    4. Backitup Error
    Backitup Error
      Thomas Braun Most Active @io2345 last edited by
      @io2345 sagte in Backitup Error:
      Mit
      CPU threads: 1
      auch.
      • I
        io2345 @Thomas Braun last edited by io2345
        Hab jetzt mal drei GB und 2 CPU eingestellt, was die Situation aber bestenfalls marginal verbessert. So bin ich eher geneigt anzunehmen, dass Debian 12 der Grund ist. Welches Template habt ihr denn verwendet - ebenfalls Debian 12 oder was anderes? Einfach alle durchprobieren möchte ich jetzt auch nicht unbedingt...
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
        Failed to query system properties: Connection timed out
        OS is similar to:
        model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         08:42:16 up 3 min,  0 user,  load average: 0.35, 0.41, 0.27
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
        *** TIME AND TIMEZONES ***
        Failed to query server: Connection timed out
        Failed to parse bus message: Connection timed out
        *** Users and Groups ***
        User that called 'iob diag':
        iobrokeradmin
        HOME=/home/iobrokeradmin
        GROUPS=iobrokeradmin sudo users iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            3.2G        957M        2.0G         86K        279M        2.3G
        Swap:           536M          0B        536M
        Total:          3.8G        957M        2.5G
        Active iob-Instances:   14
                 3072 M total memory
                  913 M used memory
                 1009 M active memory
                  119 M inactive memory
                 1891 M free memory
                    0 M buffer memory
                  266 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        top - 08:43:32 up 4 min,  0 user,  load average: 0.12, 0.33, 0.25
        Tasks:  35 total,   1 running,  34 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3072.0 total,   1890.1 free,    914.9 used,    267.1 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2157.1 avail Mem
        *** FAILED SERVICES ***
          UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
        * nftables.service                   loaded failed failed nftables
        * systemd-hostnamed.service          loaded failed failed Hostname Service
        * systemd-logind.service             loaded failed failed User Login Management
        * systemd-networkd.service           loaded failed failed Network Configuration
        * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
        * systemd-sysusers.service           loaded failed failed Create System Users
        * systemd-timedated.service          loaded failed failed Time & Date Service
        * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
        * systemd-tmpfiles-setup.service     loaded failed failed Create System Files and Directories
        * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        10 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type   Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--102--disk--0 ext4   7.8G  4.0G  3.5G  54% /
        none                             tmpfs  492K  4.0K  488K   1% /dev
        tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
        tmpfs                            tmpfs  2.4G   80K  2.4G   1% /run
        tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
        [Fri Dec 27 17:47:17 2024] EXT4-fs (dm-1): mounted filesystem b474fcca-8614-4935-abf2-ede52e720980 ro with ordered data mode. Quota mode: none.
        [Fri Dec 27 17:47:19 2024] EXT4-fs (dm-1): re-mounted b474fcca-8614-4935-abf2-ede52e720980 r/w. Quota mode: none.
        [Fri Dec 27 17:47:38 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 17:47:42 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 17:47:46 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 17:49:01 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
        [Fri Dec 27 17:49:02 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 18:09:03 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 18:09:19 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Fri Dec 27 18:12:24 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 18:15:55 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Fri Dec 27 18:15:56 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): write access unavailable, skipping orphan cleanup
        [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c ro without journal. Quota mode: none.
        [Fri Dec 27 18:31:42 2024] EXT4-fs (dm-11): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
        [Fri Dec 27 18:44:42 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
        [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
        [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
        [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Fri Dec 27 23:44:56 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
        [Fri Dec 27 23:45:17 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
        [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
        [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
        [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 14:56:32 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
        [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
        [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Sun Dec 29 15:14:23 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 15:30:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Sun Dec 29 15:30:25 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 15:39:00 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 15:40:42 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
        [Sun Dec 29 15:52:08 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 15:52:30 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
        [Sun Dec 29 15:52:52 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
        [Sun Dec 29 15:52:56 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 16:41:57 2024] EXT4-fs (dm-6): unmounting filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336.
        [Sun Dec 29 16:41:58 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 21:13:10 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 21:13:18 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
        [Sun Dec 29 21:28:18 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 21:28:31 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
        [Sun Dec 29 21:29:23 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 21:51:57 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
        [Sun Dec 29 21:51:58 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
        [Sun Dec 29 21:59:13 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
        [Mon Dec 30 08:36:04 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
        [Mon Dec 30 08:36:59 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
        [Mon Dec 30 08:38:47 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
        [Mon Dec 30 08:38:48 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
        /var:
        421M    /var/
        249M    /var/cache
        245M    /var/cache/apt
        170M    /var/cache/apt/archives
        147M    /var/lib
              Users in the 'systemd-journal' group can see all messages. Pass -q to
              turn off this notice.
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        786M    /opt/iobroker/iobroker-data/
        741M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        23M     /opt/iobroker/iobroker-data/objects.jsonl
        13M     /opt/iobroker/iobroker-data/states.jsonl
        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 272)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioBroker8                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : ioBroker8                                -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker8                                -  enabled
        + system.adapter.email.0                  : email                 : ioBroker8                                -  enabled
        + system.adapter.enigma2.0                : enigma2               : ioBroker8                                -  enabled
          system.adapter.habpanel.0               : habpanel              : ioBroker8                                - disabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker8                                -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : ioBroker8                                -  enabled
        + system.adapter.lg-thinq.0               : lg-thinq              : ioBroker8                                -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker8                                -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.tuya.0                   : tuya                  : ioBroker8                                - disabled
        + system.adapter.upnp.0                   : upnp                  : ioBroker8                                -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker8                                -  enabled
        + system.adapter.web.0                    : web                   : ioBroker8                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker8                                -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        13663
        States:         9996
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7724560    167/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7724563    167/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7724430    331/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7720832    1/init
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7728433    515/io.mqtt.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7729441    581/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7724676    342/io.admin.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7724431    331/master
        tcp6       0      0 :::111                  :::*                    LISTEN      0          7720834    1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          7725083    1/init
        udp        0      0 0.0.0.0:54961           0.0.0.0:*                           1001       7728536    548/io.upnp.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7725061    88/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7720833    1/init
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7728704    548/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          7720835    1/init
        2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/set"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.set/
        2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
        2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
        2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+" with regex /cmnd\.SmartPlug2\.[^\.]*$/
        2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+"  with regex /mqtt\.0\.cmnd\.SmartPlug2\.[^\.]*$/
        2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
        2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
        2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get" with regex /SmartPlug2\.[^.]*\.get/
        2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.get/
        2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
        2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
        2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
        2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
        2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
        2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
        2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
        2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
        2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
        2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
        2024-12-30 08:39:42.604  - info: web.0 (581) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
        2024-12-30 08:39:42.699  - info: web.0 (581) socket.io server listening on port 8082
        2024-12-30 08:39:42.701  - info: web.0 (581) http server listening on port 8082
        2024-12-30 08:40:55.500  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
        2024-12-30 08:41:00.499  - info: admin.0 (342) <== Disconnect system.user.admin from ::ffff:192.168.0.28 admin
        2024-12-30 08:41:02.730  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
        S Homoran Codierknecht 3 Replies Last reply Reply Quote 0
          Shadowhunter23 @io2345 last edited by
          Läuft bei mir ohne Probleme mir dem Template:
            Homoran Global Moderator Administrators @io2345 last edited by
            ist ja auch nur marginal verändert
            4GB ist minimum, 8GB sinnvoll
            4CPU sollten es auch sein
            • I
              io2345 @Homoran last edited by
              Somit wissen wir nun, dass es nicht an fehlenden Ressourcen liegt:
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
              Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               10:37:58 up 2 min,  0 user,  load average: 0.33, 0.27, 0.21
              CPU threads: 4
              iobrokeradmin
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            8.6G        896M        7.4G         86K        275M        7.7G
              Swap:           536M          0B        536M
              Total:          9.1G        896M        8.0G
                       8192 M total memory
                        854 M used memory
                        951 M active memory
                        114 M inactive memory
                       7074 M free memory
                          0 M buffer memory
                        262 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              top - 10:39:13 up 3 min,  0 user,  load average: 0.20, 0.24, 0.20
              MiB Mem :   8192.0 total,   7072.8 free,    856.6 used,    262.8 buff/cache
              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7335.4 avail Mem
              *** FILESYSTEM ***
              [Mon Dec 30 10:34:28 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
              [Mon Dec 30 10:35:26 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
              /var:
              421M    /var/
              249M    /var/cache
              245M    /var/cache/apt
              147M    /var/lib
              793M    /opt/iobroker/iobroker-data/
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              15M     /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 227)
              admin:          7.1.5
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        13663
              States:         9996
              Pending Updates: 0
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7969660    331/master
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7972212    167/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7971162    167/iobroker.js-con
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7969436    1/init
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7974525    515/io.mqtt.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7975376    595/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7971236    342/io.admin.0
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7969661    331/master
              tcp6       0      0 :::22                   :::*                    LISTEN      0          7970523    1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          7970885    1/init
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7977080    562/io.upnp.0
              udp        0      0 0.0.0.0:55622           0.0.0.0:*                           1001       7975269    562/io.upnp.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7970942    87/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7969437    1/init
              udp6       0      0 :::111                  :::*                                0          7970456    1/init
              2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
              2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
              2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
              2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
              2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
              2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
              2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
              2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
              2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
              2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
              2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set" with regex /SmartPlug3\.[^.]*\.set/
              2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.set/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+" with regex /cmnd\.SmartPlug3\.[^\.]*$/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+"  with regex /mqtt\.0\.cmnd\.SmartPlug3\.[^\.]*$/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get" with regex /SmartPlug3\.[^.]*\.get/
              2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.get/
              2024-12-30 10:36:18.805  - info: viessmannapi.0 (580) 1 installations found.
              2024-12-30 10:36:19.776  - info: host.ioBroker8 instance system.adapter.web.0 in version "6.2.5" started with pid 595
              2024-12-30 10:36:20.511  - info: web.0 (595) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
              2024-12-30 10:36:20.605  - info: web.0 (595) socket.io server listening on port 8082
              2024-12-30 10:36:20.610  - info: web.0 (595) http server listening on port 8082
              Dann bleiben wir halt auf Debian 11. Der Container ist ja nicht aus dem Internet erreichbar (der Host auch nicht)
                Ist zwar ein Schritt weiter, hilft dann aber leider nicht.
                Nur mal zur Klärung:
                Was hayt du denn genau gemacht?
                Die letzten Zeilen sehen aus, als ob der Restore noch nicht fertig ist.
                • I
                  io2345 @Homoran last edited by io2345
                  Danke für's Kümmern.
                  Ich habe bei beiden Containern (Debian 11 und 12) das Gleiche gemacht: Die Anleitung für die CT-Installation habe ich von hier: Proxmox Installation. Ungefähr nach dem ersten Drittel kommt der Abschnitt "Erstellen eines Linux Containers (LXC) + ioBroker Installation im Anschluß".
                  Dann die Einstellungen für den NAS-Share im BackItUp-Plugin eingestellt und darüber das identische Backup wiedereingespielt.
                    Die Liste ist auch deutlich zu umfangreich. Die müssen auch bei einem Container starten..
                      damit ist der Restore noch lange nicht fertig.
                      Srlbst wenn in der Basis nicht der Wurm drin wöre, würde jetzt erst begonnen alle Pakete für das neue Systrm passend neu zu bauen.
                      Das dauert.
                      • I
                        Richtig, aber da muss ich ja manuell nichts mehr machen. Hat gefühlt etwa fünfzehn Minuten gedauert, bis die Pakete geladen, installiert und die Adapter wieder drin waren. Gestartet sind die hinzugefügten Adapter-Instanzen übrigens nicht von alleine, die musste ich manuell starten. War aber bei dem Debian11-CT genauso.
                          aber du solltest in der Zeit auch nichts machen!
                          das kann man konfigurieren.
                          Ist aber nicht grundlos so.
                          Du kannst so noch die Einstellungen auf neue Gegebenheiten anpassen.
                          • Codierknecht
                            Codierknecht Developer Most Active @io2345 last edited by
                            Genau das. Läuft wie geschnitten Brot.
                            65
                            6169
