    4. Kaputt nach Update
    Kaputt nach Update
    • 6
      64kbyte @Homoran last edited by
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: UBU14
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Ubuntu 22.04.5 LTS
                Kernel: Linux 5.15.0-130-generic
          Architecture: arm64
       Hardware Vendor: Hetzner
        Hardware Model: vServer
      OS is similar to: debian
      Docker          : false
      Virtualization  : kvm
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       10:51:53 up 37 min,  3 users,  load average: 0.66, 0.34, 0.29
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2025-01-03 10:51:53 CET
                 Universal time: Fri 2025-01-03 09:51:53 UTC
                       RTC time: Fri 2025-01-03 09:51:54
                      Time zone: Europe/Zurich (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      iobroker
      OPENHAB_HOME=/usr/share/openhab
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      iobroker
      HOME=/home/iobroker
      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
      A root login is not required in most Linux Distributions.
      Run 'iobroker fix' or use the system tools to create a user.
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            3.8G        1.1G        824M         22M        1.8G        2.5G
      Swap:           1.0G          0B        1.0G
      Total:          4.8G        1.1G        1.8G
      Active iob-Instances:   2
               3813 M total memory
               1149 M used memory
                708 M active memory
               1894 M inactive memory
                824 M free memory
                205 M buffer memory
               1634 M swap cache
               1023 M total swap
                  0 M used swap
               1023 M free swap
      top - 10:51:54 up 37 min,  3 users,  load average: 0.66, 0.34, 0.29
      Tasks: 193 total,   2 running, 191 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 50.0 us, 12.5 sy,  0.0 ni, 37.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3813.8 total,    818.5 free,   1155.2 used,   1840.1 buff/cache
      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   2450.6 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      tmpfs          tmpfs  382M  1.1M  381M   1% /run
      /dev/sda1      ext4    38G   14G   23G  39% /
      tmpfs          tmpfs  1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda15     vfat   253M  6.3M  246M   3% /boot/efi
      tmpfs          tmpfs  382M     0  382M   0% /run/user/0
      [Fri Jan  3 10:14:45 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri Jan  3 10:14:46 2025] EXT4-fs (sda1): re-mounted. Opts: (null). Quota mode: none.
      Show mounted filesystems:
      TARGET      SOURCE     FSTYPE OPTIONS
      /           /dev/sda1  ext4   rw,relatime
      `-/boot/efi /dev/sda15 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      /var:
      2.6G    /var/
      1.4G    /var/log
      1.2G    /var/log/journal/d00883623d1e40b08f3f029f850712c9
      1023M   /var/lib
      Archived and active journals take up 400.1M in the file system.
      /opt/iobroker/backups:
      116M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      157M    /opt/iobroker/iobroker-data/
      117M    /opt/iobroker/iobroker-data/files
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      8.2M    /opt/iobroker/iobroker-data/objects.jsonl
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
      6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.6 500
              500 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 Packages
              500 http://ports.ubuntu.com/ubuntu-ports jammy-security/universe arm64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      UBU14               UBU14 (version: 7.0.6, hostname: UBU14         , alive, uptime: 91)
      Core adapters versions
      js-controller:  7.0.6
      admin:          6.13.16
      javascript:     7.8.0
      nodejs modules from github:     9
      +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#b60ff276702bbee5ca4cb4ef90ca743055281b20)
      +-- iobroker.garmin@0.0.4 (git+ssh://git@github.com/TA2k/ioBroker.garmin.git#eb23cf2960bb35e7b2917d859f153c21bf60e5d3)
      +-- iobroker.luxtronik2@0.4.2 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#68def1b194fb8cc418dc0543c3a0b48e5206cb45)
      +-- iobroker.miele@0.1.6 (git+ssh://git@github.com/soef/ioBroker.miele.git#5e90c7af1e5d8f83beaff7767e065e166e8cc544)
      +-- iobroker.mielecloudservice@6.5.4 (git+ssh://git@github.com/Grizzelbee/ioBroker.mielecloudservice.git#756d7a4dcae64ea50459e8af38e24bd8f0dd14da)
      +-- iobroker.swiss-weather-api@2.1.0 (git+ssh://git@github.com/baerengraben/ioBroker.swiss-weather-api.git#82276c9d7fb6dda69499c3d6e193a682eaabf7d0)
      +-- iobroker.vis-inventwo@3.3.3 (git+ssh://git@github.com/inventwo/ioBroker.vis-inventwo.git#c0ac2de2a01b3e616f1d230b8def838c70a680d4)
      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
      +-- iobroker.vw-connect@0.5.4 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#85f79d2a7282c7dacb8899fe2d0822971e549018)
      Adapter State
        system.adapter.admin.0                  : admin                 : UBU14                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : UBU14                                    -  enabled
        system.adapter.discovery.0              : discovery             : UBU14                                    -  enabled
        system.adapter.energiefluss.0           : energiefluss          : UBU14                                    -  enabled
        system.adapter.hm-rega.0                : hm-rega               : UBU14                                    -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : UBU14                                    -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : UBU14                                    -  enabled, port: 0
        system.adapter.hue.0                    : hue                   : UBU14                                    - disabled, port: 443
      + system.adapter.javascript.0             : javascript            : UBU14                                    -  enabled
        system.adapter.luftdaten.0              : luftdaten             : UBU14                                    -  enabled
        system.adapter.luxtronik2.0             : luxtronik2            : UBU14                                    -  enabled, port: 8214
        system.adapter.meteoalarm.0             : meteoalarm            : UBU14                                    -  enabled
        system.adapter.mielecloudservice.0      : mielecloudservice     : UBU14                                    -  enabled
        system.adapter.modbus.0                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.1                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.2                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.3                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.4                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.5                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.6                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.7                 : modbus                : UBU14                                    -  enabled
        system.adapter.modbus.8                 : modbus                : UBU14                                    -  enabled
        system.adapter.netatmo.0                : netatmo               : UBU14                                    -  enabled
        system.adapter.openhab.0                : openhab               : UBU14                                    -  enabled, port: 8080
        system.adapter.pvforecast.0             : pvforecast            : UBU14                                    -  enabled
        system.adapter.pvforecast.1             : pvforecast            : UBU14                                    - disabled
        system.adapter.robonect.0               : robonect              : UBU14                                    - disabled
        system.adapter.sql.0                    : sql                   : UBU14                                    -  enabled
        system.adapter.sql.1                    : sql                   : UBU14                                    -  enabled
        system.adapter.swiss-weather-api.0      : swiss-weather-api     : UBU14                                    -  enabled
        system.adapter.vis.0                    : vis                   : UBU14                                    -  enabled
        system.adapter.vw-connect.0             : vw-connect            : UBU14                                    -  enabled
        system.adapter.vw-connect.1             : vw-connect            : UBU14                                    -  enabled
        system.adapter.web.0                    : web                   : UBU14                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 6.13.16 [Updatable]
      Adapter    "backitup"     : 3.0.25   , installed 2.10.11 [Updatable]
      Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.0  [Updatable]
      Adapter    "garmin"       : 0.0.3    , installed 0.0.4
      Adapter    "hm-rega"      : 5.1.0    , installed 4.0.0  [Updatable]
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
      Adapter    "hue"          : 3.13.1   , installed 3.10.2 [Updatable]
      Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "luftdaten"    : 4.0.0    , installed 3.1.0  [Updatable]
      Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.2  [Updatable]
      Adapter    "miele"        : 0.1.5    , installed 0.1.6
      Adapter    "mielecloudservice": 6.5.7, installed 6.5.4  [Updatable]
      Adapter    "modbus"       : 6.3.2    , installed 6.1.0  [Updatable]
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openhab"      : 1.2.0    , installed 1.2.0
      Adapter    "pvforecast"   : 4.1.0    , installed 2.9.1  [Updatable]
      Adapter    "robonect"     : 1.4.2    , installed 1.3.4  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.0  [Updatable]
      Adapter    "socketio"     : 6.7.1    , installed 6.6.1  [Updatable]
      Adapter    "sql"          : 3.0.1    , installed 2.2.0  [Updatable]
      Adapter    "swiss-weather-api": 2.2.2, installed 2.1.0  [Updatable]
      Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 2.5.11 [Updatable]
      Objects and States
      Objects:        12300
      States:         10876
      Hit:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
      Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
      Hit:3 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
      Hit:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
      Hit:7 https://repo.zabbix.com/zabbix/6.4/ubuntu-arm64 jammy InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:10051           0.0.0.0:*               LISTEN      114        24398      762/zabbix_server
      tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21326      734/named
      tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21325      734/named
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      33         22107      718/python3
      tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN      0          21760      712/rsyslogd
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        20797      637/systemd-resolve
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21322      734/named
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21321      734/named
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17927      1/init
      tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21328      734/named
      tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21327      734/named
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21206      728/sshd: /usr/sbin
      tcp6       0      0 :::8080                 :::*                    LISTEN      116        26899      1473/java
      tcp6       0      0 :::10050                :::*                    LISTEN      114        22052      719/zabbix_agent2
      tcp6       0      0 :::10051                :::*                    LISTEN      114        24399      762/zabbix_server
      tcp6       0      0 127.0.0.1:8101          :::*                    LISTEN      116        26419      1473/java
      tcp6       0      0 127.0.0.1:37203         :::*                    LISTEN      116        26352      1473/java
      tcp6       0      0 :::8888                 :::*                    LISTEN      33         22108      718/python3
      tcp6       0      0 :::514                  :::*                    LISTEN      0          21761      712/rsyslogd
      tcp6       0      0 :::5007                 :::*                    LISTEN      116        27214      1473/java
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        22169      675/grafana
      tcp6       0      0 :::8443                 :::*                    LISTEN      116        26897      1473/java
      tcp6       0      0 :::111                  :::*                    LISTEN      0          17929      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          21217      728/sshd: /usr/sbin
      udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          21066      700/chronyd
      udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          21756      712/rsyslogd
      udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21324      734/named
      udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21323      734/named
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21320      734/named
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21319      734/named
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        20796      637/systemd-resolve
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21304      686/dhclient
      udp        0      0 10.0.2.3:68             0.0.0.0:*                           101        21533      635/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17928      1/init
      udp6       0      0 ::1:323                 :::*                                0          21067      700/chronyd
      udp6       0      0 :::514                  :::*                                0          21757      712/rsyslogd
      udp6       0      0 :::5353                 :::*                                116        27035      1473/java
      udp6       0      0 :::1900                 :::*                                116        27352      1473/java
      udp6       0      0 :::1902                 :::*                                116        27946      1473/java
      udp6       0      0 10.0.2.3:59483          :::*                                116        27919      1473/java
      udp6       0      0 :::111                  :::*                                0          17930      1/init
      2025-01-03 10:52:23.385  - error: host.UBU14 Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
      2025-01-03 10:52:23.385  - error: host.UBU14 Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
      2025-01-03 10:52:23.385  - error: host.UBU14 instance system.adapter.modbus.4 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-01-03 10:52:23.386  - info: host.UBU14 Restart adapter system.adapter.modbus.4 because enabled
      2025-01-03 10:52:23.386  - warn: host.UBU14 Do not restart adapter system.adapter.modbus.4 because restart loop detected
      2025-01-03 10:52:23.731  - info: host.UBU14 instance system.adapter.pvforecast.0 in version "2.9.1" started with pid 14090
      2025-01-03 10:52:24.385  - info: host.UBU14 instance system.adapter.vw-connect.0 in version "0.5.4" (non-npm: ta2k/ioBroker.vw-connect) started with pid 14454
      2025-01-03 10:52:24.847  - info: host.UBU14 instance system.adapter.modbus.3 in version "6.1.0" started with pid 14463
      2025-01-03 10:52:25.358  - error: pvforecast.0 (14090) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-01-03 10:52:25.360  - error: pvforecast.0 (14090) unhandled promise rejection: callback is not a function
      2025-01-03 10:52:25.361  - error: pvforecast.0 (14090) TypeError: callback is not a function
          at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
      2025-01-03 10:52:25.362  - error: pvforecast.0 (14090) callback is not a function
      2025-01-03 10:52:25.891  - info: pvforecast.0 (14090) terminating
      2025-01-03 10:52:25.891  - warn: pvforecast.0 (14090) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-01-03 10:52:25.931  - info: pvforecast.0 (14090) starting. Version 2.9.1 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v20.18.1, js-controller: 7.0.6
      2025-01-03 10:52:26.443  - error: host.UBU14 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]: TypeError: callback is not a function
      2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
      2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
      2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
      2025-01-03 10:52:26.445  - error: host.UBU14 instance system.adapter.pvforecast.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-01-03 10:52:26.445  - info: host.UBU14 Restart adapter system.adapter.pvforecast.0 because enabled
        Thomas Braun Most Active @64kbyte last edited by
        @64kbyte
        iob update
        iob upgrade all -y
        iob start admin
        Und ob die Idee, das auf einem vServer bei Hetzner zu betreiben die beste Idee ist wahrlich auch zu bezweifeln.
        6 2 Replies Last reply Reply Quote 0
        • 6
          64kbyte @Thomas Braun last edited by
          @thomas-braun said in Kaputt nach Update:
          @64kbyte
          Warum nicht? Ich habe mir da ne private cloud gebaut. Zugriff erfolgt via Site2Site VPN. Ausser vielleicht "Laufzeiten" mache ich mir da keine grossen Sorgen.
          Ich mach' mal die angegebenen Befehle und melde mich wieder
          • 6
            @64kbyte
            iob update
            iob upgrade all -y
            iob start admin
            Das war weitestgehend erfolgreich. Eine Fehlermeldung bleibt:
            2025-01-03 11:16:43.082  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
            Require stack:
            - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js
            - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js
            - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
            - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js
            - /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js
            • mcm1957
              mcm1957 @64kbyte last edited by mcm1957
              @64kbyte
              Hast du nun alle Adapter auf einem aktuellen Stand?
              Poste bitte nochmal ein aktualisiertes iob diag.
              UNd zeig bitte mal den output von npm ls @iobroker/plugin-sentry
              Sollte in etwa so aussehen:
              xxx@xxx:/opt/iobroker $ npm ls @iobroker/plugin-sentry
              iobroker.inst@3.0.0 /opt/iobroker
              └─┬ iobroker.js-controller@7.0.3
                └── @iobroker/plugin-sentry@2.0.4
              EDIT: name of plugin korrigiert
              6 1 Reply Last reply Reply Quote 0
              • 6
                64kbyte @mcm1957 last edited by
                @mcm1957 said in Kaputt nach Update:
                npm ls @iobroker/sentry-plugin
                Glaub schon, dass die Adapter alle auf dem aktuellen Stand sind. Jedenfalls funktioniert alles bis auf die Sentry Fehlermeldung. Hier das diag:
                Script v.2024-10-19
                *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 21:22:22 up 10:24,  2 users,  load average: 0.24, 0.25, 0.20
                CPU threads: 2
                               Local time: Fri 2025-01-03 21:22:22 CET
                           Universal time: Fri 2025-01-03 20:22:22 UTC
                                 RTC time: Fri 2025-01-03 20:22:23
                              NTP service: active
                          RTC in local TZ: no
                iobroker
                HOME=/home/iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            3.8G        2.3G        243M         22M        1.3G        1.3G
                Swap:           1.0G        0.0K        1.0G
                Total:          4.8G        2.3G        1.3G
                Active iob-Instances:   29
                         3813 M total memory
                         2303 M used memory
                          565 M active memory
                         2682 M inactive memory
                          243 M free memory
                          122 M buffer memory
                         1143 M swap cache
                         1023 M total swap
                            0 M used swap
                         1023 M free swap
                top - 21:22:22 up 10:24,  2 users,  load average: 0.24, 0.25, 0.20
                Tasks: 211 total,   3 running, 208 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 33.3 us,  3.0 sy,  0.0 ni, 60.6 id,  0.0 wa,  0.0 hi,  3.0 si,  0.0 st
                MiB Mem :   3813.8 total,    243.4 free,   2303.3 used,   1267.1 buff/cache
                MiB Swap:   1024.0 total,   1023.2 free,      0.8 used.   1303.5 avail Mem
                [sudo] password for iobroker:
                *** FILESYSTEM ***
                /dev/sda1      ext4    38G   15G   22G  41% /
                [Fri Jan  3 10:58:15 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Fri Jan  3 10:58:16 2025] EXT4-fs (sda1): re-mounted. Opts: (null). Quota mode: none.
                /var:
                2.6G    /var/
                1.4G    /var/log
                1023M   /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: redis
                States  type: redis
                Hosts:
                UBU14               UBU14 (version: 7.0.6, hostname: UBU14         , alive, uptime: 36662)
                admin:          7.1.5
                javascript:     8.8.3
                nodejs modules from github:     5
                Adapter State
                + system.adapter.admin.0                  : admin                 : UBU14                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.backitup.0               : backitup              : UBU14                                    -  enabled
                + system.adapter.discovery.0              : discovery             : UBU14                                    -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : UBU14                                    -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : UBU14                                    -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : UBU14                                    -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : UBU14                                    -  enabled, port: 0
                + system.adapter.luxtronik2.0             : luxtronik2            : UBU14                                    -  enabled, port: 8214
                + system.adapter.mielecloudservice.0      : mielecloudservice     : UBU14                                    -  enabled
                + system.adapter.modbus.0                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.1                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.2                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.3                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.4                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.5                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.6                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.7                 : modbus                : UBU14                                    -  enabled
                + system.adapter.modbus.8                 : modbus                : UBU14                                    -  enabled
                + system.adapter.netatmo.0                : netatmo               : UBU14                                    -  enabled
                + system.adapter.openhab.0                : openhab               : UBU14                                    -  enabled, port: 8080
                + system.adapter.pvforecast.0             : pvforecast            : UBU14                                    -  enabled
                + system.adapter.sql.0                    : sql                   : UBU14                                    -  enabled
                + system.adapter.sql.1                    : sql                   : UBU14                                    -  enabled
                + system.adapter.swiss-weather-api.0      : swiss-weather-api     : UBU14                                    -  enabled
                + system.adapter.vw-connect.0             : vw-connect            : UBU14                                    -  enabled
                + system.adapter.vw-connect.1             : vw-connect            : UBU14                                    -  enabled
                + system.adapter.web.0                    : web                   : UBU14                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                Adapter    "hue"          : 3.13.1   , installed 3.13.1
                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
                Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
                Adapter    "mielecloudservice": 6.5.7, installed 6.5.7
                Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
                Adapter    "robonect"     : 1.4.2    , installed 1.4.2
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "sql"          : 3.0.1    , installed 3.0.1
                Adapter    "swiss-weather-api": 2.2.2, installed 2.2.2
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Objects and States
                Objects:        14075
                States:         12650
                Pending Updates: 0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21092      729/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17555      1/init
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        20742      638/systemd-resolve
                tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      33         22168      719/python3
                tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21193      734/named
                tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21192      734/named
                tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN      0          21011      713/rsyslogd
                tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21189      734/named
                tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21188      734/named
                tcp        0      0 10.0.2.3:2010           0.0.0.0:*               LISTEN      1000       47554      4751/io.hm-rpc.0
                tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21203      734/named
                tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21202      734/named
                tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       46825      4688/io.hm-rpc.1
                tcp        0      0 0.0.0.0:10051           0.0.0.0:*               LISTEN      114        22143      769/zabbix_server
                tcp6       0      0 :::8443                 :::*                    LISTEN      116        53308      5179/java
                tcp6       0      0 :::22                   :::*                    LISTEN      0          21094      729/sshd: /usr/sbin
                tcp6       0      0 :::111                  :::*                    LISTEN      0          17557      1/init
                tcp6       0      0 :::8888                 :::*                    LISTEN      33         22169      719/python3
                tcp6       0      0 :::514                  :::*                    LISTEN      0          21012      713/rsyslogd
                tcp6       0      0 127.0.0.1:8101          :::*                    LISTEN      116        52709      5179/java
                tcp6       0      0 :::3000                 :::*                    LISTEN      117        22256      676/grafana
                tcp6       0      0 :::5007                 :::*                    LISTEN      116        52804      5179/java
                tcp6       0      0 127.0.0.1:36473         :::*                    LISTEN      116        52681      5179/java
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       49767      5017/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46429      4564/io.admin.0
                tcp6       0      0 :::8080                 :::*                    LISTEN      116        52716      5179/java
                tcp6       0      0 :::10051                :::*                    LISTEN      114        22144      769/zabbix_server
                tcp6       0      0 :::10050                :::*                    LISTEN      114        22132      720/zabbix_agent2
                udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21191      734/named
                udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21190      734/named
                udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21187      734/named
                udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21186      734/named
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        20741      638/systemd-resolve
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21973      686/dhclient
                udp        0      0 10.0.2.3:68             0.0.0.0:*                           101        20733      636/systemd-network
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17556      1/init
                udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          20974      709/chronyd
                udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          21007      713/rsyslogd
                udp6       0      0 :::1900                 :::*                                116        52837      5179/java
                udp6       0      0 :::1902                 :::*                                116        53588      5179/java
                udp6       0      0 :::111                  :::*                                0          17558      1/init
                udp6       0      0 ::1:323                 :::*                                0          20975      709/chronyd
                udp6       0      0 :::514                  :::*                                0          21008      713/rsyslogd
                udp6       0      0 10.0.2.3:54045          :::*                                116        52838      5179/java
                udp6       0      0 :::5353                 :::*                                116        52733      5179/java
                2025-01-03 21:22:02.565  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                2025-01-03 21:22:03.045  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                2025-01-03 21:22:03.190  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:03.190  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:12.605  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                2025-01-03 21:22:14.323  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                2025-01-03 21:22:14.465  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:14.466  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:22.647  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                2025-01-03 21:22:25.633  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                2025-01-03 21:22:25.771  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:25.771  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:32.688  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                2025-01-03 21:22:37.012  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                2025-01-03 21:22:37.182  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:37.182  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:42.729  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                2025-01-03 21:22:48.357  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                2025-01-03 21:22:48.504  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:48.504  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                2025-01-03 21:22:52.771  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                2025-01-03 21:22:59.911  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                2025-01-03 21:23:00.083  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                2025-01-03 21:23:00.083  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                2025-01-03 21:23:02.812  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                Der luxtronik Fehler ist mir bekannt, der ist schon immer da. Stört nicht, füllt nur das Log.
                und die nmp Abfrage:
                iobroker@UBU14:~$ npm ls @iobroker/sentry-plugin
                /home/iobroker
                └── (empty)
                • mcm1957
                  @64kbyte
                  npm ls bitte in /opt(/iobroker absetzen.
                  Sorry, hab ich nicht extra geschrieben.
                    Homoran Global Moderator Administrators @mcm1957 last edited by
                    @mcm1957 bei dir heisst es auch plugin-sentry
                    mcm1957 6 2 Replies Last reply Reply Quote 1
                    • mcm1957
                      mcm1957 @Homoran last edited by
                      YEP, das ist der zweite Fehler. Bin heute wohl schon zu lange am PC...
                      • 6
                        @mcm1957
                        Hab beides gemacht:
                        iobroker@UBU14:~$ cd /opt/iobroker/
                        iobroker@UBU14:/opt/iobroker$ npm ls @iobroker/sentry-plugin
                        └── (empty)
                        iobroker@UBU14:/opt/iobroker$ npm ls @iobroker/plugin-sentry
                        └─┬ iobroker.js-controller@7.0.6
                        • mcm1957
                          @64kbyte
                          OK schaut mal normal aus.
                          ioBroker funktioniert normal abgesehen von der Fehlermeldung im Log. Hab ich das richtig mitbekommen?
                          Ehrlich - ich hab keine Idee mehr was da nicht stimmen könnte. Ich glaub da kann maximal @foxriver76 noch was dazu sagen. Ev. mach ein Issue beim js-controller auf. Wenn du ein Testsystem hast, check mal mit der aktuellen Beta des js-controllers.
                          Hast du Statistic Reporting generell gesperrt / Sentry global deaktiviert? Sollte dann auch nicht den Fehler werfen aber wer weiß :-).
                          • 6
                            @64kbyte
                            Habe ich probiert, ist wirkungslos:
                            iobroker@UBU14:~$ iob plugin disable sentry
                            The plugin "sentry" was successfully disabled for host "UBU14".
                            iobroker@UBU14:~$ iob restart
                            und trotzdem im Log:
                            2025-01-04 08:58:58.360  - info: host.UBU14 instance system.adapter.sql.0 in version "3.0.1" started with pid 45612
                            2025-01-04 08:58:58.984  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
                            Require stack:
                            2025-01-04 08:59:02.406  - info: host.UBU14 instance system.adapter.javascript.0 in version "8.8.3" started with pid 45642
                            2025-01-04 08:59:03.326  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
                            Require stack:
                            ... und immer so weiter bei jedem einzelnen Adapter
                            • mcm1957
                              @foxriver76
                              Irgendeine Idee dazu?
                              939
