    4. Test Adapter Controme v0.5.x
    • N
      nobbiman @Thomas Braun last edited by
      @thomas-braun Aber wie ich schon oben sagte
      ... scheue aber die komplette Neuinstallation mit ioBroker, Grafana und Influx, da ich noch nicht erkundet habe, wie ich meine Daten der Programme sichern muss; für ioBroker habe ich Backups ...
      Ich werde das recherchieren oder hast du einen Tipp zur Hand?
      • mcm1957
        mcm1957 @nobbiman last edited by mcm1957
        @nobbiman said in Test Adapter Controme v0.5.x:
        So, nachdem ich nun meinen ioBroker wieder zum Laufen bekommen habe, hier das Fehlerprotokoll des nicht funktionierenden Controme-Adapters:
        controme.0
        	2024-12-30 10:53:25.341	error	undefined is not a valid state value
        controme.0
        	2024-12-30 10:53:25.341	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/maybeCallback.js:36:13) at Controme._setStateChanged (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:5446:48) at Controme.setStateChanged (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:5420:17) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1581:18 at new Promise (<anonymous>) at Controme.setStateChangedAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1579:12) at Controme._updateRoom (/opt/iobroker/node_modules/iobroker.controme/main.js:1018:28) at Controme._processTempsAPIforUpdate (/opt/iobroker/node_modules/iobroker.controme/main.js:853:30) at Controme._pollRoomTemps (/opt/iobroker/node_modules/iobroker.controme/main.js:877:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        controme.0
        	2024-12-30 10:53:25.340	error	unhandled promise rejection: undefined is not a valid state value
        controme.0
        	2024-12-30 10:53:25.340	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Kann das Problem jemand für mich herauslesen?
        Das ist ein Fall für den Maintainer des Adapters. Da stimmt was im Code nicht. Mach ev. ein Issue beim Adapter auf.
          Thomas Braun Most Active @nobbiman last edited by
          @nobbiman
          Soweit hatte ich schon gar nicht mehr gelesen.
          Bring das auf eine stabile Basis.
          Und nodejs wird NICHT per nvm installiert. Wo hast du den Blödsinn her?
          Versuch es per
          iob nodejs-update 20
          hinzubiegen.
            @nobbiman sagte in Test Adapter Controme v0.5.x:
            Per Backitup-Adapter.
            • N
              @thomas-braun sagte in Test Adapter Controme v0.5.x:
              @nobbiman
              Versuch es per
              hinzubiegen.
              Hab ich gemacht, Problem mit dem Controme-Adapter ist aber nicht beseitigt.
                Hab ich gemacht,
                Mit welchem Resultat?
                iob diag
                nochmal posten.
                • N
                  nobbiman @Thomas Braun last edited by nobbiman
                  @thomas-braun reicht das summary?
                  ```bash
                                          v.2024-10-19
                     Static hostname: RasPi-ioBroker
                           Icon name: computer
                    Operating System: Debian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.6.67-v8+
                        Architecture: arm64
                  Installation:           native
                  Kernel:                 aarch64
                  Userland:               64 bit
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  Display-Server:         false
                  Boot Target:            multi-user.target
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:
                  /usr/bin/nodejs         v20.18.1
                  /usr/bin/node           v20.18.1
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.4
                  Recommended versions are nodejs 20.18.1 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Mem:            3.8G        2.0G        488M        0.0K        1.3G        1.7G
                  Swap:           2.1G        246M        1.9G
                  Total:          5.9G        2.3G        2.4G
                  Active iob-Instances:   20
                  Upgrade policy: none
                  ioBroker Core:          js-controller           7.0.6
                                          admin                   7.1.5
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : RasPi-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.web.0                    : web                   : RasPi-ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects:                23107
                  States:                 19835
                  Size of iob-Database:
                  43M     /opt/iobroker/iobroker-data/objects.jsonl
                  26M     /opt/iobroker/iobroker-data/states.jsonl
                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                  Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                    @nobbiman
                    Nein, die Langfassung. Du hastt da auch noch einen ganzen Zoo an Paketquellen drin, die nicht zum bullseye passen.
                    • mcm1957
                      @nobbiman
                      Siehe:
                      https://forum.iobroker.net/topic/78355/test-adapter-controme-v0-5-x/13
                      • N
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** TIME AND TIMEZONES ***
                                       Local time: Mon 2024-12-30 11:34:38 CET
                                   Universal time: Mon 2024-12-30 10:34:38 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        pi
                        JAVA_HOME=/usr/lib/jvm/java-17-openjdk-arm64
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                        *** DISPLAY-SERVER SETUP ***
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            3.8G        2.1G        437M        0.0K        1.3G        1.6G
                        Swap:           2.1G        245M        1.9G
                        Total:          5.9G        2.3G        2.3G
                                 3790 M total memory
                                 2085 M used memory
                                 1823 M active memory
                                 1289 M inactive memory
                                  437 M free memory
                                  145 M buffer memory
                                 1121 M swap cache
                                 2147 M total swap
                                  245 M used swap
                                 1902 M free swap
                        top - 11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
                        Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 15.2 us,  4.5 sy,  0.0 ni, 78.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
                        MiB Mem :   3791.0 total,    436.7 free,   2086.9 used,   1267.3 buff/cache
                        MiB Swap:   2148.0 total,   1902.0 free,    246.0 used.   1620.3 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        /dev/root      ext4      459G   16G  425G   4% /
                        devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                        tmpfs          tmpfs     759M  1.2M  758M   1% /run
                        /dev/sda1      vfat      255M   33M  223M  13% /boot
                        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                        [Mon Dec 30 09:38:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A4:AD:F2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=94303a9e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): write access will be enabled during recovery
                        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): recovery complete
                        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): mounted filesystem d98b1a68-4ff7-4331-86d3-77c5d911b429 ro with ordered data mode. Quota mode: none.
                        [Mon Dec 30 09:38:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                        [Mon Dec 30 09:38:35 2024] EXT4-fs (sda2): re-mounted d98b1a68-4ff7-4331-86d3-77c5d911b429 r/w. Quota mode: none.
                        Show mounted filesystems:
                        TARGET  SOURCE    FSTYPE OPTIONS
                        /       /dev/sda2 ext4   rw,noatime
                        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        3.0G    /var/
                        1.6G    /var/log
                        1.3G    /var/log/journal/2d06defc2eb445c9afef1cfd904ac913
                        1.2G    /var/lib
                        Archived and active journals take up 1.2G in the file system.
                        /opt/iobroker/backups:
                        940M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        961M    /opt/iobroker/iobroker-data/
                        781M    /opt/iobroker/iobroker-data/files
                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        28M     /opt/iobroker/iobroker-data/states.jsonl
                        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        *** NodeJS-Installation ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Installed: 20.18.1-1nodesource1
                          Candidate: 20.18.1-1nodesource1
                          Version table:
                         *** 20.18.1-1nodesource1 600
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                100 /var/lib/dpkg/status
                             20.18.0-1nodesource1 600
                             20.17.0-1nodesource1 600
                             20.16.0-1nodesource1 600
                             20.15.1-1nodesource1 600
                             20.15.0-1nodesource1 600
                             20.14.0-1nodesource1 600
                             20.13.1-1nodesource1 600
                             20.13.0-1nodesource1 600
                             20.12.2-1nodesource1 600
                             20.12.1-1nodesource1 600
                             20.12.0-1nodesource1 600
                             20.11.1-1nodesource1 600
                             20.11.0-1nodesource1 600
                             20.10.0-1nodesource1 600
                             20.9.0-1nodesource1 600
                             20.8.1-1nodesource1 600
                             20.8.0-1nodesource1 600
                             20.7.0-1nodesource1 600
                             20.6.1-1nodesource1 600
                             20.6.0-1nodesource1 600
                             20.5.1-1nodesource1 600
                             20.5.0-1nodesource1 600
                             20.4.0-1nodesource1 600
                             20.3.1-1nodesource1 600
                             20.3.0-1nodesource1 600
                             20.2.0-1nodesource1 600
                             20.1.0-1nodesource1 600
                             20.0.0-1nodesource1 600
                             12.22.12~dfsg-1~deb11u5 500
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        RasPi-ioBroker      RasPi-ioBroker (version: 7.0.6, hostname: RasPi-ioBroker, alive, uptime: 830)
                        Core adapters versions
                        js-controller:  7.0.6
                        admin:          7.1.5
                        javascript:     8.8.3
                        nodejs modules from github:     1
                        +-- iobroker.controme@0.5.3 (git+ssh://git@github.com/MadErstam/ioBroker.controme.git#a40bf461eadee0352492c1bf151fcb288f890fe2)
                        Adapter State
                        + system.adapter.backitup.0               : backitup              : RasPi-ioBroker                           -  enabled
                          system.adapter.controme.0               : controme              : RasPi-ioBroker                           -  enabled
                        + system.adapter.discovery.0              : discovery             : RasPi-ioBroker                           -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPi-ioBroker                           -  enabled
                        + system.adapter.fhem.0                   : fhem                  : RasPi-ioBroker                           -  enabled, port: 7072
                        + system.adapter.fritzdect.0              : fritzdect             : RasPi-ioBroker                           -  enabled
                        + system.adapter.growatt.0                : growatt               : RasPi-ioBroker                           -  enabled
                        + system.adapter.history.0                : history               : RasPi-ioBroker                           -  enabled
                        + system.adapter.influxdb.0               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
                        + system.adapter.influxdb.1               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
                        + system.adapter.javascript.0             : javascript            : RasPi-ioBroker                           -  enabled
                          system.adapter.maxcul.0                 : maxcul                : RasPi-ioBroker                           - disabled
                        + system.adapter.modbus.0                 : modbus                : RasPi-ioBroker                           -  enabled
                          system.adapter.mqtt-client.0            : mqtt-client           : RasPi-ioBroker                           - disabled, port: 1883
                        + system.adapter.mqtt.0                   : mqtt                  : RasPi-ioBroker                           -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.powerfox2.0              : powerfox2             : RasPi-ioBroker                           -  enabled
                          system.adapter.powerfox2.1              : powerfox2             : RasPi-ioBroker                           -  enabled
                        + system.adapter.pvforecast.0             : pvforecast            : RasPi-ioBroker                           -  enabled
                        + system.adapter.pvforecast.1             : pvforecast            : RasPi-ioBroker                           -  enabled
                        + system.adapter.rpi2.0                   : rpi2                  : RasPi-ioBroker                           -  enabled
                        + system.adapter.shelly.0                 : shelly                : RasPi-ioBroker                           -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.viessmannapi.0           : viessmannapi          : RasPi-ioBroker                           -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi-ioBroker                           -  enabled
                          system.adapter.vis.0                    : vis                   : RasPi-ioBroker                           -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                        Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
                        Adapter    "fhem"         : 3.0.0    , installed 3.0.0
                        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                        Adapter    "growatt"      : 3.3.1    , installed 3.3.1
                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                        Controller "js-controller": 7.0.6    , installed 7.0.6
                        Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
                        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                        Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                        Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
                        Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
                        Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                        Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
                        Adapter    "web"          : 6.2.5    , installed 6.3.0
                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                        Objects and States
                        Objects:        23107
                        States:         19835
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease
                        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:6 https://apt.grafana.com stable InRelease
                        Hit:7 https://repos.influxdata.com/debian stable InRelease
                        Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Hit:9 https://apt.glennr.nl/repo bullseye InRelease
                        Hit:10 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/7.0 InRelease
                        Get:11 https://packages.adoptium.net/artifactory/deb bullseye InRelease [7517 B]
                        Fetched 7517 B in 2s (3034 B/s)
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       96463      20066/io.mqtt.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       94929      20027/io.shelly.0
                        tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      117        6468       1169/bin/mongod
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5527       534/cupsd
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2496       603/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       95636      19881/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       95631      19881/iobroker.js-c
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        7445       541/influxd
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       95058      20216/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96285      19901/io.admin.0
                        tcp6       0      0 :::8080                 :::*                    LISTEN      117        6029       599/java
                        tcp6       0      0 :::3000                 :::*                    LISTEN      116        7528       1063/grafana
                        tcp6       0      0 :::6789                 :::*                    LISTEN      117        7630       599/java
                        tcp6       0      0 :::8843                 :::*                    LISTEN      117        6032       599/java
                        tcp6       0      0 :::8880                 :::*                    LISTEN      117        6030       599/java
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5526       534/cupsd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          2498       603/sshd: /usr/sbin
                        tcp6       0      0 :::8443                 :::*                    LISTEN      117        6031       599/java
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2427       384/avahi-daemon: r
                        udp        0      0 0.0.0.0:40839           0.0.0.0:*                           108        2429       384/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2530       483/dhcpcd: [master
                        udp6       0      0 :::5353                 :::*                                108        2428       384/avahi-daemon: r
                        udp6       0      0 :::5514                 :::*                                117        7635       599/java
                        udp6       0      0 :::3478                 :::*                                117        7626       599/java
                        udp6       0      0 :::44558                :::*                                108        2430       384/avahi-daemon: r
                        udp6       0      0 192.168.2.40:42712      :::*                                117        7638       599/java
                        udp6       0      0 :::10001                :::*                                117        7639       599/java
                        udp6       0      0 :::546                  :::*                                0          2546       483/dhcpcd: [master
                        2024-12-30 11:34:28.120  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 23451 terminated with code 0 (NO_ERROR)
                        2024-12-30 11:34:50.031  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 23772
                        2024-12-30 11:34:52.700  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
                        2024-12-30 11:34:52.717  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
                        2024-12-30 11:34:52.762  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                        2024-12-30 11:34:52.791  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
                        2024-12-30 11:34:52.815  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                        2024-12-30 11:34:52.828  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
                        2024-12-30 11:34:53.400  - info: powerfox2.1 (23772) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                        2024-12-30 11:34:53.891  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11206.707 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11206.707
                        2024-12-30 11:34:53.916  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.684 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.684
                        2024-12-30 11:34:54.074  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3725.902 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3725.902
                        2024-12-30 11:34:54.103  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11943.326 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11943.326
                        2024-12-30 11:34:54.115  - info: powerfox2.1 (23772) Terminated (NO_ERROR): Without reason
                        2024-12-30 11:34:54.647  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 having pid 23772 terminated with code 0 (NO_ERROR)
                        2024-12-30 11:35:22.631  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
                        2024-12-30 11:35:22.656  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
                        2024-12-30 11:35:22.694  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                        2024-12-30 11:35:22.810  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
                        2024-12-30 11:35:22.822  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                        2024-12-30 11:35:22.835  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
                        2024-12-30 11:35:24.034  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 25097
                        2024-12-30 11:35:26.970  - info: powerfox2.0 (25097) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                        2024-12-30 11:35:28.040  - info: powerfox2.0 (25097) Terminated (NO_ERROR): Without reason
                        2024-12-30 11:35:28.584  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 25097 terminated with code 0 (NO_ERROR)
                        • N
                          nobbiman @mcm1957 last edited by
                          @mcm1957 Ja, ich werde ein Issue aufmachen, warte im Moment noch ab, was sich noch bei @Thomas-Braun ergibt
                          • N
                            @thomas-braun Backitup sichert auch Influxx-DB und Grafana-Einstellungen und Grafiken?
                              Da hat es wohl Einschläge im Dateisystem gegeben. Fahr die Kister IMMER ordentlich herunter, bevor du die vom Strom nimmst.
                              Zu controme: Installier den NICHT aus dem GitHub sondern aus einem ioBroker-Repo, sofern da vorhanden.
                              • system.adapter.influxdb.0 : influxdb : RasPi-ioBroker - enabled, port: 8086
                              • system.adapter.influxdb.1 : influxdb : RasPi-ioBroker - enabled, port: 8086
                              dürfte so auch falsch sein.
                              Die Quellen würde ich mir anschauen, warum die überhaupt angelegt wurden und ob es da nicht besser passende für dein Release gibt:
                              Wenn du es einstellst, ja.
                              • N
                                .. und genau da liegt mein Problem, wenn ich als Laie mit einem Profi chatte, ich verstehe nur Bahnhof und bin z.B. nicht in der Lage zu checken, ob die genannten "Hits" 4,9,10,11 dort hin gehören oder nicht.
                                Meine einzige Möglichkeit ist die einer kompletten und sauberen Neuinstalltion unter Bookworm.
                                Ich habe mich mal mit dem Backitup befasst und ein Backup durchgeführt. Dort stoße ich auf die Fehlermeldung
                                13:30:10.448
                                INFO
                                gui
                                Backup gestartet ...
                                13:30:10.516
                                DEBUG
                                mount
                                Wake on LAN wait 180 Seconds for NAS!
                                13:30:10.528
                                DEBUG
                                mount
                                Wake on LAN MAC-Address: 00:11:32:37:8C:5C
                                13:30:10.531
                                DEBUG
                                mount
                                mount activ... umount is started before mount!!
                                13:30:10.578
                                DEBUG
                                mount
                                umount successfully completed
                                [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
                                13:33:10.487
                                DEBUG
                                mount
                                cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.20/homes/backup/ioBroker/ /opt/iobroker/backups"
                                13:33:10.749
                                DEBUG
                                mount
                                13:33:10.752
                                DEBUG
                                mount
                                done
                                [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"06:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"timestamp":1735561810465,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.2.40","port":8086,"dbversion":"2.x","token":"60a9d6d04cd505C","protocol":"https","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"PoweroptiPatrickhisory","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.2.40","port":"3000","protocol":"https","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1735561810465}
                                13:33:20.052
                                DEBUG
                                iobroker
                                host.RasPi-ioBroker 23099 objects saved
                                13:33:21.952
                                DEBUG
                                iobroker
                                host.RasPi-ioBroker 19811 states saved
                                host.RasPi-ioBroker Validating backup ...
                                13:33:21.961
                                DEBUG
                                iobroker
                                host.RasPi-ioBroker "config.json" is valid
                                13:33:21.970
                                DEBUG
                                iobroker
                                host.RasPi-ioBroker "objects.jsonl" exists
                                13:33:22.016
                                DEBUG
                                iobroker
                                host.RasPi-ioBroker "states.jsonl" exists
                                13:33:23.052
                                DEBUG
                                iobroker
                                host.RasPi-ioBroker JSONL lines are valid
                                13:33:23.076
                                DEBUG
                                iobroker
                                host.RasPi-ioBroker The backup is valid!
                                13:33:26.634
                                DEBUG
                                iobroker
                                Backup created: /opt/iobroker/backups/iobroker_2024_12_30-13_33_10_backupiobroker.tar.gz
                                13:33:26.743
                                DEBUG
                                iobroker
                                This backup can only be restored with js-controller version 7.0 or higher
                                13:33:27.670
                                DEBUG
                                iobroker
                                done
                                13:33:27.857
                                DEBUG
                                influxDB
                                InfluxDB-Backup started ...
                                13:33:27.863
                                DEBUG
                                influxDB
                                Start InfluxDB Backup ...
                                13:33:27.864
                                DEBUG
                                influxDB
                                InfluxDB Backup tmp directory created
                                13:33:27.871
                                DEBUG
                                influxDB
                                Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                                13:33:27.910
                                DEBUG
                                influxDB
                                InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker" successfully deleted
                                [DEBUG] [influxDB] -
                                13:33:27.933
                                ERROR
                                influxDB
                                Error: Command failed: influx backup --bucket iobroker --host https://192.168.2.40:8086 --skip-verify -t 60a9d6d04cd505C "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                                Error: API compatibility check failed: Get "https://192.168.2.40:8086/health": http: server gave HTTP response to HTTPS client
                                13:33:27.938
                                DEBUG
                                influxDB
                                InfluxDB-Backup for is finish
                                13:33:27.944
                                DEBUG
                                influxDB
                                done
                                13:33:28.663
                                ERROR
                                historyDB
                                BackItUp cannot found source "undefined" for compress!
                                Leider kann ich in den Logdaten nicht sehen, ob alle Daten, also auch die von Grafana, gesichert wurden.
                                Bevor das nicht klar ist, wede ich keine KOmplettinstallation durchführen.
                                  Du hast sie aber als Admin von dem System angelegt. Dann musst du also auch wissen, warum.
                                  • N
                                    Das mag sein, ändert an meiner Aussage aber nichts, da mir die Installation nicht mehr bewußt ist. Vielleicht gehe ich mit meinem System auch nicht so sorgsam um wie du!
                                      @nobbiman
                                      Wenn du nicht weißt, warum die da sind brauchst du sie offenbar ja nicht.
                                      • N
                                        @thomas-braun So wollte ich auch an die Sache gehen, die sich m.E. aber mit einer Neuaufsetzung des Systems ohnehin erledigt hätte, in der Annahme, dass die genannten Bestandteile kein "Beifang" der Standardinstallation und der gelisteten Adapter sind.
                                        Kannst du denn etwas zur Backitup-Fehlermeldung beitragen, damit ich die Neuinstallation angehen kann?
                                          Deutet darauf hin, dass du da mit unterschiedlichen Protokollen hantierst.
                                          N 2 Replies Last reply Reply Quote 0
                                          • N
                                            @thomas-braun OK, Danke, dann gehe ich die Neuinstallation im neuen Jahr mal an.
                                            31.7k
                                            79.8k
                                            2439
