    4. Test Adapter Controme v0.5.x
      Thomas Braun Most Active @nobbiman last edited by
      @nobbiman sagte in Test Adapter Controme v0.5.x:
      Hab ich gemacht,
      Mit welchem Resultat?
      iob diag
      nochmal posten.
      • N
        nobbiman @Thomas Braun last edited by nobbiman
        @thomas-braun reicht das summary?
        ```bash
                                v.2024-10-19
           Static hostname: RasPi-ioBroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.6.67-v8+
              Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        Recommended versions are nodejs 20.18.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:            3.8G        2.0G        488M        0.0K        1.3G        1.7G
        Swap:           2.1G        246M        1.9G
        Total:          5.9G        2.3G        2.4G
        Active iob-Instances:   20
        Upgrade policy: none
        ioBroker Core:          js-controller           7.0.6
                                admin                   7.1.5
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : RasPi-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : RasPi-ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                23107
        States:                 19835
        Size of iob-Database:
        43M     /opt/iobroker/iobroker-data/objects.jsonl
        26M     /opt/iobroker/iobroker-data/states.jsonl
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
          @nobbiman
          Nein, die Langfassung. Du hastt da auch noch einen ganzen Zoo an Paketquellen drin, die nicht zum bullseye passen.
          • mcm1957
            mcm1957 @nobbiman last edited by
            @nobbiman
            Siehe:
            https://forum.iobroker.net/topic/78355/test-adapter-controme-v0-5-x/13
            • N
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Mon 2024-12-30 11:34:38 CET
                         Universal time: Mon 2024-12-30 10:34:38 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              JAVA_HOME=/usr/lib/jvm/java-17-openjdk-arm64
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        2.1G        437M        0.0K        1.3G        1.6G
              Swap:           2.1G        245M        1.9G
              Total:          5.9G        2.3G        2.3G
                       3790 M total memory
                       2085 M used memory
                       1823 M active memory
                       1289 M inactive memory
                        437 M free memory
                        145 M buffer memory
                       1121 M swap cache
                       2147 M total swap
                        245 M used swap
                       1902 M free swap
              top - 11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
              Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 15.2 us,  4.5 sy,  0.0 ni, 78.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
              MiB Mem :   3791.0 total,    436.7 free,   2086.9 used,   1267.3 buff/cache
              MiB Swap:   2148.0 total,   1902.0 free,    246.0 used.   1620.3 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              /dev/root      ext4      459G   16G  425G   4% /
              devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  1.2M  758M   1% /run
              /dev/sda1      vfat      255M   33M  223M  13% /boot
              tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
              [Mon Dec 30 09:38:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A4:AD:F2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=94303a9e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
              [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): write access will be enabled during recovery
              [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): recovery complete
              [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): mounted filesystem d98b1a68-4ff7-4331-86d3-77c5d911b429 ro with ordered data mode. Quota mode: none.
              [Mon Dec 30 09:38:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
              [Mon Dec 30 09:38:35 2024] EXT4-fs (sda2): re-mounted d98b1a68-4ff7-4331-86d3-77c5d911b429 r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET  SOURCE    FSTYPE OPTIONS
              /       /dev/sda2 ext4   rw,noatime
              `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              3.0G    /var/
              1.6G    /var/log
              1.3G    /var/log/journal/2d06defc2eb445c9afef1cfd904ac913
              1.2G    /var/lib
              Archived and active journals take up 1.2G in the file system.
              /opt/iobroker/backups:
              940M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              961M    /opt/iobroker/iobroker-data/
              781M    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              28M     /opt/iobroker/iobroker-data/states.jsonl
              24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
              19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
              12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Installed: 20.18.1-1nodesource1
                Candidate: 20.18.1-1nodesource1
                Version table:
               *** 20.18.1-1nodesource1 600
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.18.0-1nodesource1 600
                   20.17.0-1nodesource1 600
                   20.16.0-1nodesource1 600
                   20.15.1-1nodesource1 600
                   20.15.0-1nodesource1 600
                   20.14.0-1nodesource1 600
                   20.13.1-1nodesource1 600
                   20.13.0-1nodesource1 600
                   20.12.2-1nodesource1 600
                   20.12.1-1nodesource1 600
                   20.12.0-1nodesource1 600
                   20.11.1-1nodesource1 600
                   20.11.0-1nodesource1 600
                   20.10.0-1nodesource1 600
                   20.9.0-1nodesource1 600
                   20.8.1-1nodesource1 600
                   20.8.0-1nodesource1 600
                   20.7.0-1nodesource1 600
                   20.6.1-1nodesource1 600
                   20.6.0-1nodesource1 600
                   20.5.1-1nodesource1 600
                   20.5.0-1nodesource1 600
                   20.4.0-1nodesource1 600
                   20.3.1-1nodesource1 600
                   20.3.0-1nodesource1 600
                   20.2.0-1nodesource1 600
                   20.1.0-1nodesource1 600
                   20.0.0-1nodesource1 600
                   12.22.12~dfsg-1~deb11u5 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              RasPi-ioBroker      RasPi-ioBroker (version: 7.0.6, hostname: RasPi-ioBroker, alive, uptime: 830)
              Core adapters versions
              js-controller:  7.0.6
              admin:          7.1.5
              javascript:     8.8.3
              nodejs modules from github:     1
              +-- iobroker.controme@0.5.3 (git+ssh://git@github.com/MadErstam/ioBroker.controme.git#a40bf461eadee0352492c1bf151fcb288f890fe2)
              Adapter State
              + system.adapter.backitup.0               : backitup              : RasPi-ioBroker                           -  enabled
                system.adapter.controme.0               : controme              : RasPi-ioBroker                           -  enabled
              + system.adapter.discovery.0              : discovery             : RasPi-ioBroker                           -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPi-ioBroker                           -  enabled
              + system.adapter.fhem.0                   : fhem                  : RasPi-ioBroker                           -  enabled, port: 7072
              + system.adapter.fritzdect.0              : fritzdect             : RasPi-ioBroker                           -  enabled
              + system.adapter.growatt.0                : growatt               : RasPi-ioBroker                           -  enabled
              + system.adapter.history.0                : history               : RasPi-ioBroker                           -  enabled
              + system.adapter.influxdb.0               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
              + system.adapter.influxdb.1               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
              + system.adapter.javascript.0             : javascript            : RasPi-ioBroker                           -  enabled
                system.adapter.maxcul.0                 : maxcul                : RasPi-ioBroker                           - disabled
              + system.adapter.modbus.0                 : modbus                : RasPi-ioBroker                           -  enabled
                system.adapter.mqtt-client.0            : mqtt-client           : RasPi-ioBroker                           - disabled, port: 1883
              + system.adapter.mqtt.0                   : mqtt                  : RasPi-ioBroker                           -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.powerfox2.0              : powerfox2             : RasPi-ioBroker                           -  enabled
                system.adapter.powerfox2.1              : powerfox2             : RasPi-ioBroker                           -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : RasPi-ioBroker                           -  enabled
              + system.adapter.pvforecast.1             : pvforecast            : RasPi-ioBroker                           -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : RasPi-ioBroker                           -  enabled
              + system.adapter.shelly.0                 : shelly                : RasPi-ioBroker                           -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.viessmannapi.0           : viessmannapi          : RasPi-ioBroker                           -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi-ioBroker                           -  enabled
                system.adapter.vis.0                    : vis                   : RasPi-ioBroker                           -  enabled
              + instance is alive
              ioBroker-Repositories
              │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
              Adapter    "fhem"         : 3.0.0    , installed 3.0.0
              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
              Adapter    "growatt"      : 3.3.1    , installed 3.3.1
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
              Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
              Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
              Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
              Adapter    "shelly"       : 8.2.1    , installed 8.2.1
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
              Adapter    "web"          : 6.2.5    , installed 6.3.0
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Objects and States
              Objects:        23107
              States:         19835
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease
              Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Hit:7 https://repos.influxdata.com/debian stable InRelease
              Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:9 https://apt.glennr.nl/repo bullseye InRelease
              Hit:10 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/7.0 InRelease
              Get:11 https://packages.adoptium.net/artifactory/deb bullseye InRelease [7517 B]
              Fetched 7517 B in 2s (3034 B/s)
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       96463      20066/io.mqtt.0
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       94929      20027/io.shelly.0
              tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      117        6468       1169/bin/mongod
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5527       534/cupsd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2496       603/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       95636      19881/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       95631      19881/iobroker.js-c
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        7445       541/influxd
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       95058      20216/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96285      19901/io.admin.0
              tcp6       0      0 :::8080                 :::*                    LISTEN      117        6029       599/java
              tcp6       0      0 :::3000                 :::*                    LISTEN      116        7528       1063/grafana
              tcp6       0      0 :::6789                 :::*                    LISTEN      117        7630       599/java
              tcp6       0      0 :::8843                 :::*                    LISTEN      117        6032       599/java
              tcp6       0      0 :::8880                 :::*                    LISTEN      117        6030       599/java
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5526       534/cupsd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          2498       603/sshd: /usr/sbin
              tcp6       0      0 :::8443                 :::*                    LISTEN      117        6031       599/java
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2427       384/avahi-daemon: r
              udp        0      0 0.0.0.0:40839           0.0.0.0:*                           108        2429       384/avahi-daemon: r
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2530       483/dhcpcd: [master
              udp6       0      0 :::5353                 :::*                                108        2428       384/avahi-daemon: r
              udp6       0      0 :::5514                 :::*                                117        7635       599/java
              udp6       0      0 :::3478                 :::*                                117        7626       599/java
              udp6       0      0 :::44558                :::*                                108        2430       384/avahi-daemon: r
              udp6       0      0 192.168.2.40:42712      :::*                                117        7638       599/java
              udp6       0      0 :::10001                :::*                                117        7639       599/java
              udp6       0      0 :::546                  :::*                                0          2546       483/dhcpcd: [master
              2024-12-30 11:34:28.120  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 23451 terminated with code 0 (NO_ERROR)
              2024-12-30 11:34:50.031  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 23772
              2024-12-30 11:34:52.700  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
              2024-12-30 11:34:52.717  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
              2024-12-30 11:34:52.762  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
              2024-12-30 11:34:52.791  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
              2024-12-30 11:34:52.815  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
              2024-12-30 11:34:52.828  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
              2024-12-30 11:34:53.400  - info: powerfox2.1 (23772) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
              2024-12-30 11:34:53.891  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11206.707 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11206.707
              2024-12-30 11:34:53.916  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.684 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.684
              2024-12-30 11:34:54.074  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3725.902 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3725.902
              2024-12-30 11:34:54.103  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11943.326 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11943.326
              2024-12-30 11:34:54.115  - info: powerfox2.1 (23772) Terminated (NO_ERROR): Without reason
              2024-12-30 11:34:54.647  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 having pid 23772 terminated with code 0 (NO_ERROR)
              2024-12-30 11:35:22.631  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
              2024-12-30 11:35:22.656  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
              2024-12-30 11:35:22.694  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
              2024-12-30 11:35:22.810  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
              2024-12-30 11:35:22.822  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
              2024-12-30 11:35:22.835  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
              2024-12-30 11:35:24.034  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 25097
              2024-12-30 11:35:26.970  - info: powerfox2.0 (25097) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
              2024-12-30 11:35:28.040  - info: powerfox2.0 (25097) Terminated (NO_ERROR): Without reason
              2024-12-30 11:35:28.584  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 25097 terminated with code 0 (NO_ERROR)
              • N
                nobbiman @mcm1957 last edited by
                @mcm1957 Ja, ich werde ein Issue aufmachen, warte im Moment noch ab, was sich noch bei @Thomas-Braun ergibt
                • N
                  @thomas-braun Backitup sichert auch Influxx-DB und Grafana-Einstellungen und Grafiken?
                    Da hat es wohl Einschläge im Dateisystem gegeben. Fahr die Kister IMMER ordentlich herunter, bevor du die vom Strom nimmst.
                    Zu controme: Installier den NICHT aus dem GitHub sondern aus einem ioBroker-Repo, sofern da vorhanden.
                    • system.adapter.influxdb.0 : influxdb : RasPi-ioBroker - enabled, port: 8086
                    • system.adapter.influxdb.1 : influxdb : RasPi-ioBroker - enabled, port: 8086
                    dürfte so auch falsch sein.
                    Die Quellen würde ich mir anschauen, warum die überhaupt angelegt wurden und ob es da nicht besser passende für dein Release gibt:
                    Wenn du es einstellst, ja.
                    • N
                      @thomas-braun sagte in Test Adapter Controme v0.5.x:
                      .. und genau da liegt mein Problem, wenn ich als Laie mit einem Profi chatte, ich verstehe nur Bahnhof und bin z.B. nicht in der Lage zu checken, ob die genannten "Hits" 4,9,10,11 dort hin gehören oder nicht.
                      Meine einzige Möglichkeit ist die einer kompletten und sauberen Neuinstalltion unter Bookworm.
                      Ich habe mich mal mit dem Backitup befasst und ein Backup durchgeführt. Dort stoße ich auf die Fehlermeldung
                      13:30:10.448
                      INFO
                      gui
                      Backup gestartet ...
                      13:30:10.516
                      DEBUG
                      mount
                      Wake on LAN wait 180 Seconds for NAS!
                      13:30:10.528
                      DEBUG
                      mount
                      Wake on LAN MAC-Address: 00:11:32:37:8C:5C
                      13:30:10.531
                      DEBUG
                      mount
                      mount activ... umount is started before mount!!
                      13:30:10.578
                      DEBUG
                      mount
                      umount successfully completed
                      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
                      13:33:10.487
                      DEBUG
                      mount
                      cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.20/homes/backup/ioBroker/ /opt/iobroker/backups"
                      13:33:10.749
                      DEBUG
                      mount
                      13:33:10.752
                      DEBUG
                      mount
                      done
                      [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"06:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"timestamp":1735561810465,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.2.40","port":8086,"dbversion":"2.x","token":"60a9d6d04cd505C","protocol":"https","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"PoweroptiPatrickhisory","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.2.40","port":"3000","protocol":"https","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1735561810465}
                      13:33:20.052
                      DEBUG
                      iobroker
                      host.RasPi-ioBroker 23099 objects saved
                      13:33:21.952
                      DEBUG
                      iobroker
                      host.RasPi-ioBroker 19811 states saved
                      host.RasPi-ioBroker Validating backup ...
                      13:33:21.961
                      DEBUG
                      iobroker
                      host.RasPi-ioBroker "config.json" is valid
                      13:33:21.970
                      DEBUG
                      iobroker
                      host.RasPi-ioBroker "objects.jsonl" exists
                      13:33:22.016
                      DEBUG
                      iobroker
                      host.RasPi-ioBroker "states.jsonl" exists
                      13:33:23.052
                      DEBUG
                      iobroker
                      host.RasPi-ioBroker JSONL lines are valid
                      13:33:23.076
                      DEBUG
                      iobroker
                      host.RasPi-ioBroker The backup is valid!
                      13:33:26.634
                      DEBUG
                      iobroker
                      Backup created: /opt/iobroker/backups/iobroker_2024_12_30-13_33_10_backupiobroker.tar.gz
                      13:33:26.743
                      DEBUG
                      iobroker
                      This backup can only be restored with js-controller version 7.0 or higher
                      13:33:27.670
                      DEBUG
                      iobroker
                      done
                      13:33:27.857
                      DEBUG
                      influxDB
                      InfluxDB-Backup started ...
                      13:33:27.863
                      DEBUG
                      influxDB
                      Start InfluxDB Backup ...
                      13:33:27.864
                      DEBUG
                      influxDB
                      InfluxDB Backup tmp directory created
                      13:33:27.871
                      DEBUG
                      influxDB
                      Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                      13:33:27.910
                      DEBUG
                      influxDB
                      InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker" successfully deleted
                      [DEBUG] [influxDB] -
                      13:33:27.933
                      ERROR
                      influxDB
                      Error: Command failed: influx backup --bucket iobroker --host https://192.168.2.40:8086 --skip-verify -t 60a9d6d04cd505C "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                      Error: API compatibility check failed: Get "https://192.168.2.40:8086/health": http: server gave HTTP response to HTTPS client
                      13:33:27.938
                      DEBUG
                      influxDB
                      InfluxDB-Backup for is finish
                      13:33:27.944
                      DEBUG
                      influxDB
                      done
                      13:33:28.663
                      ERROR
                      historyDB
                      BackItUp cannot found source "undefined" for compress!
                      Leider kann ich in den Logdaten nicht sehen, ob alle Daten, also auch die von Grafana, gesichert wurden.
                      Bevor das nicht klar ist, wede ich keine KOmplettinstallation durchführen.
                        Du hast sie aber als Admin von dem System angelegt. Dann musst du also auch wissen, warum.
                        • N
                          Das mag sein, ändert an meiner Aussage aber nichts, da mir die Installation nicht mehr bewußt ist. Vielleicht gehe ich mit meinem System auch nicht so sorgsam um wie du!
                            @nobbiman
                            Wenn du nicht weißt, warum die da sind brauchst du sie offenbar ja nicht.
                            • N
                              @thomas-braun So wollte ich auch an die Sache gehen, die sich m.E. aber mit einer Neuaufsetzung des Systems ohnehin erledigt hätte, in der Annahme, dass die genannten Bestandteile kein "Beifang" der Standardinstallation und der gelisteten Adapter sind.
                              Kannst du denn etwas zur Backitup-Fehlermeldung beitragen, damit ich die Neuinstallation angehen kann?
                                Deutet darauf hin, dass du da mit unterschiedlichen Protokollen hantierst.
                                N 2 Replies Last reply Reply Quote 0
                                • N
                                  @thomas-braun OK, Danke, dann gehe ich die Neuinstallation im neuen Jahr mal an.
                                  • N
                                    @thomas-braun Ich weiß nicht, ob ich hier in diesem Thread weitermachen soll oder besser einen neuen aufmache; ich versuche es mal hier:
                                    Ich habe mittlerweile mein System komplett neu auf einem RasPi 5 (mit der alten IP-Adresse) mit bookworm aufgesetzt und über backitup die Datensicherung beim ioBroker eingespielt. Mit dabei waren Influxdb und Grafana; letztere sollen über meine abgespeicherten Links unter Windows wieder erreichbar sein.
                                    Nach dem Restore wollen aber die 3 Influx-Instanzen nicht mehr starten, im Protokoll finde ich die Hinweise
                                    influxdb.0
                                    	2025-01-04 17:22:13.573	info	Influx DB Version used: 2.x
                                    influxdb.0
                                    	2025-01-04 17:22:13.573	info	Connecting http://192.168.2.40:8086/ ...
                                    influxdb.0
                                    	2025-01-04 17:22:03.573	error	Error: connect ECONNREFUSED 192.168.2.40:8086
                                    Möglicherweise muss der Port 8086 freigegeben werden, oder? Auf Grafana kann ich über den Port 3000 auch nicht zugreifen!
                                    Kann mir jemand sagen, wie ich weiter vorgehen sollte?
                                    iob diag ergibt
                                    ========== Start marking the full check here ===========
                                    ```bash
                                    Script v.2024-10-19
                                    *** BASE SYSTEM ***
                                     Static hostname: raspberrypi
                                           Icon name: computer
                                              Kernel: Linux 6.6.51+rpt-rpi-2712
                                        Architecture: arm64
                                    OS is similar to:
                                    Model           : Raspberry Pi 5 Model B Rev 1.1
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                     17:14:06 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                                    CPU threads: 4
                                    Operating System is the current Debian stable version codenamed 'bookworm'!
                                    Current issues:
                                    ~ Under-voltage has occurred
                                                   Local time: Sat 2025-01-04 17:14:06 CET
                                               Universal time: Sat 2025-01-04 16:14:06 UTC
                                                     RTC time: Sat 2025-01-04 16:14:06
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    HOME=/home/pi
                                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            4.2G        1.8G        714M        5.5M        1.8G        2.4G
                                    Swap:           536M          0B        536M
                                    Total:          4.8G        1.8G        1.3G
                                    Active iob-Instances:   22
                                             4045 M total memory
                                             1721 M used memory
                                             1817 M active memory
                                             1210 M inactive memory
                                              681 M free memory
                                              116 M buffer memory
                                             1595 M swap cache
                                              511 M total swap
                                                0 M used swap
                                              511 M free swap
                                    top - 17:14:07 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                                    Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   4045.1 total,    681.2 free,   1721.9 used,   1712.3 buff/cache
                                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2323.2 avail Mem
                                    *** FILESYSTEM ***
                                    udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                    tmpfs          tmpfs     405M  5.2M  400M   2% /run
                                    /dev/sda2      ext4      110G  5.5G   99G   6% /
                                    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                                    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                    /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                                    tmpfs          tmpfs     405M     0  405M   0% /run/user/1000
                                    [Sat Jan  4 15:37:46 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Sat Jan  4 15:37:49 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                    [Sat Jan  4 15:37:51 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    930M    /var/
                                    206M    /var/cache
                                    200M    /var/cache/apt
                                    164M    /var/lib
                                    135M    /var/lib/apt/lists
                                    Archived and active journals take up 47.9M in the file system.
                                    9.1M    /opt/iobroker/backups/
                                    853M    /opt/iobroker/iobroker-data/
                                    808M    /opt/iobroker/iobroker-data/files
                                    33M     /opt/iobroker/iobroker-data/objects.jsonl
                                    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                    13M     /opt/iobroker/iobroker-data/states.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                     *** 20.18.1-1nodesource1 1001
                                         20.18.0-1nodesource1 1001
                                         20.17.0-1nodesource1 1001
                                         20.16.0-1nodesource1 1001
                                         20.15.1-1nodesource1 1001
                                         20.15.0-1nodesource1 1001
                                         20.14.0-1nodesource1 1001
                                         20.13.1-1nodesource1 1001
                                         20.13.0-1nodesource1 1001
                                         20.12.2-1nodesource1 1001
                                         20.12.1-1nodesource1 1001
                                         20.12.0-1nodesource1 1001
                                         20.11.1-1nodesource1 1001
                                         20.11.0-1nodesource1 1001
                                         20.10.0-1nodesource1 1001
                                         20.9.0-1nodesource1 1001
                                         20.8.1-1nodesource1 1001
                                         20.8.0-1nodesource1 1001
                                         20.7.0-1nodesource1 1001
                                         20.6.1-1nodesource1 1001
                                         20.6.0-1nodesource1 1001
                                         20.5.1-1nodesource1 1001
                                         20.5.0-1nodesource1 1001
                                         20.4.0-1nodesource1 1001
                                         20.3.1-1nodesource1 1001
                                         20.3.0-1nodesource1 1001
                                         20.2.0-1nodesource1 1001
                                         20.1.0-1nodesource1 1001
                                         20.0.0-1nodesource1 1001
                                         18.19.0+dfsg-6~deb12u2 500
                                         18.19.0+dfsg-6~deb12u1 500
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1218)
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    nodejs modules from github:     0
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                    + system.adapter.controme.0               : controme              : raspberrypi                              -  enabled
                                      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                                    + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
                                    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                    + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                                    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                    + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                    + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                    + system.adapter.maxcul.0                 : maxcul                : raspberrypi                              -  enabled
                                    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                                    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                                    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                      system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
                                      system.adapter.powerfox2.1              : powerfox2             : raspberrypi                              -  enabled
                                    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                                    + system.adapter.pvforecast.1             : pvforecast            : raspberrypi                              -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    Objects and States
                                    Objects:        22957
                                    States:         19667
                                    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                                    Pending Updates: 12
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7374       660/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41842      11153/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41837      11153/iobroker.js-c
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       45413      11889/io.mqtt.0
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       44833      12073/io.shelly.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          7376       660/sshd: /usr/sbin
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44054      11183/io.admin.0
                                    udp        0      0 0.0.0.0:42016           0.0.0.0:*                           104        7274       534/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7272       534/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                104        7273       534/avahi-daemon: r
                                    udp6       0      0 :::49420                :::*                                104        7275       534/avahi-daemon: r
                                    udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          4758       620/NetworkManager
                                    2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                                    2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                                    2025-01-04 17:14:21.005  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                                    2025-01-04 17:14:21.223  - info: powerfox2.0 (14082) Terminated (NO_ERROR): Without reason
                                    2025-01-04 17:14:21.815  - warn: powerfox2.0 (14082) get state error: Connection is closed.
                                    2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                                    2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                                    2025-01-04 17:14:23.489  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                                    2025-01-04 17:14:24.753  - info: host.raspberrypi instance system.adapter.powerfox2.0 having pid 14082 terminated with code 0 (NO_ERROR)
                                    2025-01-04 17:14:30.984  - info: influxdb.2 (11731) Connecting http://192.168.2.40:8086/ ...
                                    2025-01-04 17:14:30.985  - info: influxdb.2 (11731) Influx DB Version used: 2.x
                                    2025-01-04 17:14:30.987  - error: influxdb.2 (11731) Error: connect ECONNREFUSED 192.168.2.40:8086
                                    2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                                    2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                                    2025-01-04 17:14:31.008  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                                    2025-01-04 17:14:32.383  - info: fhem.0 (12803) event FHEM: myStatDevice | statistics myStatDevice Updated stats for: MiniPV_Messung_Shelly | state > fhem.0.myStatDevice.state Updated stats for: MiniPV_Messung_Shelly
                                    2025-01-04 17:14:32.588  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                    2025-01-04 17:14:32.608  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 0.3 > set alias.0.PVAnlage.ModulleistungGarage 0.3
                                    2025-01-04 17:14:32.627  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 2.700000047683716 > set alias.0.PVAnlage.PVGarageSystemleistungTag 2.700000047683716
                                    2025-01-04 17:14:32.648  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.5 > set alias.0.PVAnlage.Akkutemperatur 9.5
                                    2025-01-04 17:14:32.667  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 103 > set alias.0.PVAnlage.BatterieEntladen 103
                                    2025-01-04 17:14:32.695  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieLaden | 0 > set alias.0.PVAnlage.BatterieLaden 0
                                    2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                                    2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                                    2025-01-04 17:14:33.492  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                                    Nun habe ich einige Hinweise im Backupit-Wiki gefunden, da werde ich erst einmal lesen.
                                    • N
                                      @thomas-braun So, nun bin ich wieder auf Stand und habe die Neuinstallation auf meinem neuen RasPi 5 (fast) laufen. Fast? - ja, nur noch der Controme-Adapter zickt und weist Fehlermeldungen auf, obwohl ich alle Adaptereinstellungen wie auf meinem Alt-RasPi vorgenommen habe.
                                      Die Controme-Instanz zeigt eine durchgängigen grünen Status, die auszugsweisen Fehlermeldungen lauten wie folgt:
                                      2025-01-07 10:03:01.249	warn	State "controme.0.16.humidity" has no existing object, this might lead to an error in future versions
                                      controme.0
                                      	2025-01-07 10:03:01.214	warn	State "controme.0.16.temporary_mode_end" has no existing object, this might lead to an error in future versions
                                      controme.0
                                      	2025-01-07 10:03:01.209	warn	State "controme.0.16.temporary_mode_remaining" has no existing object, this might lead to an error in future versions
                                      controme.0
                                      	2025-01-07 10:03:01.208	warn	State "controme.0.16.actualTemperature" has no existing object, this might lead to an error in future versions
                                      Meine Internetrecherche ergab zu der Fehlermeldung die Notwendigkeit, den Adapter über Github zu installieren, verstehe aber nicht den Sinn, das dort auch nur die Version 0.5.3 zur Verfügung steht.
                                      Sollte ihr mich weiterhin unterstützen wollen hier zur Fehleranalyse ioB diag:
                                      ```bash
                                      Script v.2024-10-19
                                      *** BASE SYSTEM ***
                                       Static hostname: ioBraspi
                                             Icon name: computer
                                                Kernel: Linux 6.6.62+rpt-rpi-2712
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                       10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Tue 2025-01-07 10:06:52 CET
                                                 Universal time: Tue 2025-01-07 09:06:52 UTC
                                                       RTC time: Tue 2025-01-07 09:06:52
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            4.2G        2.2G        1.3G        5.5M        819M        2.0G
                                      Swap:           536M          0B        536M
                                      Total:          4.8G        2.2G        1.8G
                                      Active iob-Instances:   21
                                               4045 M total memory
                                               2110 M used memory
                                               1626 M active memory
                                                922 M inactive memory
                                               1223 M free memory
                                                123 M buffer memory
                                                657 M swap cache
                                                511 M total swap
                                                  0 M used swap
                                                511 M free swap
                                      top - 10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                      Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
                                      MiB Mem :   4045.0 total,   1223.2 free,   2110.7 used,    781.4 buff/cache
                                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1934.3 avail Mem
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  2.0G     0  2.0G   0% /dev
                                      /dev/sda2      ext4      110G  6.7G   98G   7% /
                                      /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
                                      [Mon Jan  6 22:21:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Mon Jan  6 22:21:59 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                      [Mon Jan  6 22:22:00 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                      /var:
                                      1.1G    /var/
                                      237M    /var/lib
                                      220M    /var/cache
                                      206M    /var/cache/apt
                                      144M    /var/lib/apt/lists
                                      Archived and active journals take up 87.9M in the file system.
                                      82M     /opt/iobroker/backups/
                                      991M    /opt/iobroker/iobroker-data/
                                      809M    /opt/iobroker/iobroker-data/files
                                      68M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      ioBraspi            ioBraspi (version: 7.0.6, hostname: ioBraspi      , alive, uptime: 42280)
                                      admin:          7.1.5
                                      javascript:     8.8.3
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : ioBraspi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.backitup.0               : backitup              : ioBraspi                                 -  enabled
                                        system.adapter.controme.0               : controme              : ioBraspi                                 - disabled
                                      + system.adapter.discovery.0              : discovery             : ioBraspi                                 -  enabled
                                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBraspi                                 -  enabled
                                      + system.adapter.fhem.0                   : fhem                  : ioBraspi                                 -  enabled, port: 7072
                                      + system.adapter.fritzdect.0              : fritzdect             : ioBraspi                                 -  enabled
                                      + system.adapter.growatt.0                : growatt               : ioBraspi                                 -  enabled
                                      + system.adapter.history.0                : history               : ioBraspi                                 -  enabled
                                      + system.adapter.influxdb.0               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                      + system.adapter.influxdb.1               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                      + system.adapter.influxdb.2               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                      + system.adapter.javascript.0             : javascript            : ioBraspi                                 -  enabled
                                        system.adapter.maxcul.0                 : maxcul                : ioBraspi                                 - disabled
                                      + system.adapter.modbus.0                 : modbus                : ioBraspi                                 -  enabled
                                      + system.adapter.mqtt-client.0            : mqtt-client           : ioBraspi                                 -  enabled, port: 1883
                                        system.adapter.mqtt.0                   : mqtt                  : ioBraspi                                 - disabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.powerfox2.0              : powerfox2             : ioBraspi                                 -  enabled
                                        system.adapter.powerfox2.1              : powerfox2             : ioBraspi                                 -  enabled
                                      + system.adapter.pvforecast.0             : pvforecast            : ioBraspi                                 -  enabled
                                      + system.adapter.pvforecast.1             : pvforecast            : ioBraspi                                 -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : ioBraspi                                 -  enabled
                                      + system.adapter.shelly.0                 : shelly                : ioBraspi                                 -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.viessmannapi.0           : viessmannapi          : ioBraspi                                 -  enabled
                                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBraspi                                 -  enabled
                                        system.adapter.vis.0                    : vis                   : ioBraspi                                 -  enabled
                                      + system.adapter.web.0                    : web                   : ioBraspi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                      Objects and States
                                      Objects:        23091
                                      States:         20132
                                      Hit:4 https://apt.grafana.com stable InRelease
                                      Hit:5 https://repos.influxdata.com/debian stable InRelease
                                      Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3651       662/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       350516     52939/io.shelly.0
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6476       764/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1970       764/iobroker.js-con
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      106        5972       763/grafana
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          3653       662/sshd: /usr/sbin
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9617       1263/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6530       798/io.admin.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        5939       712/influxd
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5758       540/avahi-daemon: r
                                      udp        0      0 0.0.0.0:34404           0.0.0.0:*                           1001       240749     917/io.backitup.0
                                      udp        0      0 0.0.0.0:41481           0.0.0.0:*                           104        5760       540/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                104        5759       540/avahi-daemon: r
                                      udp6       0      0 :::49431                :::*                                104        5761       540/avahi-daemon: r
                                      udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          3692       622/NetworkManager
                                      2025-01-07 10:06:23.224  - info: fhem.0 (54119) event FHEM: powerfoxZ2NEUSTART | at powerfoxZ2NEUSTART Next: 10:11:23 | state > fhem.0.powerfoxZ2NEUSTART.state Next: 10:11:23
                                      2025-01-07 10:06:27.260  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                      2025-01-07 10:06:27.285  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                      2025-01-07 10:06:27.301  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                      2025-01-07 10:06:27.318  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                      2025-01-07 10:06:27.341  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                      2025-01-07 10:06:27.354  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                      2025-01-07 10:06:34.008  - info: host.ioBraspi instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 55193
                                      2025-01-07 10:06:34.888  - info: powerfox2.1 (55193) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                      2025-01-07 10:06:35.102  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11495.02 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11495.02
                                      2025-01-07 10:06:35.120  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.922 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.922
                                      2025-01-07 10:06:35.206  - info: powerfox2.1 (55193) Terminated (NO_ERROR): Without reason
                                      2025-01-07 10:06:35.209  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3811.156 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3811.156
                                      2025-01-07 10:06:35.223  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11955.872 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11955.872
                                      2025-01-07 10:06:35.716  - info: host.ioBraspi instance system.adapter.powerfox2.1 having pid 55193 terminated with code 0 (NO_ERROR)
                                      2025-01-07 10:06:57.219  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                      2025-01-07 10:06:57.280  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                      2025-01-07 10:06:57.298  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                      2025-01-07 10:06:57.316  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                      2025-01-07 10:06:57.388  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                      2025-01-07 10:06:57.405  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                      2025-01-07 10:07:19.009  - info: host.ioBraspi instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 56169
                                      2025-01-07 10:07:19.927  - info: powerfox2.0 (56169) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                      2025-01-07 10:07:22.247  - info: powerfox2.0 (56169) Terminated (NO_ERROR): Without reason
                                      2025-01-07 10:07:22.771  - info: host.ioBraspi instance system.adapter.powerfox2.0 having pid 56169 terminated with code 0 (NO_ERROR)
                                      Jetzt sehe ich gerade, auf meinem Alt- und Neu-ioBroker sind gar keine Objekte mehr angelegt!??
                                        Versionsnummern von GitHub-Installationen sind irrelevant. Hier gilt nur der CommitHash.
                                        Deswegen wird auch immer davon abgeraten direkt aus dem GitHub zu installieren. Da kann einfach 'irgendwas in irgendeinem Zustand' angespült werden.
                                          @nobbiman
                                          Bei GitHub-Installationen muss auch manuell eine Instanz angelegt werden, das passiert nicht automatisch wie bei einer ordentlichen Installation.
                                          • N
                                            @thomas-braun Noch habe den Adapter ja auch nur aus dem Beta-Repos installiert!
                                            Bleibt die Frage, warum keine Controme-Objekte mehr angezeigt werden?
                                            Gateway-MAC-Adresse ist korrekt eingestellt
                                            Entwarnung: Hatte das erneute Einlesen der Räume nach einem Adapterneustart nicht mehr angehakt.
                                            Nun sind die Objekt im Alt- und Neu-System da, um einzelne Fehlermeldungen wie
                                            2025-01-07 10:59:24.620	warn	Room 12: Temperature value for sensor 05:17:53:3d is invalid or null
                                            controme.0
                                            	2025-01-07 10:59:24.619	warn	Room 10: Temperature value for sensor 05:81:ff:c6 is invalid or null
                                            controme.0
                                            	2025-01-07 10:59:24.618	warn	Room 10: Temperature value for sensor 05:82:05:6a is invalid or null
                                            controme.0
                                            	2025-01-07 10:59:24.615	warn	Room 9: Temperature value for sensor 05:82:00:49 is invalid or null
                                            controme.0
                                            	2025-01-07 10:58:25.234	warn	State "controme.0.2.sensors.VSensor*1.actualTemperature" has no existing object, this might lead to an error in future versions
                                            .. kümmere ich mich später
                                            Nachtrag:
                                            Nun habe ich festgestellt, dass es sich bei allen 4 Sensoren um Fensterkontakte handelt, die natürlich keine Temperatur zurückmelden können.
                                            Kann ich einfach den Datenpunkt der jeweiligen Temperatur in den Objekten löschen?
                                            31.7k
                                            79.8k
                                            2439
