    4. Anfrage Tahoma/Somfy IO Adapter
      Honnkoponko @Honnkoponko last edited by Honnkoponko
      Hat jemand Lösung für so was gefunden?
      Kommt ein mal pro 3-5 Tage... Muss tahoma neustarten warten usw...
      Gibt es eine Lösung dazu???
      Nach schnell neustart funktioniert immer nicht. Ich muss immer tahoma für za. 5 Minuten ausschalten und get wieder....
      tahoma.0
      6590	2024-11-24 17:29:37.698	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:29:34.611	debug	GET request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:29:34.610	debug	Update gateway status for id undefined
      tahoma.0
      6590	2024-11-24 17:29:24.898	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:29:21.824	debug	POST request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:29:21.823	debug	Starting state polling
      tahoma.0
      6590	2024-11-24 17:29:04.610	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:29:01.523	debug	GET request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:29:01.523	debug	Update gateway status for id undefined
      tahoma.0
      6590	2024-11-24 17:28:54.882	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:28:51.819	debug	POST request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:28:51.819	debug	Starting state polling
      tahoma.0
      6590	2024-11-24 17:28:31.522	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:28:28.436	debug	GET request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:28:28.435	debug	Update gateway status for id undefined
      tahoma.0
      6590	2024-11-24 17:28:24.898	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:28:21.814	debug	POST request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:28:21.813	debug	Starting state polling
      tahoma.0
      6590	2024-11-24 17:27:58.434	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:27:55.350	debug	GET request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
      tahoma.0
      6590	2024-11-24 17:27:55.350	debug	Update gateway status for id undefined
      tahoma.0
      6590	2024-11-24 17:27:54.882	warn	error during request: Error: connect EHOSTUNREACH 192.168.77.238:8443, request path: events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:27:51.810	debug	POST request on https://gateway-xxxx-xxxx-xxxx     :8443/enduser-mobile-web/1/enduserAPI/events/0a102a6f-33d9-45a6-a54b-826095573356/fetch with payload:{}
      tahoma.0
      6590	2024-11-24 17:27:51.810	debug	Starting state polling
        Kanumouse @Honnkoponko last edited by
        @honnkoponko
        Ich habe seit ein paar Tagen die gleiche Fehlermeldung.
        Gibt es dafür schon eine Lösung`?
        Schein mit einem Update der tahoma-Firmware zusammen zuhängen.
          Gukerl @jumbo125 last edited by
          @jumbo125 Wie hast Du am Tahoma Switch den Entwicklermodus aktiviert. Ich habe die Switch und lt. Support gibts dafür keine WebGUI?
          Danke, Andi
            Gukerl @Kanumouse last edited by
            @kanumouse said in Anfrage Tahoma/Somfy IO Adapter:
            ch habe die Tahoma Switch im Einsatz mit dem entsprechenden iobroker-Adapter und steuere ein Pergola-Dach und 2 Rolläden (ausgelöst durch ein Blockly). Funktioniert alles wunderbar.
            Wie hast Du dnn das gemacht? Welche Objekte steuerst Du? Lokal geht's ja nicht. Die Datenpunkte wurden angelegt, allerdings ohne lokale IP. Wie geht's dann weiter.
            Skript kein Problem, ich weiss nicht, welche der vielen Datenpunkte da anzugreifen sind.
            Vielen DANK, Andi
              Kanumouse @Gukerl last edited by
              @gukerl
              Ich habe 2 Velux-Rollläden und ein Pergoladach mit einem Somfy-Modul. Alles habe ich an den Switch angelernt mit der entsprechenden Tahoma-App auf dem Smartphone.
              Dann stehen unter dem Tahoma-Adapter die entsprechenden Datenpunkte zur Verfügung.
              Beispielsweise steuere ich dann die beiden Hälften meines Pergoladachs bei Regen zu.
                <block type="on_ext" id="RV2/GC9cS]`(L|42YMH6" x="13" y="13">
                  <value name="OID0">
                    <shadow type="field_oid" id="4oQMKQO9aFlN_{1WUr`n">
                      <field name="oid">hm-rega.0.39780</field>
                    <block type="comment" id="W}SKXH+5^#Z1W2iZ$0`t">
                      <field name="COMMENT">Terrassendach - linke Seite</field>
                        <block type="controls_if" id="}|(tB0f2X#76I5`qEmRX">
                            <block type="logic_operation" id="ydUNNUx|T7CWjpM8!Z+#">
                              <field name="OP">AND</field>
                                <block type="logic_compare" id="zcQ(2N-EgMAFN}=ve*GR">
                                  <field name="OP">EQ</field>
                                    <block type="get_value" id="XcSqf5an1hwc8Sas59dv">
                                      <field name="OID">hm-rega.0.39780</field>
                                    <block type="logic_boolean" id="(9h##,?OfySx@ub$R4gc">
                                <block type="logic_compare" id="GRkbB11|{hQYU;E^yJ,-">
                                  <field name="OP">NEQ</field>
                                    <block type="get_value" id="f6l/_=R`]5n|@#O_+`np">
                                      <field name="OID">tahoma.0.devices.TD_links.states.core:TargetClosureState</field>
                                    <block type="math_number" id="m^cHP!H)A!e[:ki/Xomh">
                                      <field name="NUM">0</field>
                            <block type="control" id="te|qK]pKa/zzpU0keMJT">
                              <field name="OID">tahoma.0.devices.TD_links.commands.close</field>
                                <block type="logic_boolean" id="k,J2)6=8H]xeb:TVcGZF">
                                <block type="debug" id="46P=!JdIt4sA?q^Xu?`v">
                                  <field name="Severity">debug</field>
                                  <value name="TEXT">
                                    <shadow type="text" id="uIlR-edI84z-k.!Zd?@(">
                                      <field name="TEXT">linke Seite</field>
                            <block type="comment" id="9x^`;W)O~E9k|Psa9i,/">
                              <field name="COMMENT">Terrassendach - rechte Seite</field>
                                <block type="controls_if" id="V@u@W!Ny80ii*:{eDbF%">
                                    <block type="logic_operation" id="ioQkZ!}0Z9F4[GD]{nl%">
                                        <block type="logic_compare" id="=M9vFvZ[b~kx*+*$25;F">
                                            <block type="get_value" id="KP{51^l)jg;T{ME[yVRW">
                                            <block type="logic_boolean" id="QKCuscX0.U$ap2~~Ld[.">
                                        <block type="logic_compare" id="boJ!mEZReN!Y]9jTEkf)">
                                            <block type="get_value" id="znOD.Zr(!Wkkj27ukrdY">
                                              <field name="OID">tahoma.0.devices.TD_rechts.states.core:TargetClosureState</field>
                                            <block type="math_number" id="?h3uy^W79qtvs8BM1C(M">
                                    <block type="control" id="Ker7=V1,Ti.Ja%Igka#7">
                                      <field name="OID">tahoma.0.devices.TD_rechts.commands.close</field>
                                        <block type="logic_boolean" id="LgiTKHHQs~i`Sf.$fBm9">
                                        <block type="debug" id="pD2FzFP!RRs*qpYB]RY}">
                                          <value name="TEXT">
                                            <shadow type="text" id="S$~C02cqY6[(j{z{[7,k">
                                              <field name="TEXT">rechte Seite</field>
                @kanumouse
                Was geht: Velux Dachflächen Außenrollo, was nicht geht und den Adapter lahm legt sind Somfy Außenrollos.
                Hier bekomme zB "Got action event for invalid device: und so weiter..." als Fehlermeldung.
                Nun gut, ist kein Supergau, es wird das Log zugemüllt, sobald ich mit der MobileApp was steuere.
                LG, Andi
                  Matt77CHE last edited by
                  Bei mir scheint der Adapter seit einigen Tagen nicht mehr zu funktionieren;
                  Vorher konnte ich ohne Probleme die Aussenrollos bedienen, seit einigen Tagen geht nichts mehr...:
                  tahoma.0
                  2024-12-07 09:30:44.154	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup/gateways with payload:{}
                  tahoma.0
                  2024-12-07 09:30:44.139	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                  tahoma.0
                  2024-12-07 09:30:44.139	debug	Update gateway status for id undefined
                  tahoma.0
                  2024-12-07 09:30:14.138	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup/gateways with payload:{}
                  tahoma.0
                  2024-12-07 09:30:14.098	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                  tahoma.0
                  2024-12-07 09:30:14.098	debug	Update gateway status for id undefined
                  tahoma.0
                  2024-12-07 09:30:04.185	warn	{"error":{"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.93","port":8443}}
                  tahoma.0
                  2024-12-07 09:30:04.185	warn	setup failed!
                  tahoma.0
                  2024-12-07 09:30:04.184	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup with payload:{}
                  tahoma.0
                  2024-12-07 09:30:04.149	debug	stateChange tahoma.0.update {"val":false,"ack":true,"ts":1733560204147,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1733508840950}
                  tahoma.0
                  2024-12-07 09:30:04.148	debug	stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1733560204147,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1733560204147}
                  tahoma.0
                  2024-12-07 09:30:04.098	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup with payload:{}
                  tahoma.0
                  2024-12-07 09:30:04.097	info	Using stored bearer token 6618c48391938be89f0d
                  tahoma.0
                  2024-12-07 09:30:04.096	info	Adapter will connect to Tahoma Box via local API.
                  tahoma.0
                  2024-12-07 09:30:04.095	debug	[START] Started Adapter
                    Gre4t0ne last edited by
                    Bei mir funktioniert der Adapter ABER das Protokoll wird mit folgenden Warnings überschwemmt:
                    025-01-02 21:31:58.979	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""}
                    tahoma.0
                    2025-01-02 21:31:58.978	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Thu, 02 Jan 2025 20:31:58 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2080-0101-7321.local:8443","port":"8443","hostname":"gateway-2080-0101-7321.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","href":"https://gateway-2080-0101-7321.local:8443/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 66f2f74093e4a56b44ac","Content-type":"application/json","accept":"application/json","content-length":2}}}
                    tahoma.0
                    2025-01-02 21:31:58.978	warn	error during request: null, request path: events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch with payload:{}
                    tahoma.0
                    2025-01-02 21:31:39.043	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""}
                    tahoma.0
                    2025-01-02 21:31:39.042	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Thu, 02 Jan 2025 20:31:39 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2080-0101-7321.local:8443","port":"8443","hostname":"gateway-2080-0101-7321.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","href":"https://gateway-2080-0101-7321.local:8443/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 66f2f74093e4a56b44ac","Content-type":"application/json","accept":"application/json","content-length":2}}}
                    tahoma.0
                    2025-01-02 21:31:39.042	warn	error during request: null, request path: events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch with payload:{}
                    oberfragger G 2 Replies Last reply Reply Quote 0
                    • oberfragger
                      oberfragger @Gre4t0ne last edited by
                      @gre4t0ne Bei mir kein Problem (hab den nur kurz für 1ne Minute gestartet).
                        Honnkoponko @oberfragger last edited by
                        @oberfragger
                        verwendest du Adapter in Lokal Modus via PIN oder ohne PIN?
                        Bei mir mit PIN Lokal geht nicht.
                        oberfragger 1 Reply Last reply Reply Quote 0
                        • oberfragger
                          oberfragger @Honnkoponko last edited by
                          @honnkoponko Nichts lokales. Über die Cloud. Ich habe ein Connectivity Kit.
                          https://shop.somfy.de/somfy-connectivity-kit.html
                            Gukerl last edited by Gukerl
                            Ich habe die Tahoma Switch, der Development Mode ist eingeschalten. Im Adapter verwende ich die Standard Einstellungen, Benutzer, Passwort + PIN der Tahoma-Box (z. B. 1234-5678-9012) in den "lokale API Einstellungen".
                            Leider bekomme ich beim Start des Adapter immer diese Meldung. Den Adapter habe ich bereits einmal deinstalliert und neu installiert, dann gab's auch wieder ein Token.
                            Gibt's irgendwas, das ich falsch machen könnte? Die Box Selbst hat eine fixe IP und ich hab sie sogar per Fritzbox adapter-xxxx-xxxx-xxxx (Pin) genannt.
                            Danke für Tipps, Andi 🙂
                            Edit: Neue Fehlermeldung ist aufgetaucht, als ich bim nicht laufenden Adapter was geändert und gespeichert habe:
                            tahoma has an invalid jsonConfig:
                            [{"instancePath":"/items/basicSettingsTab/items/note","schemaPath":"#/patternProperties/%5E.%2B/allOf/37/then/oneOf","keyword":"oneOf","params":{"passingSchemas":[0,1]},"message":"must match exactly one schema in oneOf"},{"instancePath":"/items/basicSettingsTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                              Murphys234d last edited by Murphys234d
                              Achtung: Lokale Api wird wohl mit aktuellem Tahoma Update deaktiviert.
                              Ich habe jetzt aus 2 Richtungen gehört, dass mit dem letzten Update nicht nur die angekündigte iftt Unterstützung sondern auch die lokale Api der Tahoma deaktiviert wird.
                              Hoffentlich wird es noch gefixt, aber wartet erstmal mit dem Update wenn ihr sie nutzt.
                              T G 2 Replies Last reply Reply Quote 0
                                toralt @Murphys234d last edited by
                                @murphys234d HA warnt ebenfalls aktiv und dort funktioniert nur noch der Cloudzugriff nach Update. Ich denke auch, dass das den ioBroker Adapter 1:1 betrifft.
                                ioT4db 1 Reply Last reply Reply Quote 0
                                • ioT4db
                                  ioT4db @toralt last edited by
                                  @toralt @Murphys234d ich hab das Update leider schon gemacht. Bei mir ist es so, dass die lokale API nicht komplett deaktiviert wurde, aber scheinbar nicht mehr alle Objekte aktualisiert werden.
                                  Raffstores kann ich weiterhin lokal steuern, aber bspw. der Sonnensensor kann nicht mehr lokal abgerufen werden, so scheint es.
                                  VG
                                    Murphys234d @ioT4db last edited by
                                    @iot4db Ich drück die Daumen, dass sie es doch noch wieder fixen.
                                    Sonst bleibt wohl nur der Weg über die Cloud.
                                      Gukerl @Murphys234d last edited by
                                      @murphys234d said in Anfrage Tahoma/Somfy IO Adapter:
                                      Interessant, denn ich hab den Entwicklermodus erst vor ein paar Tagen aktiviert, als Info bekommt man noch diesen Link: https://github.com/Somfy-Developer
                                      Allerdings führt dieser in ein 504 Gateway Time-out, scheint also nicht mehr aktiv zu sein.
                                        gammler2003 @Gre4t0ne last edited by
                                        @gre4t0ne Ich habe exakt die selbe Situation - der Adapter funktioniert, aber spuckt in ständig diese Fehlermeldung aus. Ich nutze den Zugang über die lokale API auf eine Tahoma Classic.
                                        Gibt es hier in der Runde Ideen, woran das liegen könnte? Vielen Dank euch vorab.
                                          Kanumouse @gammler2003 last edited by
                                          Ich habe den gleichen Fehler.
                                          Es kommt immer folgende Warnmeldung:
                                          Response: {"statusCode":400,"body":"{\"errorCode\":\"UNSPECIFIED_ERROR\",\"error\":\"Unknown object.\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization, Content-Type","content-length":"59","connection":"close","date":"Sat, 01 Feb 2025 15:15:17 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2052-7119-6399:8443","port":"8443","hostname":"gateway-2052-7119-6399","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/setup","path":"/enduser-mobile-web/1/enduserAPI/setup","href":"https://gateway-2052-7119-6399:8443/enduser-mobile-web/1/enduserAPI/setup"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 65823c3daa66f8769349","Content-type":"application/json"}}}
                                            Es scheint, als hätte Tahoma die API abgedreht.
                                            https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/161
                                            LG, Andi
                                            Skirf created this issue in Somfy-Developer/Somfy-TaHoma-Developer-Mode
                                            closed Can't get local API to work #161
                                            605
                                            157110
