    4. fritzdect Adapter Fehler alle 10 Sekunden im Log
      pjo123456 @Homoran last edited by
      Hier mal der Log nach einem Neustart des Adapters:
      fritzdect.0
      2024-12-29 12:11:52.399	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
      fritzdect.0
      2024-12-29 12:11:42.412	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
      fritzdect.0
      2024-12-29 12:11:32.090	info	going over to cyclic polling, messages to poll activity only in debug-mode
      fritzdect.0
      2024-12-29 12:11:32.089	info	finished initial updating devices/groups
      fritzdect.0
      2024-12-29 12:11:32.081	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
      fritzdect.0
      2024-12-29 12:11:31.767	info	start initial updating devices/groups
      fritzdect.0
      2024-12-29 12:11:31.767	info	finished creating routines (if any)
      fritzdect.0
      2024-12-29 12:11:31.494	info	start creating routines
      fritzdect.0
      2024-12-29 12:11:31.494	info	routines are used(false)
      fritzdect.0
      2024-12-29 12:11:31.494	info	finished creating templates (if any)
      fritzdect.0
      2024-12-29 12:11:31.245	info	CREATE Templates 19
      fritzdect.0
      2024-12-29 12:11:30.927	info	start creating templates
      fritzdect.0
      2024-12-29 12:11:30.927	info	templates are used(false)
      fritzdect.0
      2024-12-29 12:11:30.927	info	finished creating devices/groups (if any)
      fritzdect.0
      2024-12-29 12:11:30.926	error	iob err => undefined
      fritzdect.0
      2024-12-29 12:11:30.926	error	--------------- error calling the fritzbox -----------
      fritzdect.0
      2024-12-29 12:11:30.926	error	try/catch createDevices TypeError: Cannot read properties of undefined (reading 'replace')
      fritzdect.0
      2024-12-29 12:11:30.922	info	CREATE Devices 8
      fritzdect.0
      2024-12-29 12:11:30.596	info	start creating devices/groups
      fritzdect.0
      2024-12-29 12:11:30.596	info	finished creating global values
      fritzdect.0
      2024-12-29 12:11:30.587	info	create Main object global channel list
      fritzdect.0
      2024-12-29 12:11:30.587	info	____________________________________________
      fritzdect.0
      2024-12-29 12:11:30.587	info	start creating global values
      fritzdect.0
      2024-12-29 12:11:30.587	info	the rights are : {"Rights":{"Name":["Dial","App","HomeAuto","BoxAdmin","Phone","NAS"],"Access":["2","2","2","2","2","2"]}}
      fritzdect.0
      2024-12-29 12:11:30.366	info	checking user permissions
      fritzdect.0
      2024-12-29 12:11:29.767	info	fritzdect uses USER: pjo12345
      fritzdect.0
      2024-12-29 12:11:29.748	info	fritzdect entered ready
      fritzdect.0
      2024-12-29 12:11:29.734	info	starting. Version 2.5.11 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.20.5, js-controller: 7.0.3
      fritzdect.0
      2024-12-29 12:11:25.314	info	terminating
      fritzdect.0
      2024-12-29 12:11:24.994	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
      fritzdect.0
      2024-12-29 12:11:24.813	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fritzdect.0
      2024-12-29 12:11:24.813	info	terminating
      fritzdect.0
      2024-12-29 12:11:24.812	info	cleaned everything up...
      fritzdect.0
      2024-12-29 12:11:24.811	info	Got terminate signal TERMINATE_YOURSELF
      Fritzbox: 6660 Cable, FritzOS: 8.01
      Geräte:
      • Thermostate: 3x Comet DECT (Fritz DECT 300)
      • 2x Fritzdect 200 Steckdosen
      ioBroker läuft in einem Container auf proxmox (alles auf aktuellem Stand)
      fritzdect Adapter: 2.5.11
      npm: 10.8.2
      nodejs: 18.20.5
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @pjo123456 last edited by
        @pjo123456 bitte einmal
        iob diag
        sieht nicht aktuell aus
        Und dann bitte noch die Konfiguration vom Adapter.
        Ro75
          pjo123456 @Ro75 last edited by
          @ro75
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: ioBrokerMasterLXC
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
          Operating System: Ubuntu 23.04
                    Kernel: Linux 6.8.12-5-pve
              Architecture: x86-64
          Firmware Version: F5
          OS is similar to: debian
          model name      : Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           12:27:59 up 8 days, 14:36,  2 users,  load average: 1.17, 0.48, 0.21
          CPU threads: 1
          *** LIFE CYCLE STATUS ***
          Ubuntu Release codenamed 'lunar' reached its END OF LIFE and needs to be updated to the latest LTS release 'noble' NOW!
          *** TIME AND TIMEZONES ***
                         Local time: Sun 2024-12-29 12:27:59 CET
                     Universal time: Sun 2024-12-29 11:27:59 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth
          A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
          A root login is not required in most Linux Distributions.
          Run 'iobroker fix' or use the system tools to create a user.
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            3.2G        1.4G        274M         94K        1.6G        1.8G
          Swap:           536M        244M        292M
          Total:          3.8G        1.6G        567M
          Active iob-Instances:   23
                   3072 M total memory
                   1326 M used memory
                   1241 M active memory
                   1423 M inactive memory
                    261 M free memory
                      0 M buffer memory
                   1484 M swap cache
                    512 M total swap
                    232 M used swap
                    279 M free swap
          top - 12:27:59 up 8 days, 14:36,  2 users,  load average: 1.17, 0.48, 0.21
          Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3072.0 total,    259.3 free,   1327.8 used,   1485.2 buff/cache
          MiB Swap:    512.0 total,    279.0 free,    233.0 used.   1744.2 avail Mem
          *** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          dmesg: read kernel buffer failed: Operation not permitted
          No critical errors detected
          *** FILESYSTEM ***
          /dev/loop0     ext4       19G   13G  5.2G  71% /
          none           tmpfs     492K  4.0K  488K   1% /dev
          efivarfs       efivarfs  128K   96K   28K  78% /sys/firmware/efi/efivars
          tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
          tmpfs          tmpfs     3.2G  140K  3.2G   1% /run
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/0
          Show mounted filesystems:
          TARGET SOURCE     FSTYPE OPTIONS
          /      /dev/loop0 ext4   rw,relatime
          /var:
          521M    /var/
          233M    /var/lib
          164M    /var/log
          163M    /var/log/journal/770cb772b2aa4c2a87f7acb50f04c359
          Archived and active journals take up 162.4M in the file system.
          /opt/iobroker/backups:
          315M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          7.7G    /opt/iobroker/iobroker-data/
          6.9G    /opt/iobroker/iobroker-data/history
          794M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          14M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
          9.6M    /opt/iobroker/iobroker-data/history/20240312/history.ble.1.c4~7c~8d~6b~f9~60.rssi.json
          9.5M    /opt/iobroker/iobroker-data/history/20240311/history.ble.1.c4~7c~8d~6b~f9~60.rssi.json
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.5
          /usr/bin/node           v18.20.5
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 18.20.5-1nodesource1
            Candidate: 18.20.5-1nodesource1
            Version table:
           *** 18.20.5-1nodesource1 600
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.4-1nodesource1 600
               18.20.3-1nodesource1 600
               18.20.2-1nodesource1 600
               18.20.1-1nodesource1 600
               18.20.0-1nodesource1 600
               18.19.1-1nodesource1 600
               18.19.0-1nodesource1 600
               18.18.2-1nodesource1 600
               18.18.1-1nodesource1 600
               18.18.0-1nodesource1 600
               18.17.1-1nodesource1 600
               18.17.0-1nodesource1 600
               18.16.1-1nodesource1 600
               18.16.0-1nodesource1 600
               18.15.0-1nodesource1 600
               18.14.2-1nodesource1 600
               18.14.1-1nodesource1 600
               18.14.0-1nodesource1 600
               18.13.0+dfsg1-1ubuntu2 500
                  500 http://archive.ubuntu.com/ubuntu lunar/universe amd64 Packages
               18.13.0-1nodesource1 600
               18.12.0-1nodesource1 600
               18.11.0-1nodesource1 600
               18.10.0-1nodesource1 600
               18.9.1-1nodesource1 600
               18.9.0-1nodesource1 600
               18.8.0-1nodesource1 600
               18.7.0-1nodesource1 600
               18.6.0-1nodesource1 600
               18.5.0-1nodesource1 600
               18.4.0-1nodesource1 600
               18.3.0-1nodesource1 600
               18.2.0-1nodesource1 600
               18.1.0-1nodesource1 600
               18.0.0-1nodesource1 600
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker-Slave2     ioBroker-Slave2 (version: 7.0.3, hostname: ioBroker-Slave2, alive, uptime: 741772)
          ioBrokerMasterLXC   ioBrokerMasterLXC (version: 7.0.3, hostname: ioBrokerMasterLXC, alive, uptime: 739393)
          Core adapters versions
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBrokerMasterLXC                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : ioBroker-Slave2                          -  enabled
          + system.adapter.backitup.1               : backitup              : ioBrokerMasterLXC                        -  enabled
            system.adapter.ble.0                    : ble                   : ioBrokerMasterLXC                        - disabled
          + system.adapter.ble.1                    : ble                   : ioBroker-Slave2                          -  enabled
          + system.adapter.chromecast.0             : chromecast            : ioBrokerMasterLXC                        -  enabled
          + system.adapter.cloud.0                  : cloud                 : ioBrokerMasterLXC                        -  enabled
          + system.adapter.discovery.0              : discovery             : ioBrokerMasterLXC                        -  enabled
          + system.adapter.email.0                  : email                 : ioBrokerMasterLXC                        -  enabled
            system.adapter.flot.0                   : flot                  : ioBrokerMasterLXC                        - disabled
          + system.adapter.fritzbox.0               : fritzbox              : ioBrokerMasterLXC                        -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : ioBrokerMasterLXC                        -  enabled
          + system.adapter.history.0                : history               : ioBrokerMasterLXC                        -  enabled
            system.adapter.ical.0                   : ical                  : ioBrokerMasterLXC                        -  enabled
          + system.adapter.info.0                   : info                  : ioBrokerMasterLXC                        -  enabled
          + system.adapter.javascript.0             : javascript            : ioBrokerMasterLXC                        -  enabled
          + system.adapter.linux-control.0          : linux-control         : ioBrokerMasterLXC                        -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBrokerMasterLXC                        -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.net-tools.0              : net-tools             : ioBrokerMasterLXC                        - disabled
            system.adapter.pi-hole.0                : pi-hole               : ioBrokerMasterLXC                        - disabled
          + system.adapter.ping.0                   : ping                  : ioBrokerMasterLXC                        -  enabled
          + system.adapter.proxmox.0                : proxmox               : ioBrokerMasterLXC                        -  enabled, port: 8006
          + system.adapter.rpi2.1                   : rpi2                  : ioBroker-Slave2                          -  enabled
          + system.adapter.sayit.0                  : sayit                 : ioBrokerMasterLXC                        -  enabled
          + system.adapter.sonoff.0                 : sonoff                : ioBrokerMasterLXC                        -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : ioBrokerMasterLXC                        -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerMasterLXC                        - disabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerMasterLXC                        - disabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerMasterLXC                        - disabled
            system.adapter.vis.0                    : vis                   : ioBrokerMasterLXC                        -  enabled
          + system.adapter.web.0                    : web                   : ioBrokerMasterLXC                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          │ (index) │   name   │                           url                           │ auto upgrade │
          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "sayit"        : 5.0.0    , installed 5.0.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        3051
          States:         2539
          E: The repository 'http://archive.ubuntu.com/ubuntu lunar Release' no longer has a Release file.
          E: The repository 'http://archive.ubuntu.com/ubuntu lunar-updates Release' no longer has a Release file.
          E: The repository 'http://archive.ubuntu.com/ubuntu lunar-security Release' no longer has a Release file.
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        12306      101/systemd-resolve
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       240687     4857/io.sonoff.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       239390     4815/io.mqtt.0
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        12304      101/systemd-resolve
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       237188     4623/iobroker.js-co
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       237195     4623/iobroker.js-co
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10612      1/init
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          12891      287/master
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          12892      287/master
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12314      1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          10614      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       237339     4641/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       242532     5351/io.web.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       240819     4887/io.chromecast.
          udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        12305      101/systemd-resolve
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        12303      101/systemd-resolve
          udp        0      0 192.168.1.67:68         0.0.0.0:*                           998        15897654   93/systemd-networkd
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10613      1/init
          udp6       0      0 :::111                  :::*                                0          10615      1/init
          2024-12-29 12:25:22.449  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:25:32.450  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:25:42.456  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:25:52.450  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:25:55.734  - info: linux-control.0 (5366) getting data from ioBrokerSlave_2 (192.168.1.57:22)
          2024-12-29 12:25:55.738  - info: linux-control.0 (5366) [getConnection] Host 'ioBrokerSlave_2' (192.168.1.57:22) seems not to be online
          2024-12-29 12:26:02.457  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:26:12.475  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:26:22.457  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:26:32.489  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:26:42.484  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:26:52.464  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:26:55.743  - info: linux-control.0 (5366) getting data from ioBrokerSlave_2 (192.168.1.57:22)
          2024-12-29 12:26:55.746  - info: linux-control.0 (5366) [getConnection] Host 'ioBrokerSlave_2' (192.168.1.57:22) seems not to be online
          2024-12-29 12:27:02.458  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:27:12.460  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:27:22.487  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:27:32.465  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:27:42.467  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:27:52.505  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:27:55.753  - info: linux-control.0 (5366) getting data from ioBrokerSlave_2 (192.168.1.57:22)
          2024-12-29 12:27:55.756  - info: linux-control.0 (5366) [getConnection] Host 'ioBrokerSlave_2' (192.168.1.57:22) seems not to be online
          2024-12-29 12:28:02.475  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:28:12.464  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          2024-12-29 12:28:22.468  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
          Adapter Konfiguration? Was benötigst du da? Screenshot?
          • Ro75
            @pjo123456 sagte in fritzdect Adapter Fehler alle 10 Sekunden im Log:
            ja
            1. Ubuntu-Version ist nur eine "Zwischenversion" - bereits abgelaufen. Da muss was aktuelles her, ggfs. eine LTS Version
            2. nodejs - empfohlen V20.x
            3. Kernel Fehler.
            Ro75.
              @ro75 Hier die Konfig vom Adapter (ich hoffe es ist das richtige):
              zu 1.: Da muss ich mich erst belesen, wie ich das updaten muss
              zu 2.: werde ich machen
              zu 3.: kein Plan
              • Ro75
                @pjo123456 setze bei "excludes" dort bei allen 3 den Haken.
                Ro75.
                  @ro75 Gemacht. Adapter neu gestartet aber der Fehler kommt immer noch alle 10 Sekunden.
                  • Ro75
                    @pjo123456 du hast Master / Slave - Betrieb?
                    Ro75.
                      @ro75 Ja. Master im LXC Container, Slave auf Raspi. Der Slave hat aber nur ein paar Bluetooth Thermometer.
                      • haselchen
                        haselchen Most Active @pjo123456 last edited by haselchen
                        @pjo123456
                        Bist Du das mit dem Issue?
                        https://github.com/foxthefox/ioBroker.fritzdect/issues/599
                        Edit: Wenn nein, dann häng Dich mit ran.
                        Dann brauchen wir hier nicht weiter suchen und Du kannst Dein System solange auf Stand bringen .
                        Sandweier created this issue in foxthefox/ioBroker.fritzdect
                        closed Keine Funktion von fritzdect adapter v2.5.11 im IOB nach Update der Fritzbox 6690 auf Version 8.01 #599
                          pjo123456 @haselchen last edited by Homoran
                          @haselchen Moin!
                          Habe zwar auch ein Issue aufgemacht aber wegen einem anderen Problem. Aber vielleicht hängt das alles damit zusammen.
                          Issue 598: (https://github.com/foxthefox/ioBroker.fritzdect/issues/598)
                          pjo12345 created this issue in foxthefox/ioBroker.fritzdect
                          closed Datenpunkte im Adapter werden nicht (mehr) aktualisiert #598
                          • BertDerKleine
                            BertDerKleine last edited by
                            Ich hänge mich mal hier dran. Folgende Erlebnisse:
                            Nach dem Update meiner Fritzbox 7590ax auf FritzOS v8.02 gabs Probleme, die durch die Version 2.5.12 aus dem Beta repository behoben zu sein schienen.
                            Was ich aber erst sehr viel später festgestellt habe ist die Tatsache, dass der iobroker fritzdect Adapter v2.5.12 anscheinen per API calls die Box irgendwie zumüllt und das zur Folge hat, dass das UI der Fritzbox quasi unbrauchbar langsam wird. Selbst zum Login auf dem UI kann man 2 Minuten warten, bis sich der Screen aufgebaut hat.
                            Im Log finde ich derweil sowas hier unter v2.5.12, haufenweise:
                            2025-02-27 00:03:47.033  - error: fritzdect.0 (800200) --------------- error calling the fritzbox -----------
                            2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) API msg   => error calling executeCommand
                            2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) API funct => login_SID
                            2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) no response part in returned error message
                            2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-110,"code":"ETIMEDOUT","syscall":"connect","address":"192.168.178.1","port":80}}}
                            2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) --------------- error calling the fritzbox -----------
                            2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) API msg   => error calling executeCommand
                            2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) API funct => login_SID
                            2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) no response part in returned error message
                            2025-02-27 00:04:07.514  - error: fritzdect.0 (800200) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-110,"code":"ETIMEDOUT","syscall":"connect","address":"192.168.178.1","port":80}}}
                            2025-02-27 00:04:07.514  - warn: fritzdect.0 (800200) [Polling] <== TypeError: Cannot read properties of undefined (reading 'replace')
                            Erst durch den AVM Support ist mir der Tip mit dem Einfluss des Raspi mit dem iobroker bewusst geworden und die Fehler.
                            Ich habe dann denn Adapter wieder auf 2.5.11 gedowngraded und schwups läuft das UI der Fritzbox wieder normal.
                            Leider ist damit dann wieder der Adapter disfunktional. Die DP werden nicht aktualisiert und das Log wird nach 2-3 Minuten mit "try/catch issue updating device in updateDevices TypeError" Fehler zugespammt (unter v.2.5.12).
                            fritzdect.0
                            	2025-02-27 17:58:58.772	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                            fritzdect.0
                            	2025-02-27 17:58:53.820	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                            fritzdect.0
                            	2025-02-27 17:58:48.802	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                            fritzdect.0
                            	2025-02-27 17:58:43.881	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                            fritzdect.0
                            	2025-02-27 17:58:39.839	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                            fritzdect.0
                            	2025-02-27 17:58:33.011	info	going over to cyclic polling, messages to poll activity only in debug-mode
                            fritzdect.0
                            	2025-02-27 17:58:33.011	info	finished initial updating devices/groups
                            fritzdect.0
                            	2025-02-27 17:58:33.001	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                            fritzdect.0
                            	2025-02-27 17:58:32.070	info	start initial updating devices/groups
                            fritzdect.0
                            	2025-02-27 17:58:32.069	info	finished creating routines (if any)
                            fritzdect.0
                            	2025-02-27 17:58:31.903	info	CREATE Routines 6
                            fritzdect.0
                            	2025-02-27 17:58:31.086	info	start creating routines
                            fritzdect.0
                            	2025-02-27 17:58:31.085	info	routines are used(false)
                            fritzdect.0
                            	2025-02-27 17:58:31.085	info	finished creating templates (if any)
                            fritzdect.0
                            	2025-02-27 17:58:30.695	info	CREATE Templates 30
                            fritzdect.0
                            	2025-02-27 17:58:30.158	info	start creating templates
                            fritzdect.0
                            	2025-02-27 17:58:30.157	info	templates are used(false)
                            fritzdect.0
                            	2025-02-27 17:58:30.156	info	finished creating devices/groups (if any)
                            fritzdect.0
                            	2025-02-27 17:58:30.155	error	iob err => undefined
                            fritzdect.0
                            	2025-02-27 17:58:30.154	error	--------------- error calling the fritzbox -----------
                            fritzdect.0
                            	2025-02-27 17:58:30.152	error	try/catch createDevices TypeError: Cannot read properties of undefined (reading 'replace')
                            fritzdect.0
                            	2025-02-27 17:58:30.144	info	CREATE Devices 31
                            fritzdect.0
                            	2025-02-27 17:58:29.126	info	start creating devices/groups
                            fritzdect.0
                            	2025-02-27 17:58:29.124	info	finished creating global values
                            fritzdect.0
                            	2025-02-27 17:58:29.062	info	create Main object global channel list
                            fritzdect.0
                            	2025-02-27 17:58:29.061	info	____________________________________________
                            fritzdect.0
                            	2025-02-27 17:58:29.060	info	start creating global values
                            fritzdect.0
                            	2025-02-27 17:58:29.059	info	the rights are : {"Rights":{"Name":"HomeAuto","Access":"2"}}
                            fritzdect.0
                            	2025-02-27 17:58:28.351	info	checking user permissions
                            fritzdect.0
                            	2025-02-27 17:57:24.618	info	fritzdect uses USER: iobroker
                            fritzdect.0
                            	2025-02-27 17:57:24.574	info	fritzdect entered ready
                            fritzdect.0
                            	2025-02-27 17:57:24.547	info	starting. Version 2.5.11 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v20.18.2, js-controller: 7.0.6
                            fritzdect.0
                            	2025-02-27 17:57:11.032	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            fritzdect.0
                            	2025-02-27 17:57:11.031	info	terminating
                            fritzdect.0
                            	2025-02-27 17:57:11.030	info	cleaned everything up...
                            fritzdect.0
                            	2025-02-27 17:57:11.028	info	Got terminate signal TERMINATE_YOURSELF
                            Ich habe also die Wahl zwischen unbenutzbarer Fritzbox-UI, aber aktuellen DP in iobroker ODER funktionierender Fritzbox UI und fritzdect-Adapter kaputt.
                            Tips?
                              Peter c last edited by
                              @bertderkleine said in fritzdect Adapter Fehler alle 10 Sekunden im Log:
                              Tips?
                              Ich habe gerade auf Github gesehen, dass es eine Version 2.6.1 gibt. Die ist als debug Version ladbar. Mit der ist der Adapter wieder mit fritzboxOS 8.02 arbeitsfähig. Vielleicht geht es bei Dir damit auch.
                              BertDerKleine Detlef Meissner 3 Replies Last reply Reply Quote 1
                              • BertDerKleine
                                BertDerKleine @Peter c last edited by
                                @peter-c
                                Danke Dir. Ist einen Versuch wert.
                                • BertDerKleine
                                  @peter-c sagte in fritzdect Adapter Fehler alle 10 Sekunden im Log:
                                  Es scheint, als ob die v2.6.1 mit FritzOS v8.02 so tut, wie es soll.
                                  Danke Dir für den Tip!
                                  P Walter.O. 2 Replies Last reply Reply Quote 0
                                    Peter c @BertDerKleine last edited by
                                    Gerne
                                    • Detlef Meissner
                                      Detlef Meissner @Peter c last edited by
                                      @peter-c Hallo, ich bin Anfänger bei iobroker deshalb meine Frage, da meine Fritzbox nach Update auf ios Version 8.02 auch nicht mehr läuft, wie kann ich die Version 2.6.1 von Fritzbox dect bekommen und installieren?
                                      Wie gessagt absoluter Neuling, die Update habe ich sonst wenn Verfügbar über iobroker installiert.
                                      Vielen dank für eure Hilfe.
                                      Gruß Detlef
                                      • Walter.O.
                                        Walter.O. @BertDerKleine last edited by
                                        @bertderkleine sagte in fritzdect Adapter Fehler alle 10 Sekunden im Log:
                                        Kannst du mir bitte mal den link geben zur 2.6.1 habe das gleiche Problem.
                                        B BertDerKleine 2 Replies Last reply Reply Quote 0
                                          brofelscher @Walter.O. last edited by
                                          @walter-o und @Detlef-Meissner : Ich glaube er meint die NPM-Version vom "fritzdect"-Adapter. Ich hatte das gleiche Problem wie ihr und konnte es mit der besagten NPM-Version 2.6.0 vom fritzdect-Adapter lösen.
                                          • Dazu deinstalliert ihr erstmal den offiziellen Adapter: Adapter > fritzdect > Adapter löschen
                                          • Weiterhin im Reiter "Adapter" auf den "Expertenmodus" umschalten (Kopfsymbol oben in der Leiste)
                                          • Daraufhin seht ihr das Katzensymbol direkt unterhalb des Expertenmodus-Symbols. Nennt sich "Installieren aus eigener URL"
                                          • Standardmäßig sollte dort bereits "von NPM" ausgewählt sein, so das ihr aus der DropDown-Liste nur noch "fritzdect" wählen und suchen müsst.
                                          • Auf "Installieren" klicken
                                          • Im Nachgang noch eine neue Instanz für den Adapter anlegen
                                            rso last edited by
                                            Bei mir tauchte seit dem Update der Fritzbox auf V8.02 ein unbekanntes Gerät (wie im Issue 599 beschrieben) im Smarthomebereich auf. Dieses habe ich mir erlaubt zu löschen. Danach funktioniert alles wieder, auch mit Adapterversion 2.5.11.
                                            Ü 1 Reply Last reply Reply Quote 0
                                            28
                                            2099
