    4. Homematic - einzelne States stimmen nicht mit CCU überein
      Homoran Global Moderator Administrators @martinschm last edited by
      @martinschm bitte die Langfassung und bitte keine 4k microfiches
        martinschm @Homoran last edited by
        @homoran said in Homematic - einzelne States stimmen nicht mit CCU überein:
        ?? microfiches ?
          Langfassung
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: smarthome
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
          Operating System: Ubuntu 22.04.5 LTS
                    Kernel: Linux 5.15.0-127-generic
              Architecture: x86-64
           Hardware Vendor: QEMU
            Hardware Model: Standard PC _i440FX + PIIX, 1996_
          OS is similar to: debian
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           16:47:58 up 3 days, 22:06,  2 users,  load average: 0.46, 0.36, 0.37
          CPU threads: 8
          *** LIFE CYCLE STATUS ***
          Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
          *** TIME AND TIMEZONES ***
                         Local time: Thu 2025-01-02 16:47:58 CET
                     Universal time: Thu 2025-01-02 15:47:58 UTC
                           RTC time: Thu 2025-01-02 15:47:58
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          martin
          HOME=/home/martin
          GROUPS=martin adm cdrom sudo dip plugdev lxd iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video redis
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            4.8G        3.1G        619M        1.0M        1.1G        1.4G
          Swap:           3.9G        546M        3.4G
          Total:          8.8G        3.6G        4.0G
          Active iob-Instances:   43
                   4817 M total memory
                   3103 M used memory
                   2007 M active memory
                   1811 M inactive memory
                    619 M free memory
                    176 M buffer memory
                    918 M swap cache
                   3934 M total swap
                    546 M used swap
                   3388 M free swap
          top - 16:47:59 up 3 days, 22:06,  2 users,  load average: 0.58, 0.38, 0.38
          Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  6.9 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  1.4 si,  1.4 st
          MiB Mem :   4817.4 total,    619.7 free,   3103.3 used,   1094.4 buff/cache
          MiB Swap:   3935.0 total,   3388.9 free,    546.1 used.   1446.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                        Type   Size  Used Avail Use% Mounted on
          tmpfs                             tmpfs  482M  1.2M  481M   1% /run
          /dev/mapper/ubuntu--vg-ubuntu--lv ext4    20G   18G  1.5G  93% /
          tmpfs                             tmpfs  2.4G     0  2.4G   0% /dev/shm
          tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
          /dev/sda2                         ext4   974M  242M  665M  27% /boot
          tmpfs                             tmpfs  482M  4.0K  482M   1% /run/user/1000
          [Sun Dec 29 18:41:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sun Dec 29 18:41:31 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
          [Sun Dec 29 18:41:35 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          Show mounted filesystems:
          TARGET              SOURCE                            FSTYPE   OPTIONS
          /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
          |-/snap/core18/2846 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
          |-/snap/core18/2829 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
          |-/snap/core20/2379 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
          |-/snap/core20/2434 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
          |-/snap/lxd/24061   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
          |-/snap/lxd/29619   /dev/loop6                        squashfs ro,nodev,relatime,errors=continue
          |-/snap/snapd/21759 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
          |-/snap/snapd/23258 /dev/loop7                        squashfs ro,nodev,relatime,errors=continue
          `-/boot             /dev/sda2                         ext4     rw,relatime
          /var:
          3.4G    /var/
          2.1G    /var/log/journal/818509edfb63406a9da2a367f427536a
          2.1G    /var/log
          1.2G    /var/lib
          Archived and active journals take up 2.0G in the file system.
          /opt/iobroker/backups:
          582M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.2G    /opt/iobroker/iobroker-data/
          1.1G    /opt/iobroker/iobroker-data/files
          868M    /opt/iobroker/iobroker-data/history
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          561M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          62M     /opt/iobroker/iobroker-data/objects.jsonl
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100FA9-if03
          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100FA9-if00
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyACM0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.9~dfsg-1ubuntu3.6 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                  500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
               12.22.9~dfsg-1ubuntu3 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          Hosts:
          smarthome           smarthome (version: 7.0.3, hostname: smarthome     , alive, uptime: 338773)
          Core adapters versions
          js-controller:  7.0.3
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     3
          +-- iobroker.sma-speedwire@0.9.0 (git+ssh://git@github.com/rg-engineering/ioBroker.sma-speedwire.git#33e9a5196f7c445f4906a61281172ab71dd986bf)
          +-- iobroker.vesync@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.vesync.git#b0109fb28c94f7a3664eb0e599fd8359808a7b3e)
          +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#79889767b80052eb5093509d55a7751d966e80ed)
          Adapter State
          + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.admin.1                  : admin                 : smarthome                                -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
          + system.adapter.alarm.0                  : alarm                 : smarthome                                -  enabled
            system.adapter.alarm.1                  : alarm                 : smarthome                                - disabled
          + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
            system.adapter.alias-manager.0          : alias-manager         : smarthome                                -  enabled
          + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
          + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
            system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : smarthome                                -  enabled
            system.adapter.devices.0                : devices               : smarthome                                - disabled
          + system.adapter.discovery.0              : discovery             : smarthome                                -  enabled
          + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
            system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
            system.adapter.flot.0                   : flot                  : smarthome                                - disabled
          + system.adapter.frigate.0                : frigate               : smarthome                                -  enabled
            system.adapter.harmony.0                : harmony               : smarthome                                - disabled
          + system.adapter.heatingcontrol.0         : heatingcontrol        : smarthome                                -  enabled
          + system.adapter.history.0                : history               : smarthome                                -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : smarthome                                -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : smarthome                                -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : smarthome                                -  enabled, port: 0
            system.adapter.hm-rpc.2                 : hm-rpc                : smarthome                                - disabled, port: 0
          + system.adapter.hm-rpc.3                 : hm-rpc                : smarthome                                -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
          + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : smarthome                                -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : smarthome                                -  enabled
          + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.nuki-extended.0          : nuki-extended         : smarthome                                -  enabled
          + system.adapter.opendtu.0                : opendtu               : smarthome                                -  enabled
            system.adapter.ph803w.0                 : ph803w                : smarthome                                - disabled
          + system.adapter.ping.0                   : ping                  : smarthome                                -  enabled
          + system.adapter.proxmox.0                : proxmox               : smarthome                                -  enabled, port: 8006
            system.adapter.scenes.0                 : scenes                : smarthome                                - disabled
          + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : smarthome                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sma-speedwire.0          : sma-speedwire         : smarthome                                -  enabled, port: 9522
          + system.adapter.socketio.0               : socketio              : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
          + system.adapter.statistics.0             : statistics            : smarthome                                -  enabled
          + system.adapter.telegram.0               : telegram              : smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : smarthome                                - disabled
          + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
          + system.adapter.tuya.0                   : tuya                  : smarthome                                -  enabled
            system.adapter.unifi.0                  : unifi                 : smarthome                                - disabled
          + system.adapter.vesync.0                 : vesync                : smarthome                                -  enabled
          + system.adapter.viessmann.0              : viessmann             : smarthome                                -  enabled, port: 3002
            system.adapter.vis.0                    : vis                   : smarthome                                - disabled
          + system.adapter.volvo.0                  : volvo                 : smarthome                                -  enabled
            system.adapter.web-speedy.0             : web-speedy            : smarthome                                - disabled
          + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wifilight.0              : wifilight             : smarthome                                -  enabled
          + system.adapter.worx.0                   : worx                  : smarthome                                -  enabled
            system.adapter.yr.0                     : yr                    : smarthome                                - disabled
          + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "alarm"        : 3.6.4    , installed 3.6.4
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "frigate"      : 1.3.1    , installed 1.3.1
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
          Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "viessmann"    : 1.5.0    , installed 1.5.0
          Adapter    "volvo"        : 0.1.2    , installed 0.1.2
          Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
          Adapter    "worx"         : 3.1.1    , installed 3.1.1
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
          Objects and States
          Objects:        19904
          States:         22141
          Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
          Reading package lists...
          Pending Updates: 2
          *** Listening Ports ***
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21875      633/systemd-resolve
          tcp        0      0 192.168.1.198:9292      0.0.0.0:*               LISTEN      1001       24900      1204/io.hm-rpc.3
          tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      112        22093      655/redis-server 0.
          tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       25700      1048/io.hm-rpc.1
          tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       3007665    189732/io.hm-rpc.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       21452      1063/io.mqtt.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25800      1137/io.sonoff.0
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       23331      769/iobroker.js-con
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17274      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22027      684/sshd: /usr/sbin
          tcp6       0      0 :::8090                 :::*                    LISTEN      1001       22443      888/io.admin.1
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24254      1382/io.simple-api.
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       27015      1410/io.socketio.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27126      1505/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23381      881/io.admin.0
          tcp6       0      0 :::51989                :::*                    LISTEN      1001       70718      12052/io.nuki-exten
          tcp6       0      0 :::1886                 :::*                    LISTEN      1001       32466      1575/io.frigate.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          14680      1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          22032      684/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25900      1130/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       624385     49120/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       624386     49120/io.tuya.0
          udp        0      0 0.0.0.0:56109           0.0.0.0:*                           1001       631528     49665/io.sma-speedw
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21874      633/systemd-resolve
          udp        0      0 192.168.1.198:68        0.0.0.0:*                           100        2720036    631/systemd-network
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17275      1/init
          udp6       0      0 :::111                  :::*                                0          17276      1/init
          2025-01-02 16:43:00.188  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ad0d04fdff07000000840300006776b40400000000bfbebbb8bfeae9f5eafdfbcc00000000
          2025-01-02 16:43:00.224  - warn: sma-speedwire.0 (49665) could not translate 9067
          2025-01-02 16:43:00.381  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
          2025-01-02 16:44:00.214  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ba0d04fdff07000000840300006776b44000000000bfbebbb8bfeae9f5eafdfbcc00000000
          2025-01-02 16:44:00.362  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
          2025-01-02 16:45:00.196  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8c70d04fdff07000000840300006776b47c00000000bfbebbb8bfeae9f5eafdfbcc00000000
          2025-01-02 16:45:00.231  - warn: sma-speedwire.0 (49665) could not translate 9067
          2025-01-02 16:45:00.389  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
          2025-01-02 16:45:52.041  - info: host.smarthome instance system.adapter.daswetter.0 in version "3.2.2" started with pid 193902
          2025-01-02 16:45:55.404  - info: daswetter.0 (193902) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.3
          2025-01-02 16:46:00.210  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8d40d04fdff07000000840300006776b4b800000000bfbebbb8bfeae9f5eafdfbcc00000000
          2025-01-02 16:46:00.381  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
          2025-01-02 16:46:05.302  - info: daswetter.0 (193902) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2025-01-02 16:46:05.826  - info: daswetter.0 (193902) cleaned everything up...
          2025-01-02 16:46:05.849  - info: host.smarthome instance system.adapter.daswetter.0 having pid 193902 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-01-02 16:47:00.195  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8e10d04fdff07000000840300006776b4f400000000bfbebbb8bfeae9f5eafdfbcc00000000
          2025-01-02 16:47:00.224  - warn: sma-speedwire.0 (49665) could not translate 9067
          2025-01-02 16:47:00.385  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
          2025-01-02 16:48:00.193  - warn: sma-speedwire.0 (49665) unknown cmd : B57600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ee0d04fdff07000000840300006776b53000000000bfbebbb8bfeae9f5eafdfbcc00000000
          2025-01-02 16:48:00.251  - warn: sma-speedwire.0 (49665) could not translate 9067
          2025-01-02 16:48:00.376  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
          2025-01-02 16:48:05.509  - info: web.0 (1505) ==> Connected system.user.admin from ::ffff:192.168.1.32
          2025-01-02 16:48:54.945  - info: web.0 (1505) <== Disconnect system.user.admin from ::ffff:192.168.1.32 iqontrol.0
          2025-01-02 16:49:00.200  - warn: sma-speedwire.0 (49665) unknown cmd : B57600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8fb0d04fdff07000000840300006776b56c00000000bfbebbb8bfeae9f5eafdfbcc00000000
          2025-01-02 16:49:00.232  - warn: sma-speedwire.0 (49665) could not translate 9067
          • Samson71
            Samson71 Global Moderator @martinschm last edited by
            @martinschm sagte in Homematic - einzelne States stimmen nicht mit CCU überein:
            ?? microfiches ?
            Deine Multi-Megamini hoch aufgelösten Bildchen im ersten Post. Diese Screenshots wirken wie auf einem Microfilm. Am Mobilgerät quasi nicht lesbar.
              Homoran Global Moderator Administrators @martinschm last edited by Homoran
              HM RPC in V 2.0.2
              und davon bitte die Konfigurationen aller 4 Instanzen
              Vielleicht auch mal ein Screenshot der Servicemeldungen in der RaspberryMatic
              wie sind da die Timestamps?
                martinschm @Homoran last edited by martinschm
                HM Rega
                RPC0
                RPC1
                RPC2 - inaktiv
                RPC3
                Raspberrymatic Fehlermeldungen
                Da gibt es aktuell keine Servicemeldungen
                Timestamps der States
                Unreach bei dem Tür Rollo: 2024-07-07 18:31
                LowBat bei der WZ Rechts Heizung: 2024-12-21 18:16
                Ich hoffe die Screenshots sind jetzt besser anzuschauen
                  das ist ja wirklich schon was her.
                  War möglicherweise ein kurzer Lowbat während des Antriebs.
                  Warum beide nicht gelöscht werden kann zwei Gründe haben.
                  • Die Änderung wird von der RM nicht zuverlässig mitgeteilt.
                    • Wenn diese Info einmal verloren gegangen ist, wird erst beim nächsten Wechsel des Zustands wieder geändert.
                  • Du hast die Checkbox "Geräte nicht löschen..." nicht aktiv
                    • kann sein, dass die Meldung dadurch bei einem Neustart verloren gegangen ist oder falsch aktualisiert wurde
                  Hak die Checkboxen an, ebenfalls die "neu einlesen" und starte die Instanzen neu.
                  Warum ist in der .3 bei Adapteradresse eine IP eingetragen und keine Callback Adresse?
                  Bei allen anderen 0.0.0.0 und dafür die Iob Adresse als Callback?
                  .102 ist doch die RM und .198 iob?
                    Erledigt, die Werte bleiben aber gleich !!!
                    Ja korrekt.
                    Kann ich dir nicht mehr sagen, warum ich das mal unterschiedlich eingestellt habe.
                    Wie sollte es denn idealerweise konfiguriert sein ?
                      wenn es kein Docker oder ähnliches ist, braucht es (eigentlich) keine CallbackAdresse
                      hm-rpc übermittelt die AdapterAdresse an die CCU, damit diese dorthin die abonnierten Änderungen schickt.
                      mit 0.0.0.0 oder der internen Container Adresse kann die CCU nichts anfangen, daher braucht es dann die Callback Adresse.
                      Da es bei dir aber nur einzelne Geräte betrifft, ist das Verhalten seltsam.
                      Vielleicht hilft stromlos machen, etwas warten, und Batterien wieder einlegen ja, um eine Änderung und damit erneute Sendung des Wertes anzustoßen
                      M Homoran 2 Replies Last reply Reply Quote 0
                        Läuft ein einer Proxmox Instanz.
                        Hilft es vielleicht die Geräte doch mal zu löschen und die Liste neu einzulesen ?
                          heisst was?
                          VM oder Container?
                            heisst was?
                            VM oder Container?
                            Als VM.
                              Homoran Global Moderator Administrators @Homoran last edited by
                              @homoran sagte in Homematic - einzelne States stimmen nicht mit CCU überein:
                              hast du das versucht?
                                Ja, hat aber nichts gebracht.
                                Ich habe gerade das Gerät einmal manuell aus dem Objektbaum gelöscht und im Adapter "Geräte einmalig neueinlesen" angeklickt.
                                Jetzt wurde es korrekt wieder angelegt und die Info stimmt.
                                Hab das dann bei dem Türrollo der angeblich auf Unreach stand wiederholt und beim neu einlesen waren die Werte dann richtig.
                                Mal schauen wie lange.
                                3269
