    4. [gelöst]Node.JS lässt sich nicht updaten
      Holzwurm1976 last edited by Holzwurm1976
      so, jetzt habe ich ein paar Stunden Updates gemacht, und konnte alle Adapter aktualiseren, bis auf diese beiden:
        RPI-Monitor  1.3.2    2.3.0
        Worx  2.3.4    3.1.1
        Thomas Braun Most Active @Holzwurm1976 last edited by
        @holzwurm1976 sagte in Node.JS lässt sich nicht updaten:
        Meldungen dazu?
          Holzwurm1976 @Thomas Braun last edited by
          @thomas-braun oh man, irgendwann lerne ich es:
          $ iobroker upgrade worx@3.1.1 --debug
          Update worx from @2.3.4 to @3.1.1
          NPM version: 10.8.2
          Installing iobroker.worx@3.1.1... (System call)
          > @abandonware/noble@1.9.2-24 install> node-gyp-build
          gyp info it worked if it ends with ok
          gyp info using node@18.20.5 | linux | arm
          gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
          gyp info spawn /usr/bin/python3
          gyp info spawn args [
          gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/@abandonware/noble/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',
          gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.5/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.5',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.5/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@abandonware/noble',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
          Traceback (most recent call last):
          File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 8, in <module> import gyp.common File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/common.py", line 435 if CC := os.environ.get("CC_target") or os.environ.get("CC"): ^SyntaxError: invalid syntax
          gyp ERR! configure error
          gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/configure.js:317:18)gyp ERR! stack at ChildProcess.emit (node:events:517:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)
          gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblegyp ERR! node -v v18.20.5gyp ERR! node-gyp -v v10.3.1gyp ERR! not ok
          > aws-crt@1.21.8 install> node ./scripts/install.js
          Could not find tar version 6.2.1
          Looking for tar version 6.2.1 as a dependency...
          Could not find tar version 6.2.1Could not find tarDownloading tar from npm for build...
          npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: glob@11.0.0npm error notsup Not compatible with your version of node/npm: glob@11.0.0npm error notsup Required: {"node":"20 || >=22"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.5"}npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-12-30T11_42_03_774Z-debug-0.logERROR - npm could not download tar! tar is required to build the CRTERROR: Could not download tar! Cannot build CRTThis is likely due to being unable to download the package.Please install tar version undefined and then run the aws-crt install script againIf that does not work, ensure that:* you have npm (node package manager) installed* tar version 6.2.1 is available in your node package registry
          npm error code 1
          npm error path /opt/iobroker/node_modules/aws-crtnpm error command failednpm error command sh -c node ./scripts/install.js
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-12-30T11_41_35_974Z-debug-0.log
          Updating objects from io-package.json for adapter "worx" with version "2.3.4"
          upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
          upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
          upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
          Process exited with code 0
            Thomas Braun Most Active last edited by Thomas Braun
            und nodejs@18 ist veraltet. Installier da NEU ein aktuelles Betriebssystem.
            Diesmal dann in der 64Bit-Lite-Version.
            Ein der Abhängigkeiten benötigt offenbar node@20.
              @thomas-braun OK, also setze ich eine neue SD Karte neu auf, installiere ioBroker neu und lade über Backitup das Update neu rein, dann sollte es funktionieren?
                Jedenfalls sind dann die Chancen besser.
                  was wäre sonst die optimale Vorgehensweise, was sollte ich machen?
                    Neuinstallieren.
                      ticaki last edited by ticaki
                      Falls noch jemand was ergänzen möchte:
                      https://github.com/iobroker-community-adapters/ioBroker.worx/issues/962
                      @mcm1957 FYI
                      ticaki created this issue in iobroker-community-adapters/ioBroker.worx
                      closed One of the dependencies requires node 20 #962
                        @thomas-braun aber das ist doch komplett neu installiert?
                        neue SD
                        neues Betriebssystem
                        ioBoker neu installiert
                        und dann um die Views etc zu behalten das Backup einspielen, oder wie kann ich meine Adapter und Views etc behalten?
                        Thomas Braun T 2 Replies Last reply Reply Quote 0
                          @holzwurm1976
                          Im Backup ist das drin, was du einstellst.
                            @thomas-braun sorry, aber ich verstehe nicht was Du meinst
                              ticaki @Holzwurm1976 last edited by
                              @holzwurm1976
                              und das machst du hier:
                                OK, ich habe ioBroker jetzt neu installiert (geht mittlerweile echt schnell und einfach)
                                Bevor ich jetzt mit den Updates wieder den alten schrotten Mist einspiele meine Fragen?
                                • welche Updates kan ich bedenkenlos einspielen
                                  wie bekomme ich die visualisierungen der VIS und die Scripte wieder ins System
                                  Dein Backitup-Backup.
                                  Mittels Backitup-Backup.
                                    OK, ich habe jetzt alles neu installiert und eingespielt, scheint alles zu laufen und die Adapter konnte ich alle aktualisieren!
                                    Vielen Dank für Eure Hilfe.
                                    Wie kann ich den Beitrag jetzt auf "gelöst" stellen?
                                    • Samson71
                                      Samson71 Global Moderator @Holzwurm1976 last edited by
                                      Den Titel editieren und ein [gelöst] davor setzen.
                                        Holzwurm1976 @Samson71 last edited by
                                        @samson71
                                        Ein Problem ist mir gerade noch aufgefallen:
                                        In den Protokollen bekomme ich eine Warnung, da da lautet:
                                        Cannot read file ("socketio.admin"/"socketio.png"): Not exists
                                          Shadowhunter23 @Holzwurm1976 last edited by
                                          @holzwurm1976
                                          Mach mal ein:
                                          iob upload all
                                            Holzwurm1976 @Shadowhunter23 last edited by Holzwurm1976
                                            @shadowhunter23
                                            das sind zu viele Zeilen, oder mache ich etwas falsch?
                                            4209
