    4. Test Adapter Controme v0.5.x
      Thomas Braun Most Active @nobbiman last edited by
      @nobbiman
      Nein, die Langfassung. Du hastt da auch noch einen ganzen Zoo an Paketquellen drin, die nicht zum bullseye passen.
      • mcm1957
        mcm1957 @nobbiman last edited by
        @nobbiman
        Siehe:
        https://forum.iobroker.net/topic/78355/test-adapter-controme-v0-5-x/13
        • N
          nobbiman @Thomas Braun last edited by
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
             Static hostname: RasPi-ioBroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.6.67-v8+
                Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Mon 2024-12-30 11:34:38 CET
                     Universal time: Mon 2024-12-30 10:34:38 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          JAVA_HOME=/usr/lib/jvm/java-17-openjdk-arm64
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        2.1G        437M        0.0K        1.3G        1.6G
          Swap:           2.1G        245M        1.9G
          Total:          5.9G        2.3G        2.3G
          Active iob-Instances:   20
                   3790 M total memory
                   2085 M used memory
                   1823 M active memory
                   1289 M inactive memory
                    437 M free memory
                    145 M buffer memory
                   1121 M swap cache
                   2147 M total swap
                    245 M used swap
                   1902 M free swap
          top - 11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
          Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 15.2 us,  4.5 sy,  0.0 ni, 78.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
          MiB Mem :   3791.0 total,    436.7 free,   2086.9 used,   1267.3 buff/cache
          MiB Swap:   2148.0 total,   1902.0 free,    246.0 used.   1620.3 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          /dev/root      ext4      459G   16G  425G   4% /
          devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/sda1      vfat      255M   33M  223M  13% /boot
          tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
          [Mon Dec 30 09:38:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A4:AD:F2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=94303a9e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
          [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
          [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): write access will be enabled during recovery
          [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): recovery complete
          [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): mounted filesystem d98b1a68-4ff7-4331-86d3-77c5d911b429 ro with ordered data mode. Quota mode: none.
          [Mon Dec 30 09:38:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Mon Dec 30 09:38:35 2024] EXT4-fs (sda2): re-mounted d98b1a68-4ff7-4331-86d3-77c5d911b429 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.0G    /var/
          1.6G    /var/log
          1.3G    /var/log/journal/2d06defc2eb445c9afef1cfd904ac913
          1.2G    /var/lib
          Archived and active journals take up 1.2G in the file system.
          /opt/iobroker/backups:
          940M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          961M    /opt/iobroker/iobroker-data/
          781M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          43M     /opt/iobroker/iobroker-data/objects.jsonl
          28M     /opt/iobroker/iobroker-data/states.jsonl
          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
          19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 600
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 600
               20.17.0-1nodesource1 600
               20.16.0-1nodesource1 600
               20.15.1-1nodesource1 600
               20.15.0-1nodesource1 600
               20.14.0-1nodesource1 600
               20.13.1-1nodesource1 600
               20.13.0-1nodesource1 600
               20.12.2-1nodesource1 600
               20.12.1-1nodesource1 600
               20.12.0-1nodesource1 600
               20.11.1-1nodesource1 600
               20.11.0-1nodesource1 600
               20.10.0-1nodesource1 600
               20.9.0-1nodesource1 600
               20.8.1-1nodesource1 600
               20.8.0-1nodesource1 600
               20.7.0-1nodesource1 600
               20.6.1-1nodesource1 600
               20.6.0-1nodesource1 600
               20.5.1-1nodesource1 600
               20.5.0-1nodesource1 600
               20.4.0-1nodesource1 600
               20.3.1-1nodesource1 600
               20.3.0-1nodesource1 600
               20.2.0-1nodesource1 600
               20.1.0-1nodesource1 600
               20.0.0-1nodesource1 600
               12.22.12~dfsg-1~deb11u5 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          RasPi-ioBroker      RasPi-ioBroker (version: 7.0.6, hostname: RasPi-ioBroker, alive, uptime: 830)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     1
          +-- iobroker.controme@0.5.3 (git+ssh://git@github.com/MadErstam/ioBroker.controme.git#a40bf461eadee0352492c1bf151fcb288f890fe2)
          Adapter State
          + system.adapter.admin.0                  : admin                 : RasPi-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : RasPi-ioBroker                           -  enabled
            system.adapter.controme.0               : controme              : RasPi-ioBroker                           -  enabled
          + system.adapter.discovery.0              : discovery             : RasPi-ioBroker                           -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPi-ioBroker                           -  enabled
          + system.adapter.fhem.0                   : fhem                  : RasPi-ioBroker                           -  enabled, port: 7072
          + system.adapter.fritzdect.0              : fritzdect             : RasPi-ioBroker                           -  enabled
          + system.adapter.growatt.0                : growatt               : RasPi-ioBroker                           -  enabled
          + system.adapter.history.0                : history               : RasPi-ioBroker                           -  enabled
          + system.adapter.influxdb.0               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : RasPi-ioBroker                           -  enabled
            system.adapter.maxcul.0                 : maxcul                : RasPi-ioBroker                           - disabled
          + system.adapter.modbus.0                 : modbus                : RasPi-ioBroker                           -  enabled
            system.adapter.mqtt-client.0            : mqtt-client           : RasPi-ioBroker                           - disabled, port: 1883
          + system.adapter.mqtt.0                   : mqtt                  : RasPi-ioBroker                           -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.powerfox2.0              : powerfox2             : RasPi-ioBroker                           -  enabled
            system.adapter.powerfox2.1              : powerfox2             : RasPi-ioBroker                           -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : RasPi-ioBroker                           -  enabled
          + system.adapter.pvforecast.1             : pvforecast            : RasPi-ioBroker                           -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : RasPi-ioBroker                           -  enabled
          + system.adapter.shelly.0                 : shelly                : RasPi-ioBroker                           -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.viessmannapi.0           : viessmannapi          : RasPi-ioBroker                           -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi-ioBroker                           -  enabled
            system.adapter.vis.0                    : vis                   : RasPi-ioBroker                           -  enabled
          + system.adapter.web.0                    : web                   : RasPi-ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
          Adapter    "fhem"         : 3.0.0    , installed 3.0.0
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "growatt"      : 3.3.1    , installed 3.3.1
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
          Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
          Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
          Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
          Adapter    "web"          : 6.2.5    , installed 6.3.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        23107
          States:         19835
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease
          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://repos.influxdata.com/debian stable InRelease
          Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:9 https://apt.glennr.nl/repo bullseye InRelease
          Hit:10 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/7.0 InRelease
          Get:11 https://packages.adoptium.net/artifactory/deb bullseye InRelease [7517 B]
          Fetched 7517 B in 2s (3034 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       96463      20066/io.mqtt.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       94929      20027/io.shelly.0
          tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      117        6468       1169/bin/mongod
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5527       534/cupsd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2496       603/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       95636      19881/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       95631      19881/iobroker.js-c
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        7445       541/influxd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       95058      20216/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96285      19901/io.admin.0
          tcp6       0      0 :::8080                 :::*                    LISTEN      117        6029       599/java
          tcp6       0      0 :::3000                 :::*                    LISTEN      116        7528       1063/grafana
          tcp6       0      0 :::6789                 :::*                    LISTEN      117        7630       599/java
          tcp6       0      0 :::8843                 :::*                    LISTEN      117        6032       599/java
          tcp6       0      0 :::8880                 :::*                    LISTEN      117        6030       599/java
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5526       534/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          2498       603/sshd: /usr/sbin
          tcp6       0      0 :::8443                 :::*                    LISTEN      117        6031       599/java
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2427       384/avahi-daemon: r
          udp        0      0 0.0.0.0:40839           0.0.0.0:*                           108        2429       384/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2530       483/dhcpcd: [master
          udp6       0      0 :::5353                 :::*                                108        2428       384/avahi-daemon: r
          udp6       0      0 :::5514                 :::*                                117        7635       599/java
          udp6       0      0 :::3478                 :::*                                117        7626       599/java
          udp6       0      0 :::44558                :::*                                108        2430       384/avahi-daemon: r
          udp6       0      0 192.168.2.40:42712      :::*                                117        7638       599/java
          udp6       0      0 :::10001                :::*                                117        7639       599/java
          udp6       0      0 :::546                  :::*                                0          2546       483/dhcpcd: [master
          2024-12-30 11:34:28.120  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 23451 terminated with code 0 (NO_ERROR)
          2024-12-30 11:34:50.031  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 23772
          2024-12-30 11:34:52.700  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
          2024-12-30 11:34:52.717  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
          2024-12-30 11:34:52.762  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
          2024-12-30 11:34:52.791  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
          2024-12-30 11:34:52.815  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
          2024-12-30 11:34:52.828  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
          2024-12-30 11:34:53.400  - info: powerfox2.1 (23772) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
          2024-12-30 11:34:53.891  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11206.707 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11206.707
          2024-12-30 11:34:53.916  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.684 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.684
          2024-12-30 11:34:54.074  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3725.902 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3725.902
          2024-12-30 11:34:54.103  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11943.326 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11943.326
          2024-12-30 11:34:54.115  - info: powerfox2.1 (23772) Terminated (NO_ERROR): Without reason
          2024-12-30 11:34:54.647  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 having pid 23772 terminated with code 0 (NO_ERROR)
          2024-12-30 11:35:22.631  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
          2024-12-30 11:35:22.656  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
          2024-12-30 11:35:22.694  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
          2024-12-30 11:35:22.810  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
          2024-12-30 11:35:22.822  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
          2024-12-30 11:35:22.835  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
          2024-12-30 11:35:24.034  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 25097
          2024-12-30 11:35:26.970  - info: powerfox2.0 (25097) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
          2024-12-30 11:35:28.040  - info: powerfox2.0 (25097) Terminated (NO_ERROR): Without reason
          2024-12-30 11:35:28.584  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 25097 terminated with code 0 (NO_ERROR)
          • N
            nobbiman @mcm1957 last edited by
            @mcm1957 Ja, ich werde ein Issue aufmachen, warte im Moment noch ab, was sich noch bei @Thomas-Braun ergibt
            • N
              nobbiman @Thomas Braun last edited by nobbiman
              @thomas-braun Backitup sichert auch Influxx-DB und Grafana-Einstellungen und Grafiken?
                @nobbiman sagte in Test Adapter Controme v0.5.x:
                Da hat es wohl Einschläge im Dateisystem gegeben. Fahr die Kister IMMER ordentlich herunter, bevor du die vom Strom nimmst.
                Zu controme: Installier den NICHT aus dem GitHub sondern aus einem ioBroker-Repo, sofern da vorhanden.
                • system.adapter.influxdb.0 : influxdb : RasPi-ioBroker - enabled, port: 8086
                • system.adapter.influxdb.1 : influxdb : RasPi-ioBroker - enabled, port: 8086
                dürfte so auch falsch sein.
                Die Quellen würde ich mir anschauen, warum die überhaupt angelegt wurden und ob es da nicht besser passende für dein Release gibt:
                Wenn du es einstellst, ja.
                • N
                  @thomas-braun sagte in Test Adapter Controme v0.5.x:
                  .. und genau da liegt mein Problem, wenn ich als Laie mit einem Profi chatte, ich verstehe nur Bahnhof und bin z.B. nicht in der Lage zu checken, ob die genannten "Hits" 4,9,10,11 dort hin gehören oder nicht.
                  Meine einzige Möglichkeit ist die einer kompletten und sauberen Neuinstalltion unter Bookworm.
                  Ich habe mich mal mit dem Backitup befasst und ein Backup durchgeführt. Dort stoße ich auf die Fehlermeldung
                  13:30:10.448
                  INFO
                  gui
                  Backup gestartet ...
                  13:30:10.516
                  DEBUG
                  mount
                  Wake on LAN wait 180 Seconds for NAS!
                  13:30:10.528
                  DEBUG
                  mount
                  Wake on LAN MAC-Address: 00:11:32:37:8C:5C
                  13:30:10.531
                  DEBUG
                  mount
                  mount activ... umount is started before mount!!
                  13:30:10.578
                  DEBUG
                  mount
                  umount successfully completed
                  [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
                  13:33:10.487
                  DEBUG
                  mount
                  cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.20/homes/backup/ioBroker/ /opt/iobroker/backups"
                  13:33:10.749
                  DEBUG
                  mount
                  13:33:10.752
                  DEBUG
                  mount
                  done
                  [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"06:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"timestamp":1735561810465,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.2.40","port":8086,"dbversion":"2.x","token":"60a9d6d04cd505C","protocol":"https","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"PoweroptiPatrickhisory","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.2.40","port":"3000","protocol":"https","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1735561810465}
                  13:33:20.052
                  DEBUG
                  iobroker
                  host.RasPi-ioBroker 23099 objects saved
                  13:33:21.952
                  DEBUG
                  iobroker
                  host.RasPi-ioBroker 19811 states saved
                  host.RasPi-ioBroker Validating backup ...
                  13:33:21.961
                  DEBUG
                  iobroker
                  host.RasPi-ioBroker "config.json" is valid
                  13:33:21.970
                  DEBUG
                  iobroker
                  host.RasPi-ioBroker "objects.jsonl" exists
                  13:33:22.016
                  DEBUG
                  iobroker
                  host.RasPi-ioBroker "states.jsonl" exists
                  13:33:23.052
                  DEBUG
                  iobroker
                  host.RasPi-ioBroker JSONL lines are valid
                  13:33:23.076
                  DEBUG
                  iobroker
                  host.RasPi-ioBroker The backup is valid!
                  13:33:26.634
                  DEBUG
                  iobroker
                  Backup created: /opt/iobroker/backups/iobroker_2024_12_30-13_33_10_backupiobroker.tar.gz
                  13:33:26.743
                  DEBUG
                  iobroker
                  This backup can only be restored with js-controller version 7.0 or higher
                  13:33:27.670
                  DEBUG
                  iobroker
                  done
                  13:33:27.857
                  DEBUG
                  influxDB
                  InfluxDB-Backup started ...
                  13:33:27.863
                  DEBUG
                  influxDB
                  Start InfluxDB Backup ...
                  13:33:27.864
                  DEBUG
                  influxDB
                  InfluxDB Backup tmp directory created
                  13:33:27.871
                  DEBUG
                  influxDB
                  Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                  13:33:27.910
                  DEBUG
                  influxDB
                  InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker" successfully deleted
                  [DEBUG] [influxDB] -
                  13:33:27.933
                  ERROR
                  influxDB
                  Error: Command failed: influx backup --bucket iobroker --host https://192.168.2.40:8086 --skip-verify -t 60a9d6d04cd505C "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                  Error: API compatibility check failed: Get "https://192.168.2.40:8086/health": http: server gave HTTP response to HTTPS client
                  13:33:27.938
                  DEBUG
                  influxDB
                  InfluxDB-Backup for is finish
                  13:33:27.944
                  DEBUG
                  influxDB
                  done
                  13:33:28.663
                  ERROR
                  historyDB
                  BackItUp cannot found source "undefined" for compress!
                  Leider kann ich in den Logdaten nicht sehen, ob alle Daten, also auch die von Grafana, gesichert wurden.
                  Bevor das nicht klar ist, wede ich keine KOmplettinstallation durchführen.
                    Du hast sie aber als Admin von dem System angelegt. Dann musst du also auch wissen, warum.
                    • N
                      Das mag sein, ändert an meiner Aussage aber nichts, da mir die Installation nicht mehr bewußt ist. Vielleicht gehe ich mit meinem System auch nicht so sorgsam um wie du!
                        @nobbiman
                        Wenn du nicht weißt, warum die da sind brauchst du sie offenbar ja nicht.
                        • N
                          @thomas-braun So wollte ich auch an die Sache gehen, die sich m.E. aber mit einer Neuaufsetzung des Systems ohnehin erledigt hätte, in der Annahme, dass die genannten Bestandteile kein "Beifang" der Standardinstallation und der gelisteten Adapter sind.
                          Kannst du denn etwas zur Backitup-Fehlermeldung beitragen, damit ich die Neuinstallation angehen kann?
                            Deutet darauf hin, dass du da mit unterschiedlichen Protokollen hantierst.
                            N 2 Replies Last reply Reply Quote 0
                            • N
                              @thomas-braun OK, Danke, dann gehe ich die Neuinstallation im neuen Jahr mal an.
                              • N
                                @thomas-braun Ich weiß nicht, ob ich hier in diesem Thread weitermachen soll oder besser einen neuen aufmache; ich versuche es mal hier:
                                Ich habe mittlerweile mein System komplett neu auf einem RasPi 5 (mit der alten IP-Adresse) mit bookworm aufgesetzt und über backitup die Datensicherung beim ioBroker eingespielt. Mit dabei waren Influxdb und Grafana; letztere sollen über meine abgespeicherten Links unter Windows wieder erreichbar sein.
                                Nach dem Restore wollen aber die 3 Influx-Instanzen nicht mehr starten, im Protokoll finde ich die Hinweise
                                influxdb.0
                                	2025-01-04 17:22:13.573	info	Influx DB Version used: 2.x
                                influxdb.0
                                	2025-01-04 17:22:13.573	info	Connecting http://192.168.2.40:8086/ ...
                                influxdb.0
                                	2025-01-04 17:22:03.573	error	Error: connect ECONNREFUSED 192.168.2.40:8086
                                Möglicherweise muss der Port 8086 freigegeben werden, oder? Auf Grafana kann ich über den Port 3000 auch nicht zugreifen!
                                Kann mir jemand sagen, wie ich weiter vorgehen sollte?
                                iob diag ergibt
                                ========== Start marking the full check here ===========
                                ```bash
                                Script v.2024-10-19
                                *** BASE SYSTEM ***
                                 Static hostname: raspberrypi
                                       Icon name: computer
                                          Kernel: Linux 6.6.51+rpt-rpi-2712
                                    Architecture: arm64
                                OS is similar to:
                                Model           : Raspberry Pi 5 Model B Rev 1.1
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                 17:14:06 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                                CPU threads: 4
                                Operating System is the current Debian stable version codenamed 'bookworm'!
                                Current issues:
                                ~ Under-voltage has occurred
                                               Local time: Sat 2025-01-04 17:14:06 CET
                                           Universal time: Sat 2025-01-04 16:14:06 UTC
                                                 RTC time: Sat 2025-01-04 16:14:06
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            4.2G        1.8G        714M        5.5M        1.8G        2.4G
                                Swap:           536M          0B        536M
                                Total:          4.8G        1.8G        1.3G
                                Active iob-Instances:   22
                                         4045 M total memory
                                         1721 M used memory
                                         1817 M active memory
                                         1210 M inactive memory
                                          681 M free memory
                                          116 M buffer memory
                                         1595 M swap cache
                                          511 M total swap
                                            0 M used swap
                                          511 M free swap
                                top - 17:14:07 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                                Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   4045.1 total,    681.2 free,   1721.9 used,   1712.3 buff/cache
                                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2323.2 avail Mem
                                *** FILESYSTEM ***
                                udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                tmpfs          tmpfs     405M  5.2M  400M   2% /run
                                /dev/sda2      ext4      110G  5.5G   99G   6% /
                                tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                                tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                                tmpfs          tmpfs     405M     0  405M   0% /run/user/1000
                                [Sat Jan  4 15:37:46 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Sat Jan  4 15:37:49 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                [Sat Jan  4 15:37:51 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                930M    /var/
                                206M    /var/cache
                                200M    /var/cache/apt
                                164M    /var/lib
                                135M    /var/lib/apt/lists
                                Archived and active journals take up 47.9M in the file system.
                                9.1M    /opt/iobroker/backups/
                                853M    /opt/iobroker/iobroker-data/
                                808M    /opt/iobroker/iobroker-data/files
                                33M     /opt/iobroker/iobroker-data/objects.jsonl
                                24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                13M     /opt/iobroker/iobroker-data/states.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                 *** 20.18.1-1nodesource1 1001
                                     20.18.0-1nodesource1 1001
                                     20.17.0-1nodesource1 1001
                                     20.16.0-1nodesource1 1001
                                     20.15.1-1nodesource1 1001
                                     20.15.0-1nodesource1 1001
                                     20.14.0-1nodesource1 1001
                                     20.13.1-1nodesource1 1001
                                     20.13.0-1nodesource1 1001
                                     20.12.2-1nodesource1 1001
                                     20.12.1-1nodesource1 1001
                                     20.12.0-1nodesource1 1001
                                     20.11.1-1nodesource1 1001
                                     20.11.0-1nodesource1 1001
                                     20.10.0-1nodesource1 1001
                                     20.9.0-1nodesource1 1001
                                     20.8.1-1nodesource1 1001
                                     20.8.0-1nodesource1 1001
                                     20.7.0-1nodesource1 1001
                                     20.6.1-1nodesource1 1001
                                     20.6.0-1nodesource1 1001
                                     20.5.1-1nodesource1 1001
                                     20.5.0-1nodesource1 1001
                                     20.4.0-1nodesource1 1001
                                     20.3.1-1nodesource1 1001
                                     20.3.0-1nodesource1 1001
                                     20.2.0-1nodesource1 1001
                                     20.1.0-1nodesource1 1001
                                     20.0.0-1nodesource1 1001
                                     18.19.0+dfsg-6~deb12u2 500
                                     18.19.0+dfsg-6~deb12u1 500
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1218)
                                admin:          7.1.5
                                javascript:     8.8.3
                                nodejs modules from github:     0
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                + system.adapter.controme.0               : controme              : raspberrypi                              -  enabled
                                  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                                + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
                                + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                + system.adapter.maxcul.0                 : maxcul                : raspberrypi                              -  enabled
                                + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                                + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                  system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
                                  system.adapter.powerfox2.1              : powerfox2             : raspberrypi                              -  enabled
                                + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                                + system.adapter.pvforecast.1             : pvforecast            : raspberrypi                              -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                  system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Objects and States
                                Objects:        22957
                                States:         19667
                                Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                                Pending Updates: 12
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7374       660/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41842      11153/iobroker.js-c
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41837      11153/iobroker.js-c
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       45413      11889/io.mqtt.0
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       44833      12073/io.shelly.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          7376       660/sshd: /usr/sbin
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44054      11183/io.admin.0
                                udp        0      0 0.0.0.0:42016           0.0.0.0:*                           104        7274       534/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7272       534/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                104        7273       534/avahi-daemon: r
                                udp6       0      0 :::49420                :::*                                104        7275       534/avahi-daemon: r
                                udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          4758       620/NetworkManager
                                2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                                2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                                2025-01-04 17:14:21.005  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                                2025-01-04 17:14:21.223  - info: powerfox2.0 (14082) Terminated (NO_ERROR): Without reason
                                2025-01-04 17:14:21.815  - warn: powerfox2.0 (14082) get state error: Connection is closed.
                                2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                                2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                                2025-01-04 17:14:23.489  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                                2025-01-04 17:14:24.753  - info: host.raspberrypi instance system.adapter.powerfox2.0 having pid 14082 terminated with code 0 (NO_ERROR)
                                2025-01-04 17:14:30.984  - info: influxdb.2 (11731) Connecting http://192.168.2.40:8086/ ...
                                2025-01-04 17:14:30.985  - info: influxdb.2 (11731) Influx DB Version used: 2.x
                                2025-01-04 17:14:30.987  - error: influxdb.2 (11731) Error: connect ECONNREFUSED 192.168.2.40:8086
                                2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                                2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                                2025-01-04 17:14:31.008  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                                2025-01-04 17:14:32.383  - info: fhem.0 (12803) event FHEM: myStatDevice | statistics myStatDevice Updated stats for: MiniPV_Messung_Shelly | state > fhem.0.myStatDevice.state Updated stats for: MiniPV_Messung_Shelly
                                2025-01-04 17:14:32.588  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                2025-01-04 17:14:32.608  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 0.3 > set alias.0.PVAnlage.ModulleistungGarage 0.3
                                2025-01-04 17:14:32.627  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 2.700000047683716 > set alias.0.PVAnlage.PVGarageSystemleistungTag 2.700000047683716
                                2025-01-04 17:14:32.648  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.5 > set alias.0.PVAnlage.Akkutemperatur 9.5
                                2025-01-04 17:14:32.667  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 103 > set alias.0.PVAnlage.BatterieEntladen 103
                                2025-01-04 17:14:32.695  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieLaden | 0 > set alias.0.PVAnlage.BatterieLaden 0
                                2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                                2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                                2025-01-04 17:14:33.492  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                                Nun habe ich einige Hinweise im Backupit-Wiki gefunden, da werde ich erst einmal lesen.
                                • N
                                  @thomas-braun So, nun bin ich wieder auf Stand und habe die Neuinstallation auf meinem neuen RasPi 5 (fast) laufen. Fast? - ja, nur noch der Controme-Adapter zickt und weist Fehlermeldungen auf, obwohl ich alle Adaptereinstellungen wie auf meinem Alt-RasPi vorgenommen habe.
                                  Die Controme-Instanz zeigt eine durchgängigen grünen Status, die auszugsweisen Fehlermeldungen lauten wie folgt:
                                  2025-01-07 10:03:01.249	warn	State "controme.0.16.humidity" has no existing object, this might lead to an error in future versions
                                  controme.0
                                  	2025-01-07 10:03:01.214	warn	State "controme.0.16.temporary_mode_end" has no existing object, this might lead to an error in future versions
                                  controme.0
                                  	2025-01-07 10:03:01.209	warn	State "controme.0.16.temporary_mode_remaining" has no existing object, this might lead to an error in future versions
                                  controme.0
                                  	2025-01-07 10:03:01.208	warn	State "controme.0.16.actualTemperature" has no existing object, this might lead to an error in future versions
                                  Meine Internetrecherche ergab zu der Fehlermeldung die Notwendigkeit, den Adapter über Github zu installieren, verstehe aber nicht den Sinn, das dort auch nur die Version 0.5.3 zur Verfügung steht.
                                  Sollte ihr mich weiterhin unterstützen wollen hier zur Fehleranalyse ioB diag:
                                  ```bash
                                  Script v.2024-10-19
                                  *** BASE SYSTEM ***
                                   Static hostname: ioBraspi
                                         Icon name: computer
                                            Kernel: Linux 6.6.62+rpt-rpi-2712
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Tue 2025-01-07 10:06:52 CET
                                             Universal time: Tue 2025-01-07 09:06:52 UTC
                                                   RTC time: Tue 2025-01-07 09:06:52
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            4.2G        2.2G        1.3G        5.5M        819M        2.0G
                                  Swap:           536M          0B        536M
                                  Total:          4.8G        2.2G        1.8G
                                  Active iob-Instances:   21
                                           4045 M total memory
                                           2110 M used memory
                                           1626 M active memory
                                            922 M inactive memory
                                           1223 M free memory
                                            123 M buffer memory
                                            657 M swap cache
                                            511 M total swap
                                              0 M used swap
                                            511 M free swap
                                  top - 10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                  Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
                                  MiB Mem :   4045.0 total,   1223.2 free,   2110.7 used,    781.4 buff/cache
                                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1934.3 avail Mem
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  2.0G     0  2.0G   0% /dev
                                  /dev/sda2      ext4      110G  6.7G   98G   7% /
                                  /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
                                  [Mon Jan  6 22:21:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Mon Jan  6 22:21:59 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                  [Mon Jan  6 22:22:00 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                  /var:
                                  1.1G    /var/
                                  237M    /var/lib
                                  220M    /var/cache
                                  206M    /var/cache/apt
                                  144M    /var/lib/apt/lists
                                  Archived and active journals take up 87.9M in the file system.
                                  82M     /opt/iobroker/backups/
                                  991M    /opt/iobroker/iobroker-data/
                                  809M    /opt/iobroker/iobroker-data/files
                                  68M     /opt/iobroker/iobroker-data/objects.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  ioBraspi            ioBraspi (version: 7.0.6, hostname: ioBraspi      , alive, uptime: 42280)
                                  admin:          7.1.5
                                  javascript:     8.8.3
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : ioBraspi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.backitup.0               : backitup              : ioBraspi                                 -  enabled
                                    system.adapter.controme.0               : controme              : ioBraspi                                 - disabled
                                  + system.adapter.discovery.0              : discovery             : ioBraspi                                 -  enabled
                                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBraspi                                 -  enabled
                                  + system.adapter.fhem.0                   : fhem                  : ioBraspi                                 -  enabled, port: 7072
                                  + system.adapter.fritzdect.0              : fritzdect             : ioBraspi                                 -  enabled
                                  + system.adapter.growatt.0                : growatt               : ioBraspi                                 -  enabled
                                  + system.adapter.history.0                : history               : ioBraspi                                 -  enabled
                                  + system.adapter.influxdb.0               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                  + system.adapter.influxdb.1               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                  + system.adapter.influxdb.2               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                  + system.adapter.javascript.0             : javascript            : ioBraspi                                 -  enabled
                                    system.adapter.maxcul.0                 : maxcul                : ioBraspi                                 - disabled
                                  + system.adapter.modbus.0                 : modbus                : ioBraspi                                 -  enabled
                                  + system.adapter.mqtt-client.0            : mqtt-client           : ioBraspi                                 -  enabled, port: 1883
                                    system.adapter.mqtt.0                   : mqtt                  : ioBraspi                                 - disabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.powerfox2.0              : powerfox2             : ioBraspi                                 -  enabled
                                    system.adapter.powerfox2.1              : powerfox2             : ioBraspi                                 -  enabled
                                  + system.adapter.pvforecast.0             : pvforecast            : ioBraspi                                 -  enabled
                                  + system.adapter.pvforecast.1             : pvforecast            : ioBraspi                                 -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : ioBraspi                                 -  enabled
                                  + system.adapter.shelly.0                 : shelly                : ioBraspi                                 -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.viessmannapi.0           : viessmannapi          : ioBraspi                                 -  enabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBraspi                                 -  enabled
                                    system.adapter.vis.0                    : vis                   : ioBraspi                                 -  enabled
                                  + system.adapter.web.0                    : web                   : ioBraspi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                  Objects and States
                                  Objects:        23091
                                  States:         20132
                                  Hit:4 https://apt.grafana.com stable InRelease
                                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                                  Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3651       662/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       350516     52939/io.shelly.0
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6476       764/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1970       764/iobroker.js-con
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      106        5972       763/grafana
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          3653       662/sshd: /usr/sbin
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9617       1263/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6530       798/io.admin.0
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        5939       712/influxd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5758       540/avahi-daemon: r
                                  udp        0      0 0.0.0.0:34404           0.0.0.0:*                           1001       240749     917/io.backitup.0
                                  udp        0      0 0.0.0.0:41481           0.0.0.0:*                           104        5760       540/avahi-daemon: r
                                  udp6       0      0 :::5353                 :::*                                104        5759       540/avahi-daemon: r
                                  udp6       0      0 :::49431                :::*                                104        5761       540/avahi-daemon: r
                                  udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          3692       622/NetworkManager
                                  2025-01-07 10:06:23.224  - info: fhem.0 (54119) event FHEM: powerfoxZ2NEUSTART | at powerfoxZ2NEUSTART Next: 10:11:23 | state > fhem.0.powerfoxZ2NEUSTART.state Next: 10:11:23
                                  2025-01-07 10:06:27.260  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                  2025-01-07 10:06:27.285  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                  2025-01-07 10:06:27.301  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                  2025-01-07 10:06:27.318  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                  2025-01-07 10:06:27.341  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                  2025-01-07 10:06:27.354  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                  2025-01-07 10:06:34.008  - info: host.ioBraspi instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 55193
                                  2025-01-07 10:06:34.888  - info: powerfox2.1 (55193) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                  2025-01-07 10:06:35.102  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11495.02 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11495.02
                                  2025-01-07 10:06:35.120  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.922 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.922
                                  2025-01-07 10:06:35.206  - info: powerfox2.1 (55193) Terminated (NO_ERROR): Without reason
                                  2025-01-07 10:06:35.209  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3811.156 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3811.156
                                  2025-01-07 10:06:35.223  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11955.872 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11955.872
                                  2025-01-07 10:06:35.716  - info: host.ioBraspi instance system.adapter.powerfox2.1 having pid 55193 terminated with code 0 (NO_ERROR)
                                  2025-01-07 10:06:57.219  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                  2025-01-07 10:06:57.280  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                  2025-01-07 10:06:57.298  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                  2025-01-07 10:06:57.316  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                  2025-01-07 10:06:57.388  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                  2025-01-07 10:06:57.405  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                  2025-01-07 10:07:19.009  - info: host.ioBraspi instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 56169
                                  2025-01-07 10:07:19.927  - info: powerfox2.0 (56169) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                  2025-01-07 10:07:22.247  - info: powerfox2.0 (56169) Terminated (NO_ERROR): Without reason
                                  2025-01-07 10:07:22.771  - info: host.ioBraspi instance system.adapter.powerfox2.0 having pid 56169 terminated with code 0 (NO_ERROR)
                                  Jetzt sehe ich gerade, auf meinem Alt- und Neu-ioBroker sind gar keine Objekte mehr angelegt!??
                                    Versionsnummern von GitHub-Installationen sind irrelevant. Hier gilt nur der CommitHash.
                                    Deswegen wird auch immer davon abgeraten direkt aus dem GitHub zu installieren. Da kann einfach 'irgendwas in irgendeinem Zustand' angespült werden.
                                      @nobbiman
                                      Bei GitHub-Installationen muss auch manuell eine Instanz angelegt werden, das passiert nicht automatisch wie bei einer ordentlichen Installation.
                                      • N
                                        @thomas-braun Noch habe den Adapter ja auch nur aus dem Beta-Repos installiert!
                                        Bleibt die Frage, warum keine Controme-Objekte mehr angezeigt werden?
                                        Gateway-MAC-Adresse ist korrekt eingestellt
                                        Entwarnung: Hatte das erneute Einlesen der Räume nach einem Adapterneustart nicht mehr angehakt.
                                        Nun sind die Objekt im Alt- und Neu-System da, um einzelne Fehlermeldungen wie
                                        2025-01-07 10:59:24.620	warn	Room 12: Temperature value for sensor 05:17:53:3d is invalid or null
                                        controme.0
                                        	2025-01-07 10:59:24.619	warn	Room 10: Temperature value for sensor 05:81:ff:c6 is invalid or null
                                        controme.0
                                        	2025-01-07 10:59:24.618	warn	Room 10: Temperature value for sensor 05:82:05:6a is invalid or null
                                        controme.0
                                        	2025-01-07 10:59:24.615	warn	Room 9: Temperature value for sensor 05:82:00:49 is invalid or null
                                        controme.0
                                        	2025-01-07 10:58:25.234	warn	State "controme.0.2.sensors.VSensor*1.actualTemperature" has no existing object, this might lead to an error in future versions
                                        .. kümmere ich mich später
                                        Nachtrag:
                                        Nun habe ich festgestellt, dass es sich bei allen 4 Sensoren um Fensterkontakte handelt, die natürlich keine Temperatur zurückmelden können.
                                        Kann ich einfach den Datenpunkt der jeweiligen Temperatur in den Objekten löschen?
                                          @nobbiman
                                          Zu dem Adapter kann ich nix konkretes sagen, hab ich nicht im Einsatz.
                                          • N
                                            @thomas-braun Trotzdem vielen Dank für die unermüdliche Unterstützung!
                                            31.7k
                                            79.8k
                                            2439
