    4. <gelöst>Zigbee ist tod
    • Winni
      Winni @Thomas Braun last edited by
      @thomas-braun Wo anfangen? Soweit läuft jetzt alles. Vielleicht keine schlechte Idee ein ganz neues Image zu machen und dann iobroker neu installieren und Backup einspielen..
        Thomas Braun Most Active @Winni last edited by
        @winni sagte in <gelöst>Zigbee ist tod:
        Wo anfangen?
        Mit einem aktuellen Lauf von
        iob diag
        Winni 1 Reply Last reply Reply Quote 0
        • Winni
          Winni @Thomas Braun last edited by Winni
          @thomas-braun ok 🙂
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.6.62+rpt-rpi-2712
              Architecture: arm64
          OS is similar to:
          Model		: Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           14:05:45 up 57 min,  3 users,  load average: 0.53, 0.89, 0.83
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Wed 2025-01-01 14:05:45 CET
                     Universal time: Wed 2025-01-01 13:05:45 UTC
                           RTC time: Wed 2025-01-01 13:05:45
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          winni
          HOME=/home/winni
          GROUPS=winni adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: true
          Desktop: 	LXDE-pi-labwc
          Terminal: 	wayland
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            8.4G        4.3G        2.2G        144M        2.2G        4.1G
          Swap:           209M          0B        209M
          Total:          8.6G        4.3G        2.4G
          Active iob-Instances: 	49
                   8048 M total memory
                   4121 M used memory
                   4173 M active memory
                   1123 M inactive memory
                   2059 M free memory
                    128 M buffer memory
                   1976 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 14:05:45 up 57 min,  3 users,  load average: 0.53, 0.89, 0.83
          Tasks: 282 total,   2 running, 280 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8048.2 total,   2057.8 free,   4122.8 used,   2105.6 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3925.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     805M  9.2M  796M   2% /run
          /dev/sda2      ext4      219G   30G  178G  15% /
          tmpfs          tmpfs     4.0G   27M  4.0G   1% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/sda1      vfat      511M   77M  435M  15% /boot/firmware
          tmpfs          tmpfs     805M  192K  805M   1% /run/user/1000
          /dev/sdb1      exfat     1.9T  1.5M  1.9T   1% /media/winni/Volume1
          [Wed Jan  1 13:07:57 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:BA:ED:B0 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=6bc658c1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
          [Wed Jan  1 13:07:59 2025] EXT4-fs (sda2): mounted filesystem b8316dab-786b-45e8-815c-3d4bbf198d98 ro with ordered data mode. Quota mode: none.
          [Wed Jan  1 13:08:00 2025] EXT4-fs (sda2): re-mounted b8316dab-786b-45e8-815c-3d4bbf198d98 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET                 SOURCE    FSTYPE      OPTIONS
          /                      /dev/sda2 ext4        rw,noatime
          |-/run/user/1000/doc   portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          |-/boot/firmware       /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          `-/media/winni/Volume1 /dev/sdb1 exfat       rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,iocharset=utf8,errors=remount-ro
          /var:
          5.6G	/var/
          4.3G	/var/cache/apt
          4.3G	/var/cache
          4.2G	/var/cache/apt/archives
          855M	/var/log
          Archived and active journals take up 768.0M in the file system.
          /opt/iobroker/backups:
          449M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          3.4G	/opt/iobroker/iobroker-data/
          1.9G	/opt/iobroker/iobroker-data/history
          1.4G	/opt/iobroker/iobroker-data/files
          617M	/opt/iobroker/iobroker-data/files/javascript.admin
          560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          46M	/opt/iobroker/iobroker-data/objects.jsonl
          38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          30M	/opt/iobroker/iobroker-data/states.jsonl
          26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyUSB0
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v20.18.1
          /usr/bin/node 		v20.18.1
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          /usr/bin/corepack 	0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 3456)
          Core adapters versions
          js-controller: 	7.0.6
          admin: 		7.3.2
          javascript: 	8.8.3
          nodejs modules from github: 	4
          +-- iobroker.bluelink@3.1.0 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#ba4ca016c51236979f898af6d5310defe0e6a2a5)
          +-- iobroker.innogy-smarthome@1.2.6 (git+ssh://git@github.com/PArns/ioBroker.innogy-smarthome.git#8d8039c470db61972352f4578dd80e741e4640e8)
          +-- iobroker.nuki@2.0.0 (git+ssh://git@github.com/smaragdschlange/ioBroker.nuki.git#7bb88d9d2502908c7eadb3b573138b1ed72be910)
          +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.bluelink.0               : bluelink              : raspberrypi                              -  enabled
            system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              - disabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
            system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
            system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
          + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
          + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
          + system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, port: 80
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
            system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: raspberrypi                              - disabled
            system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi                              - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
            system.adapter.icons-smarthome.0        : icons-smarthome       : raspberrypi                              - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
          + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
          + system.adapter.innogy-smarthome.1       : innogy-smarthome      : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
          + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
          + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
          + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
          + system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
          + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.sma-em.0                 : sma-em                : raspberrypi                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sonoff.10                : sonoff                : raspberrypi                              -  enabled, port: 1893, bind: 0.0.0.0
          + system.adapter.sonoff.11                : sonoff                : raspberrypi                              -  enabled, port: 1896, bind: 0.0.0.0
          + system.adapter.sonoff.12                : sonoff                : raspberrypi                              -  enabled, port: 1897, bind: 0.0.0.0
          + system.adapter.sonoff.13                : sonoff                : raspberrypi                              -  enabled, port: 1898, bind: 0.0.0.0
          + system.adapter.sonoff.14                : sonoff                : raspberrypi                              -  enabled, port: 1899, bind: 0.0.0.0
          + system.adapter.sonoff.15                : sonoff                : raspberrypi                              -  enabled, port: 1900, bind: 0.0.0.0
          + system.adapter.sonoff.2                 : sonoff                : raspberrypi                              -  enabled, port: 1894, bind: 0.0.0.0
          + system.adapter.sonoff.3                 : sonoff                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.sonoff.4                 : sonoff                : raspberrypi                              -  enabled, port: 1887, bind: 0.0.0.0
          + system.adapter.sonoff.5                 : sonoff                : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
          + system.adapter.sonoff.6                 : sonoff                : raspberrypi                              -  enabled, port: 1889, bind: 0.0.0.0
          + system.adapter.sonoff.7                 : sonoff                : raspberrypi                              -  enabled, port: 1890, bind: 0.0.0.0
          + system.adapter.sonoff.8                 : sonoff                : raspberrypi                              -  enabled, port: 1891, bind: 0.0.0.0
          + system.adapter.sonoff.9                 : sonoff                : raspberrypi                              -  enabled, port: 1892, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
            system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          âââââââââââ¬âââââââââââ¬ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¬âââââââââââââââ (index) â name     â url                                                     â auto upgrade â
          âââââââââââ¼âââââââââââ¼ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¼âââââââââââââââ¤
          â 0       â 'stable' â 'http://download.iobroker.net/sources-dist.json'        â false        â
          â 1       â 'beta'   â 'http://download.iobroker.net/sources-dist-latest.json' â false        â
          âââââââââââ´âââââââââââ´ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ´âââââââââââââââInstalled ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.3.2
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "bluelink"     : 2.3.6    , installed 3.1.0
          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
          Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
          Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
          Adapter    "hs100"        : 2.2.2    , installed 2.2.2
          Adapter    "hue"          : 3.13.1   , installed 3.13.1
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
          Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
          Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
          Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "operating-hours": 1.2.0  , installed 1.2.0
          Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
          Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "sma-em"       : 1.1.0    , installed 1.1.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
          Objects and States
          Objects: 	32917
          States: 	26616
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8172       1232/pihole-FTL
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6985       959/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          9354       1243/lighttpd
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          9194       1281/smbd
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          9193       1281/smbd
          tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       15312      2944/io.sonoff.10
          tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       21547      3259/io.sonoff.9
          tcp        0      0 0.0.0.0:1894            0.0.0.0:*               LISTEN      1001       18584      3072/io.sonoff.2
          tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       17260      3165/io.sonoff.6
          tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       18153      3140/io.sonoff.5
          tcp        0      0 0.0.0.0:1891            0.0.0.0:*               LISTEN      1001       21530      3244/io.sonoff.8
          tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       20482      3196/io.sonoff.7
          tcp        0      0 0.0.0.0:1900            0.0.0.0:*               LISTEN      1001       18528      3051/io.sonoff.15
          tcp        0      0 0.0.0.0:1897            0.0.0.0:*               LISTEN      1001       16953      2995/io.sonoff.12
          tcp        0      0 0.0.0.0:1896            0.0.0.0:*               LISTEN      1001       16048      2974/io.sonoff.11
          tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       17020      3032/io.sonoff.14
          tcp        0      0 0.0.0.0:1898            0.0.0.0:*               LISTEN      1001       18469      3014/io.sonoff.13
          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       17177      3113/io.sonoff.4
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       17075      3094/io.sonoff.3
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17844      2910/io.sonoff.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11536      946/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10244      946/iobroker.js-con
          tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        8178       1232/pihole-FTL
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7779       945/cupsd
          tcp6       0      0 ::1:4711                :::*                    LISTEN      999        8179       1232/pihole-FTL
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7778       945/cupsd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12176      1632/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19593      3367/io.web.0
          tcp6       0      0 :::53                   :::*                    LISTEN      999        8174       1232/pihole-FTL
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6987       959/sshd: /usr/sbin
          tcp6       0      0 :::80                   :::*                    LISTEN      0          9353       1243/lighttpd
          tcp6       0      0 :::139                  :::*                    LISTEN      0          9192       1281/smbd
          tcp6       0      0 :::445                  :::*                    LISTEN      0          9191       1281/smbd
          udp        0      0 0.0.0.0:35925           0.0.0.0:*                           1001       20000      3610/io.echarts.0
          udp        0      0 0.0.0.0:44266           0.0.0.0:*                           1001       12946      2360/io.email.0
          udp        0      0 0.0.0.0:40239           0.0.0.0:*                           1001       23192      3977/io.zigbee.0
          udp        0      0 0.0.0.0:56826           0.0.0.0:*                           1001       17815      2871/io.sma-em.0
          udp        0      0 0.0.0.0:44754           0.0.0.0:*                           1001       8071       946/iobroker.js-con
          udp        0      0 0.0.0.0:48938           0.0.0.0:*                           1001       17566      2790/io.ping.0
          udp        0      0 0.0.0.0:40925           0.0.0.0:*                           1001       20579      3337/io.vis-inventw
          udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8171       1232/pihole-FTL
          udp        0      0 0.0.0.0:53331           0.0.0.0:*                           1001       21629      3321/io.tr-064.1
          udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          8148       1250/nmbd
          udp        0      0 192.168.1.134:137       0.0.0.0:*                           0          8147       1250/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          8135       1250/nmbd
          udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          8150       1250/nmbd
          udp        0      0 192.168.1.134:138       0.0.0.0:*                           0          8149       1250/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          8136       1250/nmbd
          udp        0      0 0.0.0.0:37349           0.0.0.0:*                           104        7705       748/avahi-daemon: r
          udp        0      0 0.0.0.0:57927           0.0.0.0:*                           1001       19097      3432/io.energieflus
          udp        0      0 0.0.0.0:53941           0.0.0.0:*                           1001       20863      3502/io.hs100.0
          udp        0      0 0.0.0.0:58118           0.0.0.0:*                           1001       14125      2476/io.alexa2.0
          udp        0      0 0.0.0.0:37760           0.0.0.0:*                           1001       16635      2819/io.rpi2.0
          udp        0      0 0.0.0.0:58421           0.0.0.0:*                           1001       14910      2651/io.modbus.0
          udp        0      0 0.0.0.0:33894           0.0.0.0:*                           1001       10235      2342/io.javascript.
          udp        0      0 0.0.0.0:58508           0.0.0.0:*                           1001       14980      2688/io.modbus.2
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7703       748/avahi-daemon: r
          udp        0      0 0.0.0.0:34032           0.0.0.0:*                           1001       17483      2745/io.netatmo.0
          udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       17820      2871/io.sma-em.0
          udp        0      0 0.0.0.0:54942           0.0.0.0:*                           1001       21801      3450/io.fb-checkpre
          udp        0      0 0.0.0.0:38571           0.0.0.0:*                           1001       13399      1632/io.admin.0
          udp        0      0 0.0.0.0:34505           0.0.0.0:*                           1001       15586      2667/io.modbus.1
          udp        0      0 0.0.0.0:34568           0.0.0.0:*                           1001       15446      2569/io.backitup.0
          udp        0      0 0.0.0.0:51181           0.0.0.0:*                           1001       21719      3382/io.bluelink.0
          udp        0      0 0.0.0.0:34990           0.0.0.0:*                           1001       15783      2775/io.operating-h
          udp        0      0 0.0.0.0:43287           0.0.0.0:*                           1001       19811      3519/io.iot.0
          udp        0      0 0.0.0.0:39245           0.0.0.0:*                           1001       15477      2588/io.hue.1
          udp        0      0 0.0.0.0:35203           0.0.0.0:*                           1001       14303      2636/io.innogy-smar
          udp        0      0 0.0.0.0:43419           0.0.0.0:*                           1001       22002      3591/io.sourceanaly
          udp        0      0 0.0.0.0:35497           0.0.0.0:*                           1001       19908      3546/io.pvforecast.
          udp6       0      0 :::53                   :::*                                999        8173       1232/pihole-FTL
          udp6       0      0 fe80::67fb:be67:45b:546 :::*                                0          9415       901/NetworkManager
          udp6       0      0 :::54203                :::*                                104        7706       748/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        7704       748/avahi-daemon: r
          2025-01-01 14:00:00.017  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.16.1" started with pid 20158
          2025-01-01 14:00:00.054  - info: javascript.0 (2342) script.js.common.Energie.Geräte.Wp-Ein-Ausschalttemperatur: -0.66
          2025-01-01 14:00:00.055  - info: javascript.0 (2342) script.js.common.Energie.Geräte.Wp-Ein-Ausschalttemperatur: 123
          2025-01-01 14:00:00.056  - info: javascript.0 (2342) script.js.common.Energie.Geräte.Wp-Ein-Ausschalttemperatur: 55
          2025-01-01 14:00:00.056  - info: javascript.0 (2342) script.js.common.Energie.Geräte.Wp-Ein-Ausschalttemperatur: 50
          2025-01-01 14:00:04.028  - info: host.raspberrypi instance system.adapter.daswetter.0 in version "3.2.2" started with pid 20184
          2025-01-01 14:00:08.371  - info: host.raspberrypi instance system.adapter.daswetter.0 having pid 20184 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-01-01 14:00:08.761  - info: host.raspberrypi instance system.adapter.ical.0 having pid 20158 terminated with code 0 (NO_ERROR)
          2025-01-01 14:00:12.016  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 20244
          2025-01-01 14:00:14.481  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 20244 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-01-01 14:01:30.056  - info: javascript.0 (2342) script.js.common.Energie.Geräte.Wp-Ein-Ausschalttemperatur: 125
          2025-01-01 14:01:48.339  - info: admin.0 (1632) <== Disconnect system.user.admin from ::ffff:192.168.1.134
          2025-01-01 14:01:48.384  - info: admin.0 (1632) <== Disconnect system.user.admin from ::ffff:192.168.1.134 admin
          2025-01-01 14:02:45.470  - info: admin.0 (1632) <== Disconnect system.user.admin from ::ffff:192.168.1.134 admin
          2025-01-01 14:04:00.039  - info: javascript.0 (2342) script.js.Sonstiges.Zieltemperaturen-Pruefen: Im Raum Einieger 2 wurde die Zieltemperatur  übernommen
          Copy text starting here:
          			v.2024-10-19
                 Icon name: computer
              Architecture: arm64
          Installation: 		native
          Kernel: 		aarch64
          Userland: 		64 bit
          Timezone: 		Europe/Berlin (CET, +0100)
          User-ID: 		1000
          Boot Target: 		graphical.target
          Pending OS-Updates: 	0
          Pending iob updates: 	0
          Nodejs-Installation:
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          Recommended versions are nodejs 20.18.1 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            8.4G        4.4G        2.0G        151M        2.3G        4.1G
          Swap:           209M          0B        209M
          Total:          8.6G        4.4G        2.2G
          Upgrade policy: none
          ioBroker Core: 		js-controller 		7.0.6
          			admin 			7.3.2
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		32917
          States: 		26616
          Size of iob-Database:
          31M	/opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          Edit: Die 15 CRITICAL ERRORS DETECTED! sind scheinbar weg, ich kann sie nicht mehr finden.
            Schalt den Desktop aus und stell auf multi-user um! Geht per 'iob fix'.
            USB-Devices by-id:
            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
            HINT:
            /dev/ttyUSB0
            Stell den COM-Port im zigbee-Adapter auf
            /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 statt /dev/ttyUSB0
            Prüfe, ob die alle aus dem GitHub kommen müssen oder ob nicht 'ordentliche' Versionen aus dem Repo verfügbar sind.
            Räum den Wildwuchs beim sonoff-Adapter auf. Jede Instanz verbraucht einen Port und weitere Ressourcen.
            Vermeide Umlaute und sonstigen Sonderzeichen-Unfug in Dateinamen:
            • Winni
              @thomas-braun Den Port vom Zigbee habe ich geändert. Desktop abschalten möchte ich eigentlich nicht, weil der Raspi auch mein Desktop-Computer ist, den nutze ich auch zum surfen und andere Sachen. Vielleicht richte ich mir da da noch mal einen zweiten ein. Der bluelink ist von github, aber der Innogy und der Nuki Adapter doch nicht. Beim sonoff Adapter steh ich völlig auf dem Schlauch, wie kann man damit mehrer Dosen auf einer Instanz betreiben? Jede Dose braucht doch ihren eigenen Port und in der Instanz kann ich nur einen Port angeben.
              Thomas Braun Homoran Meister Mopper 3 Replies Last reply Reply Quote 0
                Ganz ungünstige Konstellation.
                Natürlich sind die aus dem GitHub installiert... Sonst würden die dort nicht aufgeführt.
                Ich hab den selber nicht im Einsatz, aber bei anderen Adaptern braucht es ja auch natürlich nicht pro Gerät eine Instanz. Wird also beim sonoff nicht anders sein.
                  Homoran Global Moderator Administrators @Winni last edited by
                  ist nicht unbedingt das sicherste für einen Server.
                  Internet Security läuft doch und zieht Ressourcen?
                  • Winni
                    @thomas-braun sagte in <gelöst>Zigbee ist tod:
                    Natürlich sind die aus dem GitHub installiert... Sonst würden die dort nicht >aufgeführt.
                    Ich hatte die aus dem GitHub installiert, sind jetzt aber im stable Repositorie. Kann ich das ändern ohne zu löschen und neu installieren?
                    Beim sonff sehe ich keine Möglichkeit mehrere Dosen mit einer Instanz zu steuern, vielleicht geht das mit einem anderen Adapter. Ich werde mal ein bisschen hier im Forum suchen..
                      Ja, einfach den Adapter wie üblich drüber installieren. GitHub ist NICHT der übliche Weg.
                      • Winni
                        @thomas-braun Normalerweise bin ich da auch sehr vorsichtig, aber wenn eine Funktion verfügbar sind die ich unbedingt nutzen möchte, oder ich bei einer Adapteretwicklung mit testen helfen möchte, dann geht es halt nicht anders. Mal schauen wie das mit dem drüber installieren geht.
                        • Winni
                          Winni @Homoran last edited by
                          @homoran Performance Probleme habe ich mit dem Raspberry pi5 keine. Ich surfe auch keine fragwürdigen Seiten an. Ich bin da eher übervorsichtig.
                          • Meister Mopper
                            Meister Mopper @Winni last edited by
                            Indem man dieselbe Konfiguration bei jedem Sonoff-Gerät verwendet.
                            Winni 1 Reply Last reply Reply Quote 1
                            • Winni
                              Winni @Meister Mopper last edited by
                              @meister-mopper das sieht toll aus. nur alle Dosen den gleichen Port zuweisen. Manchmal sieht man den Wald vor lauter Bäumen nicht. Schon lange nicht mehr soviel über iobroker an einem Tag dazu gelernt wie heute. 😀
                                der Port ist der Port des Adapters auf dem Server.
                                Der muss identisch sein, um in der gleichen Instanz zu landen
                                • Winni
                                  @homoran ja, das war mein Denkfehler, ich dachte über den Port wird die Dose gesteuert.
                                  • Asgothian
                                    Asgothian Developer last edited by
                                    Wird ja auch. Nur das der Port halt wie ein Fenster ist. Alle Steckdosen können da ihre Nachrichten 'hinein' werfen, solange sie den Absender drauf schreiben. Und der Adapter schickt dann die Antworten an die entsprechende Absende-IP 🙂
                                    • Winni
                                      Winni @Asgothian last edited by
                                      @asgothian ok, danke
                                      update problem zigbee zigbee zigbee läuft nicht mehr
                                      1939
