    4. Test Adapter Controme v0.5.x
    • N
      nobbiman @Thomas Braun last edited by nobbiman
      @thomas-braun reicht das summary?
      ```bash
                              v.2024-10-19
         Static hostname: RasPi-ioBroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.6.67-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            3.8G        2.0G        488M        0.0K        1.3G        1.7G
      Swap:           2.1G        246M        1.9G
      Total:          5.9G        2.3G        2.4G
      Active iob-Instances:   20
      Upgrade policy: none
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : RasPi-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : RasPi-ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                23107
      States:                 19835
      Size of iob-Database:
      43M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/states.jsonl
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @nobbiman last edited by
        @nobbiman
        Nein, die Langfassung. Du hastt da auch noch einen ganzen Zoo an Paketquellen drin, die nicht zum bullseye passen.
        • mcm1957
          mcm1957 @nobbiman last edited by
          @nobbiman
          Siehe:
          https://forum.iobroker.net/topic/78355/test-adapter-controme-v0-5-x/13
          • N
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2024-12-30 11:34:38 CET
                       Universal time: Mon 2024-12-30 10:34:38 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            JAVA_HOME=/usr/lib/jvm/java-17-openjdk-arm64
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.8G        2.1G        437M        0.0K        1.3G        1.6G
            Swap:           2.1G        245M        1.9G
            Total:          5.9G        2.3G        2.3G
                     3790 M total memory
                     2085 M used memory
                     1823 M active memory
                     1289 M inactive memory
                      437 M free memory
                      145 M buffer memory
                     1121 M swap cache
                     2147 M total swap
                      245 M used swap
                     1902 M free swap
            top - 11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
            Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 15.2 us,  4.5 sy,  0.0 ni, 78.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
            MiB Mem :   3791.0 total,    436.7 free,   2086.9 used,   1267.3 buff/cache
            MiB Swap:   2148.0 total,   1902.0 free,    246.0 used.   1620.3 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4      459G   16G  425G   4% /
            devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            /dev/sda1      vfat      255M   33M  223M  13% /boot
            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
            [Mon Dec 30 09:38:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A4:AD:F2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=94303a9e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
            [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
            [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): write access will be enabled during recovery
            [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): recovery complete
            [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): mounted filesystem d98b1a68-4ff7-4331-86d3-77c5d911b429 ro with ordered data mode. Quota mode: none.
            [Mon Dec 30 09:38:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Mon Dec 30 09:38:35 2024] EXT4-fs (sda2): re-mounted d98b1a68-4ff7-4331-86d3-77c5d911b429 r/w. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE    FSTYPE OPTIONS
            /       /dev/sda2 ext4   rw,noatime
            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            3.0G    /var/
            1.6G    /var/log
            1.3G    /var/log/journal/2d06defc2eb445c9afef1cfd904ac913
            1.2G    /var/lib
            Archived and active journals take up 1.2G in the file system.
            /opt/iobroker/backups:
            940M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            961M    /opt/iobroker/iobroker-data/
            781M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            28M     /opt/iobroker/iobroker-data/states.jsonl
            24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
            19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
            12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Installed: 20.18.1-1nodesource1
              Candidate: 20.18.1-1nodesource1
              Version table:
             *** 20.18.1-1nodesource1 600
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 20.18.0-1nodesource1 600
                 20.17.0-1nodesource1 600
                 20.16.0-1nodesource1 600
                 20.15.1-1nodesource1 600
                 20.15.0-1nodesource1 600
                 20.14.0-1nodesource1 600
                 20.13.1-1nodesource1 600
                 20.13.0-1nodesource1 600
                 20.12.2-1nodesource1 600
                 20.12.1-1nodesource1 600
                 20.12.0-1nodesource1 600
                 20.11.1-1nodesource1 600
                 20.11.0-1nodesource1 600
                 20.10.0-1nodesource1 600
                 20.9.0-1nodesource1 600
                 20.8.1-1nodesource1 600
                 20.8.0-1nodesource1 600
                 20.7.0-1nodesource1 600
                 20.6.1-1nodesource1 600
                 20.6.0-1nodesource1 600
                 20.5.1-1nodesource1 600
                 20.5.0-1nodesource1 600
                 20.4.0-1nodesource1 600
                 20.3.1-1nodesource1 600
                 20.3.0-1nodesource1 600
                 20.2.0-1nodesource1 600
                 20.1.0-1nodesource1 600
                 20.0.0-1nodesource1 600
                 12.22.12~dfsg-1~deb11u5 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            RasPi-ioBroker      RasPi-ioBroker (version: 7.0.6, hostname: RasPi-ioBroker, alive, uptime: 830)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.1.5
            javascript:     8.8.3
            nodejs modules from github:     1
            +-- iobroker.controme@0.5.3 (git+ssh://git@github.com/MadErstam/ioBroker.controme.git#a40bf461eadee0352492c1bf151fcb288f890fe2)
            Adapter State
            + system.adapter.backitup.0               : backitup              : RasPi-ioBroker                           -  enabled
              system.adapter.controme.0               : controme              : RasPi-ioBroker                           -  enabled
            + system.adapter.discovery.0              : discovery             : RasPi-ioBroker                           -  enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPi-ioBroker                           -  enabled
            + system.adapter.fhem.0                   : fhem                  : RasPi-ioBroker                           -  enabled, port: 7072
            + system.adapter.fritzdect.0              : fritzdect             : RasPi-ioBroker                           -  enabled
            + system.adapter.growatt.0                : growatt               : RasPi-ioBroker                           -  enabled
            + system.adapter.history.0                : history               : RasPi-ioBroker                           -  enabled
            + system.adapter.influxdb.0               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
            + system.adapter.influxdb.1               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : RasPi-ioBroker                           -  enabled
              system.adapter.maxcul.0                 : maxcul                : RasPi-ioBroker                           - disabled
            + system.adapter.modbus.0                 : modbus                : RasPi-ioBroker                           -  enabled
              system.adapter.mqtt-client.0            : mqtt-client           : RasPi-ioBroker                           - disabled, port: 1883
            + system.adapter.mqtt.0                   : mqtt                  : RasPi-ioBroker                           -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.powerfox2.0              : powerfox2             : RasPi-ioBroker                           -  enabled
              system.adapter.powerfox2.1              : powerfox2             : RasPi-ioBroker                           -  enabled
            + system.adapter.pvforecast.0             : pvforecast            : RasPi-ioBroker                           -  enabled
            + system.adapter.pvforecast.1             : pvforecast            : RasPi-ioBroker                           -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : RasPi-ioBroker                           -  enabled
            + system.adapter.shelly.0                 : shelly                : RasPi-ioBroker                           -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.viessmannapi.0           : viessmannapi          : RasPi-ioBroker                           -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi-ioBroker                           -  enabled
              system.adapter.vis.0                    : vis                   : RasPi-ioBroker                           -  enabled
            + instance is alive
            ioBroker-Repositories
            │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
            Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
            Adapter    "fhem"         : 3.0.0    , installed 3.0.0
            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
            Adapter    "growatt"      : 3.3.1    , installed 3.3.1
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
            Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
            Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
            Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
            Adapter    "web"          : 6.2.5    , installed 6.3.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        23107
            States:         19835
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease
            Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:6 https://apt.grafana.com stable InRelease
            Hit:7 https://repos.influxdata.com/debian stable InRelease
            Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:9 https://apt.glennr.nl/repo bullseye InRelease
            Hit:10 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/7.0 InRelease
            Get:11 https://packages.adoptium.net/artifactory/deb bullseye InRelease [7517 B]
            Fetched 7517 B in 2s (3034 B/s)
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       96463      20066/io.mqtt.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       94929      20027/io.shelly.0
            tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      117        6468       1169/bin/mongod
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5527       534/cupsd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2496       603/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       95636      19881/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       95631      19881/iobroker.js-c
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        7445       541/influxd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       95058      20216/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96285      19901/io.admin.0
            tcp6       0      0 :::8080                 :::*                    LISTEN      117        6029       599/java
            tcp6       0      0 :::3000                 :::*                    LISTEN      116        7528       1063/grafana
            tcp6       0      0 :::6789                 :::*                    LISTEN      117        7630       599/java
            tcp6       0      0 :::8843                 :::*                    LISTEN      117        6032       599/java
            tcp6       0      0 :::8880                 :::*                    LISTEN      117        6030       599/java
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5526       534/cupsd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          2498       603/sshd: /usr/sbin
            tcp6       0      0 :::8443                 :::*                    LISTEN      117        6031       599/java
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2427       384/avahi-daemon: r
            udp        0      0 0.0.0.0:40839           0.0.0.0:*                           108        2429       384/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2530       483/dhcpcd: [master
            udp6       0      0 :::5353                 :::*                                108        2428       384/avahi-daemon: r
            udp6       0      0 :::5514                 :::*                                117        7635       599/java
            udp6       0      0 :::3478                 :::*                                117        7626       599/java
            udp6       0      0 :::44558                :::*                                108        2430       384/avahi-daemon: r
            udp6       0      0 192.168.2.40:42712      :::*                                117        7638       599/java
            udp6       0      0 :::10001                :::*                                117        7639       599/java
            udp6       0      0 :::546                  :::*                                0          2546       483/dhcpcd: [master
            2024-12-30 11:34:28.120  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 23451 terminated with code 0 (NO_ERROR)
            2024-12-30 11:34:50.031  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 23772
            2024-12-30 11:34:52.700  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
            2024-12-30 11:34:52.717  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
            2024-12-30 11:34:52.762  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
            2024-12-30 11:34:52.791  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
            2024-12-30 11:34:52.815  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
            2024-12-30 11:34:52.828  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
            2024-12-30 11:34:53.400  - info: powerfox2.1 (23772) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
            2024-12-30 11:34:53.891  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11206.707 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11206.707
            2024-12-30 11:34:53.916  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.684 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.684
            2024-12-30 11:34:54.074  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3725.902 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3725.902
            2024-12-30 11:34:54.103  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11943.326 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11943.326
            2024-12-30 11:34:54.115  - info: powerfox2.1 (23772) Terminated (NO_ERROR): Without reason
            2024-12-30 11:34:54.647  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 having pid 23772 terminated with code 0 (NO_ERROR)
            2024-12-30 11:35:22.631  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
            2024-12-30 11:35:22.656  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
            2024-12-30 11:35:22.694  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
            2024-12-30 11:35:22.810  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
            2024-12-30 11:35:22.822  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
            2024-12-30 11:35:22.835  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
            2024-12-30 11:35:24.034  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 25097
            2024-12-30 11:35:26.970  - info: powerfox2.0 (25097) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
            2024-12-30 11:35:28.040  - info: powerfox2.0 (25097) Terminated (NO_ERROR): Without reason
            2024-12-30 11:35:28.584  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 25097 terminated with code 0 (NO_ERROR)
            • N
              nobbiman @mcm1957 last edited by
              @mcm1957 Ja, ich werde ein Issue aufmachen, warte im Moment noch ab, was sich noch bei @Thomas-Braun ergibt
              • N
                @thomas-braun Backitup sichert auch Influxx-DB und Grafana-Einstellungen und Grafiken?
                  @nobbiman sagte in Test Adapter Controme v0.5.x:
                  Da hat es wohl Einschläge im Dateisystem gegeben. Fahr die Kister IMMER ordentlich herunter, bevor du die vom Strom nimmst.
                  Zu controme: Installier den NICHT aus dem GitHub sondern aus einem ioBroker-Repo, sofern da vorhanden.
                  • system.adapter.influxdb.0 : influxdb : RasPi-ioBroker - enabled, port: 8086
                  • system.adapter.influxdb.1 : influxdb : RasPi-ioBroker - enabled, port: 8086
                  dürfte so auch falsch sein.
                  Die Quellen würde ich mir anschauen, warum die überhaupt angelegt wurden und ob es da nicht besser passende für dein Release gibt:
                  Wenn du es einstellst, ja.
                  • N
                    @thomas-braun sagte in Test Adapter Controme v0.5.x:
                    .. und genau da liegt mein Problem, wenn ich als Laie mit einem Profi chatte, ich verstehe nur Bahnhof und bin z.B. nicht in der Lage zu checken, ob die genannten "Hits" 4,9,10,11 dort hin gehören oder nicht.
                    Meine einzige Möglichkeit ist die einer kompletten und sauberen Neuinstalltion unter Bookworm.
                    Ich habe mich mal mit dem Backitup befasst und ein Backup durchgeführt. Dort stoße ich auf die Fehlermeldung
                    13:30:10.448
                    INFO
                    gui
                    Backup gestartet ...
                    13:30:10.516
                    DEBUG
                    mount
                    Wake on LAN wait 180 Seconds for NAS!
                    13:30:10.528
                    DEBUG
                    mount
                    Wake on LAN MAC-Address: 00:11:32:37:8C:5C
                    13:30:10.531
                    DEBUG
                    mount
                    mount activ... umount is started before mount!!
                    13:30:10.578
                    DEBUG
                    mount
                    umount successfully completed
                    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
                    13:33:10.487
                    DEBUG
                    mount
                    cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.20/homes/backup/ioBroker/ /opt/iobroker/backups"
                    13:33:10.749
                    DEBUG
                    mount
                    13:33:10.752
                    DEBUG
                    mount
                    done
                    [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"06:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"timestamp":1735561810465,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.2.40","port":8086,"dbversion":"2.x","token":"60a9d6d04cd505C","protocol":"https","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"PoweroptiPatrickhisory","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.2.40","port":"3000","protocol":"https","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1735561810465}
                    13:33:20.052
                    DEBUG
                    iobroker
                    host.RasPi-ioBroker 23099 objects saved
                    13:33:21.952
                    DEBUG
                    iobroker
                    host.RasPi-ioBroker 19811 states saved
                    host.RasPi-ioBroker Validating backup ...
                    13:33:21.961
                    DEBUG
                    iobroker
                    host.RasPi-ioBroker "config.json" is valid
                    13:33:21.970
                    DEBUG
                    iobroker
                    host.RasPi-ioBroker "objects.jsonl" exists
                    13:33:22.016
                    DEBUG
                    iobroker
                    host.RasPi-ioBroker "states.jsonl" exists
                    13:33:23.052
                    DEBUG
                    iobroker
                    host.RasPi-ioBroker JSONL lines are valid
                    13:33:23.076
                    DEBUG
                    iobroker
                    host.RasPi-ioBroker The backup is valid!
                    13:33:26.634
                    DEBUG
                    iobroker
                    Backup created: /opt/iobroker/backups/iobroker_2024_12_30-13_33_10_backupiobroker.tar.gz
                    13:33:26.743
                    DEBUG
                    iobroker
                    This backup can only be restored with js-controller version 7.0 or higher
                    13:33:27.670
                    DEBUG
                    iobroker
                    done
                    13:33:27.857
                    DEBUG
                    influxDB
                    InfluxDB-Backup started ...
                    13:33:27.863
                    DEBUG
                    influxDB
                    Start InfluxDB Backup ...
                    13:33:27.864
                    DEBUG
                    influxDB
                    InfluxDB Backup tmp directory created
                    13:33:27.871
                    DEBUG
                    influxDB
                    Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                    13:33:27.910
                    DEBUG
                    influxDB
                    InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker" successfully deleted
                    [DEBUG] [influxDB] -
                    13:33:27.933
                    ERROR
                    influxDB
                    Error: Command failed: influx backup --bucket iobroker --host https://192.168.2.40:8086 --skip-verify -t 60a9d6d04cd505C "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                    Error: API compatibility check failed: Get "https://192.168.2.40:8086/health": http: server gave HTTP response to HTTPS client
                    13:33:27.938
                    DEBUG
                    influxDB
                    InfluxDB-Backup for is finish
                    13:33:27.944
                    DEBUG
                    influxDB
                    done
                    13:33:28.663
                    ERROR
                    historyDB
                    BackItUp cannot found source "undefined" for compress!
                    Leider kann ich in den Logdaten nicht sehen, ob alle Daten, also auch die von Grafana, gesichert wurden.
                    Bevor das nicht klar ist, wede ich keine KOmplettinstallation durchführen.
                      Du hast sie aber als Admin von dem System angelegt. Dann musst du also auch wissen, warum.
                      • N
                        Das mag sein, ändert an meiner Aussage aber nichts, da mir die Installation nicht mehr bewußt ist. Vielleicht gehe ich mit meinem System auch nicht so sorgsam um wie du!
                          @nobbiman
                          Wenn du nicht weißt, warum die da sind brauchst du sie offenbar ja nicht.
                          • N
                            @thomas-braun So wollte ich auch an die Sache gehen, die sich m.E. aber mit einer Neuaufsetzung des Systems ohnehin erledigt hätte, in der Annahme, dass die genannten Bestandteile kein "Beifang" der Standardinstallation und der gelisteten Adapter sind.
                            Kannst du denn etwas zur Backitup-Fehlermeldung beitragen, damit ich die Neuinstallation angehen kann?
                              Deutet darauf hin, dass du da mit unterschiedlichen Protokollen hantierst.
                              N 2 Replies Last reply Reply Quote 0
                              • N
                                @thomas-braun OK, Danke, dann gehe ich die Neuinstallation im neuen Jahr mal an.
                                • N
                                  @thomas-braun Ich weiß nicht, ob ich hier in diesem Thread weitermachen soll oder besser einen neuen aufmache; ich versuche es mal hier:
                                  Ich habe mittlerweile mein System komplett neu auf einem RasPi 5 (mit der alten IP-Adresse) mit bookworm aufgesetzt und über backitup die Datensicherung beim ioBroker eingespielt. Mit dabei waren Influxdb und Grafana; letztere sollen über meine abgespeicherten Links unter Windows wieder erreichbar sein.
                                  Nach dem Restore wollen aber die 3 Influx-Instanzen nicht mehr starten, im Protokoll finde ich die Hinweise
                                  influxdb.0
                                  	2025-01-04 17:22:13.573	info	Influx DB Version used: 2.x
                                  influxdb.0
                                  	2025-01-04 17:22:13.573	info	Connecting http://192.168.2.40:8086/ ...
                                  influxdb.0
                                  	2025-01-04 17:22:03.573	error	Error: connect ECONNREFUSED 192.168.2.40:8086
                                  Möglicherweise muss der Port 8086 freigegeben werden, oder? Auf Grafana kann ich über den Port 3000 auch nicht zugreifen!
                                  Kann mir jemand sagen, wie ich weiter vorgehen sollte?
                                  iob diag ergibt
                                  ========== Start marking the full check here ===========
                                  ```bash
                                  Script v.2024-10-19
                                  *** BASE SYSTEM ***
                                   Static hostname: raspberrypi
                                         Icon name: computer
                                            Kernel: Linux 6.6.51+rpt-rpi-2712
                                      Architecture: arm64
                                  OS is similar to:
                                  Model           : Raspberry Pi 5 Model B Rev 1.1
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   17:14:06 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                                  CPU threads: 4
                                  Operating System is the current Debian stable version codenamed 'bookworm'!
                                  Current issues:
                                  ~ Under-voltage has occurred
                                                 Local time: Sat 2025-01-04 17:14:06 CET
                                             Universal time: Sat 2025-01-04 16:14:06 UTC
                                                   RTC time: Sat 2025-01-04 16:14:06
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            4.2G        1.8G        714M        5.5M        1.8G        2.4G
                                  Swap:           536M          0B        536M
                                  Total:          4.8G        1.8G        1.3G
                                  Active iob-Instances:   22
                                           4045 M total memory
                                           1721 M used memory
                                           1817 M active memory
                                           1210 M inactive memory
                                            681 M free memory
                                            116 M buffer memory
                                           1595 M swap cache
                                            511 M total swap
                                              0 M used swap
                                            511 M free swap
                                  top - 17:14:07 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                                  Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   4045.1 total,    681.2 free,   1721.9 used,   1712.3 buff/cache
                                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2323.2 avail Mem
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                  tmpfs          tmpfs     405M  5.2M  400M   2% /run
                                  /dev/sda2      ext4      110G  5.5G   99G   6% /
                                  tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                                  tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                  /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                                  tmpfs          tmpfs     405M     0  405M   0% /run/user/1000
                                  [Sat Jan  4 15:37:46 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Sat Jan  4 15:37:49 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                  [Sat Jan  4 15:37:51 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                  `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  930M    /var/
                                  206M    /var/cache
                                  200M    /var/cache/apt
                                  164M    /var/lib
                                  135M    /var/lib/apt/lists
                                  Archived and active journals take up 47.9M in the file system.
                                  9.1M    /opt/iobroker/backups/
                                  853M    /opt/iobroker/iobroker-data/
                                  808M    /opt/iobroker/iobroker-data/files
                                  33M     /opt/iobroker/iobroker-data/objects.jsonl
                                  24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                  13M     /opt/iobroker/iobroker-data/states.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                   *** 20.18.1-1nodesource1 1001
                                       20.18.0-1nodesource1 1001
                                       20.17.0-1nodesource1 1001
                                       20.16.0-1nodesource1 1001
                                       20.15.1-1nodesource1 1001
                                       20.15.0-1nodesource1 1001
                                       20.14.0-1nodesource1 1001
                                       20.13.1-1nodesource1 1001
                                       20.13.0-1nodesource1 1001
                                       20.12.2-1nodesource1 1001
                                       20.12.1-1nodesource1 1001
                                       20.12.0-1nodesource1 1001
                                       20.11.1-1nodesource1 1001
                                       20.11.0-1nodesource1 1001
                                       20.10.0-1nodesource1 1001
                                       20.9.0-1nodesource1 1001
                                       20.8.1-1nodesource1 1001
                                       20.8.0-1nodesource1 1001
                                       20.7.0-1nodesource1 1001
                                       20.6.1-1nodesource1 1001
                                       20.6.0-1nodesource1 1001
                                       20.5.1-1nodesource1 1001
                                       20.5.0-1nodesource1 1001
                                       20.4.0-1nodesource1 1001
                                       20.3.1-1nodesource1 1001
                                       20.3.0-1nodesource1 1001
                                       20.2.0-1nodesource1 1001
                                       20.1.0-1nodesource1 1001
                                       20.0.0-1nodesource1 1001
                                       18.19.0+dfsg-6~deb12u2 500
                                       18.19.0+dfsg-6~deb12u1 500
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1218)
                                  admin:          7.1.5
                                  javascript:     8.8.3
                                  nodejs modules from github:     0
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                  + system.adapter.controme.0               : controme              : raspberrypi                              -  enabled
                                    system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                                  + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
                                  + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                  + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                  + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                  + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                  + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                  + system.adapter.maxcul.0                 : maxcul                : raspberrypi                              -  enabled
                                  + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                                  + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
                                    system.adapter.powerfox2.1              : powerfox2             : raspberrypi                              -  enabled
                                  + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                                  + system.adapter.pvforecast.1             : pvforecast            : raspberrypi                              -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                    system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  Objects and States
                                  Objects:        22957
                                  States:         19667
                                  Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                                  Pending Updates: 12
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7374       660/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41842      11153/iobroker.js-c
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41837      11153/iobroker.js-c
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       45413      11889/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       44833      12073/io.shelly.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          7376       660/sshd: /usr/sbin
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44054      11183/io.admin.0
                                  udp        0      0 0.0.0.0:42016           0.0.0.0:*                           104        7274       534/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7272       534/avahi-daemon: r
                                  udp6       0      0 :::5353                 :::*                                104        7273       534/avahi-daemon: r
                                  udp6       0      0 :::49420                :::*                                104        7275       534/avahi-daemon: r
                                  udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          4758       620/NetworkManager
                                  2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                                  2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                                  2025-01-04 17:14:21.005  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                                  2025-01-04 17:14:21.223  - info: powerfox2.0 (14082) Terminated (NO_ERROR): Without reason
                                  2025-01-04 17:14:21.815  - warn: powerfox2.0 (14082) get state error: Connection is closed.
                                  2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                                  2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                                  2025-01-04 17:14:23.489  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                                  2025-01-04 17:14:24.753  - info: host.raspberrypi instance system.adapter.powerfox2.0 having pid 14082 terminated with code 0 (NO_ERROR)
                                  2025-01-04 17:14:30.984  - info: influxdb.2 (11731) Connecting http://192.168.2.40:8086/ ...
                                  2025-01-04 17:14:30.985  - info: influxdb.2 (11731) Influx DB Version used: 2.x
                                  2025-01-04 17:14:30.987  - error: influxdb.2 (11731) Error: connect ECONNREFUSED 192.168.2.40:8086
                                  2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                                  2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                                  2025-01-04 17:14:31.008  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                                  2025-01-04 17:14:32.383  - info: fhem.0 (12803) event FHEM: myStatDevice | statistics myStatDevice Updated stats for: MiniPV_Messung_Shelly | state > fhem.0.myStatDevice.state Updated stats for: MiniPV_Messung_Shelly
                                  2025-01-04 17:14:32.588  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                  2025-01-04 17:14:32.608  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 0.3 > set alias.0.PVAnlage.ModulleistungGarage 0.3
                                  2025-01-04 17:14:32.627  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 2.700000047683716 > set alias.0.PVAnlage.PVGarageSystemleistungTag 2.700000047683716
                                  2025-01-04 17:14:32.648  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.5 > set alias.0.PVAnlage.Akkutemperatur 9.5
                                  2025-01-04 17:14:32.667  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 103 > set alias.0.PVAnlage.BatterieEntladen 103
                                  2025-01-04 17:14:32.695  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieLaden | 0 > set alias.0.PVAnlage.BatterieLaden 0
                                  2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                                  2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                                  2025-01-04 17:14:33.492  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                                  Nun habe ich einige Hinweise im Backupit-Wiki gefunden, da werde ich erst einmal lesen.
                                  • N
                                    @thomas-braun So, nun bin ich wieder auf Stand und habe die Neuinstallation auf meinem neuen RasPi 5 (fast) laufen. Fast? - ja, nur noch der Controme-Adapter zickt und weist Fehlermeldungen auf, obwohl ich alle Adaptereinstellungen wie auf meinem Alt-RasPi vorgenommen habe.
                                    Die Controme-Instanz zeigt eine durchgängigen grünen Status, die auszugsweisen Fehlermeldungen lauten wie folgt:
                                    2025-01-07 10:03:01.249	warn	State "controme.0.16.humidity" has no existing object, this might lead to an error in future versions
                                    controme.0
                                    	2025-01-07 10:03:01.214	warn	State "controme.0.16.temporary_mode_end" has no existing object, this might lead to an error in future versions
                                    controme.0
                                    	2025-01-07 10:03:01.209	warn	State "controme.0.16.temporary_mode_remaining" has no existing object, this might lead to an error in future versions
                                    controme.0
                                    	2025-01-07 10:03:01.208	warn	State "controme.0.16.actualTemperature" has no existing object, this might lead to an error in future versions
                                    Meine Internetrecherche ergab zu der Fehlermeldung die Notwendigkeit, den Adapter über Github zu installieren, verstehe aber nicht den Sinn, das dort auch nur die Version 0.5.3 zur Verfügung steht.
                                    Sollte ihr mich weiterhin unterstützen wollen hier zur Fehleranalyse ioB diag:
                                    ```bash
                                    Script v.2024-10-19
                                    *** BASE SYSTEM ***
                                     Static hostname: ioBraspi
                                           Icon name: computer
                                              Kernel: Linux 6.6.62+rpt-rpi-2712
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                     10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Tue 2025-01-07 10:06:52 CET
                                               Universal time: Tue 2025-01-07 09:06:52 UTC
                                                     RTC time: Tue 2025-01-07 09:06:52
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    HOME=/home/pi
                                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            4.2G        2.2G        1.3G        5.5M        819M        2.0G
                                    Swap:           536M          0B        536M
                                    Total:          4.8G        2.2G        1.8G
                                    Active iob-Instances:   21
                                             4045 M total memory
                                             2110 M used memory
                                             1626 M active memory
                                              922 M inactive memory
                                             1223 M free memory
                                              123 M buffer memory
                                              657 M swap cache
                                              511 M total swap
                                                0 M used swap
                                              511 M free swap
                                    top - 10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                    Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
                                    MiB Mem :   4045.0 total,   1223.2 free,   2110.7 used,    781.4 buff/cache
                                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1934.3 avail Mem
                                    *** FILESYSTEM ***
                                    udev           devtmpfs  2.0G     0  2.0G   0% /dev
                                    /dev/sda2      ext4      110G  6.7G   98G   7% /
                                    /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
                                    [Mon Jan  6 22:21:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Mon Jan  6 22:21:59 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                    [Mon Jan  6 22:22:00 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                    /var:
                                    1.1G    /var/
                                    237M    /var/lib
                                    220M    /var/cache
                                    206M    /var/cache/apt
                                    144M    /var/lib/apt/lists
                                    Archived and active journals take up 87.9M in the file system.
                                    82M     /opt/iobroker/backups/
                                    991M    /opt/iobroker/iobroker-data/
                                    809M    /opt/iobroker/iobroker-data/files
                                    68M     /opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    ioBraspi            ioBraspi (version: 7.0.6, hostname: ioBraspi      , alive, uptime: 42280)
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : ioBraspi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.backitup.0               : backitup              : ioBraspi                                 -  enabled
                                      system.adapter.controme.0               : controme              : ioBraspi                                 - disabled
                                    + system.adapter.discovery.0              : discovery             : ioBraspi                                 -  enabled
                                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBraspi                                 -  enabled
                                    + system.adapter.fhem.0                   : fhem                  : ioBraspi                                 -  enabled, port: 7072
                                    + system.adapter.fritzdect.0              : fritzdect             : ioBraspi                                 -  enabled
                                    + system.adapter.growatt.0                : growatt               : ioBraspi                                 -  enabled
                                    + system.adapter.history.0                : history               : ioBraspi                                 -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                    + system.adapter.influxdb.1               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                    + system.adapter.influxdb.2               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                    + system.adapter.javascript.0             : javascript            : ioBraspi                                 -  enabled
                                      system.adapter.maxcul.0                 : maxcul                : ioBraspi                                 - disabled
                                    + system.adapter.modbus.0                 : modbus                : ioBraspi                                 -  enabled
                                    + system.adapter.mqtt-client.0            : mqtt-client           : ioBraspi                                 -  enabled, port: 1883
                                      system.adapter.mqtt.0                   : mqtt                  : ioBraspi                                 - disabled, port: 1883, bind: 0.0.0.0
                                      system.adapter.powerfox2.0              : powerfox2             : ioBraspi                                 -  enabled
                                      system.adapter.powerfox2.1              : powerfox2             : ioBraspi                                 -  enabled
                                    + system.adapter.pvforecast.0             : pvforecast            : ioBraspi                                 -  enabled
                                    + system.adapter.pvforecast.1             : pvforecast            : ioBraspi                                 -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : ioBraspi                                 -  enabled
                                    + system.adapter.shelly.0                 : shelly                : ioBraspi                                 -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.viessmannapi.0           : viessmannapi          : ioBraspi                                 -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBraspi                                 -  enabled
                                      system.adapter.vis.0                    : vis                   : ioBraspi                                 -  enabled
                                    + system.adapter.web.0                    : web                   : ioBraspi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                    Objects and States
                                    Objects:        23091
                                    States:         20132
                                    Hit:4 https://apt.grafana.com stable InRelease
                                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                                    Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
                                    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3651       662/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       350516     52939/io.shelly.0
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6476       764/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1970       764/iobroker.js-con
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      106        5972       763/grafana
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          3653       662/sshd: /usr/sbin
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9617       1263/io.web.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6530       798/io.admin.0
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        5939       712/influxd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5758       540/avahi-daemon: r
                                    udp        0      0 0.0.0.0:34404           0.0.0.0:*                           1001       240749     917/io.backitup.0
                                    udp        0      0 0.0.0.0:41481           0.0.0.0:*                           104        5760       540/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                104        5759       540/avahi-daemon: r
                                    udp6       0      0 :::49431                :::*                                104        5761       540/avahi-daemon: r
                                    udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          3692       622/NetworkManager
                                    2025-01-07 10:06:23.224  - info: fhem.0 (54119) event FHEM: powerfoxZ2NEUSTART | at powerfoxZ2NEUSTART Next: 10:11:23 | state > fhem.0.powerfoxZ2NEUSTART.state Next: 10:11:23
                                    2025-01-07 10:06:27.260  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                    2025-01-07 10:06:27.285  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                    2025-01-07 10:06:27.301  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                    2025-01-07 10:06:27.318  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                    2025-01-07 10:06:27.341  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                    2025-01-07 10:06:27.354  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                    2025-01-07 10:06:34.008  - info: host.ioBraspi instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 55193
                                    2025-01-07 10:06:34.888  - info: powerfox2.1 (55193) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                    2025-01-07 10:06:35.102  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11495.02 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11495.02
                                    2025-01-07 10:06:35.120  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.922 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.922
                                    2025-01-07 10:06:35.206  - info: powerfox2.1 (55193) Terminated (NO_ERROR): Without reason
                                    2025-01-07 10:06:35.209  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3811.156 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3811.156
                                    2025-01-07 10:06:35.223  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11955.872 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11955.872
                                    2025-01-07 10:06:35.716  - info: host.ioBraspi instance system.adapter.powerfox2.1 having pid 55193 terminated with code 0 (NO_ERROR)
                                    2025-01-07 10:06:57.219  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                    2025-01-07 10:06:57.280  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                    2025-01-07 10:06:57.298  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                    2025-01-07 10:06:57.316  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                    2025-01-07 10:06:57.388  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                    2025-01-07 10:06:57.405  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                    2025-01-07 10:07:19.009  - info: host.ioBraspi instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 56169
                                    2025-01-07 10:07:19.927  - info: powerfox2.0 (56169) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                    2025-01-07 10:07:22.247  - info: powerfox2.0 (56169) Terminated (NO_ERROR): Without reason
                                    2025-01-07 10:07:22.771  - info: host.ioBraspi instance system.adapter.powerfox2.0 having pid 56169 terminated with code 0 (NO_ERROR)
                                    Jetzt sehe ich gerade, auf meinem Alt- und Neu-ioBroker sind gar keine Objekte mehr angelegt!??
                                      Versionsnummern von GitHub-Installationen sind irrelevant. Hier gilt nur der CommitHash.
                                      Deswegen wird auch immer davon abgeraten direkt aus dem GitHub zu installieren. Da kann einfach 'irgendwas in irgendeinem Zustand' angespült werden.
                                        @nobbiman
                                        Bei GitHub-Installationen muss auch manuell eine Instanz angelegt werden, das passiert nicht automatisch wie bei einer ordentlichen Installation.
                                        • N
                                          @thomas-braun Noch habe den Adapter ja auch nur aus dem Beta-Repos installiert!
                                          Bleibt die Frage, warum keine Controme-Objekte mehr angezeigt werden?
                                          Gateway-MAC-Adresse ist korrekt eingestellt
                                          Entwarnung: Hatte das erneute Einlesen der Räume nach einem Adapterneustart nicht mehr angehakt.
                                          Nun sind die Objekt im Alt- und Neu-System da, um einzelne Fehlermeldungen wie
                                          2025-01-07 10:59:24.620	warn	Room 12: Temperature value for sensor 05:17:53:3d is invalid or null
                                          controme.0
                                          	2025-01-07 10:59:24.619	warn	Room 10: Temperature value for sensor 05:81:ff:c6 is invalid or null
                                          controme.0
                                          	2025-01-07 10:59:24.618	warn	Room 10: Temperature value for sensor 05:82:05:6a is invalid or null
                                          controme.0
                                          	2025-01-07 10:59:24.615	warn	Room 9: Temperature value for sensor 05:82:00:49 is invalid or null
                                          controme.0
                                          	2025-01-07 10:58:25.234	warn	State "controme.0.2.sensors.VSensor*1.actualTemperature" has no existing object, this might lead to an error in future versions
                                          .. kümmere ich mich später
                                          Nachtrag:
                                          Nun habe ich festgestellt, dass es sich bei allen 4 Sensoren um Fensterkontakte handelt, die natürlich keine Temperatur zurückmelden können.
                                          Kann ich einfach den Datenpunkt der jeweiligen Temperatur in den Objekten löschen?
                                            @nobbiman
                                            Zu dem Adapter kann ich nix konkretes sagen, hab ich nicht im Einsatz.
                                            31.7k
                                            79.8k
                                            2439
