    4. Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem
    • Meister Mopper
      Meister Mopper @Dschones last edited by
      @dschones sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      Bevor weitere geriatrische Analysen durchgeführt werden, solltest du nach meiner Meinung auf bookworm wechseln und zwar in der minimalen 64Bit-Version.
      Hast du aktuelle, funktionierende Backups mit dem backitup-Adapter außerhalb des ioBroker gesichert?
        Dschones @Homoran last edited by
        Script v.2024-12-09 Raspbian+zigbee diag+masking
        *** BASE SYSTEM ***
           Static hostname: iobroker-pi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v7l+
              Architecture: arm
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         16:56:37 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Sat 2025-01-11 16:56:38 CET
                   Universal time: Sat 2025-01-11 15:56:38 UTC
                         RTC time: Sat 2025-01-11 15:56:38
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.9G        1.1G        1.8G        0.0K        982M        2.6G
        Swap:            99M          0B         99M
        Total:          4.0G        1.1G        1.9G
        Active iob-Instances:   18
                 3887 M total memory
                 1106 M used memory
                  464 M active memory
                 1500 M inactive memory
                 1799 M free memory
                  113 M buffer memory
                  868 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 16:56:38 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
        Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  3.0 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3887.9 total,   1799.4 free,   1105.6 used,    982.9 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2641.8 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       58G  7.2G   49G  13% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     778M  876K  777M   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
        3.3G    /var/
        1.9G    /var/log
        1.8G    /var/log/journal/834f3657738944fca3e7840589ae9346
        755M    /var/cache
        Archived and active journals take up 1.7G in the file system.
        /opt/iobroker/backups:
        402M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        198M    /opt/iobroker/iobroker-data/
        132M    /opt/iobroker/iobroker-data/files
        49M     /opt/iobroker/iobroker-data/backup-objects
        48M     /opt/iobroker/iobroker-data/files/javascript.admin
        32M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        15M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
        6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
        6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
        /dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEHP-if00-port0
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u5 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker-pi         iobroker-pi (version: 7.0.6, hostname: iobroker-pi   , alive, uptime: 673253)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.1.5
        javascript:     6.0.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker-pi                              -  enabled
          system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
        + system.adapter.fronius.0                : fronius               : iobroker-pi                              -  enabled
          system.adapter.history.0                : history               : iobroker-pi                              -  enabled
        + system.adapter.hm-rega.1                : hm-rega               : iobroker-pi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
        + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
          system.adapter.modbus.0                 : modbus                : iobroker-pi                              - disabled
        + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
        + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
          system.adapter.sayit.0                  : sayit                 : iobroker-pi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartmeter.0             : smartmeter            : iobroker-pi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
        + system.adapter.terminal.0               : terminal              : iobroker-pi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.velux.0                  : velux                 : iobroker-pi                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
          system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
          system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.1.5  [Updatable]
        Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
        Adapter    "daswetter"    : 3.2.2    , installed 3.1.3  [Updatable]
        Adapter    "discovery"    : 5.0.0    , installed 3.0.5  [Updatable]
        Adapter    "fronius"      : 2.1.1    , installed 2.0.2  [Updatable]
        Adapter    "history"      : 3.0.1    , installed 2.2.0  [Updatable]
        Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
        Adapter    "javascript"   : 8.8.3    , installed 6.0.3  [Updatable]
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "modbus"       : 6.3.2    , installed 5.0.11 [Updatable]
        Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
        Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
        Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
        Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
        Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "velux"        : 0.0.8    , installed 0.0.7  [Updatable]
        Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
        Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
        Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
        Adapter    "zigbee"       : 1.10.14  , installed 1.10.13 [Updatable]
        Objects and States
        Objects:        9605
        States:         8668
        W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.50:18701    0.0.0.0:*               LISTEN      1001       1161594    6723/io.hm-rpc.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1264871    20308/io.sonoff.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1160161    6800/io.shelly.0
        tcp        0      0 192.168.178.50:2010     0.0.0.0:*               LISTEN      1001       1159103    6518/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16436      968/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1158040    6374/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1158045    6374/iobroker.js-co
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14656      1013/dnsmasq
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1160707    6397/io.admin.0
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1161918    7217/io.terminal.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16438      968/sshd: /usr/sbin
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14655      1013/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14652      1013/dnsmasq
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12249      808/dhclient
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11089      406/avahi-daemon: r
        udp        0      0 0.0.0.0:38251           0.0.0.0:*                           108        11091      406/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        11090      406/avahi-daemon: r
        udp6       0      0 :::35121                :::*                                108        11092      406/avahi-daemon: r
        2025-01-11 16:13:12.167  - info: host.iobroker-pi instance system.adapter.velux.0 in version "0.0.7" started with pid 31891
        2025-01-11 16:13:14.688  - info: velux.0 (31891) starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.velux, node: v20.18.1, js-controller: 7.0.6
        2025-01-11 16:13:14.999  - error: velux.0 (31891) null
        2025-01-11 16:13:15.004  - error: velux.0 (31891) Login was not successful
        2025-01-11 16:15:54.022  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 32127
        2025-01-11 16:15:56.927  - info: daswetter.0 (32127) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
        2025-01-11 16:16:11.263  - info: daswetter.0 (32127) still wrong data structure from server received! repaired...
        2025-01-11 16:16:15.476  - info: daswetter.0 (32127) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-01-11 16:16:15.997  - info: daswetter.0 (32127) cleaned everything up...
        2025-01-11 16:16:16.015  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 32127 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-01-11 16:30:54.025  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 899
        2025-01-11 16:30:56.939  - info: daswetter.0 (899) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
        2025-01-11 16:31:11.118  - info: daswetter.0 (899) still wrong data structure from server received! repaired...
        2025-01-11 16:31:15.240  - info: daswetter.0 (899) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-01-11 16:31:15.755  - info: daswetter.0 (899) cleaned everything up...
        2025-01-11 16:31:15.772  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 899 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-01-11 16:45:54.020  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 3933
        2025-01-11 16:45:56.966  - info: daswetter.0 (3933) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
        2025-01-11 16:46:11.024  - info: daswetter.0 (3933) still wrong data structure from server received! repaired...
        2025-01-11 16:46:15.423  - info: daswetter.0 (3933) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-01-11 16:46:15.941  - info: daswetter.0 (3933) cleaned everything up...
        2025-01-11 16:46:15.958  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 3933 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-01-11 16:51:25.964  - info: admin.0 (6397) Request actual repository...
        2025-01-11 16:51:26.593  - info: host.iobroker-pi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2025-01-11 16:51:31.666  - info: admin.0 (6397) Repository received successfully.
        • Meister Mopper
          @dschones
          Ich würde die vielen Adapter-Upgrades durchführen, eine backitup-Sicherung durchführen und diese extern sichern. Anschließend würde ich das System mit dem aktuellen Debian 12.9 neu aufsetzen (wie oben beschrieben).
          Alles andere ist vermeidbare Mehrarbeit.
          Danach kann man das Zigbee-Problem angehen.
            Dschones @Meister Mopper last edited by
            @meister-mopper
            die Updates der Adapter habe ich durchgeführt, das Upgrade auf die neuste Debin-Version scheue ich aktuell weil ich noch nicht weis ob und wie ich das system wieder soaufgesetzt bekommne. Da ist auch u.a. eine Homematic - Version drauf mit der ich meine Heuzung steuere, wäre doof wenn das nun im Winter nicht mehr klappt.
            gibt es keine andere Möglichkeit ?
            • Asgothian
              Asgothian Developer @Dschones last edited by
              Du kannst den Hinweis erst einmal ignorieren - ich gehe eher nicht davon aus das die Probleme mit dem Sonoff an der OS Version hängen. eher ist denkbar das der Stick / die firmware defekt ist.
              Insbesondere wenn USB Verlängerung etc. nichts gebracht haben.
              Also Firmware neu flashen, neu versuchen.
              Bevor die Diskussion los geht: Hier geht es mir nicht darum ob es sinnvoll ist das System zu aktualisieren, sondern ob das relevant für den beschriebenen Fehler ist. Das ist es sicher nicht. Ich habe die längste Zeit ein solches System selber betrieben - es funktioniert.
              A.
              B D 2 Replies Last reply Reply Quote 0
                bommel @Asgothian last edited by bommel
                Das gleiche Chaos hatte ich auch neulich...
                Letztendlich: iobroker runter (war strubbelich..) , neu drauf, vorher den Sonoff USB-Dongle mit der 7-er Firmware versehen
                Unnu? Alles löppt wie Pavoo.
                Firmware flashen via Web (https://darkxst.github.io/silabs-firmware-builder/) ging super, nachdem ich temporär die Rechte für ttyACM0 frei gesetzt hatte.
                Die Geräte waren nach 20 min. neu angelernt, so groß ist meine Hütte nicht.
                Gruß, Bommel
                  Thomas Braun Most Active @bommel last edited by Thomas Braun
                  @bommel sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                  Du hättest besser den user in die passende Gruppe gepackt.
                  Nachschauen wie die Rechte da vom Treiber/Kernel vergeben werden, ist aber i.d.R. entweder dialup oder plugdevices
                  • Codierknecht
                    Codierknecht Developer Most Active @Dschones last edited by
                    Freunde von mir haben den Stick ebenfalls (auf noch viel älteren System) problemlos am laufen
                    Schönen Gruß an die Freunde. Auch die sollten sich zeitnah um Systemupdates kümmern.
                    "never change a running system" funktioniert nicht.
                      bommel @Thomas Braun last edited by
                      @thomas-braun said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                      Hatte gelesen, daß dialup diejenige sei, in der war ich.
                      Dann wars wahrscheinlich plugdevices...
                        Schau es halt nach...
                        ls -l /dev/ttyACM0
                        Und so ganz grundsätzlich verwendet man die Gerätedateien auch nicht direkt sonder nur über die Links 'by-id' beispielsweise.
                          Dschones @Asgothian last edited by
                          @asgothian
                          Nur um euch auf dem laufenden zu halten: Der Sonoff Sitck hat (nach vielen Rückschlägen (bootloader wollte nicht)) eine neue Firmware, aber das Problem ist 1:1 das gleiche. Es gibt keine erkennbare Veränderung.
                          Mir reichts nun etwas und auf den aktuellen Stick (ZBDongle-P) habe ich keine Lust mehr- daher habe ich mir einen neuen(ZBDongle-E) bestellt- der kommt anfang kommender woche. Dann versuche ich es erneut.
                          Ggf. Mache ich vorab auch gleich prophylaktisch die neue Firmware drauf.
                            Dschones @Dschones last edited by
                            Update: Es schaut nicht gut aus
                            Neuer Stick ist gekauft , mit neuster Firmeware geflashed und das Problem ist das nahezu das gleiche ...
                            Hier der Log:
                            2025-01-21 21:21:15.638 - info: host.iobroker-pi "system.adapter.zigbee.0" disabled
                            2025-01-21 21:21:15.639 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2025-01-21 21:21:15.645 - info: zigbee.0 (9841) Got terminate signal TERMINATE_YOURSELF
                            2025-01-21 21:21:15.648 - info: zigbee.0 (9841) cleaned everything up...
                            2025-01-21 21:21:15.651 - info: zigbee.0 (9841) Zigbee: disabling joining new devices.
                            2025-01-21 21:21:15.659 - info: zigbee.0 (9841) terminating
                            2025-01-21 21:21:15.661 - info: zigbee.0 (9841) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2025-01-21 21:21:15.692 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 send kill signal
                            2025-01-21 21:21:16.148 - info: zigbee.0 (9841) terminating
                            2025-01-21 21:21:16.249 - info: host.iobroker-pi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2025-01-21 21:21:21.092 - info: host.iobroker-pi "system.adapter.zigbee.0" enabled
                            2025-01-21 21:21:21.812 - info: host.iobroker-pi instance system.adapter.zigbee.0 in version "1.10.14" started with pid 12553
                            2025-01-21 21:21:27.109 - info: zigbee.0 (12553) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
                            2025-01-21 21:21:27.206 - info: zigbee.0 (12553) delete old Backup files. keep only last 10
                            2025-01-21 21:21:27.209 - info: zigbee.0 (12553) Starting Zigbee npm ...
                            2025-01-21 21:21:27.547 - info: zigbee.0 (12553) Installed Version: iobroker.zigbee@1.10.14
                            2025-01-21 21:21:48.223 - error: zigbee.0 (12553) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2025-01-21 21:21:48.224 - error: zigbee.0 (12553) Failed to start Zigbee
                            2025-01-21 21:21:48.224 - error: zigbee.0 (12553) Error herdsman start
                            2025-01-21 21:21:58.228 - info: zigbee.0 (12553) Try to reconnect. 1 attempts left
                            2025-01-21 21:21:58.229 - info: zigbee.0 (12553) Starting Zigbee npm ...
                            2025-01-21 21:21:58.243 - info: zigbee.0 (12553) Installed Version: iobroker.zigbee@1.10.14
                            2025-01-21 21:21:58.410 - error: zigbee.0 (12553) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                            2025-01-21 21:21:58.411 - error: zigbee.0 (12553) Failed to start Zigbee
                            2025-01-21 21:21:58.412 - error: zigbee.0 (12553) Error herdsman start
                            was nun ?
                            • Asgothian
                              Asgothian Developer @Dschones last edited by Asgothian
                              was nun ?
                              • Hast du die Einstellungen angepasst (EZSP firmware statt TI firmware ?)
                              • hast du shepherd.db und nvbackup.json beseitigt ?
                              A.
                                @asgothian said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                                was nun ?
                                A.
                                Sorry für die späte Antwort - war beruflich länger weg
                                Neuer Stick ist da - Firmeware ist geflashed
                                --> Zigbee (EZSP) 7.4.5.0 build 0
                                shepherd.db und nvbackup.json sind nicht "beseitigt" , da es bei mir immer heißt "existiert nicht"
                                pi@iobroker-pi:~ $ rm opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                                rm: cannot remove 'opt/iobroker/iobroker-data/zigbee_0/nvbackup.json': No such file or directory
                                ansonsten ist das Problem 1:1 das gleiche wie immer ... der Log sieht noch 1:1 aus wie oben
                                • Asgothian
                                  Bist du 100% sicher das die Meldung die gleiche ist ? Insbesondere das diese Meldung kommt:
                                  Wenn ja, dann passt etwas nicht mit dem USB Port bzw. den Treibern. Hast du versucht einen anderen Port zu wählen ?
                                  Also sind sie beseitigt - es gibt keine. Das war der Ziel-Zustand.
                                  Aktuell muss ich dich wahrscheinlich 2 bis 3 Tage vertrösten, dann kann ich Dir eine aktualisierte Version des Adapters zum Testen anbieten - für den Fall das es Probleme zwischen Herdsman und Stick gibt. Die ist aber aktuell noch in Arbeit.
                                  A.
                                    Dschones @Asgothian last edited by Dschones
                                    @asgothian
                                    alos ich habe alle 4 Ports durchprobiert - das ergebis war das gleiche
                                    zigbee.0
                                    	2025-02-23 12:46:12.986	error	Error herdsman start
                                    zigbee.0
                                    	2025-02-23 12:46:12.985	error	Failed to start Zigbee
                                    zigbee.0
                                    	2025-02-23 12:46:12.984	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                                    zigbee.0
                                    	2025-02-23 12:46:12.837	info	Installed Version: iobroker.zigbee@1.10.14
                                    zigbee.0
                                    	2025-02-23 12:46:12.823	info	Starting Zigbee npm ...
                                    zigbee.0
                                    	2025-02-23 12:46:12.822	info	Try to reconnect. 1 attempts left
                                    zigbee.0
                                    	2025-02-23 12:46:02.819	error	Error herdsman start
                                    zigbee.0
                                    	2025-02-23 12:46:02.818	error	Failed to start Zigbee
                                    zigbee.0
                                    	2025-02-23 12:46:02.817	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                    zigbee.0
                                    	2025-02-23 12:45:42.254	info	Installed Version: iobroker.zigbee@1.10.14
                                    zigbee.0
                                    	2025-02-23 12:45:41.875	info	Starting Zigbee npm ...
                                    zigbee.0
                                    	2025-02-23 12:45:41.873	info	delete old Backup files. keep only last 10
                                    zigbee.0
                                    	2025-02-23 12:45:41.746	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
                                    zigbee.0
                                    	2025-02-23 12:45:31.660	info	terminating
                                    zigbee.0
                                    	2025-02-23 12:45:31.171	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    zigbee.0
                                    	2025-02-23 12:45:31.169	info	terminating
                                    zigbee.0
                                    	2025-02-23 12:45:31.162	info	Zigbee: disabling joining new devices.
                                    zigbee.0
                                    	2025-02-23 12:45:31.158	info	cleaned everything up...
                                    zigbee.0
                                    	2025-02-23 12:45:31.156	info	Got terminate signal TERMINATE_YOURSELF
                                    zigbee.0
                                    	2025-02-23 12:45:21.917	info	Installed Version: iobroker.zigbee@1.10.14
                                    zigbee.0
                                    	2025-02-23 12:45:21.529	info	Starting Zigbee npm ...
                                    zigbee.0
                                    	2025-02-23 12:45:21.527	info	delete old Backup files. keep only last 10
                                    zigbee.0
                                    	2025-02-23 12:45:21.388	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
                                    zigbee.0
                                    	2025-02-23 12:45:21.267	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"3c357f1f8439ef1193585df454516304","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_3c357f1f8439ef1193585df454516304-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"}]
                                    zigbee.0
                                    	2025-02-23 12:45:10.886	info	terminating
                                    zigbee.0
                                    	2025-02-23 12:45:10.394	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    zigbee.0
                                    	2025-02-23 12:45:10.393	info	terminating
                                    was genau ist denn dieses Herdsman ? ich finde dazu im Netz nix wirklich detailiertes
                                    • Asgothian
                                      der Zigbee-Herdsman ist die Bibliothek die für die Kommunikation mit der Firmware auf dem Stick verantwortlich ist. Die Fehlermeldung deutet darauf hin das keine Kommunikation zur Firmware aufgebaut werden kann.
                                      Da das prinzipiell geht (sonst wäre das Forum voll mit Beschwerden das der Zigbee-Adapter nicht geht) muss etwas auf Deinem System nicht OK sein.
                                      Relevant dafür ist diese Meldung:
                                      Alles weitere, auch das mit dem unable to lock port sind Folgefehler die aus dieser einen Meldung resultieren.
                                      Wenn ich den Thread richtig zusammenfasse:
                                      • du hast einen anderen Stick probiert - gleiche Meldung
                                      • du hast andere Firmware probiert - gleiche Meldung
                                      • du hast das OS aktualisiert - gleiche Meldung
                                      Bleibt ggf. noch ein hardware-Defekt im USB Bereich ? Hast du die Möglichkeit auf einem anderen Rechner zum testen einen ioBroker zu installieren und zu schauen ob der Zigbee-Adapter da startet ? Ansonsten gehen mir leider die Ideen aus.
                                      A.
                                        @asgothian
                                        einer der USB-Port war (irgendwann habe ich den weg, damit es nicht ggf. daran liegen könnte) mit einem enocean gateway verbunden, dieser hat bisher auch immer hervorragend funktioniert .
                                        welche möglichkeiten gibt es die USB-Port zu testen?
                                          Dschones @Dschones last edited by Dschones
                                          Update:
                                          ich habe nun damit ich möglichst viele Fehlerquellen ausschließe mir kurzerhand nen nietnagelneuen RaspberryPi 5 (4GB) zugelegt und darauf auch die neueste Version des Betriebssystems draufgespielt.
                                          dazu gab es einen neuen Sonoff Zigbee Stick welchen ich auch passend der Anleitungen geflasht habe.
                                          und .... das Problem ist immer noch da . Da ich nun Hardware oder Betriebssystem-Probleme ausgeschlossen habe --> woran könnte es noch liegen ?
                                          hier der Log:
                                          2025-03-15 13:59:25.966 - info: zigbee.0 (1564) terminating
                                          2025-03-15 13:59:26.000 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2025-03-15 13:59:29.166 - info: host.raspberrypi instance system.adapter.zigbee.0 in version "1.10.14" started with pid 1682
                                          2025-03-15 13:59:30.683 - info: zigbee.0 (1682) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                                          2025-03-15 13:59:30.717 - info: zigbee.0 (1682) delete old Backup files. keep only last 10
                                          2025-03-15 13:59:30.718 - info: zigbee.0 (1682) Starting Zigbee npm ...
                                          2025-03-15 13:59:30.839 - info: zigbee.0 (1682) Installed Version: iobroker.zigbee@1.10.14
                                          2025-03-15 13:59:51.069 - error: zigbee.0 (1682) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                          2025-03-15 13:59:51.070 - error: zigbee.0 (1682) Failed to start Zigbee
                                          2025-03-15 13:59:51.070 - error: zigbee.0 (1682) Error herdsman start
                                          2025-03-15 14:00:01.071 - info: zigbee.0 (1682) Try to reconnect. 1 attempts left
                                          2025-03-15 14:00:01.072 - info: zigbee.0 (1682) Starting Zigbee npm ...
                                          2025-03-15 14:00:01.079 - info: zigbee.0 (1682) Installed Version: iobroker.zigbee@1.10.14
                                          2025-03-15 14:00:01.161 - error: zigbee.0 (1682) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                                          2025-03-15 14:00:01.162 - error: zigbee.0 (1682) Failed to start Zigbee
                                          2025-03-15 14:00:01.162 - error: zigbee.0 (1682) Error herdsman start
                                          Hier die Adaptereinstellungen
                                            wie währe es wenn du den Adapter richtig einstellst
                                            für EZSP
                                            Thomas Braun D 2 Replies Last reply Reply Quote 1
                                            1834
