    4. Homematic - einzelne States stimmen nicht mit CCU überein
      martinschm @Homoran last edited by
      @homoran said in Homematic - einzelne States stimmen nicht mit CCU überein:
      Langfassung
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: smarthome
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Ubuntu 22.04.5 LTS
                Kernel: Linux 5.15.0-127-generic
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      OS is similar to: debian
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       16:47:58 up 3 days, 22:06,  2 users,  load average: 0.46, 0.36, 0.37
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-01-02 16:47:58 CET
                 Universal time: Thu 2025-01-02 15:47:58 UTC
                       RTC time: Thu 2025-01-02 15:47:58
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      martin
      HOME=/home/martin
      GROUPS=martin adm cdrom sudo dip plugdev lxd iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            4.8G        3.1G        619M        1.0M        1.1G        1.4G
      Swap:           3.9G        546M        3.4G
      Total:          8.8G        3.6G        4.0G
      Active iob-Instances:   43
               4817 M total memory
               3103 M used memory
               2007 M active memory
               1811 M inactive memory
                619 M free memory
                176 M buffer memory
                918 M swap cache
               3934 M total swap
                546 M used swap
               3388 M free swap
      top - 16:47:59 up 3 days, 22:06,  2 users,  load average: 0.58, 0.38, 0.38
      Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  6.9 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  1.4 si,  1.4 st
      MiB Mem :   4817.4 total,    619.7 free,   3103.3 used,   1094.4 buff/cache
      MiB Swap:   3935.0 total,   3388.9 free,    546.1 used.   1446.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  482M  1.2M  481M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    20G   18G  1.5G  93% /
      tmpfs                             tmpfs  2.4G     0  2.4G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   974M  242M  665M  27% /boot
      tmpfs                             tmpfs  482M  4.0K  482M   1% /run/user/1000
      [Sun Dec 29 18:41:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun Dec 29 18:41:31 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
      [Sun Dec 29 18:41:35 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      Show mounted filesystems:
      TARGET              SOURCE                            FSTYPE   OPTIONS
      /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
      |-/snap/core18/2846 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core18/2829 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2379 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2434 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/24061   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/29619   /dev/loop6                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/21759 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/23258 /dev/loop7                        squashfs ro,nodev,relatime,errors=continue
      `-/boot             /dev/sda2                         ext4     rw,relatime
      /var:
      3.4G    /var/
      2.1G    /var/log/journal/818509edfb63406a9da2a367f427536a
      2.1G    /var/log
      1.2G    /var/lib
      Archived and active journals take up 2.0G in the file system.
      /opt/iobroker/backups:
      582M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.2G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      868M    /opt/iobroker/iobroker-data/history
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      561M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      62M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100FA9-if03
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100FA9-if00
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.6 500
              500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Hosts:
      smarthome           smarthome (version: 7.0.3, hostname: smarthome     , alive, uptime: 338773)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     3
      +-- iobroker.sma-speedwire@0.9.0 (git+ssh://git@github.com/rg-engineering/ioBroker.sma-speedwire.git#33e9a5196f7c445f4906a61281172ab71dd986bf)
      +-- iobroker.vesync@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.vesync.git#b0109fb28c94f7a3664eb0e599fd8359808a7b3e)
      +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#79889767b80052eb5093509d55a7751d966e80ed)
      Adapter State
      + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : smarthome                                -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : smarthome                                -  enabled
        system.adapter.alarm.1                  : alarm                 : smarthome                                - disabled
      + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
        system.adapter.alias-manager.0          : alias-manager         : smarthome                                -  enabled
      + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
      + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
        system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : smarthome                                -  enabled
        system.adapter.devices.0                : devices               : smarthome                                - disabled
      + system.adapter.discovery.0              : discovery             : smarthome                                -  enabled
      + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
        system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
        system.adapter.flot.0                   : flot                  : smarthome                                - disabled
      + system.adapter.frigate.0                : frigate               : smarthome                                -  enabled
        system.adapter.harmony.0                : harmony               : smarthome                                - disabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : smarthome                                -  enabled
      + system.adapter.history.0                : history               : smarthome                                -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : smarthome                                -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : smarthome                                -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : smarthome                                -  enabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : smarthome                                - disabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : smarthome                                -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
      + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : smarthome                                -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : smarthome                                -  enabled
      + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.nuki-extended.0          : nuki-extended         : smarthome                                -  enabled
      + system.adapter.opendtu.0                : opendtu               : smarthome                                -  enabled
        system.adapter.ph803w.0                 : ph803w                : smarthome                                - disabled
      + system.adapter.ping.0                   : ping                  : smarthome                                -  enabled
      + system.adapter.proxmox.0                : proxmox               : smarthome                                -  enabled, port: 8006
        system.adapter.scenes.0                 : scenes                : smarthome                                - disabled
      + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : smarthome                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sma-speedwire.0          : sma-speedwire         : smarthome                                -  enabled, port: 9522
      + system.adapter.socketio.0               : socketio              : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
      + system.adapter.statistics.0             : statistics            : smarthome                                -  enabled
      + system.adapter.telegram.0               : telegram              : smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : smarthome                                - disabled
      + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
      + system.adapter.tuya.0                   : tuya                  : smarthome                                -  enabled
        system.adapter.unifi.0                  : unifi                 : smarthome                                - disabled
      + system.adapter.vesync.0                 : vesync                : smarthome                                -  enabled
      + system.adapter.viessmann.0              : viessmann             : smarthome                                -  enabled, port: 3002
        system.adapter.vis.0                    : vis                   : smarthome                                - disabled
      + system.adapter.volvo.0                  : volvo                 : smarthome                                -  enabled
        system.adapter.web-speedy.0             : web-speedy            : smarthome                                - disabled
      + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wifilight.0              : wifilight             : smarthome                                -  enabled
      + system.adapter.worx.0                   : worx                  : smarthome                                -  enabled
        system.adapter.yr.0                     : yr                    : smarthome                                - disabled
      + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alarm"        : 3.6.4    , installed 3.6.4
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "frigate"      : 1.3.1    , installed 1.3.1
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
      Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "viessmann"    : 1.5.0    , installed 1.5.0
      Adapter    "volvo"        : 0.1.2    , installed 0.1.2
      Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
      Adapter    "worx"         : 3.1.1    , installed 3.1.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
      Objects and States
      Objects:        19904
      States:         22141
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 2
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21875      633/systemd-resolve
      tcp        0      0 192.168.1.198:9292      0.0.0.0:*               LISTEN      1001       24900      1204/io.hm-rpc.3
      tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      112        22093      655/redis-server 0.
      tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       25700      1048/io.hm-rpc.1
      tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       3007665    189732/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       21452      1063/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25800      1137/io.sonoff.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       23331      769/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17274      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22027      684/sshd: /usr/sbin
      tcp6       0      0 :::8090                 :::*                    LISTEN      1001       22443      888/io.admin.1
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24254      1382/io.simple-api.
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       27015      1410/io.socketio.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27126      1505/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23381      881/io.admin.0
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       70718      12052/io.nuki-exten
      tcp6       0      0 :::1886                 :::*                    LISTEN      1001       32466      1575/io.frigate.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14680      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          22032      684/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25900      1130/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       624385     49120/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       624386     49120/io.tuya.0
      udp        0      0 0.0.0.0:56109           0.0.0.0:*                           1001       631528     49665/io.sma-speedw
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21874      633/systemd-resolve
      udp        0      0 192.168.1.198:68        0.0.0.0:*                           100        2720036    631/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17275      1/init
      udp6       0      0 :::111                  :::*                                0          17276      1/init
      2025-01-02 16:43:00.188  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ad0d04fdff07000000840300006776b40400000000bfbebbb8bfeae9f5eafdfbcc00000000
      2025-01-02 16:43:00.224  - warn: sma-speedwire.0 (49665) could not translate 9067
      2025-01-02 16:43:00.381  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
      2025-01-02 16:44:00.214  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ba0d04fdff07000000840300006776b44000000000bfbebbb8bfeae9f5eafdfbcc00000000
      2025-01-02 16:44:00.362  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
      2025-01-02 16:45:00.196  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8c70d04fdff07000000840300006776b47c00000000bfbebbb8bfeae9f5eafdfbcc00000000
      2025-01-02 16:45:00.231  - warn: sma-speedwire.0 (49665) could not translate 9067
      2025-01-02 16:45:00.389  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
      2025-01-02 16:45:52.041  - info: host.smarthome instance system.adapter.daswetter.0 in version "3.2.2" started with pid 193902
      2025-01-02 16:45:55.404  - info: daswetter.0 (193902) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.3
      2025-01-02 16:46:00.210  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8d40d04fdff07000000840300006776b4b800000000bfbebbb8bfeae9f5eafdfbcc00000000
      2025-01-02 16:46:00.381  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
      2025-01-02 16:46:05.302  - info: daswetter.0 (193902) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-01-02 16:46:05.826  - info: daswetter.0 (193902) cleaned everything up...
      2025-01-02 16:46:05.849  - info: host.smarthome instance system.adapter.daswetter.0 having pid 193902 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-02 16:47:00.195  - warn: sma-speedwire.0 (49665) unknown cmd : B47600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8e10d04fdff07000000840300006776b4f400000000bfbebbb8bfeae9f5eafdfbcc00000000
      2025-01-02 16:47:00.224  - warn: sma-speedwire.0 (49665) could not translate 9067
      2025-01-02 16:47:00.385  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
      2025-01-02 16:48:00.193  - warn: sma-speedwire.0 (49665) unknown cmd : B57600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8ee0d04fdff07000000840300006776b53000000000bfbebbb8bfeae9f5eafdfbcc00000000
      2025-01-02 16:48:00.251  - warn: sma-speedwire.0 (49665) could not translate 9067
      2025-01-02 16:48:00.376  - warn: sma-speedwire.0 (49665) could not translate INV_TEMP
      2025-01-02 16:48:05.509  - info: web.0 (1505) ==> Connected system.user.admin from ::ffff:192.168.1.32
      2025-01-02 16:48:54.945  - info: web.0 (1505) <== Disconnect system.user.admin from ::ffff:192.168.1.32 iqontrol.0
      2025-01-02 16:49:00.200  - warn: sma-speedwire.0 (49665) unknown cmd : B57600 cmdLength : 156 pointer : 124 hex : 534d4100000402a000000001003a001060650ed07800c8e80338000180007045cb7d000100000000e8fb0d04fdff07000000840300006776b56c00000000bfbebbb8bfeae9f5eafdfbcc00000000
      2025-01-02 16:49:00.232  - warn: sma-speedwire.0 (49665) could not translate 9067
      • Samson71
        Samson71 Global Moderator @martinschm last edited by
        @martinschm sagte in Homematic - einzelne States stimmen nicht mit CCU überein:
        ?? microfiches ?
        Deine Multi-Megamini hoch aufgelösten Bildchen im ersten Post. Diese Screenshots wirken wie auf einem Microfilm. Am Mobilgerät quasi nicht lesbar.
          Homoran Global Moderator Administrators @martinschm last edited by Homoran
          HM RPC in V 2.0.2
          und davon bitte die Konfigurationen aller 4 Instanzen
          Vielleicht auch mal ein Screenshot der Servicemeldungen in der RaspberryMatic
          wie sind da die Timestamps?
            martinschm @Homoran last edited by martinschm
            HM Rega
            RPC0
            RPC1
            RPC2 - inaktiv
            RPC3
            Raspberrymatic Fehlermeldungen
            Da gibt es aktuell keine Servicemeldungen
            Timestamps der States
            Unreach bei dem Tür Rollo: 2024-07-07 18:31
            LowBat bei der WZ Rechts Heizung: 2024-12-21 18:16
            Ich hoffe die Screenshots sind jetzt besser anzuschauen
              das ist ja wirklich schon was her.
              War möglicherweise ein kurzer Lowbat während des Antriebs.
              Warum beide nicht gelöscht werden kann zwei Gründe haben.
              • Die Änderung wird von der RM nicht zuverlässig mitgeteilt.
                • Wenn diese Info einmal verloren gegangen ist, wird erst beim nächsten Wechsel des Zustands wieder geändert.
              • Du hast die Checkbox "Geräte nicht löschen..." nicht aktiv
                • kann sein, dass die Meldung dadurch bei einem Neustart verloren gegangen ist oder falsch aktualisiert wurde
              Hak die Checkboxen an, ebenfalls die "neu einlesen" und starte die Instanzen neu.
              Warum ist in der .3 bei Adapteradresse eine IP eingetragen und keine Callback Adresse?
              Bei allen anderen 0.0.0.0 und dafür die Iob Adresse als Callback?
              .102 ist doch die RM und .198 iob?
                Erledigt, die Werte bleiben aber gleich !!!
                Ja korrekt.
                Kann ich dir nicht mehr sagen, warum ich das mal unterschiedlich eingestellt habe.
                Wie sollte es denn idealerweise konfiguriert sein ?
                  wenn es kein Docker oder ähnliches ist, braucht es (eigentlich) keine CallbackAdresse
                  hm-rpc übermittelt die AdapterAdresse an die CCU, damit diese dorthin die abonnierten Änderungen schickt.
                  mit 0.0.0.0 oder der internen Container Adresse kann die CCU nichts anfangen, daher braucht es dann die Callback Adresse.
                  Da es bei dir aber nur einzelne Geräte betrifft, ist das Verhalten seltsam.
                  Vielleicht hilft stromlos machen, etwas warten, und Batterien wieder einlegen ja, um eine Änderung und damit erneute Sendung des Wertes anzustoßen
                  M Homoran 2 Replies Last reply Reply Quote 0
                    Läuft ein einer Proxmox Instanz.
                    Hilft es vielleicht die Geräte doch mal zu löschen und die Liste neu einzulesen ?
                      heisst was?
                      VM oder Container?
                        heisst was?
                        VM oder Container?
                        Als VM.
                          Homoran Global Moderator Administrators @Homoran last edited by
                          @homoran sagte in Homematic - einzelne States stimmen nicht mit CCU überein:
                          hast du das versucht?
                            Ja, hat aber nichts gebracht.
                            Ich habe gerade das Gerät einmal manuell aus dem Objektbaum gelöscht und im Adapter "Geräte einmalig neueinlesen" angeklickt.
                            Jetzt wurde es korrekt wieder angelegt und die Info stimmt.
                            Hab das dann bei dem Türrollo der angeblich auf Unreach stand wiederholt und beim neu einlesen waren die Werte dann richtig.
                            Mal schauen wie lange.
                            3269
