    4. Test Adapter Bosch ebik connect / flow
    • bahnuhr
      ebike flow
      Funktioniert der Adapter bei euch noch ?
      • bahnuhr
        Auch mit der 0.1.9 bekomme ich noch error:
        host.iobroker
        2024-12-30 10:22:28.476	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2024-12-30 10:22:28.476	error	Caught by controller[1]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        host.iobroker
        2024-12-30 10:22:28.476	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        host.iobroker
        2024-12-30 10:22:28.476	error	Caught by controller[1]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:204:65)
        host.iobroker
        2024-12-30 10:22:28.476	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'split')
        host.iobroker
        2024-12-30 10:22:28.475	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        bosch-ebike.0
        2024-12-30 10:22:27.893	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        bosch-ebike.0
        2024-12-30 10:22:27.892	info	terminating
        bosch-ebike.0
        2024-12-30 10:22:27.883	error	Cannot read properties of undefined (reading 'split')
        bosch-ebike.0
        2024-12-30 10:22:27.883	error	TypeError: Cannot read properties of undefined (reading 'split') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:204:65) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        bosch-ebike.0
        2024-12-30 10:22:27.881	error	unhandled promise rejection: Cannot read properties of undefined (reading 'split')
        bosch-ebike.0
        2024-12-30 10:22:27.880	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        bosch-ebike.0
        2024-12-30 10:22:27.150	info	Login to eBike flow
        B T 2 Replies Last reply Reply Quote 0
          bommel_030 @bahnuhr last edited by
          @bahnuhr
          Bei mir lief er einwandfrei. Nach deinem Post hab ich neu gestartet, seitdem den gleichen Fehler 😞
            tombox @bahnuhr last edited by
            @bahnuhr @bommel_030
            bitte die GitHub Version testen
            bahnuhr B 2 Replies Last reply Reply Quote 0
            • bahnuhr
              bahnuhr Forum Testing Most Active @tombox last edited by
              @tombox
              Habe von github installiert.
              Im log kommt dann:
              bosch-ebike.0
              2025-01-03 14:46:01.590	error	Please set captcha in the instance settings
              Dann probiert die Instanz zu öffnen.
              Unten erscheint dann:
              file "jsonConfig.json: Not exist
              Bitte nochmal schauen. Danke.
                @bahnuhr ich musste was umstellen
                entweder man löscht die Instanz und erzeugt sie neu
                oder man löscht in
                "adminUI": {
                  "config": "json"
                bahnuhr 1 Reply Last reply Reply Quote 1
                • bahnuhr
                  bahnuhr Forum Testing Most Active @tombox last edited by bahnuhr
                  @tombox sagte in Test Adapter Bosch ebik connect / flow:
                  oder man löscht in
                  Super, Danke.
                  Das löschen hat geklappt und die Instanz öffnet sich wieder.
                    reini84 last edited by
                    läuft die 0.1.11 bei euch?
                    Captcha erstellt aber dennoch Fehler im Log
                      tombox @reini84 last edited by
                      @reini84 Im Debug log gucken ob mehr angezeigt wird
                        reini84 @tombox last edited by Negalein
                        @tombox
                        2025-01-05 11:04:07.694 - info: admin.0 (622645) <== Disconnect system.user.admin from ::ffff:192.168.178.105 admin
                        2025-01-05 11:04:08.082 - info: admin.0 (622645) ==> Connected system.user.admin from ::ffff:192.168.178.105
                        2025-01-05 11:04:18.799 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 (force=false, process=true)
                        2025-01-05 11:04:18.801 - info: bosch-ebike.0 (630546) Got terminate signal TERMINATE_YOURSELF
                        2025-01-05 11:04:18.802 - info: bosch-ebike.0 (630546) terminating
                        2025-01-05 11:04:18.802 - debug: bosch-ebike.0 (630546) Plugin sentry destroyed
                        2025-01-05 11:04:18.802 - info: bosch-ebike.0 (630546) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2025-01-05 11:04:18.840 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 send kill signal
                        2025-01-05 11:04:19.303 - info: bosch-ebike.0 (630546) terminating
                        2025-01-05 11:04:19.348 - info: host.iobroker instance system.adapter.bosch-ebike.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2025-01-05 11:04:22.643 - info: host.iobroker instance system.adapter.bosch-ebike.0 in version "0.1.11" (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) started with pid 630576
                        2025-01-05 11:04:23.116 - debug: bosch-ebike.0 (630576) Redis Objects: Use Redis connection: 0.0.0.0:9001
                        2025-01-05 11:04:23.134 - debug: bosch-ebike.0 (630576) Objects client ready ... initialize now
                        2025-01-05 11:04:23.176 - debug: bosch-ebike.0 (630576) Objects create System PubSub Client
                        2025-01-05 11:04:23.177 - debug: bosch-ebike.0 (630576) Objects create User PubSub Client
                        2025-01-05 11:04:23.202 - debug: bosch-ebike.0 (630576) Objects client initialize lua scripts
                        2025-01-05 11:04:23.205 - debug: bosch-ebike.0 (630576) Objects connected to redis: 0.0.0.0:9001
                        2025-01-05 11:04:23.223 - debug: bosch-ebike.0 (630576) Redis States: Use Redis connection: 0.0.0.0:9000
                        2025-01-05 11:04:23.231 - debug: bosch-ebike.0 (630576) States create System PubSub Client
                        2025-01-05 11:04:23.231 - debug: bosch-ebike.0 (630576) States create User PubSub Client
                        2025-01-05 11:04:23.286 - debug: bosch-ebike.0 (630576) States connected to redis: 0.0.0.0:9000
                        2025-01-05 11:04:23.303 - debug: bosch-ebike.0 (630576) Plugin sentry Initialize Plugin (enabled=true)
                        2025-01-05 11:04:23.439 - info: bosch-ebike.0 (630576) starting. Version 0.1.11 (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v20.18.1, js-controller: 7.0.6
                        2025-01-05 11:04:23.455 - info: bosch-ebike.0 (630576) Login to eBike flow
                        2025-01-05 11:04:23.456 - error: bosch-ebike.0 (630576) Please set captcha in the instance settings
                        2025-01-05 11:04:29.847 - info: admin.0 (622645) ==> Connected system.user.admin from ::ffff:192.168.178.105
                        2025-01-05 11:04:30.049 - info: sonoff.0 (613233) Client [Heizung] reconnected. Old secret 1735914402782_2115 ==> New secret 1736071470048_7239
                        2025-01-05 11:04:33.129 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 (force=false, process=true)
                        2025-01-05 11:04:33.131 - info: bosch-ebike.0 (630576) Got terminate signal TERMINATE_YOURSELF
                        2025-01-05 11:04:33.132 - info: bosch-ebike.0 (630576) terminating
                        2025-01-05 11:04:33.132 - debug: bosch-ebike.0 (630576) Plugin sentry destroyed
                        2025-01-05 11:04:33.133 - info: bosch-ebike.0 (630576) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2025-01-05 11:04:33.171 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 send kill signal
                        2025-01-05 11:04:33.633 - info: bosch-ebike.0 (630576) terminating
                        2025-01-05 11:04:33.676 - info: host.iobroker instance system.adapter.bosch-ebike.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2025-01-05 11:04:36.589 - info: admin.0 (622645) <== Disconnect system.user.admin from ::ffff:192.168.178.105
                        2025-01-05 11:04:36.972 - info: host.iobroker instance system.adapter.bosch-ebike.0 in version "0.1.11" (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) started with pid 630591
                        2025-01-05 11:04:37.452 - debug: bosch-ebike.0 (630591) Redis Objects: Use Redis connection: 0.0.0.0:9001
                        2025-01-05 11:04:37.469 - debug: bosch-ebike.0 (630591) Objects client ready ... initialize now
                        2025-01-05 11:04:37.470 - debug: bosch-ebike.0 (630591) Objects create System PubSub Client
                        2025-01-05 11:04:37.471 - debug: bosch-ebike.0 (630591) Objects create User PubSub Client
                        2025-01-05 11:04:37.497 - debug: bosch-ebike.0 (630591) Objects client initialize lua scripts
                        2025-01-05 11:04:37.500 - debug: bosch-ebike.0 (630591) Objects connected to redis: 0.0.0.0:9001
                        2025-01-05 11:04:37.519 - debug: bosch-ebike.0 (630591) Redis States: Use Redis connection: 0.0.0.0:9000
                        2025-01-05 11:04:37.527 - debug: bosch-ebike.0 (630591) States create System PubSub Client
                        2025-01-05 11:04:37.528 - debug: bosch-ebike.0 (630591) States create User PubSub Client
                        2025-01-05 11:04:37.583 - debug: bosch-ebike.0 (630591) States connected to redis: 0.0.0.0:9000
                        2025-01-05 11:04:37.602 - debug: bosch-ebike.0 (630591) Plugin sentry Initialize Plugin (enabled=true)
                        2025-01-05 11:04:37.728 - info: bosch-ebike.0 (630591) starting. Version 0.1.11 (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v20.18.1, js-controller: 7.0.6
                        2025-01-05 11:04:37.744 - info: bosch-ebike.0 (630591) Login to eBike flow
                        2025-01-05 11:04:38.583 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n \n <title>Willkommen - SingleKey ID</title>\n <meta name="\"description\"" content="\"Willkommen\"">\n\n <base href="\"https://singlekey-id.com\"">\n <link rel="\"icon\"" type="\"image/svg+xml\"" href="\"https://cdn.singlekey-id.com/images/favicons/vector.fLinwNmN0b4.svg\"" sizes="\"any\"">\n <link rel="\"icon\"" type="\"image/png\"" href="\"https://cdn.singlekey-id.com/images/favicons/16x16.Ie2d4OLHBZc.png\"" sizes="\"16x16\"">\n\n <meta name="\"viewport\"" content="\"width=device-width," initial-scale="1\"">\n\n <meta name="\"htmx-config\"" content="{\"inlineScriptNonce\":\"BGPomBS76d7pEfO8KFP12B-e\", \"includeIndicatorStyles\":false, \"refreshOnHistoryMiss\": true, \"timeout\": 20000}">\n\n \n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/default.8ULbJ7zIe70.css\"">\n\n \n\n\n <script nonce="\"BGPomBS76d7pEfO8KFP12B-e\"">\n document.querySelector(\"html\").className = \"js\";\n </script>\n \n\n \n <div class="\"captcha-dialog\"">\n <div class="\"captcha-dialog__content\""></div>\n </div>\n\n \n\n\n\n<header class="\"seamless-layout__header\"">\n <h1>\n <a class="\"seamless-layout__header-link\"" data-hx-boost="\"false\"" href="\"/de-de/home\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" srcset="\"https://cdn.singlekey-id.com/images/logo-on-dark.t-FKZg_FN7I.svg\"">\n <img class="\"seamless-layout__skid-logo\"" src="\"https://cdn.singlekey-id.com/images/logo-on-light.qEQuOq98Y4I.svg\"" alt="\"SingleKey" id\"="">\n </picture>\n </a>\n </h1>\n\n <img class="\"seamless-layout__partner-logo\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/brand-logo.4p7gk_UxIDA.svg\"" alt="\"Bosch\"" data-testid="\"seamless-partner-logo\"">\n</header>\n\n<main class="\"seamless-layout__main\"" data-hx-swap="\"show:none" focus-scroll:true\"="">\n <div class="\"seamless-layout__left-panel\"">\n <div class="\"seamless-layout__content\"">\n \n<div id="\"inline-messages\"" class="\"" messages\"="">\n <noscript>\n <div class=\"message message--error message--permanent\" data-testid=\"javascript-required-error\">\n <i class=\"message__icon icon icon--size-l icon--error\"></i>\n <span>Bitte aktivieren Sie JavaScript, um fortzufahren.</span>\n </div>\n </noscript>\n</div>\n\n <div id="\"body\"">\n \n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"" data-testid="\"enter-username\"">\n <h2 class="\"seamless-content__header\"">\n Registrieren oder einloggen\n \n<div class="\"popup" \"="">\n <a class="\"popup__open-popup\"" role="\"button\"" aria-label="\"Open" popup\"="" aria-expanded="\"false\"" aria-controls="\"signup-or-login-hint\"" hx-boost="\"false\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#signup-or-login-hint\"">\n <i class="\"icon" icon--info="" popup__open-popup-icon="" icon--size-s\"=""></i>\n </a>\n <div id="\"signup-or-login-hint\"" class="\"popup__content\"">\n <h2 class="\"popup__header\"">\n Registrieren oder einloggen\n <a class="\"popup__close-popup\"" role="\"button\"" aria-label="\"Close" popup\"="" hx-boost="\"false\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#\"">\n <i class="\"icon" icon--close="" icon--invert="" icon--size-s\"=""></i>\n </a>\n </h2>\n <p class="\"popup__text\"">Bitte geben Sie Ihre E-Mail-Adresse oder Handynummer ein, damit wir prüfen können, ob Sie bereits eine SingleKey ID haben. Wir leiten Sie dann entweder zur Anmeldung oder zur Registrierung weiter.</p>\n </div>\n</div>\n </h2>\n\n <form class="\"form\"" method="\"post\"">\n \n\n<div>\n\n\n\n\n<div class="\"input\"">\n <input class="\"input__element\"" type="\"text\"" inputmode="\"email\"" placeholder="\" \"" autocomplete="\"email\"" autofocus="\"autofocus\"" id="\"UserIdentifierInput_EmailInput_StringValue\"" name="\"UserIdentifierInput.EmailInput.StringValue\"" value="\"\"">\n <label class="\"input__placeholder\"" for="\"UserIdentifierInput_EmailInput_StringValue\"">E-Mail</label>\n \n</div> <a data-testid="\"user-identifier-switch-to-phone-link\"" class="\"link" user-identifier__switch-link\"="" href="\"/de-de/login?input=phone&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n <i class="\"user-identifier__icon" icon="" icon--smartphone-blue="" icon--size-s\"=""></i>\n <span>Handynummer verwenden</span>\n </a>\n</div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit="" button--protected\"="" data-loading-class="\"button--loading\"" data-testid="\"enter-username.submit\"" data-sitekey="\"f8fe2d56-ad42-4f44-b9fe-5b30fcb0dd38\"" data-hl="\"de\"" disabled="\"\"">\n Weiter\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDUtwJh6c3XWMrt76-0kJH1OHg_Pq9_HtGlJxUojIXIcAaAm4GUzUZhnb8_WQePNhamcWkEB8hWgGAsVBD4J4UL9QTWI3xbsRIcIPmFGG2eeri6g99HyBg_3BXed-6zu7M\""></form>\n</div>\n </div>\n </div>\n <div class="\"about\"" id="\"about\"" data-hx-boost="\"false\"">\n <div class="\"about__header\"">\n <text class="\"about__title\"">Ein Login für viele Marken</text>\n <a class="\"about__show-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Show" singlekey="" id="" info\"="" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#about\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert="" icon--rotate180\"=""></i>\n </a>\n <a class="\"about__hide-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Hide" singlekey="" id="" info\"="" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert\"=""></i>\n </a>\n </div>\n \n<div class="\"brands" about__brands\"="">\n <button class="\"brands__nav" brands__btn-left="" brands__btn-left--hidden="" button="" button--icon\"="" role="\"button\"" aria-hidden="\"true\"">\n <i class="\"icon" icon--arrow-left="" icon--size-m\"=""></i>\n </button>\n <div class="\"brands__carousel\"">\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Bosch\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_01.4p7gk_UxIDA.svg\"" width="\"130\"" height="\"28,822172\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Siemens" home="" appliances\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_02.VXu-FBivXhE.svg\"" width="\"130\"" height="\"52,769993\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Buderus\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_03.OiMrTqOdPwk.svg\"" width="\"130\"" height="\"47,068966\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Home" connect\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_04.yP-gzACpJjE.svg\"" width="\"130\"" height="\"21,77665\"" draggable="\"false\"">\n </div>\n </div>\n <button class="\"brands__nav" brands__btn-right="" button="" button--icon\"="" role="\"button\"">\n <i class="\"icon" icon--arrow-right="" icon--size-m\"=""></i>\n </button>\n</div>\n <div class="\"about__info\""><a href="\"/our-promise/\"">SingleKey ID</a> bietet bequemen Zugang zu Websites, Shops, Apps und Services vieler Marken mit <b>einem einzigen Login</b>.</div>\n </div>\n </div>\n <div class="\"seamless-layout__right-panel\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" sizes="\"1px\"" srcset="\"https://cdn.singlekey-id.com/images/none.590RTqhrx1o.gif" 1w\"="">\n\n <source media="\"(min-width:" 768px)\"="" type="\"image/avif\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.DzqOrR_opYg.avif" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.7mgln4u6d_s.avif="" 1024w,="" background_1366x986.zu1usdfcir4.avif="" 1366w,="" background_1600x1155.5wo0czejume.avif="" 1600w,="" background_1920x1386.mhctivdddms.avif="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/webp\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.4m-_t_WNuD4.webp" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.aqnzlbdi_no.webp="" 1024w,="" background_1366x986.ulgityj-5a0.webp="" 1366w,="" background_1600x1155.gviq-nk338y.webp="" 1600w,="" background_1920x1386.efuynlavpgu.webp="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/jpeg\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.AAH3SmmHwGE.jpg" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.xzvtpkydfve.jpg="" 1024w,="" background_1366x986.jfxrhjeqyw8.jpg="" 1366w,="" background_1600x1155.udo9ihuhy48.jpg="" 1600w,="" background_1920x1386.g6onbgekap8.jpg="" 1920w\"="">\n <img class="\"seamless-layout__hero-image\"" alt="\"\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/background_1920x1386.g6ONbGEKAp8.jpg\"" data-testid="\"seamless-background\"">\n </picture>\n </div>\n</main>\n\n\n\n<footer class="\"footer\"">\n <nav class="\"footer__content" footer__content--justified\"="">\n <ul class="\"footer__links\"">\n <li>\n <a class="\"footer__link\"" href="\"/de-de/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Impressum\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/data-protection-notice\"" data-hx-boost="\"false\"">\n Datenschutzrichtlinie\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Rechtliche Hinweise\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/terms-of-use\"" data-hx-boost="\"false\"">\n Nutzungsbedingungen\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"https://cdn.singlekey-id.com/disclosure-document.BMdLREMiXRU.pdf\"" data-hx-boost="\"false\"">\n Open Source Informationen\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/frequently-asked-questions\"" data-hx-boost="\"false\"">\n FAQs\n </a>\n </li>\n </ul>\n \n\n<form class="\"language-switch" footer__link\"="" method="\"post\"" action="\"/de-de/language\"">\n <i class="\"icon" icon--globe="" icon--size-xl\"=""></i>\n <select name="\"culture\"" class="\"language-switch__select\"" data-testid="\"language-switch\""><option value="\"az-AZ\"">azərbaycan (Azərbaycan)</option>\n<option value="\"bs-BA\"">bosanski (Bosna i Hercegovina)</option>\n<option value="\"cs-CZ\"">čeština (Česko)</option>\n<option value="\"da-DK\"">dansk (Danmark)</option>\n<option value="\"de-BE\"">Deutsch (Belgien)</option>\n<option selected="\"selected\"" value="\"de-DE\"">Deutsch (Deutschland)</option>\n<option value="\"de-LI\"">Deutsch (Liechtenstein)</option>\n<option value="\"de-LU\"">Deutsch (Luxemburg)</option>\n<option value="\"de-AT\"">Deutsch (Österreich)</option>\n<option value="\"de-CH\"">Deutsch (Schweiz)</option>\n<option value="\"et-EE\"">eesti (Eesti)</option>\n<option value="\"en-AU\"">English (Australia)</option>\n<option value="\"en-BD\"">English (Bangladesh)</option>\n<option value="\"en-CA\"">English (Canada)</option>\n<option value="\"en-GH\"">English (Ghana)</option>\n<option value="\"en-IN\"">English (India)</option>\n<option value="\"en-IE\"">English (Ireland)</option>\n<option value="\"en-KE\"">English (Kenya)</option>\n<option value="\"en-MY\"">English (Malaysia)</option>\n<option value="\"en-MT\"">English (Malta)</option>\n<option value="\"en-NP\"">English (Nepal)</option>\n<option value="\"en-NZ\"">English (New Zealand)</option>\n<option value="\"en-NG\"">English (Nigeria)</option>\n<option value="\"en-PH\"">English (Philippines)</option>\n<option value="\"en-SG\"">English (Singapore)</option>\n<option value="\"en-ZA\"">English (South Africa)</option>\n<option value="\"en-LK\"">English (Sri Lanka)</option>\n<option value="\"en-GB\"">English (United Kingdom)</option>\n<option value="\"en-US\"">English (United States)</option>\n<option value="\"es-AR\"">español (Argentina)</option>\n<option value="\"es-BO\"">español (Bolivia)</option>\n<option value="\"es-CL\"">español (Chile)</option>\n<option value="\"es-CO\"">español (Colombia)</option>\n<option value="\"es-CR\"">español (Costa Rica)</option>\n<option value="\"es-EC\"">español (Ecuador)</option>\n<option value="\"es-SV\"">español (El Salvador)</option>\n<option value="\"es-ES\"">español (España)</option>\n<option value="\"es-GT\"">español (Guatemala)</option>\n<option value="\"es-HN\"">español (Honduras)</option>\n<option value="\"es-MX\"">español (México)</option>\n<option value="\"es-NI\"">español (Nicaragua)</option>\n<option value="\"es-PA\"">español (Panamá)</option>\n<option value="\"es-PY\"">español (Paraguay)</option>\n<option value="\"es-PE\"">español (Perú)</option>\n<option value="\"es-DO\"">español (República Dominicana)</option>\n<option value="\"es-UY\"">español (Uruguay)</option>\n<option value="\"es-VE\"">español (Venezuela)</option>\n<option value="\"fr-BE\"">français (Belgique)</option>\n<option value="\"fr-CA\"">français (Canada)</option>\n<option value="\"fr-FR\"">français (France)</option>\n<option value="\"fr-LU\"">français (Luxembourg)</option>\n<option value="\"fr-CH\"">français (Suisse)</option>\n<option value="\"fr-TN\"">français (Tunisie)</option>\n<option value="\"hr-HR\"">hrvatski (Hrvatska)</option>\n<option value="\"id-ID\"">Indonesia (Indonesia)</option>\n<option value="\"is-IS\"">íslenska (Ísland)</option>\n<option value="\"it-IT\"">italiano (Italia)</option>\n<option value="\"it-CH\"">italiano (Svizzera)</option>\n<option value="\"lv-LV\"">latviešu (Latvija)</option>\n<option value="\"lt-LT\"">lietuvių (Lietuva)</option>\n<option value="\"hu-HU\"">magyar (Magyarország)</option>\n<option value="\"cnr-ME\"">Montenegrin (Montenegro)</option>\n<option value="\"nl-BE\"">Nederlands (België)</option>\n<option value="\"nl-NL\"">Nederlands (Nederland)</option>\n<option value="\"no-NO\"">norsk (Norge)</option>\n<option value="\"pl-PL\"">polski (Polska)</option>\n<option value="\"pt-AO\"">português (Angola)</option>\n<option value="\"pt-BR\"">português (Brasil)</option>\n<option value="\"pt-PT\"">português (Portugal)</option>\n<option value="\"ro-MD\"">română (Republica Moldova)</option>\n<option value="\"ro-RO\"">română (România)</option>\n<option value="\"sq-XK\"">shqip (Kosovë)</option>\n<option value="\"sq-AL\"">shqip (Shqipëri)</option>\n<option value="\"sk-SK\"">slovenčina (Slovensko)</option>\n<option value="\"sl-SI\"">slovenščina (Slovenija)</option>\n<option value="\"fi-FI\"">suomi (Suomi)</option>\n<option value="\"sv-SE\"">svenska (Sverige)</option>\n<option value="\"vi-VN\"">Tiếng Việt (Việt Nam)</option>\n<option value="\"tr-TR\"">Türkçe (Türkiye)</option>\n<option value="\"el-GR\"">Ελληνικά (Ελλάδα)</option>\n<option value="\"el-CY\"">Ελληνικά (Κύπρος)</option>\n<option value="\"bg-BG\"">български (България)</option>\n<option value="\"kk-KZ\"">қазақ тілі (Қазақстан)</option>\n<option value="\"mk-MK\"">македонски (Северна Македонија)</option>\n<option value="\"sr-RS\"">српски (Србија)</option>\n<option value="\"uk-UA\"">українська (Україна)</option>\n<option value="\"ka-GE\"">ქართული (საქართველო)</option>\n<option value="\"he-IL\"">עברית (ישראל)</option>\n<option value="\"ar-AE\"">العربية (الإمارات العربية المتحدة)</option>\n<option value="\"ar-BH\"">العربية (البحرين)</option>\n<option value="\"ar-KW\"">العربية (الكويت)</option>\n<option value="\"ar-MA\"">العربية (المغرب)</option>\n<option value="\"ar-SA\"">العربية (المملكة العربية السعودية)</option>\n<option value="\"ar-TN\"">العربية (تونس)</option>\n<option value="\"ar-OM\"">العربية (عُمان)</option>\n<option value="\"ar-QA\"">العربية (قطر)</option>\n<option value="\"ar-LB\"">العربية (لبنان)</option>\n<option value="\"ar-EG\"">العربية (مصر)</option>\n<option value="\"th-TH\"">ไทย (ไทย)</option>\n<option value="\"ko-KR\"">한국어(대한민국)</option>\n<option value="\"zh-HK\"">中文(中國香港特別行政區)</option>\n<option value="\"zh-TW\"">中文(台灣)</option>\n<option value="\"ja-JP\"">日本語 (日本)</option>\n</select>\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/de-de/login?ReturnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n\n <button class="\"language-switch__submit" button="" button--submit\"="" type="\"submit\"">\n Speichern\n </button>\n<input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDUtwJh6c3XWMrt76-0kJH1OHg_Pq9_HtGlJxUojIXIcAaAm4GUzUZhnb8_WQePNhamcWkEB8hWgGAsVBD4J4UL9QTWI3xbsRIcIPmFGG2eeri6g99HyBg_3BXed-6zu7M\""></form>\n </nav>\n</footer>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/htmx.00GdzawUlLg.mjs\""></script>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/base.veDyGCvmY8w.mjs\""></script>\n <script defer="" nomodule="" src="\"https://cdn.singlekey-id.com/scripts/base.B5E8ztDgVe0.js\""></script>\n\n <script nonce="\"BGPomBS76d7pEfO8KFP12B-e\"">(function() {\n if (window.hcaptcha === undefined) {\n var hcaptchaScript = document.createElement('script');\n hcaptchaScript.src = 'https://js.hcaptcha.com/1/api.js?recaptchacompat=off&onload=onHCaptchaLoaded&render=explicit';\n hcaptchaScript.defer = true;\n hcaptchaScript.async = true;\n document.head.appendChild(hcaptchaScript);\n }\n})();</script>\n\n \n \n\n \n\n"
                        2025-01-05 11:04:38.892 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"">\n <h2 class="\"seamless-content__header\"">Einloggen</h2>\n <form class="\"form\"" method="\"post\"" data-hx-boost="\"true\"">\n \n<a class="\"seamless-content__username-link" link\"="" data-testid="\"link-back-to-login\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n <i class="\"icon" icon--arrow-left="" icon--size-s\"=""></i>\n <span class="\"break-word\"">reinhold.dobmeier@gmail.com</span>\n</a>\n \n<div class="\"input\"">\n <input class="\"input__element\"" placeholder="\" \"" autocomplete="\"current-password\"" autofocus="\"autofocus\"" type="\"password\"" id="\"Password\"" name="\"Password\"">\n <label class="\"input__placeholder\"" for="\"Password\"">Passwort</label>\n \n\n <button class="\"input__password-toggle" button="" button--icon\"="" type="\"button\"" role="\"switch\"" aria-pressed="\"false\"" title="\"Sichtbarkeit" des="" passworts="" umschalten\"="" aria-label="\"Sichtbarkeit">\n <i class="\"icon" icon--eye-open="" icon--size-l\"=""></i>\n </button>\n</div>\n <div class="\"password\"">\n <div class="\"password__remember-me\"">\n \n<div class="\"input" checkbox\"="">\n <div class="\"checkbox__group\"">\n <input class="\"checkbox__element\"" type="\"checkbox\"" id="\"RememberMe\"" name="\"RememberMe\"" value="\"true\"">\n <label class="\"checkbox__label\"" for="\"RememberMe\"">Eingeloggt bleiben</label>\n </div>\n \n</div>\n </div>\n <div class="\"password__forgot-password\"">\n <button class="\"link\"" data-testid="\"link-forgot-password\"" formaction="\"/de-de/login/password?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx&handler=ForgotPassword\"">Passwort vergessen?</button>\n </div>\n </div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit\"="" data-loading-class="\"button--loading\"" type="\"submit\"" data-testid="\"enter-password.submit\"">\n Weiter\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"RememberMe\"" type="\"hidden\"" value="\"false\""><input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QA2_h-JjdAD9WWabPzgckLb0i_cF9CmQ3AO_iWkbi31ZwyLoMAuYMnxcL3Ud9woFzIn8b3ALwarwhrgQXSA2ty9xynP2QoZgjRVY5BNbCqIJa5Asyy6JNvIsWMa24f_2-0\""></form>\n</div>\n\n<script nonce="\"X90qMjdVnI65X4PF1ou1P7ev\"">\n setTimeout(() => {\n document.title = \"Willkommen - SingleKey ID\";\n document.querySelector('meta[name=\"description\"]').setAttribute(\"content\", \"Willkommen\");\n document.body.setAttribute(\"data-testid\", \"login\");\n }, 0);\n</script>\n\n <a id="\"login-button\"" class="\"header__button" header__button--secondary="" header__button--login\"="" data-hx-swap-oob="\"true\"" data-hx-boost="\"false\"" data-testid="\"login\"" href="\"/de-de/login?forward=%2Fde-de%2Flogin%2Fpassword%3FreturnUrl%3D%252Fauth%252Fconnect%252Fauthorize%252Fcallback%253Fscope%253Dopenid%252520email%252520profile%252520offline_access%2526state%253DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%2526response_type%253Dcode%2526client_id%253DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%2526redirect_uri%253Dhttps%25253A%25252F%25252Fp9.authz.bosch.com%25252Fauth%25252Frealms%25252Fobc%25252Fbroker%25252Fskid%25252Fendpoint%2526prompt%253Dlogin%2526code_challenge%253DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%2526code_challenge_method%253DS256%2526nonce%253DMZqss0rdp9TovSq2Zs_vZQ%2526suppressed_prompt%253Dlogin%26f%3DaUyx&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n Einloggen\n </a>\n\n\n\n\n\n<div id="\"inline-messages\"" class="\"" messages\"="" data-hx-swap-oob="\"innerHTML\"">\n</div>\n\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/de-de/login/password?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n\n\n\n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/pages/login-or-signup/enter-password.ni6XlYwjP1Q.css\"">\n\n\n\n"
                        2025-01-05 11:04:39.643 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n \n <title>Welcome - SingleKey ID</title>\n <meta name="\"description\"" content="\"Welcome\"">\n\n <base href="\"https://singlekey-id.com\"">\n <link rel="\"icon\"" type="\"image/svg+xml\"" href="\"https://cdn.singlekey-id.com/images/favicons/vector.fLinwNmN0b4.svg\"" sizes="\"any\"">\n <link rel="\"icon\"" type="\"image/png\"" href="\"https://cdn.singlekey-id.com/images/favicons/16x16.Ie2d4OLHBZc.png\"" sizes="\"16x16\"">\n\n <meta name="\"viewport\"" content="\"width=device-width," initial-scale="1\"">\n\n <meta name="\"htmx-config\"" content="{\"inlineScriptNonce\":\"xi6ip3ZL9NWZ-x3udR9k7D8N\", \"includeIndicatorStyles\":false, \"refreshOnHistoryMiss\": true, \"timeout\": 20000}">\n\n \n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/default.8ULbJ7zIe70.css\"">\n\n \n\n\n <script nonce="\"xi6ip3ZL9NWZ-x3udR9k7D8N\"">\n document.querySelector(\"html\").className = \"js\";\n </script>\n \n\n \n <div class="\"captcha-dialog\"">\n <div class="\"captcha-dialog__content\""></div>\n </div>\n\n \n\n\n\n<header class="\"seamless-layout__header\"">\n <h1>\n <a class="\"seamless-layout__header-link\"" data-hx-boost="\"false\"" href="\"/en-gb/home\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" srcset="\"https://cdn.singlekey-id.com/images/logo-on-dark.t-FKZg_FN7I.svg\"">\n <img class="\"seamless-layout__skid-logo\"" src="\"https://cdn.singlekey-id.com/images/logo-on-light.qEQuOq98Y4I.svg\"" alt="\"SingleKey" id\"="">\n </picture>\n </a>\n </h1>\n\n <img class="\"seamless-layout__partner-logo\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/brand-logo.4p7gk_UxIDA.svg\"" alt="\"Bosch\"" data-testid="\"seamless-partner-logo\"">\n</header>\n\n<main class="\"seamless-layout__main\"" data-hx-swap="\"show:none" focus-scroll:true\"="">\n <div class="\"seamless-layout__left-panel\"">\n <div class="\"seamless-layout__content\"">\n \n<div id="\"inline-messages\"" class="\"" messages\"="">\n <noscript>\n <div class=\"message message--error message--permanent\" data-testid=\"javascript-required-error\">\n <i class=\"message__icon icon icon--size-l icon--error\"></i>\n <span>Please activate JavaScript in order to progress.</span>\n </div>\n </noscript>\n</div>\n\n <div id="\"body\"">\n \n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"" data-testid="\"enter-username\"">\n <h2 class="\"seamless-content__header\"">\n Sign up or log in\n \n<div class="\"popup" \"="">\n <a class="\"popup__open-popup\"" role="\"button\"" aria-label="\"Open" popup\"="" aria-expanded="\"false\"" aria-controls="\"signup-or-login-hint\"" hx-boost="\"false\"" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#signup-or-login-hint\"">\n <i class="\"icon" icon--info="" popup__open-popup-icon="" icon--size-s\"=""></i>\n </a>\n <div id="\"signup-or-login-hint\"" class="\"popup__content\"">\n <h2 class="\"popup__header\"">\n Sign up or log in\n <a class="\"popup__close-popup\"" role="\"button\"" aria-label="\"Close" popup\"="" hx-boost="\"false\"" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#\"">\n <i class="\"icon" icon--close="" icon--invert="" icon--size-s\"=""></i>\n </a>\n </h2>\n <p class="\"popup__text\"">Please enter your email address or mobile phone number and we will check if you already have a SingleKey ID. We will then redirect you to either login or signup.</p>\n </div>\n</div>\n </h2>\n\n <form class="\"form\"" method="\"post\"">\n \n\n<div>\n\n\n\n\n<div class="\"input\"">\n <input class="\"input__element\"" type="\"text\"" inputmode="\"email\"" placeholder="\" \"" autocomplete="\"email\"" autofocus="\"autofocus\"" id="\"UserIdentifierInput_EmailInput_StringValue\"" name="\"UserIdentifierInput.EmailInput.StringValue\"" value="\"\"">\n <label class="\"input__placeholder\"" for="\"UserIdentifierInput_EmailInput_StringValue\"">Email</label>\n \n</div> <a data-testid="\"user-identifier-switch-to-phone-link\"" class="\"link" user-identifier__switch-link\"="" href="\"/en-gb/login?input=phone&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U\"">\n <i class="\"user-identifier__icon" icon="" icon--smartphone-blue="" icon--size-s\"=""></i>\n <span>Use mobile phone number </span>\n </a>\n</div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit="" button--protected\"="" data-loading-class="\"button--loading\"" data-testid="\"enter-username.submit\"" data-sitekey="\"f8fe2d56-ad42-4f44-b9fe-5b30fcb0dd38\"" data-hl="\"en\"" disabled="\"\"">\n Continue\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDFDwsyguCI1OC2qSE4eGok8_Ub_Sb1sUkzhNvfOMH1PoGYxvsWgO9NDDyDGR_itfjTwG1yA09fs1iL4xN0snXsQaj2M6Zorz1-0qVbpFTii3_VOSv7wi1OYNtRTsFI1J0\""></form>\n</div>\n </div>\n </div>\n <div class="\"about\"" id="\"about\"" data-hx-boost="\"false\"">\n <div class="\"about__header\"">\n <text class="\"about__title\"">One login for many brands</text>\n <a class="\"about__show-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Show" singlekey="" id="" info\"="" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#about\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert="" icon--rotate180\"=""></i>\n </a>\n <a class="\"about__hide-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Hide" singlekey="" id="" info\"="" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert\"=""></i>\n </a>\n </div>\n \n<div class="\"brands" about__brands\"="">\n <button class="\"brands__nav" brands__btn-left="" brands__btn-left--hidden="" button="" button--icon\"="" role="\"button\"" aria-hidden="\"true\"">\n <i class="\"icon" icon--arrow-left="" icon--size-m\"=""></i>\n </button>\n <div class="\"brands__carousel\"">\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Bosch\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_01.4p7gk_UxIDA.svg\"" width="\"130\"" height="\"28.822172\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Siemens" home="" appliances\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_02.VXu-FBivXhE.svg\"" width="\"130\"" height="\"52.769993\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Buderus\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_03.OiMrTqOdPwk.svg\"" width="\"130\"" height="\"47.068966\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Home" connect\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_04.yP-gzACpJjE.svg\"" width="\"130\"" height="\"21.77665\"" draggable="\"false\"">\n </div>\n </div>\n <button class="\"brands__nav" brands__btn-right="" button="" button--icon\"="" role="\"button\"">\n <i class="\"icon" icon--arrow-right="" icon--size-m\"=""></i>\n </button>\n</div>\n <div class="\"about__info\""><a href="\"/our-promise/\"">SingleKey ID</a> offers convenient access to websites, shops, apps and services from many different brands with <b>one single login</b>.</div>\n </div>\n </div>\n <div class="\"seamless-layout__right-panel\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" sizes="\"1px\"" srcset="\"https://cdn.singlekey-id.com/images/none.590RTqhrx1o.gif" 1w\"="">\n\n <source media="\"(min-width:" 768px)\"="" type="\"image/avif\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.DzqOrR_opYg.avif" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.7mgln4u6d_s.avif="" 1024w,="" background_1366x986.zu1usdfcir4.avif="" 1366w,="" background_1600x1155.5wo0czejume.avif="" 1600w,="" background_1920x1386.mhctivdddms.avif="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/webp\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.4m-_t_WNuD4.webp" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.aqnzlbdi_no.webp="" 1024w,="" background_1366x986.ulgityj-5a0.webp="" 1366w,="" background_1600x1155.gviq-nk338y.webp="" 1600w,="" background_1920x1386.efuynlavpgu.webp="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/jpeg\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.AAH3SmmHwGE.jpg" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.xzvtpkydfve.jpg="" 1024w,="" background_1366x986.jfxrhjeqyw8.jpg="" 1366w,="" background_1600x1155.udo9ihuhy48.jpg="" 1600w,="" background_1920x1386.g6onbgekap8.jpg="" 1920w\"="">\n <img class="\"seamless-layout__hero-image\"" alt="\"\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/background_1920x1386.g6ONbGEKAp8.jpg\"" data-testid="\"seamless-background\"">\n </picture>\n </div>\n</main>\n\n\n\n<footer class="\"footer\"">\n <nav class="\"footer__content" footer__content--justified\"="">\n <ul class="\"footer__links\"">\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Corporate Information\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/data-protection-notice\"" data-hx-boost="\"false\"">\n Data Protection Policy\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Legal Notice\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/terms-of-use\"" data-hx-boost="\"false\"">\n Terms of Use\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"https://cdn.singlekey-id.com/disclosure-document.BMdLREMiXRU.pdf\"" data-hx-boost="\"false\"">\n Open Source Disclosure\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/frequently-asked-questions\"" data-hx-boost="\"false\"">\n FAQs\n </a>\n </li>\n </ul>\n \n\n<form class="\"language-switch" footer__link\"="" method="\"post\"" action="\"/en-gb/language\"">\n <i class="\"icon" icon--globe="" icon--size-xl\"=""></i>\n <select name="\"culture\"" class="\"language-switch__select\"" data-testid="\"language-switch\""><option value="\"az-AZ\"">azərbaycan (Azərbaycan)</option>\n<option value="\"bs-BA\"">bosanski (Bosna i Hercegovina)</option>\n<option value="\"cs-CZ\"">čeština (Česko)</option>\n<option value="\"da-DK\"">dansk (Danmark)</option>\n<option value="\"de-BE\"">Deutsch (Belgien)</option>\n<option value="\"de-DE\"">Deutsch (Deutschland)</option>\n<option value="\"de-LI\"">Deutsch (Liechtenstein)</option>\n<option value="\"de-LU\"">Deutsch (Luxemburg)</option>\n<option value="\"de-AT\"">Deutsch (Österreich)</option>\n<option value="\"de-CH\"">Deutsch (Schweiz)</option>\n<option value="\"et-EE\"">eesti (Eesti)</option>\n<option value="\"en-AU\"">English (Australia)</option>\n<option value="\"en-BD\"">English (Bangladesh)</option>\n<option value="\"en-CA\"">English (Canada)</option>\n<option value="\"en-GH\"">English (Ghana)</option>\n<option value="\"en-IN\"">English (India)</option>\n<option value="\"en-IE\"">English (Ireland)</option>\n<option value="\"en-KE\"">English (Kenya)</option>\n<option value="\"en-MY\"">English (Malaysia)</option>\n<option value="\"en-MT\"">English (Malta)</option>\n<option value="\"en-NP\"">English (Nepal)</option>\n<option value="\"en-NZ\"">English (New Zealand)</option>\n<option value="\"en-NG\"">English (Nigeria)</option>\n<option value="\"en-PH\"">English (Philippines)</option>\n<option value="\"en-SG\"">English (Singapore)</option>\n<option value="\"en-ZA\"">English (South Africa)</option>\n<option value="\"en-LK\"">English (Sri Lanka)</option>\n<option selected="\"selected\"" value="\"en-GB\"">English (United Kingdom)</option>\n<option value="\"en-US\"">English (United States)</option>\n<option value="\"es-AR\"">español (Argentina)</option>\n<option value="\"es-BO\"">español (Bolivia)</option>\n<option value="\"es-CL\"">español (Chile)</option>\n<option value="\"es-CO\"">español (Colombia)</option>\n<option value="\"es-CR\"">español (Costa Rica)</option>\n<option value="\"es-EC\"">español (Ecuador)</option>\n<option value="\"es-SV\"">español (El Salvador)</option>\n<option value="\"es-ES\"">español (España)</option>\n<option value="\"es-GT\"">español (Guatemala)</option>\n<option value="\"es-HN\"">español (Honduras)</option>\n<option value="\"es-MX\"">español (México)</option>\n<option value="\"es-NI\"">español (Nicaragua)</option>\n<option value="\"es-PA\"">español (Panamá)</option>\n<option value="\"es-PY\"">español (Paraguay)</option>\n<option value="\"es-PE\"">español (Perú)</option>\n<option value="\"es-DO\"">español (República Dominicana)</option>\n<option value="\"es-UY\"">español (Uruguay)</option>\n<option value="\"es-VE\"">español (Venezuela)</option>\n<option value="\"fr-BE\"">français (Belgique)</option>\n<option value="\"fr-CA\"">français (Canada)</option>\n<option value="\"fr-FR\"">français (France)</option>\n<option value="\"fr-LU\"">français (Luxembourg)</option>\n<option value="\"fr-CH\"">français (Suisse)</option>\n<option value="\"fr-TN\"">français (Tunisie)</option>\n<option value="\"hr-HR\"">hrvatski (Hrvatska)</option>\n<option value="\"id-ID\"">Indonesia (Indonesia)</option>\n<option value="\"is-IS\"">íslenska (Ísland)</option>\n<option value="\"it-IT\"">italiano (Italia)</option>\n<option value="\"it-CH\"">italiano (Svizzera)</option>\n<option value="\"lv-LV\"">latviešu (Latvija)</option>\n<option value="\"lt-LT\"">lietuvių (Lietuva)</option>\n<option value="\"hu-HU\"">magyar (Magyarország)</option>\n<option value="\"cnr-ME\"">Montenegrin (Montenegro)</option>\n<option value="\"nl-BE\"">Nederlands (België)</option>\n<option value="\"nl-NL\"">Nederlands (Nederland)</option>\n<option value="\"no-NO\"">norsk (Norge)</option>\n<option value="\"pl-PL\"">polski (Polska)</option>\n<option value="\"pt-AO\"">português (Angola)</option>\n<option value="\"pt-BR\"">português (Brasil)</option>\n<option value="\"pt-PT\"">português (Portugal)</option>\n<option value="\"ro-MD\"">română (Republica Moldova)</option>\n<option value="\"ro-RO\"">română (România)</option>\n<option value="\"sq-XK\"">shqip (Kosovë)</option>\n<option value="\"sq-AL\"">shqip (Shqipëri)</option>\n<option value="\"sk-SK\"">slovenčina (Slovensko)</option>\n<option value="\"sl-SI\"">slovenščina (Slovenija)</option>\n<option value="\"fi-FI\"">suomi (Suomi)</option>\n<option value="\"sv-SE\"">svenska (Sverige)</option>\n<option value="\"vi-VN\"">Tiếng Việt (Việt Nam)</option>\n<option value="\"tr-TR\"">Türkçe (Türkiye)</option>\n<option value="\"el-GR\"">Ελληνικά (Ελλάδα)</option>\n<option value="\"el-CY\"">Ελληνικά (Κύπρος)</option>\n<option value="\"bg-BG\"">български (България)</option>\n<option value="\"kk-KZ\"">қазақ тілі (Қазақстан)</option>\n<option value="\"mk-MK\"">македонски (Северна Македонија)</option>\n<option value="\"sr-RS\"">српски (Србија)</option>\n<option value="\"uk-UA\"">українська (Україна)</option>\n<option value="\"ka-GE\"">ქართული (საქართველო)</option>\n<option value="\"he-IL\"">עברית (ישראל)</option>\n<option value="\"ar-AE\"">العربية (الإمارات العربية المتحدة)</option>\n<option value="\"ar-BH\"">العربية (البحرين)</option>\n<option value="\"ar-KW\"">العربية (الكويت)</option>\n<option value="\"ar-MA\"">العربية (المغرب)</option>\n<option value="\"ar-SA\"">العربية (المملكة العربية السعودية)</option>\n<option value="\"ar-TN\"">العربية (تونس)</option>\n<option value="\"ar-OM\"">العربية (عُمان)</option>\n<option value="\"ar-QA\"">العربية (قطر)</option>\n<option value="\"ar-LB\"">العربية (لبنان)</option>\n<option value="\"ar-EG\"">العربية (مصر)</option>\n<option value="\"th-TH\"">ไทย (ไทย)</option>\n<option value="\"ko-KR\"">한국어(대한민국)</option>\n<option value="\"zh-HK\"">中文(中國香港特別行政區)</option>\n<option value="\"zh-TW\"">中文(台灣)</option>\n<option value="\"ja-JP\"">日本語 (日本)</option>\n</select>\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/en-gb/login?ReturnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U\"">\n\n <button class="\"language-switch__submit" button="" button--submit\"="" type="\"submit\"">\n Save\n </button>\n<input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDFDwsyguCI1OC2qSE4eGok8_Ub_Sb1sUkzhNvfOMH1PoGYxvsWgO9NDDyDGR_itfjTwG1yA09fs1iL4xN0snXsQaj2M6Zorz1-0qVbpFTii3_VOSv7wi1OYNtRTsFI1J0\""></form>\n </nav>\n</footer>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/htmx.00GdzawUlLg.mjs\""></script>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/base.veDyGCvmY8w.mjs\""></script>\n <script defer="" nomodule="" src="\"https://cdn.singlekey-id.com/scripts/base.B5E8ztDgVe0.js\""></script>\n\n <script nonce="\"xi6ip3ZL9NWZ-x3udR9k7D8N\"">(function() {\n if (window.hcaptcha === undefined) {\n var hcaptchaScript = document.createElement('script');\n hcaptchaScript.src = 'https://js.hcaptcha.com/1/api.js?recaptchacompat=off&onload=onHCaptchaLoaded&render=explicit';\n hcaptchaScript.defer = true;\n hcaptchaScript.async = true;\n document.head.appendChild(hcaptchaScript);\n }\n})();</script>\n\n \n \n\n \n\n"
                        2025-01-05 11:04:39.644 - error: bosch-ebike.0 (630591) No code received.
                        2025-01-05 11:04:39.864 - error: bosch-ebike.0 (630591) AxiosError: Request failed with status code 400
                        2025-01-05 11:04:39.865 - error: bosch-ebike.0 (630591) {"error":"invalid_request","error_description":"Missing parameter: code"}
                          @reini84 Irgendwas ist mit dem Passwort komisch
                            bommel_030 @tombox last edited by
                            @tombox
                            Danke, Instanz löschen, neu anlegen und läuft wieder.
                              @tombox
                              Vielen Dank, das Passwort war das Problem
                                @reini84 Falsch oder Sonderzeichen
                                  wolfgangf last edited by
                                  Ich komme leider nicht über die hCaptcha Stelle hinweg:
                                  Hat da jemand eine Idee oder einen Tipp?
                                  Ivan Andric 1 Reply Last reply Reply Quote 0
                                  • Ivan Andric
                                    Ivan Andric @wolfgangf last edited by
                                    @wolfgangf Einen Tipp habe ich leider nicht, jedoch das gleiche Problem.
                                      tombox @Ivan Andric last edited by
                                      @ivan-andric Bitte die GitHub version test. Login flow wurde geändert
                                        lindi200000 @tombox last edited by
                                        @tombox Moin, hab das gleiche Problem und die Github Version getestet.
                                        Ich komme nicht in die EInstellungen des Adapters rein, es kommt immer [JsonConfig] Cannot read file "jsonConfig.json: Not exists
                                        Reload, anderer Browser etc .... alles schon gemacht, keine Besserung. Andere Adapter Einstellungen gehen, nur nicht der hier.
                                          tombox @lindi200000 last edited by
                                          @lindi200000 probier die aktuelle GitHub version
                                          • bahnuhr
                                            @tombox
                                            Habe die git installiert.
                                            Komme aber mit der Anleitung nicht klar.
                                            Im Einzelnen:
                                            Dort steht:
                                            zu 1.
                                            Habe unten auf den Link geklickt.
                                            Dann kam ich zur Seite:
                                            Dann mich dort angemeldet und war drin.
                                            zu 2.
                                            F12 gedrückt.
                                            zu 3.
                                            Ich sehe dort keine Fehlermeldung.
                                            Fazit:
                                            Fehlermeldung hab ich nicht.
                                            Was mach ich denn nun falsch ?
                                            Bitte kurze Rückinfo.
                                            Danke.
                                            T L 2 Replies Last reply Reply Quote 0
                                            178
                                            32304
