    4. Zigbee Stick plötzlich nicht mehr grün CC2531 / Sonoff
      Thomas Braun Most Active @Fruchtzwergi last edited by
      @fruchtzwergi
      Verwende
      iob diag
      in der Testversion mit der 'unhide'-Option.
      Dann kannst du die fehlenden/falschen Einstellungen auslesen.
        Fruchtzwergi @Thomas Braun last edited by
        @thomas-braun said in Zigbee Stick plötzlich nicht mehr grün CC2531 / Sonoff:
        iob diag
                                v.2024-10-19
         Static hostname: raspberrypi4
               Icon name: computer
                  Kernel: Linux 6.6.51+rpt-rpi-v8
            Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        Recommended versions are nodejs 20.18.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:            4.0G        881M        338M        1.2M        2.8G        3.1G
        Swap:           536M          0B        536M
        Total:          4.5G        881M        875M
        Active iob-Instances:   6
        Upgrade policy: none
        ioBroker Core:          js-controller           7.0.6
                                admin                   7.4.10
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        Objects:                232
        States:                 168
        Size of iob-Database:
        6.2M    /opt/iobroker/iobroker-data/objects.jsonl
        1.1M    /opt/iobroker/iobroker-data/states.jsonl
        Operating System is the current Debian stable version codenamed 'bookworm'!
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         21:41:34 up  1:39,  2 users,  load average: 0.40, 0.28, 0.15
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2025-01-14 21:41:35 CET
                   Universal time: Tue 2025-01-14 20:41:35 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.0G        879M        340M        1.2M        2.8G        3.1G
        Swap:           536M          0B        536M
        Total:          4.5G        879M        877M
                 3791 M total memory
                  838 M used memory
                 1148 M active memory
                 2040 M inactive memory
                  324 M free memory
                   73 M buffer memory
                 2632 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        top - 21:41:35 up  1:39,  2 users,  load average: 0.40, 0.28, 0.15
        Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3792.0 total,    324.8 free,    838.3 used,   2705.7 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2953.7 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.2M  379M   1% /run
        /dev/mmcblk0p2 ext4       59G  5.2G   50G  10% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Tue Jan 14 20:01:53 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:59:78:CF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4f18ebf4-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Tue Jan 14 20:01:55 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
        [Tue Jan 14 20:01:57 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        920M    /var/
        205M    /var/cache
        199M    /var/cache/apt
        167M    /var/lib
        135M    /var/lib/apt/lists
        Archived and active journals take up 36.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        807M    /opt/iobroker/iobroker-data/
        800M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
        7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d0b9e07e2555ef11b63a5b73cc32aab1-if00-port0
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        *** NodeJS-Installation ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
             18.19.0+dfsg-6~deb12u1 500
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi4        raspberrypi4 (version: 7.0.6, hostname: raspberrypi4  , alive, uptime: 5088)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.4.10
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi4                             -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
          system.adapter.ping.0                   : ping                  : raspberrypi4                             - disabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d0b9e07e2555ef11b63a5b73cc32aab1-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
        Objects and States
        Objects:        232
        States:         168
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50689      22987/iobroker.js-c
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50694      22987/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12600      3877/sshd: /usr/sbi
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12602      3877/sshd: /usr/sbi
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50765      23083/io.admin.0
        udp        0      0 0.0.0.0:54433           0.0.0.0:*                           104        17749      9503/avahi-daemon:
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        17747      9503/avahi-daemon:
        udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       56261      23153/io.discovery.
        udp6       0      0 :::51185                :::*                                104        17750      9503/avahi-daemon:
        udp6       0      0 fe80::a489:5f3:56c2:546 :::*                                0          6510       537/NetworkManager
        udp6       0      0 :::5353                 :::*                                104        17748      9503/avahi-daemon:
        2025-01-14 20:45:04.405  - info: admin.0 (23083) <== Disconnect system.user.admin from ::ffff:192.168.178.25
        2025-01-14 20:45:07.001  - info: host.raspberrypi4 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 23823
        2025-01-14 20:45:12.144  - info: zigbee.0 (23823) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
        2025-01-14 20:45:12.251  - info: zigbee.0 (23823) Starting Zigbee  npm ...
        2025-01-14 20:45:12.637  - info: zigbee.0 (23823) Installed Version: iobroker.zigbee@1.10.14
        2025-01-14 20:45:13.400  - error: zigbee.0 (23823) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        2025-01-14 20:45:13.401  - error: zigbee.0 (23823) Failed to start Zigbee
        2025-01-14 20:45:13.402  - error: zigbee.0 (23823) Error herdsman start
        2025-01-14 20:45:23.406  - info: zigbee.0 (23823) Try to reconnect. 1 attempts left
        2025-01-14 20:45:23.408  - info: zigbee.0 (23823) Starting Zigbee  npm ...
        2025-01-14 20:45:23.431  - info: zigbee.0 (23823) Installed Version: iobroker.zigbee@1.10.14
        2025-01-14 20:45:23.647  - error: zigbee.0 (23823) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
        2025-01-14 20:45:23.648  - error: zigbee.0 (23823) Failed to start Zigbee
        2025-01-14 20:45:23.649  - error: zigbee.0 (23823) Error herdsman start
        2025-01-14 21:02:50.610  - info: admin.0 (23083) ==> Connected system.user.admin from ::ffff:192.168.178.25
        2025-01-14 21:02:53.635  - info: admin.0 (23083) <== Disconnect system.user.admin from ::ffff:192.168.178.25 javascript
        2025-01-14 21:09:45.103  - info: admin.0 (23083) <== Disconnect system.user.admin from ::ffff:192.168.178.25 admin
        2025-01-14 21:22:12.671  - info: admin.0 (23083) ==> Connected system.user.admin from ::ffff:192.168.178.25
        2025-01-14 21:22:51.093  - info: admin.0 (23083) <== Disconnect system.user.admin from ::ffff:192.168.178.25 admin
        2025-01-14 21:28:57.192  - info: admin.0 (23083) ==> Connected system.user.admin from ::ffff:192.168.178.25
        2025-01-14 21:31:31.113  - info: admin.0 (23083) <== Disconnect system.user.admin from ::ffff:192.168.178.25 admin
        2025-01-14 21:34:39.773  - info: admin.0 (23083) ==> Connected system.user.admin from ::ffff:192.168.178.25
        2025-01-14 21:34:58.935  - info: admin.0 (23083) <== Disconnect system.user.admin from ::ffff:192.168.178.25 admin
        2025-01-14 21:34:59.004  - info: admin.0 (23083) ==> Connected system.user.admin from ::ffff:192.168.178.25
        2025-01-14 21:34:59.218  - info: admin.0 (23083) <== Disconnect system.user.admin from ::ffff:192.168.178.25 admin
        So richtig?
          Thomas Braun Most Active @Fruchtzwergi last edited by Thomas Braun
          @fruchtzwergi
          Das ist nicht die Testversion.
          Bin unterwegs und kann die gerade selber nicht suchen.
          Edit:
          https://forum.iobroker.net/topic/59549/iob-diag-skript
          Das Ding laden und mit der --unmask Option starten.
          • Asgothian
            Asgothian Developer last edited by
            @fruchtzwergi
            Das ist eine ältere Version des diag Skript. Da sind die Zigbee-Parameter noch nicht drin. Mach mal bitte folgendes:
            • einen Screenshot von der Einstellungsseite des Zigbee-Adapters posten
            • auf der Konsole den Befehl more /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json eingeben und die ersten 20 Zeilen hier posten. Das sollte in etwa so aussehen:
              "metadata": {
                "format": "zigpy/open-coordinator-backup",
                "version": 1,
                "source": "zigbee-herdsman@2.1.9",
                "internal": {
                  "date": "2025-01-13T15:37:10.613Z",
                  "znpVersion": 2
              "stack_specific": {
                "zstack": {
                  "tclk_seed": "b516f78e444470d3e7dd88d9e5ba0bf3"
              "coordinator_ieee": "00124b0009d6cafe",
              "pan_id": "1ddd",
              "extended_pan_id": "00124b0009d6cafe",
              "nwk_update_id": 0,
              "security_level": 5,
              "channel": 11,
              "channel_mask": [
                11
            Dann noch die Frage - du willst ein bestehendes Netz wieder ans laufen bekommen, oder ist das alles neu aufgesetzt, so das sowieso alle Geräte neu anzulernen sind ?
            A.
              @fruchtzwergi sagte in Zigbee Stick plötzlich nicht mehr grün CC2531 / Sonoff:
              20210708
              du scheinst mehrere probleme zu haben
              die Firmware auf dem sonoff ist auch nicht mehr aktuell ..
              wirst dich wohl ein wenig einlesen müssen...
                Fruchtzwergi @Asgothian last edited by Fruchtzwergi
                @asgothian said in Zigbee Stick plötzlich nicht mehr grün CC2531 / Sonoff:
                hier die Screenshots und der Log, ich bekomme auch jedes mal wenn ich auf den Adapter gehe folgenden Error
                und ich möchte jetzt auch alles neu aufsetzen, ist kein problem, will alles frisch haben
                Screenshot 2025-01-15 at 11-18-36 instances - raspberrypi4.png Screenshot 2025-01-15 at 11-18-56 instances - raspberrypi4.png
                pi@raspberrypi4:~ $ more /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                  "metadata": {
                    "version": 1,
                    "internal": {
                      "date": "2025-01-15T10:13:49.921Z",
                      "znpVersion": 1
                  "stack_specific": {
                    "zstack": {
                      "tclk_seed": "f8aa5c854a84512950b4f0ace0f1d52a"
                  "coordinator_ieee": "00124b002f899ee1",
                  "pan_id": "1a62",
                  "extended_pan_id": "00124b002f899ee1",
                  "nwk_update_id": 0,
                  "channel": 11,
                  "channel_mask": [
                    11
                  "network_key": {
                    "key": "01030507090b0d0f00020406080a0c0d",
                    "sequence_number": 0,
                    "frame_counter": 3751
                  "devices": []
                So ok?
                ========== Start marking the full check here ===========
                ```bash
                Script v.2024-12-09 Raspbian+zigbee diag+masking
                *** BASE SYSTEM ***
                       Icon name: computer
                          Kernel: Linux 6.6.62+rpt-rpi-v8
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 11:27:39 up 36 min,  3 users,  load average: 0.31, 0.23, 0.38
                CPU threads: 4
                Current issues:
                               Local time: Wed 2025-01-15 11:27:39 CET
                           Universal time: Wed 2025-01-15 10:27:39 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                Display-Server: true
                Desktop:
                Terminal:       tty
                System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or r        un 'iobroker fix'
                *** MEMORY ***
                Mem:            4.0G        1.1G        311M         23M        2.7G        2.9G
                Swap:           536M          0B        536M
                Total:          4.5G        1.1G        848M
                         3791 M total memory
                         1057 M used memory
                         1491 M active memory
                         1736 M inactive memory
                          296 M free memory
                           57 M buffer memory
                         2478 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                top - 11:27:40 up 36 min,  3 users,  load average: 0.31, 0.23, 0.38
                Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
                MiB Mem :   3791.9 total,    295.6 free,   1058.5 used,   2535.6 buff/cache
                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2733.4 avail Mem
                *** FILESYSTEM ***
                tmpfs          tmpfs     380M  1.3M  378M   1% /run
                /dev/mmcblk0p2 ext4       58G   16G   40G  28% /
                tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
                /dev/mmcblk0p1 vfat      510M   67M  444M  14% /boot/firmware
                tmpfs          tmpfs     380M   52K  380M   1% /run/user/1000
                [Wed Jan 15 10:51:14 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_poli        cy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:59:78:CF vc_mem.mem        _base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe563e6f-02 rootfstype=ext4 fsck.repair=yes rootwai        t quiet splash plymouth.ignore-serial-consoles
                [Wed Jan 15 10:51:16 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4ba6ec5-aeed-4cda-967b-d004c1b2cb5c ro with ordered data mode. Quota mode: n        one.
                [Wed Jan 15 10:51:18 2025] EXT4-fs (mmcblk0p2): re-mounted d4ba6ec5-aeed-4cda-967b-d004c1b2cb5c r/w. Quota mode: none.
                /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
                |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                /var:
                978M    /var/
                232M    /var/lib
                184M    /var/cache
                174M    /var/cache/apt
                Archived and active journals take up 47.8M in the file system.
                7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-mat        erial_esm_index_js.d7ed606b.chunk.js.map
                USB-Devices by-id:
                *** ZigBee Settings ***
                Zigbee Network Settings on your coordinator/in nvbackup are:
                zigbee.0
                Extended Pan ID:
                00124b002f899ee1
                Pan ID:
                6754
                Channel:
                11
                Network Key:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                raspberrypi4        raspberrypi4 (version: 7.0.6, hostname: raspberrypi4  , alive, uptime: 1641)
                admin:          7.4.10
                javascript:     8.8.3
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0        .0, run as: admin
                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             - disabled
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/serial/by-id        /usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d0b9e07e2555ef11b63a5b73cc32aab1-if00-port0
                + instance is alive
                Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                Objects and States
                Objects:        1104
                States:         387
                Reading package lists... Done
                Pending Updates: 0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6349       664/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41355      10398/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41350      10398/iobroker.js-c
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3637       652/cupsd
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3636       652/cupsd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          6360       664/sshd: /usr/sbin
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41430      10416/io.admin.0
                udp        0      0 0.0.0.0:34015           0.0.0.0:*                           104        752        462/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        750        462/avahi-daemon: r
                udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       46315      10486/io.discovery.
                udp6       0      0 :::43052                :::*                                104        753        462/avahi-daemon: r
                udp6       0      0 fe80::de81:dad3:c9a:546 :::*                                0          8216       594/NetworkManager
                udp6       0      0 :::5353                 :::*                                104        751        462/avahi-daemon: r
                2025-01-15 11:15:01.908  - info: zigbee.0 (11082) Zigbee: disabling joining new devices.
                2025-01-15 11:15:01.928  - info: zigbee.0 (11082) terminating
                2025-01-15 11:15:01.930  - info: zigbee.0 (11082) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-01-15 11:15:01.958  - info: host.raspberrypi4 stopInstance system.adapter.zigbee.0 send kill signal
                2025-01-15 11:15:02.404  - info: zigbee.0 (11082) terminating
                2025-01-15 11:15:02.490  - info: host.raspberrypi4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-01-15 11:15:14.426  - info: host.raspberrypi4 "system.adapter.zigbee.0" enabled
                2025-01-15 11:15:14.941  - info: host.raspberrypi4 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 11102
                2025-01-15 11:15:16.376  - info: admin.0 (10416) <== Disconnect system.user.admin from ::ffff:192.168.178.25
                2025-01-15 11:15:19.588  - info: zigbee.0 (11102) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-co        ntroller: 7.0.6
                2025-01-15 11:15:19.692  - info: zigbee.0 (11102) Starting Zigbee  npm ...
                2025-01-15 11:15:20.080  - info: zigbee.0 (11102) Installed Version: iobroker.zigbee@1.10.14
                2025-01-15 11:15:20.715  - error: zigbee.0 (11102) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see log        s above for more information"
                2025-01-15 11:15:20.715  - error: zigbee.0 (11102) Failed to start Zigbee
                2025-01-15 11:15:20.717  - error: zigbee.0 (11102) Error herdsman start
                2025-01-15 11:15:30.719  - info: zigbee.0 (11102) Try to reconnect. 1 attempts left
                2025-01-15 11:15:30.721  - info: zigbee.0 (11102) Starting Zigbee  npm ...
                2025-01-15 11:15:30.745  - info: zigbee.0 (11102) Installed Version: iobroker.zigbee@1.10.14
                2025-01-15 11:15:30.950  - error: zigbee.0 (11102) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                2025-01-15 11:15:30.951  - error: zigbee.0 (11102) Failed to start Zigbee
                2025-01-15 11:15:30.952  - error: zigbee.0 (11102) Error herdsman start
                2025-01-15 11:17:26.307  - info: admin.0 (10416) ==> Connected system.user.admin from ::ffff:192.168.178.25
                2025-01-15 11:17:26.588  - info: zigbee.0 (11102) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"d0b9e07e2555ef11b        63a5b73cc32aab1","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d0b9e07e2555ef11b63a5b73cc32aab1-if00-port0","vendorId":"10c4","productId"        :"ea60"}]
                2025-01-15 11:21:21.352  - info: admin.0 (10416) <== Disconnect system.user.admin from ::ffff:192.168.178.25
                2025-01-15 11:21:21.366  - info: admin.0 (10416) <== Disconnect system.user.admin from ::ffff:192.168.178.25 admin
                iob diag has finished.
                Press any key for a summary
                  Die Werte aus den
                  musst du jetzt in der Instanz einstellen.
                  Dann sollte sich zumindest der Eintrag zu
                  erledigen.
                    Das wars, er ist grün, ich werd bekloppt, kannst du mir das für mich als noob bitte erklären? Ich hab doch alles komplett neu eingerichtet usw, warum muss ich da solche werte aus logs eintragen?
                    Asgothian Homoran 2 Replies Last reply Reply Quote 0
                    • Asgothian
                      Asgothian Developer @Fruchtzwergi last edited by
                      Ich kann dir das erklären:
                      wenn du den Adapter aufsetzt und das erste mal mit eingetragenem Seriellen port startest wird er durchstarten - dabei braucht er für den ersten Start nach der Installation durchaus 1 - 2 Minuten, und wird ggf. 1. neu gestartet. In diesem Zusammenhang wird auch die Konfiguration des Systems gespeichert (nvbackup.json)
                      Wenn du in der Folge die Konfiguration anpasst dann stimmt die Konfiguration nicht mehr mit der abgesicherten überein. Um nicht 'aus versehen' das Zigbee Netz zu zerstören wird der Adapter in diesem Zustand nicht gestartet, sondern es kommt die Meldung über die unpassend Konfiguration.
                      An dieser Stelle gibt es 2 Möglichkeiten das zu lösen:
                      • Adapter anhalten, Dateien löschen (shepherd.db, nvbackup.json), Adapter starten. In diesem Fall muss man alle Geräte neu anlernen
                      • Adapter anhalten, Konfiguration so anpassen das sie zum nvbackup.json passt, Adapter starten. In diesem Fall bleibt das Netz erhalten.
                      An die notwendigen Werte kommt man manuell (wie ich geschrieben hatte) oder die neuste Version des iobroker Diag Skript, wie @Thomas-Braun geschrieben hat.
                      A.
                        Homoran Global Moderator Administrators @Fruchtzwergi last edited by
                        @fruchtzwergi Das wäre so als ob du dir eine neue Haustür einbaust.
                        kann man machen, aber wenn du mit dem alten Schlüssel ins Haus willst, musst du das Schloss zurücktauschen.
                          Anders herum. Das Schloss ist das alte geblieben, du musst dir einen Nachschlüssel mit dem dazu passenden Bart fertigen.
                          1.2k
                          591
