    4. Fehler Nach update Judo soft Adapter
    • marcel-drzal
      marcel-drzal last edited by
      Nach update Fehlermeldung im Judo Soft Adapter
      Bitte um Hilfe Danke
      ed063ce9-2917-443e-a8dd-cbd4da1a9ad5-image.png code_text
      2025-01-13 20:49:07.825 - info: judoisoft.0 (1334) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
      2025-01-13 20:49:07.825 - info: judoisoft.0 (1334) terminating
      2025-01-13 20:49:07.826 - info: judoisoft.0 (1334) Terminated (NO_ERROR): Without reason
      2025-01-13 20:49:08.326 - info: judoisoft.0 (1334) terminating
      2025-01-13 20:49:08.349 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
      2025-01-13 20:49:08.349 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
      2025-01-13 20:49:09.285 - info: influxdb.0 (442) Do not store value "{"Time":"2025-01-13T20:49:08","Haus":{"Tariflos":18648.6654,"Power_cur":2560,"Power_p1":184,"Power_p2":158,"Power_p3":2217},"Heizung":{"Tariflos":9223.6689,"Power_cur":1300,"Power_p1":2,"Power_p2":0,"Power_p3":1298}}" for StromHaus because no number
      2025-01-13 20:49:12.502 - info: admin.0 (346) ==> Connected system.user.admin from ::ffff:172.16.0.166
      2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: {"Time":"2025-01-13T20:49:12","Switch1":"OFF","DHT11":{"Temperature":8.3,"Humidity":88.0,"DewPoint":6.4},"TempUnit":"C"}
      2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 8.3
      2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 88
      2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 6.4
      2025-01-13 20:49:16.022 - info: admin.0 (346) <== Disconnect system.user.admin from ::ffff:172.16.0.166
      2025-01-13 20:49:19.297 - info: host.iobroker "system.adapter.judoisoft.0" disabled
      2025-01-13 20:49:20.466 - info: host.iobroker "system.adapter.judoisoft.0" enabled
      2025-01-13 20:49:20.754 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1349
      2025-01-13 20:49:21.224 - info: judoisoft.0 (1349) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
      2025-01-13 20:49:21.421 - info: judoisoft.0 (1349) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
      2025-01-13 20:49:21.470 - info: judoisoft.0 (1349) reconnect 1736797761469
      2025-01-13 20:49:21.531 - error: judoisoft.0 (1349) getInfosCloud ERROR reconnect wait 5 min
      2025-01-13 20:49:21.531 - warn: judoisoft.0 (1349) Restart initiated
      2025-01-13 20:49:21.532 - info: judoisoft.0 (1349) cleaned everything up...
      2025-01-13 20:49:21.533 - info: judoisoft.0 (1349) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
      2025-01-13 20:49:21.534 - info: judoisoft.0 (1349) terminating
      2025-01-13 20:49:21.534 - info: judoisoft.0 (1349) Terminated (NO_ERROR): Without reason
      2025-01-13 20:49:22.034 - info: judoisoft.0 (1349) terminating
      2025-01-13 20:49:22.058 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
      2025-01-13 20:49:22.058 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
      2025-01-13 20:49:25.655 - info: admin.0 (346) ==> Connected system.user.admin from ::ffff:172.16.0.166
      2025-01-13 20:49:30.781 - info: host.iobroker "system.adapter.judoisoft.0" disabled
      2025-01-13 20:49:31.748 - info: host.iobroker "system.adapter.judoisoft.0" enabled
      2025-01-13 20:49:31.984 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1364
      2025-01-13 20:49:32.476 - info: judoisoft.0 (1364) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
      2025-01-13 20:49:32.693 - info: judoisoft.0 (1364) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
      2025-01-13 20:49:32.741 - info: judoisoft.0 (1364) reconnect 1736797772741
      2025-01-13 20:49:32.792 - error: judoisoft.0 (1364) getInfosCloud ERROR reconnect wait 5 min
      2025-01-13 20:49:32.792 - warn: judoisoft.0 (1364) Restart initiated
      2025-01-13 20:49:32.793 - info: judoisoft.0 (1364) cleaned everything up...
      2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
      2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) terminating
      2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) Terminated (NO_ERROR): Without reason
      2025-01-13 20:49:33.294 - info: judoisoft.0 (1364) terminating
      2025-01-13 20:49:33.322 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
      2025-01-13 20:49:33.322 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
      2025-01-13 20:49:48.524 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1379
      2025-01-13 20:49:48.999 - info: judoisoft.0 (1379) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
      arteck mcm1957 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @marcel-drzal last edited by
        @marcel-drzal sagte in Fehler Nach update Judo soft Adapter:
        die Daten können nicht abgeholt werden..warum auch immer
          SmartHomer 0 @arteck last edited by SmartHomer 0
          @arteck
          Ich denke, das passt auch zu diesem Problem in diesem Thread:
          judo i-soft+ Adapter
          Auch bei mir funktioniert es wieder nicht mehr, sieht aus als ob judo erneut was gemacht hat.
          • mcm1957
            mcm1957 @marcel-drzal last edited by
            @marcel-drzal
            Aktuelle Version ist 1.1.2. Keine Ahnung ob da was gefixed wurde, aber ein Test kann wahrscheinlich nicht schaden,
              SmartHomer 0 @mcm1957 last edited by
              @mcm1957
              Korrekt, mit 1.1.2 hatte es auch eine Zeit lang funktioniert, aber zwischenzeitlich eben auch nicht mehr.
              Ich vermute, dass seitens judo zwischenzeitlich der Datenabruf via Portal gesperrt wurde und die Server den ioBroker-Adapter blocken... 😕
              Müsste man also vermutlich für ioBroker-Abfragen eine Lösung über die dafür gedachte API bauen (wer immer dazu in der Lage ist)...
              • mcm1957
                mcm1957 last edited by mcm1957
                @smarthomer-0
                OK - scheingt auch als Issue registriert zu sein. (https://github.com/arteck/ioBroker.judoisoft/issues/75)
                Das ist ein Adapter von arteck und er kann (und wird sicher auch) da was anpassen.
                ER hat das Problem ja auch schon wie hier zu lesen war gesehen.
                tiigaaa created this issue in arteck/ioBroker.judoisoft
                closed Judo wieder was umgestellt? Adapter bleibt ROT. #75
                  hab mal blind gemacht
                  https://github.com/arteck/ioBroker.judoisoft/tarball/header
                  musste von jemanden getestet werden..
                  sonst brauch ich login Daten von jemanden
                  Fredi Van Wensen 3 Replies Last reply Reply Quote 0
                  • Fredi Van Wensen
                    Fredi Van Wensen @arteck last edited by
                    @arteck Ich versuche es diesen Tage mal. Habe gerade erst alles von Windows auf Linux umgestellt, deswegen war es kurz ruhig hier.
                    Fredi Van Wensen 1 Reply Last reply Reply Quote 0
                    • Fredi Van Wensen
                      Fredi Van Wensen @Fredi Van Wensen last edited by
                      @fredi-van-wensen Welche Version soll man installieren?
                      • Fredi Van Wensen
                        @arteck 1.1.2
                        • Fredi Van Wensen
                          @arteck Hat bei mir leider nicht funktioniert.
                            dann brauch ich deine Login daten.. da ich keine judo hier habe
                            • Fredi Van Wensen
                              @arteck Wie soll ich die dir zukommen lassen?
                                arteck Developer Most Active @Fredi Van Wensen last edited by
                                @fredi-van-wensen
                                  @fredi-van-wensen so jetzt aber
                                  alles da
                                  2345
