    4. Adapter Klipper-Moonraker
      stenmic @Merlin123 last edited by stenmic
      @merlin123
      so mach ich es
      (ip vom Drucker anpassen)
      <block xmlns="https://developers.google.com/blockly/xml" type="on" id="/Z2O}ZB#,a]kn33Dz4F$" x="116" y="2253">
       <field name="OID">mqtt.0.Mainsail.klipper.state.print_stats.filename</field>
         <block type="variables_set" id="y[Oc#E_92,_2BKo4(5~[">
           <field name="VAR" id="BXYL{xhaLkN~v2Ldl!%!">text</field>
             <block type="get_attr" id="XXR]WqWt.=HMLUr3gR}@">
               <value name="PATH">
                 <shadow type="text" id="rrx*$IEHd@w{;*~Z+8`n">
                   <field name="TEXT">value</field>
               <value name="OBJECT">
                 <shadow type="get_object" id="^cMzi*_aj{`Pl0P725m~">
                 <block type="on_source" id="pgo{+7GzQz;]qj)e34}A">
             <block type="update" id="bIOV@RC*Q+u,j_l+cDZ,">
               <field name="OID">0_userdata.0.Klipper.API.Printjob.Name</field>
                 <block type="text_getSubstring" id=";P~^,bl^VhcaeFBrn4B7">
                   <mutation at1="false" at2="true"></mutation>
                   <field name="WHERE1">FIRST</field>
                   <field name="WHERE2">FROM_START</field>
                   <value name="STRING">
                     <block type="variables_get" id=".)~:q(Mh|eeSdPJRu*2!">
                   <value name="AT2">
                     <block type="math_arithmetic" id="~]oa3qPRWU)spG%YB1]]">
                         <shadow type="math_number" id="PqrA)w7#cW-.+R7[s$Ut">
                           <field name="NUM">1</field>
                         <block type="text_indexOf" id="r51`DlwiN)v*}8k4q}5p">
                           <field name="END">FIRST</field>
                             <block type="variables_get" id="sqPwTzw6?t1]F1dwmj|P">
                           <value name="FIND">
                             <shadow type="text" id="NN88q$[rF?qy3R1S,=Fk">
                               <field name="TEXT">.gcode</field>
                         <shadow type="math_number" id="Gp.#K1A?Y{{b4u]f,mK_">
                 <block type="update" id="v~`h#IPc]?2X#3=M{X[a">
                   <field name="OID">0_userdata.0.Klipper.API.Printjob.Thumbnail</field>
                     <block type="text_join" id="=uC)c{XD(`=yL3+qnM$/">
                       <value name="ADD0">
                         <block type="text" id="+hu6Z]DDV49vxZEG3^KI">
                           <field name="TEXT">http://192.168.178.113/server/files/gcodes/.thumbs/</field>
                       <value name="ADD1">
                         <block type="text_getSubstring" id=".jX}L{b`]tqX[lP+wIR2">
                             <block type="variables_get" id="ZUXf!~C]B[?oTqjrU3mF">
                           <value name="AT2">
                             <block type="math_arithmetic" id="rArUrH5JD`!U0PI6`=Lt">
                                 <block type="text_indexOf" id="Gji4dA%oP(rS[%9W%X(m">
                                     <block type="variables_get" id="i=BXKzmS]z$x=!47DA!B">
                                   <value name="FIND">
                                     <shadow type="text" id="nTgAoKx?A/?1e#g9JTXQ">
                                 <shadow type="math_number" id="u3_-Ii7/U+4%YQw8Az@I">
                       <value name="ADD2">
                         <block type="text" id="sn3+k)T(}R(KvqNhQ6;v">
                           <field name="TEXT">.png</field>
      Merlin123 D 2 Replies Last reply Reply Quote 0
      • Merlin123
        Merlin123 @stenmic last edited by
        @stenmic Erstmal danke für das Script 🙂
        Die URL baut er richtig zusammen, aber unter der Adresse liefert mein Drucker kein Bild:
        http://192.168.0.252/server/files/gcodes/.thumbs/Plate%201%20-%20Charcoal%20Black_0.15mm_PLA_Generic%20Klipper%20Printer_6h52m.png
        Bei mir liegt das Thumbnail unter
        /usr/data/printer_data/gcodes/.thumbs/Plate 1 - Charcoal Black_0.15mm_PLA_Generic Klipper Printer_6h52m-100x100.png
        Weißt Du, was ich machen muss, damit der Drucker das via HTML ausliefert?
        K S 2 Replies Last reply Reply Quote 0
          Kammi_ @Merlin123 last edited by Kammi_
          @merlin123
          öffne deinen drucker im browser bei mir wäre das http://192.168.0.84 rechts klick auf das tumbnail -> Grafik im neuen tab öffnen und du hast deine Adresse wo du brauchst
          http://192.168.0.84/server/files/gcodes/.cache/.thumbs/Calibration%20Cube_PETG_22m3s-272x272.png?date=1735204837
          wäre es bei mir also genau das gleiche du musst nur deine ip austauschen
            @merlin123 mach mal bitte zum test einen Druck mit einem einfachen Dateinamen und ohne Lehrzeichen.
            • Merlin123
              Merlin123 @Kammi_ last edited by
              @kammi_ Wenn das so einfach wäre 😉
              Wenn ich in Mailsail oder Fluidd nen Rechtsklick auf das Thumb mache kann ich das Bild nicht anzeigen. Der Seitenquelltext sagt nur "ohne Javescript geht da nix....."
              • Merlin123
                Merlin123 @stenmic last edited by Merlin123
                @stenmic sagte in Adapter Klipper-Moonraker:
                Hab jetzt einen der Thumbs als test.png kopiert.
                Unter
                http://192.168.0.252/server/files/gcodes/.thumbs/test.png
                kommte trotzdem ein
                Die Website ist nicht erreichbar
                192.168.0.252 hat die Verbindung abgelehnt.
                Versuche Folgendes:
                Verbindung prüfen
                Proxy und Firewall prüfen
                ERR_CONNECTION_REFUSED
                  @merlin123 kommt das bild im browser wenn du den Pfad dort eingibst?
                  • Merlin123
                    @stenmic @Kammi_
                    Ursache gefunden....
                    Muss den Port mit angeben:
                    http://192.168.0.252:4409/server/files/gcodes/.thumbs/test.png
                    Jetzt nur noch das Anzeigen hinbekommen....
                      @merlin123 bei mir geht es über das Image Widget
                      Merlin123 2 Replies Last reply Reply Quote 0
                      • Merlin123
                        @stenmic War mein erster Versuch... Aber.....
                        Rufe ich die URL
                        mit dem Browser auf kommt ein Download
                        Das gleiche, wenn ich den DP auf diese URL setzt und den als Quelle für nen iFrame nutze....
                        • Merlin123
                          @stenmic Darüber ging ein erster Test, danke für den Hinweis! Aber die Auflösung scheint sehr gering zu sein (zumindest bei dem Testbild). Das war ein Temp-Tower, der in Mailsail eigentlich gut aussieht.
                            @merlin123 nuzt du cura?
                            bei mir haben die pngs eine Top Auflösung
                            • Merlin123
                              @stenmic Problem gefunden 😄
                              Ich hatte ein x-beliebiges File kopiert...
                              Bei mir werden immer 3 Thumbs erzeugt: 32x32, 100x100 und 320x320.
                              Ich hab ein 32x32 kopiert 😉
                              UND:
                              Ich muss an den Filenamen ein
                              -320x320
                              anhängen.
                              Damit geht es dann.
                              Also vielen Dank nochmal 🙂
                              • V
                                Vetinari77 @1Topf last edited by
                                @1topf
                                Wenn du den Drucker per Steckdose ein und ausschaltest, dann kannst du auch einfach die Instanz per script ein und ausschalten. Dann meckert das script auch nicht, das es keine Verbindung hat....
                                • Diginix
                                  Diginix @1Topf last edited by Diginix
                                  @1topf sagte in Adapter Klipper-Moonraker:
                                  Was momentan wirklich stört ist, daß der Adapter den Fehlerspeicher von ioB füllt, sobald die Verbindung zum Drucker weg ist. Und auch, daß der Adapter mit jedem neuen Druck einen Neustart benötigt.
                                  Sonst hab ich nix zu meckern. 😀
                                  Das mit dem Log kann ich bestätigen. Ich starte die Instanz sobald die Drucker IP pingbar ist bzw. der Drucker die MQTT Verbindung hergestellt hat (mqtt habe ich in Klipper ebenfalls aktiviert). Und sobald klipper-moonraker.0.info.connection false ist, wird die Instanz gestoppt. So bekomme ich im Log keinerlei Fehler. Wenn er einmal läuft und ich mache mehrere Drucke nacheinander, muss ich die Instanz allerdings nicht neu starten.
                                  1Topf 1 Reply Last reply Reply Quote 0
                                  • 1Topf
                                    1Topf @Diginix last edited by
                                    @diginix
                                    Ich habe es anders gelöst. In der main.js /opt/iobroker/node_modules/iobroker.klipper-moonraker/main.js hab ich die Zeit für den reconnect von 10 auf 7200 Sekunden gesetzt. In Notepad++ ist das bei mir die Zeile 335.
                                    		// Handle closure of socket connection, try to connect again in 10seconds (if adapter enabled)
                                    		ws.on('close', () => {
                                    			console.log(`Connection closed`);
                                    			this.log.info(`Connection closed`);
                                    			this.setState('info.connection', false, true);
                                    			connectionState = false;
                                    			// Try to reconnect if connections is closed after 10 seconds
                                    			if (reconnectTimer) {
                                    				clearTimeout(reconnectTimer);
                                    				reconnectTimer = null;
                                    			reconnectTimer = setTimeout(() => {
                                    				console.log(`Trying to reconnect`);
                                    				this.log.info(`Trying to reconnect`);
                                    				if (this.config.auth) {
                                    					try {
                                    						this.getOneShotToken();
                                    					} catch (e) {
                                    						this.log.error(e.message);
                                    				this.handleWebSocket();
                                    			}, (7200_000));
                                    • mcm1957
                                      mcm1957 @1Topf last edited by
                                      Wenn ich nicht übersehen habe ist der Adapter klipper-moonraker nicht in den Repositories verfügbar. Eine INstallation ist daher nur via GitHub möglich. Der Status des Adapters muss daher als im ALPHA Test definiert werden.
                                      Da dieses Topic nicht im Testerbereich liegt eine WARNING an alle User die sich nicht als ALPHA Tester bezeichnen:
                                      Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                                      GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                      Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                      Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                      Und falls es irgendwie unklar ist:
                                      ioBroker unterstützt folgende Arten von Installation:
                                      • aus dem STABLE Repository
                                        Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                                      • aus dem LATEST Repository
                                        Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                                      • direkt von GITHUB
                                        Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                                      • direkt von npm
                                        Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                                      Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit Sicherheit minimalistisch.
                                        CaesarII @Netcrusher last edited by
                                        @netcrusher
                                        dein Skript gefällt mir sehr gut. Ein dickes DANKE dafür.
                                        Allerdings hätte da 2 Wünsche.
                                        -Wäre es möglich dass der Ausgabepfad nicht in javascript.0 sondern ein Verzeichnis in 0_userdata die Daten schreibt?
                                        -Dann bekomme ich eine Fehlermeldung über "request package is deprecated - please use httpGet (or a stable lib like axios) instead!"
                                        Würde mich freuen wenn der Skript wieder ohne Fehlermeldungen funktioniert.
                                        • foxriver76
                                          foxriver76 Developer @CaesarII last edited by
                                          @caesarii auch gerne mal 0.1.1 probieren ob das problem behoben ist dass der reconnect nicht funktioniert.
                                            CaesarII @foxriver76 last edited by
                                            @foxriver76
                                            0.1.1 installiert und auch getestet
                                            Jedoch startet der Adapter gerade bei meinem aktuellen Druck nicht richtig und liefert keine aktuellen Daten. Erst ein "Neu starten" löst das Problem. Dann funktioniert auch alles perfekt.
                                            Das andere Problem ist wenn der 3D-Drucker ausgeschaltet ist, bekomme ich quasi im Minutentackt die Error Meldung dass keine Verbindung zu moonraker besteht. Hab mir damit geholfen dass ich den Adapter erst dann starte nachdem auch den 3D-Drucker mit Spannung versorgt wird (timeout 30000).
                                            Wenn ich irgendwie behilflich sein kann kein Problem.
                                            adapter update klipper moonraker
                                            24
                                            124
                                            19863
