    4. [HOW-TO] backitup Konfiguration mit nfs
      Thomas Braun Most Active @norbert999 last edited by
      @norbert999 sagte in [HOW-TO] backitup Konfiguration mit nfs:
      iobroker fix
      auf der Kister mit der ioBroker-Installation ausführen.
      • N
        norbert999 @Thomas Braun last edited by
        @thomas-braun said in [HOW-TO] backitup Konfiguration mit nfs:
        iobroker fix
        Hier der raspi5 auf dem der iob läuft (mit sudo davor das gleiche)
        pi@raspi5:~ $ iobroker fix
        -bash: iobroker: command not found
        Was mache ich falsch?
          FINGER weg von sudo.
          Versuch mal die Testversion von
          iob diag
          von hier:
          https://forum.iobroker.net/topic/59549/iob-diag-skript
          • N
            obwohl backitup durchläuft, habe ich jedesmal eine Fehlermeldung:
            ========== Start marking the full check here ===========
            ```bash
            Script v.2024-12-09 Raspbian+zigbee diag+masking
            *** BASE SYSTEM ***
             Static hostname: raspi5
                   Icon name: computer
                      Kernel: Linux 6.6.62+rpt-rpi-2712
                Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 5 Model B Rev 1.0
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             07:42:33 up 14:38,  3 users,  load average: 0.37, 0.98, 0.86
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Wed 2025-01-15 07:42:33 CET
                       Universal time: Wed 2025-01-15 06:42:33 UTC
                             RTC time: Wed 2025-01-15 06:42:33
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:            8.4G        2.1G        4.9G         40M        1.5G        6.3G
            Swap:           536M          0B        536M
            Total:          9.0G        2.1G        5.4G
            Active iob-Instances:   0
                     8052 M total memory
                     2042 M used memory
                     2333 M active memory
                      718 M inactive memory
                     4682 M free memory
                      137 M buffer memory
                     1325 M swap cache
                      511 M total swap
                        0 M used swap
                      511 M free swap
            top - 07:42:33 up 14:38,  3 users,  load average: 0.37, 0.98, 0.86
            Tasks: 236 total,   1 running, 235 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni, 25.0 id, 25.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8052.2 total,   4682.4 free,   2042.1 used,   1463.0 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6010.1 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem                            Type      Size  Used Avail Use% Mounted on
            udev                                  devtmpfs  3.9G     0  3.9G   0% /dev
            tmpfs                                 tmpfs     806M  6.2M  800M   1% /run
            /dev/sda2                             ext4       29G   10G   18G  37% /
            tmpfs                                 tmpfs     4.0G  4.2M  4.0G   1% /dev/shm
            tmpfs                                 tmpfs     5.0M   48K  5.0M   1% /run/lock
            /dev/sda1                             vfat      510M   67M  444M  14% /boot/firmware
            192.168.1.12:/share/backup_raspi5     nfs       5.4T  3.0T  2.4T  56% /opt/iobroker/backups
            192.168.1.12:/share/backup_raspberry5 nfs       5.4T  3.0T  2.4T  56% /backup
            tmpfs                                 tmpfs     806M  192K  806M   1% /run/user/1000
            Show mounted filesystems:
            TARGET                  SOURCE                            FSTYPE      OPTIONS
            /                       /dev/sda2                         ext4        rw,noatime
            |-/run/user/1000/doc    portal                            fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            |-/boot/firmware        /dev/sda1                         vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            |-/opt/iobroker/backups 192.168.1.12:/share/backup_raspi5 nfs         rw,nosuid,nodev,noexec,relatime,sync,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,proto=tcp,timeo=600,retr
            `-/backup               192.168.1.12:/share/backup_raspberry5
            /var:
            1.6G    /var/
            483M    /var/cache
            476M    /var/cache/apt
            361M    /var/cache/apt/archives
            345M    /var/log
            Archived and active journals take up 324.6M in the file system.
            /opt/iobroker/backups:
            51M     /opt/iobroker/backups/
            16K     /opt/iobroker/backups/.@__thumb
            12K     /opt/iobroker/backups/@Recycle
            8.0K    /opt/iobroker/backups/raspi5
            /opt/iobroker/iobroker-data:
            1.2G    /opt/iobroker/iobroker-data/
            1007M   /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            30M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.1
            /usr/bin/node           v20.18.1
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.4
            nodejs:
              Installed: 20.18.1-1nodesource1
              Candidate: 20.18.1-1nodesource1
              Version table:
             *** 20.18.1-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                 18.19.0+dfsg-6~deb12u1 500
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            ./iob_diag.sh: line 879: iob: command not found
            Hosts:
            ./iob_diag.sh: line 881: iob: command not found
            Core adapters versions
            ./iob_diag.sh: line 887: iob: command not found
            js-controller:
            ./iob_diag.sh: line 888: iob: command not found
            admin:
            ./iob_diag.sh: line 889: iob: command not found
            javascript:
            nodejs modules from github:     0
            Adapter State
            ioBroker-Repositories
            ./iob_diag.sh: line 901: iob: command not found
            Installed ioBroker-Instances
            ./iob_diag.sh: line 904: iob: command not found
            Objects and States
            Objects:        0
            States:         0
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://repos.influxdata.com/debian stable InRelease
            Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:6 https://apt.grafana.com stable InRelease
            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists... Done
            Pending Updates: 75
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          6673       876/upsd
            tcp        0      0 192.168.1.6:3493        0.0.0.0:*               LISTEN      0          6672       876/upsd
            tcp        0      0 192.168.1.6:2001        0.0.0.0:*               LISTEN      1001       12040      2467/io.hm-rpc.0
            tcp        0      0 192.168.1.6:2010        0.0.0.0:*               LISTEN      1001       12042      2492/io.hm-rpc.1
            tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          7300       825/unbound
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          7581       977/lighttpd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2973       822/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        9289       922/pihole-FTL
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          88226      17640/cupsd
            tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        9295       922/pihole-FTL
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9162       1220/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9152       1220/iobroker.js-co
            tcp6       0      0 :::3000                 :::*                    LISTEN      113        9916       1219/grafana
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11807      1698/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15031      2526/io.web.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      995        9504       891/influxd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          88225      17640/cupsd
            tcp6       0      0 ::1:4711                :::*                    LISTEN      999        9296       922/pihole-FTL
            tcp6       0      0 :::80                   :::*                    LISTEN      0          7580       977/lighttpd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          2975       822/sshd: /usr/sbin
            tcp6       0      0 :::53                   :::*                    LISTEN      999        9291       922/pihole-FTL
            udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        9288       922/pihole-FTL
            udp        0      0 0.0.0.0:49669           0.0.0.0:*                           1001       14561      2397/io.snmp.0
            udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          7299       825/unbound
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6558       562/avahi-daemon: r
            udp        0      0 0.0.0.0:34034           0.0.0.0:*                           1001       12835      2415/io.snmp.1
            udp        0      0 0.0.0.0:39364           0.0.0.0:*                           104        6560       562/avahi-daemon: r
            udp6       0      0 :::53                   :::*                                999        9290       922/pihole-FTL
            udp6       0      0 fe80::f0ae:1c2a:23c:546 :::*                                0          7356       780/NetworkManager
            udp6       0      0 :::5353                 :::*                                104        6559       562/avahi-daemon: r
            udp6       0      0 :::51537                :::*                                104        6561       562/avahi-daemon: r
            2025-01-15 07:37:47.267  - debug: hm-rpc.0 (2467) xml multicall <event>: raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19,CENTRAL,PONG,raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19
            2025-01-15 07:37:47.267  - debug: hm-rpc.0 (2467) xmlrpc <- event ["raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19","CENTRAL","PONG","raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19"]
            2025-01-15 07:37:47.267  - debug: hm-rpc.0 (2467) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19 discarded, no matching device
            2025-01-15 07:39:17.263  - debug: hm-rpc.0 (2467) [KEEPALIVE] Check if connection is alive
            2025-01-15 07:39:17.263  - debug: hm-rpc.0 (2467) Send PING...
            2025-01-15 07:39:17.267  - debug: hm-rpc.0 (2467) PING ok
            2025-01-15 07:39:17.268  - debug: hm-rpc.0 (2467) xml multicall <event>: raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19,CENTRAL,PONG,raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19
            2025-01-15 07:39:17.268  - debug: hm-rpc.0 (2467) xmlrpc <- event ["raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19","CENTRAL","PONG","raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19"]
            2025-01-15 07:39:17.268  - debug: hm-rpc.0 (2467) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19 discarded, no matching device
            2025-01-15 07:40:32.011  - info: host.raspi5 instance system.adapter.dwd.0 in version "2.8.5" started with pid 26300
            2025-01-15 07:40:32.764  - info: dwd.0 (26300) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.6
            2025-01-15 07:40:33.665  - info: dwd.0 (26300) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-01-15 07:40:34.174  - info: host.raspi5 instance system.adapter.dwd.0 having pid 26300 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-01-15 07:40:47.264  - debug: hm-rpc.0 (2467) [KEEPALIVE] Check if connection is alive
            2025-01-15 07:40:47.264  - debug: hm-rpc.0 (2467) Send PING...
            2025-01-15 07:40:47.268  - debug: hm-rpc.0 (2467) PING ok
            2025-01-15 07:40:47.269  - debug: hm-rpc.0 (2467) xml multicall <event>: raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19,CENTRAL,PONG,raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19
            2025-01-15 07:40:47.269  - debug: hm-rpc.0 (2467) xmlrpc <- event ["raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19","CENTRAL","PONG","raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19"]
            2025-01-15 07:40:47.269  - debug: hm-rpc.0 (2467) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19 discarded, no matching device
            2025-01-15 07:42:17.264  - debug: hm-rpc.0 (2467) [KEEPALIVE] Check if connection is alive
            2025-01-15 07:42:17.264  - debug: hm-rpc.0 (2467) Send PING...
            2025-01-15 07:42:17.271  - debug: hm-rpc.0 (2467) PING ok
            2025-01-15 07:42:17.275  - debug: hm-rpc.0 (2467) xml multicall <event>: raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19,CENTRAL,PONG,raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19
            2025-01-15 07:42:17.275  - debug: hm-rpc.0 (2467) xmlrpc <- event ["raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19","CENTRAL","PONG","raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19"]
            2025-01-15 07:42:17.275  - debug: hm-rpc.0 (2467) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19 discarded, no matching device
            Hier jetzt der output von iob diag. Siehst Du, wo es hakt?
              Thomas Braun Most Active @norbert999 last edited by Thomas Braun
              @norbert999
              Fehlermeldungen bitte nie als Screenshot, immer als Text.
                @norbert999
                Da sind aber auch noch andere Kinken drin.
                • N
                  Sorry. Mein Fehler. Hier der log
                  2025-01-15 08:18:17.284 - debug: hm-rpc.0 (2467) [KEEPALIVE] Check if connection is alive
                  2025-01-15 08:18:17.284 - debug: hm-rpc.0 (2467) Send PING...
                  2025-01-15 08:18:17.289 - debug: hm-rpc.0 (2467) PING ok
                  2025-01-15 08:18:17.291 - debug: hm-rpc.0 (2467) xml multicall : raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19,CENTRAL,PONG,raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19
                  2025-01-15 08:18:17.291 - debug: hm-rpc.0 (2467) xmlrpc <- event ["raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19","CENTRAL","PONG","raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19"]
                  2025-01-15 08:18:17.291 - debug: hm-rpc.0 (2467) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:raspi5:hm-rpc.0:a6f04f6e3cdc89967739550158ac1a19 discarded, no matching device
                  2025-01-15 08:18:19.949 - info: admin.0 (1698) ==> Connected system.user.admin from ::ffff:192.168.1.209
                  2025-01-15 08:18:25.734 - error: backitup.0 (2452) [iobroker] chmod for Backup directory could not be completed: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups' Please run "iobroker fix"!!
                  2025-01-15 08:18:28.313 - info: admin.0 (1698) <== Disconnect system.user.admin from ::ffff:192.168.1.209 backitup
                  2025-01-15 08:18:35.066 - warn: backitup.0 (2452) [iobroker/clean] No older backup files are deleted, because this backup was started manually
                  • N
                    @thomas-braun Ich gebe Dir ein Königreich wenn Du mir hilfst.
                      @norbert999
                      Solange
                      ioBroker Status
                      vorliegt brauchst du dir um ein Backup keinen Kopf machen. Da ist schon auf tieferer Ebene was schief.
                      • N
                        Nur was? Da hänge ich als hoch motivierter Laie schon Tage dran und es geht nicht voran. Ich habe viel gelesen, viel probiert, komme aber nicht ohne Experte weiter. Es ist ein Frust! Kann nur auf Hilfe hoffen.
                          @norbert999
                          iobroker start
                          sowie
                          systemctl status iobroker
                          sagen?
                          • N
                            pi@raspi5:~ $ iobroker start
                            pi@raspi5:~ $ systemctl status iobroker
                            ● iobroker.service - ioBroker Server
                                 Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                                 Active: active (running) since Tue 2025-01-14 17:05:13 CET; 15h ago
                                   Docs: http://iobroker.net
                               Main PID: 1220 (iobroker.js-con)
                                  Tasks: 220 (limit: 9564)
                                    CPU: 1h 27min 5.187s
                                 CGroup: /system.slice/iobroker.service
                                         ├─1220 iobroker.js-controller
                                         ├─1698 io.admin.0
                                         ├─1739 io.javascript.0
                                         ├─2336 io.nut.0
                                         ├─2397 io.snmp.0
                                         ├─2415 io.snmp.1
                                         ├─2433 io.tr-064.0
                                         ├─2452 io.backitup.0
                                         ├─2467 io.hm-rpc.0
                                         ├─2474 io.hm-rega.0
                                         ├─2492 io.hm-rpc.1
                                         ├─2515 io.discovery.0
                                         ├─2526 io.web.0
                                         ├─2541 io.fronius-solarweb.0
                                         ├─2552 io.trashschedule.0
                                         ├─2559 io.pi-hole.0
                                         ├─2569 io.energiefluss-erweitert.0
                                         ├─2664 io.vis-2.0
                                         ├─3519 io.pushover.0
                                         └─3546 io.fronius-wattpilot.0
                            Jan 15 07:12:13 raspi5 sudo[22204]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                            Jan 15 07:12:13 raspi5 sudo[22204]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                            Jan 15 07:12:14 raspi5 sudo[22204]: pam_unix(sudo:session): session closed for user root
                            Jan 15 08:17:14 raspi5 bash[1220]: Send diag info: {"uuid":"6314d3b3-71c3-1ccc-c873-938803957853","language":"de","country":"Germany","hosts":[{"version":"7.0.6","platform":"Javascript/Nod>
                            Jan 15 08:17:14 raspi5 sudo[29199]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
                            Jan 15 08:17:14 raspi5 sudo[29199]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                            Jan 15 08:17:14 raspi5 sudo[29199]: pam_unix(sudo:session): session closed for user root
                            Jan 15 08:17:14 raspi5 sudo[29204]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                            Jan 15 08:17:14 raspi5 sudo[29204]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                            Jan 15 08:17:15 raspi5 sudo[29204]: pam_unix(sudo:session): session closed for user root
                              @norbert999
                              Jag den Fixer mal über das System. Musst du aber wohl dann direkt aus dem Netz ziehen, wenn 'iobroker' und 'iob' nicht direkt aufrufbar sind.
                              Ich meine @Homoran hat den Befehl dazu in der Signatur.
                              Homoran N 2 Replies Last reply Reply Quote 0
                                @thomas-braun sagte in [HOW-TO] backitup Konfiguration mit nfs:
                                hat er!
                                wenn der noch passt
                                • N
                                  pi@raspi5:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
                                  Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
                                  library: loaded
                                  Library version=2024-10-22
                                  ioBroker or some processes are still running:
                                  1698 io.admin.0
                                  2336 io.nut.0
                                  2397 io.snmp.0
                                  2415 io.snmp.1
                                  2433 io.tr-064.0
                                  2452 io.backitup.0
                                  2467 io.hm-rpc.0
                                  2474 io.hm-rega.0
                                  2492 io.hm-rpc.1
                                  2515 io.discovery.0
                                  2526 io.web.0
                                  2559 io.pi-hole.0
                                  2664 io.vis-2.0
                                  3519 io.pushover.0
                                  Please stop them first and try again!
                                  pi@raspi5:~ $ ^C
                                  pi@raspi5:~ $
                                  Wie stoppe ich das alles? Alle iob Instanzen anhalten, oder wie?
                                    Homoran Global Moderator Administrators @norbert999 last edited by
                                    iob stop in der Konsole
                                    • N
                                      norbert999 @Homoran last edited by
                                      @homoran said in [HOW-TO] backitup Konfiguration mit nfs:
                                      pi@raspi5:~ $ sudo iob stop
                                      sudo: iob: command not found
                                      pi@raspi5:~ $
                                      Geht nicht.
                                        @norbert999 wer hat was von sudo gesagt?
                                        Niemals Befehle mit iob... mit sudo anfassen
                                        • N
                                          @homoran Verstanden. Aber auch ohne sudo dasgleiche Resultat.
                                            Dann ist da richtig was faul
                                            was sagt iob status?
                                            81.1k
                                            backitup nas iob nfs bookworm
                                            4781
