    4. Homematic - einzelne States stimmen nicht mit CCU überein
      Homoran Global Moderator Administrators @martinschm last edited by
      @martinschm warum hat sich gerade der output von iob diag verändert?
        martinschm @Homoran last edited by
        @homoran said in Homematic - einzelne States stimmen nicht mit CCU überein:
        Ich hab eigentlich nur die Info zur RaspberryMatic Firmware nach getragen.
          @martinschm bitte die Langfassung und bitte keine 4k microfiches
            ?? microfiches ?
              Langfassung
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
               Static hostname: smarthome
                     Icon name: computer-vm
                       Chassis: vm
                Virtualization: kvm
              Operating System: Ubuntu 22.04.5 LTS
                        Kernel: Linux 5.15.0-127-generic
                  Architecture: x86-64
               Hardware Vendor: QEMU
                Hardware Model: Standard PC _i440FX + PIIX, 1996_
              OS is similar to: debian
              model name      : Common KVM processor
              Docker          : false
              Virtualization  : kvm
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               16:47:58 up 3 days, 22:06,  2 users,  load average: 0.46, 0.36, 0.37
              CPU threads: 8
              *** LIFE CYCLE STATUS ***
              Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
              *** TIME AND TIMEZONES ***
                             Local time: Thu 2025-01-02 16:47:58 CET
                         Universal time: Thu 2025-01-02 15:47:58 UTC
                               RTC time: Thu 2025-01-02 15:47:58
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              martin
              HOME=/home/martin
              GROUPS=martin adm cdrom sudo dip plugdev lxd iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video redis
              *** DISPLAY-SERVER SETUP ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
              *** MEMORY ***
              Mem:            4.8G        3.1G        619M        1.0M        1.1G        1.4G
              Swap:           3.9G        546M        3.4G
              Total:          8.8G        3.6G        4.0G
              Active iob-Instances:   43
                       4817 M total memory
                       3103 M used memory
                       2007 M active memory
                       1811 M inactive memory
                        619 M free memory
                        176 M buffer memory
                        918 M swap cache
                       3934 M total swap
                        546 M used swap
                       3388 M free swap
              top - 16:47:59 up 3 days, 22:06,  2 users,  load average: 0.58, 0.38, 0.38
              Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  6.9 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  1.4 si,  1.4 st
              MiB Mem :   4817.4 total,    619.7 free,   3103.3 used,   1094.4 buff/cache
              MiB Swap:   3935.0 total,   3388.9 free,    546.1 used.   1446.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem                        Type   Size  Used Avail Use% Mounted on
              tmpfs                             tmpfs  482M  1.2M  481M   1% /run
              /dev/mapper/ubuntu--vg-ubuntu--lv ext4    20G   18G  1.5G  93% /
              tmpfs                             tmpfs  2.4G     0  2.4G   0% /dev/shm
              tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
              /dev/sda2                         ext4   974M  242M  665M  27% /boot
              tmpfs                             tmpfs  482M  4.0K  482M   1% /run/user/1000
              [Sun Dec 29 18:41:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Sun Dec 29 18:41:31 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
              [Sun Dec 29 18:41:35 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              Show mounted filesystems:
              TARGET              SOURCE                            FSTYPE   OPTIONS
              /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
              |-/snap/core18/2846 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/core18/2829 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/core20/2379 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/core20/2434 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/lxd/24061   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/lxd/29619   /dev/loop6                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/snapd/21759 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/snapd/23258 /dev/loop7                        squashfs ro,nodev,relatime,errors=continue
              `-/boot             /dev/sda2                         ext4     rw,relatime
              /var:
              3.4G    /var/
              2.1G    /var/log/journal/818509edfb63406a9da2a367f427536a
              2.1G    /var/log
              1.2G    /var/lib
              Archived and active journals take up 2.0G in the file system.
              /opt/iobroker/backups:
              582M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              2.2G    /opt/iobroker/iobroker-data/
              1.1G    /opt/iobroker/iobroker-data/files
              868M    /opt/iobroker/iobroker-data/history
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              561M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              62M     /opt/iobroker/iobroker-data/objects.jsonl
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100FA9-if03
              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100FA9-if00
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              /dev/ttyACM0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.18.1
              /usr/bin/node           v20.18.1
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.4
              nodejs:
                Installed: 20.18.1-1nodesource1
                Candidate: 20.18.1-1nodesource1
                Version table:
               *** 20.18.1-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.9~dfsg-1ubuntu3.6 500
                      500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                      500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                   12.22.9~dfsg-1ubuntu3 500
                      500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: redis
              Hosts:
              smarthome           smarthome (version: 7.0.3, hostname: smarthome     , alive, uptime: 338773)
              Core adapters versions
              js-controller:  7.0.3
              admin:          7.1.5
              javascript:     8.8.3
              nodejs modules from github:     3
              +-- iobroker.sma-speedwire@0.9.0 (git+ssh://git@github.com/rg-engineering/ioBroker.sma-speedwire.git#33e9a5196f7c445f4906a61281172ab71dd986bf)
              +-- iobroker.vesync@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.vesync.git#b0109fb28c94f7a3664eb0e599fd8359808a7b3e)
              +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#79889767b80052eb5093509d55a7751d966e80ed)
              Adapter State
              + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.admin.1                  : admin                 : smarthome                                -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
              + system.adapter.alarm.0                  : alarm                 : smarthome                                -  enabled
                system.adapter.alarm.1                  : alarm                 : smarthome                                - disabled
              + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
                system.adapter.alias-manager.0          : alias-manager         : smarthome                                -  enabled
              + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
              + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
                system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : smarthome                                -  enabled
                system.adapter.devices.0                : devices               : smarthome                                - disabled
              + system.adapter.discovery.0              : discovery             : smarthome                                -  enabled
              + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
                system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
                system.adapter.flot.0                   : flot                  : smarthome                                - disabled
              + system.adapter.frigate.0                : frigate               : smarthome                                -  enabled
                system.adapter.harmony.0                : harmony               : smarthome                                - disabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : smarthome                                -  enabled
              + system.adapter.history.0                : history               : smarthome                                -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : smarthome                                -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : smarthome                                -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : smarthome                                -  enabled, port: 0
                system.adapter.hm-rpc.2                 : hm-rpc                : smarthome                                - disabled, port: 0
              + system.adapter.hm-rpc.3                 : hm-rpc                : smarthome                                -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
              + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : smarthome                                -  enabled
              + system.adapter.iqontrol.0               : iqontrol              : smarthome                                -  enabled
              + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1885, bind: 0.0.0.0
              + system.adapter.nuki-extended.0          : nuki-extended         : smarthome                                -  enabled
              + system.adapter.opendtu.0                : opendtu               : smarthome                                -  enabled
                system.adapter.ph803w.0                 : ph803w                : smarthome                                - disabled
              + system.adapter.ping.0                   : ping                  : smarthome                                -  enabled
              + system.adapter.proxmox.0                : proxmox               : smarthome                                -  enabled, port: 8006
                system.adapter.scenes.0                 : scenes                : smarthome                                - disabled
              + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.simple-api.0             : simple-api            : smarthome                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.sma-speedwire.0          : sma-speedwire         : smarthome                                -  enabled, port: 9522
              + system.adapter.socketio.0               : socketio              : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
              + system.adapter.statistics.0             : statistics            : smarthome                                -  enabled
              + system.adapter.telegram.0               : telegram              : smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.text2command.0           : text2command          : smarthome                                - disabled
              + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
              + system.adapter.tuya.0                   : tuya                  : smarthome                                -  enabled
                system.adapter.unifi.0                  : unifi                 : smarthome                                - disabled
              + system.adapter.vesync.0                 : vesync                : smarthome                                -  enabled
              + system.adapter.viessmann.0              : viessmann             : smarthome                                -  enabled, port: 3002
                system.adapter.vis.0                    : vis                   : smarthome                                - disabled
              + system.adapter.volvo.0                  : volvo                 : smarthome                                -  enabled
                system.adapter.web-speedy.0             : web-speedy            : smarthome                                - disabled
              + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.wifilight.0              : wifilight             : smarthome                                -  enabled
              + system.adapter.worx.0                   : worx                  : smarthome                                -  enabled
                system.adapter.yr.0                     : yr                    : smarthome                                - disabled
              + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alarm"        : 3.6.4    , installed 3.6.4
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "alias-manager": 2.0.0    , installed 2.0.0
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "echarts"      : 1.9.2    , installed 1.9.2
              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
              Adapter    "frigate"      : 1.3.1    , installed 1.3.1
              Adapter    "harmony"      : 1.5.0    , installed 1.5.0
              Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "ical"         : 1.16.1   , installed 1.16.1
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
              Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
              Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
              Adapter    "scenes"       : 3.2.3    , installed 3.2.3
              Adapter    "shelly"       : 8.2.1    , installed 8.2.1
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
              Adapter    "statistics"   : 2.4.0    , installed 2.4.0
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
              Adapter    "viessmann"    : 1.5.0    , installed 1.5.0
              Adapter    "volvo"        : 0.1.2    , installed 0.1.2
              Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
              Adapter    "worx"         : 3.1.1    , installed 3.1.1
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "yr"           : 5.3.0    , installed 5.3.0
              Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
              Objects and States
              Objects:        19904
              States:         22141
              Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
              Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
              Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
              Reading package lists...
              Pending Updates: 2
              *** Listening Ports ***
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21875      633/systemd-resolve
              tcp        0      0 192.168.1.198:9292      0.0.0.0:*               LISTEN      1001       24900      1204/io.hm-rpc.3
              tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      112        22093      655/redis-server 0.
              tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       25700      1048/io.hm-rpc.1
              tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       3007665    189732/io.hm-rpc.0
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       21452      1063/io.mqtt.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25800      1137/io.sonoff.0
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       23331      769/iobroker.js-con
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17274      1/init
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22027      684/sshd: /usr/sbin
              tcp6       0      0 :::8090                 :::*                    LISTEN      1001       22443      888/io.admin.1
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24254      1382/io.simple-api.
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       27015      1410/io.socketio.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27126      1505/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23381      881/io.admin.0
              tcp6       0      0 :::51989                :::*                    LISTEN      1001       70718      12052/io.nuki-exten
              tcp6       0      0 :::1886                 :::*                    LISTEN      1001       32466      1575/io.frigate.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          14680      1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          22032      684/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25900      1130/io.shelly.0
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       624385     49120/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       624386     49120/io.tuya.0
              udp        0      0 0.0.0.0:56109           0.0.0.0:*                           1001       631528     49665/io.sma-speedw
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21874      633/systemd-resolve
              udp        0      0 192.168.1.198:68        0.0.0.0:*                           100        2720036    631/systemd-network
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17275      1/init
              udp6       0      0 :::111                  :::*                                0          17276      1/init
              2025-01-02 16:43:00.188  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ad0d04fdff07000000840300006776b40400000000bfbebbb8bfeae9f5eafdfbcc00000000
              2025-01-02 16:43:00.224  - warn: sma-speedwire.0 (49665) could not translate 9067
              2025-01-02 16:43:00.381  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
              2025-01-02 16:44:00.214  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ba0d04fdff07000000840300006776b44000000000bfbebbb8bfeae9f5eafdfbcc00000000
              2025-01-02 16:44:00.362  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
              2025-01-02 16:45:00.196  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8c70d04fdff07000000840300006776b47c00000000bfbebbb8bfeae9f5eafdfbcc00000000
              2025-01-02 16:45:00.231  - warn: sma-speedwire.0 (49665) could not translate 9067
              2025-01-02 16:45:00.389  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
              2025-01-02 16:45:52.041  - info: host.smarthome instance system.adapter.daswetter.0 in version "3.2.2" started with pid 193902
              2025-01-02 16:45:55.404  - info: daswetter.0 (193902) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.3
              2025-01-02 16:46:00.210  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8d40d04fdff07000000840300006776b4b800000000bfbebbb8bfeae9f5eafdfbcc00000000
              2025-01-02 16:46:00.381  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
              2025-01-02 16:46:05.302  - info: daswetter.0 (193902) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2025-01-02 16:46:05.826  - info: daswetter.0 (193902) cleaned everything up...
              2025-01-02 16:46:05.849  - info: host.smarthome instance system.adapter.daswetter.0 having pid 193902 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2025-01-02 16:47:00.195  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8e10d04fdff07000000840300006776b4f400000000bfbebbb8bfeae9f5eafdfbcc00000000
              2025-01-02 16:47:00.224  - warn: sma-speedwire.0 (49665) could not translate 9067
              2025-01-02 16:47:00.385  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
              2025-01-02 16:48:00.193  - warn: sma-speedwire.0 (49665) unknown cmd : B57600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ee0d04fdff07000000840300006776b53000000000bfbebbb8bfeae9f5eafdfbcc00000000
              2025-01-02 16:48:00.251  - warn: sma-speedwire.0 (49665) could not translate 9067
              2025-01-02 16:48:00.376  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
              2025-01-02 16:48:05.509  - info: web.0 (1505) ==> Connected system.user.admin from ::ffff:192.168.1.32
              2025-01-02 16:48:54.945  - info: web.0 (1505) <== Disconnect system.user.admin from ::ffff:192.168.1.32 iqontrol.0
              2025-01-02 16:49:00.200  - warn: sma-speedwire.0 (49665) unknown cmd : B57600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8fb0d04fdff07000000840300006776b56c00000000bfbebbb8bfeae9f5eafdfbcc00000000
              2025-01-02 16:49:00.232  - warn: sma-speedwire.0 (49665) could not translate 9067
              • Samson71
                Samson71 Global Moderator @martinschm last edited by
                @martinschm sagte in Homematic - einzelne States stimmen nicht mit CCU überein:
                ?? microfiches ?
                Deine Multi-Megamini hoch aufgelösten Bildchen im ersten Post. Diese Screenshots wirken wie auf einem Microfilm. Am Mobilgerät quasi nicht lesbar.
                  Homoran Global Moderator Administrators @martinschm last edited by Homoran
                  HM RPC in V 2.0.2
                  und davon bitte die Konfigurationen aller 4 Instanzen
                  Vielleicht auch mal ein Screenshot der Servicemeldungen in der RaspberryMatic
                  wie sind da die Timestamps?
                    martinschm @Homoran last edited by martinschm
                    HM Rega
                    RPC0
                    RPC1
                    RPC2 - inaktiv
                    RPC3
                    Raspberrymatic Fehlermeldungen
                    Da gibt es aktuell keine Servicemeldungen
                    Timestamps der States
                    Unreach bei dem Tür Rollo: 2024-07-07 18:31
                    LowBat bei der WZ Rechts Heizung: 2024-12-21 18:16
                    Ich hoffe die Screenshots sind jetzt besser anzuschauen
                      das ist ja wirklich schon was her.
                      War möglicherweise ein kurzer Lowbat während des Antriebs.
                      Warum beide nicht gelöscht werden kann zwei Gründe haben.
                      • Die Änderung wird von der RM nicht zuverlässig mitgeteilt.
                        • Wenn diese Info einmal verloren gegangen ist, wird erst beim nächsten Wechsel des Zustands wieder geändert.
                      • Du hast die Checkbox "Geräte nicht löschen..." nicht aktiv
                        • kann sein, dass die Meldung dadurch bei einem Neustart verloren gegangen ist oder falsch aktualisiert wurde
                      Hak die Checkboxen an, ebenfalls die "neu einlesen" und starte die Instanzen neu.
                      Warum ist in der .3 bei Adapteradresse eine IP eingetragen und keine Callback Adresse?
                      Bei allen anderen 0.0.0.0 und dafür die Iob Adresse als Callback?
                      .102 ist doch die RM und .198 iob?
                        Erledigt, die Werte bleiben aber gleich !!!
                        Ja korrekt.
                        Kann ich dir nicht mehr sagen, warum ich das mal unterschiedlich eingestellt habe.
                        Wie sollte es denn idealerweise konfiguriert sein ?
                          wenn es kein Docker oder ähnliches ist, braucht es (eigentlich) keine CallbackAdresse
                          hm-rpc übermittelt die AdapterAdresse an die CCU, damit diese dorthin die abonnierten Änderungen schickt.
                          mit 0.0.0.0 oder der internen Container Adresse kann die CCU nichts anfangen, daher braucht es dann die Callback Adresse.
                          Da es bei dir aber nur einzelne Geräte betrifft, ist das Verhalten seltsam.
                          Vielleicht hilft stromlos machen, etwas warten, und Batterien wieder einlegen ja, um eine Änderung und damit erneute Sendung des Wertes anzustoßen
                          M Homoran 2 Replies Last reply Reply Quote 0
                            Läuft ein einer Proxmox Instanz.
                            Hilft es vielleicht die Geräte doch mal zu löschen und die Liste neu einzulesen ?
                              heisst was?
                              VM oder Container?
                                heisst was?
                                VM oder Container?
                                Als VM.
                                  Homoran Global Moderator Administrators @Homoran last edited by
                                  @homoran sagte in Homematic - einzelne States stimmen nicht mit CCU überein:
                                  hast du das versucht?
                                    Ja, hat aber nichts gebracht.
                                    Ich habe gerade das Gerät einmal manuell aus dem Objektbaum gelöscht und im Adapter "Geräte einmalig neueinlesen" angeklickt.
                                    Jetzt wurde es korrekt wieder angelegt und die Info stimmt.
                                    Hab das dann bei dem Türrollo der angeblich auf Unreach stand wiederholt und beim neu einlesen waren die Werte dann richtig.
                                    Mal schauen wie lange.
                                    3269
