    4. [HOW-TO] backitup Konfiguration mit nfs
    • N
      norbert999 @Homoran last edited by
      @homoran said in [HOW-TO] backitup Konfiguration mit nfs:
      Run iobroker start to start ioBroker again!
      pi@raspi5:~ $ iobroker start
      pi@raspi5:~ $ iob status
      Objects type: jsonl
      States  type: jsonl
      pi@raspi5:~ $
      Jetzt geht der iob status, der definitiv vorher nicht ging!
        Homoran Global Moderator Administrators @norbert999 last edited by
        @norbert999 sagte in [HOW-TO] backitup Konfiguration mit nfs:
        da war ja auch alles massiv verbogen
        • N
          @thomas-braun said in [HOW-TO] backitup Konfiguration mit nfs:
          Jag den Fixer mal über das System
          Fixer habe ich erfolgreich ausgeführt. Danach nochmal iob diag:
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: raspi5
                 Icon name: computer
                    Kernel: Linux 6.6.62+rpt-rpi-2712
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           09:58:28 up 1 min,  4 users,  load average: 5.60, 2.02, 0.73
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Wed 2025-01-15 09:58:28 CET
                     Universal time: Wed 2025-01-15 08:58:28 UTC
                           RTC time: Wed 2025-01-15 08:58:29
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            8.4G        1.9G        5.4G         39M        1.2G        6.5G
          Swap:           536M          0B        536M
          Total:          9.0G        1.9G        5.9G
          Active iob-Instances:   12
                   8052 M total memory
                   1854 M used memory
                   2143 M active memory
                    505 M inactive memory
                   5134 M free memory
                     59 M buffer memory
                   1132 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          top - 09:58:29 up 1 min,  4 users,  load average: 5.60, 2.02, 0.73
          Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8052.2 total,   5133.2 free,   1855.9 used,   1192.1 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6196.3 avail Mem
          *** FAILED SERVICES ***
            UNIT               LOAD   ACTIVE SUB    DESCRIPTION
          * nut-server.service loaded failed failed Network UPS Tools - power devices information server
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                            Type      Size  Used Avail Use% Mounted on
          udev                                  devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs                                 tmpfs     806M  6.2M  800M   1% /run
          /dev/sda2                             ext4       29G   10G   18G  37% /
          tmpfs                                 tmpfs     4.0G  3.3M  4.0G   1% /dev/shm
          tmpfs                                 tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/sda1                             vfat      510M   67M  444M  14% /boot/firmware
          192.168.1.12:/share/backup_raspi5     nfs       5.4T  3.0T  2.4T  56% /opt/iobroker/backups
          192.168.1.12:/share/backup_raspberry5 nfs       5.4T  3.0T  2.4T  56% /backup
          tmpfs                                 tmpfs     806M  192K  806M   1% /run/user/1000
          [Wed Jan 15 09:56:40 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:8D:08:0B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1cf07110-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
          [Wed Jan 15 09:56:45 2025] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
          [Wed Jan 15 09:56:46 2025] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET                  SOURCE                                FSTYPE      OPTIONS
          /                       /dev/sda2                             ext4        rw,noatime
          |-/run/user/1000/doc    portal                                fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          |-/boot/firmware        /dev/sda1                             vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          |-/opt/iobroker/backups 192.168.1.12:/share/backup_raspi5     nfs         rw,nosuid,nodev,noexec,relatime,sync,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=all,addr=192.168.1.12
          `-/backup               192.168.1.12:/share/backup_raspberry5 nfs         rw,nosuid,nodev,noexec,relatime,sync,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=all,addr=192.168.1.12
          /var:
          1.6G    /var/
          482M    /var/cache
          476M    /var/cache/apt
          361M    /var/cache/apt/archives
          354M    /var/log
          Archived and active journals take up 332.6M in the file system.
          /opt/iobroker/backups:
          64M     /opt/iobroker/backups/
          16K     /opt/iobroker/backups/.@__thumb
          12K     /opt/iobroker/backups/@Recycle
          8.0K    /opt/iobroker/backups/raspi5
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          1007M   /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          15M     /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          raspi5              raspi5 (version: 7.0.6, hostname: raspi5        , alive, uptime: 72)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.4.10
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
          + system.adapter.discovery.0              : discovery             : raspi5                                   -  enabled
            system.adapter.dwd.0                    : dwd                   : raspi5                                   -  enabled
            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspi5                                   -  enabled
            system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspi5                                   -  enabled
            system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : raspi5                                   -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : raspi5                                   -  enabled
          + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
          + system.adapter.nut.0                    : nut                   : raspi5                                   -  enabled
            system.adapter.pi-hole.0                : pi-hole               : raspi5                                   -  enabled
            system.adapter.pushover.0               : pushover              : raspi5                                   -  enabled
          + system.adapter.snmp.0                   : snmp                  : raspi5                                   -  enabled
          + system.adapter.snmp.1                   : snmp                  : raspi5                                   -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspi5                                   -  enabled
            system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
            system.adapter.vis-2.0                  : vis-2                 : raspi5                                   -  enabled
            system.adapter.vis.0                    : vis                   : raspi5                                   -  enabled
            system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "snmp"         : 3.2.0    , installed 3.2.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        7241
          States:         5787
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8348       921/pihole-FTL
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4884       822/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8334       974/lighttpd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5920       812/cupsd
          tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        8354       921/pihole-FTL
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7816       1217/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9732       1217/iobroker.js-co
          tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          7090       824/unbound
          tcp        0      0 192.168.1.6:2001        0.0.0.0:*               LISTEN      1001       14578      2412/io.hm-rpc.0
          tcp        0      0 192.168.1.6:2010        0.0.0.0:*               LISTEN      1001       13581      2452/io.hm-rpc.1
          tcp6       0      0 :::53                   :::*                    LISTEN      999        8350       921/pihole-FTL
          tcp6       0      0 :::22                   :::*                    LISTEN      0          4886       822/sshd: /usr/sbin
          tcp6       0      0 :::80                   :::*                    LISTEN      0          8333       974/lighttpd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13362      1584/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13700      2575/io.web.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      995        10517      897/influxd
          tcp6       0      0 ::1:4711                :::*                    LISTEN      999        8355       921/pihole-FTL
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5919       812/cupsd
          tcp6       0      0 :::3000                 :::*                    LISTEN      113        9167       1216/grafana
          udp        0      0 0.0.0.0:55571           0.0.0.0:*                           1001       13679      2366/io.snmp.0
          udp        0      0 0.0.0.0:43935           0.0.0.0:*                           104        6932       561/avahi-daemon: r
          udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8347       921/pihole-FTL
          udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          7089       824/unbound
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6930       561/avahi-daemon: r
          udp        0      0 0.0.0.0:50633           0.0.0.0:*                           1001       12860      2377/io.snmp.1
          udp6       0      0 :::44673                :::*                                104        6933       561/avahi-daemon: r
          udp6       0      0 :::53                   :::*                                999        8349       921/pihole-FTL
          udp6       0      0 fe80::f0ae:1c2a:23c:546 :::*                                0          6011       777/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        6931       561/avahi-daemon: r
          2025-01-15 09:58:30.841  - info: pi-hole.0 (2784) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v20.18.1, js-controller: 7.0.6
          2025-01-15 09:58:33.986  - info: host.raspi5 instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 2885
          2025-01-15 09:58:34.908  - info: energiefluss-erweitert.0 (2885) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.1, js-controller: 7.0.6
          2025-01-15 09:58:34.927  - info: energiefluss-erweitert.0 (2885) Adapter started. Loading config!
          2025-01-15 09:58:35.312  - info: energiefluss-erweitert.0 (2885) Configuration loaded!
          2025-01-15 09:58:35.313  - info: energiefluss-erweitert.0 (2885) Requesting the following states: energiefluss-erweitert.0.configuration,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerPV.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerLoad.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerFeedIn.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.BattSOC.value,0_userdata.0.Photovoltaik.BattLoadState,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerBattCharge.value,0_userdata.0.Photovoltaik.BattCapac,energiefluss-erweitert.0.calculation.battery.remaining,0_userdata.0.Photovoltaik.FlowSelfConsumption,0_userdata.0.Photovoltaik.PowerIntoGrid,0_userdata.0.Photovoltaik.BattMinDischarge,0_userdata.0.Photovoltaik.FlowBattCharge
          2025-01-15 09:58:35.941  - info: web.0 (2575) <== Disconnect system.user.admin from ::ffff:192.168.1.209
          2025-01-15 09:58:36.090  - info: web.0 (2575) ==> Connected system.user.admin from ::ffff:192.168.1.209
          2025-01-15 09:58:37.946  - info: host.raspi5 instance system.adapter.vis-2.0 in version "2.9.64" started with pid 2931
          2025-01-15 09:58:38.730  - info: vis-2.0 (2931) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.1, js-controller: 7.0.6
          2025-01-15 09:58:38.889  - info: vis-2.0 (2931) vis-2 license is OK.
          2025-01-15 09:58:42.004  - info: host.raspi5 instance scheduled system.adapter.dwd.0 */5 * * * *
          2025-01-15 09:58:42.007  - info: host.raspi5 instance system.adapter.dwd.0 in version "2.8.5" started with pid 2999
          2025-01-15 09:58:42.953  - info: dwd.0 (2999) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.6
          2025-01-15 09:58:43.273  - info: dwd.0 (2999) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-01-15 09:58:43.799  - info: host.raspi5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-01-15 09:58:48.496  - info: vis.0 (3014) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.6
          2025-01-15 09:58:50.064  - info: host.raspi5 instance system.adapter.pushover.0 in version "4.1.0" started with pid 3046
          2025-01-15 09:58:51.750  - info: pushover.0 (3046) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v20.18.1, js-controller: 7.0.6
          2025-01-15 09:58:52.051  - info: vis.0 (3014) Terminated (NO_ERROR): Without reason
          2025-01-15 09:58:52.588  - info: host.raspi5 instance system.adapter.vis.0 terminated while should be started once
          2025-01-15 09:58:53.946  - info: host.raspi5 instance system.adapter.fronius-wattpilot.0 in version "4.6.3" started with pid 3078
          2025-01-15 09:58:54.866  - info: fronius-wattpilot.0 (3078) starting. Version 4.6.3 in /opt/iobroker/node_modules/iobroker.fronius-wattpilot, node: v20.18.1, js-controller: 7.0.6
          2025-01-15 09:58:54.880  - info: fronius-wattpilot.0 (3078) Try to connect to: ws://192.168.1.132/ws
          2025-01-15 09:58:56.402  - info: fronius-wattpilot.0 (3078) Connected!
          Siehts jetzt besser aus?
            Thomas Braun Most Active @norbert999 last edited by Thomas Braun
            • nut-server.service loaded failed failed Network UPS Tools - power devices information server*** FAILED SERVICES ***
            Musst du dir anschauen.
            Die NFS-Freigaben auf dem Host 192.168.1.12 musst du dir auch anschauen. Da stimmt was mit den Rechten und/oder Versionen nicht.
            Näheres hier: https://wiki.ubuntuusers.de/NFS/ Insbesondere unter 'Problembehebung' schauen.
            • N
              norbert999 @Thomas Braun last edited by
              Ich kriege es einfach nicht hin.
              Habe jetzt folgendes gemacht: Neues, frisches OS auf raspi installiert. Dazu noch iob installiert mit 2 Adaptern, dass da was drin ist.
              Dann habe ich raspiBackup installiert. Habe das Verzeichnis /backup auf dem raspi erstellt und den QNAP share statisch über fstab gemounted.
              Wenn ich nun raspiBackup starte, gibt es wie immer eine Rechte-Fehlermeldung.
              Ich bitte um Hilfe, bin am verzweifeln. Es kann doch nicht sein, dass das mit frischem OS immer noch nicht funzt.
              Hier die Ausgabe:
              pi@raspi5:/backup $ sudo raspiBackup
              --- RBK0009I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:53:50 CET 2025 gestartet.
              ??? RBK0266E: Es fehlt die Berechtigung um Linux Dateiattribute auf /backup zu erstellen (Dateisystem: nfs).
              --- RBK0033I: Bitte warten bis aufgeräumt wurde.
              --- RBK0043I: Unvollständiges Backup in /backup/raspi5/raspi5-rsync-backup-20250115-145350 wird gelöscht. Das kann etwas dauern. Bitte Geduld.
              ??? RBK0005E: Backup fehlerhaft beendet. Siehe vorhergehende Fehlermeldungen.
              --- RBK0010I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:54:03 CET 2025 beendet mit Returncode 102.
              --- RBK0026I: Debug Logdatei wurde in /home/pi/raspiBackup.log gesichert.
              pi@raspi5:/backup $ more /home/pi/raspiBackup.log
              20250115-145350 DBG 2101:  --- Logfiles used: /tmp/raspiBackup.log and /tmp/raspiBackup.msg
              20250115-145350 DBG 2112:  --- raspiBackup.sh 0.6.9.1, 2024-09-28/22:55:07 - be4ba6d
              20250115-145350 DBG 2115:  --- +================================================================================================================
              20250115-145350 DBG 2116:  --- | ===> A lot of sensitive information is masqueraded in this log file. Nevertheless please check the log carefull
              y before you distribute it <=== |
              20250115-145350 DBG 2117:  --- +================================================================================================================
              20250115-145350 DBG 1943:  --> trapWithArg cleanupStartup SIGINT SIGTERM EXIT
              20250115-145350 DBG 1948:  <-- trapWithArg
              20250115-145350 DBG 3813:  --> readConfigParameters
              20250115-145350 DBG 3511:      --> extractVersionFromFile /usr/local/etc/raspiBackup.conf VERSION_.*CONF.*
              20250115-145350 DBG 3515:      <-- extractVersionFromFile 0.1.8
              20250115-145350 DBG 3840:      --- Read config /usr/local/etc/raspiBackup.conf : 0.1.8
              20250115-145350 DBG 3840:      --- VERSION_CONFIG="0.1.8"
              20250115-145350 DBG 3840:      --- DEFAULT_BACKUPPATH="/backup"
              20250115-145350 DBG 3840:      --- DEFAULT_BACKUPTYPE="rsync"
              20250115-145350 DBG 3840:      --- DEFAULT_ZIP_BACKUP="0"
              20250115-145350 DBG 3840:      --- DEFAULT_DD_BACKUP_SAVE_USED_PARTITIONS_ONLY=0
              20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS="10"
              20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_DD=0
              20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_DDZ=0
              20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_TAR=0
              20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_TGZ=0
              20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_RSYNC=0
              20250115-145350 DBG 3840:      --- DEFAULT_SMART_RECYCLE="0"
              20250115-145350 DBG 3840:      --- DEFAULT_SMART_RECYCLE_DRYRUN="1"
              20250115-145350 DBG 3840:      --- DEFAULT_SMART_RECYCLE_OPTIONS="7 4 12 1"
              20250115-145350 DBG 3840:      --- DEFAULT_STOPSERVICES=":"
              20250115-145350 DBG 3840:      --- DEFAULT_STARTSERVICES=":"
              20250115-145350 DBG 3840:      --- DEFAULT_BEFORE_STOPSERVICES=""
              20250115-145350 DBG 3840:      --- DEFAULT_AFTER_STARTSERVICES=""
              20250115-145350 DBG 3840:      --- DEFAULT_EMAIL=""
              20250115-145350 DBG 3840:      --- DEFAULT_SENDER_EMAIL=""
              20250115-145350 DBG 3840:      --- DEFAULT_EMAIL_PARMS=""
              20250115-145350 DBG 3840:      --- DEFAULT_MAIL_PROGRAM="mail"
              20250115-145350 DBG 3840:      --- DEFAULT_TELEGRAM_TOKEN=""
              20250115-145350 DBG 3840:      --- DEFAULT_TELEGRAM_CHATID=""
              20250115-145350 DBG 3840:      --- DEFAULT_TELEGRAM_NOTIFICATIONS="F"
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_ADDITIONAL_OPTIONS=""
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_DEVICE=""
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_TOKEN=""
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_USER=""
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_NOTIFICATIONS="F"
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_SOUND_SUCCESS=""
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_SOUND_FAILURE=""
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_PRIORITY_SUCCESS="0"
              20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_PRIORITY_FAILURE="1"
              20250115-145350 DBG 3840:      --- DEFAULT_SLACK_WEBHOOK_URL=""
              20250115-145350 DBG 3840:      --- DEFAULT_SLACK_NOTIFICATIONS=""
              20250115-145350 DBG 3840:      --- DEFAULT_NOTIFY_START=0
              20250115-145350 DBG 3840:      --- DEFAULT_MAIL_ON_ERROR_ONLY=0
              20250115-145350 DBG 3840:      --- DEFAULT_MSG_LEVEL="0"
              20250115-145350 DBG 3840:      --- DEFAULT_COLORING="CM"
              20250115-145350 DBG 3840:      --- DEFAULT_EMAIL_COLORING="SUBJECT"
              20250115-145350 DBG 3840:      --- DEFAULT_COLOR_CODES=("#FF8000 33" "#FF0000 31")
              20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_DEVICE=""
              20250115-145350 DBG 3840:      --- DEFAULT_VERBOSE=0
              20250115-145350 DBG 3840:      --- DEFAULT_SKIPLOCALCHECK=0
              20250115-145350 DBG 3840:      --- DEFAULT_DD_BLOCKSIZE=1M
              20250115-145350 DBG 3840:      --- DEFAULT_DD_PARMS=""
              20250115-145350 DBG 3840:      --- DEFAULT_EXCLUDE_LIST=""
              20250115-145350 DBG 3840:      --- DEFAULT_EXTENSIONS="mem temp disk"
              20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_EXTENSIONS=""
              20250115-145350 DBG 3840:      --- DEFAULT_LANGUAGE="DE"
              20250115-145350 DBG 3840:      --- DEFAULT_DEPLOYMENT_HOSTS=""
              20250115-145350 DBG 3840:      --- DEFAULT_RESIZE_ROOTFS=1
              20250115-145350 DBG 3840:      --- DEFAULT_LINK_BOOTPARTITIONFILES=0
              20250115-145350 DBG 3840:      --- DEFAULT_TAR_BOOT_PARTITION_ENABLED=0
              20250115-145350 DBG 3840:      --- DEFAULT_SKIP_DEPRECATED=""
              20250115-145350 DBG 3840:      --- DEFAULT_CHECK_FOR_BAD_BLOCKS=0
              20250115-145350 DBG 3840:      --- DEFAULT_TIMESTAMPS=0
              20250115-145350 DBG 3840:      --- DEFAULT_SYSTEMSTATUS=0
              20250115-145350 DBG 3840:      --- DEFAULT_REBOOT_SYSTEM=0
              20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_REMINDER_INTERVAL=6
              20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_REMINDER_REPEAT=3
              20250115-145350 DBG 3840:      --- DEFAULT_OLD_REMINDER_REPEAT="5"
              20250115-145350 DBG 3840:      --- DEFAULT_PARTITIONBASED_BACKUP="1"
              20250115-145350 DBG 3840:      --- DEFAULT_PARTITIONS_TO_BACKUP="1 2"
              20250115-145350 DBG 3840:      --- DEFAULT_PARTITIONS_TO_RESTORE="1 2"
              20250115-145350 DBG 3840:      --- DEFAULT_DYNAMIC_MOUNT=""
              20250115-145350 DBG 3870:  <-- readConfigParameters
              20250115-145350 DBG 2660:  --> logOptions Standard option files
              20250115-145350 DBG 2662:      --- Options:
              20250115-145350 DBG 2663:      --- AFTER_STARTSERVICES=
              20250115-145350 DBG 2664:      --- APPEND_LOG=0
              20250115-145350 DBG 2665:      --- APPEND_LOG_OPTION=-a
              20250115-145350 DBG 2666:      --- BACKUPPATH=/backup
              20250115-145350 DBG 2667:      --- BACKUPTYPE=rsync
              20250115-145350 DBG 2668:      --- BEFORE_STOPSERVICES=
              20250115-145350 DBG 2669:      --- BOOT_DEVICE=
              20250115-145350 DBG 2670:      --- CHECK_FOR_BAD_BLOCKS=0
              20250115-145350 DBG 2671:      --- COLOR_CODES=#FF8000 33 #FF0000 31
              20250115-145350 DBG 2672:      --- COLORING=CM
              20250115-145350 DBG 2673:      --- CONFIG_FILE=
              20250115-145350 DBG 2674:      --- DD_BACKUP_SAVE_USED_PARTITIONS_ONLY=0
              20250115-145350 DBG 2675:      --- DD_BLOCKSIZE=1M
              20250115-145350 DBG 2676:      --- DD_PARMS=
              20250115-145350 DBG 2677:      --- DD_WARNING=0
              20250115-145350 DBG 2678:      --- DEPLOYMENT_HOSTS=
              20250115-145350 DBG 2679:      --- DYNAMIC_MOUNT=
              20250115-145350 DBG 2680:      --- EMAIL=
              20250115-145350 DBG 2681:      --- EMAIL_COLORING=SUBJECT
              20250115-145350 DBG 2682:      --- EMAIL_PARMS=
              20250115-145350 DBG 2683:      --- EXCLUDE_LIST=
              20250115-145350 DBG 2684:      --- EXTENSIONS=mem temp disk
              20250115-145350 DBG 2685:      --- FAKE=0
              20250115-145350 DBG 2686:      --- FINAL_COMMAND=
              20250115-145350 DBG 2687:      --- HANDLE_DEPRECATED=
              20250115-145350 DBG 2688:      --- IGNORE_ADDITIONAL_PARTITIONS=0
              20250115-145350 DBG 2689:      --- KEEPBACKUPS=10
              20250115-145350 DBG 2690:      --- KEEPBACKUPS_DD=0
              20250115-145350 DBG 2691:      --- KEEPBACKUPS_DDZ=0
              20250115-145350 DBG 2692:      --- KEEPBACKUPS_TAR=0
              20250115-145350 DBG 2693:      --- KEEPBACKUPS_TGZ=0
              20250115-145350 DBG 2694:      --- KEEPBACKUPS_RSYNC=0
              20250115-145350 DBG 2695:      --- LANGUAGE=EN
              20250115-145350 DBG 2696:      --- LINK_BOOTPARTITIONFILES=0
              20250115-145350 DBG 2697:      --- LOG_LEVEL=1
              20250115-145350 DBG 2698:      --- LOG_OUTPUT=2
              20250115-145350 DBG 2699:      --- MAIL_ON_ERROR_ONLY=0
              20250115-145350 DBG 2700:      --- MAIL_PROGRAM=mail
              20250115-145350 DBG 2701:      --- MSG_LEVEL=0
              20250115-145350 DBG 2702:      --- NOTIFY_START=0
              20250115-145350 DBG 2703:      --- NOTIFY_UPDATE=1
              20250115-145350 DBG 2704:      --- PARTITIONBASED_BACKUP=1
              20250115-145350 DBG 2705:      --- PARTITIONS_TO_BACKUP=1 2
              20250115-145350 DBG 2706:      --- PUSHOVER_TOKEN=
              20250115-145350 DBG 2707:      --- PUSHOVER_USER=
              20250115-145350 DBG 2708:      --- PUSHOVER_NOTIFICATIONS=F
              20250115-145350 DBG 2709:      --- PUSHOVER_SOUND_SUCCESS=
              20250115-145350 DBG 2710:      --- PUSHOVER_SOUND_FAILURE=
              20250115-145350 DBG 2711:      --- PUSHOVER_PRIORITY_SUCCESS=0
              20250115-145350 DBG 2712:      --- PUSHOVER_PRIORITY_FAILURE=1
              20250115-145350 DBG 2713:      --- REBOOT_SYSTEM=0
              20250115-145350 DBG 2714:      --- RESIZE_ROOTFS=1
              20250115-145350 DBG 2715:      --- RESTORE_DEVICE=
              20250115-145350 DBG 2716:      --- RESTORE_EXTENSIONS=
              20250115-145350 DBG 2717:      --- ROOT_PARTITION=
              20250115-145350 DBG 2718:      --- RSYNC_BACKUP_ADDITIONAL_OPTIONS=
              20250115-145350 DBG 2719:      --- RSYNC_BACKUP_OPTIONS=-aHAx --delete
              20250115-145350 DBG 2720:      --- RSYNC_IGNORE_ERRORS=
              20250115-145350 DBG 2721:      --- SENDER_EMAIL=
              20250115-145350 DBG 2722:      --- SKIP_DEPRECATED=
              20250115-145350 DBG 2723:      --- SKIPLOCALCHECK=0
              20250115-145350 DBG 2724:      --- SLACK_WEBHOOK_URL=
              20250115-145350 DBG 2725:      --- SLACK_NOTIFICATIONS=
              20250115-145350 DBG 2726:      --- SMART_RECYCLE=0
              20250115-145350 DBG 2727:      --- SMART_RECYCLE_DRYRUN=1
              20250115-145350 DBG 2728:      --- SMART_RECYCLE_OPTIONS=7 4 12 1
              20250115-145350 DBG 2729:      --- STARTSERVICES=:
              20250115-145350 DBG 2730:      --- STOPSERVICES=:
              20250115-145350 DBG 2731:      --- SYSTEMSTATUS=0
              20250115-145350 DBG 2732:      --- TAR_BACKUP_ADDITIONAL_OPTIONS=
              20250115-145350 DBG 2733:      --- TAR_BACKUP_OPTIONS=-cpi --one-file-system
              20250115-145350 DBG 2734:      --- TAR_BOOT_PARTITION_ENABLED=0
              20250115-145350 DBG 2735:      --- TAR_IGNORE_ERRORS=
              20250115-145350 DBG 2736:      --- TAR_RESTORE_ADDITIONAL_OPTIONS=
              20250115-145350 DBG 2737:      --- TELEGRAM_TOKEN=
              20250115-145350 DBG 2738:      --- TELEGRAM_CHATID=
              20250115-145350 DBG 2739:      --- TELEGRAM_NOTIFICATIONS=F
              20250115-145350 DBG 2740:      --- TIMESTAMPS=0
              20250115-145350 DBG 2741:      --- UPDATE_UUIDS=1
              20250115-145350 DBG 2742:      --- VERBOSE=0
              20250115-145350 DBG 2743:      --- YES_NO_RESTORE_DEVICE=loop
              20250115-145350 DBG 2744:      --- ZIP_BACKUP=0
              20250115-145350 DBG 2746:  <-- logOptions
              20250115-145350 DBG 2388:  --> isSupportedEnvironment
              20250115-145350 DBG 2405:      --- PRETTY_NAME="Debian GNU/Linux 12 (bookworm)" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)"
              VERSION_CODENAME=bookworm ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs
              .debian.org/"
              20250115-145350 DBG 2410:      --- IS_UBUNTU: 0
              20250115-145350 DBG 2418:      --- Modelpath: Raspberry Pi 5 Model B Rev 1.0
              20250115-145350 DBG 2423:      --- /etc/rpi-issue: Raspberry Pi reference 2024-11-19
              20250115-145350 DBG 2423:      --- Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 891df1e21ed2b6099a2e6a13e26c91dea44b34d4, stage
              20250115-145350 DBG 2424:  <-- isSupportedEnvironment 0
              20250115-145350 DBG 8738:  --> check4RequiredCommands
              20250115-145350 DBG 8759:  <-- check4RequiredCommands
              20250115-145350 DBG 9570:  --- RESTORE: 0 - fileParameter:
              20250115-145350 DBG 9591:  --- Enabling trap handler
              20250115-145350 DBG 1943:  --> trapWithArg cleanup SIGINT SIGTERM EXIT
              20250115-145350 DBG 4754:  --> lockMe
              20250115-145350 DBG 4756:  <-- lockMe
              --- RBK0009I: @HOSTNAME@: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:53:50 CET 2025 gestartet.
              20250115-145350 DBG 3875:  --> setupEnvironment
              20250115-145350 DBG 3935:      --- BACKUPTARGET_DIR: /backup/@HOSTNAME@/@HOSTNAME@-rsync-backup-20250115-145350
              20250115-145350 DBG 3936:      --- BACKUPTARGET_FILE: /backup/@HOSTNAME@/@HOSTNAME@-rsync-backup-20250115-145350/@HOSTNAME@-rsync-backup-2025011
              5-145350
              20250115-145350 DBG 3938:  <-- setupEnvironment
              20250115-145350 DBG 9628:  --- Read config /usr/local/etc/raspiBackup.conf : 0.1.8
              20250115-145350 DBG 9628:  --- VERSION_CONFIG="0.1.8"
              20250115-145350 DBG 9628:  --- DEFAULT_BACKUPPATH="/backup"
              20250115-145350 DBG 9628:  --- DEFAULT_BACKUPTYPE="rsync"
              20250115-145350 DBG 9628:  --- DEFAULT_ZIP_BACKUP="0"
              20250115-145350 DBG 9628:  --- DEFAULT_DD_BACKUP_SAVE_USED_PARTITIONS_ONLY=0
              20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS="10"
              20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_DD=0
              20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_DDZ=0
              20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_TAR=0
              20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_TGZ=0
              20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_RSYNC=0
              20250115-145350 DBG 9628:  --- DEFAULT_SMART_RECYCLE="0"
              20250115-145350 DBG 9628:  --- DEFAULT_SMART_RECYCLE_DRYRUN="1"
              20250115-145350 DBG 9628:  --- DEFAULT_SMART_RECYCLE_OPTIONS="7 4 12 1"
              20250115-145350 DBG 9628:  --- DEFAULT_STOPSERVICES=":"
              20250115-145350 DBG 9628:  --- DEFAULT_STARTSERVICES=":"
              20250115-145350 DBG 9628:  --- DEFAULT_BEFORE_STOPSERVICES=""
              20250115-145350 DBG 9628:  --- DEFAULT_AFTER_STARTSERVICES=""
              20250115-145350 DBG 9628:  --- DEFAULT_EMAIL=""
              20250115-145350 DBG 9628:  --- DEFAULT_SENDER_EMAIL=""
              20250115-145350 DBG 9628:  --- DEFAULT_EMAIL_PARMS=""
              20250115-145350 DBG 9628:  --- DEFAULT_MAIL_PROGRAM="mail"
              20250115-145350 DBG 9628:  --- DEFAULT_TELEGRAM_TOKEN=""
              20250115-145350 DBG 9628:  --- DEFAULT_TELEGRAM_CHATID=""
              20250115-145350 DBG 9628:  --- DEFAULT_TELEGRAM_NOTIFICATIONS="F"
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_ADDITIONAL_OPTIONS=""
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_DEVICE=""
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_TOKEN=""
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_USER=""
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_NOTIFICATIONS="F"
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_SOUND_SUCCESS=""
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_SOUND_FAILURE=""
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_PRIORITY_SUCCESS="0"
              20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_PRIORITY_FAILURE="1"
              20250115-145350 DBG 9628:  --- DEFAULT_SLACK_WEBHOOK_URL=""
              20250115-145350 DBG 9628:  --- DEFAULT_SLACK_NOTIFICATIONS=""
              20250115-145350 DBG 9628:  --- DEFAULT_NOTIFY_START=0
              20250115-145350 DBG 9628:  --- DEFAULT_MAIL_ON_ERROR_ONLY=0
              20250115-145350 DBG 9628:  --- DEFAULT_MSG_LEVEL="0"
              20250115-145350 DBG 9628:  --- DEFAULT_COLORING="CM"
              20250115-145350 DBG 9628:  --- DEFAULT_EMAIL_COLORING="SUBJECT"
              20250115-145350 DBG 9628:  --- DEFAULT_COLOR_CODES=("#FF8000 33" "#FF0000 31")
              20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_DEVICE=""
              20250115-145350 DBG 9628:  --- DEFAULT_VERBOSE=0
              20250115-145350 DBG 9628:  --- DEFAULT_SKIPLOCALCHECK=0
              20250115-145350 DBG 9628:  --- DEFAULT_DD_BLOCKSIZE=1M
              20250115-145350 DBG 9628:  --- DEFAULT_DD_PARMS=""
              20250115-145350 DBG 9628:  --- DEFAULT_EXCLUDE_LIST=""
              20250115-145350 DBG 9628:  --- DEFAULT_EXTENSIONS="mem temp disk"
              20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_EXTENSIONS=""
              20250115-145350 DBG 9628:  --- DEFAULT_LANGUAGE="DE"
              20250115-145350 DBG 9628:  --- DEFAULT_DEPLOYMENT_HOSTS=""
              20250115-145350 DBG 9628:  --- DEFAULT_RESIZE_ROOTFS=1
              20250115-145350 DBG 9628:  --- DEFAULT_LINK_BOOTPARTITIONFILES=0
              20250115-145350 DBG 9628:  --- DEFAULT_TAR_BOOT_PARTITION_ENABLED=0
              20250115-145350 DBG 9628:  --- DEFAULT_SKIP_DEPRECATED=""
              20250115-145350 DBG 9628:  --- DEFAULT_CHECK_FOR_BAD_BLOCKS=0
              20250115-145350 DBG 9628:  --- DEFAULT_TIMESTAMPS=0
              20250115-145350 DBG 9628:  --- DEFAULT_SYSTEMSTATUS=0
              20250115-145350 DBG 9628:  --- DEFAULT_REBOOT_SYSTEM=0
              20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_REMINDER_INTERVAL=6
              20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_REMINDER_REPEAT=3
              20250115-145350 DBG 9628:  --- DEFAULT_OLD_REMINDER_REPEAT="5"
              20250115-145350 DBG 9628:  --- DEFAULT_PARTITIONBASED_BACKUP="1"
              20250115-145350 DBG 9628:  --- DEFAULT_PARTITIONS_TO_BACKUP="1 2"
              20250115-145350 DBG 9628:  --- DEFAULT_PARTITIONS_TO_RESTORE="1 2"
              20250115-145350 DBG 9628:  --- DEFAULT_DYNAMIC_MOUNT=""
              20250115-145350 DBG 2660:  --> logOptions Invocation options
              20250115-145350 DBG 2695:      --- LANGUAGE=DE
              20250115-145350 DBG 2033:  --> logSystem
              20250115-145350 DBG 2034:          *** uname -a
              20250115-145350 DBG 2034:              Linux @HOSTNAME@ 6.6.62+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64 GNU/Linux
              20250115-145350 DBG 2035:          *** cat /etc/os-release
              20250115-145350 DBG 2035:              PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
              20250115-145350 DBG 2035:              NAME="Debian GNU/Linux"
              20250115-145350 DBG 2035:              VERSION_ID="12"
              20250115-145350 DBG 2035:              VERSION="12 (bookworm)"
              20250115-145350 DBG 2035:              VERSION_CODENAME=bookworm
              20250115-145350 DBG 2035:              ID=debian
              20250115-145350 DBG 2035:              HOME_URL="https://www.debian.org/"
              20250115-145350 DBG 2035:              SUPPORT_URL="https://www.debian.org/support"
              20250115-145350 DBG 2035:              BUG_REPORT_URL="https://bugs.debian.org/"
              20250115-145350 DBG 2036:          *** cat /etc/debian_version
              20250115-145350 DBG 2036:              12.9
              20250115-145350 DBG 2037:          *** cat /etc/fstab
              20250115-145350 DBG 2037:              proc            /proc           proc    defaults          0       0
              20250115-145350 DBG 2037:              PARTUUID=3ee3f3c5-01  /boot/firmware  vfat    defaults          0       2
              20250115-145350 DBG 2037:              PARTUUID=3ee3f3c5-02  /               ext4    defaults,noatime  0       1
              20250115-145350 DBG 2037:              # pount point for QNAP NAS used in rsync backup.
              20250115-145350 DBG 2037:              # inserted by nt Jan 15, 2025
              20250115-145350 DBG 2037:              192.168.1.12:/share/backup_@HOSTNAME@ /backup nfs rw     0       0
              20250115-145350 DBG 2037:              # a swapfile is not a swap partition, no line here
              20250115-145350 DBG 2037:              #   use  dphys-swapfile swap[on|off]  for that
              20250115-145350 DBG 2038:          *** locale
              20250115-145350 DBG 2038:              LANG=en_GB.UTF-8
              20250115-145350 DBG 2038:              LANGUAGE=
              20250115-145350 DBG 2038:              LC_CTYPE="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_NUMERIC="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_TIME="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_COLLATE="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_MONETARY="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_MESSAGES="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_PAPER="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_NAME="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_ADDRESS="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_TELEPHONE="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_MEASUREMENT="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_IDENTIFICATION="en_GB.UTF-8"
              20250115-145350 DBG 2038:              LC_ALL=
              20250115-145350 DBG 2039:  <-- logSystem
              20250115-145350 DBG 3134:  --> downloadPropertiesFile
              20250115-145350 DBG 3226:      --> shouldRenewDownloadPropertiesFile
              20250115-145350 DBG 3240:          --- 20250115 : 20250115
              20250115-145350 DBG 3243:          --- Skip download
              20250115-145350 DBG 3249:      <-- shouldRenewDownloadPropertiesFile 1
              20250115-145350 DBG 3171:  <-- downloadPropertiesFile 0
              20250115-145350 DBG 8125:  --> updateRestoreReminder
              20250115-145350 DBG 8173:  <-- updateRestoreReminder
              20250115-145350 DBG 6876:  --> reportNews
              20250115-145350 DBG 3113:      --> isUpdatePossible
              20250115-145350 DBG 3354:          --> isNewVersionAvailable
              20250115-145350 DBG 3368:              --- Versionsplit: 0.6.9.1 -
              20250115-145350 DBG 3397:              --- Returning: 0.0 0.0 0.6.9.1
              20250115-145350 DBG 3399:          <-- isNewVersionAvailable 99
              20250115-145350 DBG 3128:      <-- isUpdatePossible
              20250115-145350 DBG 5021:      --> isBetaAvailable
              20250115-145350 DBG 5031:      <-- isBetaAvailable
              20250115-145350 DBG 6893:  <-- reportNews
              20250115-145350 DBG 3204:  --> isVersionDeprecated
              20250115-145350 DBG 3220:  <-- isVersionDeprecated 1
              20250115-145350 DBG 6385:  --> doit
              20250115-145350 DBG 6388:      --- Startingdirectory: /backup
              20250115-145350 DBG 6389:          *** fdisk -l | grep -v ^
              20250115-145350 DBG 6389:              fdisk from util-linux 2.38.1
              20250115-145350 DBG 6390:          *** mount
              20250115-145350 DBG 6390:              sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              proc on /proc type proc (rw,relatime)
              20250115-145350 DBG 6390:              udev on /dev type devtmpfs (rw,nosuid,relatime,size=4080976k,nr_inodes=255061,mode=755)
              20250115-145350 DBG 6390:              devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
              20250115-145350 DBG 6390:              tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755)
              20250115-145350 DBG 6390:              /dev/mmcblk0p2 on / type ext4 (rw,noatime)
              20250115-145350 DBG 6390:              securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
              20250115-145350 DBG 6390:              tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
              20250115-145350 DBG 6390:              cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
              20250115-145350 DBG 6390:              pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
              20250115-145350 DBG 6390:              systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto
              =5,direct,pipe_ino=4595)
              20250115-145350 DBG 6390:              mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
              20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
              20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,
              mode=700)
              20250115-145350 DBG 6390:              /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=asci
              i,shortname=mixed,errors=remount-ro)
              20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode
              =700)
              20250115-145350 DBG 6390:              binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
              20250115-145350 DBG 6390:              sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
              20250115-145350 DBG 6390:              192.168.1.12:/share/backup_@HOSTNAME@ on /backup type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576
              ,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=none,addr=19
              2.168.1.12)
              20250115-145350 DBG 6390:              tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1
              000,gid=1000)
              20250115-145350 DBG 6390:              gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=10
              00)
              20250115-145350 DBG 6390:              portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
              20250115-145350 DBG 2379:      --> isUnsupportedVersion
              20250115-145350 DBG 2382:      <-- isUnsupportedVersion 1
              20250115-145350 DBG 6899:      --> doitBackup 1
              20250115-145350 DBG 6650:          --> getRootPartition
              20250115-145350 DBG 6655:                  *** cat /proc/cmdline
              20250115-145351 DBG 6655:                      reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=int
              erleave  smsc95xx.macaddr=2C:CF:67:56:DA:B9 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PAR
              TUUID=3ee3f3c5-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              20250115-145351 DBG 6658:              --- RootPartition: PARTUUID=3ee3f3c5-02
              20250115-145351 DBG 6662:          <-- getRootPartition PARTUUID=3ee3f3c5-02
              20250115-145351 DBG 6687:          --> inspect4Backup
              20250115-145351 DBG 6689:                  *** ls -1 /dev/mmcblk*
              20250115-145351 DBG 6689:                      /dev/mmcblk0
              20250115-145351 DBG 6689:                      /dev/mmcblk0p1
              20250115-145351 DBG 6689:                      /dev/mmcblk0p2
              20250115-145351 DBG 6690:                  *** ls -1 /dev/sd*
              20250115-145351 DBG 6690:                      ls: cannot access '/dev/sd*': No such file or directory
              20250115-145351 DBG 6691:                  *** ls -1 /dev/nvme*
              20250115-145351 DBG 6691:                      ls: cannot access '/dev/nvme*': No such file or directory
              20250115-145351 DBG 6712:              --- Starting boot discovery
              20250115-145351 DBG 6717:              --- bootMountpoint1: /boot mounted?
              20250115-145351 DBG 6722:              --- bootMountpoint2: /boot/firmware mounted? /dev/mmcblk0p1
              20250115-145351 DBG 6732:              --- bootMountpoint: /boot/firmware, bootPartition: /dev/mmcblk0p1
              20250115-145351 DBG 6734:              --- Starting root discovery
              20250115-145351 DBG 6738:              --- rootPartition: / mounted? /dev/mmcblk0p2
              20250115-145351 DBG 6674:              --> deviceInfo /dev/mmcblk0p1
              20250115-145351 DBG 6682:              <-- deviceInfo mmcblk0 1
              20250115-145351 DBG 6674:              --> deviceInfo /dev/mmcblk0p2
              20250115-145351 DBG 6682:              <-- deviceInfo mmcblk0 2
              20250115-145351 DBG 6759:              --- boot: mmcblk0 1
              20250115-145351 DBG 6760:              --- root: mmcblk0 2
              20250115-145351 DBG 6780:              --- BOOT_DEVICE: mmcblk0
              20250115-145351 DBG 6784:              --- BOOT_DEVICENAME: /dev/mmcblk0
              20250115-145351 DBG 3019:              --> getPartitionPrefix mmcblk0
              20250115-145351 DBG 3028:              <-- getPartitionPrefix mmcblk0p
              20250115-145351 DBG 6788:              --- BOOT_PARTITION_PREFIX: mmcblk0p
              20250115-145351 DBG 6791:          <-- inspect4Backup
              20250115-145351 DBG 6614:          --> commonChecks
              20250115-145351 DBG 6644:          <-- commonChecks
              20250115-145351 DBG 3747:          --> getFsType /backup
              20250115-145351 DBG 3790:              --> findMountPath /backup
              20250115-145351 DBG 3798:                  --- Path: /backup
              20250115-145351 DBG 3806:              <-- findMountPath /backup
              20250115-145351 DBG 3750:              --- Mountpoint: /backup
              20250115-145351 DBG 3753:              --- df -T: nfs
              20250115-145351 DBG 3756:          <-- getFsType nfs
              20250115-145351 DBG 6935:          --- Found partitions on /dev/mmcblk0: 2
              20250115-145351 DBG 3685:          --> supportsHardlinks /backup
              20250115-145351 DBG 3698:              --- Links: 2
              20250115-145351 DBG 3708:          <-- supportsHardlinks 0
              20250115-145351 DBG 7060:          --- Filesystem: nfs
              20250115-145351 DBG 3629:          --> supportsFileAttributes /backup
              20250115-145351 DBG 3646:              --- ----r-xrwx # nobody # nogroup
              cp: failed to preserve ownership for '//backup/raspiBackup.fileattributes': Operation not permitted
              20250115-145351 DBG 3654:              --- cp failed with rc 1 - retryCount
              cp: cannot create regular file '//backup/raspiBackup.fileattributes': Permission denied
              20250115-145354 DBG 3654:              --- cp failed with rc 1 - retryCount
              20250115-145357 DBG 3654:              --- cp failed with rc 1 - retryCount
              20250115-145400 DBG 3654:              --- cp failed with rc 1 - retryCount
              20250115-145403 DBG 3676:          <-- supportsFileAttributes 1
              20250115-145403 DBG 3790:          --> findMountPath /backup
              20250115-145403 DBG 3798:              --- Path: /backup
              20250115-145403 DBG 3806:          <-- findMountPath /backup
              20250115-145403 DBG 2529:          --> exitError 102
              20250115-145403 DBG 2536:          <-- exitError 102
              20250115-145403 DBG 4767:          --> cleanup
              20250115-145403 DBG 5037:              --> cleanupBackup
              20250115-145403 DBG 5039:                  --- Got trap EXIT
              20250115-145403 DBG 5040:                  --- rc: 102
              20250115-145403 DBG 6299:                  --> umountSDPartitions
              20250115-145403 DBG 6301:                      --- BEFORE: mount sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- proc on /proc type proc (rw,relatime)
              20250115-145403 DBG 6301:                      --- udev on /dev type devtmpfs (rw,nosuid,relatime,size=4080976k,nr_inodes=255061,mode=755)
              20250115-145403 DBG 6301:                      --- devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
              20250115-145403 DBG 6301:                      --- tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755)
              20250115-145403 DBG 6301:                      --- /dev/mmcblk0p2 on / type ext4 (rw,noatime)
              20250115-145403 DBG 6301:                      --- securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
              20250115-145403 DBG 6301:                      --- tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
              20250115-145403 DBG 6301:                      --- cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_rec
              ursiveprot)
              20250115-145403 DBG 6301:                      --- pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
              20250115-145403 DBG 6301:                      --- systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minprot
              o=5,maxproto=5,direct,pipe_ino=4595)
              20250115-145403 DBG 6301:                      --- mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,
              mode=700)
              20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatim
              e,mode=700)
              20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noex
              20250115-145403 DBG 6301:                      --- /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,io
              charset=ascii,shortname=mixed,errors=remount-ro)
              20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,r
              elatime,mode=700)
              20250115-145403 DBG 6301:                      --- binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6301:                      --- sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
              20250115-145403 DBG 6301:                      --- 192.168.1.12:/share/backup_@HOSTNAME@ on /backup type nfs (rw,relatime,vers=3,rsize=1048576,w
              size=1048576,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=
              none,addr=192.168.1.12)
              20250115-145403 DBG 6301:                      --- tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mo
              de=700,uid=1000,gid=1000)
              20250115-145403 DBG 6301:                      --- gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000
              ,group_id=1000)
              20250115-145403 DBG 6301:                      --- portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id
              =1000)
              20250115-145403 DBG 3733:                      --> isMounted /tmp/mmcblk0p1 2
              20250115-145403 DBG 3741:                      <-- isMounted 1
              20250115-145403 DBG 6313:                      --- AFTER: mount sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- proc on /proc type proc (rw,relatime)
              20250115-145403 DBG 6313:                      --- udev on /dev type devtmpfs (rw,nosuid,relatime,size=4080976k,nr_inodes=255061,mode=755)
              20250115-145403 DBG 6313:                      --- devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
              20250115-145403 DBG 6313:                      --- tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755)
              20250115-145403 DBG 6313:                      --- /dev/mmcblk0p2 on / type ext4 (rw,noatime)
              20250115-145403 DBG 6313:                      --- securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
              20250115-145403 DBG 6313:                      --- tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
              20250115-145403 DBG 6313:                      --- cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_rec
              ursiveprot)
              20250115-145403 DBG 6313:                      --- pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
              20250115-145403 DBG 6313:                      --- systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minprot
              20250115-145403 DBG 6313:                      --- mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,
              mode=700)
              20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatim
              e,mode=700)
              20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noex
              20250115-145403 DBG 6313:                      --- /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,io
              20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,r
              elatime,mode=700)
              20250115-145403 DBG 6313:                      --- binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
              20250115-145403 DBG 6313:                      --- sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
              20250115-145403 DBG 6313:                      --- 192.168.1.12:/share/backup_@HOSTNAME@ on /backup type nfs (rw,relatime,vers=3,rsize=1048576,w
              20250115-145403 DBG 6313:                      --- tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mo
              20250115-145403 DBG 6313:                      --- gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000
              ,group_id=1000)
              20250115-145403 DBG 6313:                      --- portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id
              =1000)
              20250115-145403 DBG 6315:                  <-- umountSDPartitions
              20250115-145403 DBG 3463:                  --> startServices
              20250115-145403 DBG 2052:                      --> logSystemServices
              20250115-145403 DBG 2061:                      <-- logSystemServices
              20250115-145403 DBG 3489:                  <-- startServices
              20250115-145403 DBG 3493:                  --> executeAfterStartServices
              20250115-145403 DBG 3507:                  <-- executeAfterStartServices
              20250115-145403 DBG 4512:                  --> cleanupBackupDirectory
              --- RBK0043I: Unvollständiges Backup in /backup/@HOSTNAME@/@HOSTNAME@-rsync-backup-20250115-145350 wird gelöscht. Das kann etwas dauern. Bitte G
              eduld.
              20250115-145403 DBG 4529:                  <-- cleanupBackupDirectory
              20250115-145403 DBG 5055:              <-- cleanupBackup
              20250115-145403 DBG 5061:              --> cleanupTempFiles
              20250115-145403 DBG 5068:              <-- cleanupTempFiles
              20250115-145403 DBG 3446:              --> finalCommand
              20250115-145403 DBG 3458:              <-- finalCommand
              20250115-145403 DBG 4800:              --- Terminate now with rc 102
              --- RBK0010I: @HOSTNAME@: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:54:03 CET 2025 beendet mit Returncode 102.
              20250115-145403 DBG 4384:              --> sendEMail
              20250115-145403 DBG 4506:              <-- sendEMail
              20250115-145403 DBG 4603:              --- Masquerading some mount options
              20250115-145403 DBG 4634:              --- Masquerading home directory name
              20250115-145403 DBG 4639:              --- Masquerading hostname
              20250115-145403 DBG 4644:              --- Masquerading sensitive non local IPs
              20250115-145403 DBG 2123:              --> logFinish
              20250115-145403 DBG 2134:                  --- 102 2 0
              20250115-145403 DBG 2139:                  --- LOG_OUTPUT=3
              20250115-145403 DBG 2143:                  --- LOG_OUTPUT: 3
              20250115-145403 DBG 2170:                  --- DEST_LOGFILE: /home/pi/raspiBackup.log
              20250115-145403 DBG 2171:                  --- DEST_MSGFILE: /home/pi/raspiBackup.msg
              20250115-145403 DBG 2174:                  --- Moving Logfile: /tmp/raspiBackup.log
              20250115-145403 DBG 2177:                  --- Logfiles used: /home/pi/raspiBackup.log and /tmp/raspiBackup.msg
              20250115-145403 DBG 2180:                  --- Moving Msgfile: /tmp/raspiBackup.msg
              20250115-145403 DBG 2183:                  --- Logfiles used: /home/pi/raspiBackup.log and /home/pi/raspiBackup.msg
              20250115-145403 DBG 2190:                      *** cat /tmp/raspiBackup.logf
              20250115-145403 DBG 2205:              <-- logFinish
              20250115-145403 DBG 4704:              --> callNotificationExtension 102
              20250115-145403 DBG 2230:                  --> callExtensions notify
              20250115-145403 DBG 2297:                      --- raspiBackup_mem.sh not found - skipping
              20250115-145403 DBG 2297:                      --- raspiBackup_temp.sh not found - skipping
              20250115-145403 DBG 2297:                      --- raspiBackup_disk.sh not found - skipping
              20250115-145403 DBG 2302:                  <-- callExtensions
              20250115-145403 DBG 4713:                  --- NotificationExtension rc: 0
              20250115-145403 DBG 4718:              <-- callNotificationExtension 0
              20250115-145403 DBG 4898:          <-- cleanup
              20250115-145403 DBG 4760:          --> unLockMe
              20250115-145403 DBG 4762:          <-- unLockMe
              code_text
                Das hat ja auch nix mit dem Raspberry OS zu tun, die Freigabe auf dem NAS muss angepasst werden. Sofern möglich.
                • N
                  @thomas-braun Das sind die Stellschrauben auf dem QNAP. Es muss doch eine Möglichkeit geben, systematisch sich der Problemursache zu nähern. Mit rumprobieren (auch nach zig Std lesen) komme ich nicht weiter.
                    @norbert999
                    Zu QNAP kann ich dir nix sagen, hab ich nicht im Einsatz.
                    Aber offenbar fehlen da Berechtigungen für den user 'iobroker' und dessen UID/GID.
                    • N
                      Kannst Du mir sagen, woran Du das siehst?
                      Muss der Nutzer "iobroker" auf dem QNAP eingerichtet sein? Und wenn ja, zu welcher Gruppe muss er gehören?
                        @norbert999
                        Ja, auf dem NFS-Server muss ein User mit den gleichen UID/GID existieren wie auf dem System wo das Dateisystem gemountet werden soll. Usernames sind dabei irrelevant, die Kisten sprechen nur über IDs miteinander.
                        Die IDs findest du per
                        id
                        Bzw. per
                        sudo -u iobroker id
                        N 2 Replies Last reply Reply Quote 0
                        • N
                          @thomas-braun Danke Dir für Deine Antwort.
                          pi@raspi5:/backup $ id
                          uid=1000(pi) gid=1000(pi) groups=1000(pi),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),60(games),100(users),102(input),105(render),110(netdev),115(lpadmin),993(gpio),994(i2c),995(spi),1001(iobroker)
                          pi@raspi5:/backup $
                          D.h. ich brauche auf dem QNAP einen user mit uid=1000 und gid=1000
                          Ist das richtig?
                          sudo -u iobroker id
                          Dein alternatives Kommando hat nicht funktioniert:
                          pi@raspi5:/backup $ sudo iobroker id
                          ***For security reasons ioBroker should not be run or administrated as root.***
                          By default only a user that is member of iobroker group can execute ioBroker commands.
                          Please read the Documentation on how to set up such a user, if not done yet.
                          Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
                          Please note that this option may be disabled in the future, so please change your setup accordingly now.
                            Das würde funktionieren, wenn du es auch genauso eingegeben hättest...
                            Edit: Weitere Voraussetzungen sind übrigens ein NFS-Server in gleicher Major-Version wie auf dem Client sowie ein Dateisystem auf dem Server, das die unix-Rechte auch kennt.
                            • N
                              pi@raspi5:/backup $ sudo -u iobroker id
                              uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker),5(tty),20(dialout),29(audio),44(video),46(plugdev),108(bluetooth),993(gpio),994(i2c)
                              pi@raspi5:/backup $
                              Wer ist denn der user, der raspiBackup ausführt? ist das pi mit uid1000 oder iobroker mit 1001?
                                @norbert999
                                Der user iobroker natürlich.
                                • N
                                  D.h. ich muss auf dem NAS folgenden user haben:
                                  uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker). Richtig?
                                    @norbert999
                                    Ja die UID/GID wird durchgereicht.
                                    • N
                                      Hallo Thomas, muss Dich schon wieder nerven. Habe jetzt folgendes "erreicht":
                                      Auf raspi5 user iobroker in gruppe iobroker mit uid=1001 und gid=1001:
                                      pi@raspi5:/backup $ id iobroker
                                      uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker),5(tty),20(dialout),29(audio),44(video),46(plugdev),108(bluetooth),994(i2c),993(gpio)
                                      Auf QNAP user iobroker in gruppe iobroker mit uid=1001 und gid=1001:
                                      [/] # id iobroker
                                      uid=1001(iobroker) gid=100(everyone) groups=100(everyone),1001(iobroker)
                                      Der mount statische mount auf dem raspi ist da:
                                      pi@raspi5:/backup $ mount
                                      192.168.1.12:/share/backup_raspi5 on /backup type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=44352,mountproto=udp,local_lock=none,addr=192.168.1.12)
                                      tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1000,gid=1000)
                                      Leider geht es immer noch nicht, gleicher Fehler bei raspiBackup:
                                      --- RBK0009I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Thu 16 Jan 09:02:46 CET 2025 gestartet.
                                      --- RBK0043I: Unvollständiges Backup in /backup/raspi5/raspi5-rsync-backup-20250116-090246 wird gelöscht. Das kann etwas dauern. Bitte Geduld.
                                      --- RBK0010I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Thu 16 Jan 09:02:59 CET 2025 beendet mit Returncode 102.
                                      pi@raspi5:/backup $
                                      Hast Du noch eine Idee für mich, wie ich weiter vorgehen kann?
                                        @norbert999
                                        Welches Dateisystem ist auf dem NAS angelegt?
                                        Welche Version des NFS-Servers werkelt auf dem NAS?
                                        • N
                                          ext4 (wie kann das nochmal über ssh auf dem NAS überprüfen?)
                                          NFSv3
                                            @norbert999
                                            Auf dem Client wird NFS4 laufen. Das ist aber nicht vollständig abwärtskompatibel zu NFS3.
                                            blkid
                                            81.1k
                                            backitup nas iob nfs bookworm
                                            4780
