nut.0 (6418) Set State status.overload = false
      2024-12-27 12:31:16.173 - debug: nut.0 (6418) Create State status.trimming
      2024-12-27 12:31:16.174 - debug: nut.0 (6418) Set State status.trimming = false
      2024-12-27 12:31:16.176 - debug: nut.0 (6418) Create State status.boosting
      2024-12-27 12:31:16.177 - debug: nut.0 (6418) Set State status.boosting = false
      2024-12-27 12:31:16.178 - debug: nut.0 (6418) Create State status.shutdown
      2024-12-27 12:31:16.179 - debug: nut.0 (6418) Set State status.shutdown = false
      2024-12-27 12:31:16.181 - debug: nut.0 (6418) Set State status.severity = 4
      2024-12-27 12:31:16.185 - debug: nut.0 (6418) NUT Connection ready
      2024-12-27 12:31:16.186 - debug: nut.0 (6418) NUT Connection closed. Done.
      2024-12-27 12:31:16.188 - debug: nut.0 (6418) connected set to true```
      Was läuft den schief?
        Homoran Global Moderator Administrators @norbert999 last edited by
        @norbert999 sagte in [Nut Adapter] Adapterkonfiguration:
        Wie kriege ich denn den ausführlichen debug-log hin?
        hab ich dir verlinkt und nochmal beschrieben.
        Wo hakt es denn?
          Homoran Global Moderator Administrators @norbert999 last edited by Homoran
          läuft der Nut-Server, bzw hat er Verbindung zu USV?
          • N
            norbert999 @Homoran last edited by
            @homoran Welches Kommando brauche ich denn, um nach dem ssh-login auf das NAS nachzuschauen, ob der NUT server läuft?
            • N
              "Netzwerk USV-Master" auf dem NAS ist aktiviert und der raspi (192.168.1.6) ist unter den Netzwerkgeräten, die benachricht werden sollen, eingetragen.
              Mehr kann ich auf der NAS-Seite über die Oberfläche nicht machen.
                Wie gesagt kenne ich QNAP nicht, aber das ist meiner Meinung nach nur eine Meldung bei Ausfall.
                Das sind nicht die Clients, die auf den Server zugreifen dürfen.
                und wofür sind die Checkboxen vor den IPs?
                ist das nur dann aktiv wenn angehakt?
                • N
                  @homoran said in [Nut Adapter] Adapterkonfiguration:
                  Da hast Du wahrscheinlich Recht. Ich müßte schauen, wie ich überprüfen kann, ob wirklich ein NUT-server auf QNAP läuft. Muss googeln, weiss nämlich nicht wie das geht. ssh Zugang zum QNAP habe ich.
                  Die sind nur dafür da, dass wenn ich einen Eintrag entfernen möchte. Dazu muss ich vorher die checkbox beim entsprechenden Eintrag anklicken und kann dann "Entfernen" anklicken. Sonst keine Funktion.
                  Laut QNAP werden dies dort eingetragenen IP´s bei z.B. Stromausfall "informiert".
                  Habe erst mal keine Idee mehr. Ich lese natürlich alles was ich finden kann. Aber die Konfiguration "USV per USB an QNAP und raspi mit iob gibt es nicht so oft. Daher passen die meisten Anleitungen nicht.
                  Die für mich wichtige Frage jetzt ist, muss ich noch einen NUT-client auf raspi installieren, oder nicht. Meister Mopper hat ja gesagt, ich muss den installieren. Ich bin mir da aber unsicher, weil ich auf der github-Seite des NUT-Adapters dazu keine Aussage gefunden habe. Deshalb hatte ich Meister Mopper in meinem letzten Post gefragt, ob ich wirklich installieren muss, oder nicht. Leider hat er noch nicht geantwortet.
                  Was denkst Du, wie ich weitermachen soll?
                    eher nicht!
                    @homoran sagte in [Nut Adapter] Adapterkonfiguration:
                    @meister-mopper sagte in [Nut Adapter] Adapterkonfiguration:
                    Du hast den client nicht installiert.
                    jetzt bin ich irritiert!
                    braucht es den wirklich?
                    Ich werde sofort nochmal den alten Thread durchlesen. Ist bei mir einige Jährchen her.
                    Bei meiner APC USV an der Synology kann ich mich nicht erinnern einen client installiert zu haben.
                    Der Adapter verbindet dich doch mit dem nut-Server
                    EDIT:
                    Aus dem erwähnten Thread
                    Für ioBroker gibt es den nut Adapter von @Apollon77, Github und ioBrokerForum . Dieser Adapter stellt einen NUT-Cient bereit
                    • N
                      eher nicht!
                      Ich habe noch keinen "extra"-NUT-client auf raspi installiert. Hatte auf meister mopper seine Antwort geantwortet. Persönlich glaube ich, dass es keinen "extra"-NUT-client auf dem raspi braucht. Bin aber natürlich kein Experte und lasse mich gern belehren.
                      Die Adaperbeschreibung von @Apollon77, Github habe ich mir natürlich durchgelesen und entsprechend konfiguriert. Aber irgendwie ist der Wurm noch drin.
                      Bin erstmal ratlos und hoffe auf Tips, werde aber natürlich nochmal alle sourcen im Netz durchgehen, um zu schauen, ob ich nicht doch was falsch gemacht habe.
                      Auch vielen Dank für Deine ständige und gute Hilfe. Sagst Du mir bitte, was das schon wieder neues ist mit dem Auswahlfeld in Deinem reply-post? Weiss nicht, wie das funktioniert. Habe meine Auswahl im letzten post von Dir gemacht, aber das ist ja schon Vergangenheit. Das siehst Du doch gar nicht mehr
                        ich doch auch!
                        Warum brauchst du dann noch seine Antwort?
                        wo ist ein Auswahlfeld?
                        Wer sagt das?
                        Wichtig ist erstmal jemanden zu haben, der den NUT Server auf QNAP betreibt.
                        Alles andere müsste passen.
                        N 1 Reply Last reply Reply Quote 1
                        • N
                          ich doch auch!
                          Weil ich nicht so ein Experte bin, wie Ihr es seid. Bei mir "Halbwissendem" schwingt natürlich immer ein Stück "Unsicherheit" mit. Daher wäre es natürlich hilfreich, wenn es ein klares stement gäbe, ob ich den zusätzlichen NUT-client brauche. Ich denke nach wie vor, NEIN, den brauche ich nicht.
                          Schau mal hier:
                          Wer sagt das?
                          Da werde ich mich jetzt auf die Suche machen. Macht es Sinn, nochmal in einem anderen Unterforum zu posten, weil Du und meister hopper die einzigen waren, die geantwortet haben.
                          Homoran Meister Mopper 2 Replies Last reply Reply Quote 0
                            das steht in dem "Auswahlfeld"!
                            Das ist aber kein Auswahlfeld. Die Forensoftware klappt die zusätzlichen Ebenen ein.
                            Wenn du nicht zu dem referenzierten Post zurückgehen willst, musst du dies aufklappen.
                            auf keinen Fall!
                            steht auch in den bereits verlinkten Thread
                            Vielleicht ist Weihnachten!?
                            und die benötigten User sind bei ihren Familien statt im Forum unterwegs
                            Warum so nervös?
                            Der Thread ist doch gerade 24h alt!
                            • Meister Mopper
                              Meister Mopper @norbert999 last edited by
                              @norbert999
                              Wie ich es verstehe:
                              So wie du QNAP konfiguriert hast, darf der nut-Adapter von ioBroker auf den nut server des QNAP zugreifen. Damit fährt der Raspi aber noch nicht sauber runter, wenn mal der Strom weg ist.
                              Das musst du dann im ioBroker per Skript programmieren.
                              Wenn du möchtest, dass dieses Runterfahren automatisch erfolgt, muss auf dem Raspi ein nut client laufen.
                              Bei Stromausfall fährt der Server alle Clients bei einem definierten Batterietiefstand automatisch herunter.
                              Es bedeutet, dass der nut-Adapter das USV-Geschehen per se lediglich beobachtet und kein automatisches Herunterfahren des Raspi bewirkt.
                              Alle Maschinen, deren IP du im QNAP Nut Server freigibst, müssen einen Nut Client installiert haben, wenn du möchtest, dass der Server sie automatisch herunterfährt.
                              Ich hoffe, dass das jetzt deutlich geworden ist.
                                Homoran Global Moderator Administrators @Meister Mopper last edited by
                                Danke, aber ich glaube darum ging es bisher noch nicht.
                                aber es kommen keine Werte an.
                                Da hängt es noch.
                                1.3k
                                3794
