    4. TibberLink Adapter
    TibberLink Adapter
    • icebear
      icebear @Merlin123 last edited by icebear
      @merlin123 said in TibberLink Adapter:
      Und Du setzt im Script die Variable "PV_Energyforecast" auf "Wert von Objekt ID 'energyforecast'"?
      Ok. Ein Schritt weiter. Ich hatte den DP falsch konfiguriert, der stand auf 'Zustandstyp' = array.
      Ich hab den jetzt mal auf Zustandstyp = string geändert und jetzt liefert er schonmal Werte. Beim Debug Output kommen 62 Werte.
      Der DP für das Diagramm sieht jetzt so aus:
      { backgroundColor: "rgba(255,52,179, 0)", 	"tooltip":  	{"trigger":  		"axis", 		"axisPointer":  			{"type": "shadow"} 	}, 	"legend": {"show":false}, 	"xAxis": 		[ 			{ 				"type": "category", 				"data": ["10. 0Uhr","10. 1Uhr","10. 2Uhr","10. 3Uhr","10. 4Uhr","10. 5Uhr","10. 6Uhr","10. 7Uhr","10. 8Uhr","10. 9Uhr","10. 10Uhr","10. 11Uhr","10. 12Uhr","10. 13Uhr","10. 14Uhr","10. 15Uhr","10. 16Uhr","10. 17Uhr","10. 18Uhr","10. 19Uhr","10. 20Uhr","10. 21Uhr","10. 22Uhr","10. 23Uhr","11. 0Uhr","11. 1Uhr","11. 2Uhr","11. 3Uhr","11. 4Uhr","11. 5Uhr","11. 6Uhr","11. 7Uhr","11. 8Uhr","11. 9Uhr","11. 10Uhr","11. 11Uhr","11. 12Uhr","11. 13Uhr","11. 14Uhr"] 			} 		],    	"yAxis": 		[ 			{ 				"type": "value", 				"min": 0, 				"max":50} 		], 	"dataZoom": 		[ 			{ 				"show": false 			} 		], 	"series":  		[			{ 				"name": "Preis", 				"type": "line", 				"color": "#ff0000", 				lineStyle:  					{ 						width: 3, 						type: "solid" 					}, 				"data":  					[35.1,34.5,33.5,33.2,33.3,35,36.8,39.7,41.6,41.3,39.7,38.5,37.8,37.5,38.1,40.3,41,42,42.1,41.8,41,39.6,39.2,38.3,35.6,35.2,34.7,34.4,34.2,34.1,34.2,34.4,34.5,34.5,34,33.6,33.7,33.9,34.4] 			}, 			{ 				"name": "Forecast",tooltip: {show: false},	 				"type": "bar", 				"color": "rgba(255;52;179, 0.2)", 				"barWidth":"100%" , 				"data":  					[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,50,50,50,50,50,50,50,50,50,50,50,50,50,50,50] 			}, 			{ 				"name": "Laden", 	tooltip: {show: false},				"type": "bar", 				"color": "rgba(120, 200, 120, 0.2)", 				"barWidth":"100%" , 				"data":  					[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0] 			} 		] 	}
      jetzt bleibt noch die Frage wo pack ich das rein das ich das auch als Graph angezeigt bekomme, so wie bei dir oder noch besser so wie bei @nograx beide in einem
      • Merlin123
        Merlin123 @icebear last edited by
        @icebear IFrame Widget, als Quelle sowas in der Art (musst halt die IP von Deinem iobroker und den DP am Ende anpassen:
        http://192.168.0.251:8082/flexcharts/echarts.html?source=state&id=0_userdata.0.Tibber_Diagramm_Preis_Forecast_Laden
        icebear 1 Reply Last reply Reply Quote 0
        • icebear
          Geht bei mir nich. Das iframe bleibt leer.
          Ich hab aber glaub ich die Ursache gefunden warum es bei mir nicht funktioniert, es geht nämlich auch nicht wenn ich den Link direkt im Browser eingebe.
          Bei mir läuft über den Port 8082 noch der hm-rpc adapter (für meine CCU3).
          Da muß ich erstmal schauen wie ich das auseinander dividiert bekomme.
          Leider kann man ja bei flexchart adapter den Port nicht selber festlegen auf dem der laufen soll.
          • icebear
            icebear @icebear last edited by
            @icebear
            Problem gelöst. Gefahr erkannt - Gefahr gebannt.
            Bei mir läuft der web.0 Adapter auf Port 8083, dann muß ich natürlich auch in dem Link vom flexchart Adapter den Port 8083 nehmen, und dann funktionierts auch.
            Wenn man sich mal in Ruhe anschaut was da im Log passiert wenn man den flexchart Adapter startet, dann kommt man auch dahinter. Naja jetzt gehts ja und ich kann weiter basteln.
            Merlin123 mcBirne 2 Replies Last reply Reply Quote 1
            • Merlin123
              @icebear Klasse 🙂 Dann viel Spaß beim basteln.
              • icebear
                icebear @nograx last edited by
                @nograx said in TibberLink Adapter:
                Ich lege mir die bei mir übereinander in einen Graphen.
                Kannst du mir zeigen wie du beide Graphen in ein Diagramm bekommen hast?
                nograx 1 Reply Last reply Reply Quote 0
                • nograx
                  nograx Developer @icebear last edited by
                  @icebear sagte in TibberLink Adapter:
                  Ich nutze Lovelace und dort das Apex Chart. Ich schreibe mir das JSON von Tibber und von EnergyForecast in einen State. Diesen formatiere ich dann im ApexChart mit dem data_generator um.
                  • mcBirne
                    mcBirne @icebear last edited by
                    @icebear
                    Ich komme da immer noch nicht weiter. Ich komme mit ip:8082 auf die iobroker Übersicht. Dort kann ich zu Vis Runtime, Vis Editor oder Admin wechseln. Im Vis Editor habe ich dann das iFrame ausgewählt und als Quelle folgende Adresse eingegeben:
                    http://192.168.178.xxx:8082/flexcharts/echarts.html?source=state&id=tibberlink.0.Homes.96bxyz.PricesTotal.jsonFlexCharts
                    Leider erhalte ich die Felermeldung "File echarts.html not found:{}"
                    Hat jemand eine Idee, was ich da falsch mache?
                    • Merlin123
                      Merlin123 @mcBirne last edited by
                      @mcbirne ist echarts installiert?
                      mcBirne 1 Reply Last reply Reply Quote 0
                      • mcBirne
                        mcBirne @Merlin123 last edited by
                        @merlin123
                        Ja, das habe ich installiert
                        • icebear
                          icebear @mcBirne last edited by
                          @mcbirne
                          kann es vielleicht daran liegen?
                          bei gehts nämlich auch nich mit der v4.2.1, ich hab noch nichmal den Ordner 'Prices total' wo das jsonFlexCharts drin liegen soll.
                          • mcBirne
                            mcBirne @icebear last edited by mcBirne
                            @icebear Vielleicht? Aber ich habe den Objektpunkt mit dem FlexChart seitdem ich einen Kanal angelegt habe. Vorher war er nicht da.
                            Allerdings scheint es ja bei einigen zu funktionieren.
                            Merlin123 R 2 Replies Last reply Reply Quote 0
                            • Merlin123
                              @mcbirne Hast Du ein JSON Template reinkopiert? Sonst wird das nix 🙂
                              • mcBirne
                                @merlin123
                                Nein, wo sollte ich was reinkopieren?
                                • Merlin123
                                  @mcbirne sagte in TibberLink Adapter:
                                  @merlin123
                                  Siehe Bild von icebear..... Im Adapter unter "Spezielle Einstellungen" gibt es des JSON Editor und darunter ein Link zu nem Beispiel, dass du einfach kopieren kannst
                                  mcBirne 1 Reply Last reply Reply Quote 1
                                  • mcBirne
                                    @merlin123
                                    Danke für den Tipp. Das werde ich mal testen
                                      ReblausGT Developer @mcBirne last edited by
                                      @mcbirne
                                      Also mit 4.2.1 sollte das in TibberLink Konfig Screen so ausschauen:
                                      Ich habe das deaktiviert für den Release um erst einen Bugfix unter die Leute zu bekommen.... Der Channel Typ Best Block LTF war tot, wenn die einzuschaltende Stunde auf die letzte Stunde des LTF viel....
                                        ReblausGT Developer @ReblausGT last edited by
                                        FYI FlexCharts gibt es jetzt als 0.3.0.... https://github.com/MyHomeMyData/ioBroker.flexcharts
                                          Habe eben die Version 4.3.0-beta1 in GIT gestellt ... jetzt schreibt der TibberLink das JSON für FlexCharts etc... wieder. Auch die Einstellungen für das Template sind wieder da....
                                          Hinweis: Lasst am anfang mal als JSON Template das Standardmäßige ""%%xAxisData%%\n\n%%yAxisData%%\n\n%%CalcChannelsData%%"" drin.... da kann man einmal ganz gut sehen was der Adapter schreibt, bzw. in einem Template austauscht...
                                            ReblausGT Developer @Merlin123 last edited by
                                            @ReblausGT Noch ne andere Frage: Bei Deinem Diagramm ist in der Beschriftung der X-Achse ein Zeilenumbruch. Wie hast Du den hinbekommen?
                                            "\n" in der Beschriftung
                                            593
                                            179452
