    2. English
    3. Development
    4. New Adapter - Soliscloud
    • M T
      M T @mcm1957 last edited by
      @mcm57 said in New Adapter - Soliscloud:
      @m-t
      As your screenshot shows there is exactly one field for api key and one filed for the api secret at the first line.
      Did you try to enter them there?
      Or did I misunderstand your question.
      What cocerns do you have?
      I use iobroker which data I have to enter where so that I can establish a connection
      Trixx 1 Reply Last reply Reply Quote 0
      • Trixx
        Trixx @M T last edited by
        @m-t
        Hi!
        What you show in your screenshot should work.
        You will also need to add a specific interval that's used between each API call. (Between 45 & 1800 seconds).
        Unrelated remark: I noticed I've left some test code in the last release that logs an error every time the api is polled. This will show "This is the error" in the logging. This can be ignored, I'll push a new version during the weekend that fixes this.
        Regards,
        T
        M T 1 Reply Last reply Reply Quote 0
        • M T
          M T @Trixx last edited by
          @trixx said in New Adapter - Soliscloud:
          @m-t
          Hi!
          Regards,
          T
          The connection is established! Excellent ! Can't you shorten the polling time by 0-1800?
          • mcm1957
            mcm1957 @M T last edited by
            @m-t
            Cloud access MUST have a reasonable minimum Intervall. Otherwise cloud service might ve overliaded an access might be blocked for all ioBroker users. So a minimum of 0bis definitly too low and would not be accepted at repository.
              Luapsi @Trixx last edited by
              @trixx
              Thank you for the implementation and your commitment.
              Update carried out.
              My adapter version is 1.4.0.
              What settings can I make to support you?
              greeting
              Luapsi
                gabylein @mcm1957 last edited by
                Hy
                installed it V1.4.1 - but getting no value from the cloud.
                get this error
                Instance:
                Objects:
                What is the right way to get the Information from the Cloud ?
                greatings
                gabylein
                • Trixx
                  Trixx @gabylein last edited by
                  @gabylein
                  Hi !
                  Do you see more info if you set the logging level to debug ? The configuration seems right.
                  It should show what is returned from the different api calls.
                    gabylein @Trixx last edited by gabylein
                    Its running
                    all the time I call directly this link ..
                    https://www.soliscloud.com/#/station/inverter/inverterdetail?id=xxxxxxxxxxxxxxxxxxxxxxxx&stationId=xxxxxxxxxxxxxxxxxxx
                    there is a mistake * Station ID is not Inverter ID 🙂
                    running now
                    gabylein
                      meikel last edited by
                      First of all, great work 👍 . The adapter works perfectly and provides reliable data.
                      If adjustments are made to the data points in the future, I would find the "total yield" value very interesting for further evaluations.
                      Regards
                        Mirtl last edited by
                        @Trixx
                        Is it possible for you to integrate these?
                        • iDC1 Current
                        • iDC2 Current
                        • iDC3 Current
                        • iCD4 Current
                        • uDC1 Voltage
                        • uDC2 Voltage
                        • uDC3 Voltage
                        • uDC4 Voltage
                        • pDC1 Power
                        • pDC2 Power
                        • pDC3 Power
                        • pDC4 Power
                        Thank you very much in advance!
                        Mirtl
                        • mcm1957
                          mcm1957 @Mirtl last edited by mcm1957
                          @trixx
                          You archived the repo ioBroker.soliscloud.
                          Please let us lnow if hhe adapter is nonlonger worki g due tp some cganges at the solis website or if you just do not have time or interrest to makntain it any further.
                          If the later is valud please consider movi g itvinto iobroker-community-adapters.This wpukd ne only a few clicks for you. Transfer ownership of repo to me (mcm1957) would be sufficient. I can do the rest.
                          Thanks for your feedback
                          Mcm1956
                          Edit
                          https://github.com/iobroker-community-adapters/info?tab=readme-ov-file#ask-to-move-your-repository-to-iobroker-community-adapters
                          des ribes the steps to initiate a transfer
                            Honnkoponko last edited by
                            @Trixx
                            Is it possible to implement Inverter Control as on Home Assistant?
                            Energy Storage Control Switch
                            Overdischarge SOC
                            Force Charge SOC
                            Backup SOC
                            Or does anyone knows how to control and monitor those values via Iobroker?
                            • mcm1957
                              mcm1957 @Honnkoponko last edited by
                              @honnkoponko
                              This adapter is no longer maintained. I do not have any information WHY it was archived.
                              IF the adpater is still working (and change by solis cloud etc.) is the reason to stop maintaining this adapter we could move it to iobroker-community-area so that at least base maintainance can be provided. Adding new features is always possible but depends on available developers.
                              Please let me know if adapter is still working and if you eventually would help testing after migration to iobroker-community-area.
                              (Please ping me again if I miss any answer)
                              57
                              8520
