    4. Support Adapter Energiefluss-erweitert v0.7.7
    • SKB
      SKB Developer Most Active @Fenrir last edited by
      @fenrir So sieht das Log nicht aus.
      Bitte die vollständigen Log Einträge posten.
        2025-01-01 12:50:58.987 - info: admin.0 (125596) ==> Connected system.user.admin from ::ffff:192.168.178.20
        2025-01-01 12:50:59.140 - info: zigbee.0 (125932) List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
        2025-01-01 12:51:05.423 - info: admin.0 (125596) <== Disconnect system.user.admin from ::ffff:192.168.178.20
        2025-01-01 12:51:05.426 - info: admin.0 (125596) <== Disconnect system.user.admin from ::ffff:192.168.178.20 admin
        2025-01-01 12:54:50.079 - info: admin.0 (125596) ==> Connected system.user.admin from ::ffff:192.168.178.20
        2025-01-01 12:55:01.002 - info: host.iobroker "system.adapter.energiefluss-erweitert.0" enabled
        2025-01-01 12:55:01.355 - warn: web.0 (126173) Terminated (-100): Without reason
        2025-01-01 12:55:01.445 - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 126205
        2025-01-01 12:55:01.863 - warn: web.0 (126173) setTimeout called, but adapter is shutting down
        2025-01-01 12:55:01.901 - info: host.iobroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2025-01-01 12:55:01.901 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
        2025-01-01 12:55:02.221 - info: energiefluss-erweitert.0 (126205) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.1, js-controller: 7.0.6
        2025-01-01 12:55:02.238 - info: energiefluss-erweitert.0 (126205) Adapter started. Loading config!
        2025-01-01 12:55:02.344 - info: energiefluss-erweitert.0 (126205) Calculation for ID 4 is valid, as the element is still in use!
        2025-01-01 12:55:02.344 - info: energiefluss-erweitert.0 (126205) Calculation for ID 6 is valid, as the element is still in use!
        2025-01-01 12:55:02.505 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:02.548 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:02.681 - info: energiefluss-erweitert.0 (126205) Configuration loaded!
        2025-01-01 12:55:02.681 - info: energiefluss-erweitert.0 (126205) Requesting the following states: energiefluss-erweitert.0.configuration,plenticore.0.devices.local.Pv_P,plenticore.0.devices.local.Home_P,plenticore.0.devices.local.ToGrid_P,plenticore.0.devices.local.HomeGrid_P,plenticore.0.devices.local.battery.Charge_P,plenticore.0.devices.local.HomeBat_P,plenticore.0.devices.local.battery.SoC,go-e.0.energy.power,go-e.1.energy.power,sonoff.0.Spülmaschine.ENERGY_Power,sonoff.0.Waschmaschine.ENERGY_Power
        2025-01-01 12:55:03.224 - info: host.iobroker instance system.adapter.web.0 in version "6.3.1" started with pid 126220
        2025-01-01 12:55:04.115 - info: web.0 (126220) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
        2025-01-01 12:55:04.194 - info: web.0 (126220) socket.io server listening on port 8082
        2025-01-01 12:55:04.229 - info: web.0 (126220) Connecting extension "energiefluss-erweitert/lib/web.js"
        2025-01-01 12:55:04.233 - info: web.0 (126220) http server listening on port 8082
        2025-01-01 12:55:05.224 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:08.602 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:12.555 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:15.785 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:18.905 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:22.182 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:25.055 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:28.083 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:31.081 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:34.378 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:37.459 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:40.411 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:46.673 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:49.811 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:52.713 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:55.849 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:55:58.923 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:02.222 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:05.258 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:08.457 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:11.687 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:15.380 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:18.598 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:21.803 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:25.292 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:28.288 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:31.422 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:34.629 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:37.735 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:40.636 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:43.961 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:47.127 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:50.049 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:53.041 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:56.201 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:56:59.176 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:02.188 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:05.182 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:08.287 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:11.637 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:15.114 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:18.462 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:21.437 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:24.703 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:27.871 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:31.051 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:34.202 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:37.305 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:40.192 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:43.298 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:46.227 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:49.439 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:52.429 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:55.438 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:57:58.479 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:01.807 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:04.951 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:08.026 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:10.938 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:14.529 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:17.479 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:20.573 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:23.613 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:26.786 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:30.033 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:32.958 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:36.171 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:39.468 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:42.499 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:45.545 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:48.563 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:51.911 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:55.116 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:58:57.955 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:01.063 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:04.054 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:07.293 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:10.064 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:13.173 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:16.170 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:19.538 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:22.429 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:25.386 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:28.584 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:31.559 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:34.736 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:37.723 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:44.329 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:47.310 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:50.196 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:53.200 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:56.284 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 12:59:59.456 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:00.014 - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 126236
        2025-01-01 13:00:00.937 - info: ical.0 (126236) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.1, js-controller: 7.0.6
        2025-01-01 13:00:01.401 - info: ical.0 (126236) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/i9l5irbfrmqbutk6rm6lh8hi9g%40group.calendar.google.com/private-1c020a68ee512cc556db88b9f94e1308/basic.ics
        2025-01-01 13:00:03.261 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:04.021 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.2" started with pid 126251
        2025-01-01 13:00:04.829 - info: daswetter.0 (126251) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
        2025-01-01 13:00:05.243 - info: daswetter.0 (126251) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-01-01 13:00:05.750 - info: daswetter.0 (126251) cleaned everything up...
        2025-01-01 13:00:05.757 - info: host.iobroker instance system.adapter.daswetter.0 having pid 126251 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-01-01 13:00:06.513 - info: ical.0 (126236) Terminated (NO_ERROR): Without reason
        2025-01-01 13:00:07.026 - info: host.iobroker instance system.adapter.ical.0 having pid 126236 terminated with code 0 (NO_ERROR)
        2025-01-01 13:00:07.154 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:10.275 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:13.455 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:16.569 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:19.638 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:22.588 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:25.565 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:28.453 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:31.769 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:34.941 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:37.935 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:41.331 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:44.893 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:48.003 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:50.911 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:53.885 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:56.776 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:00:59.969 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:03.006 - warn: energiefluss-erweitert.0 (126205) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:05.404 - info: host.iobroker "system.adapter.energiefluss-erweitert.0" disabled
        2025-01-01 13:01:05.404 - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 (force=false, process=true)
        2025-01-01 13:01:05.408 - info: energiefluss-erweitert.0 (126205) Got terminate signal TERMINATE_YOURSELF
        2025-01-01 13:01:05.409 - info: energiefluss-erweitert.0 (126205) Cleared interval for relative values!
        2025-01-01 13:01:05.410 - info: energiefluss-erweitert.0 (126205) terminating
        2025-01-01 13:01:05.410 - info: energiefluss-erweitert.0 (126205) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-01-01 13:01:05.412 - warn: web.0 (126220) Terminated (-100): Without reason
        2025-01-01 13:01:05.456 - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 send kill signal
        2025-01-01 13:01:05.911 - info: energiefluss-erweitert.0 (126205) terminating
        2025-01-01 13:01:05.920 - warn: web.0 (126220) setTimeout called, but adapter is shutting down
        2025-01-01 13:01:05.949 - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-01-01 13:01:06.008 - info: host.iobroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2025-01-01 13:01:06.008 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
        2025-01-01 13:01:07.298 - info: host.iobroker instance system.adapter.web.0 in version "6.3.1" started with pid 126266
        2025-01-01 13:01:08.190 - info: web.0 (126266) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
        2025-01-01 13:01:08.270 - info: web.0 (126266) socket.io server listening on port 8082
        2025-01-01 13:01:08.273 - info: web.0 (126266) http server listening on port 8082
        2025-01-01 13:01:42.261 - info: host.iobroker "system.adapter.energiefluss-erweitert.0" enabled
        2025-01-01 13:01:42.560 - warn: web.0 (126266) Terminated (-100): Without reason
        2025-01-01 13:01:42.784 - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 126281
        2025-01-01 13:01:43.067 - warn: web.0 (126266) setTimeout called, but adapter is shutting down
        2025-01-01 13:01:43.112 - info: host.iobroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2025-01-01 13:01:43.112 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
        2025-01-01 13:01:43.547 - info: energiefluss-erweitert.0 (126281) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.1, js-controller: 7.0.6
        2025-01-01 13:01:43.564 - info: energiefluss-erweitert.0 (126281) Adapter started. Loading config!
        2025-01-01 13:01:43.633 - info: energiefluss-erweitert.0 (126281) Calculation for ID 4 is valid, as the element is still in use!
        2025-01-01 13:01:43.633 - info: energiefluss-erweitert.0 (126281) Calculation for ID 6 is valid, as the element is still in use!
        2025-01-01 13:01:43.795 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:43.797 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:44.011 - info: energiefluss-erweitert.0 (126281) Configuration loaded!
        2025-01-01 13:01:44.011 - info: energiefluss-erweitert.0 (126281) Requesting the following states: energiefluss-erweitert.0.configuration,plenticore.0.devices.local.Pv_P,plenticore.0.devices.local.Home_P,plenticore.0.devices.local.ToGrid_P,plenticore.0.devices.local.HomeGrid_P,plenticore.0.devices.local.battery.Charge_P,plenticore.0.devices.local.HomeBat_P,plenticore.0.devices.local.battery.SoC,go-e.0.energy.power,go-e.1.energy.power,sonoff.0.Spülmaschine.ENERGY_Power,sonoff.0.Waschmaschine.ENERGY_Power
        2025-01-01 13:01:44.386 - info: host.iobroker instance system.adapter.web.0 in version "6.3.1" started with pid 126296
        2025-01-01 13:01:45.272 - info: web.0 (126296) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
        2025-01-01 13:01:45.351 - info: web.0 (126296) socket.io server listening on port 8082
        2025-01-01 13:01:45.385 - info: web.0 (126296) Connecting extension "energiefluss-erweitert/lib/web.js"
        2025-01-01 13:01:45.390 - info: web.0 (126296) http server listening on port 8082
        2025-01-01 13:01:45.785 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:48.637 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:51.573 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:54.774 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:01:57.910 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:00.766 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:03.774 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:07.000 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:09.981 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:13.003 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:15.925 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:18.971 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:22.207 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:25.195 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:28.246 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        2025-01-01 13:02:31.359 - warn: energiefluss-erweitert.0 (126281) Calculation for battery-remaining failed! Error: TypeError: Cannot read properties of undefined (reading 'factor')
        • JLeg
          JLeg last edited by
          Hallo & ein frohes Neues,
          kleiner Kosmetikbug: Verbindung löschen, Kontextmenü (rechte Maustaste): Menü ist ausgegraut, Zeiger zeigt Parkverbot - Löschen klappt aber trotzdem. Wobei ich es praktisch fände, wenn beim Löschen über's Kontextmenü - genau wie beim "Aktionen"-Menü rechts - keine "willst du wirklich?" Rückfrage käme (beim Tastendruck "Del" bleibt's natürlich sinnvoll).
          Was dabei noch aufgefallen ist - "Undo" (Strg-Z) gibt's wohl nur beim Löschen per Kontextmenü oder "Del" - nicht beim Löschen über's "Aktionen"-Menü...
          Und was ich entweder nicht gefunden habe, oder nur ein frommer Wunsch ist: Gibt's (k)einen Magnetismus (snap to grid) wenn's Grid aktiviert ist? Fände ich sehr hilfreich... 🙂
          • SKB
            SKB Developer Most Active @JLeg last edited by
            @jleg Danke - für dich natürlich auch.
            Diese Dinge überarbeite ich gerade, damit es ein einheitliches 'Undo' und 'Redo' gibt.
            Auch wird es ein Snap geben - leider komme ich erst nach den Feiertagen dazu, weil's doch umfangreicher ist, als anfangs angenommen 😉
            • SKB
              @fenrir Temporär bitte bei den Datenpunkten den Faktor angeben. Dies kam neu hinzu.
              • wendy2702
                wendy2702 last edited by
                Hallo zusammen und Frohes neues Jahr,
                ich bin leider seid einiger Zeit nicht wirklich zur Systempflege gekommen. Deshalb gibt es jetzt hier noch diesen Stau 🙂
                Was muss ich beachten wenn ich das Update mache?
                • Merlin123
                  Merlin123 @wendy2702 last edited by
                  @wendy2702 Ich konnte einfach aktualisieren. 🙂
                  • wendy2702
                    wendy2702 @Merlin123 last edited by
                    @merlin123 auch von so einer „alten“ Version in einem Schritt?
                    • SKB
                      SKB Developer Most Active @wendy2702 last edited by
                      @wendy2702 Alle Versionen sind miteinander kompatibel. Problemlose up- und downgrades möglich 😉
                      Einzige Problematik, die auftreten kann - bei den Datenquellen muss nun der Faktor der Datenquelle angegeben werden. Das kann man problemlos nach dem Update nachholen/erledigen!
                        Ich habe doch schon überall einen Faktor drin stehen oder gilt die 1 nicht als Faktor?
                        • SKB
                          @fenrir Wenn du einen Faktor drin hast, sollte die Berechnung funktionieren.
                          Ansonsten den Adapter einmal auf Debug stellen und den Bereich einstellen, der mit der Berechnung zu tun haben.
                          • wendy2702
                            So, update lief durch.
                            Kann ich die Hinweise bei CSS ignorieren?
                            Bildschirmfoto 2025-01-02 um 19.06.06.png Bildschirmfoto 2025-01-02 um 19.06.14.png
                            • SKB
                              @wendy2702 Hinweise können ignoriert werden - funktioniert trotzdem weiterhin 😉
                                Danke, habe den Fehler gefunden, unter der Berechnung war das Feld für die Batteriekapazität leer (was mich allerdings wundert da ich im am Adapter nichts verändert hab)
                                  warp735 last edited by warp735
                                  @skb
                                  Da der Adapter nun im stable ist, fang ich auch mal an zu spielen. Leider ruckelt bei mir die Animation. Auch mit Energiesparmodus. Habe ich mit dem einfachen Energiefluss Adapter nicht.
                                  btw. beide zusammen laufen auch nicht richtig. Muss immer den jeweils anderen abschalten.
                                  CPU: 1.67 %
                                  RAM: 10 %
                                  Betriebszeit: 8d23h
                                  Verfügbar: 7.0.6
                                  Installiert: 7.0.6
                                  Ereignisse: ⇥32 / ↦13
                                  Plattform: docker (official image - v10.0.0)
                                  Betriebssystem: linux
                                  Architektur: x64
                                  CPUs: 4
                                  Geschwindigkeit: 4003 MHz
                                  Modell: Intel(R) Core(TM) i3-9100 CPU @ 3.60GHz
                                  RAM: 62.5 GB
                                  System-Betriebszeit: 128 T. 19:22:03
                                  Node.js: v20.18.1
                                  time: 1736234838928
                                  timeOffset: -60
                                  NPM: 10.8.2
                                  Adapter-Anzahl: 554
                                  Datenträgergröße: 20.0 GB
                                  Freier Festplattenspeicher: 13.7 GB
                                  Aktive Instanzen: 32
                                  Pfad: /opt/iobroker/
                                  Betriebszeit: 8 T. 19:38:12
                                  • SKB
                                    SKB Developer Most Active @warp735 last edited by SKB
                                    @warp735 Die Animation läuft auf so gut wie jedem Endgerät ruckelfrei - außer auf einem sehr alten Smartphone, Tablet oder Kühlschrank. Dies ist nicht davon anhängig, wie leistungsstark der ioBroker-Server ist.
                                    Wieso sollten "beide Adapter zusammen nicht richtig laufen?
                                      warp735 @SKB last edited by
                                      @skb
                                      Hab gerade mal mit Edge Browser probiert. Da läufts flüssig. Scheint also an Firefox zu liegen.
                                      • SKB
                                        @warp735
                                        Firefox 133.0.3
                                        Chrome 131.0.6778.205
                                        Edge 131.0.2903.112
                                        Alles problemlos.
                                          @skb
                                          Schön für dich... 😂
                                          Bei mir leider nicht. Hab aber auch ne ältere Version. Ist nicht so tragisch. Nur komisch das der alte flüssig läuft.
                                          • SKB
                                            @warp735 Der alte Adapter verwendet andere Animationen. Mit dem Energiesparmodus läuft es auch nicht flüssig(er)?
                                            W 2 Replies Last reply Reply Quote 0
                                            vis
                                            192
                                            4365
                                            5688710
