    4. [HOW-TO] backitup Konfiguration mit nfs
      Thomas Braun Most Active @norbert999 last edited by
      @norbert999
      iobroker start
      sowie
      systemctl status iobroker
      sagen?
      • N
        norbert999 @Thomas Braun last edited by
        @thomas-braun said in [HOW-TO] backitup Konfiguration mit nfs:
        pi@raspi5:~ $ iobroker start
        -bash: iobroker: command not found
        pi@raspi5:~ $ systemctl status iobroker
        ● iobroker.service - ioBroker Server
             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
             Active: active (running) since Tue 2025-01-14 17:05:13 CET; 15h ago
               Docs: http://iobroker.net
           Main PID: 1220 (iobroker.js-con)
              Tasks: 220 (limit: 9564)
                CPU: 1h 27min 5.187s
             CGroup: /system.slice/iobroker.service
                     ├─1220 iobroker.js-controller
                     ├─1698 io.admin.0
                     ├─1739 io.javascript.0
                     ├─2336 io.nut.0
                     ├─2397 io.snmp.0
                     ├─2415 io.snmp.1
                     ├─2433 io.tr-064.0
                     ├─2452 io.backitup.0
                     ├─2467 io.hm-rpc.0
                     ├─2474 io.hm-rega.0
                     ├─2492 io.hm-rpc.1
                     ├─2515 io.discovery.0
                     ├─2526 io.web.0
                     ├─2541 io.fronius-solarweb.0
                     ├─2552 io.trashschedule.0
                     ├─2559 io.pi-hole.0
                     ├─2569 io.energiefluss-erweitert.0
                     ├─2664 io.vis-2.0
                     ├─3519 io.pushover.0
                     └─3546 io.fronius-wattpilot.0
        Jan 15 07:12:13 raspi5 sudo[22204]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
        Jan 15 07:12:13 raspi5 sudo[22204]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
        Jan 15 07:12:14 raspi5 sudo[22204]: pam_unix(sudo:session): session closed for user root
        Jan 15 08:17:14 raspi5 bash[1220]: Send diag info: {"uuid":"6314d3b3-71c3-1ccc-c873-938803957853","language":"de","country":"Germany","hosts":[{"version":"7.0.6","platform":"Javascript/Nod>
        Jan 15 08:17:14 raspi5 sudo[29199]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
        Jan 15 08:17:14 raspi5 sudo[29199]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
        Jan 15 08:17:14 raspi5 sudo[29199]: pam_unix(sudo:session): session closed for user root
        Jan 15 08:17:14 raspi5 sudo[29204]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
        Jan 15 08:17:14 raspi5 sudo[29204]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
        Jan 15 08:17:15 raspi5 sudo[29204]: pam_unix(sudo:session): session closed for user root
          @norbert999
          Jag den Fixer mal über das System. Musst du aber wohl dann direkt aus dem Netz ziehen, wenn 'iobroker' und 'iob' nicht direkt aufrufbar sind.
          Ich meine @Homoran hat den Befehl dazu in der Signatur.
          Homoran N 2 Replies Last reply Reply Quote 0
            @thomas-braun sagte in [HOW-TO] backitup Konfiguration mit nfs:
            hat er!
            wenn der noch passt
            • N
              pi@raspi5:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
              Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
              library: loaded
              Library version=2024-10-22
              ioBroker or some processes are still running:
              1698 io.admin.0
              2336 io.nut.0
              2397 io.snmp.0
              2415 io.snmp.1
              2433 io.tr-064.0
              2452 io.backitup.0
              2467 io.hm-rpc.0
              2474 io.hm-rega.0
              2492 io.hm-rpc.1
              2515 io.discovery.0
              2526 io.web.0
              2559 io.pi-hole.0
              2664 io.vis-2.0
              3519 io.pushover.0
              Please stop them first and try again!
              pi@raspi5:~ $ ^C
              pi@raspi5:~ $
              Wie stoppe ich das alles? Alle iob Instanzen anhalten, oder wie?
                Homoran Global Moderator Administrators @norbert999 last edited by
                @norbert999 sagte in [HOW-TO] backitup Konfiguration mit nfs:
                iob stop in der Konsole
                • N
                  norbert999 @Homoran last edited by
                  @homoran said in [HOW-TO] backitup Konfiguration mit nfs:
                  pi@raspi5:~ $ sudo iob stop
                  sudo: iob: command not found
                  pi@raspi5:~ $
                  Geht nicht.
                    @norbert999 wer hat was von sudo gesagt?
                    Niemals Befehle mit iob... mit sudo anfassen
                    • N
                      @homoran Verstanden. Aber auch ohne sudo dasgleiche Resultat.
                        Dann ist da richtig was faul
                        was sagt iob status?
                        • N
                          pi@raspi5:~ $ iob status
                          -bash: iob: command not found
                          pi@raspi5:~ $
                            @norbert999 du bist wirklich auf dem pi, auf dem iob installiert ist?
                              dann müsste dir @Thomas-Braun mal die richtige Syntax von sudo systemctl status iobroker sagen.
                              ich weiß nicht ob das so passt
                              • N
                                Ganz sicher!
                                     Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
                                     Active: active (running) since Wed 2025-01-15 09:40:52 CET; 2min 14s ago
                                   Main PID: 1261 (iobroker.js-con)
                                        CPU: 1min 2.054s
                                             ├─1261 iobroker.js-controller
                                             ├─1741 io.admin.0
                                             ├─2271 io.javascript.0
                                             ├─2411 io.nut.0
                                             ├─2432 io.snmp.0
                                             ├─2447 io.snmp.1
                                             ├─2462 io.tr-064.0
                                             ├─2469 io.backitup.0
                                             ├─2496 io.hm-rpc.0
                                             ├─2514 io.hm-rega.0
                                             ├─2529 io.hm-rpc.1
                                             ├─2544 io.discovery.0
                                             ├─2559 io.web.0
                                             ├─2566 io.fronius-solarweb.0
                                             ├─2585 io.trashschedule.0
                                lines 1-23
                                  @norbert999 wenn der staus klappt, dann mach sudo systemctl stop iobroker
                                  • N
                                    norbert999 @norbert999 last edited by
                                    @norbert999
                                    Sorry, hatte nicht die vollständige Ausgabe kopiert. Jetzt richtig, untenstehen die Fehlermeldungen
                                         Active: active (running) since Wed 2025-01-15 09:40:52 CET; 3min 9s ago
                                            CPU: 1min 9.071s
                                                 ├─1741 io.admin.0
                                                 ├─2411 io.nut.0
                                                 ├─2432 io.snmp.0
                                                 ├─2447 io.snmp.1
                                                 ├─2462 io.tr-064.0
                                                 ├─2496 io.hm-rpc.0
                                                 ├─2514 io.hm-rega.0
                                                 ├─2529 io.hm-rpc.1
                                                 ├─2559 io.web.0
                                                 ├─2593 io.pi-hole.0
                                                 ├─2608 io.energiefluss-erweitert.0
                                                 ├─2628 io.vis-2.0
                                                 ├─2672 io.pushover.0
                                                 └─2692 io.fronius-wattpilot.0
                                    Jan 15 09:41:26 raspi5 sudo[2402]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                    Jan 15 09:41:26 raspi5 sudo[2402]: pam_unix(sudo:session): session closed for user root
                                    Jan 15 09:41:26 raspi5 sudo[2407]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                                    Jan 15 09:41:26 raspi5 sudo[2407]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                    Jan 15 09:41:26 raspi5 sudo[2407]: pam_unix(sudo:session): session closed for user root
                                    Jan 15 09:41:27 raspi5 su[2377]: FAILED SU (to root) iobroker on none
                                    Jan 15 09:41:27 raspi5 su[2423]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
                                    Jan 15 09:41:29 raspi5 su[2423]: FAILED SU (to pi) iobroker on none
                                    Jan 15 09:41:30 raspi5 su[2439]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
                                    Jan 15 09:41:32 raspi5 su[2439]: FAILED SU (to pi) iobroker on none
                                    • N
                                      Das hat funktioniert!
                                      aspi5:~ $ sudo systemctl stop iobroker
                                      library: loaded
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 2024-10-22
                                          You might need to enter your password a couple of times.
                                          Installing prerequisites (1/5)
                                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:4 https://apt.grafana.com stable InRelease
                                      Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Hit:6 https://repos.influxdata.com/debian stable InRelease
                                      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Reading package lists... Done
                                          Checking ioBroker user and directory permissions (2/5)
                                      Created /etc/sudoers.d/iobroker
                                      Fixing directory permissions...
                                      chown: changing ownership of '/opt/iobroker/backups/@Recycle/desktop.ini': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/@Recycle': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/.@__thumb/sanlight-bt-dimmer-manual-2023-de.pdf.error': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/.@__thumb/sanlight-bt-dimmer-manual-2023-dexxxxxxxxxxxxxxxxxxxxxxxxx.pdf.error': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/.@__thumb': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_11-17_26_51_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/raspi5': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_11-17_26_58_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_11-17_44_54_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_11-17_45_00_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_12-02_48_10_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_12-02_48_16_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_13-02_48_10_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_13-02_48_16_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_14-02_48_10_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_14-02_48_17_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-02_48_11_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-02_48_18_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-07_16_49_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-07_16_55_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-07_21_52_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-07_21_59_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-08_18_25_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-08_18_32_backupiobroker.tar.gz': Operation not permitted
                                      chown: changing ownership of '/opt/iobroker/backups': Operation not permitted
                                      This system does not support setting default permissions.
                                      Do not use npm to manually install adapters unless you know what you are doing!
                                          Check and cleanup npm temporary directories (3/5)
                                      Done.
                                          Database maintenance (4/5)
                                      Checking for uncompressed JSONL databases... This might take a while!
                                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                      Compressed 2 JSONL files. Done
                                          Checking autostart (5/5)
                                      Enabling autostart...
                                      Autostart enabled!
                                          Your installation was fixed successfully
                                          Run iobroker start to start ioBroker again!
                                      pi@raspi5:~ $
                                      Und jetzt?
                                        Und jetzt?
                                        N 1 Reply Last reply Reply Quote 1
                                        • N
                                          Objects type: jsonl
                                          States  type: jsonl
                                          pi@raspi5:~ $
                                          Jetzt geht der iob status, der definitiv vorher nicht ging!
                                            da war ja auch alles massiv verbogen
                                            81.1k
                                            backitup nas iob nfs bookworm
                                            4789
