    4. Problem beim Aktualisieren des Admin Adapters
    UNSOLVED Problem beim Aktualisieren des Admin Adapters
      Ecopilot @Thomas Braun last edited by
      @thomas-braun said in Problem beim Aktualisieren des Admin Adapters:
      Im jetzigen System:
      raik@raspberrypi:~ $ iob update
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 5.3.8  [Updatable]
      Adapter    "backitup"     : 3.0.25   , installed 2.4.6  [Updatable]
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
      Adapter    "fronius"      : 2.1.1    , installed 1.1.3  [Updatable]
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
      Adapter    "javascript"   : 8.8.3    , installed 5.2.21 [Updatable]
      Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
      Adapter    "mqtt"         : 6.1.2    , installed 2.1.14 [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      raik@raspberrypi:~ $ iob upgrade all -y
      Update admin from @5.3.8 to @7.1.5
      Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
        Thomas Braun Most Active @Ecopilot last edited by
        @ecopilot
        Das kommt halt davon, wenn man da alles versumpfen lässt...
        iob stop
        cd /opt/iobroker
        npm install iobroker.js-controller@5.0.0 --omit=dev
        npm install iobroker.js-controller@6.0.0 --omit=dev
        npm install iobroker.js-controller@7.0.0 --omit=dev
        iob update
        iob upgrade self
          iob upgrade self
          raik@raspberrypi:~ $ iob stop
          raik@raspberrypi:~ $ cd /opt/iobroker
          raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.0 --omit=dev
          npm error code ETARGET
          npm error notarget No matching version found for iobroker.js-controller@5.0.0.
          npm error notarget In most cases you or one of your dependencies are requesting
          npm error notarget a package version that doesn't exist.
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-12-29T21_48_50_900Z-debug-0.log
          raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.17 --omit=dev
          added 15 packages, removed 5 packages, and changed 16 packages in 37s
          72 packages are looking for funding
            run `npm fund` for details
          raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@6.0.0 --omit=dev
          removed 33 packages, and changed 14 packages in 33s
          raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@7.0.0 --omit=dev
          added 2 packages, removed 2 packages, and changed 14 packages in 31s
          raik@raspberrypi:/opt/iobroker $ iob update
          Controller "js-controller": 7.0.6    , installed 7.0.0  [Updatable]
          raik@raspberrypi:/opt/iobroker $ iob upgrade self
          Update js-controller from @7.0.0 to @7.0.6
          Stopped Objects DB
          Stopped States DB
          NPM version: 10.8.2
          Installing iobroker.js-controller@7.0.6... (System call)
          changed 12 packages in 27s
            @ecopilot
            Dann schau jetzt mal ob du die einzelnen Adapter nachgezogen bekommst.
              Nee, das gleiche Problem besteht immer noch.
              raik@raspberrypi:/opt/iobroker $ iob upgrade all -y
                @ecopilot
                Mach es einzeln, den admin dann als letzten.
                  Homoran Global Moderator Administrators @Ecopilot last edited by
                  @ecopilot sagte in Problem beim Aktualisieren des Admin Adapters:
                  Da liegt der controller v5.0.0 wohl nicht mehr auf npm
                    Das funktioniert nicht, da werden Abhängigkeiten beanstandet.
                    raik@raspberrypi:/opt/iobroker $ iob upgrade fronius
                    Cannot check dependencies: Invalid version of "admin". Installed "5.3.8", required ">=6.13.16
                      @ecopilot
                      Dependency hell.
                      Handelt man sich ein, wenn das Ding nie Updates bekommt....
                      iob upgrade admin@6.13.16 --omit=dev
                        Es läuft immer wieder auf das Problem mit den nicht lesbaren Eigenschaften hinaus.
                        raik@raspberrypi:/opt/iobroker $ iob upgrade admin@6.13.16 --omit=dev
                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                        Would you like to upgrade admin from @5.3.8 to @6.13.16 now? [(y)es, (n)o]: y
                        Update admin from @5.3.8 to @6.13.16
                          @ecopilot
                          Da sind ja noch mehr Adapter. Versuch die nacheinander hochzuziehen.
                          E 2 Replies Last reply Reply Quote 0
                            Ich muss jetzt erst mal in die Horizontale... ich mache morgen an der Stelle weiter....
                            Danke erst mal für Deine Bemühungen. 👍
                            • mcm1957
                              mcm1957 @Homoran last edited by
                              @homoran said in Problem beim Aktualisieren des Admin Adapters:
                              5.0.19 ist der letzte aktuelle 5er.
                              Ob 5.0.0 jemals online ging kann ich mich nicht erinnern. Beim schrittweisen hochpäppeln sollte man immer die aktualleste Version der jeweiligen major nehmen da die ersten Versionen einer Major durchaus fehlerhaft sein können.
                                Ecopilot @Ecopilot last edited by Ecopilot
                                @ecopilot
                                ich habe jetzt mal alle Adapter, bei denen es funktioniert, schrittweise bis auf die Sollversion hoch gezogen.
                                Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                                Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Controller "js-controller": 7.0.6    , installed 7.0.6
                                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                Nur der "Admin" und der "Backitup" lassen sich nicht updaten. Da kommt immer wieder der Fehler mit den nicht lesbaren Eigenschaften.
                                raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.11.0
                                Would you like to upgrade backitup from @2.4.6 to @2.11.0 now? [(y)es, (n)o]: y
                                Update backitup from @2.4.6 to @2.11.0
                                raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.4.16
                                Would you like to upgrade backitup from @2.4.6 to @2.4.16 now? [(y)es, (n)o]: y
                                Update backitup from @2.4.6 to @2.4.16
                                raik@raspberrypi:/opt/iobroker $ iob upgrade admin@5.4.9
                                Would you like to upgrade admin from @5.3.8 to @5.4.9 now? [(y)es, (n)o]: y
                                Update admin from @5.3.8 to @5.4.9
                                Wie bekommt man das jetzt weg?
                                  Gibt es irgendwo ein log, wo man sieht, was da nicht lesbar ist? Die Meldung an sich ist nicht besonders aussagefähig.
                                  Oder bringt es was, die beiden Adapter über npm hoch zu ziehen?
                                  Das wird zwar vermutlich nicht das Grundlegende Problem lösen, aber das System wäre erst mal wieder lauffähig. Oder bin ich da auf dem Holzweg?
                                  mcm1957 Homoran 2 Replies Last reply Reply Quote 0
                                  • mcm1957
                                    mcm1957 @Ecopilot last edited by
                                    @foxriver76
                                    @apollon77
                                    @Bluefox
                                    Habt ihr ne Idee insbesondere auch was ein allfälliger aussagekräftigeres Log betrifft?
                                      @ecopilot hast du es mal mit dem --debug Flag versucht?
                                      also iob ugrade adapterName --debug?
                                        Ecopilot @Homoran last edited by
                                        Ja, da kommt auch nicht mehr.
                                        raik@raspberrypi:~ $ iob upgrade admin@6.13.16 --debug
                                          Homoran Global Moderator Administrators @Ecopilot last edited by Homoran
                                          @ecopilot Danke.
                                          Ich würde es jetzt mit einer Neuinstallation (ggf. Downgrade des Controllers) und dem Restore des aktuellsten Backups versuchen.
                                          Dürfte letztendlich schneller gehen.
                                            @Thomas-Braun
                                            @mcm1957
                                            Ich habe die beiden störrischen Adapter jetzt erst mal per npm hochgezogen und jetzt funktioniert das System erst mal wieder auf neustem Stand. Beim nächsten Update wird es dann sicher wieder das gleiche Problem geben. Vlt. hat bis dahin jemand eine Idee, wie da eine bessere Diagnose möglich ist. Jetzt ist auch etwas Zeit, um das System dann mal mit Version 12 (bookworm) neu aufzusetzen.
                                            Euch vielen Dank für die Unterstützung und einen guten Rutsch.
                                            1934
