    3. Off Topic
    4. Pflege des Betriebssystems
    5. RPI5 apt-get upgrade schlägt Fehlermeldung
      Homoran Global Moderator Administrators @knopers1 last edited by
      @knopers1 sagte in RPI5 apt-get upgrade schlägt Fehlermeldung:
      Use 'sudo apt autoremove' to remove them.
        Thomas Braun Most Active @knopers1 last edited by
        @knopers1
        Kommt davon, wenn man den ganzen Desktop-Mumpitz mitschleppt und dann nicht regelmäßig updated.
        sudo apt remove libjavascriptcoregtk
        sudo apt update
        sudo apt full-upgrade
          knopers1 @Thomas Braun last edited by knopers1
          @thomas-braun said in RPI5 apt-get upgrade schlägt Fehlermeldung:
          Hallo Thomas, danke für deine Zeit!
          pi@VISundGrafana:~ $ sudo apt remove libjavascriptcoregtk
          Reading package lists... Done
          Building dependency tree... Done
          E: Unable to locate package libjavascriptcoregtk
          soll ich trotzdem weiter damit machen?
          sudo apt update
            @knopers1
            Ja, zeig mal was bei
            sudo apt update
            nun gemeldet wird.
              @thomas-braun Danke für deine Zeit, siehe unten.....
              login as: pi
              pi@192.168.1.100's password:
              Linux VISundGrafana 6.6.62+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64
              The programs included with the Debian GNU/Linux system are free software;
              the exact distribution terms for each program are described in the
              individual files in /usr/share/doc/*/copyright.
              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
              permitted by applicable law.
              Last login: Sun Jan  5 19:27:09 2025 from 192.168.1.174
              pi@VISundGrafana:~ $ sudo apt update
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Get:5 http://archive.raspberrypi.com/debian bookworm InRelease [39.3 kB]
              Get:6 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [549 kB]
              Get:7 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [520 kB]
              Fetched 1,164 kB in 1s (1,495 kB/s)
              3 packages can be upgraded. Run 'apt list --upgradable' to see them.
              pi@VISundGrafana:~ $ sudo apt full-upgrade
              Calculating upgrade... Done
              The following packages were automatically installed and are no longer required:
                chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra
                edid-decode libqt5qmlworkerscript5 libqt5quickcontrols2-5
                libqt5quicktemplates2-5 libwlroots12 linux-headers-6.6.31+rpt-common-rpi
                linux-kbuild-6.6.31+rpt python3-gi-cairo qml-module-qtgraphicaleffects
                qml-module-qtquick-controls2 qml-module-qtquick-layouts
                qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2
              The following packages will be REMOVED:
                linux-headers-6.6.31+rpt-rpi-2712 linux-headers-6.6.31+rpt-rpi-v8
                linux-image-6.6.31+rpt-rpi-2712 linux-image-6.6.31+rpt-rpi-v8
              The following packages will be upgraded:
                initramfs-tools initramfs-tools-core realvnc-vnc-server
              3 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
              Need to get 9,493 kB of archives.
              After this operation, 71.6 MB disk space will be freed.
              Do you want to continue? [Y/n] y
              Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools all 0.142+rpt3+deb12u1 [17.2 kB]
              Get:2 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools-core all 0.142+rpt3+deb12u1 [53.1 kB]
              Get:3 http://archive.raspberrypi.com/debian bookworm/main arm64 realvnc-vnc-server arm64 7.13.1.57 [9,422 kB]
              Fetched 9,493 kB in 1s (6,650 kB/s)
              Reading changelogs... Done
              (Reading database ... 179703 files and directories currently installed.)
              Removing linux-headers-6.6.31+rpt-rpi-2712 (1:6.6.31-1+rpt1) ...
              Removing linux-headers-6.6.31+rpt-rpi-v8 (1:6.6.31-1+rpt1) ...
              Removing linux-image-6.6.31+rpt-rpi-2712 (1:6.6.31-1+rpt1) ...
              /etc/kernel/postrm.d/initramfs-tools:
              update-initramfs: Deleting /boot/initrd.img-6.6.31+rpt-rpi-2712
              Removing linux-image-6.6.31+rpt-rpi-v8 (1:6.6.31-1+rpt1) ...
              update-initramfs: Deleting /boot/initrd.img-6.6.31+rpt-rpi-v8
              (Reading database ... 166892 files and directories currently installed.)
              Preparing to unpack .../initramfs-tools_0.142+rpt3+deb12u1_all.deb ...
              Unpacking initramfs-tools (0.142+rpt3+deb12u1) over (0.142+rpt2+deb12u1) ...
              Preparing to unpack .../initramfs-tools-core_0.142+rpt3+deb12u1_all.deb ...
              Unpacking initramfs-tools-core (0.142+rpt3+deb12u1) over (0.142+rpt2+deb12u1) ...
              Preparing to unpack .../realvnc-vnc-server_7.13.1.57_arm64.deb ...
              Unpacking realvnc-vnc-server (7.13.1.57) over (7.11.0.18) ...
              Setting up realvnc-vnc-server (7.13.1.57) ...
              Updating /etc/pam.d/vncserver
              Updating /etc/pam.conf... done
              Looking for font path... not found.
              Original config file "/etc/vnc/pulse/daemon.conf.old" preserved
              Generating private key... done
              Installed systemd unit for VNC Server in Service Mode daemon
              Start or stop the service with:
                systemctl (start|stop) vncserver-x11-serviced.service
              Mark or unmark the service to be started at boot time with:
                systemctl (enable|disable) vncserver-x11-serviced.service
              Installed systemd unit for VNC Server in Virtual Mode daemon
                systemctl (start|stop) vncserver-virtuald.service
                systemctl (enable|disable) vncserver-virtuald.service
              Setting up initramfs-tools-core (0.142+rpt3+deb12u1) ...
              Setting up initramfs-tools (0.142+rpt3+deb12u1) ...
              update-initramfs: deferring update (trigger activated)
              Processing triggers for gnome-menus (3.36.0-1.1) ...
              Processing triggers for man-db (2.11.2-2) ...
              Processing triggers for mailcap (3.70+nmu1) ...
              Processing triggers for desktop-file-utils (0.26-1) ...
              Processing triggers for hicolor-icon-theme (0.17-2) ...
              Processing triggers for initramfs-tools (0.142+rpt3+deb12u1) ...
              update-initramfs: Generating /boot/initrd.img-6.6.62+rpt-rpi-v8
              '/boot/initrd.img-6.6.62+rpt-rpi-v8' -> '/boot/firmware/initramfs8'
              update-initramfs: Generating /boot/initrd.img-6.6.62+rpt-rpi-2712
              '/boot/initrd.img-6.6.62+rpt-rpi-2712' -> '/boot/firmware/initramfs_2712'
              update-initramfs: Generating /boot/initrd.img-6.6.51+rpt-rpi-v8
              update-initramfs: Generating /boot/initrd.img-6.6.51+rpt-rpi-2712
                @knopers1
                Sauberen Neustart und dann nochmal.
                  pi@VISundGrafana:~ $ sudo apt-get update
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                  pi@VISundGrafana:~ $ sudo apt-get upgrade
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    immer noch!
                      @knopers1
                      Ja, autoremove.
                      Aber der ganze Desktop -Kladderadatsch rumpelt immer noch mit.
                      Und macht Updates dadurch komplexer als notwendig. Neben anderen Nachteilen.
                      K 2 Replies Last reply Reply Quote 0
                        pi@VISundGrafana:~ $ sudo apt autoremove chromium-browser
                        0 upgraded, 0 newly installed, 17 to remove and 0 not upgraded.
                        After this operation, 65.6 MB disk space will be freed.
                        Removing chromium-browser (1:130.0.6723.116-1~deb12u1+rpt1) ...
                        Removing chromium-browser-l10n (1:130.0.6723.116-1~deb12u1+rpt1) ...
                        Removing chromium-codecs-ffmpeg-extra (126.0.6478.164-rpt1) ...
                        Removing edid-decode (0.1~git20241119.5332a3b-1) ...
                        Removing qml-module-qtgraphicaleffects:arm64 (5.15.8-2) ...
                        Removing qml-module-qtquick2:arm64 (5.15.8+dfsg-3) ...
                        Removing libqt5qmlworkerscript5:arm64 (5.15.8+dfsg-3) ...
                        Removing qml-module-qtquick-controls2:arm64 (5.15.8+dfsg-2) ...
                        Removing libqt5quickcontrols2-5:arm64 (5.15.8+dfsg-2) ...
                        Removing qml-module-qtquick-templates2:arm64 (5.15.8+dfsg-2) ...
                        Removing libqt5quicktemplates2-5:arm64 (5.15.8+dfsg-2) ...
                        Removing libwlroots12:arm64 (0.17.4-1+rpt1) ...
                        Removing linux-headers-6.6.31+rpt-common-rpi (1:6.6.31-1+rpt1) ...
                        Removing linux-kbuild-6.6.31+rpt (1:6.6.31-1+rpt1) ...
                        Removing python3-gi-cairo (3.42.2-3+b1) ...
                        Removing qml-module-qtquick-layouts:arm64 (5.15.8+dfsg-3) ...
                        Removing qml-module-qtquick-window2:arm64 (5.15.8+dfsg-3) ...
                        Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) ...
                          @knopers1
                          Ja, autoremove.
                          ja, habe leider die letzte Zeit keine Updates gemacht.... Kann ich irgendwie noch was verbessern?
                          Ich hatte vor einigen Monaten das System auf RPI5 vom RPI4 umgezogen und danach praktisch kaum etwas gemacht... Sonst sieht es jetzt wieder gut aus! Besten Dank! @Homoran - Dir ebenso riesen Dank für die Interesse!
                            Kann ich dir sagen, wenn ich die Langfassung von
                            iob diag
                            sehe.
                              @thomas-braun gerne doch....
                              ========== Start marking the full check here ===========
                              ```bash
                              Script v.2024-10-19
                              *** BASE SYSTEM ***
                               Static hostname: VISundGrafana
                                     Icon name: computer
                                        Kernel: Linux 6.6.62+rpt-rpi-2712
                                  Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 5 Model B Rev 1.0
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               18:21:20 up 36 min,  4 users,  load average: 2.15, 0.99, 0.50
                              CPU threads: 4
                              *** LIFE CYCLE STATUS ***
                              Operating System is the current Debian stable version codenamed 'bookworm'!
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              *** TIME AND TIMEZONES ***
                                             Local time: Mon 2025-01-06 18:21:20 CET
                                         Universal time: Mon 2025-01-06 17:21:20 UTC
                                               RTC time: Mon 2025-01-06 17:21:20
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              pi
                              HOME=/home/pi
                              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server: true
                              Desktop:
                              Terminal:       tty
                              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                              *** MEMORY ***
                              Mem:            8.4G        2.5G        4.6G         24M        1.4G        5.9G
                              Swap:           209M          0B        209M
                              Total:          8.7G        2.5G        4.8G
                              Active iob-Instances:   29
                                       8052 M total memory
                                       2429 M used memory
                                       2413 M active memory
                                        768 M inactive memory
                                       4389 M free memory
                                        149 M buffer memory
                                       1204 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              top - 18:21:20 up 36 min,  4 users,  load average: 2.15, 0.99, 0.50
                              Tasks: 237 total,   2 running, 235 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8052.2 total,   4388.5 free,   2429.9 used,   1354.3 buff/cache
                              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5622.4 avail Mem
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              No critical errors detected
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.9G     0  3.9G   0% /dev
                              tmpfs          tmpfs     806M  6.0M  800M   1% /run
                              /dev/sda2      ext4      235G  9.3G  214G   5% /
                              tmpfs          tmpfs     4.0G  288K  4.0G   1% /dev/shm
                              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                              /dev/sda1      vfat      510M   76M  435M  15% /boot/firmware
                              tmpfs          tmpfs     806M  192K  806M   1% /run/user/1000
                              [Mon Jan  6 17:44:37 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:3C:5E:BB vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=11c29a44-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              [Mon Jan  6 17:44:38 2025] EXT4-fs (sda2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
                              [Mon Jan  6 17:44:39 2025] EXT4-fs (sda2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
                              Show mounted filesystems:
                              TARGET               SOURCE    FSTYPE      OPTIONS
                              /                    /dev/sda2 ext4        rw,noatime
                              |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                              `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              1.1G    /var/
                              403M    /var/cache
                              391M    /var/cache/apt
                              302M    /var/log/journal/1671f0a4980a454dbb2a7d3bf10bcd54
                              Archived and active journals take up 301.0M in the file system.
                              /opt/iobroker/backups:
                              122M    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              1.2G    /opt/iobroker/iobroker-data/
                              972M    /opt/iobroker/iobroker-data/files
                              617M    /opt/iobroker/iobroker-data/files/javascript.admin
                              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                              28M     /opt/iobroker/iobroker-data/objects.jsonl
                              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v20.18.1
                              /usr/bin/node           v20.18.1
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.29.4
                              nodejs:
                                Installed: 20.18.1-1nodesource1
                                Candidate: 20.18.1-1nodesource1
                                Version table:
                               *** 20.18.1-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                      100 /var/lib/dpkg/status
                                   20.18.0-1nodesource1 1001
                                   20.17.0-1nodesource1 1001
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u2 500
                                   18.19.0+dfsg-6~deb12u1 500
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              VISundGrafana       VISundGrafana (version: 7.0.6, hostname: VISundGrafana , alive, uptime: 121)
                              Core adapters versions
                              js-controller:  7.0.6
                              admin:          7.1.5
                              javascript:     8.8.3
                              nodejs modules from github:     2
                              | | +-- browser-serialport@2.0.3 (git+ssh://git@github.com/noopkat/browser-serialport.git#c8628c41c11890d3058875994c15f83f2df8185b)
                              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : VISundGrafana                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : VISundGrafana                            -  enabled
                              + system.adapter.backitup.0               : backitup              : VISundGrafana                            -  enabled
                              + system.adapter.cloud.0                  : cloud                 : VISundGrafana                            -  enabled
                              + system.adapter.discovery.0              : discovery             : VISundGrafana                            -  enabled
                              + system.adapter.email.1                  : email                 : VISundGrafana                            -  enabled
                              + system.adapter.ems-esp.0                : ems-esp               : VISundGrafana                            -  enabled
                                system.adapter.energiefluss.0           : energiefluss          : VISundGrafana                            - disabled
                              + system.adapter.enigma2.0                : enigma2               : VISundGrafana                            -  enabled
                                system.adapter.flot.0                   : flot                  : VISundGrafana                            - disabled
                              + system.adapter.fritzbox.0               : fritzbox              : VISundGrafana                            -  enabled
                              + system.adapter.fritzdect.0              : fritzdect             : VISundGrafana                            -  enabled
                              + system.adapter.history.0                : history               : VISundGrafana                            -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : VISundGrafana                            -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : VISundGrafana                            -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : VISundGrafana                            -  enabled, port: 0
                                system.adapter.ical.0                   : ical                  : VISundGrafana                            -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: VISundGrafana                            - disabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : VISundGrafana                            - disabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : VISundGrafana                            - disabled
                                system.adapter.influxdb.0               : influxdb              : VISundGrafana                            - disabled, port: 8086
                              + system.adapter.influxdb.1               : influxdb              : VISundGrafana                            -  enabled, port: 8086
                              + system.adapter.javascript.0             : javascript            : VISundGrafana                            -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : VISundGrafana                            -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.node-red.0               : node-red              : VISundGrafana                            -  enabled, port: 1880, bind: 0.0.0.0
                              + system.adapter.opendtu.0                : opendtu               : VISundGrafana                            -  enabled
                              + system.adapter.opendtu.1                : opendtu               : VISundGrafana                            -  enabled
                              + system.adapter.ping.0                   : ping                  : VISundGrafana                            -  enabled
                              + system.adapter.rflink.0                 : rflink                : VISundGrafana                            -  enabled
                              + system.adapter.rpi2.0                   : rpi2                  : VISundGrafana                            -  enabled
                                system.adapter.samsung.0                : samsung               : VISundGrafana                            - disabled
                              + system.adapter.shelly.0                 : shelly                : VISundGrafana                            -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.sonoff.0                 : sonoff                : VISundGrafana                            -  enabled, port: 1500, bind: 0.0.0.0
                              + system.adapter.sourceanalytix.0         : sourceanalytix        : VISundGrafana                            -  enabled
                                system.adapter.tankerkoenig.0           : tankerkoenig          : VISundGrafana                            -  enabled
                                system.adapter.terminal.0               : terminal              : VISundGrafana                            -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                              + system.adapter.tr-064.0                 : tr-064                : VISundGrafana                            -  enabled
                                system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : VISundGrafana                            - disabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : VISundGrafana                            - disabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : VISundGrafana                            - disabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : VISundGrafana                            - disabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : VISundGrafana                            - disabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : VISundGrafana                            - disabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : VISundGrafana                            - disabled
                                system.adapter.vis-keyboard.0           : vis-keyboard          : VISundGrafana                            - disabled
                                system.adapter.vis-metro.0              : vis-metro             : VISundGrafana                            - disabled
                                system.adapter.vis-rgraph.0             : vis-rgraph            : VISundGrafana                            - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : VISundGrafana                            - disabled
                                system.adapter.vis-weather.0            : vis-weather           : VISundGrafana                            - disabled
                                system.adapter.vis.0                    : vis                   : VISundGrafana                            -  enabled
                              + system.adapter.web.0                    : web                   : VISundGrafana                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              ioBroker-Repositories
                              │ (index) │ name      │ url        │ auto upgrade │
                              │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
                              │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
                              │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
                              │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
                              Active repo(s): stable
                              Upgrade policy: none
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "admin"        : 7.1.5    , installed 7.1.5
                              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                              Adapter    "email"        : 1.3.1    , installed 1.3.1
                              Adapter    "ems-esp"      : 5.0.6    , installed 5.0.6
                              Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                              Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
                              Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                              Adapter    "ical"         : 1.16.1   , installed 1.16.1
                              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                              Controller "js-controller": 7.0.6    , installed 7.0.6
                              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                              Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                              Adapter    "rflink"       : 2.1.12   , installed 2.1.12
                              Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                              Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                              Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
                              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                              Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
                              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                              Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                              Adapter    "web"          : 6.2.5    , installed 6.2.6
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              Objects and States
                              Objects:        8688
                              States:         7367
                              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 192.168.1.100:2001      0.0.0.0:*               LISTEN      1001       60989      8442/io.hm-rpc.0
                              tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1001       62975      9385/io.sonoff.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       63828      9366/io.shelly.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       61228      8521/io.mqtt.0
                              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       58758      7874/node-red
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4949       854/sshd: /usr/sbin
                              tcp        0      0 192.168.1.100:8701      0.0.0.0:*               LISTEN      1001       61745      8457/io.hm-rpc.1
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       59480      7774/iobroker.js-co
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59475      7774/iobroker.js-co
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7007       841/cupsd
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7006       841/cupsd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          4951       854/sshd: /usr/sbin
                              tcp6       0      0 :::80                   :::*                    LISTEN      1001       58759      7874/node-red
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       63321      9675/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       57834      7792/io.admin.0
                              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       66381      9845/io.terminal.0
                              udp        0      0 192.168.1.100:5353      0.0.0.0:*                           1001       63954      9436/io.tr-064.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7721       656/avahi-daemon: r
                              udp        0      0 0.0.0.0:59726           0.0.0.0:*                           104        7723       656/avahi-daemon: r
                              udp6       0      0 fe80::c3f8:2347:667:546 :::*                                0          8371       806/NetworkManager
                              udp6       0      0 :::5353                 :::*                                104        7722       656/avahi-daemon: r
                              udp6       0      0 :::43675                :::*                                104        7724       656/avahi-daemon: r
                              2025-01-06 18:21:14.182  - info: tankerkoenig.0 (9816) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.18.1, js-controller: 7.0.6
                              2025-01-06 18:21:14.201  - info: tankerkoenig.0 (9816) Adapter is already in daemon mode
                              2025-01-06 18:21:14.202  - warn: tankerkoenig.0 (9816) Sync time was too short (5). New sync time is 10 min
                              2025-01-06 18:21:14.202  - info: tankerkoenig.0 (9816) Sync time set to 10 minutes or 600000 ms
                              2025-01-06 18:21:14.629  - info: shelly.0 (9366) [MQTT] Device with client id "shellyplus1pm-48551999ccc0" connected!
                              2025-01-06 18:21:15.797  - info: ems-esp.0 (8088) KM200 recordings: polling every hour
                              2025-01-06 18:21:15.933  - info: sourceanalytix.0 (9778) Updating SourceAnalytix configuration for : shelly.0.shellyplus1pm#48551999ccc0#1.Relay0.Energy
                              2025-01-06 18:21:17.220  - info: host.VISundGrafana instance system.adapter.terminal.0 in version "1.0.0" started with pid 9845
                              2025-01-06 18:21:17.366  - debug: rflink.0 (9713) Serial data received: 20;02;Aster;ID=0dcc;SWITCH=01;CMD=ON;
                              2025-01-06 18:21:17.367  - debug: rflink.0 (9713) Device "Aster not included, because inclusion mode disabled
                              2025-01-06 18:21:18.815  - info: terminal.0 (9845) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.terminal, node: v20.18.1, js-controller: 7.0.6
                              2025-01-06 18:21:18.838  - info: terminal.0 (9845) http server listening on port 8088
                              2025-01-06 18:21:19.255  - info: tankerkoenig.0 (9816) Start first request
                              2025-01-06 18:21:22.031  - info: vis.0 (10027) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.6
                              2025-01-06 18:21:22.422  - info: web.0 (9675) ==> Connected system.user.admin from ::ffff:192.168.1.174
                              2025-01-06 18:21:22.436  - info: web.0 (9675) <== Disconnect system.user.admin from ::ffff:192.168.1.174
                              2025-01-06 18:21:22.444  - info: web.0 (9675) ==> Connected system.user.admin from ::ffff:192.168.1.174
                              2025-01-06 18:21:22.459  - info: web.0 (9675) <== Disconnect system.user.admin from ::ffff:192.168.1.174
                              2025-01-06 18:21:22.750  - info: vis.0 (10027) Terminated (NO_ERROR): Without reason
                              2025-01-06 18:21:23.299  - info: host.VISundGrafana instance system.adapter.vis.0 terminated while should be started once
                              2025-01-06 18:21:23.643  - info: web.0 (9675) ==> Connected system.user.admin from ::ffff:192.168.1.174
                              2025-01-06 18:21:40.436  - debug: rflink.0 (9713) Serial data received: 20;03;Aster;ID=0ff8;SWITCH=01;CMD=ON;
                              2025-01-06 18:21:40.437  - debug: rflink.0 (9713) Device "Aster not included, because inclusion mode disabled
                              2025-01-06 18:21:43.944  - debug: rflink.0 (9713) Serial data received: 20;04;Aster;ID=0e7c;SWITCH=01;CMD=OFF;
                              2025-01-06 18:21:43.944  - debug: rflink.0 (9713) Device "Aster not included, because inclusion mode disabled
                              iob diag has finished.
                              Copy text starting here:
                                                      v.2024-10-19
                                     Icon name: computer
                                  Architecture: arm64
                              Installation:           native
                              Kernel:                 aarch64
                              Userland:               64 bit
                              Timezone:               Europe/Berlin (CET, +0100)
                              User-ID:                1000
                              Boot Target:            graphical.target
                              Pending OS-Updates:     0
                              Pending iob updates:    1
                              Nodejs-Installation:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              Recommended versions are nodejs 20.18.1 and npm 10.8.2
                              nodeJS installation is correct
                              MEMORY:
                              Mem:            8.4G        2.4G        4.8G         24M        1.4G        6.0G
                              Swap:           209M          0B        209M
                              Total:          8.7G        2.4G        5.0G
                              Active iob-Instances:   31
                              ioBroker Core:          js-controller           7.0.6
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                8688
                              States:                 7359
                              Size of iob-Database:
                              29M     /opt/iobroker/iobroker-data/objects.jsonl
                              2.6M    /opt/iobroker/iobroker-data/states.jsonl
                              === Mark text until here for copying ===
                                Ausschalten...
                                Updaten.
                                  besten Dank Thomas 👍
                                  1.0k
                                  81.1k
                                  2964
