    4. BackItUp Adapter jarvis Fehlermeldung
    • chappo59
      chappo59 @simatec last edited by Homoran
      @simatec
      Ich sehe gerade, da hat sich eine Instanz 1 eingeschlichen, die es bei mir gar nicht gibt.
      [DEBUG] [jarvis] Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
      [DEBUG] [jarvis] found Jarvis Instance: 0
      [DEBUG] [jarvis] start Jarvis Backup for Instance 0...
      [DEBUG] [jarvis] Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis1"
      [DEBUG] [jarvis] found Jarvis Instance: 1
      [DEBUG] [jarvis] start Jarvis Backup for Instance 1...
      [DEBUG] [jarvis] /opt/iobroker/iobroker-data/jarvis/0 copy success!
      [DEBUG] [jarvis] Created states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
      [DEBUG] [jarvis] /opt/iobroker/iobroker-data/jarvis/1 copy success!
      [DEBUG] [jarvis] Created states_tmp directory: "/opt/iobroker/backups/tmpJavis1/states"
      [WARN] [jarvis] settings "css" not found
      [WARN] [jarvis] settings "devices" not found
      [WARN] [jarvis] settings "layout" not found
      [WARN] [jarvis] settings "notifications" not found
      [WARN] [jarvis] settings "widgets" not found
      [WARN] [jarvis] settings "scripts" not found
      [WARN] [jarvis] settings "theme" not found
      [WARN] [jarvis] settings "pro" not found
      [DEBUG] [jarvis] Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis1"
      [DEBUG] [jarvis] Jarvis tmp directory "/opt/iobroker/backups/tmpJavis1" successfully deleted
      [DEBUG] [jarvis] Backup created: /opt/iobroker/backups/jarvis.1_2024_11_14-18_13_39_backupiobroker.tar.gz
      [DEBUG] [jarvis] Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
      [DEBUG] [jarvis] Jarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
      [DEBUG] [jarvis] Backup created: /opt/iobroker/backups/jarvis.0_2024_11_14-18_13_39_backupiobroker.tar.gz
      [DEBUG] [jarvis] done
      • simatec
        simatec Developer Most Active @chappo59 last edited by
        @chappo59 Dann lösche mal den Ordner in /iobroker-data und ggfs. die Objekte unter jarvis.1.
        • simatec
          simatec Developer Most Active @el-lutschi last edited by
          @el-lutschi auch bei dir wäre der vollständige Debuglog vom Backup interessant
          chappo59 1 Reply Last reply Reply Quote 0
          • chappo59
            chappo59 @simatec last edited by chappo59
            @simatec Das Objekt jarvis.1 hatte ich gerade kurz zuvor versuchsweise gelöscht. Das brachte keinen Erfolg.
            Des Rätsels Lösung war vermutlich den Ordner "1" unter /iobroker-data/jarvis zu löschen. Jetzt lief das Backup ohne Fehlermeldung durch.
            Herzlichen Dank für die tolle Unterstützung.
            • simatec
              @chappo59 sehr gerne 😉
                gutgut30 last edited by
                Auch ich erhalte die Meldung "[iobroker/jarvis] settings "theme" not found", habe den Eintrag "theme" in den Objekten aber auch nicht. Die Installation ist "frisch".
                Den Eintrag im Adapter anlegen fühlt sich nicht so ganz korrekt an.
                  MCU @gutgut30 last edited by
                  @gutgut30 Ist bei neueren Versionen korrigiert worden.
                  Dort gibt es aber noch andere Probleme, so dass man sich ein Wechsel überlegen, bzw. Issues prüfen sollte.
                    gutgut30 @MCU last edited by
                    @mcu Okay, danke für die Info. Dann warte ich mal ab.
                    Aktuell wird also die Meldung ausgegeben, das Backup aber erstellt?
                      MCU @gutgut30 last edited by MCU
                      @gutgut30 Solange du keine neue jarvis-Version installierst, kannst du auch einen jarvis.0.theme DP anlegen, dann verschwindet die Meldung.
                        "_id": "jarvis.0.theme",
                        "type": "state",
                        "common": {
                          "name": "Theme",
                          "role": "json",
                          "type": "string",
                          "read": true,
                          "write": true,
                          "def": "{}"
                        "from": "system.adapter.jarvis.0",
                        "user": "system.user.admin",
                        "ts": 1734304396000,
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                        sokrates @MCU last edited by
                        @mcu vielen dank, das hat bei mir funktioniert. aber man muss theme klein schreiben. 🙂
                          MCU @sokrates last edited by MCU
                          @sokrates sagte in BackItUp Adapter jarvis Fehlermeldung:
                          Wo ist es groß geschrieben? Oder nur als Hinweis?
                          2040
