    4. Backitup Error
    Backitup Error
      Thomas Braun Most Active @io2345 last edited by
      @io2345
      Debian 12 'Bookworm'
      Wird ab Release 3 Jahre voll unterstützt.
      Ist LTS genug, auf einen privaten System.
      EOL für Debian 12 ist demnach im Sommer 2026.
      • Codierknecht
        Codierknecht Developer Most Active @io2345 last edited by
        @io2345
        Um die Aussage von @Thomas-Braun zu untermauern:
        https://wiki.debian.org/DebianReleases#Production_Releases
        • I
          io2345 @io2345 last edited by
          Jetzt hab ich mit Debian-12 nochmal installiert. Dafür hab ich jetzt wieder failed services in der Übersicht. Man kann wohl nicht alles haben 😉
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
          Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           22:32:55 up 40 min,  0 user,  load average: 0.24, 0.13, 0.22
          CPU threads: 1
          *** LIFE CYCLE STATUS ***
          Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
          *** TIME AND TIMEZONES ***
          Failed to query server: Connection timed out
          Failed to parse bus message: Connection timed out
          *** Users and Groups ***
          User that called 'iob diag':
          iobrokeradmin
          HOME=/home/iobrokeradmin
          GROUPS=iobrokeradmin sudo users iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            2.1G        1.2G        154M         69K        760M        914M
          Swap:           536M         16K        536M
          Total:          2.7G        1.2G        691M
          Active iob-Instances:   14
                   2048 M total memory
                   1175 M used memory
                   1215 M active memory
                    574 M inactive memory
                    147 M free memory
                      0 M buffer memory
                    725 M swap cache
                    512 M total swap
                      0 M used swap
                    511 M free swap
          top - 22:34:10 up 42 min,  0 user,  load average: 0.18, 0.13, 0.20
          Tasks:  35 total,   1 running,  34 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   2048.0 total,    145.4 free,   1177.4 used,    725.4 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.    870.6 avail Mem
          *** FAILED SERVICES ***
            UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
          * nftables.service                   loaded failed failed nftables
          * systemd-hostnamed.service          loaded failed failed Hostname Service
          * systemd-logind.service             loaded failed failed User Login Management
          * systemd-networkd.service           loaded failed failed Network Configuration
          * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
          * systemd-sysusers.service           loaded failed failed Create System Users
          * systemd-timedated.service          loaded failed failed Time & Date Service
          * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
          * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
          * systemd-tmpfiles-setup.service     loaded failed failed Create System Files and Directories
          * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          11 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                       Type   Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--102--disk--0 ext4   7.8G  4.0G  3.5G  54% /
          none                             tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
          tmpfs                            tmpfs  2.4G   80K  2.4G   1% /run
          tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
          [Fri Dec 27 17:47:17 2024] EXT4-fs (dm-1): mounted filesystem b474fcca-8614-4935-abf2-ede52e720980 ro with ordered data mode. Quota mode: none.
          [Fri Dec 27 17:47:19 2024] EXT4-fs (dm-1): re-mounted b474fcca-8614-4935-abf2-ede52e720980 r/w. Quota mode: none.
          [Fri Dec 27 17:47:38 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 17:47:42 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 17:47:46 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 17:49:01 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
          [Fri Dec 27 17:49:02 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 18:09:03 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 18:09:19 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Fri Dec 27 18:12:24 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 18:15:55 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Fri Dec 27 18:15:56 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): write access unavailable, skipping orphan cleanup
          [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c ro without journal. Quota mode: none.
          [Fri Dec 27 18:31:42 2024] EXT4-fs (dm-11): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
          [Fri Dec 27 18:44:42 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
          [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
          [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
          [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Fri Dec 27 23:44:56 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
          [Fri Dec 27 23:45:17 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
          [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
          [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
          [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 14:56:32 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
          [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
          [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Sun Dec 29 15:14:23 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 15:30:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Sun Dec 29 15:30:25 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 15:39:00 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 15:40:42 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
          [Sun Dec 29 15:52:08 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 15:52:30 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
          [Sun Dec 29 15:52:52 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
          [Sun Dec 29 15:52:56 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 16:41:57 2024] EXT4-fs (dm-6): unmounting filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336.
          [Sun Dec 29 16:41:58 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 21:13:10 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 21:13:18 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
          [Sun Dec 29 21:28:18 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 21:28:31 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
          [Sun Dec 29 21:29:23 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 21:51:57 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
          [Sun Dec 29 21:51:58 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
          [Sun Dec 29 21:59:13 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
          Show mounted filesystems:
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
          /var:
          421M    /var/
          249M    /var/cache
          245M    /var/cache/apt
          170M    /var/cache/apt/archives
          147M    /var/lib
                Users in the 'systemd-journal' group can see all messages. Pass -q to
                turn off this notice.
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          4.0K    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          765M    /opt/iobroker/iobroker-data/
          741M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          18M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 2027)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker8                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : ioBroker8                                -  enabled
          + system.adapter.discovery.0              : discovery             : ioBroker8                                -  enabled
          + system.adapter.email.0                  : email                 : ioBroker8                                -  enabled
          + system.adapter.enigma2.0                : enigma2               : ioBroker8                                -  enabled
            system.adapter.habpanel.0               : habpanel              : ioBroker8                                - disabled
          + system.adapter.influxdb.0               : influxdb              : ioBroker8                                -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : ioBroker8                                -  enabled
          + system.adapter.lg-thinq.0               : lg-thinq              : ioBroker8                                -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker8                                -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.tuya.0                   : tuya                  : ioBroker8                                - disabled
          + system.adapter.upnp.0                   : upnp                  : ioBroker8                                -  enabled
          + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker8                                -  enabled
          + system.adapter.web.0                    : web                   : ioBroker8                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker8                                -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
          Adapter    "upnp"         : 1.1.0    , installed 1.1.0
          Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        13663
          States:         9986
          Hit:2 http://security.debian.org bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6502397    1/init
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6506337    331/master
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6551665    1590/io.mqtt.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6535230    751/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6535225    751/iobroker.js-con
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6535444    783/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6548230    1575/io.web.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6506338    331/master
          tcp6       0      0 :::111                  :::*                    LISTEN      0          6505475    1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6505789    1/init
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6505718    87/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6502400    1/init
          udp        0      0 0.0.0.0:42352           0.0.0.0:*                           1001       6545120    1418/io.upnp.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       6545364    1418/io.upnp.0
          udp6       0      0 :::111                  :::*                                0          6505478    1/init
          2024-12-29 22:21:46.815  - info: mqtt.0 (1590) Client [Wassersensor2_WP] subscribes on "Wassersensor2_WP/+/get"  with regex /mqtt\.0\.Wassersensor2_WP\.[^.]*\.get/
          2024-12-29 22:25:16.788  - info: mqtt.0 (1590) Client [Wassersensor2_WP] connection closed: timeout
          2024-12-29 22:26:21.514  - info: mqtt.0 (1590) Client [Wassersensor1] connected with secret 1735507581513_4320
          2024-12-29 22:26:21.519  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set" with regex /Wassersensor1\.[^.]*\.set/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.set/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set" with regex /bekens_n\.[^.]*\.set/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set"  with regex /mqtt\.0\.bekens_n\.[^.]*\.set/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+" with regex /cmnd\.Wassersensor1\.[^\.]*$/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+"  with regex /mqtt\.0\.cmnd\.Wassersensor1\.[^\.]*$/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+" with regex /cmnd\.bekens_n\.[^\.]*$/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+"  with regex /mqtt\.0\.cmnd\.bekens_n\.[^\.]*$/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get" with regex /Wassersensor1\.[^.]*\.get/
          2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.get/
          2024-12-29 22:27:41.571  - info: mqtt.0 (1590) Client [Wassersensor1] reconnected. Old secret 1735507581513_4320. New secret 1735507661570_5281
          2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set" with regex /Wassersensor1\.[^.]*\.set/
          2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.set/
          2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set" with regex /bekens_n\.[^.]*\.set/
          2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set"  with regex /mqtt\.0\.bekens_n\.[^.]*\.set/
          2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+" with regex /cmnd\.Wassersensor1\.[^\.]*$/
          2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+"  with regex /mqtt\.0\.cmnd\.Wassersensor1\.[^\.]*$/
          2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+" with regex /cmnd\.bekens_n\.[^\.]*$/
          2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+"  with regex /mqtt\.0\.cmnd\.bekens_n\.[^\.]*$/
          2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get" with regex /Wassersensor1\.[^.]*\.get/
          2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.get/
          2024-12-29 22:31:11.567  - info: mqtt.0 (1590) Client [Wassersensor1] connection closed: timeout
            Homoran Global Moderator Administrators @io2345 last edited by
            @io2345 mit 2GB RAM wird's schon zu knapp.
              @io2345 sagte in Backitup Error:
              Mit
              CPU threads: 1
              auch.
              • I
                io2345 @Thomas Braun last edited by io2345
                Hab jetzt mal drei GB und 2 CPU eingestellt, was die Situation aber bestenfalls marginal verbessert. So bin ich eher geneigt anzunehmen, dass Debian 12 der Grund ist. Welches Template habt ihr denn verwendet - ebenfalls Debian 12 oder was anderes? Einfach alle durchprobieren möchte ich jetzt auch nicht unbedingt...
                ```bash
                Script v.2024-10-19
                *** BASE SYSTEM ***
                Failed to query system properties: Connection timed out
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 08:42:16 up 3 min,  0 user,  load average: 0.35, 0.41, 0.27
                CPU threads: 2
                iobrokeradmin
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            3.2G        957M        2.0G         86K        279M        2.3G
                Swap:           536M          0B        536M
                Total:          3.8G        957M        2.5G
                         3072 M total memory
                          913 M used memory
                         1009 M active memory
                          119 M inactive memory
                         1891 M free memory
                            0 M buffer memory
                          266 M swap cache
                          512 M total swap
                            0 M used swap
                          512 M free swap
                top - 08:43:32 up 4 min,  0 user,  load average: 0.12, 0.33, 0.25
                MiB Mem :   3072.0 total,   1890.1 free,    914.9 used,    267.1 buff/cache
                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2157.1 avail Mem
                10 loaded units listed.
                *** FILESYSTEM ***
                [Mon Dec 30 08:36:04 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
                [Mon Dec 30 08:36:59 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
                [Mon Dec 30 08:38:47 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
                [Mon Dec 30 08:38:48 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
                /var:
                421M    /var/
                249M    /var/cache
                245M    /var/cache/apt
                147M    /var/lib
                786M    /opt/iobroker/iobroker-data/
                23M     /opt/iobroker/iobroker-data/objects.jsonl
                13M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 272)
                admin:          7.1.5
                javascript:     8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        13663
                States:         9996
                Hit:1 http://security.debian.org bookworm-security InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Pending Updates: 0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7724560    167/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7724563    167/iobroker.js-con
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7724430    331/master
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7720832    1/init
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7728433    515/io.mqtt.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7729441    581/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7724676    342/io.admin.0
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7724431    331/master
                tcp6       0      0 :::111                  :::*                    LISTEN      0          7720834    1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          7725083    1/init
                udp        0      0 0.0.0.0:54961           0.0.0.0:*                           1001       7728536    548/io.upnp.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7725061    88/dhclient
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7720833    1/init
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7728704    548/io.upnp.0
                udp6       0      0 :::111                  :::*                                0          7720835    1/init
                2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/set"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.set/
                2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
                2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
                2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+" with regex /cmnd\.SmartPlug2\.[^\.]*$/
                2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+"  with regex /mqtt\.0\.cmnd\.SmartPlug2\.[^\.]*$/
                2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
                2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
                2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get" with regex /SmartPlug2\.[^.]*\.get/
                2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.get/
                2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
                2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
                2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
                2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
                2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
                2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
                2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
                2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
                2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
                2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
                2024-12-30 08:39:42.604  - info: web.0 (581) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
                2024-12-30 08:39:42.699  - info: web.0 (581) socket.io server listening on port 8082
                2024-12-30 08:39:42.701  - info: web.0 (581) http server listening on port 8082
                2024-12-30 08:40:55.500  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
                2024-12-30 08:41:00.499  - info: admin.0 (342) <== Disconnect system.user.admin from ::ffff:192.168.0.28 admin
                2024-12-30 08:41:02.730  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
                S Homoran Codierknecht 3 Replies Last reply Reply Quote 0
                  Shadowhunter23 @io2345 last edited by
                  Läuft bei mir ohne Probleme mir dem Template:
                    ist ja auch nur marginal verändert
                    4GB ist minimum, 8GB sinnvoll
                    4CPU sollten es auch sein
                    • I
                      io2345 @Homoran last edited by
                      Somit wissen wir nun, dass es nicht an fehlenden Ressourcen liegt:
                      ```bash
                      Script v.2024-10-19
                      *** BASE SYSTEM ***
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       10:37:58 up 2 min,  0 user,  load average: 0.33, 0.27, 0.21
                      CPU threads: 4
                      iobrokeradmin
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Mem:            8.6G        896M        7.4G         86K        275M        7.7G
                      Swap:           536M          0B        536M
                      Total:          9.1G        896M        8.0G
                               8192 M total memory
                                854 M used memory
                                951 M active memory
                                114 M inactive memory
                               7074 M free memory
                                  0 M buffer memory
                                262 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      top - 10:39:13 up 3 min,  0 user,  load average: 0.20, 0.24, 0.20
                      MiB Mem :   8192.0 total,   7072.8 free,    856.6 used,    262.8 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7335.4 avail Mem
                      *** FILESYSTEM ***
                      [Mon Dec 30 10:34:28 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
                      [Mon Dec 30 10:35:26 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
                      /var:
                      421M    /var/
                      249M    /var/cache
                      245M    /var/cache/apt
                      147M    /var/lib
                      793M    /opt/iobroker/iobroker-data/
                      28M     /opt/iobroker/iobroker-data/objects.jsonl
                      15M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 227)
                      admin:          7.1.5
                      javascript:     8.8.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        13663
                      States:         9996
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7969660    331/master
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7972212    167/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7971162    167/iobroker.js-con
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7969436    1/init
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7974525    515/io.mqtt.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7975376    595/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7971236    342/io.admin.0
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7969661    331/master
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          7970523    1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          7970885    1/init
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7977080    562/io.upnp.0
                      udp        0      0 0.0.0.0:55622           0.0.0.0:*                           1001       7975269    562/io.upnp.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7970942    87/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7969437    1/init
                      udp6       0      0 :::111                  :::*                                0          7970456    1/init
                      2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
                      2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
                      2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
                      2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
                      2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
                      2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
                      2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
                      2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
                      2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
                      2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
                      2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set" with regex /SmartPlug3\.[^.]*\.set/
                      2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.set/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+" with regex /cmnd\.SmartPlug3\.[^\.]*$/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+"  with regex /mqtt\.0\.cmnd\.SmartPlug3\.[^\.]*$/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get" with regex /SmartPlug3\.[^.]*\.get/
                      2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.get/
                      2024-12-30 10:36:18.805  - info: viessmannapi.0 (580) 1 installations found.
                      2024-12-30 10:36:19.776  - info: host.ioBroker8 instance system.adapter.web.0 in version "6.2.5" started with pid 595
                      2024-12-30 10:36:20.511  - info: web.0 (595) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
                      2024-12-30 10:36:20.605  - info: web.0 (595) socket.io server listening on port 8082
                      2024-12-30 10:36:20.610  - info: web.0 (595) http server listening on port 8082
                      Dann bleiben wir halt auf Debian 11. Der Container ist ja nicht aus dem Internet erreichbar (der Host auch nicht)
                        Ist zwar ein Schritt weiter, hilft dann aber leider nicht.
                        Nur mal zur Klärung:
                        Was hayt du denn genau gemacht?
                        Die letzten Zeilen sehen aus, als ob der Restore noch nicht fertig ist.
                        • I
                          io2345 @Homoran last edited by io2345
                          Danke für's Kümmern.
                          Ich habe bei beiden Containern (Debian 11 und 12) das Gleiche gemacht: Die Anleitung für die CT-Installation habe ich von hier: Proxmox Installation. Ungefähr nach dem ersten Drittel kommt der Abschnitt "Erstellen eines Linux Containers (LXC) + ioBroker Installation im Anschluß".
                          Dann die Einstellungen für den NAS-Share im BackItUp-Plugin eingestellt und darüber das identische Backup wiedereingespielt.
                            Die Liste ist auch deutlich zu umfangreich. Die müssen auch bei einem Container starten..
                              damit ist der Restore noch lange nicht fertig.
                              Srlbst wenn in der Basis nicht der Wurm drin wöre, würde jetzt erst begonnen alle Pakete für das neue Systrm passend neu zu bauen.
                              Das dauert.
                              • I
                                Richtig, aber da muss ich ja manuell nichts mehr machen. Hat gefühlt etwa fünfzehn Minuten gedauert, bis die Pakete geladen, installiert und die Adapter wieder drin waren. Gestartet sind die hinzugefügten Adapter-Instanzen übrigens nicht von alleine, die musste ich manuell starten. War aber bei dem Debian11-CT genauso.
                                  aber du solltest in der Zeit auch nichts machen!
                                  das kann man konfigurieren.
                                  Ist aber nicht grundlos so.
                                  Du kannst so noch die Einstellungen auf neue Gegebenheiten anpassen.
                                  • Codierknecht
                                    Genau das. Läuft wie geschnitten Brot.
                                    65
                                    6169
