    4. Backitup Error
    Backitup Error
    • I
      io2345 @io2345 last edited by
      Jetzt hab ich mit Debian-12 nochmal installiert. Dafür hab ich jetzt wieder failed services in der Übersicht. Man kann wohl nicht alles haben 😉
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
      Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
      OS is similar to:
      model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       22:32:55 up 40 min,  0 user,  load average: 0.24, 0.13, 0.22
      CPU threads: 1
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
      Failed to query server: Connection timed out
      Failed to parse bus message: Connection timed out
      *** Users and Groups ***
      User that called 'iob diag':
      iobrokeradmin
      HOME=/home/iobrokeradmin
      GROUPS=iobrokeradmin sudo users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            2.1G        1.2G        154M         69K        760M        914M
      Swap:           536M         16K        536M
      Total:          2.7G        1.2G        691M
      Active iob-Instances:   14
               2048 M total memory
               1175 M used memory
               1215 M active memory
                574 M inactive memory
                147 M free memory
                  0 M buffer memory
                725 M swap cache
                512 M total swap
                  0 M used swap
                511 M free swap
      top - 22:34:10 up 42 min,  0 user,  load average: 0.18, 0.13, 0.20
      Tasks:  35 total,   1 running,  34 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   2048.0 total,    145.4 free,   1177.4 used,    725.4 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.    870.6 avail Mem
      *** FAILED SERVICES ***
        UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
      * nftables.service                   loaded failed failed nftables
      * systemd-hostnamed.service          loaded failed failed Hostname Service
      * systemd-logind.service             loaded failed failed User Login Management
      * systemd-networkd.service           loaded failed failed Network Configuration
      * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
      * systemd-sysusers.service           loaded failed failed Create System Users
      * systemd-timedated.service          loaded failed failed Time & Date Service
      * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
      * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
      * systemd-tmpfiles-setup.service     loaded failed failed Create System Files and Directories
      * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      11 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--102--disk--0 ext4   7.8G  4.0G  3.5G  54% /
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
      tmpfs                            tmpfs  2.4G   80K  2.4G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      [Fri Dec 27 17:47:17 2024] EXT4-fs (dm-1): mounted filesystem b474fcca-8614-4935-abf2-ede52e720980 ro with ordered data mode. Quota mode: none.
      [Fri Dec 27 17:47:19 2024] EXT4-fs (dm-1): re-mounted b474fcca-8614-4935-abf2-ede52e720980 r/w. Quota mode: none.
      [Fri Dec 27 17:47:38 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 17:47:42 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 17:47:46 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 17:49:01 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
      [Fri Dec 27 17:49:02 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 18:09:03 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 18:09:19 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Fri Dec 27 18:12:24 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 18:15:55 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Fri Dec 27 18:15:56 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): write access unavailable, skipping orphan cleanup
      [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c ro without journal. Quota mode: none.
      [Fri Dec 27 18:31:42 2024] EXT4-fs (dm-11): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
      [Fri Dec 27 18:44:42 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
      [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
      [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Fri Dec 27 23:44:56 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
      [Fri Dec 27 23:45:17 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
      [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
      [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
      [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 14:56:32 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
      [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
      [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Sun Dec 29 15:14:23 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 15:30:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Sun Dec 29 15:30:25 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 15:39:00 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 15:40:42 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
      [Sun Dec 29 15:52:08 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 15:52:30 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
      [Sun Dec 29 15:52:52 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
      [Sun Dec 29 15:52:56 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 16:41:57 2024] EXT4-fs (dm-6): unmounting filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336.
      [Sun Dec 29 16:41:58 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 21:13:10 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 21:13:18 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
      [Sun Dec 29 21:28:18 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 21:28:31 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
      [Sun Dec 29 21:29:23 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 21:51:57 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
      [Sun Dec 29 21:51:58 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 21:59:13 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
      /var:
      421M    /var/
      249M    /var/cache
      245M    /var/cache/apt
      170M    /var/cache/apt/archives
      147M    /var/lib
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      765M    /opt/iobroker/iobroker-data/
      741M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 2027)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker8                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : ioBroker8                                -  enabled
      + system.adapter.discovery.0              : discovery             : ioBroker8                                -  enabled
      + system.adapter.email.0                  : email                 : ioBroker8                                -  enabled
      + system.adapter.enigma2.0                : enigma2               : ioBroker8                                -  enabled
        system.adapter.habpanel.0               : habpanel              : ioBroker8                                - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker8                                -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : ioBroker8                                -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : ioBroker8                                -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker8                                -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.tuya.0                   : tuya                  : ioBroker8                                - disabled
      + system.adapter.upnp.0                   : upnp                  : ioBroker8                                -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker8                                -  enabled
      + system.adapter.web.0                    : web                   : ioBroker8                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker8                                -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        13663
      States:         9986
      Hit:2 http://security.debian.org bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6502397    1/init
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6506337    331/master
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6551665    1590/io.mqtt.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6535230    751/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6535225    751/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6535444    783/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6548230    1575/io.web.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6506338    331/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          6505475    1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6505789    1/init
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6505718    87/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6502400    1/init
      udp        0      0 0.0.0.0:42352           0.0.0.0:*                           1001       6545120    1418/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       6545364    1418/io.upnp.0
      udp6       0      0 :::111                  :::*                                0          6505478    1/init
      2024-12-29 22:21:46.815  - info: mqtt.0 (1590) Client [Wassersensor2_WP] subscribes on "Wassersensor2_WP/+/get"  with regex /mqtt\.0\.Wassersensor2_WP\.[^.]*\.get/
      2024-12-29 22:25:16.788  - info: mqtt.0 (1590) Client [Wassersensor2_WP] connection closed: timeout
      2024-12-29 22:26:21.514  - info: mqtt.0 (1590) Client [Wassersensor1] connected with secret 1735507581513_4320
      2024-12-29 22:26:21.519  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set" with regex /Wassersensor1\.[^.]*\.set/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.set/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set" with regex /bekens_n\.[^.]*\.set/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set"  with regex /mqtt\.0\.bekens_n\.[^.]*\.set/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+" with regex /cmnd\.Wassersensor1\.[^\.]*$/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+"  with regex /mqtt\.0\.cmnd\.Wassersensor1\.[^\.]*$/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+" with regex /cmnd\.bekens_n\.[^\.]*$/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+"  with regex /mqtt\.0\.cmnd\.bekens_n\.[^\.]*$/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get" with regex /Wassersensor1\.[^.]*\.get/
      2024-12-29 22:26:21.520  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.get/
      2024-12-29 22:27:41.571  - info: mqtt.0 (1590) Client [Wassersensor1] reconnected. Old secret 1735507581513_4320. New secret 1735507661570_5281
      2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set" with regex /Wassersensor1\.[^.]*\.set/
      2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/set"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.set/
      2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set" with regex /bekens_n\.[^.]*\.set/
      2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "bekens_n/+/set"  with regex /mqtt\.0\.bekens_n\.[^.]*\.set/
      2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+" with regex /cmnd\.Wassersensor1\.[^\.]*$/
      2024-12-29 22:27:41.577  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/Wassersensor1/+"  with regex /mqtt\.0\.cmnd\.Wassersensor1\.[^\.]*$/
      2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+" with regex /cmnd\.bekens_n\.[^\.]*$/
      2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "cmnd/bekens_n/+"  with regex /mqtt\.0\.cmnd\.bekens_n\.[^\.]*$/
      2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get" with regex /Wassersensor1\.[^.]*\.get/
      2024-12-29 22:27:41.578  - info: mqtt.0 (1590) Client [Wassersensor1] subscribes on "Wassersensor1/+/get"  with regex /mqtt\.0\.Wassersensor1\.[^.]*\.get/
      2024-12-29 22:31:11.567  - info: mqtt.0 (1590) Client [Wassersensor1] connection closed: timeout
        Homoran Global Moderator Administrators @io2345 last edited by
        @io2345 mit 2GB RAM wird's schon zu knapp.
          Thomas Braun Most Active @io2345 last edited by
          @io2345 sagte in Backitup Error:
          Mit
          CPU threads: 1
          auch.
          • I
            io2345 @Thomas Braun last edited by io2345
            Hab jetzt mal drei GB und 2 CPU eingestellt, was die Situation aber bestenfalls marginal verbessert. So bin ich eher geneigt anzunehmen, dass Debian 12 der Grund ist. Welches Template habt ihr denn verwendet - ebenfalls Debian 12 oder was anderes? Einfach alle durchprobieren möchte ich jetzt auch nicht unbedingt...
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
            Failed to query system properties: Connection timed out
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             08:42:16 up 3 min,  0 user,  load average: 0.35, 0.41, 0.27
            CPU threads: 2
            iobrokeradmin
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            3.2G        957M        2.0G         86K        279M        2.3G
            Swap:           536M          0B        536M
            Total:          3.8G        957M        2.5G
                     3072 M total memory
                      913 M used memory
                     1009 M active memory
                      119 M inactive memory
                     1891 M free memory
                        0 M buffer memory
                      266 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            top - 08:43:32 up 4 min,  0 user,  load average: 0.12, 0.33, 0.25
            MiB Mem :   3072.0 total,   1890.1 free,    914.9 used,    267.1 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2157.1 avail Mem
            10 loaded units listed.
            *** FILESYSTEM ***
            [Mon Dec 30 08:36:04 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
            [Mon Dec 30 08:36:59 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
            [Mon Dec 30 08:38:47 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
            [Mon Dec 30 08:38:48 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
            /var:
            421M    /var/
            249M    /var/cache
            245M    /var/cache/apt
            147M    /var/lib
            786M    /opt/iobroker/iobroker-data/
            23M     /opt/iobroker/iobroker-data/objects.jsonl
            13M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 272)
            admin:          7.1.5
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        13663
            States:         9996
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7724560    167/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7724563    167/iobroker.js-con
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7724430    331/master
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7720832    1/init
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7728433    515/io.mqtt.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7729441    581/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7724676    342/io.admin.0
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7724431    331/master
            tcp6       0      0 :::111                  :::*                    LISTEN      0          7720834    1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          7725083    1/init
            udp        0      0 0.0.0.0:54961           0.0.0.0:*                           1001       7728536    548/io.upnp.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7725061    88/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7720833    1/init
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7728704    548/io.upnp.0
            udp6       0      0 :::111                  :::*                                0          7720835    1/init
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/set"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.set/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+" with regex /cmnd\.SmartPlug2\.[^\.]*$/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+"  with regex /mqtt\.0\.cmnd\.SmartPlug2\.[^\.]*$/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get" with regex /SmartPlug2\.[^.]*\.get/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.get/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
            2024-12-30 08:39:42.604  - info: web.0 (581) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
            2024-12-30 08:39:42.699  - info: web.0 (581) socket.io server listening on port 8082
            2024-12-30 08:39:42.701  - info: web.0 (581) http server listening on port 8082
            2024-12-30 08:40:55.500  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
            2024-12-30 08:41:00.499  - info: admin.0 (342) <== Disconnect system.user.admin from ::ffff:192.168.0.28 admin
            2024-12-30 08:41:02.730  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
            S Homoran Codierknecht 3 Replies Last reply Reply Quote 0
              Shadowhunter23 @io2345 last edited by
              Läuft bei mir ohne Probleme mir dem Template:
                ist ja auch nur marginal verändert
                4GB ist minimum, 8GB sinnvoll
                4CPU sollten es auch sein
                • I
                  io2345 @Homoran last edited by
                  Somit wissen wir nun, dass es nicht an fehlenden Ressourcen liegt:
                  ```bash
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   10:37:58 up 2 min,  0 user,  load average: 0.33, 0.27, 0.21
                  CPU threads: 4
                  iobrokeradmin
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            8.6G        896M        7.4G         86K        275M        7.7G
                  Swap:           536M          0B        536M
                  Total:          9.1G        896M        8.0G
                           8192 M total memory
                            854 M used memory
                            951 M active memory
                            114 M inactive memory
                           7074 M free memory
                              0 M buffer memory
                            262 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  top - 10:39:13 up 3 min,  0 user,  load average: 0.20, 0.24, 0.20
                  MiB Mem :   8192.0 total,   7072.8 free,    856.6 used,    262.8 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7335.4 avail Mem
                  *** FILESYSTEM ***
                  [Mon Dec 30 10:34:28 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
                  [Mon Dec 30 10:35:26 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
                  /var:
                  421M    /var/
                  249M    /var/cache
                  245M    /var/cache/apt
                  147M    /var/lib
                  793M    /opt/iobroker/iobroker-data/
                  28M     /opt/iobroker/iobroker-data/objects.jsonl
                  15M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 227)
                  admin:          7.1.5
                  javascript:     8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        13663
                  States:         9996
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7969660    331/master
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7972212    167/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7971162    167/iobroker.js-con
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7969436    1/init
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7974525    515/io.mqtt.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7975376    595/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7971236    342/io.admin.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7969661    331/master
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          7970523    1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          7970885    1/init
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7977080    562/io.upnp.0
                  udp        0      0 0.0.0.0:55622           0.0.0.0:*                           1001       7975269    562/io.upnp.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7970942    87/dhclient
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7969437    1/init
                  udp6       0      0 :::111                  :::*                                0          7970456    1/init
                  2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
                  2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
                  2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
                  2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
                  2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
                  2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
                  2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
                  2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
                  2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
                  2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
                  2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set" with regex /SmartPlug3\.[^.]*\.set/
                  2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.set/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+" with regex /cmnd\.SmartPlug3\.[^\.]*$/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+"  with regex /mqtt\.0\.cmnd\.SmartPlug3\.[^\.]*$/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get" with regex /SmartPlug3\.[^.]*\.get/
                  2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.get/
                  2024-12-30 10:36:18.805  - info: viessmannapi.0 (580) 1 installations found.
                  2024-12-30 10:36:19.776  - info: host.ioBroker8 instance system.adapter.web.0 in version "6.2.5" started with pid 595
                  2024-12-30 10:36:20.511  - info: web.0 (595) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
                  2024-12-30 10:36:20.605  - info: web.0 (595) socket.io server listening on port 8082
                  2024-12-30 10:36:20.610  - info: web.0 (595) http server listening on port 8082
                  Dann bleiben wir halt auf Debian 11. Der Container ist ja nicht aus dem Internet erreichbar (der Host auch nicht)
                    Ist zwar ein Schritt weiter, hilft dann aber leider nicht.
                    Nur mal zur Klärung:
                    Was hayt du denn genau gemacht?
                    Die letzten Zeilen sehen aus, als ob der Restore noch nicht fertig ist.
                    • I
                      io2345 @Homoran last edited by io2345
                      Danke für's Kümmern.
                      Ich habe bei beiden Containern (Debian 11 und 12) das Gleiche gemacht: Die Anleitung für die CT-Installation habe ich von hier: Proxmox Installation. Ungefähr nach dem ersten Drittel kommt der Abschnitt "Erstellen eines Linux Containers (LXC) + ioBroker Installation im Anschluß".
                      Dann die Einstellungen für den NAS-Share im BackItUp-Plugin eingestellt und darüber das identische Backup wiedereingespielt.
                        Die Liste ist auch deutlich zu umfangreich. Die müssen auch bei einem Container starten..
                          damit ist der Restore noch lange nicht fertig.
                          Srlbst wenn in der Basis nicht der Wurm drin wöre, würde jetzt erst begonnen alle Pakete für das neue Systrm passend neu zu bauen.
                          Das dauert.
                          • I
                            Richtig, aber da muss ich ja manuell nichts mehr machen. Hat gefühlt etwa fünfzehn Minuten gedauert, bis die Pakete geladen, installiert und die Adapter wieder drin waren. Gestartet sind die hinzugefügten Adapter-Instanzen übrigens nicht von alleine, die musste ich manuell starten. War aber bei dem Debian11-CT genauso.
                              aber du solltest in der Zeit auch nichts machen!
                              das kann man konfigurieren.
                              Ist aber nicht grundlos so.
                              Du kannst so noch die Einstellungen auf neue Gegebenheiten anpassen.
                              • Codierknecht
                                Codierknecht Developer Most Active @io2345 last edited by
                                Genau das. Läuft wie geschnitten Brot.
                                65
                                6169
