    4. Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem
      Homoran Global Moderator Administrators @Dschones last edited by
      @dschones gib mal die Langversion von iob diag preis.
        Dschones @Homoran last edited by
        @homoran said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
        hmm ... das will irgendwie nicht - es kommt immer:
        *** iob diag is starting up, please wait ***
        iob diag needs to be updated. Please execute 'iobroker fix' first.
        Führe ich iobroker fix aus, so läuft folgendes durch, aber das Ergebnis ist das gleiche.
        pi@iobroker-pi:~ $ iobroker fix
        library: loaded
        Library version=2024-10-22
            Welcome to the ioBroker installation fixer!
            Script version: 2024-10-22
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Get:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
        Err:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        Reading package lists... Done
        W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        Installed polkitd
            Checking ioBroker user and directory permissions (2/5)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (5/5)
        ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
        Authentication is required to stop 'iobroker.service'.
        Authenticating as: ,,, (pi)
        Password:
        ==== AUTHENTICATION COMPLETE ===
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        Homoran J 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Dschones last edited by Homoran
          @dschones
          ist das ein Raspi?
          da braucht es im Moment eine Sonderbehandlung
          curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
          chmod 744 iob_diag.sh
          ./iob_diag.sh
            Jaksa @Dschones last edited by
            @dschones said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
            library: loaded
            Installed polkitd
            Done.
            Password:
            Autostart enabled!
            Dein System ist alles nur nicht aktuell. Du hast da noch Debian Bullseye drauf laut den Paketquellen.
            Mach die Karte platt, installiert Debian Bookworm und probiere es dann nochmal.
            • Asgothian
              Asgothian Developer @Dschones last edited by
              @dschones sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
              Die Einstellungen im Adapter sind die folgenden - ich haeb auch schon andere PAN ID's versucht , aber das Problem blieb das gleich
              Das ist auch nicht verwunderlich. Dem Adapter gelingt es nicht mit der Firmware auf dem Stick zu reden. Mögliche Ursachen:
              • Störungen durch USB3 (in welchem Port steckt der Zigbee-Stick ? In einem der USB3 oder einem der USB2, mit oder ohne USB Verlängerung
              • Defekte Firmware auf dem Stick - da wäre dann neu Flaschen angesagt
              • falsche Auswahl der Firmware im Adapter. Welchen Sonoff Dongle hast du genau ?
              A.
              p.s. All dies ist unabhängig von der alten Software auf dem PI4. Ein Update macht sicher Sinn, hat aber mit diesem Problem wenig bis nichts zu tun.
                Dschones @Asgothian last edited by
                @asgothian said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                ohne USB-Verlängerung , ich habe auch schon andere USB-Ports versucht - gleiches Ergebnis
                pi@iobroker-pi:~ $ ls -la /dev/serial/by-id/
                total 0
                drwxr-xr-x 2 root root 80 Jan  2 22:17 .
                drwxr-xr-x 4 root root 80 Jan  2 22:17 ..
                lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEH                                                    P-if00-port0 -> ../../ttyUSB0
                lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                                                    us_902fb787e3e7ed119668d7770b2af5ab-if00-port0 -> ../../ttyUSB1
                ok, das habe ich noch nicht in Betracht zu gezogen, das ding ist ja "frisch"
                hast du da ne gute Anleitung ?
                Hier:
                A.
                Das sehe ich ähnlich - Freunde von mir haben den Stick ebenfalls (auf noch viel älteren System) problemlos am laufen
                Asgothian Codierknecht 2 Replies Last reply Reply Quote 0
                  Dschones @Homoran last edited by Dschones
                  da komme ich nicht weiter:
                  pi@iobroker-pi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.shchmod 744 iob_diag.sh./iob_diag.sh
                    % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                   Dload  Upload   Total   Spent    Left  Speed
                  100 42291  100 42291    0     0   581k      0 --:--:-- --:--:-- --:--:--  581k
                    0     0    0     0    0     0      0      0 --:--:--  0:02:09 --:--:--     0
                  curl: (28) Failed to connect to 744 port 80: Connection timed out
                    0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: iob_diag.sh.
                  • Asgothian
                    Bitte eine USB Verlängerung einsetzen, damit der Stick vom PI weg kommt - ich denke da gibt es Störungen aus dem USB3 Bereich. Nutzt Du ggf. eine SSD ?
                    A.
                      bitte die Befehle nicht verschmelzen
                        @asgothian
                        Usb- Verlängerung ist drin , Problem ist dasselbe
                          da tut sich leider nix
                          100 42291  100 42291    0     0   522k      0 --:--:-- --:--:-- --:--:--  522k
                           0     0    0     0    0     0      0      0 --:--:--  0:00:24 --:--:--     0
                           0     0    0     0    0     0      0      0 --:--:--  0:02:11 --:--:--     0
                          was mache ich falsch ?
                          Homoran Meister Mopper 2 Replies Last reply Reply Quote 0
                            du hast immer noch 2 Befehle verschmolzen!
                            sieh dir die drei einzelnen Befehle mal hier an
                            @homoran sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                            @dschones
                            ist das ein Raspi?
                            ./iob_diag.sh
                            • Meister Mopper
                              Meister Mopper @Dschones last edited by
                              @dschones
                              Du kannst das nicht einfach ins Clipboard kopieren und in der Konsole ausführen, denn es sind drei Befehle.
                              Du kannst sie allerdings mit && verbinden und dann in der Konsole ausführen. Dann wird der nächste Befehl erst ausgeführt, wenn der vorherige abgeschlossen ist.
                              z. B.
                              curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh && chmod 744 && iob_diag.sh && ./iob_diag.sh
                                sorry - ich bin da noch etwas zu ungeübt und unerfahren
                                hier das Ergebnis
                                                        v.2024-12-09 Raspbian+zigbee diag+masking
                                   Static hostname: iobroker-pi
                                         Icon name: computer
                                  Operating System: Raspbian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 6.1.21-v7l+
                                      Architecture: arm
                                Installation:           native
                                Kernel:                 armv7l
                                Userland:               32 bit
                                Timezone:               Europe/Berlin (CET, +0100)
                                User-ID:                1000
                                Display-Server:         false
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0
                                Pending iob updates:    23
                                Nodejs-Installation:
                                /usr/bin/nodejs         v20.18.1
                                /usr/bin/node           v20.18.1
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                /usr/bin/corepack       0.29.4
                                Recommended versions are nodejs 20.18.1 and npm 10.8.2
                                nodeJS installation is correct
                                MEMORY:
                                Mem:            3.9G        1.1G        2.1G        0.0K        697M        2.6G
                                Swap:            99M          0B         99M
                                Total:          4.0G        1.1G        2.2G
                                Active iob-Instances:   18
                                Upgrade policy: none
                                ioBroker Core:          js-controller           7.0.6
                                                        admin                   7.1.5
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                9605
                                States:                 8668
                                Size of iob-Database:
                                15M     /opt/iobroker/iobroker-data/objects.jsonl
                                2.8M    /opt/iobroker/iobroker-data/states.jsonl
                                Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                  hier das Ergebnis
                                  das ist leider nur das Summary!
                                  bitte die Langfassung, die kommt vorher.
                                  • Meister Mopper
                                    Bevor weitere geriatrische Analysen durchgeführt werden, solltest du nach meiner Meinung auf bookworm wechseln und zwar in der minimalen 64Bit-Version.
                                    Hast du aktuelle, funktionierende Backups mit dem backitup-Adapter außerhalb des ioBroker gesichert?
                                      Script v.2024-12-09 Raspbian+zigbee diag+masking
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm
                                      OS is similar to: debian
                                      Model           : Raspberry Pi 4 Model B Rev 1.5
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : armv7l
                                      Userland        : 32 bit
                                      Systemuptime and Load:
                                       16:56:37 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
                                      CPU threads: 4
                                      *** LIFE CYCLE STATUS ***
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** TIME AND TIMEZONES ***
                                                     Local time: Sat 2025-01-11 16:56:38 CET
                                                 Universal time: Sat 2025-01-11 15:56:38 UTC
                                                       RTC time: Sat 2025-01-11 15:56:38
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                      *** DISPLAY-SERVER SETUP ***
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.9G        1.1G        1.8G        0.0K        982M        2.6G
                                      Swap:            99M          0B         99M
                                      Total:          4.0G        1.1G        1.9G
                                               3887 M total memory
                                               1106 M used memory
                                                464 M active memory
                                               1500 M inactive memory
                                               1799 M free memory
                                                113 M buffer memory
                                                868 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      top - 16:56:38 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
                                      Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us,  3.0 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3887.9 total,   1799.4 free,   1105.6 used,    982.9 buff/cache
                                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2641.8 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       58G  7.2G   49G  13% /
                                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                      tmpfs          tmpfs     778M  876K  777M   1% /run
                                      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                      tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                      Show mounted filesystems:
                                      TARGET  SOURCE         FSTYPE OPTIONS
                                      /       /dev/mmcblk0p2 ext4   rw,noatime
                                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                      /var:
                                      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                      3.3G    /var/
                                      1.9G    /var/log
                                      1.8G    /var/log/journal/834f3657738944fca3e7840589ae9346
                                      755M    /var/cache
                                      Archived and active journals take up 1.7G in the file system.
                                      /opt/iobroker/backups:
                                      402M    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      198M    /opt/iobroker/iobroker-data/
                                      132M    /opt/iobroker/iobroker-data/files
                                      49M     /opt/iobroker/iobroker-data/backup-objects
                                      48M     /opt/iobroker/iobroker-data/files/javascript.admin
                                      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
                                      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                                      6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
                                      6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
                                      /dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEHP-if00-port0
                                      *** ZigBee Settings ***
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      Zigbee Network Settings on your coordinator/in nvbackup are:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      To unmask the settings run 'iob diag --unmask'
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Installed: 20.18.1-1nodesource1
                                        Candidate: 20.18.1-1nodesource1
                                        Version table:
                                       *** 20.18.1-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                              100 /var/lib/dpkg/status
                                           20.18.0-1nodesource1 1001
                                           20.17.0-1nodesource1 1001
                                           20.16.0-1nodesource1 1001
                                           20.15.1-1nodesource1 1001
                                           20.15.0-1nodesource1 1001
                                           20.14.0-1nodesource1 1001
                                           20.13.1-1nodesource1 1001
                                           20.13.0-1nodesource1 1001
                                           20.12.2-1nodesource1 1001
                                           20.12.1-1nodesource1 1001
                                           20.12.0-1nodesource1 1001
                                           20.11.1-1nodesource1 1001
                                           20.11.0-1nodesource1 1001
                                           20.10.0-1nodesource1 1001
                                           20.9.0-1nodesource1 1001
                                           20.8.1-1nodesource1 1001
                                           20.8.0-1nodesource1 1001
                                           20.7.0-1nodesource1 1001
                                           20.6.1-1nodesource1 1001
                                           20.6.0-1nodesource1 1001
                                           20.5.1-1nodesource1 1001
                                           20.5.0-1nodesource1 1001
                                           20.4.0-1nodesource1 1001
                                           20.3.1-1nodesource1 1001
                                           20.3.0-1nodesource1 1001
                                           20.2.0-1nodesource1 1001
                                           20.1.0-1nodesource1 1001
                                           20.0.0-1nodesource1 1001
                                           12.22.12~dfsg-1~deb11u5 500
                                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker-pi         iobroker-pi (version: 7.0.6, hostname: iobroker-pi   , alive, uptime: 673253)
                                      Core adapters versions
                                      js-controller:  7.0.6
                                      admin:          7.1.5
                                      javascript:     6.0.3
                                      nodejs modules from github:     0
                                      Adapter State
                                      + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                        system.adapter.daswetter.0              : daswetter             : iobroker-pi                              -  enabled
                                        system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                      + system.adapter.fronius.0                : fronius               : iobroker-pi                              -  enabled
                                        system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                      + system.adapter.hm-rega.1                : hm-rega               : iobroker-pi                              -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                      + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                        system.adapter.modbus.0                 : modbus                : iobroker-pi                              - disabled
                                      + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
                                      + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                        system.adapter.sayit.0                  : sayit                 : iobroker-pi                              -  enabled
                                      + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.smartmeter.0             : smartmeter            : iobroker-pi                              -  enabled
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
                                      + system.adapter.terminal.0               : terminal              : iobroker-pi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      + system.adapter.velux.0                  : velux                 : iobroker-pi                              -  enabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
                                        system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
                                      + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 7.4.10   , installed 7.1.5  [Updatable]
                                      Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
                                      Adapter    "daswetter"    : 3.2.2    , installed 3.1.3  [Updatable]
                                      Adapter    "discovery"    : 5.0.0    , installed 3.0.5  [Updatable]
                                      Adapter    "fronius"      : 2.1.1    , installed 2.0.2  [Updatable]
                                      Adapter    "history"      : 3.0.1    , installed 2.2.0  [Updatable]
                                      Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                                      Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
                                      Adapter    "javascript"   : 8.8.3    , installed 6.0.3  [Updatable]
                                      Controller "js-controller": 7.0.6    , installed 7.0.6
                                      Adapter    "modbus"       : 6.3.2    , installed 5.0.11 [Updatable]
                                      Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                                      Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                                      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                                      Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
                                      Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
                                      Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
                                      Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
                                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                      Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
                                      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                      Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                      Adapter    "velux"        : 0.0.8    , installed 0.0.7  [Updatable]
                                      Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
                                      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                                      Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
                                      Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
                                      Adapter    "zigbee"       : 1.10.14  , installed 1.10.13 [Updatable]
                                      Objects and States
                                      Objects:        9605
                                      States:         8668
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 192.168.178.50:18701    0.0.0.0:*               LISTEN      1001       1161594    6723/io.hm-rpc.1
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1264871    20308/io.sonoff.0
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1160161    6800/io.shelly.0
                                      tcp        0      0 192.168.178.50:2010     0.0.0.0:*               LISTEN      1001       1159103    6518/io.hm-rpc.0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16436      968/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1158040    6374/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1158045    6374/iobroker.js-co
                                      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14656      1013/dnsmasq
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1160707    6397/io.admin.0
                                      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1161918    7217/io.terminal.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          16438      968/sshd: /usr/sbin
                                      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14655      1013/dnsmasq
                                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14652      1013/dnsmasq
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12249      808/dhclient
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11089      406/avahi-daemon: r
                                      udp        0      0 0.0.0.0:38251           0.0.0.0:*                           108        11091      406/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        11090      406/avahi-daemon: r
                                      udp6       0      0 :::35121                :::*                                108        11092      406/avahi-daemon: r
                                      2025-01-11 16:13:12.167  - info: host.iobroker-pi instance system.adapter.velux.0 in version "0.0.7" started with pid 31891
                                      2025-01-11 16:13:14.688  - info: velux.0 (31891) starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.velux, node: v20.18.1, js-controller: 7.0.6
                                      2025-01-11 16:13:14.999  - error: velux.0 (31891) null
                                      2025-01-11 16:13:15.004  - error: velux.0 (31891) Login was not successful
                                      2025-01-11 16:15:54.022  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 32127
                                      2025-01-11 16:15:56.927  - info: daswetter.0 (32127) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                      2025-01-11 16:16:11.263  - info: daswetter.0 (32127) still wrong data structure from server received! repaired...
                                      2025-01-11 16:16:15.476  - info: daswetter.0 (32127) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                      2025-01-11 16:16:15.997  - info: daswetter.0 (32127) cleaned everything up...
                                      2025-01-11 16:16:16.015  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 32127 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2025-01-11 16:30:54.025  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 899
                                      2025-01-11 16:30:56.939  - info: daswetter.0 (899) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                      2025-01-11 16:31:11.118  - info: daswetter.0 (899) still wrong data structure from server received! repaired...
                                      2025-01-11 16:31:15.240  - info: daswetter.0 (899) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                      2025-01-11 16:31:15.755  - info: daswetter.0 (899) cleaned everything up...
                                      2025-01-11 16:31:15.772  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 899 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2025-01-11 16:45:54.020  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 3933
                                      2025-01-11 16:45:56.966  - info: daswetter.0 (3933) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                      2025-01-11 16:46:11.024  - info: daswetter.0 (3933) still wrong data structure from server received! repaired...
                                      2025-01-11 16:46:15.423  - info: daswetter.0 (3933) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                      2025-01-11 16:46:15.941  - info: daswetter.0 (3933) cleaned everything up...
                                      2025-01-11 16:46:15.958  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 3933 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2025-01-11 16:51:25.964  - info: admin.0 (6397) Request actual repository...
                                      2025-01-11 16:51:26.593  - info: host.iobroker-pi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                      2025-01-11 16:51:31.666  - info: admin.0 (6397) Repository received successfully.
                                      • Meister Mopper
                                        @dschones
                                        Ich würde die vielen Adapter-Upgrades durchführen, eine backitup-Sicherung durchführen und diese extern sichern. Anschließend würde ich das System mit dem aktuellen Debian 12.9 neu aufsetzen (wie oben beschrieben).
                                        Alles andere ist vermeidbare Mehrarbeit.
                                        Danach kann man das Zigbee-Problem angehen.
                                          Dschones @Meister Mopper last edited by
                                          @meister-mopper
                                          die Updates der Adapter habe ich durchgeführt, das Upgrade auf die neuste Debin-Version scheue ich aktuell weil ich noch nicht weis ob und wie ich das system wieder soaufgesetzt bekommne. Da ist auch u.a. eine Homematic - Version drauf mit der ich meine Heuzung steuere, wäre doof wenn das nun im Winter nicht mehr klappt.
                                          gibt es keine andere Möglichkeit ?
                                          • Asgothian
                                            Du kannst den Hinweis erst einmal ignorieren - ich gehe eher nicht davon aus das die Probleme mit dem Sonoff an der OS Version hängen. eher ist denkbar das der Stick / die firmware defekt ist.
                                            Insbesondere wenn USB Verlängerung etc. nichts gebracht haben.
                                            Also Firmware neu flashen, neu versuchen.
                                            Bevor die Diskussion los geht: Hier geht es mir nicht darum ob es sinnvoll ist das System zu aktualisieren, sondern ob das relevant für den beschriebenen Fehler ist. Das ist es sicher nicht. Ich habe die längste Zeit ein solches System selber betrieben - es funktioniert.
                                            A.
                                            B D 2 Replies Last reply Reply Quote 0
                                            1831
