    4. Homematic RPC und Gerätebeschreibungen
    • SmartStuffCoyote
      SmartStuffCoyote @JoJo58 last edited by SmartStuffCoyote
      @jojo58 Die sind halbt abgeschnitten. Aber ich habe die gleichen Symptome:
      /var/log/messages
      Jan  8 20:30:18 ccu3 local0.info ReGaHss: Info: ScriptRuntimeError: Stack trace: [-1]   0 0x0000 [0]  72 0x0048 [1]   0 0x0000 [2]   7 0x0007 [3]   0 0x0000 [4]  16 0x0010  [ExecError():iseESPexec.cpp:12945]
      Jan  8 20:30:18 ccu3 local0.err ReGaHss: ERROR: ScriptRuntimeError: !# devices.fn 1.4 !# !# Dieses Homematic-Script gibt eine Liste aller Geraete/Kanaele als JSON String aus !# !# 3'2013-7'2013 hobbyquaker https://github.com/hobbyquaker !#  string sDevId; string sChnId;  Write('{');  boolean dFirst = true;  foreach (sDevId, root.Devices().EnumUsedIDs()) {      object oDevice   = dom.GetObject(sDevId);     boolean bDevReady = oDevice.ReadyConfig();     string sDevInterfaceId = oDevice.Interface();     string sDevInterface   = dom.GetObject(sDevInterfaceId).Name();          if (bDevReady) {          if (dFirst) {           dFirst = false;         } else {           WriteLine(',');         }          Write('"' # oDevice.Address() # '":{"Name":"');         WriteURL(oDevice.Name());         Write('","Interface":"' # sDevInterface # '"}');                  foreach(sChnId, oDevice.Channels()) {         	object oChannel = dom.GetObject(sChnId);             WriteLine(',');           	Write('"' # oChannel.Address() # '":{"Name":
      Jan  8 20:30:18 ccu3 local0.info ReGaHss: Info: ScriptRuntimeError: Stack trace: [-1]   0 0x0000 [0]  65 0x0041 [1]   0 0x0000 [2]  58 0x003a [3]   0 0x0000 [4]  59 0x003b  [ExecError():iseESPexec.cpp:12945]
      Jan  8 20:30:23 ccu3 local0.info ReGaHss: Info: ScriptRuntimeError: Stack trace: [-1]   0 0x0000 [0]  72 0x0048 [1]   0 0x0000 [2]  65 0x0041 [3]   0 0x0000 [4]  58 0x003a  [ExecError():iseESPexec.cpp:12945]
      Jan  8 20:30:23 ccu3 local0.err ReGaHss: ERROR: ScriptRuntimeError: !# functions.fn 1.3 !# !# Dieses Script gibt eine Liste der Gewerke als JSON String aus !# !# 6'2013-7'2014 bluefox, hobbyquaker !#  object  oFunction; string  sFunctionId; string  sChannelId; object  oChannel; boolean bFirst       = true; boolean bFirstSecond = true;  Write("{"); foreach (sFunctionId, dom.GetObject(ID_FUNCTIONS).EnumUsedIDs()) {     if (bFirst == false) {       WriteLine(',');     } else {       bFirst = false;     }     oFunction = dom.GetObject(sFunctionId); 	Write('"' # sFunctionId # '": ');     Write('{"Name": "');     WriteURL(oFunction.Name());     Write('","TypeName":"' # oFunction.TypeName() # '_FUNCTIONS');     Write('", "EnumInfo": "');     WriteURL(oFunction.EnumInfo());     Write('", "Channels": ['); 	bFirstSecond = true;     foreach(sChannelId, oFunction.EnumUsedIDs()) {         oChannel = dom.GetObject(sChannelId);         ! Objekt ueberspringen, falls nicht vom Typ CHANNEL (33)         if (oChannel.Type() != 33) { conti
      Jan  8 20:30:23 ccu3 local0.info ReGaHss: Info: ScriptRuntimeError: Stack trace: [-1]   0 0x0000 [0]  65 0x0041 [1]   0 0x0000 [2]  58 0x003a [3]   0 0x0000 [4]  59 0x003b  [ExecError():iseESPexec.cpp:12945]
      /var/log/hmserver.log zeigt dieses:
      2025-01-06 20:48:28,362 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getDeviceDescription called for address null!
      2025-01-06 20:48:28,381 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getParamset: VirtualDevice not found for address :0
      2025-01-06 20:51:02,888 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getDeviceDescription called for address null!
      2025-01-06 20:51:02,894 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getParamset: VirtualDevice not found for address :0
      2025-01-06 20:52:51,735 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getDeviceDescription called for address null!
      2025-01-06 20:52:51,738 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getParamset: VirtualDevice not found for address :0
      2025-01-07 17:02:42,535 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getDeviceDescription called for address null!
      2025-01-07 17:02:42,539 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getParamset: VirtualDevice not found for address :0
      2025-01-08 08:11:46,140 de.eq3.lib.measurement.MeasurementService ERROR [Timer-0] Could not retrieve unhandled events
      java.util.ConcurrentModificationException: null
      	at java.util.ArrayList$Itr.checkForComodification(Unknown Source) ~[?:?]
      	at java.util.ArrayList$Itr.next(Unknown Source) ~[?:?]
      	at de.eq3.lib.measurement.MeasurementService.writeLogValues(MeasurementService.java:835) ~[HMIPServer.jar:?]
      	at de.eq3.lib.measurement.MeasurementService$EventTimerTask.run(MeasurementService.java:121) ~[HMIPServer.jar:?]
      	at java.util.TimerThread.mainLoop(Unknown Source) ~[?:?]
      	at java.util.TimerThread.run(Unknown Source) ~[?:?]
      2025-01-08 13:14:26,728 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getDeviceDescription called for address null!
      2025-01-08 13:14:26,732 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega ERROR [vert.x-eventloop-thread-0] getParamset: VirtualDevice not found for address :0
      lighttpd-error.log hat die letzten Einträge vom 05.01. lighttpd-access.log hat um den Zeitraum die Rega-Aufrufe verzeichnet, aber nur Statuscodes HTTP 200, also alles in Ordnung.
      Für die Fehelrmeldungen habe ich zwei Infos gefunden, beide ein paar Jahre alt:
      1. das mit dem null kommt, wenn die CCU3 Konfigurationsänderungen nicht übertragen kann. Das deckt sich mit meinen aktuellen Einstellungsänderungen an den Heizgruppen.
      2. die Exception kommt möglicherweise, wenn man GetObject-Aufrufe schachtelt. Das war ein Post von 2017 oder so und so einen Quatsch mache ich nicht.
      Firmware 3.79.6, dann Downgrade auf 3.77.6, dann wieder Upgrade auf 3.79.6, dann Wechsel zu Raspberrymatic 3.79.6.20241122. XML-API 2.3, dann Downgrade auf 2.1 und wieder zurück auf 2.3.
      SmartStuffCoyote 1 Reply Last reply Reply Quote 0
      • SmartStuffCoyote
        SmartStuffCoyote @SmartStuffCoyote last edited by
        Ich hab jetzt mal im HM-Forum nachgefragt:
        https://homematic-forum.de/forum/viewtopic.php?f=26&t=84694
        Vielleicht gibts da bessere Einsichten von der anderen Seite.
        JoJo58 1 Reply Last reply Reply Quote 0
        • JoJo58
          JoJo58 @SmartStuffCoyote last edited by
          @smartstuffcoyote sagte in Homematic RPC und Gerätebeschreibungen:
          Gute Idee 👍
          Ich glaube auch langsam, das es an der CCU liegt. Ich habe insgesamt 3 Rechner mit IoBroker laufen, 2x VMs und ein Raspi 4 und auf allen das gleiche Problem. Bis auf die Fehlermeldung, Da wird noch die lange angezeigt, wie in meinem Post vom 08.01.25 um 10:12, also das ist das erste Gerät in der Liste der CCU und da bricht er ja schon ab..
          Abwarten was das HM Forum sagt.
          SmartStuffCoyote bahnuhr 2 Replies Last reply Reply Quote 0
          • SmartStuffCoyote
            @JoJo58 Ich hab für die Skeptiker übrigens auch mal alle Geräte und Kanäle mit Umlaut drin umbenannt. Ändert am Verhalten nichts. Ich wollte es mal eingrenzen indem ich versucht habe, den Rega-Adapter lediglich die wenigen virtuellen oder HM-IP-Geräte zu synchronisieren, aber er greift trotzdem auch ins rpc und produziert den Fehler.
            Frage an dich: du hattest als letztes ein HM-IP-Gerät hinzugefügt? Zufällig ein Fensterkontakt? Das war auch die letzte Änderung am System meinerseits, abgesehen vom jüngsten Ausfall. Ist schon eine Weile her, aber solange ich die Datenbäume nicht neu einlese, merke ich davon ja nichts.
            • bahnuhr
              bahnuhr Forum Testing Most Active @JoJo58 last edited by
              @jojo58
              @SmartStuffCoyote
              Ich habe den thread nicht komplett gelesen; vermute aber es liegt an euren Einstellungen.
              Bitte komplett zeigen:
              ccu:
              • screenshot firewall
              • screenshot systemsteuerung.sicherheit (Authentifizierung und Https)
              • Hast du viele Programme auf der ccu ?
              iob hm-rega:
              • screenshot config
              iob hm-rpc:
              • screenshot config
              Und bitte komplett.
              mfg
              JoJo58 SmartStuffCoyote 2 Replies Last reply Reply Quote 0
              • JoJo58
                JoJo58 @bahnuhr last edited by
                @bahnuhr
                Okay, ich kann dir gerne die ganzen Screenshots machen, aber es liegt nicht an den Einstellungen. Die hm-rps.0 Instanz liest die Geräte ja alle ein, nur die Namen werden nicht ausgelesen und es wurden keine Einstellungen geändert.
                Gib mit ne halbe Stunde, dann poste ich hier die Screenshots.
                • bahnuhr
                  @jojo58
                  du musst aber irgendwas anders machen.
                  Denn dieses Problem hatte ich noch nie !
                  • JoJo58
                    @bahnuhr
                    Das Problem ist ja auch neu und tauchte erst auf, nachdem ich die Geräte neu eingelesen habe, weil beim neuen Gerät nur die Nummer stand.
                    Das sind die Screenshots und ich habe nur 6 kleine Programme laufen.
                    Firewall
                    Systemsteuerung Sicherheit
                    HM-REGA
                    HM-RPC
                    Homoran bahnuhr 2 Replies Last reply Reply Quote 0
                      Homoran Global Moderator Administrators @JoJo58 last edited by
                      @jojo58 sagte in Homematic RPC und Gerätebeschreibungen:
                      Auch ich habe das Problem (bisher) nicht, obwohl ich vor paar Tagen neue HmIP Geräte angeernt habe.
                      Ich vermute daher, dass es möglicherweise an deiner CCU / HM-Installation liegt.
                      Wie viele HmIP Geräte hast du?
                      in den Anfängen von Homematic war die Anzahl möglicher Geräte reativ niedrig. Es wäre ja für Home und nicht Business.
                      Diese Anzahl wurde sukzessive erhöht.
                      Möglicherweise ist bei IP ein Problem beim Erstellen des json
                      • JoJo58
                        @smartstuffcoyote
                        Ich habe eine Steckdose HmIP-PSM-2 angelernt. Und das mit dem umbenennen habe ich auch getestet, wie bei dir ohne Erfolg.
                        Ich glaube, das hier ist die Funktion, die die Namen abruft und die passt so. Ich habe keine Ahnung von Programmieren, aber ich habe die durch KI geprüft. Da antwortet die CCU3 nicht wie gewohnt und man kann auch sehen, an welcher Stelle der Funktion abgebrochen wird.
                        Ich habe auch keine Ahnung von Github, sonst würde ich den Entwickler fragen, ob der eine Idee hat.
                        !# devices.fn 1.4
                        string sDevId;
                        string sChnId;
                        Write('{');
                            if (bDevReady) {
                                if (dFirst) {
                                  dFirst = false;
                                } else {
                                  WriteLine(',');
                                    WriteLine(',');
                                  	Write('"' # oChannel.Address() # '":{"Name":"');
                                	WriteURL(oChannel.Name());
                        Write('}');
                        • bahnuhr
                          @jojo58
                          zu ccu:
                          Was sind dies für IP ?
                          Du hast doch 192.168.1.xx !
                          hm-rega
                          Haken bei https raus
                          hm-rpc.0
                          Angaben nicht geliefert !
                          Seite fehlt !
                          Warum ?
                          Ich vermute, dass dies auch nicht korrekt eingestellt ist.
                          hm-rpc.1
                          Port ändern auf 2010
                          HTTPS Haken raus nehmen
                          Fazit:
                          Leider nicht vollständig geliefert.
                          Screenshot von hm-rpc.0 und hm-rpc.3 fehlt.
                          Ändere dies mal wie oben genannt ab.
                          Dann läuft es.
                          • SmartStuffCoyote
                            SmartStuffCoyote @bahnuhr last edited by SmartStuffCoyote
                            @bahnuhr Ich hab 33 Programme, davon eins inaktiv und die allermeisten ziemlich simpel. Das komplexeste sind das Astro-Skript (das ich glaube ich langsam mal entsorgen kann) und Dr. Tob's Update-Skript für das Wanddisplay. Keine Ahnung, ob das jetzt "viel" ist, würde mich überraschen.
                            Abgesehen von der CCU3 habe ich zwei HmIP-Geräte - HmIP-STHO-A und HmIP-SWDO-2.
                            Firewall
                            Config hm-rega
                            Config hm-rpc
                            • JoJo58
                              JoJo58 @Homoran last edited by
                              @homoran sagte in Homematic RPC und Gerätebeschreibungen:
                              Sorry, hatte deinen Post überlesen. Ich habe jetzt 25 HM IP Geräte und das wäre schon krass, wenn das zu viel ist. Oder Zählen die ganzen Kanäle der CCU3 auch zu den IP Geräten? Beim Einlesen kommt da irgendwas mit 263 Geräte oder so.
                              • bahnuhr
                                bahnuhr Forum Testing Most Active @SmartStuffCoyote last edited by
                                @smartstuffcoyote
                                CCU:
                                Was ist 12001 und 9292 ?
                                Unten die IP
                                dürften nicht stimmen.
                                Bei mir steht da z.B.
                                Vergleiche dies mal.
                                CCU Sicherheit: ist ok
                                hm-rega.o
                                IP Adresse eintragen; nicht ccu3
                                Und bei duty cycle auf der 2. Seite ein Intervall in Sek.
                                hm-rpc.0
                                Als callback Adresse die IP von iob
                                Leider fehlt auch hier:
                                hm-rpc.1 und hm-rpc.2
                                Liefere alles, dann kann man es beurteilen.
                                • SmartStuffCoyote
                                  @bahnuhr sagte in Homematic RPC und Gerätebeschreibungen:
                                  Soll das ein Witz sein? 192.168.178.33 und 34 sind die IPs des ioBroker. Der Rest ist schlich Voreinstellung der CCU. Warum sollte ich deine IPs dort eintragen? Die IPv6-Adresse hab ich rausgeworfen, weil ich kein IPv6 habe.
                                  Und nein, die IP-Adresse trage ich da nicht ein. Ich nehme den DNS-Alias. Als Callback ist exakt die IP-Adresse des ioBrokers eingetragen, die du in den Firewall-Einstellungen noch als falsch bezeichnet hast.
                                  Ja, hm-rpc.1 und hm-rpc.2 fehlen, aber ich muss schon so langsam fragen, ob du das aus Prinzipienreiterei wissen willst. Das Problem wird vom hm-reha geloggt bei der RPC-Abfrage. Was die anderen Adapter da machen ist wurscht. Wenn die IP-Adressen nicht stimmen würden, käme nicht die halbe Antwort, von der CCU, sondern gar keine, und sämtliche ioBroker-Programme, die die Geräte verwenden, würden nicht funktionieren.
                                  @JoJo58 Im homematic-Forum gibts jetzt eine Lösungsansatz. Wie erwartet wird auch dort vermutet, dass das Skript zur JSON-Erstellung abbricht. Wir sollen CCU-seitig schauen, warum.
                                  Nachtrag: bestätigt, das geht CCU-seitig kaputt, das Skript bricht ab.
                                  • JoJo58
                                    hm-rpc.0
                                    Seite fehlt !
                                    Warum ?
                                    Von den Instanzen 0 und 3 habe ich nichts gepostet, weil die funktionieren .
                                    Ich habe die Einstellungen jetzt angepasst und musste bei hm-rpc.1 auch noch das https rausnehmen. Dann die Geräte neu eingelesen und der Fehler ist der Gleiche, nur die Nummern und im Protokoll die gleiche Meldung:
                                    hm-rega.0
                                    	2025-01-10 11:04:56.201	error	Cannot parse answer for devices: {"0008DD89B328D6":{"Name":"DA-B%FCro","Interface":"HmIP-RF"}, "0008DD89B328D6:0":{"Name":"DA-B%FCro%3A0","Interface":"HmIP-RF"}, "0008DD89B328D6:1":{"Name":"DA-B%FCro%3A1","Interface":"HmIP-RF"}, "0008DD89B328D6:2":{"Name":"DA-B%FCro%3A2","Interface":"HmIP-RF"}, "0008DD89B328D6:3":{"Name":"DA-B%FCro%3A3","Interface":"HmIP-RF"}, "0008DD89B328D6:4":{"Name":"DA-B%FCro%3A4","Interface":"HmIP-RF"}, "0008DD89B328D6:5":{"Name":"DA-B%FCro%3A5","Interface":"HmIP-RF"}, "0008DD89B328D6:6":{"Name":"DA-B%FCro%3A6","Interface":"HmIP-RF"}, "0008DD89B328D6:7":{"Name":"DA-B%FCro%3A7","Interface":"HmIP-RF"}
                                    • SmartStuffCoyote
                                      @jojo58 Scheint am CuXD-MAIL zu liegen - da bricht die Schleife bei mir ab. Ich hab grad keine Zeit, ich mache nachher mal einen Downgrade und schaue, ob es an der aktualisierten CuXD-Version lag.
                                      • bahnuhr
                                        Na, wenn du meinst.
                                        Dann bin ich raus.
                                        Wie gesagt, das Problem hatte ich noch nicht.
                                        • wendy2702
                                          wendy2702 @SmartStuffCoyote last edited by
                                          Welche Version nutzt du denn?
                                          • SmartStuffCoyote
                                            SmartStuffCoyote @wendy2702 last edited by
                                            @wendy2702 2.12. Hab jetzt schnell noch 2.10.1 draufgemacht, ändert aber nichts
                                            3047
