    4. Test Adapter VeSync
    Test Adapter VeSync
      sherlock @Sven Berg last edited by
      @sven-berg
      vesync.0
      2024-10-19 19:17:02.317 info Login to VeSync
      vesync.0
      2024-10-19 19:17:02.150 info starting. Version 0.0.7 (non-npm: Apollon77/ioBroker.vesync#b0109fb28c94f7a3664eb0e599fd8359808a7b3e) in /opt/iobroker/node_modules/iobroker.vesync, node: v18.20.2, js-controller: 5.0.19
      kein Objekt gefunden... Bin bei Admin@iobroker auch auf der neusten version
      @tombox hast du Zeit dir das anzugucken, warum meine Cosory CAF-P583S-KEU nicht mehr geholt wird?
        sherlock last edited by
        wem kann ich meine Login Daten geben, zum testen?
          sherlock last edited by Negalein
          vesync.0 2024-10-20 11:33:29.377	debug	{"traceId":"","code":-11000029,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
          vesync.0 2024-10-20 11:33:28.995	debug	{"traceId":"","code":0,"msg":"request success","module":null,"stacktrace":null,"result":{"isRequiredVerify":true,"accountID":"11758821","avatarIcon":"https://image.vesync.com/defaultImages/user/avatar_nor.png","birthday":"","gender":"","acceptLanguage":"de","userType":"1","nickName":"vesync.de1304","mailConfirmation":true,"termsStatus":true,"gdprStatus":true,"countryCode":"DE","registerAppVersion":"VeSync 4.3.70 build17","registerTime":"2023-07-30 14:55:12","verifyEmail":"xxx@xxx.de","measureUnit":"Imperial","weightG":0,"heightCm":0,"weightTargetSt":0,"heightUnit":"FT","heightFt":0,"weightTargetKg":0,"weightTargetLb":0,"weightUnit":"KG","maximalHeartRate":0,"targetBfr":0,"displayFlag":[],"targetStatus":0,"realWeightKg":0,"realWeightLb":0,"realWeightUnit":"lb","heartRateZones":0,"runStepLongCm":0,"walkStepLongCm":0,"stepTarget":0,"sleepTargetMins":0,"token":"100100qSdz78CimQp4KlaFap-WgZE1ubX1_HzV3ckzgUtA_d-uRrfAbS5cph4WZ-8rn6aZpysslfh9pqm2SHTFXTuUnysfnGAjtAk=","accountLockTimeInSec":null}}
          vesync.0 2024-10-20 11:33:28.493	info	Login to VeSync
            Login is working, aber
            vesync.0 | 2024-10-20 15:12:38.271 | debug | {"traceId":"","code":-11000029,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
            vesync.0 | 2024-10-20 15:12:38.174 | silly | States user redis pmessage vesync.0.*/vesync.0.info.connection:{"val":true,"ack":true,"ts":1729429958171,"q":0,"from":"system.adapter.vesync.0","user":"system.user.admin","lc":1729429958171}
            vesync.0 | 2024-10-20 15:12:38.155 | info | Login successful
            vesync.0 | 2024-10-20 15:12:38.154 | debug | {"traceId":"","code":0,"msg":"request success","module":null,"stacktrace":null,"result":{"isRequiredVerify":true,"accountID":"11758821","avatarIcon":"https://image.vesync.com/defaultImages/user/avatar_nor.png","birthday":"","gender":"","acceptLanguage":"de","userType":"1","nickName":"vesync.de1304","mailConfirmation":true,"termsStatus":true,"gdprStatus":true,"countryCode":"DE","registerAppVersion":"VeSync 4.3.70 build17","registerTime":"2023-07-30 14:55:12","verifyEmail":"x@xlk.de","measureUnit":"Imperial","weightG":0,"heightCm":0,"weightTargetSt":0,"heightUnit":"FT","heightFt":0,"weightTargetKg":0,"weightTargetLb":0,"weightUnit":"KG","maximalHeartRate":0,"targetBfr":0,"displayFlag":[],"targetStatus":0,"realWeightKg":0,"realWeightLb":0,"realWeightUnit":"lb","heartRateZones":0,"runStepLongCm":0,"walkStepLongCm":0,"stepTarget":0,"sleepTargetMins":0,"token":"100100qCd34cSrkgp5I1mHZ5SQgdr4q_fMpzOZbRWF57ZLqycgPJ4m-kpKzS2NTr52QgeS5IgJKcH3nP43qBcDru827dc4sXcLF4o=","accountLockTimeInSec":null}}
            vesync.0 | 2024-10-20 15:12:37.803 | silly | States user redis pmessage vesync.0.*/vesync.0.info.connection:{"val":false,"ack":true,"ts":1729429957799,"q":0,"from":"system.adapter.vesync.0","user":"system.user.admin","lc":1729429952451}
            vesync.0 | 2024-10-20 15:12:37.668 | info | Login to VeSync
            vesync.0 | 2024-10-20 15:12:37.665 | debug | terminalId: 943C353585EE4F82AE1E9C66B4B68087
            vesync.0 | 2024-10-20 15:12:37.653 | silly | States system redis pmessage system.adapter.vesync.0.logLevel/system.adapter.vesync.0.logLevel:{"val":"silly","ack":true,"ts":1729429957635,"q":0,"from":"system.adapter.vesync.0","lc":1729429841840}
            vesync.0 | 2024-10-20 15:12:37.589 | info | starting. Version 0.0.7 (non-npm: TA2k/ioBroker.vesync#06244eda18f3fb8303e929e1955d96c1712f2305) in /opt/iobroker/node_modules/iobroker.vesync, node: v22.10.0, js-controller: 5.0.19
            sniping
            was fehlt ist das Device
            sniping2
            Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
            Hier gehts zur Hilfe.
              maxlox @sherlock last edited by
              @sherlock
              Hallo
              Habe leider das Problem das der Adapter Vers. 0.0.8
              Den Fehler: 2024-12-21 15:50:57.883 error {"traceId":"","code":-11000022,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
              bringt.
              In den Instanzen hat der Adapter ein Rufzeichen mit der Meldung:
              (X in rot)Verbunden mit Gerät oder Dienst.
              Bis vor ein paar Tagen hat der Adapter noch funktioniert.
              Wäre für eine Hilfe sehr dankbar.
              P T 2 Replies Last reply Reply Quote 0
                Papi 0 @maxlox last edited by Papi 0
                @maxlox
                Ich würde sagen, Ruhe bewahren, denn exakt denselben Fehler hatte ich heute Morgen auch.
                Momentan scheint er aber wieder zu laufen.
                Edit:
                Heute (22.12.24) ist 0.0.7 wieder mit demselben Fehler erschienen.
                Ich möchte 0.0.9 aber nicht ausprobieren, da man dafür das Latest-Repo auswählen muss.
                Bananenprodukte sind mir zu gefährlich.
                  tombox @maxlox last edited by
                  @maxlox 0.0.9 testen
                  Sven Berg 1 Reply Last reply Reply Quote 0
                  • Sven Berg
                    Sven Berg @tombox last edited by
                    @tombox Wann wird die Heißluftfriteuse Cosori Modell CAF-TF101S unterstützt? Wie kann ich dabei helfen?
                      tombox @Sven Berg last edited by
                      @sven-berg hast du das gerät mit mir geshared was funktionier genau nicht
                        mk122 last edited by
                        @tombox Hallo, ich verwende den Luftbefeuchter LV600S der wunderbar mit dem Adapter funktioniert. Bei unserem zweiten im Haus der OasisMist 1000S, funktioniert zwar der "status" Ordner den er laufend aktualisieren kann, jedoch alle "remote" Parameter werden nicht gelesen und angenommen, sie wurden nur beim ersten einrichten einmalig ausgelesen. Hast du eine Idee was da die mögliche Ursache sein kann? Vielen Dank! Lg
                          tombox @mk122 last edited by
                          @mk122 sagt der debug log irgendwas
                          M T 2 Replies Last reply Reply Quote 0
                            mk122 @tombox last edited by
                            @tombox Danke für deine Antwort. Ja, code 11000000.
                            "{"traceId":"1736450305669","code":0,"msg":"request success","module":null,"stacktrace":null,"result":{"traceId":"1736450305669","code":11000000}}"
                              tombox @tombox last edited by
                              @tombox scheint aber so dass der Befehl angenommen und verarbeitet wird
                                robbsen @JoJAPJo last edited by robbsen
                                @jojapjo ich scheine blind zu sein, habe Version 0.0.9 sehe diesen wert aber leider nicht 😞 (Watt Zahl) welche Version brauche ich denn dafür
                                scheint aber grundsätzlich ja zu funktionieren https://www.home-assistant.io/integrations/vesync/
                                  JoJAPJo @robbsen last edited by
                                  @robbsen: Ich habe gerade auch einmal auf die Version 0.0.9 geupdatet;
                                  Der Wert lautet realTimePower:
                                  zu finden wäre es wie folgt:
                                  vesync
                                  ->0
                                  -->Info
                                  --->vs........ (Device-ID)
                                  ---->status
                                  Daniel
                                    @jojapjo ok also diesen Datenpunkt habe ich eindeutig nicht trotz Version 0.0.9, spannen das es ihn bei dir gibt.
                                    • mcm1957
                                      mcm1957 @robbsen last edited by
                                      @robbsen
                                      Von wo / wie installiert?
                                      LATEST Repository oder GitHub?
                                        Direkt über den Link von Github runtergeladen, auch versucht über TA2k/ioBroker.vesync also ebenfalls Github
                                        • mcm1957
                                          mcm1957 @robbsen last edited by mcm1957
                                          @robbsen said in Test Adapter VeSync:
                                          Bei Github Installationsn sagen die Versionsnummern absolut nichts aus. Die Versionnummer wird im Allgemeinen erst beim Erstellen einer Release geändert. Version 1.2.3 kann sich zwischen der offiziellen Release auf npm und dem Stand auf Github total unterscheiden. Auch zwei Github Installation mit selber Versinsnummer müssen nicht ein Bit identisch haben.
                                          Wenn du bei Github Installationen eine eindeutige Referenz des SW Standes haben willst, musst du den Github SHA nehmen. Dazu mit der Maus auf die GH Katze gehen. Der SHA wird dir als Tooltip angezeigt:
                                          Mit der INfo kannst den exakten SW STand identifizieren.
                                          • Negalein
                                            Negalein Global Moderator last edited by Negalein
                                            Hallo
                                            Ich habe heute den AirFryer CS158-AF mit dem Adapter (0.0.9) verbunden.
                                            Klappte sofort. 🙂
                                            Unter vesync.0.vssk8fa8b19425c9c4ffe882e0027886.status werden die DP korrekt aktualisiert.
                                            Aber wie steuere ich den AirFryer vom ioB aus?
                                            Egal was in vesync.0.vssk8fa8b19425c9c4ffe882e0027886.remote geschaltet wird, der AirFryer macht keinen Murks. 😞
                                            31.7k
                                            79.8k
                                            124
                                            11454
