    4. Test Adapter rpi2 2.x
      Smallfeuer @Smallfeuer last edited by Smallfeuer
      @Homoran @thomas-braun
      rpi2.0
      2024-12-30 14:38:37.582	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
      rpi2.0
      2024-12-30 14:38:37.581	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
      rpi2.0
      2024-12-30 14:38:37.579	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
      rpi2.0
      2024-12-30 14:38:33.471	info	starting. Version 2.3.0 (non-npm: iobroker-community-adapters/ioBroker.rpi2#9c52326d12cf43e152fca1daedb16389cead6fb6) in /opt/iobroker/node_modules/iobroker.rpi2, node: v23.5.0, js-controller: 7.0.6
      host.pi3garage
      2024-12-30 14:38:29.335	info	instance system.adapter.rpi2.0 in version "2.3.0" (non-npm: iobroker-community-adapters/ioBroker.rpi2#9c52326d12cf43e152fca1daedb16389cead6fb6) started with pid 1493
      host.pi3garage
      2024-12-30 14:38:15.164	info	instance system.adapter.rpi2.0 terminated with code null ()
      host.pi3garage
      2024-12-30 14:38:15.163	warn	instance system.adapter.rpi2.0 terminated due to SIGKILL
      host.pi3garage
      2024-12-30 14:38:14.475	info	stopInstance timeout system.adapter.rpi2.0 killing pid 1485
      host.pi3garage
      2024-12-30 14:38:13.473	info	stopInstance system.adapter.rpi2.0 send kill signal
      host.pi3garage
      2024-12-30 14:38:13.343	info	stopInstance system.adapter.rpi2.0 (force=false, process=true)
      host.pi3garage
      2024-12-30 14:38:12.435	info	instance system.adapter.rpi2.0 in version "2.3.0" (non-npm: iobroker-community-adapters/ioBroker.rpi2#9c52326d12cf43e152fca1daedb16389cead6fb6) started with pid 1485
      host.pi3garage
      2024-12-30 14:38:00.516	info	iobroker exit 0
      host.pi3garage
      2024-12-30 14:37:59.414	info	iobroker host.pi3garage object system.adapter.rpi2.0 created
      host.pi3garage
      2024-12-30 14:37:59.353	info	iobroker host.pi3garage object system.adapter.rpi2.0.logLevel created
      host.pi3garage
      2024-12-30 14:37:59.294	info	iobroker host.pi3garage object system.adapter.rpi2.0.sigKill created
      host.pi3garage
      2024-12-30 14:37:59.234	info	iobroker host.pi3garage object system.adapter.rpi2.0.eventLoopLag created
      host.pi3garage
      2024-12-30 14:37:59.178	info	iobroker host.pi3garage object system.adapter.rpi2.0.outputCount created
      host.pi3garage
      2024-12-30 14:37:59.122	info	iobroker host.pi3garage object system.adapter.rpi2.0.inputCount created
      host.pi3garage
      2024-12-30 14:37:59.061	info	iobroker host.pi3garage object system.adapter.rpi2.0.uptime created
      host.pi3garage
      2024-12-30 14:37:59.013	info	iobroker host.pi3garage object system.adapter.rpi2.0.memRss created
      host.pi3garage
      2024-12-30 14:37:58.962	info	iobroker host.pi3garage object system.adapter.rpi2.0.memHeapTotal created
      host.pi3garage
      2024-12-30 14:37:58.906	info	iobroker host.pi3garage object system.adapter.rpi2.0.memHeapUsed created
      host.pi3garage
      2024-12-30 14:37:58.851	info	iobroker host.pi3garage object system.adapter.rpi2.0.cputime created
      host.pi3garage
      2024-12-30 14:37:58.790	info	iobroker host.pi3garage object system.adapter.rpi2.0.cpu created
      host.pi3garage
      2024-12-30 14:37:58.734	info	iobroker host.pi3garage object system.adapter.rpi2.0.compactMode created
      host.pi3garage
      2024-12-30 14:37:58.678	info	iobroker host.pi3garage object system.adapter.rpi2.0.connected created
      host.pi3garage
      2024-12-30 14:37:58.618	info	iobroker host.pi3garage object system.adapter.rpi2.0.alive created
      host.pi3garage
      2024-12-30 14:37:58.562	info	iobroker host.pi3garage create instance rpi2
      host.pi3garage
      2024-12-30 14:37:50.686	info	iobroker add rpi2 auto --host pi3garage --debug
      host.pi3garage
      2024-12-30 14:31:40.001	info	iobroker exit 0
      host.pi3garage
      2024-12-30 14:31:36.084	info	iobroker Updating objects from io-package.json for adapter "rpi2" with version "2.3.0"
      host.pi3garage
      2024-12-30 14:31:35.864	info	iobroker upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
      host.pi3garage
      2024-12-30 14:31:35.714	info	iobroker upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
      host.pi3garage
      2024-12-30 14:31:35.603	info	iobroker upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
      host.pi3garage
      2024-12-30 14:31:35.425	info	iobroker upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:35.293	info	iobroker upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:35.080	info	iobroker upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.982	info	iobroker upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.896	info	iobroker upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.781	info	iobroker upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.684	info	iobroker upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.564	info	iobroker upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.393	info	iobroker upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.288	info	iobroker upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:34.125	info	iobroker upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      host.pi3garage
      2024-12-30 14:31:22.448	info	iobroker up to date in 3m57 packages are looking for funding run `npm fund` for details
      host.pi3garage
      2024-12-30 14:28:09.019	info	iobroker Installing iobroker-community-adapters/ioBroker.rpi2#9c52326d12cf43e152fca1daedb16389cead6fb6... (System call)
      host.pi3garage
      2024-12-30 14:28:09.016	info	iobroker NPM version: 10.9.2
      host.pi3garage
      2024-12-30 14:28:08.497	info	iobroker install iobroker-community-adapters/ioBroker.rpi2#9c52326d12cf43e152fca1daedb16389cead6fb6
      host.pi3garage
      2024-12-30 14:28:03.035	info	iobroker url https://github.com/iobroker-community-adapters/ioBroker.rpi2.git --host pi3garage --host pi3garage --debug
      In dem Files Pfad taucht allerdings kein rpi2.admin auf. Aber vielleicht hat er da auch nichts zu suchen. Diesen finde ich nur auf dem Master. Das Thema hatten wir gestern bereits angekratzt.
      smallfeuer@pi3garage:/opt/iobroker/iobroker-data/files $ dir
      admin.admin  backitup.admin  discovery.admin
      @smallfeuer sagte in Test Adapter rpi2 2.x:
      Der Pfad /opt/iobroker/iobroker-date/files/rpi2.admin wurde bei mir auf dem Master erstellt. Nicht auf dem Slave. Ist das korrekt? Wäre es nicht sinnvoll das die Daten auf dem Slave installiert werden?
        stenmic @stoffel67 last edited by stenmic
        ich wollte heute den Adapter auf einem neuen System endlich testen.
        Pi4 mit Pi OS Lite (64-bit Bookworm)
        Nach dem Start kommt fogende Meldung
        rpi2.0
        	2025-01-01 12:55:44.374	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
        rpi2.0
        	2025-01-01 12:55:44.373	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
        rpi2.0
        	2025-01-01 12:55:44.372	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
        Reading package lists... Done
        Building dependency tree... Done
        libgpiod-dev is already the newest version (1.6.3-1+b3).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        npm list | grep opengpio zeigt nix an.
        Ich möchte lediglich den Reeder meiner Gasuhr einbinden.
        Jemand einen Tipp für mich?
          Thomas Braun Most Active @stenmic last edited by
          @stenmic sagte in Test Adapter rpi2 2.x:
          Kann auch nicht. Der Befehl lautet
          cd /opt/iobroker && npm ls opengpio
          S 2 Replies Last reply Reply Quote 1
            stenmic @Thomas Braun last edited by
            @thomas-braun sagte in Test Adapter rpi2 2.x:
            dann komm das hier
            pi@Smartmeter:~ $ cd /opt/iobroker && npm ls opengpio
            iobroker.inst@3.0.0 /opt/iobroker
            └─┬ iobroker.rpi2@2.2.1
              └── opengpio@1.0.17
            pi@Smartmeter:/opt/iobroker $
              @thomas-braun muss ich noch etwas unter "raspi-config" einstellen?
                @stenmic
                  2024-12-30 12:24:43.719 warn Cannot initialize GPIO: No chip found. GPIO functionality disabled!
                  Ist das im
                  rpi-config
                  aktiviert?
                  was muss denn in der config aktiviert werden?
                    @stenmic
                    'Früher' konnte man da soweit ich weiß die GPIOs einstellen. Ist aber wohl rausgefallen.
                      Smallfeuer @Thomas Braun last edited by
                      @stenmic
                      @Homoran
                      Wenn ich es richtig sehe liegt der Fehler in der Initialisierung des richtigen Pi. Der Fehler läuft also in der Abfrage in der Datei gpioControl.js in den Fehler.
                      Pi kleiner 5 sollte hier also gpio Chip 0 sein. ansonsten 4.
                      Vielleicht sieht hier einer von euch das Problem: Zeile 9 liest er das Model aus, oder versucht es aus der Info:
                      der Befehl
                      cat /proc/cpuinfo
                      ergibt bei mir in der letzten Zeile:
                      "Model           : Raspberry Pi 3 Model B Rev 1.2"
                      was hier anscheinend abgefragt wird - mal ein Ausschnitt aus der Datei - am Ende unsere Fehlermeldung:
                      function getRaspberryModelFromCpuInfo(cpuinfo) {
                          //Zero reports: Raspberry Pi Zero 2 W Rev 1.0
                          // RPi Zero family has a different naming.
                          // All Rpi Zero share the same ChipNum as RPi 1 and thus can all be handled as a Rpi 1.
                          if (cpuinfo.includes('Zero')) {
                              return 1;
                          const modelRegEx = /^Raspberry Pi (\d+) Model.*/mi;
                          const model = modelRegEx.exec(cpuinfo)[1];
                          return Number(model);
                      class GpioControl {
                          constructor(adapter, log) {
                              this.adapter = adapter;
                              this.gpioChip = null;
                              //this.gpioButtons = null;
                              this.log = log;
                              this.gpioPorts = [];
                              this.gpioSettings = [];
                              this.gpioPortLastWrite = [];
                              this.gpioInputPorts = [];
                              this.gpioOutputPorts = [];
                              this.gpioInputPortsHandler = null;
                           * Setup GPIO ports & buttons
                           * @param gpioPorts {Array<Object>}
                           * @param buttonPorts {Array<Object>}
                           * @returns undefined
                          async setupGpio(gpioPorts, buttonPorts) {
                              if (gpioPorts.length === 0 && buttonPorts.length === 0) return;
                              try {
                                  const { DefaultDevice, Edge } = require('opengpio');
                                  let chipNum = 0;
                                  try {
                                      this.log.debug(DefaultDevice);
                                      const {stdout, stderr} = await exec('cat /proc/device-tree/model');
                                      this.log.debug('CPU Info: ' + stdout);
                                      this.log.debug('STDERR: ' + stderr);
                                      const model = getRaspberryModelFromCpuInfo(stdout);
                                      this.log.debug(`Got ${model} from ${stdout}.`);
                                      if (model >= 5) {
                                          this.log.debug('Using GPIO chip 4 for Raspberry Pi 5 or newer.');
                                          chipNum = 4;
                                      this.gpioChip = true; //let's keep this condition for now.
                                  } catch (e) {
                                      this.log.error('Cannot read CPU Info: ' + e);
                                  this.gpioChip = DefaultDevice;
                                  if (this.gpioChip === undefined) {
                                      this.log.warn('Cannot initialize GPIO: No chip found. GPIO functionality disabled!');
                                      this.log.warn('Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.');
                                      this.log.warn('If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.');
                                  this.log.debug('Got chip: ' + this.gpioChip);
                                  this.log.debug(`GPIO chip ${JSON.stringify(this.gpioChip?.info)} initialized`);
                      • Garfonso
                        Garfonso Developer @searcher57 last edited by
                        @searcher57 said in Test Adapter rpi2 2.x:
                        So jetzt hab ich es!
                        Jo... das ist das debug log.
                        Puh... keine Idee, was das ist... 😕
                        Letzter Strohalm war, dass du opengio@1.0.17 installiert hast. Hab ich jetzt auch mal bei mir installiert, aber läuft weiterhin...
                        @smallfeuer said in Test Adapter rpi2 2.x:
                        Das (und alles, was mit upload passiert) hat nur was mit der Configseite zu tun. Kann gut sein, dass das nur da benötigt wird, wo admin installiert ist (also vermutlich auf dem Master). Die Datei wird jedenfalls nichts mit deinem Problem zu tun haben.
                        An euch beide, könnt ihr mal gucken, ob im Pfad /opt/iobroker/node_modules/opengpio/build/Release eine Datei opengpio.node liegt? (sollte eigentlich, sonst sollte der Adapter nicht starten bzw. abstürzen, beim Versuch das zu laden, aber wer weiß)
                        Wie kommst du darauf?
                        Und warum sollte es da ein Problem geben? Wenn du das vermutest, dann mach doch mal debug log an und guck, welchen Chip er für den RPI 3 nimmt.
                        Er nimmt übrigens nicht /proc/cpuinfo, sondern /proc/device-tree/model (wie man in dem von dir kopierten Code-Teil auch sehen kann). Da steht nur das Modell drin, daher passt damit auch der RegEx (hast mich erst geschockt 😛 ).
                        Ich nehme gerne Alternativvorschläge für den Code entgegen (als PR auf Github). Bisher war das so die einfachste Lösung. 🙂 Und ich bin mir relativ sicher, dass es an der Stelle kein Problem gibt... ich fürchte es gibt da irgendwo subtile Buildprobleme oder irgendwas in der Richtung.... 😕
                        S S 2 Replies Last reply Reply Quote 0
                          Smallfeuer @Garfonso last edited by Smallfeuer
                          @garfonso Hi, ich hab grad auf meinem TestPi die 2.1.0 drüber installiert. Diese läuft jetzt. Keine Fehler bisher. Teste ich morgen mal im Master Slave Verbund.
                          Das spricht aber ebenfalls dafür, das etwas beim Erkennen des Pi 3B schief läuft.
                          Die Datei opengpio.node existiert bei mir, kann sie mit nano allerdings nicht leserlich öffnen.
                          Ein identisches Log zu meinem ist auf Github bereits gepostet von @stenmic
                            searcher57 @Garfonso last edited by
                            @garfonso said in Test Adapter rpi2 2.x:
                            Ja, das ist so!
                            pi@Raspi58GB:/opt/iobroker/node_modules/opengpio/build/Release $ ls -la
                            insgesamt 116
                            drwxrwxr-x+ 4 iobroker iobroker   4096 28. Dez 19:57 .
                            drwxrwxr-x+ 3 iobroker iobroker   4096 28. Dez 19:57 ..
                            drwxrwxr-x+ 3 iobroker iobroker   4096 28. Dez 19:57 .deps
                            drwxrwxr-x+ 3 iobroker iobroker   4096 28. Dez 19:57 obj.target
                            -rwxrwxr-x+ 2 iobroker iobroker 148560 28. Dez 19:57 opengpio.node
                              searcher57 @searcher57 last edited by
                              Ja, das ist so!
                              insgesamt 116
                              Hiermal zum Verständnis: Ich kann nur Anweisungen von Euch ausführen. Ich habe keinerlei Programmierkenntnisse!👎 😠
                                @Garfonso Es läuft die 2.1.0 auch im Slave. Hier der Debug....du hast recht...er erkennt eigentlich korrekt, scheint dann aber nicht zum richtigen Erg3bnis zu kommen.
                                rpi2.0
                                2025-01-02 22:17:03.273	debug	GPIO chip undefined initialized
                                rpi2.0
                                2025-01-02 22:17:03.272	debug	Got chip: undefined
                                rpi2.0
                                2025-01-02 22:17:03.272	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
                                rpi2.0
                                2025-01-02 22:17:03.271	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
                                rpi2.0
                                2025-01-02 22:17:03.270	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
                                rpi2.0
                                2025-01-02 22:17:03.269	debug	Got 3 from Raspberry Pi 3 Model B Rev 1.2.
                                rpi2.0
                                2025-01-02 22:17:03.267	debug	STDERR:
                                rpi2.0
                                2025-01-02 22:17:03.266	debug	CPU Info: Raspberry Pi 3 Model B Rev 1.2```
                                • Garfonso
                                  Garfonso Developer @Smallfeuer last edited by
                                  Ne, die Erkennung ist korrekt. Aus irgendeinem Grund kann er aber die Bibliothek um die GPIOs anzusprechen nicht (richtig) laden.
                                  Mehr verlangt ja auch keiner. Hast du super ausgeführt. Wenn du am 28.12. das letzte mal probiert hast, den adapter zu installieren / updaten / neuinstallieren, ist da alles, wie es soll.
                                  Das Problem ist, dass ich, solange ich das Problem bei mir selber nicht sehe und auch sonst keinen Hinweis hab, wo es herkommt, nur im Nebel stochern kann...
                                  Ich überlege nochmal, wie man das Laden der Bibliothek debuggen kann. Aber gerade hat sich der PI, den ich dafür verwende, aus dem Netzwerk verabschiedet.
                                    Ach, es macht einfach Freude sich mit jemandem zu unterhalten, der nicht gleich alles Fachwissen voraussetzt! Es würde uns nur erfreuen endlich wieder einen funktionsfähigen Adapter RPI2 zu haben. Ich wünsche Dir viel Erfolg dabei!!👍 😚
                                      stenmic @Garfonso last edited by
                                      @garfonso wie schon geschrieben hab ich ein Testsystem (PI4 mit frischem Bookworm)
                                      Außer iobroker ist aktuell nur der Adapter installiert.
                                      Wenn ich helfen kann, gerne Anweisungen was ich machen soll.
                                      • Garfonso
                                        Garfonso Developer @searcher57 last edited by Garfonso
                                        tl;dr: Mal Version 2.3.1 ausprobieren (auf NPM, sollte spätestens morgen im latest sein)
                                        Ok, hab jetzt was gefunden. Ihr habt version 1.0.17 der Bibliothek, mein Entwicklungssystem hatte 1.0.16, irgendwie hatte mein Testsystem wohl einen Mix aus 16 und 17... und mit denen hat es funktioniert. Hab jetzt (nachdem ich das Testsystem wieder grundsätzlich ans laufen bringen musste, war irgendwie aus den WLAN gefallen) nochmal testen können und mit 17 lädt es tatsächlich nicht.
                                        Das konnte ich reparieren und jetzt wird auch mindestens Version 17 verlangt... ich hoffe, dass es nun bei allen, wo die Bibliothek erfolgreich installiert wird, auch funktioniert und bleibt.
                                        Falls das nochmal passiert, werde ich die Bibliotheksversion fix lassen. Aber mal sehen.
                                          @garfonso mit der neuen Version startet der Adapter
                                          hier das Log
                                          2025-01-06 18:38:25.991 - debug: rpi2.0 (4379) ---> REGEXP: /SwapFree:\s+(\d+)/m
                                          2025-01-06 18:38:25.992 - debug: rpi2.0 (4379) GROUPS: 2
                                          2025-01-06 18:38:25.992 - debug: rpi2.0 (4379) ---> POST: (rpi.swap_total - $1)/1024
                                          2025-01-06 18:38:25.992 - debug: rpi2.0 (4379) PARSING: temperature
                                          2025-01-06 18:38:25.992 - debug: rpi2.0 (4379) PARSING: soc_temp
                                          2025-01-06 18:38:25.993 - debug: rpi2.0 (4379) ---> cat /sys/devices/virtual/thermal/thermal_zone0/temp
                                          2025-01-06 18:38:25.998 - debug: rpi2.0 (4379) ------------- 47712
                                          2025-01-06 18:38:25.999 - debug: rpi2.0 (4379) ---> REGEXP: /(.*)/
                                          2025-01-06 18:38:25.999 - debug: rpi2.0 (4379) GROUPS: 2
                                          2025-01-06 18:38:25.999 - debug: rpi2.0 (4379) ---> POST: $1/1000
                                          2025-01-06 18:38:26.000 - debug: rpi2.0 (4379) PARSING: uptime
                                          2025-01-06 18:38:26.000 - debug: rpi2.0 (4379) ---> cat /proc/uptime
                                          2025-01-06 18:38:26.005 - debug: rpi2.0 (4379) ------------- 5437.94 21345.37
                                          2025-01-06 18:38:26.006 - debug: rpi2.0 (4379) ---> REGEXP: /(^\S+)/
                                          2025-01-06 18:38:26.006 - debug: rpi2.0 (4379) GROUPS: 2
                                          2025-01-06 18:38:26.006 - debug: rpi2.0 (4379) ---> POST:
                                          2025-01-06 18:38:26.007 - debug: rpi2.0 (4379) PARSING: wlan
                                          2025-01-06 18:38:26.007 - debug: rpi2.0 (4379) PARSING: wifi_received
                                          2025-01-06 18:38:26.007 - debug: rpi2.0 (4379) ---> cat /sys/class/net/wl*/statistics/rx_bytes
                                          2025-01-06 18:38:26.013 - debug: rpi2.0 (4379) ------------- 4155424
                                          2025-01-06 18:38:26.013 - debug: rpi2.0 (4379) ---> REGEXP: /(.*)/
                                          2025-01-06 18:38:26.013 - debug: rpi2.0 (4379) GROUPS: 2
                                          2025-01-06 18:38:26.013 - debug: rpi2.0 (4379) ---> POST: $1*-1
                                          2025-01-06 18:38:26.014 - debug: rpi2.0 (4379) PARSING: wifi_send
                                          2025-01-06 18:38:26.014 - debug: rpi2.0 (4379) ---> cat /sys/class/net/wl*/statistics/tx_bytes
                                          2025-01-06 18:38:26.019 - debug: rpi2.0 (4379) ------------- 9130894
                                          2025-01-06 18:38:26.020 - debug: rpi2.0 (4379) ---> REGEXP: /(.*)/
                                          2025-01-06 18:38:26.020 - debug: rpi2.0 (4379) GROUPS: 2
                                          2025-01-06 18:38:26.020 - debug: rpi2.0 (4379) ---> POST:
                                          2025-01-06 18:38:26.020 - debug: rpi2.0 (4379) CURRENT = cpu true
                                          2025-01-06 18:38:26.021 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:26.104 - debug: rpi2.0 (4379) ---> POST: $1/1000 for cpu_frequency in [object Object]
                                          2025-01-06 18:38:26.105 - debug: rpi2.0 (4379) VALUE: 1800000 POST: $1/1000
                                          2025-01-06 18:38:26.106 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.cpu.cpu_frequency VALUE = 1800
                                          2025-01-06 18:38:26.159 - debug: rpi2.0 (4379) ---> POST: for load1,load5,load15 in [object Object]
                                          2025-01-06 18:38:26.160 - debug: rpi2.0 (4379) MATCHING: 0
                                          2025-01-06 18:38:26.160 - debug: rpi2.0 (4379) NAME: load1 VALUE: 0
                                          2025-01-06 18:38:26.160 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.cpu.load1 VALUE = 0
                                          2025-01-06 18:38:26.210 - debug: rpi2.0 (4379) MATCHING: 0.02
                                          2025-01-06 18:38:26.211 - debug: rpi2.0 (4379) NAME: load5 VALUE: 0.02
                                          2025-01-06 18:38:26.211 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.cpu.load5 VALUE = 0.02
                                          2025-01-06 18:38:26.264 - debug: rpi2.0 (4379) MATCHING: 0
                                          2025-01-06 18:38:26.265 - debug: rpi2.0 (4379) NAME: load15 VALUE: 0
                                          2025-01-06 18:38:26.265 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.cpu.load15 VALUE = 0
                                          2025-01-06 18:38:26.314 - debug: rpi2.0 (4379) ---> POST: for scaling_governor in [object Object]
                                          2025-01-06 18:38:26.314 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.cpu.scaling_governor VALUE = ondemand
                                          2025-01-06 18:38:26.367 - debug: rpi2.0 (4379) CURRENT = raspberry false
                                          2025-01-06 18:38:26.367 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:26.368 - debug: rpi2.0 (4379) raspberry disabled -> clean up.
                                          2025-01-06 18:38:26.368 - debug: rpi2.0 (4379) CURRENT = memory true
                                          2025-01-06 18:38:26.368 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:26.377 - debug: rpi2.0 (4379) ---> POST: $1/1024 for memory_total in [object Object]
                                          2025-01-06 18:38:26.377 - debug: rpi2.0 (4379) VALUE: 928824 POST: $1/1024
                                          2025-01-06 18:38:26.378 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.memory.memory_total VALUE = 907.05
                                          2025-01-06 18:38:26.430 - debug: rpi2.0 (4379) ---> POST: $1/1024 for memory_free in [object Object]
                                          2025-01-06 18:38:26.430 - debug: rpi2.0 (4379) VALUE: 368908 POST: $1/1024
                                          2025-01-06 18:38:26.431 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.memory.memory_free VALUE = 360.26
                                          2025-01-06 18:38:26.482 - debug: rpi2.0 (4379) ---> POST: $1/1024 for memory_available in [object Object]
                                          2025-01-06 18:38:26.482 - debug: rpi2.0 (4379) VALUE: 599548 POST: $1/1024
                                          2025-01-06 18:38:26.483 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.memory.memory_available VALUE = 585.5
                                          2025-01-06 18:38:26.535 - debug: rpi2.0 (4379) CURRENT = network true
                                          2025-01-06 18:38:26.535 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:26.543 - debug: rpi2.0 (4379) ---> POST: $1*-1 for net_received in [object Object]
                                          2025-01-06 18:38:26.543 - debug: rpi2.0 (4379) VALUE: 0 POST: $1*-1
                                          2025-01-06 18:38:26.544 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.network.net_received VALUE = 0
                                          2025-01-06 18:38:26.595 - debug: rpi2.0 (4379) ---> POST: for net_send in [object Object]
                                          2025-01-06 18:38:26.595 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.network.net_send VALUE = 0
                                          2025-01-06 18:38:26.646 - debug: rpi2.0 (4379) CURRENT = sdcard true
                                          2025-01-06 18:38:26.646 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:26.652 - debug: rpi2.0 (4379) ---> POST: $1/1024 for sdcard_root_total in [object Object]
                                          2025-01-06 18:38:26.653 - debug: rpi2.0 (4379) VALUE: 30120332 POST: $1/1024
                                          2025-01-06 18:38:26.653 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.sdcard.sdcard_root_total VALUE = 29414.39
                                          2025-01-06 18:38:26.702 - debug: rpi2.0 (4379) ---> POST: $1/1024 for sdcard_boot_total in [object Object]
                                          2025-01-06 18:38:26.703 - debug: rpi2.0 (4379) VALUE: 522230 POST: $1/1024
                                          2025-01-06 18:38:26.703 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.sdcard.sdcard_boot_total VALUE = 509.99
                                          2025-01-06 18:38:26.754 - debug: rpi2.0 (4379) ---> POST: $1/1024 for sdcard_root_used in [object Object]
                                          2025-01-06 18:38:26.755 - debug: rpi2.0 (4379) VALUE: 3510516 POST: $1/1024
                                          2025-01-06 18:38:26.755 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.sdcard.sdcard_root_used VALUE = 3428.24
                                          2025-01-06 18:38:26.806 - debug: rpi2.0 (4379) ---> POST: $1/1024 for sdcard_boot_used in [object Object]
                                          2025-01-06 18:38:26.806 - debug: rpi2.0 (4379) VALUE: 80128 POST: $1/1024
                                          2025-01-06 18:38:26.807 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.sdcard.sdcard_boot_used VALUE = 78.25
                                          2025-01-06 18:38:26.858 - debug: rpi2.0 (4379) CURRENT = swap true
                                          2025-01-06 18:38:26.858 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:26.865 - debug: rpi2.0 (4379) ---> POST: $1/1024 for swap_total in [object Object]
                                          2025-01-06 18:38:26.865 - debug: rpi2.0 (4379) VALUE: 524284 POST: $1/1024
                                          2025-01-06 18:38:26.866 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.swap.swap_total VALUE = 512
                                          2025-01-06 18:38:26.914 - debug: rpi2.0 (4379) ---> POST: (rpi.swap_total - $1)/1024 for swap_used in [object Object]
                                          2025-01-06 18:38:26.914 - debug: rpi2.0 (4379) VALUE: 524284 POST: (rpi.swap_total - $1)/1024
                                          2025-01-06 18:38:26.915 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.swap.swap_used VALUE = 0
                                          2025-01-06 18:38:26.966 - debug: rpi2.0 (4379) CURRENT = temperature true
                                          2025-01-06 18:38:26.966 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:26.972 - debug: rpi2.0 (4379) ---> POST: $1/1000 for soc_temp in [object Object]
                                          2025-01-06 18:38:26.973 - debug: rpi2.0 (4379) VALUE: 47712 POST: $1/1000
                                          2025-01-06 18:38:26.973 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 47.71
                                          2025-01-06 18:38:27.023 - debug: rpi2.0 (4379) CURRENT = uptime true
                                          2025-01-06 18:38:27.023 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:27.030 - debug: rpi2.0 (4379) ---> POST: for uptime in [object Object]
                                          2025-01-06 18:38:27.031 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.uptime.uptime VALUE = 5437.94
                                          2025-01-06 18:38:27.082 - debug: rpi2.0 (4379) CURRENT = wlan true
                                          2025-01-06 18:38:27.083 - debug: rpi2.0 (4379) -1
                                          2025-01-06 18:38:27.089 - debug: rpi2.0 (4379) ---> POST: $1*-1 for wifi_received in [object Object]
                                          2025-01-06 18:38:27.089 - debug: rpi2.0 (4379) VALUE: 4155424 POST: $1*-1
                                          2025-01-06 18:38:27.090 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.wlan.wifi_received VALUE = -4155424
                                          2025-01-06 18:38:27.138 - debug: rpi2.0 (4379) ---> POST: for wifi_send in [object Object]
                                          2025-01-06 18:38:27.138 - debug: rpi2.0 (4379) SETSTATE FOR rpi2.0.wlan.wifi_send VALUE = 9130894
                                          2025-01-06 18:38:27.195 - debug: rpi2.0 (4379) Creating gpio.17.isInput
                                          2025-01-06 18:38:27.241 - debug: rpi2.0 (4379) class Default extends classes_1.Device {
                                          2025-01-06 18:38:27.249 - debug: rpi2.0 (4379) CPU Info: Raspberry Pi 4 Model B Rev 1.5
                                          2025-01-06 18:38:27.250 - debug: rpi2.0 (4379) STDERR:
                                          2025-01-06 18:38:27.251 - debug: rpi2.0 (4379) Got 4 from Raspberry Pi 4 Model B Rev 1.5.
                                          2025-01-06 18:38:27.251 - debug: rpi2.0 (4379) Got chip: class Default extends classes_1.Device {
                                          2025-01-06 18:38:27.251 - debug: rpi2.0 (4379) GPIO chip undefined initialized
                                          2025-01-06 18:38:27.252 - debug: rpi2.0 (4379) Port 17 direction: in
                                          2025-01-06 18:38:27.254 - debug: rpi2.0 (4379) Setting state for port 17 to false
                                          2025-01-06 18:38:27.306 - debug: rpi2.0 (4379) Adding event listener for port 17
                                          ist die Meldung "GPIO chip undefined initialized" ok?
                                          • Garfonso
                                            Garfonso Developer @stenmic last edited by
                                            @stenmic said in Test Adapter rpi2 2.x:
                                            Ja, die ist ein Überbleibsel von Versuchen mit verschiedenen Bibliotheken. Muss ich mal wegräumen.
                                            519
                                            146254
